# # ChangeLog for c/src/ChangeLog in rtems # # Generated by Trac 1.2.1.dev0 # 04/19/24 23:24:49 Tue, 15 Sep 2009 14:48:00 GMT Ralf Corsepius [e5e9f1a] * c/src/ChangeLog (modified) * c/src/aclocal/bsp-configure.m4 (modified) 2009-09-15 Ralf Corsépius * ... Thu, 20 Aug 2009 23:56:17 GMT Joel Sherrill [b580e71] * c/src/ChangeLog (modified) * c/src/aclocal/check-networking.m4 (modified) 2009-08-20 Joel Sherrill * ... Mon, 10 Aug 2009 16:53:30 GMT Joel Sherrill [439aade] * c/src/ChangeLog (modified) * c/src/libchip/network/elnk.c (modified) 2009-08-10 Joel Sherrill * ... Mon, 03 Aug 2009 14:23:29 GMT Joel Sherrill [354fb2e] * c/src/ChangeLog (modified) * c/src/libchip/shmdr/shm_driver.h (modified) 2009-08-03 Roger Dahlkvist * ... Wed, 22 Jul 2009 16:00:55 GMT Joel Sherrill [0d3b27cd] * c/src/ChangeLog (modified) * c/src/libchip/ide/ata.c (modified) 2009-07-22 Joel Sherrill * ... Fri, 17 Jul 2009 13:53:24 GMT Thomas Doerfler [ec5d4505] * c/src/ChangeLog (modified) * c/src/libchip/serial/ns16550.c (modified) * c/src/libchip/serial/ns16550_p.h (modified) code cleanup Thu, 16 Jul 2009 23:12:55 GMT Joel Sherrill [8785e906] * c/src/ChangeLog (modified) * c/src/aclocal/bsp-bootcard-options.m4 (modified) * c/src/aclocal/bsp-bspcleanup-options.m4 (added) 2009-07-16 Joel Sherrill * ... Fri, 12 Jun 2009 17:40:04 GMT Joel Sherrill [84d7499] * c/src/ChangeLog (modified) * c/src/libchip/i2c/spi-sd-card.c (modified) * c/src/libchip/ide/ata.c (modified) 2009-06-12 Joel Sherrill * ... Sat, 30 May 2009 04:48:30 GMT Chris Johns [b30c618] * c/src/ChangeLog (modified) * c/src/libchip/ide/ata.c (modified) 2009-05-30 Chris Johns * ... Mon, 11 May 2009 20:10:25 GMT Joel Sherrill [79269f6e] * c/src/ChangeLog (modified) * c/src/libchip/network/i82586.c (modified) 2009-05-11 Joel Sherrill * ... Wed, 06 May 2009 16:37:32 GMT Joel Sherrill [80ab5f4] * c/src/ChangeLog (modified) * c/src/libchip/network/if_dc.c (modified) 2009-05-06 Joel Sherrill * ... Mon, 04 May 2009 00:53:45 GMT Joel Sherrill [9c2eaca] * c/src/ChangeLog (modified) * c/src/libchip/rtc/ds1375.c (modified) * c/src/libchip/rtc/mc146818a.c (modified) 2009-05-03 Joel Sherrill * ... Wed, 29 Apr 2009 08:36:45 GMT Chris Johns [92c70b9] * c/src/ChangeLog (modified) * c/src/libchip/ide/ata.c (modified) * c/src/libchip/ide/ide_controller.c (modified) 2009-04-29 Chris Johns * ... Thu, 12 Mar 2009 15:42:51 GMT Joel Sherrill [a33af586] * c/src/ChangeLog (modified) * c/src/libchip/i2c/spi-memdrv.c (modified) 2009-03-12 Daniel Hellstrom PR ... Fri, 27 Feb 2009 11:10:46 GMT Thomas Doerfler [ca5bcd8] * c/src/ChangeLog (modified) * c/src/libchip/i2c/spi-sd-card.c (modified) PR 1356 * libchip/i2c/spi-sd-card.c: Added support for high ... Thu, 19 Feb 2009 19:25:53 GMT Joel Sherrill [66913da2] * c/src/ChangeLog (modified) * c/src/libchip/network/dec21140.c (modified) * c/src/libchip/network/elnk.c (modified) 2009-02-19 Joel Sherrill * ... Tue, 03 Feb 2009 09:13:41 GMT Ralf Corsepius [43892800] * c/src/ChangeLog (modified) * c/src/aclocal/bspopts.m4 (modified) 2009-02-03 Ralf Corsépius * ... Wed, 21 Jan 2009 18:08:32 GMT Joel Sherrill [4c18d8c] * c/src/ChangeLog (modified) * c/src/libchip/i2c/spi-sd-card.c (modified) * c/src/libchip/i2c/spi-sd-card.h (modified) 2009-01-21 Sebastian Huber ... Mon, 05 Jan 2009 19:49:23 GMT Joel Sherrill [a26d515] * c/src/ChangeLog (modified) * c/src/libchip/serial/ns16550.c (modified) 2009-01-05 Joel Sherrill * ... Tue, 23 Dec 2008 08:31:47 GMT Thomas Doerfler [9814d2dd] * c/src/ChangeLog (modified) * c/src/libchip/i2c/spi-sd-card.c (modified) * c/src/libchip/i2c/spi-sd-card.h (modified) spi-sd-card.c, spi-sd-card.h: removed high-level driver IF, added ... Mon, 22 Dec 2008 04:29:33 GMT Ralf Corsepius [26cc5909] * c/src/ChangeLog (modified) 2008-12-22 Ralf Corsépius * ... Mon, 22 Dec 2008 03:45:47 GMT Ralf Corsepius [b503274b] * c/src/ChangeLog (modified) 2008-12-22 Ralf Corsépius * ... Mon, 22 Dec 2008 03:43:14 GMT Ralf Corsepius [44415fd] * c/src/ChangeLog (modified) 2008-12-22 Ralf Corsépius * ... Thu, 18 Dec 2008 21:10:04 GMT Joel Sherrill [0f4ad570] * c/src/ChangeLog (modified) * c/src/lib/libbsp/sparc/shared/bspgetworkarea.c (modified) * c/src/libchip/serial/ns16550_p.h (modified) 2008-12-18 Joel Sherrill * ... Thu, 18 Dec 2008 17:15:51 GMT Joel Sherrill [534c893] * c/src/ChangeLog (modified) * c/src/libchip/shmdr/dump.c (modified) * c/src/libchip/shmdr/init.c (modified) * c/src/libchip/shmdr/send.c (modified) * c/src/libchip/shmdr/shm_driver.h (modified) 2008-12-18 Joel Sherrill * ... Wed, 17 Dec 2008 22:47:55 GMT Joel Sherrill [1fae1c6b] * c/src/ChangeLog (modified) * c/src/optman/sapi/no-ext.c (modified) * c/src/optman/sapi/no-io.c (modified) 2008-12-17 Joel Sherrill * ... Wed, 17 Dec 2008 20:25:43 GMT Joel Sherrill [45c4499e] * c/src/ChangeLog (modified) * c/src/optman/rtems/no-barrier.c (modified) * c/src/optman/rtems/no-dpmem.c (modified) * c/src/optman/rtems/no-event.c (modified) * c/src/optman/rtems/no-mp.c (modified) * c/src/optman/rtems/no-msg.c (modified) * c/src/optman/rtems/no-part.c (modified) * c/src/optman/rtems/no-region.c (modified) * c/src/optman/rtems/no-rtmon.c (modified) * c/src/optman/rtems/no-sem.c (modified) * c/src/optman/rtems/no-signal.c (modified) * c/src/optman/rtems/no-timer.c (modified) 2008-12-17 Joel Sherrill * ... Wed, 17 Dec 2008 12:48:04 GMT Ralf Corsepius [69be08ee] * c/src/ChangeLog (modified) * c/src/libchip/serial/ns16550.c (modified) 2008-12-17 Ralf Corsépius * ... Wed, 17 Dec 2008 12:46:27 GMT Ralf Corsepius [f7cb3cf] * c/src/ChangeLog (modified) Fix broken changelog entry. Tue, 16 Dec 2008 21:58:18 GMT Joel Sherrill [b0f45d8] * c/src/ChangeLog (modified) * c/src/libchip/network/i82586.c (modified) * c/src/libchip/network/smc91111config.h (modified) 2008-12-16 Joel Sherrill * ... Wed, 10 Dec 2008 23:31:21 GMT Ralf Corsepius [4e18296] * c/src/ChangeLog (modified) 2008-12-10 Ralf Corsépius * ... Thu, 04 Dec 2008 22:57:10 GMT Joel Sherrill [3c12db5f] * c/src/ChangeLog (modified) * c/src/aclocal/rtems-cpu-subdirs.m4 (modified) 2008-12-04 Jukka Pietarinen ... Tue, 18 Nov 2008 09:20:18 GMT Thomas Doerfler [9151ec6] * c/src/ChangeLog (modified) * c/src/libchip/serial/ns16550.c (modified) libchip/serial/ns16550.c: Transmit the character in the polled write ... Fri, 10 Oct 2008 15:52:41 GMT Thomas Doerfler [f049983] * c/src/ChangeLog (modified) * c/src/libchip/i2c/spi-sd-card.c (modified) Update for status-checks.h changes. Thu, 02 Oct 2008 21:41:53 GMT Joel Sherrill [e2e736b] * c/src/ChangeLog (modified) * c/src/aclocal/rtems-cpu-subdirs.m4 (modified) 2008-10-02 Joel Sherrill * ... Tue, 30 Sep 2008 10:02:59 GMT Thomas Doerfler [a12796f3] * c/src/ChangeLog (modified) *** empty log message *** Wed, 24 Sep 2008 13:44:04 GMT Joel Sherrill [13b8c65] * c/src/ChangeLog (modified) * c/src/aclocal/bsp-bootcard-options.m4 (modified) 2008-09-24 Joel Sherrill * ... Wed, 24 Sep 2008 09:29:24 GMT Ralf Corsepius [c736dcf] * c/src/ChangeLog (modified) * c/src/aclocal/bsp-bootcard-options.m4 (modified) 2008-09-24 Ralf Corsépius * ... Tue, 23 Sep 2008 19:50:37 GMT Joel Sherrill [12d02b8] * c/src/ChangeLog (modified) * c/src/aclocal/bsp-bootcard-options.m4 (added) * c/src/aclocal/bsp-bootcards-handles-ram-allocation.m4 (deleted) 2008-09-23 Joel Sherrill * ... Tue, 23 Sep 2008 14:07:19 GMT Joel Sherrill [8c0cab0] * c/src/ChangeLog (modified) * c/src/libchip/serial/ns16550.c (modified) 2008-09-23 Sebastian Huber ... Mon, 22 Sep 2008 21:51:15 GMT Joel Sherrill [95ef82c] * c/src/ChangeLog (modified) * c/src/libchip/serial/ns16550.c (modified) 2008-09-22 Joel Sherrill * ... Mon, 22 Sep 2008 17:23:14 GMT Joel Sherrill [0fbd231] * c/src/ChangeLog (modified) * c/src/libchip/serial/ns16550.c (modified) 2008-09-22 Joel Sherrill * ... Mon, 22 Sep 2008 17:02:16 GMT Joel Sherrill [00a23585] * c/src/ChangeLog (modified) * c/src/libchip/serial/ns16550.c (modified) 2008-09-22 Joel Sherrill * ... Mon, 22 Sep 2008 15:42:54 GMT Joel Sherrill [fc9cbcf3] * c/src/ChangeLog (modified) * c/src/libchip/serial/ns16550.c (modified) 2008-09-22 Joel Sherrill * ... Mon, 22 Sep 2008 14:14:09 GMT Ralf Corsepius [f8f2e41] * ChangeLog (modified) * aclocal/version.m4 (modified) * c/src/ChangeLog (modified) * c/src/aclocal/version.m4 (modified) * testsuites/ChangeLog (modified) * testsuites/aclocal/version.m4 (modified) 2008-09-22 Ralf Corsépius * ... Mon, 22 Sep 2008 11:49:50 GMT Thomas Doerfler [8dcfc0a] * c/src/ChangeLog (modified) * c/src/lib/libbsp/arm/lpc24xx/startup/linkcmds (added) * c/src/lib/libbsp/arm/shared/include/linker-symbols.h (added) * c/src/lib/libbsp/arm/shared/include/start.h (added) * c/src/lib/libbsp/arm/shared/start/start.S (added) * c/src/lib/libbsp/arm/shared/startup/linkcmds.base (added) *** empty log message *** Sat, 20 Sep 2008 22:20:14 GMT Joel Sherrill [0b6ca8aa] * c/src/ChangeLog (modified) * c/src/libchip/network/dec21140.c (modified) * c/src/libchip/network/elnk.c (modified) 2008-09-20 Joel Sherrill * ... Fri, 19 Sep 2008 19:29:50 GMT Joel Sherrill [4c9784e8] * c/src/ChangeLog (modified) * c/src/libchip/network/dec21140.c (modified) * c/src/libchip/network/elnk.c (modified) * c/src/libchip/network/if_dc.c (modified) 2008-09-19 Joel Sherrill * ... Wed, 17 Sep 2008 16:22:40 GMT Joel Sherrill [35150aa] * c/src/ChangeLog (modified) * c/src/optman/Makefile.am (modified) * c/src/optman/no-console.c (deleted) * c/src/optman/no-filesystem.c (deleted) * c/src/optman/no-libio.c (deleted) * c/src/optman/preinstall.am (modified) 2008-09-17 Miao Yan * ... Mon, 08 Sep 2008 06:57:28 GMT Ralf Corsepius [ec07659] * c/src/ChangeLog (modified) 2008-09-08 Ralf Corsépius * ... Sun, 07 Sep 2008 03:44:23 GMT Ralf Corsepius [b4d0eec3] * c/src/ChangeLog (modified) 2008-09-07 Ralf Corsépius * ... Sun, 07 Sep 2008 03:42:23 GMT Ralf Corsepius [d5150397] * c/src/ChangeLog (modified) 2008-09-07 Ralf Corsépius * ... Sun, 07 Sep 2008 03:38:46 GMT Ralf Corsepius [33c36c81] * c/src/ChangeLog (modified) 2008-09-07 Ralf Corsépius * ... Sun, 07 Sep 2008 03:35:43 GMT Ralf Corsepius [2c0b598] * c/src/ChangeLog (modified) 2008-09-07 Ralf Corsépius * ... Sun, 07 Sep 2008 03:32:13 GMT Ralf Corsepius [e7672d6] * c/src/ChangeLog (modified) 2008-09-07 Ralf Corsépius * ... Sun, 07 Sep 2008 03:29:55 GMT Ralf Corsepius [90d21b36] * c/src/ChangeLog (modified) 2008-09-07 Ralf Corsépius * ... Sun, 07 Sep 2008 03:18:40 GMT Ralf Corsepius [686f66d] * c/src/ChangeLog (modified) 2008-09-07 Ralf Corsépius * ... Fri, 05 Sep 2008 14:48:37 GMT Joel Sherrill [5c980d0] * c/src/ChangeLog (modified) * c/src/libchip/Makefile.am (modified) * c/src/libchip/shmdr/init.c (modified) * c/src/libchip/shmdr/mpisr.c (modified) * c/src/libchip/shmdr/poll.c (modified) * c/src/libchip/shmdr/setckvec.c (deleted) * c/src/libchip/shmdr/shm_driver.h (modified) 2008-09-05 Joel Sherrill * ... Sat, 30 Aug 2008 20:29:57 GMT Joel Sherrill [a818530b] * c/src/ChangeLog (modified) * c/src/libchip/network/sonic.c (modified) 2008-08-30 Joel Sherrill * ... Wed, 20 Aug 2008 17:30:07 GMT Joel Sherrill [dccd351] * c/src/ChangeLog (modified) * c/src/libchip/i2c/spi-sd-card.c (modified) 2008-08-20 Sebastian Huber ... Tue, 19 Aug 2008 20:02:37 GMT Joel Sherrill [cc4c524b] * c/src/ChangeLog (modified) * c/src/libchip/display/disp_hcms29xx.c (modified) * c/src/libchip/network/dec21140.c (modified) * c/src/libchip/network/if_dc.c (modified) 2008-08-19 Joel Sherrill * ... Tue, 19 Aug 2008 17:39:05 GMT Joel Sherrill [593297e] * c/src/ChangeLog (modified) * c/src/libchip/display/disp_hcms29xx.c (modified) 2008-08-19 Joel Sherrill * ... Tue, 19 Aug 2008 15:22:41 GMT Joel Sherrill [aec17f1] * c/src/ChangeLog (modified) * c/src/libchip/shmdr/shm_driver.h (modified) 2008-08-19 Joel Sherrill * ... Tue, 19 Aug 2008 12:27:47 GMT Joel Sherrill [54c7a7f] * c/src/ChangeLog (modified) * c/src/libchip/display/disp_hcms29xx.c (modified) 2008-08-19 Sebastian Huber ... Mon, 18 Aug 2008 21:26:50 GMT Joel Sherrill [73d5344] * c/src/ChangeLog (modified) * c/src/libchip/serial/ns16550.c (modified) 2008-08-18 Joel Sherrill * ... Mon, 18 Aug 2008 15:27:59 GMT Ralf Corsepius [1f27c1f7] * c/src/ChangeLog (modified) * c/src/aclocal/prog-cc.m4 (modified) 2008-08-18 Ralf Corsepius * ... Mon, 18 Aug 2008 10:49:03 GMT Ralf Corsepius [fc216b96] * c/src/ChangeLog (modified) 2008-08-18 Ralf Corsépius * ... Mon, 18 Aug 2008 07:20:15 GMT Ralf Corsepius [891bd246] * c/src/ChangeLog (modified) 2008-08-18 Ralf Corsépius * ... Sat, 16 Aug 2008 04:02:41 GMT Ralf Corsepius [0063a93a] * c/src/ChangeLog (modified) * c/src/aclocal/prog-cc.m4 (modified) * cpukit/ChangeLog (modified) * cpukit/aclocal/prog-cc.m4 (modified) 2008-08-16 Ralf Corsepius * ... Sat, 02 Aug 2008 06:26:29 GMT Chris Johns [f031251c] * c/src/ChangeLog (modified) * c/src/libchip/i2c/spi-sd-card.c (modified) * c/src/libchip/ide/ata.c (modified) 2008-08-02 Chris Johns * ... Tue, 29 Jul 2008 02:23:48 GMT Chris Johns [3735f08] * c/src/ChangeLog (modified) * c/src/libchip/i2c/spi-sd-card.c (modified) * c/src/libchip/ide/ata.c (modified) * c/src/libchip/ide/ata.h (modified) * c/src/libchip/ide/ata_internal.h (modified) * c/src/libchip/ide/ide_controller.c (modified) * c/src/libchip/ide/ide_ctrl_cfg.h (modified) * c/src/libchip/ide/ide_ctrl_io.h (modified) 2008-07-29 Chris Johns * ... Sun, 27 Jul 2008 07:15:14 GMT Ralf Corsepius [1b39f18] * c/src/ChangeLog (modified) * c/src/configure.ac (modified) 2008-07-27 Ralf Corsépius * ... Wed, 23 Jul 2008 08:03:28 GMT Thomas Doerfler [be78809] * c/src/ChangeLog (modified) * c/src/libchip/i2c/spi-sd-card.c (modified) * c/src/libchip/i2c/spi-sd-card.h (modified) usee inttypes.h for output format specifiers Fri, 18 Jul 2008 14:03:47 GMT Joel Sherrill [eb98e4c6] * c/src/ChangeLog (modified) * c/src/lib/libcpu/powerpc/ChangeLog (modified) typos. Thu, 17 Jul 2008 21:33:08 GMT Joel Sherrill [708a8b46] * c/src/ChangeLog (modified) Formatting. Thu, 17 Jul 2008 14:39:34 GMT Thomas Doerfler [9bd5118] * c/src/ChangeLog (modified) * c/src/libchip/display/disp_hcms29xx.c (modified) * c/src/libchip/display/font_hcms29xx.h (modified) fixes for display driver Mon, 14 Jul 2008 16:15:28 GMT Thomas Doerfler [574fb67] * ChangeLog (modified) * aclocal/bsp-alias.m4 (modified) * aclocal/check-bsps.m4 (modified) * c/src/ChangeLog (modified) * c/src/lib/libbsp/m68k/acinclude.m4 (modified) * c/src/lib/libbsp/powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/acinclude.m4 (modified) * c/src/lib/libbsp/powerpc/gen83xx/ChangeLog (modified) * c/src/lib/libbsp/powerpc/gen83xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen83xx/README.mpc8313erdb (added) * c/src/lib/libbsp/powerpc/gen83xx/configure.ac (modified) * c/src/lib/libbsp/powerpc/gen83xx/console/config.c (modified) * c/src/lib/libbsp/powerpc/gen83xx/console/console.c (modified) * c/src/lib/libbsp/powerpc/gen83xx/i2c/i2c_init.c (modified) * c/src/lib/libbsp/powerpc/gen83xx/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/gen83xx/include/hwreg_vals.h (modified) * c/src/lib/libbsp/powerpc/gen83xx/include/irq-config.h (added) * c/src/lib/libbsp/powerpc/gen83xx/include/irq.h (moved) * c/src/lib/libbsp/powerpc/gen83xx/irq/ipic.c (deleted) * c/src/lib/libbsp/powerpc/gen83xx/irq/irq.c (added) * c/src/lib/libbsp/powerpc/gen83xx/irq/irq_init.c (deleted) * c/src/lib/libbsp/powerpc/gen83xx/network/network.c (modified) * c/src/lib/libbsp/powerpc/gen83xx/preinstall.am (modified) * c/src/lib/libbsp/powerpc/gen83xx/spi/spi_init.c (modified) * c/src/lib/libbsp/powerpc/gen83xx/start/start.S (modified) * c/src/lib/libbsp/powerpc/gen83xx/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/gen83xx/startup/cpuinit.c (modified) * c/src/lib/libbsp/powerpc/gen83xx/startup/linkcmds (deleted) * c/src/lib/libbsp/powerpc/gen83xx/startup/linkcmds.base (added) * c/src/lib/libbsp/powerpc/gen83xx/startup/linkcmds.hsc_cm01 (modified) * c/src/lib/libbsp/powerpc/gen83xx/startup/linkcmds.mpc8313erdb (added) * c/src/lib/libbsp/powerpc/gen83xx/startup/linkcmds.mpc8349eamds (modified) * c/src/lib/libbsp/powerpc/haleakala/ChangeLog (modified) * c/src/lib/libbsp/powerpc/haleakala/Makefile.am (modified) * c/src/lib/libbsp/powerpc/haleakala/irq/irq.c (modified) * c/src/lib/libbsp/powerpc/haleakala/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/haleakala/startup/linkcmds (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/ChangeLog (added) * c/src/lib/libbsp/powerpc/mpc55xxevb/Makefile.am (added) * c/src/lib/libbsp/powerpc/mpc55xxevb/README (added) * c/src/lib/libbsp/powerpc/mpc55xxevb/bsp_specs (added) * c/src/lib/libbsp/powerpc/mpc55xxevb/configure.ac (added) * c/src/lib/libbsp/powerpc/mpc55xxevb/include/bsp.h (added) * c/src/lib/libbsp/powerpc/mpc55xxevb/include/irq-config.h (added) * c/src/lib/libbsp/powerpc/mpc55xxevb/include/mpc55xxevb.h (added) * c/src/lib/libbsp/powerpc/mpc55xxevb/network/network.c (added) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/bspclean.c (added) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/bspstart.c (added) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/linkcmds (added) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/linkcmds.memory (added) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/sd-card-init.c (added) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/start.S (added) * c/src/lib/libbsp/powerpc/mpc55xxevb/tests/tests.c (added) * c/src/lib/libbsp/shared/ChangeLog (modified) * c/src/lib/libbsp/shared/bootcard.c (modified) * c/src/lib/libcpu/powerpc/ChangeLog (modified) * c/src/lib/libcpu/powerpc/Makefile.am (modified) * c/src/lib/libcpu/powerpc/configure.ac (modified) * c/src/lib/libcpu/powerpc/mpc55xx/dspi/dspi.c (added) * c/src/lib/libcpu/powerpc/mpc55xx/edma/edma.c (added) * c/src/lib/libcpu/powerpc/mpc55xx/esci/esci.c (added) * c/src/lib/libcpu/powerpc/mpc55xx/fec/fec.c (added) * c/src/lib/libcpu/powerpc/mpc55xx/include/dspi.h (added) * c/src/lib/libcpu/powerpc/mpc55xx/include/edma.h (added) * c/src/lib/libcpu/powerpc/mpc55xx/include/esci.h (added) * c/src/lib/libcpu/powerpc/mpc55xx/include/irq.h (added) * c/src/lib/libcpu/powerpc/mpc55xx/include/mpc55xx.h (added) * c/src/lib/libcpu/powerpc/mpc55xx/include/reg-defs.h (added) * c/src/lib/libcpu/powerpc/mpc55xx/include/regs.h (added) * c/src/lib/libcpu/powerpc/mpc55xx/irq/irq.c (added) * c/src/lib/libcpu/powerpc/mpc55xx/misc/copy.S (added) * c/src/lib/libcpu/powerpc/mpc55xx/misc/flash.S (added) * c/src/lib/libcpu/powerpc/mpc55xx/misc/fmpll.S (added) * c/src/lib/libcpu/powerpc/mpc83xx/gtm/gtm.c (added) * c/src/lib/libcpu/powerpc/mpc83xx/i2c/mpc83xx_i2cdrv.c (modified) * c/src/lib/libcpu/powerpc/mpc83xx/include/gtm.h (added) * c/src/lib/libcpu/powerpc/mpc83xx/network/tsec.c (modified) * c/src/lib/libcpu/powerpc/mpc83xx/spi/mpc83xx_spidrv.c (modified) * c/src/lib/libcpu/powerpc/mpc83xx/spi/mpc83xx_spidrv.h (modified) * c/src/lib/libcpu/powerpc/preinstall.am (modified) * c/src/lib/libcpu/powerpc/rtems/powerpc/powerpc.h (modified) * c/src/lib/libcpu/powerpc/shared/include/powerpc-utility.h (modified) * c/src/lib/libcpu/powerpc/shared/src/cache.c (modified) * c/src/lib/libcpu/powerpc/shared/src/cache_.h (modified) * c/src/libchip/Makefile.am (modified) * c/src/libchip/i2c/spi-sd-card.c (modified) * c/src/libchip/preinstall.am (modified) * make/ChangeLog (modified) * make/custom/gen83xx.cfg (modified) * make/custom/mpc5566evb.cfg (added) * make/custom/mpc55xx.cfg (added) * make/custom/mpc8313erdb.cfg (added) updated gen83xx BSP updated haleakala BSP added MPC55xx BSP Mon, 14 Jul 2008 08:45:32 GMT Thomas Doerfler [9ec91233] * c/src/ChangeLog (modified) * c/src/libchip/display/disp_fonts.h (modified) * c/src/libchip/display/font_hcms29xx.c (modified) corrections in display driver Fri, 11 Jul 2008 10:07:00 GMT Thomas Doerfler [224aebb3] * ChangeLog (modified) * README.configure (modified) * aclocal/bsp-alias.m4 (modified) * aclocal/check-bsps.m4 (modified) * c/src/ChangeLog (modified) * cpukit/ChangeLog (modified) * cpukit/Makefile.am (modified) * cpukit/include/rtems/status-checks.h (modified) * make/ChangeLog (modified) * make/custom/pgh360.cfg (added) added BSP to m68k adapted PPC exception code Thu, 10 Jul 2008 06:19:03 GMT Thomas Doerfler [780428f] * c/src/ChangeLog (modified) * c/src/lib/libbsp/ChangeLog (modified) * c/src/lib/libbsp/m68k/acinclude.m4 (modified) * c/src/lib/libbsp/shared/include/irq-config.h (added) * c/src/lib/libbsp/shared/include/irq-generic.h (added) * c/src/lib/libbsp/shared/src/irq-generic.c (added) * c/src/lib/libbsp/shared/src/irq-legacy.c (added) * cpukit/ChangeLog (modified) * cpukit/libcsupport/include/rtems/libcsupport.h (modified) * cpukit/rtems/include/rtems/rtems/intr.h (modified) Extension of the RTEMS Interrupt Manager (shared handler and handler ... Sun, 29 Jun 2008 06:26:44 GMT Ralf Corsepius [6a75acb] * c/src/ChangeLog (modified) 2008-06-29 Ralf Corsépius * ... Sun, 01 Jun 2008 09:03:30 GMT Ralf Corsepius [89ae273d] * c/src/ChangeLog (modified) 2008-06-01 Ralf Corsépius * ... Thu, 22 May 2008 20:19:55 GMT Joel Sherrill [adaf33af] * c/src/ChangeLog (modified) * c/src/libchip/Makefile.am (modified) * c/src/libchip/serial/termios_baud2index.c (deleted) * c/src/libchip/serial/termios_baud2num.c (deleted) 2008-05-22 Joel Sherrill * ... Thu, 15 May 2008 16:16:29 GMT Joel Sherrill [61b7dae] * c/src/ChangeLog (modified) * c/src/aclocal/bsp-bootcards-handles-ram-allocation.m4 (added) 2008-05-15 Joel Sherrill * ... Thu, 15 May 2008 