@99494370
03/04/20 11:34:34 |
Sebastian Huber |
bsp/stm32h7: New BSP
Update #3910.
@c44e404
04/03/20 09:12:53 |
Sebastian Huber |
bsp/stm32h7: Fix warnings
Update #3910.
@e4ba06f
04/02/20 06:28:56 |
Sebastian Huber |
bsp/stm32h7: Disable unused functions
Update #3910.
@abb7858
04/01/20 09:11:59 |
Sebastian Huber |
bsp/stm32h7: Enable LL drivers
Update #3910.
@2f157e2
03/23/20 10:37:46 |
Sebastian Huber |
bsp/stm32h7: Move <math.h> include
This is necessary for libbsd …
@2cfcd00
03/19/20 10:28:45 |
Sebastian Huber |
bsp/stm32h7: Constify some functions
Update #3910.
@2131228
03/04/20 11:33:17 |
Sebastian Huber |
bsp/stm32h7: Import from STM32CubeMX-5.6.0
Update #3910.
@db94626b
10/26/20 14:09:36 |
Sebastian Huber |
bsp/leon3: Updat due to API changes
@273613f
04/03/20 08:03:28 |
Sebastian Huber |
bsps/arm: Sort fast text/data sections
@3fccdc95
03/20/20 07:10:46 |
Sebastian Huber |
bsps/arm: Add support for MPU region alignment
Update #3910.
@bb4e534
10/19/20 15:39:10 |
Sebastian Huber |
bsps: Fix rtems_interrupt_server_delete()
The ISR lock must be …
@f9c8e14
09/18/20 08:00:46 |
Sebastian Huber |
grlib: Add ambapp_common_info to derived types
This avoids a cast in …
@c15c520
09/18/20 08:00:45 |
Sebastian Huber |
grlib: Remove unused conversion macros
@3154203b
09/18/20 08:00:44 |
Sebastian Huber |
grlib: Remove superfluous forward decls
@cf16821
10/16/20 04:34:39 |
Sebastian Huber |
bsps/arm: Add workaround for Errata 794072
Add a workaround for …
@e7b878e
10/02/20 09:36:20 |
Sebastian Huber |
bsps/arm: Workaround for Errata 845369
Add a workaround for Cortex-A9 …
@7db9c14
10/12/20 15:12:55 |
joel |
lpc32xx_mzx_stage_1-testsuite.tcfg: Add ttest01
@2695e7d0
10/12/20 15:12:38 |
joel |
lpc2362-testsuite.tcfg: Add monitor and psxmsgq01
@562c2a71
10/12/20 15:12:17 |
joel |
lm3s3749-testsuite.tcfg: Add spcxx01
@f28a6def
10/05/20 14:28:24 |
frank.kuehndel |
disp_hcms29xx: Fix string truncation warning
The strlcpy() function …
@d7a48e1
10/06/20 05:39:44 |
Sebastian Huber |
rtems: Improve RTEMS_NO_RETURN attribute
Provide RTEMS_NO_RETURN also …
@e1a0e0c3
10/08/20 05:50:10 |
Sebastian Huber |
grlib: Add and use irqmp_has_timestamp()
Replace …
@560c08c
10/07/20 15:34:27 |
joel |
bsps/include/bsp/fatal.h: Add GRLIB specific fatal error
updates #4028.
@0c74ff9
10/07/20 13:38:28 |
joel |
Misc: Correct spelling of occurred
@ed9c88c
10/02/20 14:27:54 |
kinsey.moore |
bsps: Add Cortex-A53 ILP32 BSP variant
This adds an AArch64 ILP32 BSP …
@db68ea1
09/22/20 13:32:56 |
kinsey.moore |
bsps: Add Cortex-A53 LP64 basic BSP
This adds an AArch64 basic BSP …
@cb2afd2
09/30/20 00:54:20 |
kinsey.moore |
bsps/shared: Add PSCI-based bspreset implementation
This adds a …
@f8ad5bb2
08/28/20 03:13:47 |
kinsey.moore |
bsps: Break out AArch32 GICv3 support
This breaks out …
@1480c3f
08/28/20 03:07:52 |
kinsey.moore |
bsps: Break out AArch32 portions of GPT driver
This breaks …
@1c03649
06/10/20 18:46:12 |
kinsey.moore |
Move ARM PL011 UART driver
This UART driver is now needed for BSPs …
@a9995f1
10/05/20 15:14:33 |
Sebastian Huber |
bsp/lpc176x: Fix memory map
Due to the static allocation of operating …
@1f77518
09/23/20 10:36:56 |
jan.sommer |
bsps/pc386: Add missing license header
Closes #4093.
@e8450a6c
09/22/20 15:38:12 |
Sebastian Huber |
bsps/riscv: Add bsp_fdt_map_intr()
This function is required by libbsd.
