source: rtems/bsps
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
(edit) @9002859   11/29/18 16:53:32 joel lpc2362-testsuite.tcfg: Add dl07 5
(edit) @7ed1e618   11/29/18 15:19:44 joel lpc1768_mbed_ahb_ram_eth-testsuite.tcfg: Add dl07 5
(edit) @1491db5b   11/29/18 15:19:06 joel lpc1768_mbed_ahb_ram-testsuite.tcfg: Add dl07 5
(edit) @1d78d66   11/29/18 15:18:48 joel lpc1768_mbed-testsuite.tcfg: Add dl07 5
(edit) @1fe6d11   11/28/18 17:53:36 shashvatjain2002 m68k/mcf52235:Add per-section compilation and linking support(GCI … 5
(edit) @9c4dc7b0   11/28/18 20:07:41 shashvatjain2002 m68k/mcf5225x:Add per-section compilation and linking support(GCI … 5
(edit) @cc119eb   11/28/18 15:36:31 shashvatjain2002 m68k/mcf5329:Add per-section compilation and linking support (GCI … 5
(edit) @e80d34e   11/28/18 13:15:38 shashvatjain2002 m68k/mcf5235:Add per-section compilation and linking support (GCI … 5
(edit) @a919807   11/28/18 16:43:23 joel lm3s3749-testsuite.tcfg: Add dl07 5
(edit) @5bf0c1a   11/28/18 13:52:22 Sebastian Huber bsps/sparc: Fix SMP build Update #3622. 5
(edit) @89bff5a   11/27/18 02:29:49 shashvatjain2002 m68k/av5282: Add per-section compilation and linking support (GCI … 5
(edit) @a7267241   11/26/18 14:44:25 Sebastian Huber bsps/sparc: Add and use <grlib_impl.h> Reduce copy and paste. 5
(edit) @0a75a4aa   11/26/18 13:04:59 Sebastian Huber Remove rtems_cache_*_processor_set() functions The following … 5
(edit) @1947449   11/25/18 20:17:54 shashvatjain2002 m68k/uC5282: Add per-section compilation and linking (GCI 2018) The … 5
(edit) @ffe9e7a   11/25/18 07:37:01 shashvatjain2002 m68k/gen68360:Add per-section compilation and linking support The … 5
(edit) @1b2124d   11/24/18 20:55:07 pritishjain2001 m68k/gen68340:Add per-section compilation and linking support The … 5
(edit) @2ce44de   11/22/18 01:25:43 zenon.hans.taneka Changed slightly awkward sentence structure 5
(edit) @e0caabe   11/20/18 12:09:53 Sebastian Huber bsps/arm: Avoid short range branch in start.S 5
(edit) @faafc229   11/20/18 12:06:04 Sebastian Huber bsps/arm: Use local labels in start.S 5
(edit) @94529131   11/20/18 12:03:20 Sebastian Huber bsps/arm: Simplify start.S The boot_card() function does not return. 5
(edit) @0a6a4ddb   11/16/18 06:46:16 Sebastian Huber bsps/moxie: Use interrupt stack for init stack Update #3459. 5
(edit) @38f81bfc   11/16/18 07:01:24 Sebastian Huber bsps/nios2: Use interrupt stack for init stack Update #3459. 5
(edit) @0989001   11/15/18 05:40:35 Sebastian Huber bsps/sparc64: Use interrupt stack for init stack Update #3459. 5
(edit) @5f5bbd1   11/16/18 07:55:30 Sebastian Huber bsps/x86_64: Use interrupt stack for init stack Update #3459. 5
(edit) @0ce6bf3   11/16/18 05:39:49 Sebastian Huber bsps/epiphany: Use interrupt stack for init stack Update #3459. 5
(edit) @a74ee417   11/16/18 05:36:28 Sebastian Huber bsps/bfin: Use interrupt stack for init stack Update #3459. 5
(edit) @508f319e   11/16/18 06:43:51 Sebastian Huber bsps/mips: Use interrupt stack for init stack Update #3459. 5
(edit) @84e59b7c   11/15/18 19:47:22 Sebastian Huber bsps/powerpc: Use interrupt stack for init stack Move start.o to … 5
(edit) @cc61d5c   11/16/18 06:36:04 Sebastian Huber bsps/m68k: Use interrupt stack for init stack Update #3459. 5
(edit) @5247a214   11/14/18 22:48:56 pisa bsp/tms570: correct baudrate calculation. 5
(edit) @aefd4a2   11/14/18 22:46:43 pisa bsp/tms570: correct inclusion of header files for build with HW init. … 5
(edit) @a13b89b   11/14/18 07:42:22 Sebastian Huber bsp/i386: Use interrupt stack for init stack Update #3459. 5
