# # ChangeLog for c/src/aclocal in rtems # # Generated by Trac 1.2.1.dev0 # 05/01/24 08:27:55 Tue, 27 Mar 2007 06:13:04 GMT Ralf Corsepius [d48955ea] * c/src/ChangeLog (modified) * c/src/aclocal/target.m4 (modified) 2007-03-27 Ralf Corsépius * ... Tue, 13 Mar 2007 19:45:55 GMT Joel Sherrill [307c7af1] * VERSION (modified) * aclocal/version.m4 (modified) * c/src/aclocal/version.m4 (modified) * cpukit/aclocal/version.m4 (modified) * testsuites/aclocal/version.m4 (modified) Upgrade to 4.7.99.1 Thu, 22 Feb 2007 09:12:51 GMT Ralf Corsepius [1fa64f9] * VERSION (modified) * aclocal/version.m4 (modified) * c/src/aclocal/version.m4 (modified) * cpukit/aclocal/version.m4 (modified) * testsuites/aclocal/version.m4 (modified) Revert to version 4.7.99-0 Thu, 22 Feb 2007 07:42:53 GMT Ralf Corsepius [5e854044] * VERSION (modified) * aclocal/version.m4 (modified) * c/src/aclocal/version.m4 (modified) * cpukit/aclocal/version.m4 (modified) * testsuites/aclocal/version.m4 (modified) Testing: Upgrade to 4.7.99.1 Wed, 13 Dec 2006 05:37:07 GMT Ralf Corsepius [b25d6119] * c/src/aclocal/rtems-ampolish.m4 (modified) * cpukit/aclocal/rtems-ampolish.m4 (modified) Use am_aux_dir/ampolish3. Wed, 13 Dec 2006 02:20:29 GMT Ralf Corsepius [a7529ced] * c/src/aclocal/project-root.m4 (modified) Require RTEMS_AMPOLISH. Wed, 13 Dec 2006 02:19:13 GMT Ralf Corsepius [4db0f6f3] * c/src/aclocal/rtems-top.m4 (modified) Remove RTEMS_AMPOLISH. Wed, 13 Dec 2006 02:18:46 GMT Ralf Corsepius [ff01b21f] * c/src/aclocal/rtems-ampolish.m4 (modified) Require AM_MAINTAINER_MODE. Wed, 15 Nov 2006 14:34:44 GMT Ralf Corsepius [4b02af0] * c/src/aclocal/rtems-top.m4 (modified) Add RTEMS_AMPOLISH3. Wed, 15 Nov 2006 14:34:23 GMT Ralf Corsepius [633bae4] * c/src/aclocal/rtems-ampolish.m4 (modified) Pick up ampolish3 from ac_aux_dir. Wed, 15 Nov 2006 14:34:00 GMT Ralf Corsepius [d4e28828] * c/src/aclocal/bsp-configure.m4 (modified) AC_PREREQ(2.60). Remove checks for AMPOLISH3. Wed, 15 Nov 2006 09:55:27 GMT Ralf Corsepius [e4a0c4e] * c/src/ChangeLog (modified) * c/src/aclocal/target.m4 (modified) 2006-11-15 Ralf Corsépius * ... Wed, 15 Nov 2006 06:29:07 GMT Ralf Corsepius [f8235c07] * c/src/ChangeLog (modified) * c/src/aclocal/prog-cc.m4 (modified) * c/src/configure.ac (modified) 2006-11-15 Ralf Corsépius * ... Mon, 23 Oct 2006 19:39:05 GMT Joel Sherrill [bb932d4] * c/src/ChangeLog (modified) * c/src/aclocal/rtems-cpu-subdirs.m4 (modified) 2006-10-23 Joel Sherrill * ... Wed, 18 Oct 2006 03:37:19 GMT Ralf Corsepius [9b5e72b] * ChangeLog (modified) * aclocal/rtems-top.m4 (modified) * aclocal/version.m4 (modified) * c/src/ChangeLog (modified) * c/src/aclocal/rtems-top.m4 (modified) * c/src/aclocal/version.m4 (modified) * cpukit/ChangeLog (modified) * cpukit/aclocal/rtems-top.m4 (modified) * cpukit/aclocal/version.m4 (modified) * testsuites/ChangeLog (modified) * testsuites/aclocal/rtems-top.m4 (modified) * testsuites/aclocal/version.m4 (modified) 2006-10-18 Ralf Corsépius * ... Tue, 17 Oct 2006 17:09:33 GMT Ralf Corsepius [4f5e472] * c/src/ChangeLog (modified) * c/src/aclocal/prog-ccas.m4 (modified) 2006-10-17 Ralf Corsépius * ... Tue, 17 Oct 2006 17:06:38 GMT Ralf Corsepius [d6a6cff2] * c/src/ChangeLog (modified) * c/src/aclocal/prog-cxx.m4 (modified) * testsuites/ChangeLog (modified) * testsuites/aclocal/prog-cxx.m4 (modified) 2006-10-17 Ralf Corsépius * ... Tue, 17 Oct 2006 15:49:31 GMT Ralf Corsepius [2e28876] * ChangeLog (modified) * aclocal/version.m4 (modified) * c/src/ChangeLog (modified) * c/src/aclocal/version.m4 (modified) * cpukit/ChangeLog (modified) * cpukit/aclocal/version.m4 (modified) * testsuites/ChangeLog (modified) * testsuites/aclocal/version.m4 (modified) 2006-10-17 Ralf Corsépius * ... Wed, 09 Aug 2006 21:04:13 GMT Joel Sherrill [28b8d3af] * c/src/ChangeLog (modified) * c/src/aclocal/rtems-cpu-subdirs.m4 (modified) 2006-08-09 Kolja Waschk * ... Thu, 29 Jun 2006 08:55:00 GMT Ralf Corsepius [82d11fc5] * c/src/ChangeLog (modified) * c/src/aclocal/rtems-ampolish.m4 (modified) * c/src/ampolish3 (added) 2006-06-28 Ralf Corsépius * ... Tue, 16 May 2006 14:26:57 GMT Ralf Corsepius [068cf700] * c/src/ChangeLog (modified) * c/src/aclocal/rtems-ampolish.m4 (added) * c/src/configure.ac (modified) * cpukit/ChangeLog (modified) * cpukit/aclocal/rtems-ampolish.m4 (added) * cpukit/configure.ac (modified) 2006-05-16 Ralf Corsépius * ... Tue, 18 Apr 2006 21:47:28 GMT Joel Sherrill [c5a67176] * ChangeLog (modified) * aclocal/version.m4 (modified) * c/src/ChangeLog (modified) * c/src/aclocal/version.m4 (modified) * cpukit/ChangeLog (modified) * cpukit/aclocal/version.m4 (modified) * testsuites/ChangeLog (modified) * testsuites/aclocal/version.m4 (modified) 2006-04-18 Joel Sherrill * ... Wed, 11 Jan 2006 04:43:46 GMT Ralf Corsepius [cce0948] * c/src/ChangeLog (modified) * c/src/aclocal/bsp-configure.m4 (modified) 2006-01-11 Ralf Corsepius * ... Sun, 20 Nov 2005 08:10:58 GMT Ralf Corsepius [546c41d0] * c/src/aclocal/prog-cc.m4 (modified) Remove RTEMS_USE_GCC. Add RTEMS_RELLDFLAGS. Tue, 08 Nov 2005 14:28:49 GMT Ralf Corsepius [1343b11d] * c/src/aclocal/env-rtemsbsp.m4 (modified) Remove RTEMS_BSP_SPECS. Remove GCC_SPECS. Tue, 08 Nov 2005 14:27:37 GMT Ralf Corsepius [1eeac702] * c/src/aclocal/prog-cc.m4 (modified) Add GCCSPECS Fri, 16 Sep 2005 07:51:54 GMT Ralf Corsepius [88b6d8d9] * c/src/ChangeLog (modified) * c/src/aclocal/bspopts.m4 (modified) 2005-09-16 Ralf Corsepius * ... Fri, 02 Sep 2005 14:50:05 GMT Joel Sherrill [95f9447] * ChangeLog (modified) * aclocal/version.m4 (modified) * c/src/ChangeLog (modified) * c/src/aclocal/version.m4 (modified) * cpukit/ChangeLog (modified) * cpukit/aclocal/version.m4 (modified) * testsuites/ChangeLog (modified) * testsuites/aclocal/version.m4 (modified) 2005-09-02 Joel Sherrill * ... Wed, 25 May 2005 12:20:58 GMT Ralf Corsepius [d7610229] * c/src/ChangeLog (modified) * c/src/aclocal/check-rdbg.m4 (modified) * c/src/configure.ac (modified) 2005-05-25 Ralf Corsepius * ... Wed, 16 Feb 2005 10:05:22 GMT Ralf Corsepius [a3f91c6] * c/src/ChangeLog (modified) * c/src/aclocal/ppc.m4 (modified) 2005-02-16 Ralf Corsepius * ... Sat, 12 Feb 2005 03:37:18 GMT Ralf Corsepius [ec899eaf] * c/src/ChangeLog (modified) * c/src/aclocal/ppc.m4 (modified) 2005-02-11 Ralf Corsepius * ... Tue, 08 Feb 2005 02:54:07 GMT Ralf Corsepius [ea68ed5] * c/src/ChangeLog (modified) * c/src/aclocal/prog-cc.m4 (modified) 2005-02-08 Ralf Corsepius * ... Tue, 08 Feb 2005 02:50:06 GMT Ralf Corsepius [0598fb8] * c/src/ChangeLog (modified) * c/src/aclocal/rtems-top.m4 (modified) * cpukit/ChangeLog (modified) * cpukit/aclocal/rtems-top.m4 (modified) 2005-02-08 Ralf Corsepius * ... Thu, 06 Jan 2005 10:45:41 GMT Ralf Corsepius [6c2b5324] * c/src/ChangeLog (modified) * c/src/aclocal/prog-cxx.m4 (modified) * c/src/configure.ac (modified) 2005-01-06 Ralf Corsepius * ... Wed, 05 Jan 2005 17:52:33 GMT Ralf Corsepius [ea3f559] * c/src/ChangeLog (modified) * c/src/aclocal/env-rtemsbsp.m4 (modified) * c/src/aclocal/prog-cc.m4 (modified) * c/src/aclocal/prog-ccas.m4 (modified) * c/src/aclocal/rtems-flags.m4 (deleted) * c/src/automake/compile.am (modified) * c/src/configure.ac (modified) 2005-01-05 Ralf Corsepius * ... Mon, 22 Nov 2004 09:39:12 GMT Ralf Corsepius [f4857b21] * c/src/ChangeLog (modified) * c/src/aclocal/enable-itron.m4 (deleted) 2004-11-22 Ralf Corsepius * ... Fri, 22 Oct 2004 14:47:07 GMT Ralf Corsepius [ba5288d] * ChangeLog (modified) * aclocal/check-custom-bsp.m4 (modified) * c/src/ChangeLog (modified) * c/src/aclocal/check-custom-bsp.m4 (modified) 2004-10-22 Ralf Corsepius * ... Tue, 19 Oct 2004 08:08:22 GMT Ralf Corsepius [41ed282] * c/src/ChangeLog (modified) * c/src/aclocal/enable-bare.m4 (deleted) * c/src/aclocal/env-rtemsbsp.m4 (modified) * c/src/configure.ac (modified) 2004-10-19 Ralf Corsepius * ... Wed, 29 Sep 2004 20:36:20 GMT Joel Sherrill [7452b855] * c/src/ChangeLog (modified) * c/src/aclocal/rtems-cpu-subdirs.m4 (modified) * c/src/libchip/shmdr/shm_driver.h (modified) * c/src/libnetworking/pppd/utils.c (modified) * cpukit/pppd/utils.c (modified) 2004-09-29 Joel Sherrill * ... Fri, 24 Sep 2004 04:43:53 GMT Ralf Corsepius [f27c25f] * c/src/ChangeLog (modified) * c/src/aclocal/rtems-cpu-subdirs.m4 (modified) 