source: rtems/bsps
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
(edit) @8e8e269   Feb 28, 2019, 10:35:53 AM Sebastian Huber bsps/arm: Fix typo
(edit) @e33be09   Feb 27, 2019, 2:10:53 PM Sebastian Huber bsps/arm: Support GIC group 0/1
(edit) @feea03b6   Feb 27, 2019, 9:53:30 AM Sebastian Huber Remove explicit file names from @file This makes the @file …
(edit) @262cb534   Feb 27, 2019, 10:43:49 AM Sebastian Huber bsp/altera-cyclone-v: Move header file This gets rid of a special …
(edit) @68a5f751   Feb 25, 2019, 10:30:11 PM garnie_a arm/beagle: Fix sdcard.sh tool
(edit) @ecf62845   Feb 25, 2019, 10:30:09 PM garnie_a arm/beagle: SPI driver
(edit) @bdec62c4   Feb 18, 2019, 8:01:27 AM Sebastian Huber bsps/arm: Move device tree copy Move device tree copy operation after …
(edit) @af80b0a   Feb 18, 2019, 7:24:37 AM Sebastian Huber bsp/altera-cyclone-v: Use FDT for clock frequency
(edit) @43fbb50f   Feb 15, 2019, 11:07:23 AM Sebastian Huber bsp/altera-cyclone-v: Make FDT support optional
(edit) @eec706e2   Feb 11, 2019, 6:34:14 AM Sebastian Huber bsps/powerpc: Fix small data area section Fix small data area in case …
(edit) @6c9f017   Feb 2, 2019, 4:09:53 AM Chris Johns libdl: Add powerpc large memory and small data support. - Add support …
(edit) @b08278e   Feb 2, 2019, 4:32:38 AM Chris Johns powerpc/psim: Increase the psim memory to 256M This allows test dl09 …
(edit) @568490a   Feb 8, 2019, 11:40:45 AM Jiri Gaisler griscv: add additional cpu configurations * Also switch default …
(edit) @4e686261   Feb 7, 2019, 10:13:01 AM Sebastian Huber bsps/irq: Fix interrupt server init (SMP)
(edit) @0fb52ce   Feb 7, 2019, 6:45:58 AM Sebastian Huber bsps/arm: Fix generic timer frequency Update #3456.
(edit) @b1381ae   Jan 25, 2019, 2:50:14 PM Sebastian Huber bsps/powerpc: Fix warnings
(edit) @81aec18   Jan 24, 2019, 1:29:03 PM Sebastian Huber bsps/powerpc: Fix 64-bit issues in assembler files We have to be …
(edit) @d3d4e77   Jan 18, 2019, 11:37:55 AM Jiri Gaisler riscv: add griscv bsp Update #3678.
(edit) @c1dcd6af   Jan 21, 2019, 10:27:07 AM Jiri Gaisler grlib: make memory coherency cpu-independent Update #3678.
(edit) @9b2b389   Jan 18, 2019, 5:00:47 PM Jiri Gaisler grlib: use cpu-independent routines for uncached access Update #3678.
(edit) @5981c8ca   Jan 18, 2019, 10:29:08 AM Jiri Gaisler grlib: use rtems_interrupt_handler_install() Update #3678.
(edit) @411c297   Jan 18, 2019, 10:24:18 AM Jiri Gaisler grlib: make apbuart driver independent of bsp Update #3678.
(edit) @7eb606d3   Dec 22, 2018, 5:31:04 PM Sebastian Huber grlib: Move source files Update #3678.
(edit) @31720925   Dec 22, 2018, 6:13:44 AM Sebastian Huber grlib: Move header files Update #3678.
(edit) @95c1921   Jan 21, 2019, 8:17:05 AM Sebastian Huber bsps/arm: Remove unused bsp_stack_irq_size Update #3459.
