source: rtems/bsps
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
(edit) @54d87f2   Sep 4, 2018, 4:28:57 PM Sebastian Huber bsps/powerpc: Simplify ppc_exc_initialize() Remove parameters from …
(edit) @9a21fc7   Sep 5, 2018, 5:38:13 AM Sebastian Huber bsp/mpc55xxevb: Fix format warning Close #3504.
(edit) @ccdce9d8   Sep 5, 2018, 5:31:23 AM Sebastian Huber libchip/ata: Fix ATA_DRIVER_TABLE_ENTRY Drop unused and deprecated …
(edit) @fad3f79b   Aug 31, 2018, 5:44:53 AM Sebastian Huber bsps: BSP_INTERRUPT_STACK_AT_WORK_AREA_BEGIN Remove the …
(edit) @66e78854   Aug 29, 2018, 5:51:50 PM joel Remove bsps/sparc64/shared/helenos/boot/generic/string.c
(edit) @5da1593   Aug 29, 2018, 5:39:17 PM joel psim/include/tm27.h: Fix not a prototype warnings
(edit) @a8d3f10   Aug 29, 2018, 5:39:01 PM joel mvme5500/include/tm27.h: Fix not a prototype warnings
(edit) @a5c3bfb   Aug 29, 2018, 5:37:29 PM joel uC5282/clock/clock.c: Correct bsp_idle_thread() prototype
(edit) @34e959fa   Aug 29, 2018, 5:36:50 PM joel gen68340/include/m340timer.h: Fix not a prototype warnings
(edit) @76ac42ff   Aug 29, 2018, 5:36:18 PM joel lpc32xx/include/bsp.h: Resolve set but not used warning
(edit) @350b07a   Aug 29, 2018, 5:34:58 PM joel monlib.[ch]: Fix warnings for external vs internal use of .h
(edit) @60702ab   Aug 22, 2018, 4:58:12 PM joel qoriq/include/tm27.h: Fix warnings
(edit) @126a454   Aug 22, 2018, 4:57:57 PM joel gen5200/include/tm27.h: Fix warnings
(edit) @c80f5afc   Aug 22, 2018, 4:50:19 PM joel mpc55xxevb/clock/clock-config.c: Remove unused mpc55xx_clock_cleanup() …
(edit) @76b3f8c   Aug 22, 2018, 2:30:44 PM joel gen5200/include/bsp/bestcomm.h: Fix unused variable warning
(edit) @bb6eeabf   Aug 21, 2018, 3:35:26 PM joel bsps/i386/shared/cache/cache.c: Fix warnings
(edit) @c2e8ed6   Aug 21, 2018, 3:35:16 PM joel gdbarmsim/include/bsp.h: Fix warnings
(edit) @cba349c   Aug 17, 2018, 6:30:19 PM joel bsps/m68k/shared/cache/cache.h: Fix warnings and clean up
(edit) @a6fca76   Aug 29, 2018, 5:46:31 AM Sebastian Huber bsp/qoriq: Remove README Update #2854.
(edit) @408fad3   Jun 20, 2018, 7:23:31 AM Daniel Hellstrom leon,grspw_pkt: remove incorrect comment on SMP not being tested To …
(edit) @aea3134e   Jun 15, 2018, 6:49:31 AM Daniel Hellstrom leon,apbuart: replace termios c_cflag & CBAUD with c_{i,o}speed ince …
(edit) @243ddb5   Jun 15, 2018, 12:28:36 PM Daniel Hellstrom leon,greth: enable MAC filtering (promiscous mode, multicast) It …
(edit) @2fbe2ef3   Feb 13, 2018, 6:47:14 AM Daniel Hellstrom leon, greth: 10/100 MAC enable TX BD interrupt Missed to enable …
(edit) @a87964d   Aug 23, 2018, 9:13:44 AM Daniel Hellstrom sparc,smp: typo in start.S causing SMP not working
(edit) @2cd3716   Aug 20, 2018, 6:35:26 AM Sebastian Huber bsps/arm: Fix PL111 register define re-definition Close #3502.