2004-09-24 Ralf Corsepius * ... Tue, 21 Sep 2004 14:30:53 GMT Ralf Corsepius [d71ab7fd] * c/src/ChangeLog (modified) * c/src/aclocal/gcc-weak.m4 (added) * c/src/configure.ac (modified) * cpukit/ChangeLog (modified) * cpukit/aclocal/gcc-weak.m4 (added) * cpukit/configure.ac (modified) 2004-09-21 Ralf Corsepius * ... Wed, 18 Aug 2004 01:24:35 GMT Ralf Corsepius [0ad53a9] * c/src/ChangeLog (modified) * c/src/aclocal/ppc.m4 (modified) * c/src/aclocal/target.m4 (modified) 2004-08-17 Ralf Corsepius * ... Wed, 28 Jul 2004 15:32:02 GMT Joel Sherrill [82fe9c1] * ChangeLog (modified) * aclocal/version.m4 (modified) * c/src/ChangeLog (modified) * c/src/aclocal/version.m4 (modified) * cpukit/ChangeLog (modified) * cpukit/aclocal/version.m4 (modified) * testsuites/ChangeLog (modified) * testsuites/aclocal/version.m4 (modified) 2004-07-28 * aclocal/version.m4: Updated to rtems-4.6.99.1. Mon, 10 May 2004 04:24:50 GMT Ralf Corsepius [1eaf0fda] * c/src/ChangeLog (modified) * c/src/aclocal/check-cxx.m4 (modified) 2004-05-10 Ralf Corsepius * ... Wed, 14 Apr 2004 15:18:56 GMT Ralf Corsepius [61c78ab] * c/src/ChangeLog (modified) * c/src/aclocal/rtems-top.m4 (modified) 2004-04-14 Ralf Corsepius * ... Wed, 14 Apr 2004 13:27:39 GMT Ralf Corsepius [0d0528d3] * c/src/ChangeLog (modified) * c/src/aclocal/rtems-top.m4 (modified) * testsuites/ChangeLog (modified) * testsuites/aclocal/rtems-top.m4 (modified) 2004-04-14 Ralf Corsepius * ... Fri, 26 Mar 2004 03:57:24 GMT Ralf Corsepius [ef02bc1] * c/src/ChangeLog (modified) * c/src/aclocal/rtems-top.m4 (modified) 2004-03-26 Ralf Corsepius * ... Tue, 09 Mar 2004 09:53:08 GMT Ralf Corsepius [5569cec] * c/src/ChangeLog (modified) * c/src/aclocal/canonicalize-tools.m4 (modified) 2004-03-09 Ralf Corsepius * ... Fri, 05 Mar 2004 18:28:38 GMT Joel Sherrill [e73c249] * c/src/ChangeLog (modified) * c/src/aclocal/canonicalize-tools.m4 (modified) 2004-03-04 Joel Sherrill * ... Fri, 20 Feb 2004 01:22:04 GMT Ralf Corsepius [789694a1] * c/src/ChangeLog (modified) * c/src/acinclude.m4 (modified) * c/src/aclocal/rtems-top.m4 (modified) * c/src/configure.ac (modified) 2004-02-20 Ralf Corsepius * ... Thu, 19 Feb 2004 06:08:15 GMT Ralf Corsepius [5e5cf07] * c/src/ChangeLog (modified) * c/src/aclocal/check-multiprocessing.m4 (modified) * c/src/aclocal/env-rtemsbsp.m4 (modified) * c/src/aclocal/project-root.m4 (modified) * c/src/libchip/Makefile.am (modified) * c/src/librdbg/Makefile.am (modified) * c/src/optman/Makefile.am (modified) * c/src/wrapup/Makefile.am (modified) 2004-02-19 Ralf Corsepius * ... Sat, 14 Feb 2004 18:18:04 GMT Ralf Corsepius [c9251c7] * c/src/ChangeLog (modified) * c/src/aclocal/check-rdbg.m4 (modified) 2004-02-14 Ralf Corsepius * ... Sat, 14 Feb 2004 04:55:06 GMT Ralf