(edit) @12dfe5dc   Jan 16, 2019, 9:42:18 PM joel bsps/i386/shared/cache/cache.c: Make compile
(edit) @e7d623e7   Jan 10, 2019, 6:57:36 AM Sebastian Huber bsps/arm: Conditional ARMv7-AR data cache disable Update #3667. Close …
(edit) @0abe47f   Jan 10, 2019, 6:29:54 AM thomas.doerfler bsps/arm: Fix typo in disable cache for ARMv7-AR Update #3667.
(edit) @9aee88a   Jan 8, 2019, 1:43:02 PM Sebastian Huber bsp/riscv: Clear boot command line
(edit) @c05d7a9d   Dec 21, 2018, 8:43:27 PM Sebastian Huber bsps/sparc: Fix warnings
(edit) @75e1009f   Dec 21, 2018, 8:42:09 PM Sebastian Huber bsps/sparc: Fix typo
(edit) @11f3b9a   Nov 26, 2018, 2:55:38 PM Sebastian Huber bsps/sparc: Add grlib_malloc(), grlib_calloc() This avoids a …
(edit) @c37807e9   Dec 21, 2018, 10:57:26 AM Sebastian Huber bsps/arm: Add cache size support for CP15
(edit) @41a557bc   Dec 21, 2018, 7:39:33 AM Sebastian Huber bsps/arm: Add ARMv7-AR disable data cache Close #3667.
(edit) @b0c2d48   Dec 21, 2018, 6:49:47 AM Sebastian Huber bsps: Add CPU_CACHE_SUPPORT_PROVIDES_DISABLE_DATA Update #3667.
(edit) @5e0ab02   Dec 21, 2018, 6:46:58 AM Sebastian Huber bsps: Update cache manager documentation Update #3667.
(edit) @a6f70e1   Dec 21, 2018, 6:14:42 AM Sebastian Huber bsps: Remove superfluous comments in cacheimpl.h Remove superfluous …
(edit) @ba85655   Dec 21, 2018, 9:16:02 AM Sebastian Huber ARM_CACHE_L1_CPU_SUPPORT_PROVIDES_RANGE_FUNCTIONS Remove this …
(edit) @750e795   Dec 21, 2018, 6:27:16 AM Sebastian Huber bsps/i386: Enable instruction cache support
(edit) @9edc558d   Dec 20, 2018, 1:21:40 PM Sebastian Huber bsp/imx: Fix for RAM end at 4GiB
(edit) @0a1f5df9   May 3, 2018, 11:03:27 AM Sebastian Huber Simplify _CPU_Counter_difference() In order to simplify the use of …
(edit) @2e8b5de   Dec 5, 2018, 12:02:59 PM Sebastian Huber bsp/leon2: Move printk() support Avoid assert() in …
(edit) @99de42c   Dec 4, 2018, 10:05:10 PM mcomajoancara Capitalize Rtems to RTEMS
(edit) @0446f680   Dec 3, 2018, 8:37:32 PM mcomajoancara Spelling and grammar fixes in source code comments (GCI 2018)
(edit) @fdcba406   Dec 4, 2018, 2:26:55 PM Sebastian Huber bsp/leon3: Fix CPU counter frequency
(edit) @f40f86d   Nov 30, 2018, 7:01:50 PM shashvatjain2002 powerpc/haleakala:Add per-section compilation and linking support (GCI …
(edit) @c056f21   Nov 30, 2018, 6:07:17 PM shashvatjain2002 powerpc/mpc8260ads:Add per-section compilation and linking support …
(edit) @8b3ca0c   Nov 30, 2018, 4:39:29 PM shashvatjain2002 powerpc/qemuppc:Add per-section compilation and linking support (GCI …
(edit) @8b6273a8   Nov 30, 2018, 3:03:25 PM shashvatjain2002 powerpc/ss555:Add per-section compilation and linking support(GCI …
(edit) @10e7d87   Nov 30, 2018, 2:33:31 PM joel mcf52235-testsuite.tcfg: Add dl07