(edit) @bc731313   Aug 13, 2018, 10:55:34 AM amaan.cheval bsps/x86_64: Add APIC timer based clock driver The APIC timer is …
(edit) @6869321   Aug 13, 2018, 10:50:38 AM amaan.cheval bsps/x86_64: Add support for RTEMS interrupts Updates #2898.
(edit) @4544749e   Aug 13, 2018, 10:33:12 AM amaan.cheval bsps/x86_64: Add paging support with 1GiB super pages Updates #2898.
(edit) @6eccd0c   Aug 13, 2018, 10:25:51 AM amaan.cheval bsps/x86_64: Reduce default RamSize? to 1GiB Simulators may not always …
(edit) @ab971bf5   Aug 13, 2018, 10:21:47 AM amaan.cheval bsps/x86_64: Reorganize header files and compile-options Updates #2898.
(edit) @b3693f5   Aug 10, 2018, 1:22:49 PM joel bsps/sparc/include/bsp/gradcdac.h: Fix nested comment warning
(edit) @d071d9a   Aug 10, 2018, 1:22:02 PM joel qoriq/include/tm27.h: Fix prototype warning
(edit) @ebd1937   Aug 10, 2018, 1:21:36 PM joel motorola_powerpc/include/tm27.h: Fix prototype warning
(edit) @3cff531f   Aug 10, 2018, 1:21:09 PM joel bsps/powerpc/include/mpc83xx/mpc83xx.h: Fix nested comment warning
(edit) @5896da4   Aug 10, 2018, 1:20:38 PM joel bsps/powerpc/include/bsp/tictac.h: Fix protototype warnings
(edit) @ae4fbf3b   Aug 10, 2018, 1:20:07 PM joel gen83xx/include/tm27.h: Fix prototype warning
(edit) @ec8c955d   Aug 10, 2018, 1:19:40 PM joel gen5200/include/tm27.h: Fix prototype warning
(edit) @7de51829   Aug 10, 2018, 1:18:59 PM joel gen5200/include/bsp/ata.h: Fix warning
(edit) @0fc87d47   Aug 10, 2018, 1:18:40 PM joel csb337/include/at91rm9200_dbgu.h: Fix nested comment warning
(edit) @0e6f7dc4   Aug 10, 2018, 5:10:20 AM Sebastian Huber bsps/sparc: Fix external variable declarations
(edit) @f4424cfb   Aug 9, 2018, 7:20:33 AM Sebastian Huber bsps/sparc: Move polled APBUART functions This reduces the link-time …
(edit) @8e6cfcc   Aug 6, 2018, 8:29:14 AM christian.mauderer bsp/atsam: Fix handling of slow SPI speeds. This patch fixes an …
(edit) @1836c6a   Aug 4, 2018, 8:45:19 AM Sebastian Huber bsp/gen5200: Avoid deprecated routine Update #3358.
(edit) @f7cecc33   Aug 3, 2018, 8:53:40 PM Sebastian Huber libchip/ata: Use rtems_blkdev_create() Update #3358.
(edit) @d279e74   Aug 1, 2018, 4:14:14 AM Sebastian Huber bsp/smdk2410: Use rtems_blkdev_create() Update #3358.
(edit) @1dec54f9   Jul 31, 2018, 2:05:49 PM Sebastian Huber bsps/lm32: Use rtems_blkdev_create() Update #3358.
(edit) @32ccc01   Aug 3, 2018, 12:03:39 PM Sebastian Huber bsps: Fix the generic IRQ support The genmcf548x partly uses is own …
(edit) @141d502   Aug 2, 2018, 11:23:26 AM Sebastian Huber bsp/riscv: Add missing BSP variant Update #3433.
(edit) @4c740de   Aug 2, 2018, 12:13:25 PM Sebastian Huber bsp/riscv: Fix build with RTEMS_SMP undefined Update #3433.
(edit) @3d11c1e   Aug 1, 2018, 8:06:37 AM Sebastian Huber bsp/riscv: Fix a synchronization issue for PLIC Update #3433.