Corsepius [dcf277c] * c/src/ChangeLog (modified) * c/src/aclocal/canonicalize-tools.m4 (modified) 2004-02-14 Ralf Corsepius * ... Thu, 12 Feb 2004 16:56:47 GMT Ralf Corsepius [3025a4a] * c/src/ChangeLog (modified) * c/src/aclocal/bsp-configure.m4 (modified) * c/src/aclocal/bspopts.m4 (modified) * c/src/aclocal/check-custom-bsp.m4 (modified) * c/src/aclocal/enable-rtemsbsp.m4 (modified) 2004-02-12 Ralf Corsepius * ... Thu, 12 Feb 2004 14:41:32 GMT Ralf Corsepius [31ffd58] * c/src/ChangeLog (modified) * c/src/aclocal/version.m4 (modified) * cpukit/ChangeLog (modified) * cpukit/aclocal/version.m4 (modified) * testsuites/ChangeLog (modified) * testsuites/aclocal/version.m4 (modified) 2004-02-12 Ralf Corsepius * ... Mon, 02 Feb 2004 18:13:10 GMT Ralf Corsepius [477180fa] * c/src/ChangeLog (modified) * c/src/aclocal/check-multiprocessing.m4 (modified) * c/src/aclocal/enable-cxx.m4 (modified) * c/src/aclocal/enable-itron.m4 (modified) * c/src/aclocal/enable-multiprocessing.m4 (modified) * c/src/aclocal/enable-networking.m4 (modified) * c/src/aclocal/enable-posix.m4 (modified) * c/src/aclocal/enable-rdbg.m4 (modified) * c/src/aclocal/multilib.m4 (modified) * c/src/configure.ac (modified) * c/src/wrapup/Makefile.am (modified) 2004-02-02 Ralf Corsepius * ... Wed, 21 Jan 2004 15:47:08 GMT Ralf Corsepius [1734d37] * c/src/ChangeLog (modified) * c/src/aclocal/enable-bare.m4 (modified) * c/src/wrapup/Makefile.am (modified) 2004-01-21 Ralf Corsepius * ... Sat, 17 Jan 2004 02:40:23 GMT Ralf Corsepius [208aa86e] * c/src/ChangeLog (modified) * c/src/aclocal/rtems-top.m4 (modified) * c/src/automake/compile.am (modified) 2004-01-17 Ralf Corsepius * ... Wed, 07 Jan 2004 20:39:46 GMT Joel Sherrill [6416628] * c/src/ChangeLog (modified) * c/src/aclocal/rtems-cpu-subdirs.m4 (modified) * testsuites/ChangeLog (modified) * testsuites/aclocal/rtems-cpu-subdirs.m4 (modified) 2004-01-07 Joel Sherrill * ... Wed, 17 Dec 2003 18:55:59 GMT Joel Sherrill [2b2353d] * c/src/ChangeLog (modified) * c/src/aclocal/version.m4 (modified) 2003-12-17 * c/src/aclocal/version.m4: Updated to ... Sat, 13 Dec 2003 05:25:41 GMT Ralf Corsepius [b946613] * c/src/ChangeLog (modified) * c/src/aclocal/env-rtemsbsp.m4 (modified) * c/src/wrapup/Makefile.am (modified) 2003-12-13 Ralf Corsepius * ... Fri, 12 Dec 2003 12:36:19 GMT Ralf Corsepius [14348a00] * c/src/ChangeLog (modified) * c/src/aclocal/env-rtemsbsp.m4 (modified) * c/src/aclocal/lead-dot.m4 (deleted) * c/src/automake/compile.am (modified) * c/src/automake/lib.am (modified) 2003-12-12 Ralf Corsepius * ... Thu, 11 Dec 2003 12:43:55 GMT Ralf Corsepius [0e31ed7] * c/src/ChangeLog (modified) * c/src/aclocal/env-rtemsbsp.m4 (modified) * c/src/automake/lib.am (modified) * c/src/wrapup/Makefile.am (modified) 2003-12-11 Ralf Corsepius * ... Mon, 01 Dec 2003 06:29:27 GMT Ralf Corsepius [82bdc057] * c/src/ChangeLog (modified) * c/src/aclocal/lead-dot.m4 (added) * c/src/aclocal/rtems-top.m4 (modified) 2003-12-01 Ralf Corsepius * ... Wed, 26 Nov 2003 06:18:03 GMT Ralf Corsepius [9550125e] * c/src/ChangeLog (modified) * c/src/aclocal/bsp-arg-enable.m4 (modified) * c/src/aclocal/canonical-target-name.m4 (modified) * c/src/aclocal/canonicalize-tools.m4 (modified) * c/src/aclocal/check-custom-bsp.m4 (modified) * c/src/aclocal/check-posix.m4 (modified) * c/src/aclocal/check-rdbg.m4 (modified) * c/src/aclocal/check-tool.m4 (modified) * c/src/aclocal/config-subdirs.m4 (modified) * c/src/aclocal/enable-bare.m4 (modified) * c/src/aclocal/enable-cxx.m4 (modified) * c/src/aclocal/enable-itron.m4 (modified) * c/src/aclocal/enable-multiprocessing.m4 (modified) * c/src/aclocal/enable-networking.m4 (modified) * c/src/aclocal/enable-posix.m4 (modified) * c/src/aclocal/enable-rdbg.m4 (modified) * c/src/aclocal/enable-rtemsbsp.m4 (modified) * c/src/aclocal/env-rtemsbsp.m4 (modified) * c/src/aclocal/gcc-isystem.m4 (modified) * c/src/aclocal/gcc-pipe.m4 (modified) * c/src/aclocal/gcc-specs.m4 (modified) * c/src/aclocal/i386-gas-code16.m4 (modified) * c/src/aclocal/multilib.m4 (modified) * c/src/aclocal/path-ksh.m4 (modified) * c/src/aclocal/prog-cc.m4 (modified) * c/src/aclocal/prog-cxx.m4 (modified) * c/src/aclocal/project-root.m4 (modified) * c/src/aclocal/rtems-top.m4 (modified) * c/src/aclocal/target.m4 (modified) * c/src/aclocal/tool-paths.m4 (modified) 2003-11-26 Ralf Corsepius * ... Wed, 22 Oct 2003 12:40:47 GMT Ralf Corsepius [4f21a587] * c/src/ChangeLog (modified) * c/src/aclocal/bsp-configure.m4 (modified) 2003-10-22 Ralf Corsepius * ... Wed, 22 Oct 2003 11:24:48 GMT Ralf Corsepius [69decf3] * c/src/ChangeLog (modified) * c/src/aclocal/canonical-host.m4 (deleted) * c/src/aclocal/canonical-target-name.m4 (modified) 2003-10-22 Ralf Corsepius * ... Tue, 21 Oct 2003 11:42:53 GMT Ralf Corsepius [51d35b2] * c/src/ChangeLog (modified) * c/src/aclocal/check-cpu.m4 (deleted) * c/src/configure.ac (modified) 2003-10-21 Ralf Corsepius * ... Tue, 21 Oct 2003 11:28:41 GMT Ralf Corsepius [3993b6f7] * c/src/ChangeLog (modified) * c/src/aclocal/canonical-target-name.m4 (modified) * c/src/aclocal/check-cxx.m4 (modified) * c/src/aclocal/check-multiprocessing.m4 (modified) * c/src/aclocal/check-networking.m4 (modified) * c/src/aclocal/check-posix.m4 (modified) * c/src/aclocal/check-rdbg.m4 (modified) 2003-10-21 Ralf Corsepius * ... Mon, 20 Oct 2003 13:43:23 GMT Ralf Corsepius [2eaee845] * c/src/ChangeLog (modified) * c/src/aclocal/bsp-alias.m4 (deleted) * c/src/aclocal/check-multiprocessing.m4 (modified) 2003-10-20 