(edit) @e447d4c0   Nov 29, 2018, 10:46:06 PM joel generic_or1k-testsuite.tcfg: Enable sptls01 now that GCC is from FSF …
(edit) @8b28fdd   Nov 29, 2018, 8:39:47 PM shashvatjain2002 m68k/mrm332:Add per-section compilation and linking support (GCI 2018) …
(edit) @f57d4d5   Nov 29, 2018, 6:32:46 PM shashvatjain2002 m68k/mcf5206elite:Add per-section compilation and linking support (GCI …
(edit) @d6d4002   Nov 29, 2018, 4:54:12 PM joel bfin/shared/dev/clock.c: Include rtems/score/thread.h
(edit) @b56edf1   Nov 29, 2018, 4:53:48 PM joel lpc23xx_tli800-testsuite.tcfg: Add dl07
(edit) @9002859   Nov 29, 2018, 4:53:32 PM joel lpc2362-testsuite.tcfg: Add dl07
(edit) @7ed1e618   Nov 29, 2018, 3:19:44 PM joel lpc1768_mbed_ahb_ram_eth-testsuite.tcfg: Add dl07
(edit) @1491db5b   Nov 29, 2018, 3:19:06 PM joel lpc1768_mbed_ahb_ram-testsuite.tcfg: Add dl07
(edit) @1d78d66   Nov 29, 2018, 3:18:48 PM joel lpc1768_mbed-testsuite.tcfg: Add dl07
(edit) @1fe6d11   Nov 28, 2018, 5:53:36 PM shashvatjain2002 m68k/mcf52235:Add per-section compilation and linking support(GCI …
(edit) @9c4dc7b0   Nov 28, 2018, 8:07:41 PM shashvatjain2002 m68k/mcf5225x:Add per-section compilation and linking support(GCI …
(edit) @cc119eb   Nov 28, 2018, 3:36:31 PM shashvatjain2002 m68k/mcf5329:Add per-section compilation and linking support (GCI …
(edit) @e80d34e   Nov 28, 2018, 1:15:38 PM shashvatjain2002 m68k/mcf5235:Add per-section compilation and linking support (GCI …
(edit) @a919807   Nov 28, 2018, 4:43:23 PM joel lm3s3749-testsuite.tcfg: Add dl07
(edit) @5bf0c1a   Nov 28, 2018, 1:52:22 PM Sebastian Huber bsps/sparc: Fix SMP build Update #3622.
(edit) @89bff5a   Nov 27, 2018, 2:29:49 AM shashvatjain2002 m68k/av5282: Add per-section compilation and linking support (GCI …
(edit) @a7267241   Nov 26, 2018, 2:44:25 PM Sebastian Huber bsps/sparc: Add and use <grlib_impl.h> Reduce copy and paste.
(edit) @0a75a4aa   Nov 26, 2018, 1:04:59 PM Sebastian Huber Remove rtems_cache_*_processor_set() functions The following …
(edit) @1947449   Nov 25, 2018, 8:17:54 PM shashvatjain2002 m68k/uC5282: Add per-section compilation and linking (GCI 2018) The …
(edit) @ffe9e7a   Nov 25, 2018, 7:37:01 AM shashvatjain2002 m68k/gen68360:Add per-section compilation and linking support The …
(edit) @1b2124d   Nov 24, 2018, 8:55:07 PM pritishjain2001 m68k/gen68340:Add per-section compilation and linking support The …
(edit) @2ce44de   Nov 22, 2018, 1:25:43 AM zenon.hans.taneka Changed slightly awkward sentence structure
(edit) @e0caabe   Nov 20, 2018, 12:09:53 PM Sebastian Huber bsps/arm: Avoid short range branch in start.S
(edit) @faafc22   Nov 20, 2018, 12:06:04 PM Sebastian Huber bsps/arm: Use local labels in start.S
(edit) @94529131   Nov 20, 2018, 12:03:20 PM Sebastian Huber bsps/arm: Simplify start.S The boot_card() function does not return.