(edit) @dee2ebb   Aug 1, 2018, 9:15:55 AM Sebastian Huber bsp/riscv: Remove unused variable Update #3433.
(edit) @56b0387   Aug 1, 2018, 6:13:39 AM Sebastian Huber bsp/riscv: Add NS16750 support to console driver Update #3433.
(edit) @a7cd4b73   Jul 31, 2018, 9:38:56 AM Sebastian Huber serial/ns16550: Precision clock synthesizer Set the FIFO control …
(edit) @8a78b784   Jul 31, 2018, 8:45:41 AM Sebastian Huber serial/ns16550: Use standard register names Use the standard register …
(edit) @529154b   Jul 31, 2018, 7:15:00 AM Sebastian Huber bsp/riscv: Initialize FPU depending on ISA Initialize fcsr to zero …
(edit) @48cbd63   Jul 31, 2018, 5:19:33 AM Sebastian Huber bsp/riscv: Fix clock driver Do not assume that mtime is zero at boot …
(edit) @71284ce   Aug 1, 2018, 5:41:49 AM Sebastian Huber bsps/sparc: Fix typo in start.S Fix typo in start.S introduced by …
(edit) @44c2d393   Jul 27, 2018, 1:04:38 PM Sebastian Huber bsp/riscv: Fix inter-processor interrupts The previous version worked …
(edit) @cfc9573   Jul 27, 2018, 12:47:17 PM Sebastian Huber riscv: Rework CPU counter support Update #3433.
(edit) @581a0f88   Jul 24, 2018, 12:47:05 PM Sebastian Huber bsp/riscv: Use interrupt driven NS16550 driver Update #3433.
(edit) @adede135   Jul 24, 2018, 11:27:54 AM Sebastian Huber bsp/riscv: Add PLIC support Update #3433.
(edit) @bd560386   Jul 23, 2018, 11:50:02 AM Sebastian Huber bsp/riscv: Add simple SMP support to clock driver This is a hack. …
(edit) @6552ba8   Jul 24, 2018, 8:10:12 AM Sebastian Huber bsp/riscv: Use CPU counter btimer Update #3433.
(edit) @447fd89   Jul 20, 2018, 11:11:04 AM Sebastian Huber bsp/riscv: Add basic SMP startup Update #3433.
(edit) @6b9ef09   Jul 20, 2018, 8:57:59 AM Sebastian Huber riscv: Add CLINT and PLIC support The CLINT and PLIC need some …
(edit) @f5fd8eb   Jul 19, 2018, 1:12:11 PM Sebastian Huber bsps/riscv: Update linker-symbols.h Update #3433.
(edit) @dda6e06   Jul 19, 2018, 12:45:47 PM Sebastian Huber bsp/riscv: Add reset via for SiFive? Test Finisher Update #3433.
(edit) @3a263a9b   Jul 19, 2018, 12:38:44 PM Sebastian Huber bsp/riscv: Add and use riscv_fdt_get_address() Update #3433.
(edit) @7fe4855   Jul 19, 2018, 11:58:12 AM Sebastian Huber bsp/riscv: Fix HTIF warnings Update #3433.
(edit) @8db3f0e   Jul 19, 2018, 10:11:19 AM Sebastian Huber riscv: Rework exception handling Remove …
(edit) @406dd62   Jul 24, 2018, 9:18:27 AM Sebastian Huber _SMP_Start_multitasking_on_secondary_processor() Pass current …
(edit) @4678d1a   Jul 24, 2018, 8:50:39 AM Sebastian Huber bsps: bsp_start_on_secondary_processor() Pass current processor …
(edit) @0d362ff3   Jul 23, 2018, 12:54:51 PM Sebastian Huber score: _SMP_Inter_processor_interrupt_handler() Pass current …
(edit) @caccc5b   Jul 24, 2018, 9:35:09 AM Sebastian Huber bsps: Fix function declaration warnings
(edit) @61c51db   Jul 24, 2018, 6:25:35 AM Sebastian Huber bsp/beagle: Fix warnings
(edit) @1b57b75   Jul 18, 2018, 5:14:41 AM Sebastian Huber bsp/realview-pbx-a9: Support unassigned processors
(edit) @cf811a4   Jul 9, 2018, 11:12:57 AM amaan.cheval x86_64/console: Add NS16550 polled console driver This addition …
(edit) @76c03152   Jul 9, 2018, 11:12:56 AM amaan.cheval bsp/x86_64: Minimal bootable BSP Current state: - Basic context …
(edit) @1a19239   Jul 6, 2018, 9:20:31 AM Sebastian Huber bsp/riscv: Add console support for NS16550 devices Update #3433.
