@a87964d
08/23/18 09:13:44 |
Daniel Hellstrom |
sparc,smp: typo in start.S causing SMP not working
5
@2cd3716
08/20/18 06:35:26 |
Sebastian Huber |
bsps/arm: Fix PL111 register define re-definition
Close #3502.
5
@bc731313
08/13/18 10:55:34 |
amaan.cheval |
bsps/x86_64: Add APIC timer based clock driver
The APIC timer is …
5
@6869321
08/13/18 10:50:38 |
amaan.cheval |
bsps/x86_64: Add support for RTEMS interrupts
Updates #2898.
5
@4544749e
08/13/18 10:33:12 |
amaan.cheval |
bsps/x86_64: Add paging support with 1GiB super pages
Updates #2898.
5
@6eccd0c
08/13/18 10:25:51 |
amaan.cheval |
bsps/x86_64: Reduce default RamSize? to 1GiB
Simulators may not always …
5
@ab971bf5
08/13/18 10:21:47 |
amaan.cheval |
bsps/x86_64: Reorganize header files and compile-options
Updates #2898.
5
@b3693f5
08/10/18 13:22:49 |
joel |
bsps/sparc/include/bsp/gradcdac.h: Fix nested comment warning
5
@d071d9a
08/10/18 13:22:02 |
joel |
qoriq/include/tm27.h: Fix prototype warning
5
@ebd1937
08/10/18 13:21:36 |
joel |
motorola_powerpc/include/tm27.h: Fix prototype warning
5
@3cff531f
08/10/18 13:21:09 |
joel |
bsps/powerpc/include/mpc83xx/mpc83xx.h: Fix nested comment warning
5
@5896da4
08/10/18 13:20:38 |
joel |
bsps/powerpc/include/bsp/tictac.h: Fix protototype warnings
5
@ae4fbf3b
08/10/18 13:20:07 |
joel |
gen83xx/include/tm27.h: Fix prototype warning
5
@ec8c955d
08/10/18 13:19:40 |
joel |
gen5200/include/tm27.h: Fix prototype warning
5
@7de51829
08/10/18 13:18:59 |
joel |
gen5200/include/bsp/ata.h: Fix warning
5
@0fc87d47
08/10/18 13:18:40 |
joel |
csb337/include/at91rm9200_dbgu.h: Fix nested comment warning
5
@0e6f7dc4
08/10/18 05:10:20 |
Sebastian Huber |
bsps/sparc: Fix external variable declarations
5
@f4424cfb
08/09/18 07:20:33 |
Sebastian Huber |
bsps/sparc: Move polled APBUART functions
This reduces the link-time …
5
@8e6cfcc
08/06/18 08:29:14 |
christian.mauderer |
bsp/atsam: Fix handling of slow SPI speeds.
This patch fixes an …
5
@1836c6a
08/04/18 08:45:19 |
Sebastian Huber |
bsp/gen5200: Avoid deprecated routine
Update #3358.
5
@f7cecc33
08/03/18 20:53:40 |
Sebastian Huber |
libchip/ata: Use rtems_blkdev_create()
Update #3358.
5
@d279e74
08/01/18 04:14:14 |
Sebastian Huber |
bsp/smdk2410: Use rtems_blkdev_create()
Update #3358.
5
@1dec54f9
07/31/18 14:05:49 |
Sebastian Huber |
bsps/lm32: Use rtems_blkdev_create()
Update #3358.
5
@32ccc01
08/03/18 12:03:39 |
Sebastian Huber |
bsps: Fix the generic IRQ support
The genmcf548x partly uses is own …
5
@141d502
08/02/18 11:23:26 |
Sebastian Huber |
bsp/riscv: Add missing BSP variant
Update #3433.
5
@4c740de
08/02/18 12:13:25 |
Sebastian Huber |
bsp/riscv: Fix build with RTEMS_SMP undefined
Update #3433.
5
@3d11c1e
08/01/18 08:06:37 |
Sebastian Huber |
bsp/riscv: Fix a synchronization issue for PLIC
Update #3433.
5
@dee2ebb
08/01/18 09:15:55 |
Sebastian Huber |
bsp/riscv: Remove unused variable
Update #3433.
5
@56b0387
08/01/18 06:13:39 |
Sebastian Huber |
bsp/riscv: Add NS16750 support to console driver
Update #3433.
5
@a7cd4b73
07/31/18 09:38:56 |
Sebastian Huber |
serial/ns16550: Precision clock synthesizer
Set the FIFO control …
5
@8a78b784
07/31/18 08:45:41 |
Sebastian Huber |
serial/ns16550: Use standard register names
Use the standard register …
5
@529154b
07/31/18 07:15:00 |
Sebastian Huber |
bsp/riscv: Initialize FPU depending on ISA
Initialize fcsr to zero …
5
@48cbd63
07/31/18 05:19:33 |
Sebastian Huber |
bsp/riscv: Fix clock driver
Do not assume that mtime is zero at boot …
5
@71284ce
08/01/18 05:41:49 |
Sebastian Huber |
bsps/sparc: Fix typo in start.S
Fix typo in start.S introduced by …
5
@44c2d393
07/27/18 13:04:38 |
Sebastian Huber |
bsp/riscv: Fix inter-processor interrupts
The previous version worked …
5
@cfc9573
07/27/18 12:47:17 |
Sebastian Huber |
riscv: Rework CPU counter support
Update #3433.