(edit) @5f32da0   11/14/18 06:58:38 Sebastian Huber bsp/or1k: Use interrupt stack for init stack Update #3459. 5
(edit) @28bf4ca   11/14/18 06:00:59 Sebastian Huber or1k: Support GCC 9 Close #3602. 5
(edit) @9a029ce   11/09/18 12:06:52 Sebastian Huber bsps/irq: Use rtems_malloc() 5
(edit) @510fbfc3   11/08/18 14:31:03 Sebastian Huber sh: Remove use of proc_ptr Update #3585. 5
(edit) @54c5ffc   11/08/18 14:05:22 Sebastian Huber or1k: Remove use of proc_ptr Update #3585. 5
(edit) @5c6edee   11/08/18 14:44:56 Sebastian Huber m68k: Remove use of proc_ptr Update #3585. 5
(edit) @3c6a6e8   11/08/18 14:14:32 Sebastian Huber i386: Remove use of proc_ptr Update #3585. 5
(edit) @a043ff8   11/08/18 14:33:47 Sebastian Huber epiphany: Remove use of proc_ptr Update #3585. 5
(edit) @93fae332   11/12/18 08:33:04 Sebastian Huber Include missing <sys/types.h> Update #3598. 5
(edit) @bfcf1473   11/08/18 15:21:48 Sebastian Huber m32c: Remove this target Update #3599. 5
(edit) @7ea7178   11/09/18 18:16:27 shashvatjain2002 arm/csb337: Update Doxygen (GCI 2018) 5
(edit) @b3c624d8   11/08/18 00:47:49 shashvatjain2002 arm/altera cyclone v: Update Doxygen (GCI 2018) 5
(edit) @84aedcae   11/08/18 12:49:38 Sebastian Huber Include missing <rtems/score/thread.h> Update #3598. 5
(edit) @5841e0b   11/09/18 12:47:20 Sebastian Huber bsp/lpc32xx: Include missing <time.h> Update #3598. 5
(edit) @fdd3b85   11/09/18 09:46:50 Sebastian Huber bsp/motorola_powerpc: Include <sys/param.h> Update #3598. 5
(edit) @0288536   11/09/18 08:40:45 Sebastian Huber bsps: Include missing header files Update #3598. 5
(edit) @efdb4a7   11/09/18 08:37:53 Sebastian Huber bsp/beatnik: Fix warnings 5
(edit) @32953f90   11/08/18 07:38:24 Sebastian Huber bsp/realview-pbx-a9: Update headers.am 5
(edit) @4fea054c   11/06/18 18:34:15 Sebastian Huber score: Remove _ISR_Dispatch() This function was only used on some … 5
(edit) @ff081aee   11/06/18 15:58:02 Sebastian Huber score: Rename interrupt stack symbols Rename * … 5
(edit) @2faea99   11/07/18 10:08:50 Sebastian Huber bsp/realview-pbx-a9: Fix printk() support Avoid dependencies on the … 5
(edit) @d7c51da   11/05/18 20:48:20 Gedare Bloom altera-cyclone-v: tweak ingroup 5
(edit) @3b930548   11/03/18 20:45:50 44733601+ABR290B arm/altera-cyclone-v: update doxygen (GCI 2018) 5
(edit) @01595a4   10/24/18 08:17:58 Sebastian Huber bsp/imx: Adjust workspace according to device tree 5
(edit) @28fb5b71   09/05/18 23:02:30 joel mpc8260ads/start/bspstart.c: Fix unused function warning 5
(edit) @c1233a33   09/04/18 13:35:37 joel qemuppc/start/cmain.c: Cast args to memcpy and bzero to fix warnings 5
(edit) @156b77a   09/04/18 13:35:07 joel gen5200/mscan/mscan.c: Fix printf() format warning 5
(edit) @023bd1d   09/04/18 13:34:42 joel or1k/shared/cache/cache.c: Remove unused methods 5
(edit) @35eab84   09/04/18 13:34:22 joel gdbarmsim/include/bsp.h: Include <sys/stat.h> to fix warning 5
(edit) @68799dac   10/18/18 05:22:44 Sebastian Huber bsp/atsam: Add const qualifier to AES_SetInput() 5
(edit) @143c8d0   10/17/18 07:43:55 Sebastian Huber serial/ns16550: Fix precision clock synthesizer The precision clock … 5
(edit) @d7c13c8   10/16/18 12:34:38 Sebastian Huber bsp/imx7: Add getchark() support 5
(edit) @186a0b1   10/15/18 08:38:49 Sebastian Huber bsps/arm: Recognize .tm_clone_table input section 5
(edit) @1822649   10/15/18 06:44:52 pisa bsp/tms570: Simple fix to resolve macro redefinitions. closes #3347 5
(edit) @dc32b6a   08/31/18 06:21:05 Daniel Hellstrom leon: do not use -mfix-{device} with Clang Clang do not support … 5