(edit) @31f90a2   Jul 6, 2018, 11:52:22 AM Sebastian Huber bsp/riscv: Simplify printk() support This is a prepartion to add …
(edit) @bca36d9   Jul 6, 2018, 9:07:20 AM Sebastian Huber riscv: Add LADDR assembler define An address must be loaded to a …
(edit) @dd32e2b2   Jul 6, 2018, 6:12:40 AM Sebastian Huber riscv: Implement CPU counter Update #3433.
(edit) @fc5cc9a   Jul 5, 2018, 6:54:34 AM Sebastian Huber bsps/arm: Include missing header file
(edit) @d3dff40   Jul 4, 2018, 2:15:22 PM Sebastian Huber bsps: Update headers.am
(edit) @0fd8287   Jun 26, 2018, 5:15:28 AM Sebastian Huber riscv: Add _CPU_Get_current_per_CPU_control() Update #3433.
(edit) @3be4478f   Jun 26, 2018, 5:13:28 AM Sebastian Huber riscv: Avoid namespace pollution Remove <rtems/score/riscv-utility.h> …
(edit) @ff7b104   Jun 27, 2018, 5:47:33 AM Sebastian Huber bsp/riscv: Remove bsp_interrupt_handler_default() It duplicated the …
(edit) @cdfed94f   Jun 25, 2018, 9:12:24 AM Sebastian Huber bsp/riscv: Rework clock driver Use device tree provided timebase …
(edit) @1232cd46   Jun 25, 2018, 6:44:16 AM Sebastian Huber bsp/riscv: Add device tree support for console Update #3433.
(edit) @c558cc4   Jun 28, 2018, 11:04:58 AM Sebastian Huber bsp/riscv: Fix vector table for lp64 Update #3433.
(edit) @5f5c450   Jun 22, 2018, 11:58:11 AM Sebastian Huber bsp/riscv: Add SMP startup synchronization Update #3433.
(edit) @fe2cd01   Jun 22, 2018, 6:01:48 AM Sebastian Huber bsp/riscv: Add device tree support Update #3433.
(edit) @2086948a   May 11, 2018, 4:54:59 AM Sebastian Huber riscv: Add dummy SMP support Update #3433.
(edit) @9b2ef07f   Jun 22, 2018, 11:30:21 AM Sebastian Huber bsp/riscv: Load global pointer Update #3433.
(edit) @b0ee789   Jun 22, 2018, 9:14:07 AM Sebastian Huber bsp/riscv: Use memset() to clear .bss Update #3433.
(edit) @52f4fb6   Jun 26, 2018, 5:48:06 AM Sebastian Huber riscv: Format assembler files Use tabs to match the GCC generated …
(edit) @fef0a41   Jun 22, 2018, 7:03:19 AM Sebastian Huber bsp/riscv: Do not clear integer registers at start There is no need …
(edit) @38024362   Jun 22, 2018, 9:00:01 AM Sebastian Huber bsp/riscv: Fix some warnings Update #3444.
(edit) @16d905f   Jun 22, 2018, 5:51:08 AM Sebastian Huber bsp/riscv: Add BSP options to define RAM region Update #3433.
(edit) @f3da074a   Jun 22, 2018, 5:10:44 AM Sebastian Huber bsp/riscv: Add new BSP variants The latest RISC-V tool chain …