@e59cb6a2
09/20/20 15:45:11 |
Sebastian Huber |
bsps/powerpc: Remove ppc_generic define
Do not force BSPs to define …
@4897a82d
09/15/20 07:07:29 |
Hesham.Almatary |
riscv: Make sifive_test finisher 4 bytes
QEMU is now stricter with …
@4b767bd
04/03/20 07:53:53 |
Sebastian Huber |
bsps/arm: Use RTEMS_SECTION()
@20d8237
09/04/20 18:10:57 |
Sebastian Huber |
arm: Fix arm_cp15_set_translation_table_entries()
In a …
@2a4ccc4
09/15/20 13:07:25 |
Sebastian Huber |
bsp/pc386: Remove support for obsolete Binutils
Update #3818.
@2786b0a
09/13/20 14:13:14 |
Sebastian Huber |
bsps/riscv: Use far jump to boot_card()
Use a far jump to avoid …
@f3f0370f
07/19/19 11:09:43 |
Sebastian Huber |
build: Alternative build system based on waf
Update #3818.
@5959b1e
09/10/20 17:29:11 |
joel |
Remove tmoverhd which existed to produce the obsolete coverhd.h
@e563e61
09/10/20 16:41:33 |
joel |
Remove remaining references to coverhd.h
Closes #4040.
@764ea578
09/06/20 21:07:29 |
Hesham.Almatary |
htif_console_handler is defined in htif.c
closes #4069.
@d556af36
08/31/20 12:12:14 |
Sebastian Huber |
bsps: Always install IPI in SMP configs
The inter-processor interrupt …
@b87efa7
08/20/20 07:18:06 |
jan.sommer |
bsp/xilinx-zynq: Flush TX-Buffer before initializing uart
Closes …
@fe6191f
04/15/20 14:36:07 |
Sebastian Huber |
bsps/leon3: Remove superfluous includes
@95d37b6
08/03/20 10:16:51 |
Sebastian Huber |
bsps/arm: Use _Assert()
@3ec5f20
07/27/20 01:23:19 |
Chris Johns |
powerpc/io: The eieio() function clashes with FreeBSD. Change.
@1b421585
08/03/20 07:42:25 |
Sebastian Huber |
arm/atsam: Make interrupt server configurable
The external UART over …
@6014fad
07/08/20 08:53:26 |
christian.mauderer |
bsps/beagle: Remove some debug output from I2C.
@29e7a069
08/01/20 12:30:10 |
Sebastian Huber |
dev/spi-memdrv: Fix use of uninit mem_param_ptr
@c60942ea
07/30/20 08:30:15 |
Sebastian Huber |
rtems: Add rtems_interrupt_server_create()
Add …
@02c9eb85
07/20/20 05:46:53 |
bsps/fdt: Make sure data is cache aligned
The cache of the fdt blob …
@29a73d8
07/17/20 05:54:44 |
bsp/imx: Use GPIOs for SPI CS
The chip select lines of the iMX SPI …
@0f4b911c
07/17/20 05:54:43 |
bsp/imx: Add a GPIO driver
Update 3869
@a3bcc79
07/30/20 17:29:23 |
Sebastian Huber |
bsps/lm32: Use shared <bsp/irq.h>
Having a duplicate header with the …
@33314eb
07/23/20 06:42:59 |
Sebastian Huber |
bsps/clock: Fix fast idle clock tick support
If we interrupt a thread …
@9cb107c9
07/03/20 12:31:47 |
jan.sommer |
bsps/pc386: Fix IPI for non-consecutive APICIDs
- properly use the …
@479b2bf
05/11/20 06:25:32 |
Sebastian Huber |
rtems: Remove _Copyright_Notice from API header
Close #3981.
@a3b86d6c
07/05/20 10:39:37 |
james.fitzsimons |
Fix for Beaglebone BSP PWM bug
@401b237
07/03/20 05:46:24 |
Sebastian Huber |
epiphany: Remove support for this target
Due to an unmaintained …
@523551cc
07/03/20 07:18:13 |
Sebastian Huber |
bsps/powerpc: Remove obsolete BSPs
Update #3951.
