@cdfed94f
06/25/18 09:12:24 |
Sebastian Huber |
bsp/riscv: Rework clock driver
Use device tree provided timebase …
5
@1232cd46
06/25/18 06:44:16 |
Sebastian Huber |
bsp/riscv: Add device tree support for console
Update #3433.
5
@c558cc4
06/28/18 11:04:58 |
Sebastian Huber |
bsp/riscv: Fix vector table for lp64
Update #3433.
5
@5f5c450
06/22/18 11:58:11 |
Sebastian Huber |
bsp/riscv: Add SMP startup synchronization
Update #3433.
5
@fe2cd01b
06/22/18 06:01:48 |
Sebastian Huber |
Update #3433.
5
@2086948a
05/11/18 04:54:59 |
Sebastian Huber |
riscv: Add dummy SMP support
Update #3433.
5
@9b2ef07f
06/22/18 11:30:21 |
Sebastian Huber |
bsp/riscv: Load global pointer
Update #3433.
5
@b0ee789
06/22/18 09:14:07 |
Sebastian Huber |
bsp/riscv: Use memset() to clear .bss
Update #3433.
5
@52f4fb6
06/26/18 05:48:06 |
Sebastian Huber |
riscv: Format assembler files
Use tabs to match the GCC generated …
5
@fef0a41
06/22/18 07:03:19 |
Sebastian Huber |
bsp/riscv: Do not clear integer registers at start
There is no need …
5
@38024362
06/22/18 09:00:01 |
Sebastian Huber |
bsp/riscv: Fix some warnings
Update #3444.
5
@16d905f
06/22/18 05:51:08 |
Sebastian Huber |
bsp/riscv: Add BSP options to define RAM region
Update #3433.
5
@f3da074a
06/22/18 05:10:44 |
Sebastian Huber |
bsp/riscv: Add new BSP variants
The latest RISC-V tool chain …
5
@6f5d88a
06/22/18 05:06:57 |
Sebastian Huber |
bsp/riscv_generic: Rename to "riscv"
Update #3433.
5
@41e2295
06/22/18 05:04:12 |
Sebastian Huber |
bsp/riscv_generic: Use standard optimization flags
Update #3433.
5
@92388f6
05/28/18 11:14:12 |
Hesham.Almatary |
bsps/riscv_generic: Rename and add variants
Add BSP variants to match …
5
@9e3bb45
05/29/18 07:14:24 |
Sebastian Huber |
bsp/riscv_generic: New linker command file
This linker command file …
5
@511dc4b
06/19/18 07:09:51 |
Sebastian Huber |
Rework initialization and interrupt stack support
Statically …
5
@715d616
06/19/18 13:10:36 |
Sebastian Huber |
bsps: Support .rtemsstack.* linker input sections
Use a dedicated …
5
@7ee59313
06/01/18 05:11:12 |
Sebastian Huber |
Remove Clock_driver_support_shutdown_hardware()
The aim of this clock …
5
@b0c3ba2f
06/19/18 13:20:52 |
Sebastian Huber |
bsps: Remove superfluous bsp_processor_count
This is unused copy and …
5
@762fa62
05/22/18 06:52:13 |
Sebastian Huber |
arm: Simplify CPU counter support
Use the standard ARMv7-M systick …
5
@65f868c
05/23/18 12:17:25 |
Sebastian Huber |
Add _CPU_Counter_frequency()
Add rtems_counter_frequency() API …
5
@1f283f17
06/15/18 06:07:17 |
Sebastian Huber |
bsp/beatnik: Remove CFLAGS_DEBUG_V
This was the only BSP setting this …
5
@e8b28ba
06/07/18 04:37:39 |
Sebastian Huber |
tools: Remove packhex
All tools should be removed from the RTEMS …
5
@8c62cf4
06/06/18 14:21:22 |
Sebastian Huber |
tools: Remove shgen
All tools should be removed from the RTEMS source …
5
@5249a4c
06/07/18 05:18:23 |
Sebastian Huber |
powerpc: Fix ss555 build
The mpc555 define is provided via …
5
@07c5976
06/07/18 04:58:59 |
Sebastian Huber |
bsps/powerpc: Hack to fix the build
The ppc405 define must be checked …
5
@dea4bbe3
06/01/18 05:00:37 |
Sebastian Huber |
bsps: Avoid malloc() in generic IRQ support
Use …
5
@4b3c8b82
05/25/18 06:21:18 |
christian.mauderer |
bsp/atsam: Remove side effect from gmac functions.
Quite a number of …
5
@3b2817b6
05/25/18 08:19:32 |
Sebastian Huber |
gumstix: Remove CONFIGURE_INTERRUPT_STACK_MEMORY
This define is not …
5
@ef61d89
05/24/18 08:32:35 |
bsp/atsam: Reserve one region for applications.
