# # ChangeLog for c/src/ada-tests/ada.am in rtems # # Generated by Trac 1.2.1.dev0 # 04/26/24 14:32:50 Fri, 03 Jan 2003 22:51:40 GMT Joel Sherrill [0f9e7f96] * c/src/ada-tests/ChangeLog (modified) * c/src/ada-tests/ada.am (modified) * c/src/ada-tests/samples/ticker/Makefile.am (modified) * c/src/ada-tests/sptests/sp01/Makefile.am (modified) * c/src/ada-tests/sptests/sp01/config.h (modified) * c/src/ada-tests/sptests/sp04/Makefile.am (modified) * c/src/ada-tests/sptests/sp04/config.h (modified) * c/src/ada-tests/support/init.c (modified) 2003-01-03 Joel Sherrill * ada.am, ... Tue, 27 Aug 2002 06:57:46 GMT Ralf Corsepius [a846105] * c/src/ada-tests/ChangeLog (modified) * c/src/ada-tests/ada.am (modified) * c/src/ada-tests/configure.ac (modified) * c/src/ada-tests/sptests/sp09/sptest.adb (modified) * c/src/ada-tests/sptests/sp21/sptest.adb (modified) * c/src/ada-tests/tmtests/tm20/tmtest.adb (modified) 2002-08-27 Ralf Corsepius * ... Mon, 26 Aug 2002 06:12:08 GMT Ralf Corsepius [2af6056] * c/src/ada-tests/ChangeLog (modified) * c/src/ada-tests/Makefile.am (added) * c/src/ada-tests/ada.am (added) * c/src/ada-tests/configure.ac (added) * c/src/ada-tests/samples/Makefile.am (added) * c/src/ada-tests/samples/base_mp/Makefile.am (added) * c/src/ada-tests/samples/base_sp/Makefile.am (added) * c/src/ada-tests/samples/hello/Makefile.am (added) * c/src/ada-tests/samples/ticker/Makefile.am (added) * c/src/ada-tests/support/Makefile.am (added) 2002-08-26 Ralf Corsepius * ...