15:56:58 GMT Joel Sherrill [8357ea27] * c/src/ChangeLog (modified) * c/src/wrapup/Makefile.am (modified) 2008-05-15 Joel Sherrill * ... Thu, 15 May 2008 15:10:38 GMT Thomas Doerfler [42bf1b9] * c/src/ChangeLog (modified) * c/src/lib/libbsp/arm/edb7312/preinstall.am (modified) * c/src/lib/libbsp/arm/nds/preinstall.am (modified) * c/src/lib/libbsp/bfin/eZKit533/preinstall.am (modified) * c/src/lib/libbsp/powerpc/gen83xx/ChangeLog (modified) * c/src/lib/libbsp/powerpc/gen83xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen83xx/console/config.c (modified) * c/src/lib/libbsp/powerpc/gen83xx/console/console.c (modified) * c/src/lib/libbsp/powerpc/gen83xx/i2c/i2c_init.c (modified) * c/src/lib/libbsp/powerpc/gen83xx/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/gen83xx/include/hwreg_vals.h (added) * c/src/lib/libbsp/powerpc/gen83xx/irq/ipic.c (modified) * c/src/lib/libbsp/powerpc/gen83xx/network/network.c (modified) * c/src/lib/libbsp/powerpc/gen83xx/preinstall.am (modified) * c/src/lib/libbsp/powerpc/gen83xx/spi/spi_init.c (modified) * c/src/lib/libbsp/powerpc/gen83xx/start/start.S (modified) * c/src/lib/libbsp/powerpc/gen83xx/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/gen83xx/startup/linkcmds (modified) * c/src/lib/libbsp/powerpc/gen83xx/startup/linkcmds.hsc_cm01 (modified) * c/src/lib/libbsp/powerpc/gen83xx/startup/linkcmds.mpc8349eamds (modified) * c/src/lib/libbsp/powerpc/mbx8xx/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mbx8xx/irq/irq.c (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/irq/irq.c (modified) * c/src/lib/libbsp/powerpc/mvme3100/preinstall.am (modified) * c/src/lib/libbsp/powerpc/mvme5500/preinstall.am (modified) * c/src/lib/libcpu/powerpc/ChangeLog (modified) * c/src/lib/libcpu/powerpc/mpc83xx/i2c/mpc83xx_i2cdrv.c (modified) * c/src/lib/libcpu/powerpc/mpc83xx/i2c/mpc83xx_i2cdrv.h (modified) * c/src/lib/libcpu/powerpc/mpc83xx/include/mpc83xx.h (modified) * c/src/lib/libcpu/powerpc/mpc83xx/network/tsec.c (modified) * c/src/lib/libcpu/powerpc/mpc83xx/spi/mpc83xx_spidrv.c (modified) * c/src/lib/libcpu/powerpc/mpc83xx/spi/mpc83xx_spidrv.h (modified) * c/src/libchip/Makefile.am (modified) * c/src/libchip/i2c/spi-flash-m25p40.c (modified) * c/src/libchip/i2c/spi-flash-m25p40.h (modified) * c/src/libchip/i2c/spi-fram-fm25l256.c (added) * c/src/libchip/i2c/spi-fram-fm25l256.h (added) * c/src/libchip/i2c/spi-memdrv.c (added) * c/src/libchip/i2c/spi-memdrv.h (added) * c/src/libchip/preinstall.am (modified) * cpukit/ChangeLog (modified) * cpukit/libi2c/libi2c.c (modified) * cpukit/libi2c/libi2c.h (modified) adapted gen83xx to new board Wed, 07 May 2008 20:49:05 GMT Joel Sherrill [89d19033] * c/src/ChangeLog (modified) * c/src/libchip/ide/ata.c (modified) 2008-05-07 Till Straumann ... Fri, 25 Apr 2008 14:16:45 GMT Joel Sherrill [d3e21f3] * c/src/ChangeLog (modified) * c/src/nfsclient/.cvsignore (deleted) * c/src/nfsclient/ChangeLog.slac (deleted) * c/src/nfsclient/LICENSE (deleted) * c/src/nfsclient/Makefile.am (deleted) * c/src/nfsclient/README (deleted) * c/src/nfsclient/preinstall.am (deleted) * c/src/nfsclient/proto/mount_prot.h (deleted) * c/src/nfsclient/proto/mount_prot.x (deleted) * c/src/nfsclient/proto/mount_prot_xdr.c (deleted) * c/src/nfsclient/proto/nfs_prot.h (deleted) * c/src/nfsclient/proto/nfs_prot.x (deleted) * c/src/nfsclient/proto/nfs_prot_xdr.c (deleted) * c/src/nfsclient/rfc1094.txt (deleted) * c/src/nfsclient/rtems-filesystem-patch (deleted) * c/src/nfsclient/src/cexphelp.c (deleted) * c/src/nfsclient/src/dirutils.c (deleted) * c/src/nfsclient/src/librtemsNfs.h (deleted) * c/src/nfsclient/src/nfs.c (deleted) * c/src/nfsclient/src/nfs.modini.c (deleted) * c/src/nfsclient/src/nfsTest.c (deleted) * c/src/nfsclient/src/rpcio.c (deleted) * c/src/nfsclient/src/rpcio.h (deleted) * c/src/nfsclient/src/rpcio.modini.c (deleted) * c/src/nfsclient/src/sock_mbuf.c (deleted) * c/src/nfsclient/src/xdr_mbuf.c (deleted) 2008-04-25 Joel Sherrill ... Tue, 26 Feb 2008 19:29:45 GMT Joel Sherrill [ad20f595] * c/src/ChangeLog (modified) * c/src/configure.ac (modified) 2008-02-26 Joel Sherrill * ... Sat, 05 Jan 2008 06:59:11 GMT Chris Johns [a61cc6c] * c/src/ChangeLog (modified) * c/src/libchip/flash/am29lv160.c (modified) 2008-01-05 Chris Johns * ... Sat, 22 Dec 2007 08:29:36 GMT Chris Johns [107f4d34] * c/src/ChangeLog (modified) * c/src/nfsclient/src/nfs.c (modified) * c/src/nfsclient/src/rpcio.c (modified) 2007-12-22 Chris Johns * ... Fri, 14 Dec 2007 04:54:57 GMT Chris Johns [f3bf21f2] * c/src/ChangeLog (modified) * c/src/libchip/Makefile.am (modified) * c/src/libchip/flash/am29lv160.c (added) * c/src/libchip/flash/am29lv160.h (added) * c/src/libchip/preinstall.am (modified) * c/src/wrapup/Makefile.am (modified) 2007-12-14 Chris Johns * ... Mon, 26 Nov 2007 22:25:53 GMT Joel Sherrill [9d7fa71] * c/src/ChangeLog (modified) * c/src/libchip/network/if_fxp.c (modified) 2007-11-26 Joel Sherrill * ... Wed, 21 Nov 2007 06:23:12 GMT Till Straumann [d371a97] * c/src/ChangeLog (modified) * c/src/libchip/rtc/ds1375-rtc.h (modified) * c/src/libchip/rtc/ds1375.c (modified) 2007-11-20 Till Straumann ... Tue, 20 Nov 2007 20:16:43 GMT Till Straumann [381a2f18] * c/src/ChangeLog (modified) * c/src/libchip/Makefile.am (modified) * c/src/libchip/preinstall.am (modified) * c/src/libchip/rtc/ds1375-rtc.h (added) * c/src/libchip/rtc/ds1375.c (added) 2007-11-20 Till Straumann ... Fri, 26 Oct 2007 09:54:28 GMT Thomas Doerfler [7a4e8e7c] * c/src/ChangeLog (modified) * c/src/libchip/i2c/spi-flash-m25p40.c (modified) * c/src/libchip/i2c/spi-flash-m25p40.h (modified) corrected bug in libchip/i2c/spi-flash-m25p40 Thu, 25 Oct 2007 16:17:56 GMT Thomas Doerfler [55a685b] * c/src/ChangeLog (modified) * c/src/lib/libbsp/powerpc/gen83xx/ChangeLog (modified) * c/src/lib/libbsp/powerpc/gen83xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen83xx/i2c/i2c_init.c (modified) * c/src/lib/libbsp/powerpc/gen83xx/include/bsp.h (modified) * c/src/lib/libcpu/powerpc/ChangeLog (modified) * c/src/lib/libcpu/powerpc/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc83xx/i2c/mpc83xx_i2cdrv.c (modified) * c/src/lib/libcpu/powerpc/mpc83xx/include/mpc83xx.h (modified) * c/src/lib/libcpu/powerpc/mpc83xx/network/tsec.c (modified) * c/src/lib/libcpu/powerpc/preinstall.am (modified) * c/src/libchip/Makefile.am (modified) * c/src/libchip/preinstall.am (modified) * cpukit/ChangeLog (modified) * cpukit/libi2c/libi2c.c (modified) * cpukit/libi2c/libi2c.h (modified) added SPI support to libi2c added IRQ support to MPC83xx i2c driver ... Tue, 25 Sep 2007 21:34:43 GMT Joel Sherrill [a29bf16b] * c/src/ChangeLog (modified) * c/src/libchip/shmdr/dump.c (modified) * c/src/libchip/shmdr/shm_driver.h (modified) 2007-09-25 Joel Sherrill * ... Tue, 25 Sep 2007 21:13:27 GMT Joel Sherrill [21961089] * c/src/ChangeLog (modified) * c/src/nfsclient/Makefile.am (modified) 2007-09-25 Joel Sherrill * ... Tue, 25 Sep 2007 16:56:48 GMT Joel Sherrill [96eadec4] * c/src/ChangeLog (modified) * c/src/nfsclient/Makefile.am (modified) * c/src/nfsclient/preinstall.am (modified) 2007-09-25 Joel Sherrill * ...