@70b803b5
07/03/20 07:15:50 |
Sebastian Huber |
bsps/powerpc: Remove SPE enabled variants
The PowerPC SPE support was …
@69690f6
04/21/20 11:10:07 |
Sebastian Huber |
bsps/powerpc: Remove atexit form start.o
Remove superflous atexit …
@9b5af6a
04/08/20 11:19:51 |
Sebastian Huber |
bsps/powerpc: Fix tlbie instruction usage
GCC 10 no longer passes …
@9b3b33d
04/07/20 06:26:00 |
Sebastian Huber |
bsps/powerpc: Fix inline assembly
GCC 10 no longer passes -many to …
@b4a786d
04/08/20 11:48:41 |
Sebastian Huber |
bsp/qoriq: Fix tlbwe sequence
@6a02c11b
07/05/20 10:52:01 |
Sebastian Huber |
bsps/mips: Fix issues with -fno-common
@bc73a085
06/17/20 05:57:26 |
Chris Johns |
i386/pc: Initialise the printk serial port on first use
5
@4a8b135
06/10/20 16:45:26 |
joel |
bsps/i386/pc386/start/*.S: Remove space before tab
5
@96d9823
05/31/20 14:22:59 |
jan.sommer |
bsp/pc386: Disable interrupt nesting for job handler
- Fixes timeout …
5
@208cd6b
05/31/20 14:22:57 |
jan.sommer |
bsps/pc386: Separate smp API functions. Makes smpfatal08 link
5
@c954003
05/31/20 14:22:56 |
jan.sommer |
bsps/pc386: Fix Clock_isr for SMP
- Do not forward Clock_isr through …
5
@5d4a1edc
05/31/20 14:22:55 |
jan.sommer |
bsp/pc386: Define interrupt stack frame for smp
- Defines …
5
@85d6a760
05/31/20 14:22:53 |
jan.sommer |
bsp/pc386: Update GDT to work for SMP
Create a GS segment in the GDT …
5
@f99b1f0
05/31/20 14:22:52 |
jan.sommer |
bsp/pc386: Turn start16.S into a startAP.S
start16.S is now only used …
5
@084ea83
05/06/20 08:30:51 |
Chris Johns |
testsuite: Add expected-fail to beagleboneblack
Updates #2962
5
@7e3af67
05/06/20 05:19:15 |
Chris Johns |
testsuite: Add expected-fail to xilinx's zedboard, a9_qemu, zc702 and …
5
@1b1755d9
05/06/20 05:18:13 |
Chris Johns |
testsuite: Add expected-fail to psim
Updates #2962
5
@7d00247
05/05/20 23:52:48 |
Chris Johns |
testsuite: Add expected-fail to erc32, leon2, and leon3 BSPs
Updates #2962
5
@4b9b6dd
05/05/20 12:34:32 |
Sebastian Huber |
Use rtems_get_version_string()
Update #3970.
5
@222d6879
04/16/20 12:14:12 |
bsps/arm: Fix uninitialized value in generic timer
5
@01219541
03/30/20 14:38:22 |
bsp/imx: Add an extra ecspi clock.
Some imx chips or boards don't use …
5
@d35722e6
04/08/20 09:52:45 |
Sebastian Huber |
bsps/riscv: Fix multiple definition
5
@19efa9a0
03/28/20 18:24:07 |
niteesh.gs |
bsp/raspberrypi: Fix build warnings.
1) _Memory_Initialize makes …
5
@f493534
04/07/20 22:08:34 |
joel |
lpc23xx_tli800-testsuite.tcfg: Add psxaoi03 and psxsignal07
Updates #3938.
5
@af7e519
04/07/20 22:07:47 |
joel |
mcf52235-testsuite.tcfg: Add sp16
Updates #3938.
5
@a7ea726f
04/07/20 22:07:08 |
joel |
lpc1768_mbed-testsuite.tcfg: Add psxaoi03 and psxsignal07
Updates #3938.
5
@dcb097a
04/07/20 22:06:37 |
joel |
lpc2362-testsuite.tcfg: Add psxaoi03 and psxsignal07
Updates #3938.
5
@fe5d50ed
04/07/20 22:05:52 |
joel |
lpc1768_mbed_ahb_ram_eth-testsuite.tcfg: Add psxsignal07
Updates #3938.
5
@f74d70e6
04/07/20 22:05:00 |
joel |
lm4f120-testsuite.tcfg: Add psxsignal07
Updates #3938.
5
@92a3a19c
04/06/20 19:21:26 |
Sebastian Huber |
tests: Exclude record02 for some BSPs
Update #3938.
5
@2db1fd85
04/06/20 17:15:59 |
Gedare Bloom |
sparc64: update linkcmds with missing sections for TLS
Closes #3936.
5
@bb8ae78
03/09/20 22:00:58 |
bsp/raspberry: Add a bsp_fdt_map_intr().
Fixes #3903
5
@1483012
04/02/20 19:05:48 |
jan.sommer |
bsp/shared/clock: Reset Clock_driver_isrs to correct value
5
@51307919
03/20/20 08:12:26 |
Sebastian Huber |
arm: ARMv7-M statically initialized vector table
Statically …
5
@299a82f4
04/02/20 07:01:43 |
Sebastian Huber |
bsp/qoriq: Fix off by one error in clock init
Close #3921.
5
@37e7cc5
03/19/20 20:55:26 |
joel |
gdbarmsim: Remove
Closes #3611.
5
@5662210
03/13/20 14:14:04 |
Sebastian Huber |
bsps: Remove legacy interrupt API from default
This fixes linker …
5
@2ff83634
03/12/20 21:00:25 |
joel |
mrm332-testsuite.tcfg: Add dl01
5