(edit) @0a6a4ddb   Nov 16, 2018, 6:46:16 AM Sebastian Huber bsps/moxie: Use interrupt stack for init stack Update #3459.
(edit) @38f81bfc   Nov 16, 2018, 7:01:24 AM Sebastian Huber bsps/nios2: Use interrupt stack for init stack Update #3459.
(edit) @0989001   Nov 15, 2018, 5:40:35 AM Sebastian Huber bsps/sparc64: Use interrupt stack for init stack Update #3459.
(edit) @5f5bbd1   Nov 16, 2018, 7:55:30 AM Sebastian Huber bsps/x86_64: Use interrupt stack for init stack Update #3459.
(edit) @0ce6bf3   Nov 16, 2018, 5:39:49 AM Sebastian Huber bsps/epiphany: Use interrupt stack for init stack Update #3459.
(edit) @a74ee417   Nov 16, 2018, 5:36:28 AM Sebastian Huber bsps/bfin: Use interrupt stack for init stack Update #3459.
(edit) @508f319e   Nov 16, 2018, 6:43:51 AM Sebastian Huber bsps/mips: Use interrupt stack for init stack Update #3459.
(edit) @84e59b7c   Nov 15, 2018, 7:47:22 PM Sebastian Huber bsps/powerpc: Use interrupt stack for init stack Move start.o to …
(edit) @cc61d5c   Nov 16, 2018, 6:36:04 AM Sebastian Huber bsps/m68k: Use interrupt stack for init stack Update #3459.
(edit) @5247a214   Nov 14, 2018, 10:48:56 PM pisa bsp/tms570: correct baudrate calculation.
(edit) @aefd4a2   Nov 14, 2018, 10:46:43 PM pisa bsp/tms570: correct inclusion of header files for build with HW init. …
(edit) @a13b89b   Nov 14, 2018, 7:42:22 AM Sebastian Huber bsp/i386: Use interrupt stack for init stack Update #3459.
(edit) @5f32da0   Nov 14, 2018, 6:58:38 AM Sebastian Huber bsp/or1k: Use interrupt stack for init stack Update #3459.
(edit) @28bf4ca   Nov 14, 2018, 6:00:59 AM Sebastian Huber or1k: Support GCC 9 Close #3602.
(edit) @9a029ce   Nov 9, 2018, 12:06:52 PM Sebastian Huber bsps/irq: Use rtems_malloc()
(edit) @510fbfc3   Nov 8, 2018, 2:31:03 PM Sebastian Huber sh: Remove use of proc_ptr Update #3585.
(edit) @54c5ffc   Nov 8, 2018, 2:05:22 PM Sebastian Huber or1k: Remove use of proc_ptr Update #3585.
(edit) @5c6edee   Nov 8, 2018, 2:44:56 PM Sebastian Huber m68k: Remove use of proc_ptr Update #3585.
(edit) @3c6a6e8   Nov 8, 2018, 2:14:32 PM Sebastian Huber i386: Remove use of proc_ptr Update #3585.
(edit) @a043ff8   Nov 8, 2018, 2:33:47 PM Sebastian Huber epiphany: Remove use of proc_ptr Update #3585.
(edit) @93fae332   Nov 12, 2018, 8:33:04 AM Sebastian Huber Include missing <sys/types.h> Update #3598.
(edit) @bfcf1473   Nov 8, 2018, 3:21:48 PM Sebastian Huber m32c: Remove this target Update #3599.
(edit) @7ea7178   Nov 9, 2018, 6:16:27 PM shashvatjain2002 arm/csb337: Update Doxygen (GCI 2018)
(edit) @b3c624d8   Nov 8, 2018, 12:47:49 AM shashvatjain2002 arm/altera cyclone v: Update Doxygen (GCI 2018)
(edit) @84aedca   Nov 8, 2018, 12:49:38 PM Sebastian Huber Include missing <rtems/score/thread.h> Update #3598.