5
@581a0f88
07/24/18 12:47:05 |
Sebastian Huber |
bsp/riscv: Use interrupt driven NS16550 driver
Update #3433.
5
@adede135
07/24/18 11:27:54 |
Sebastian Huber |
bsp/riscv: Add PLIC support
Update #3433.
5
@bd560386
07/23/18 11:50:02 |
Sebastian Huber |
bsp/riscv: Add simple SMP support to clock driver
This is a hack. …
5
@6552ba8
07/24/18 08:10:12 |
Sebastian Huber |
bsp/riscv: Use CPU counter btimer
Update #3433.
5
@447fd89
07/20/18 11:11:04 |
Sebastian Huber |
bsp/riscv: Add basic SMP startup
Update #3433.
5
@6b9ef09
07/20/18 08:57:59 |
Sebastian Huber |
riscv: Add CLINT and PLIC support
The CLINT and PLIC need some …
5
@f5fd8eb
07/19/18 13:12:11 |
Sebastian Huber |
bsps/riscv: Update linker-symbols.h
Update #3433.
5
@dda6e06
07/19/18 12:45:47 |
Sebastian Huber |
bsp/riscv: Add reset via for SiFive? Test Finisher
Update #3433.
5
@3a263a9b
07/19/18 12:38:44 |
Sebastian Huber |
bsp/riscv: Add and use riscv_fdt_get_address()
Update #3433.
5
@7fe4855
07/19/18 11:58:12 |
Sebastian Huber |
bsp/riscv: Fix HTIF warnings
Update #3433.
5
@8db3f0e
07/19/18 10:11:19 |
Sebastian Huber |
riscv: Rework exception handling
Remove …
5
@406dd62
07/24/18 09:18:27 |
Sebastian Huber |
_SMP_Start_multitasking_on_secondary_processor()
Pass current …
5
@4678d1a
07/24/18 08:50:39 |
Sebastian Huber |
bsps: bsp_start_on_secondary_processor()
Pass current processor …
5
@0d362ff3
07/23/18 12:54:51 |
Sebastian Huber |
score: _SMP_Inter_processor_interrupt_handler()
Pass current …
5
@caccc5b
07/24/18 09:35:09 |
Sebastian Huber |
bsps: Fix function declaration warnings
5
@61c51db
07/24/18 06:25:35 |
Sebastian Huber |
bsp/beagle: Fix warnings
5
@1b57b75
07/18/18 05:14:41 |
Sebastian Huber |
bsp/realview-pbx-a9: Support unassigned processors
5
@cf811a4
07/09/18 11:12:57 |
amaan.cheval |
x86_64/console: Add NS16550 polled console driver
This addition …
5
@76c03152
07/09/18 11:12:56 |
amaan.cheval |
bsp/x86_64: Minimal bootable BSP
Current state:
- Basic context …
5
@1a19239
07/06/18 09:20:31 |
Sebastian Huber |
bsp/riscv: Add console support for NS16550 devices
Update #3433.
5
@31f90a2
07/06/18 11:52:22 |
Sebastian Huber |
bsp/riscv: Simplify printk() support
This is a prepartion to add …
5
@bca36d9
07/06/18 09:07:20 |
Sebastian Huber |
riscv: Add LADDR assembler define
An address must be loaded to a …
5
@dd32e2b2
07/06/18 06:12:40 |
Sebastian Huber |
riscv: Implement CPU counter
Update #3433.
5
@fc5cc9a
07/05/18 06:54:34 |
Sebastian Huber |
bsps/arm: Include missing header file
5
@d3dff40
07/04/18 14:15:22 |
Sebastian Huber |
bsps: Update headers.am
5
@0fd8287
06/26/18 05:15:28 |
Sebastian Huber |
riscv: Add _CPU_Get_current_per_CPU_control()
Update #3433.
5
@3be4478f
06/26/18 05:13:28 |
Sebastian Huber |
riscv: Avoid namespace pollution
Remove <rtems/score/riscv-utility.h> …
5
@ff7b104
06/27/18 05:47:33 |
Sebastian Huber |
bsp/riscv: Remove bsp_interrupt_handler_default()
It duplicated the …
5
@cdfed94f
06/25/18 09:12:24 |
Sebastian Huber |
bsp/riscv: Rework clock driver
Use device tree provided timebase …
5
@1232cd46
06/25/18 06:44:16 |
Sebastian Huber |
bsp/riscv: Add device tree support for console
Update #3433.
5
@c558cc4
06/28/18 11:04:58 |
Sebastian Huber |
bsp/riscv: Fix vector table for lp64
Update #3433.