Ralf Corsepius * ... Fri, 17 Oct 2003 16:43:09 GMT Ralf Corsepius [8857d525] * c/src/ChangeLog (modified) * c/src/aclocal/path-perl.m4 (deleted) 2003-10-17 Ralf Corsepius * ... Fri, 29 Aug 2003 00:06:15 GMT Ralf Corsepius [ac3786b] * aclocal/rtems-top.m4 (modified) * c/src/ChangeLog (modified) * c/src/aclocal/rtems-top.m4 (modified) * c/src/tests/ChangeLog (modified) * c/src/tests/aclocal/rtems-top.m4 (modified) * cpukit/ChangeLog (modified) * cpukit/aclocal/rtems-top.m4 (modified) * testsuites/ChangeLog (modified) * testsuites/aclocal/rtems-top.m4 (modified) 2003-08-28 Ralf Corsepius * ... Mon, 18 Aug 2003 12:00:25 GMT Ralf Corsepius [161f2651] * c/src/ChangeLog (modified) * c/src/aclocal/check-itron.m4 (deleted) * c/src/aclocal/enable-inlines.m4 (deleted) 2003-08-18 Ralf Corsepius * ... Mon, 18 Aug 2003 06:35:41 GMT Ralf Corsepius [867ab080] * c/src/ChangeLog (modified) * c/src/aclocal/bsp-alias.m4 (added) * c/src/aclocal/bsp-arg-enable.m4 (added) * c/src/aclocal/bsp-configure.m4 (added) * c/src/aclocal/bspopts.m4 (added) * c/src/aclocal/canonical-host.m4 (added) * c/src/aclocal/canonical-target-name.m4 (added) * c/src/aclocal/canonicalize-tools.m4 (added) * c/src/aclocal/check-cpu.m4 (added) * c/src/aclocal/check-custom-bsp.m4 (added) * c/src/aclocal/check-cxx.m4 (added) * c/src/aclocal/check-itron.m4 (added) * c/src/aclocal/check-multiprocessing.m4 (added) * c/src/aclocal/check-networking.m4 (added) * c/src/aclocal/check-posix.m4 (added) * c/src/aclocal/check-rdbg.m4 (added) * c/src/aclocal/check-tool.m4 (added) * c/src/aclocal/config-subdirs.m4 (added) * c/src/aclocal/enable-bare.m4 (added) * c/src/aclocal/enable-cxx.m4 (added) * c/src/aclocal/enable-inlines.m4 (added) * c/src/aclocal/enable-itron.m4 (added) * c/src/aclocal/enable-multiprocessing.m4 (added) * c/src/aclocal/enable-networking.m4 (added) * c/src/aclocal/enable-posix.m4 (added) * c/src/aclocal/enable-rdbg.m4 (added) * c/src/aclocal/enable-rtemsbsp.m4 (added) * c/src/aclocal/env-rtemsbsp.m4 (added) * c/src/aclocal/gcc-isystem.m4 (added) * c/src/aclocal/gcc-pipe.m4 (added) * c/src/aclocal/gcc-specs.m4 (added) * c/src/aclocal/i386-gas-code16.m4 (added) * c/src/aclocal/multilib.m4 (added) * c/src/aclocal/path-ksh.m4 (added) * c/src/aclocal/path-perl.m4 (added) * c/src/aclocal/ppc.m4 (added) * c/src/aclocal/prog-cc.m4 (added) * c/src/aclocal/prog-ccas.m4 (added) * c/src/aclocal/prog-cxx.m4 (added) * c/src/aclocal/project-root.m4 (added) * c/src/aclocal/quoting.m4 (added) * c/src/aclocal/rtems-cpu-subdirs.m4 (added) * c/src/aclocal/rtems-flags.m4 (added) * c/src/aclocal/rtems-top.m4 (added) * c/src/aclocal/target.m4 (added) * c/src/aclocal/tool-paths.m4 (added) * c/src/aclocal/version.m4 (added) 2003-08-18 Ralf Corsepius * ...