This allows a user to …
5
@eaf5bec
05/16/18 15:07:26 |
joel |
virtex5: Move -Dxxx to configure.ac
Updates #3425.
5
@17f69e4
05/16/18 15:01:26 |
joel |
virtex4: Move -Dxxx to configure.ac
Updates #3425.
5
@4afc1efa
05/16/18 15:01:09 |
joel |
virtex: Move -Dxxx to configure.ac
Updates #3425.
5
@3d43c475
05/16/18 14:58:13 |
joel |
tqm8xx: Move -Dxxx to configure.ac
Updates #3425.
5
@3274ec75
05/16/18 14:57:54 |
joel |
t32mppc: Move -Dxxx to configure.ac
Updates #3425.
5
@c20001c4
05/16/18 14:57:37 |
joel |
ss555: Move -Dxxx to configure.ac
Updates #3425.
5
@1a41818
05/16/18 14:55:14 |
joel |
qoriq: Move -Dxxx to configure.ac
Updates #3425.
5
@b06e8d61
05/16/18 14:54:50 |
joel |
qemuppc: Move -Dxxx to configure.ac
Updates #3425.
5
@c3b609d5
05/16/18 14:54:33 |
joel |
psim: Move -Dxxx to configure.ac
Updates #3425.
5
@beb4468
05/16/18 14:54:13 |
joel |
mvme5500: Move -Dxxx to configure.ac
Updates #3425.
5
@5aa8ac2
05/16/18 14:50:11 |
joel |
mvme3100: Move -Dxxx to configure.ac
Updates #3425.
5
@a03f73c
05/16/18 14:49:51 |
joel |
mpc8260ads: Move -Dxxx to configure.ac
Updates #3425.
5
@1e84462
05/16/18 14:49:22 |
joel |
mpc55xxevb: Move -Dxxx to configure.ac
Updates #3425.
5
@2261ef2
05/16/18 14:47:40 |
joel |
motorola_powerpc: Move -Dxxx to configure.ac
Updates #3425.
5
@01da0ac
05/16/18 14:47:07 |
joel |
haleakala: Move -Dxxx to configure.ac
Updates #3425.
5
@b1b5afba
05/16/18 14:43:24 |
joel |
beatnik: Move -Dxxx to configure.ac
Updates #3425.
5
@7bf072b
02/21/18 11:40:40 |
Sebastian Huber |
bsp/powerpc: Remove wildcards in linkcmds.base
This reverts commit …
5
@c4d35fb
03/03/18 12:30:01 |
Sebastian Huber |
libchip: Use rtems_blkdev_create()
Update #3358.
5
@a3fe23c
04/30/18 22:21:16 |
joel |
Drop executable permissions on .[S] files
5
@c8dcdf54
05/09/18 20:22:04 |
joel |
sparc64 niagara, usiii: Remove -D options from cfg file and move to …
5
@85602e0d
05/09/18 19:47:37 |
joel |
smdk2410: Move define of CPU_S3C2410 to bspopts.h
Updates #3425.
5
@2a1171d8
05/08/18 22:34:49 |
joel |
rtl22xx_t.cfg: Remove comment with -D THUMB_INTERWORK
Updates #3425.
5
@c77cd426
04/30/18 22:18:49 |
joel |
Drop executable permissions on .[ch] files
5
@3d703f4
04/26/18 05:29:28 |
Sebastian Huber |
bsp/pc386: Remove bin2boot support
Update #3408.
Close #3410.