5
@5f5c450
06/22/18 11:58:11 |
Sebastian Huber |
bsp/riscv: Add SMP startup synchronization
Update #3433.
5
@fe2cd01b
06/22/18 06:01:48 |
Sebastian Huber |
Update #3433.
5
@2086948a
05/11/18 04:54:59 |
Sebastian Huber |
riscv: Add dummy SMP support
Update #3433.
5
@9b2ef07f
06/22/18 11:30:21 |
Sebastian Huber |
bsp/riscv: Load global pointer
Update #3433.
5
@b0ee789
06/22/18 09:14:07 |
Sebastian Huber |
bsp/riscv: Use memset() to clear .bss
Update #3433.
5
@52f4fb6
06/26/18 05:48:06 |
Sebastian Huber |
riscv: Format assembler files
Use tabs to match the GCC generated …
5
@fef0a41
06/22/18 07:03:19 |
Sebastian Huber |
bsp/riscv: Do not clear integer registers at start
There is no need …
5
@38024362
06/22/18 09:00:01 |
Sebastian Huber |
bsp/riscv: Fix some warnings
Update #3444.
5
@16d905f
06/22/18 05:51:08 |
Sebastian Huber |
bsp/riscv: Add BSP options to define RAM region
Update #3433.
5
@f3da074a
06/22/18 05:10:44 |
Sebastian Huber |
bsp/riscv: Add new BSP variants
The latest RISC-V tool chain …
5
@6f5d88a
06/22/18 05:06:57 |
Sebastian Huber |
bsp/riscv_generic: Rename to "riscv"
Update #3433.
5
@41e2295
06/22/18 05:04:12 |
Sebastian Huber |
bsp/riscv_generic: Use standard optimization flags
Update #3433.
5
@92388f6
05/28/18 11:14:12 |
Hesham.Almatary |
bsps/riscv_generic: Rename and add variants
Add BSP variants to match …
5
@9e3bb45
05/29/18 07:14:24 |
Sebastian Huber |
bsp/riscv_generic: New linker command file
This linker command file …
5
@511dc4b
06/19/18 07:09:51 |
Sebastian Huber |
Rework initialization and interrupt stack support
Statically …
5
@715d616
06/19/18 13:10:36 |
Sebastian Huber |
bsps: Support .rtemsstack.* linker input sections
Use a dedicated …
5
@7ee59313
06/01/18 05:11:12 |
Sebastian Huber |
Remove Clock_driver_support_shutdown_hardware()
The aim of this clock …
5
@b0c3ba2f
06/19/18 13:20:52 |
Sebastian Huber |
bsps: Remove superfluous bsp_processor_count
This is unused copy and …
5
@762fa62
05/22/18 06:52:13 |
Sebastian Huber |
arm: Simplify CPU counter support
Use the standard ARMv7-M systick …
5
@65f868c
05/23/18 12:17:25 |
Sebastian Huber |
Add _CPU_Counter_frequency()
Add rtems_counter_frequency() API …
5
@1f283f17
06/15/18 06:07:17 |
Sebastian Huber |
bsp/beatnik: Remove CFLAGS_DEBUG_V
This was the only BSP setting this …
5
@e8b28ba
06/07/18 04:37:39 |
Sebastian Huber |
tools: Remove packhex
All tools should be removed from the RTEMS …
5
@8c62cf4
06/06/18 14:21:22 |
Sebastian Huber |
tools: Remove shgen
All tools should be removed from the RTEMS source …
5
@5249a4c
06/07/18 05:18:23 |
Sebastian Huber |
powerpc: Fix ss555 build
The mpc555 define is provided via …
5
@07c5976
06/07/18 04:58:59 |
Sebastian Huber |
bsps/powerpc: Hack to fix the build
The ppc405 define must be checked …
5
@dea4bbe3
06/01/18 05:00:37 |
Sebastian Huber |
bsps: Avoid malloc() in generic IRQ support
Use …
5
@4b3c8b82
05/25/18 06:21:18 |
bsp/atsam: Remove side effect from gmac functions.
Quite a number of …
5
@3b2817b6
05/25/18 08:19:32 |
Sebastian Huber |
gumstix: Remove CONFIGURE_INTERRUPT_STACK_MEMORY
This define is not …
5
@ef61d89
05/24/18 08:32:35 |
bsp/atsam: Reserve one region for applications.
This allows a user to …
5
@eaf5bec
05/16/18 15:07:26 |
joel |
virtex5: Move -Dxxx to configure.ac
Updates #3425.
5
@17f69e4
05/16/18 15:01:26 |
joel |
virtex4: Move -Dxxx to configure.ac
Updates #3425.
5
@4afc1efa
05/16/18 15:01:09 |
joel |
virtex: Move -Dxxx to configure.ac
Updates #3425.
5
@3d43c475
05/16/18 14:58:13 |
joel |
tqm8xx: Move -Dxxx to configure.ac
Updates #3425.
5