(edit) @6dc0b5f   07/21/17 12:18:50 javier.jalle leon, spwtdp: Initial driver commit 5
(edit) @511ef83c   10/09/18 09:59:48 Sebastian Huber bsps/arm: Fix ctor/dtor invocation order Remove obsolete .ctor and … 5
(edit) @b131cb2   10/04/18 12:35:00 Sebastian Huber bsp/atsam: Use internal SRAM for stack area 5
(edit) @f004b2b8   10/02/18 08:22:15 Sebastian Huber Use rtems_task_exit() Update #3530. Update #3533. 5
(edit) @5cb23f4b   10/01/18 06:59:14 Sebastian Huber bsp/atsam: Use binary semaphore for I2C Remove superfluous sleep … 5
(edit) @fca9132   09/28/18 12:45:16 Sebastian Huber bsp/atsam: Use binary semaphore for SPI Update #3534. 5
(edit) @69a24c3   09/21/18 05:38:23 Sebastian Huber bsp/imx: Add imx_ccm_sdhci_hz() Update #3525. 5
(edit) @9ed109c   09/19/18 13:18:38 Daniel Hellstrom leon: remove warning missing string.h 5
(edit) @c2011b47   02/21/18 18:23:35 maberg leon, grspw_pkt: support CCSDS/ISO16 data CRC When the CCSDS/CCITT … 5
(edit) @0aae151   08/13/18 09:36:03 Daniel Hellstrom leon,grspw_pkt: protect TX descriptor from bad input (hdrlen) 5
(edit) @ddc95ab0   06/15/18 10:54:32 maberg leon, l2cache: workaround for scrubber This is a workaround for a … 5
(edit) @56a7540   01/23/18 09:12:36 Daniel Hellstrom leon: substitute printf with printk in driver init 5
(edit) @68a0012   11/21/17 12:19:05 Daniel Hellstrom leon3, ckinit: avoid unsued code warnings when drvmgr is enabled 5
(edit) @d952d73   11/21/17 10:09:58 Daniel Hellstrom leon3: fix warning when SMP is enabled 5
(edit) @b3cf79b   09/20/18 05:27:28 Sebastian Huber bsp/leon3: Fix typo which breaks the CPU counter Update #3456. 5
(edit) @9cda6f29   09/17/18 12:12:07 Hesham.Almatary riscv: Allow platforms with no PLIC to proceed Spike simulator and … 5
(edit) @62cb39d7   09/17/18 06:28:29 Sebastian Huber bsp/tqm8xx: Remove unused files Close #3513. 5
(edit) @688e101a   09/14/18 05:30:46 Sebastian Huber bsp/tqm8xx: Fix polled vs. interrupt output Update #3513. 5
(edit) @d22147e   09/12/18 09:47:19 Sebastian Huber bsp/tqm8xx: Convert console to new Termios API Update #3513. 5
(edit) @68920e7f   09/12/18 08:43:02 Sebastian Huber bsp/tqm8xx: Move DMA support to channel descriptor Update #3513. 5
(edit) @53fb03fe   09/12/18 08:24:56 Sebastian Huber bsp/tqm8xx: Move rxBuf to channel descriptor Update #3513. 5
(edit) @7b93d857   09/12/18 08:08:50 Sebastian Huber bsp/tqm8xx: Use IRQ extensions API Update #3513. 5
(edit) @94ea8a8   09/13/18 09:34:23 Sebastian Huber bsp/tqm8xx: Clear sbss section 5
(edit) @7916139   09/13/18 09:33:50 Sebastian Huber bsp/tqm8xx: Use custom string to uint32_t Avoid C locale support … 5
(edit) @cb68253   09/07/18 04:19:02 Sebastian Huber network: Use kernel/user space header files Add and use … 5
(edit) @2f61eb21   09/06/18 05:03:49 Sebastian Huber bsp/qoriq: Add struct qoriq to allow forward decls 5
(edit) @54d87f2   09/04/18 16:28:57 Sebastian Huber bsps/powerpc: Simplify ppc_exc_initialize() Remove parameters from … 5
(edit) @9a21fc7   09/05/18 05:38:13 Sebastian Huber bsp/mpc55xxevb: Fix format warning Close #3504. 5
(edit) @ccdce9d8   09/05/18 05:31:23 Sebastian Huber libchip/ata: Fix ATA_DRIVER_TABLE_ENTRY Drop unused and deprecated … 5
(edit) @fad3f79b   08/31/18 05:44:53 Sebastian Huber bsps: BSP_INTERRUPT_STACK_AT_WORK_AREA_BEGIN Remove the … 5
(edit) @66e78854   08/29/18 17:51:50 joel Remove bsps/sparc64/shared/helenos/boot/generic/string.c 5
(edit) @5da1593   08/29/18 17:39:17 joel psim/include/tm27.h: Fix not a prototype warnings 5
(edit) @a8d3f10   08/29/18 17:39:01 joel mvme5500/include/tm27.h: Fix not a prototype warnings 5