5
@419d1e9
04/25/18 14:06:34 |
Sebastian Huber |
bsp/mcf5206elite: Do not install runtest script
Provide the runtest …
5
@eb36d11
04/25/18 13:06:08 |
Sebastian Huber |
bsps: Move documentation, etc. files to bsps
This patch is a part of …
5
@1554415e
04/25/18 12:54:27 |
Sebastian Huber |
bsp/sparc64: Move asm.S to bsps and rename
5
@a5bf9b6
04/25/18 12:53:33 |
Sebastian Huber |
bsps/mips: Move liblnk to bsps
This patch is a part of the BSP source …
5
@3460c522
04/25/18 12:51:49 |
Sebastian Huber |
bsps/powerpc: Move bsp-start-zero.S to bsps
5
@b80be135
04/25/18 12:51:01 |
Sebastian Huber |
bsp/psim: Move align_h.S to bsps
This patch is a part of the BSP …
5
@0b60c54
04/25/18 12:50:36 |
Sebastian Huber |
bsp/haleakala: Move assembler files to bsps
5
@f7eaf316
04/25/18 09:01:45 |
Sebastian Huber |
bsps: Remove unused u-boot-generic-board-info.h
This patch is a part …
5
@531d160
04/25/18 08:50:12 |
Sebastian Huber |
bsp/beagle: Move source files to bsps
5
@720ebc0
04/25/18 08:49:53 |
Sebastian Huber |
bsp/gumstix: Move fb.c to bsps
5
@82bfda92
04/25/18 08:49:39 |
Sebastian Huber |
bsp/lm3s69xx: Move ssi.c to bsps
5
@e945b049
04/25/18 08:43:38 |
Sebastian Huber |
bsp/lpc176x: Move source files to bsps
This patch is a part of the …
5
@74df15c
04/25/18 08:40:40 |
Sebastian Huber |
bsp/lpc24xx: Move source files to bsps
5
@43250167
04/25/18 08:36:52 |
Sebastian Huber |
bsp/lpc32xx: Move source files to bsps
5
@fc1bdb83
04/25/18 08:36:01 |
Sebastian Huber |
bsp/raspberrypi: Move source files to bsps
5
@ede0eb3
04/25/18 08:34:09 |
Sebastian Huber |
bsp/smdk2410: Move smc.c to bsps
5
@4183b711
04/25/18 08:33:35 |
Sebastian Huber |
bsp/tms570: Move cpucounterread.c to bsps
5
@a79d650
04/25/18 08:32:28 |
Sebastian Huber |
bsp/mcf5206elite: Move nvram.c to bsps
5
@0e15ba3
04/25/18 08:32:09 |
Sebastian Huber |
bsp/mrm332: Move interr.c to bsps
5
@100c9723
04/25/18 08:31:53 |
Sebastian Huber |
bsp/mrm332: Move spinit.c to bsps
5
@64d4fc7
04/25/18 08:26:24 |
Sebastian Huber |
bsp/gen5200: Move source files to bsps
5
@95d5426c
04/25/18 08:26:05 |
Sebastian Huber |
bsp/haleakala: Move mmu_405.c to bsps
5
@8266fb53
04/25/18 08:25:00 |
Sebastian Huber |
bsp/beatnik: Move source files to bsps
5
@bf16ee5
04/25/18 08:24:49 |
Sebastian Huber |
bsp/mvme3100: Move flashcfg.c to bsps
5
@8f12ee32
04/25/18 08:22:37 |
Sebastian Huber |
bsp/mvme5500: Move source files to bsps
5
@25787041
04/25/18 08:22:18 |
Sebastian Huber |
bsp/virtex5: Move mmu.c to bsps
5
@8bf101c
04/25/18 08:22:05 |
Sebastian Huber |
bsp/virtex4: Move mmu.c to bsps
5
@b07da56e
04/25/18 08:21:07 |
Sebastian Huber |
bsp/gensh4: Move hw_init.c to bsps
5
@891754f7
04/24/18 05:49:25 |
Sebastian Huber |
bsps: Move arm-cp15-set-ttb-entries.c to bsps
5
@aa705fe
04/24/18 05:49:12 |
Sebastian Huber |
bsps: Move arm-cp15-set-exception-handler.c to bsps
This patch is a …
5
@864e72e
04/24/18 05:47:32 |
Sebastian Huber |
bsps: Move arm-a9mpcore-smp.c to bsps
5
@fc6d8c2
04/24/18 05:47:04 |
Sebastian Huber |
bsps: Move arm-pl050.c to bsps
5
@3ad74cba
04/24/18 05:46:57 |
Sebastian Huber |
bsps: Move arm-pl011.c to bsps
5
@bbedc47b
04/24/18 05:46:26 |
Sebastian Huber |
bsps: Move arm-pl111-fb.c to bsps
5
@1ded97b9
04/24/18 05:44:31 |
Sebastian Huber |
bsps: Move arm-generic-timer-clock-config.c to bsps
This patch is a …
5
@e2f63219
04/24/18 05:43:51 |
Sebastian Huber |
bsps: Move arm-a9mpcore-clock-config.c to bsps
5
@d7a9eb90
04/24/18 05:42:33 |
Sebastian Huber |
bsps: Move armv7m-cpucounter.c to bsps
5
@c3a44343
04/24/18 05:41:51 |
Sebastian Huber |
bsps: Move bspreset.c to bsps
5
@7a8e71b
04/24/18 05:36:46 |
Sebastian Huber |
bsps/i386: Move shared files to bsps
5
@fe077b3
04/24/18 05:26:17 |
Sebastian Huber |
bsps: Move spansionFlash.c to bsps
5
@ff04935
04/24/18 05:26:11 |
Sebastian Huber |
bsps: Move intelFlash.c to bsps
5
@b5d4c80
04/24/18 05:25:25 |
Sebastian Huber |
bsps: Move flash.c to bsps
5
@afa90ee5
04/24/18 05:24:52 |
Sebastian Huber |
bsps: Move vpd.c to bsps
5
@499385e
04/24/18 05:24:31 |
Sebastian Huber |
bsps: Move motorola.c to bsps
5
