# # ChangeLog for bsps in rtems # # Generated by Trac 1.2.1.dev0 # 05/04/24 21:10:42 Thu, 01 Jul 2021 14:32:41 GMT Sebastian Huber [52fb74c] * bsps/sparc/leon3/include/bsp/irq.h (modified) bsp/leon3: Fix bsp_interrupt_is_valid_vector() The fix to address ... Wed, 30 Jun 2021 13:22:57 GMT Sebastian Huber [f2b0877] * bsps/shared/dev/irq/arm-gicv3.c (modified) bsps: Fix GICv3 support for AArch32 The GICv3 support is shared ... Mon, 28 Jun 2021 13:03:22 GMT Kinsey Moore [c18b041b] * bsps/include/dev/spi/cadence-spi-regs.h (modified) bsps/cadence-spi: Fix moduleid offset Move the moduleid register to ... Wed, 23 Jun 2021 16:57:18 GMT Kinsey Moore [26d61c86] * bsps/aarch64/xilinx-zynqmp/console/console.c (modified) * bsps/shared/dev/serial/zynq-uart-polled.c (modified) * bsps/shared/dev/serial/zynq-uart.c (modified) bsps/zynq-uart: Make post baud change kick global The existing fix ... Thu, 24 Jun 2021 16:02:53 GMT Gedare Bloom [17a9103] * bsps/aarch64/shared/start/start.S (modified) aarch64: whitespace fixes in start.S Thu, 24 Jun 2021 15:33:22 GMT Gedare Bloom [93088fb8] * bsps/aarch64/shared/start/start.S (modified) * spec/build/bsps/aarch64/xilinx-versal/grp_qemu.yml (modified) * spec/build/bsps/aarch64/xilinx-versal/grp_vck190.yml (modified) * spec/build/bsps/aarch64/xilinx-zynqmp/grp_zu3eg.yml (modified) * spec/build/bsps/optstartmon.yml (deleted) bsps/aarch64: replace boot options with asm switch code Wed, 23 Jun 2021 02:01:17 GMT Gedare Bloom [76c6caad] * bsps/aarch64/shared/start/start.S (modified) * bsps/shared/dev/irq/arm-gicv3.c (modified) * spec/build/bsps/aarch64/a53/grp.yml (modified) * spec/build/bsps/aarch64/a72/grp.yml (modified) * spec/build/bsps/aarch64/optisns.yml (added) * spec/build/bsps/aarch64/xilinx-versal/bspqemuilp32.yml (modified) * spec/build/bsps/aarch64/xilinx-versal/bspqemulp64.yml (modified) * spec/build/bsps/aarch64/xilinx-versal/grp.yml (modified) * spec/build/bsps/aarch64/xilinx-versal/grp_qemu.yml (added) * spec/build/bsps/aarch64/xilinx-zynqmp/grp.yml (modified) * spec/build/bsps/optstartmon.yml (added) bsps/aarch64: add non-secure mode and versal support Wed, 23 Jun 2021 01:57:08 GMT Gedare Bloom [2076129] * bsps/aarch64/shared/clock/arm-generic-timer-aarch64.c (modified) * bsps/aarch64/xilinx-versal/include/bsp/irq.h (modified) * spec/build/bsps/aarch64/optgtuseps.yml (added) * spec/build/bsps/aarch64/optgtusevirt.yml (added) bsps/aarch64: add physical secure timer Wed, 23 Jun 2021 01:55:39 GMT Gedare Bloom [bcad0aae] * bsps/shared/dev/irq/arm-gicv3.c (modified) bsps/aarch64: add mnemonic for ICC_IGRPEN1_EL3 Wed, 23 Jun 2021 01:52:28 GMT Gedare Bloom [fedd279f] * bsps/include/dev/irq/arm-gic-regs.h (modified) bsps/dev/irq: make icspicfgr an indexable array Thu, 17 Jun 2021 20:02:30 GMT Kinsey Moore [e613068e] * bsps/aarch64/shared/start/start.S (modified) aarch64: add support to drop EL3 to EL2 Thu, 10 Jun 2021 23:03:03 GMT Gedare Bloom [3705962] * bsps/aarch64/xilinx-versal/console/console.c (added) * bsps/aarch64/xilinx-versal/dev/serial/versal-uart-polled.c (added) * bsps/aarch64/xilinx-versal/include/bsp.h (added) * bsps/aarch64/xilinx-versal/include/bsp/irq.h (added) * bsps/aarch64/xilinx-versal/include/dev/serial/versal-uart-regs.h (added) * bsps/aarch64/xilinx-versal/include/dev/serial/versal-uart.h (added) * bsps/aarch64/xilinx-versal/include/tm27.h (added) * bsps/aarch64/xilinx-versal/start/bspstart.c (added) * bsps/aarch64/xilinx-versal/start/bspstarthooks.c (added) * bsps/aarch64/xilinx-versal/start/bspstartmmu.c (added) * spec/build/bsps/aarch64/xilinx-versal/abi.yml (added) * spec/build/bsps/aarch64/xilinx-versal/bspqemuilp32.yml (added) * spec/build/bsps/aarch64/xilinx-versal/bspqemulp64.yml (added) * spec/build/bsps/aarch64/xilinx-versal/bspvck190ilp32.yml (added) * spec/build/bsps/aarch64/xilinx-versal/bspvck190lp64.yml (added) * spec/build/bsps/aarch64/xilinx-versal/grp.yml (added) * spec/build/bsps/aarch64/xilinx-versal/grp_vck190.yml (added) * spec/build/bsps/aarch64/xilinx-versal/linkcmds_ilp32.yml (added) * spec/build/bsps/aarch64/xilinx-versal/linkcmds_lp64.yml (added) * spec/build/bsps/aarch64/xilinx-versal/obj.yml (added) * spec/build/bsps/aarch64/xilinx-versal/optclkuart.yml (added) * spec/build/bsps/aarch64/xilinx-versal/optconminor.yml (added) * spec/build/bsps/aarch64/xilinx-versal/optloadoff.yml (added) * spec/build/bsps/aarch64/xilinx-versal/optnocachelen.yml (added) * spec/build/bsps/aarch64/xilinx-versal/optramlen.yml (added) * spec/build/bsps/aarch64/xilinx-versal/optramori.yml (added) * spec/build/bsps/aarch64/xilinx-versal/tstqemu.yml (added) * spec/build/bsps/aarch64/xilinx-versal/tstvck190.yml (added) aarch64/xilinx-versal: new BSPs for qemu and vck190 Fri, 18 Jun 2021 14:44:11 GMT Sebastian Huber [be96cb43] * bsps/sparc/erc32/include/bsp.h (modified) * bsps/sparc/erc32/start/bspstart.c (modified) * bsps/sparc/leon2/include/bsp.h (modified) * bsps/sparc/leon2/start/bspstart.c (modified) * bsps/sparc/leon3/include/bsp.h (modified) * bsps/sparc/leon3/start/bspsmp.c (modified) * bsps/sparc/leon3/start/bspstart.c (modified) * bsps/sparc/shared/irq/bsp_isr_handler.c (modified) * bsps/sparc/shared/irq/irq-shared.c (modified) * bsps/sparc/shared/start/start.S (modified) * cpukit/Makefile.am (modified) * cpukit/score/cpu/sparc/cpu_asm.S (modified) * cpukit/score/cpu/sparc/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/sparc-isr-handler.S (added) * spec/build/cpukit/cpusparc.yml (modified) sparc: Simplify trap table initialization Move _ISR_Handler() to a ... Wed, 23 Jun 2021 06:24:49 GMT Sebastian Huber [005c79be] * bsps/include/bsp/irq-generic.h (modified) bsps: bsp_interrupt_handler_dispatch_unchecked() Add ... Tue, 22 Jun 2021 13:40:39 GMT Sebastian Huber [5c30e3d3] * bsps/sparc/erc32/clock/ckinit.c (modified) * bsps/sparc/erc32/include/bsp.h (modified) * bsps/sparc/erc32/include/tm27.h (modified) * bsps/sparc/leon2/clock/ckinit.c (modified) * bsps/sparc/leon2/include/bsp.h (modified) * bsps/sparc/leon2/include/tm27.h (modified) * bsps/sparc/leon3/include/bsp.h (modified) * bsps/sparc/leon3/include/tm27.h (modified) * bsps/sparc/leon3/mpci/mpisr.c (modified) * bsps/sparc/leon3/start/bspsmp.c (modified) bsps/sparc: Use rtems_interrupt_handler_install() Avoid using ... Mon, 21 Jun 2021 09:24:27 GMT Sebastian Huber [d73e657e] * bsps/sparc/erc32/include/bsp.h (modified) * bsps/sparc/erc32/start/bspstart.c (modified) * bsps/sparc/erc32/start/spurious.c (deleted) * bsps/sparc/leon2/include/bsp.h (modified) * bsps/sparc/leon2/start/bspstart.c (modified) * bsps/sparc/leon2/start/spurious.c (deleted) * bsps/sparc/leon3/include/bsp.h (modified) * bsps/sparc/leon3/start/bspstart.c (modified) * bsps/sparc/leon3/start/spurious.c (deleted) * bsps/sparc/shared/start/start.S (modified) * c/src/lib/libbsp/sparc/erc32/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * cpukit/Makefile.am (modified) * cpukit/score/cpu/sparc/cpu.c (modified) * cpukit/score/cpu/sparc/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/sparc/sparc-bad-trap.S (added) * cpukit/score/cpu/sparc/sparc-exception-frame-print.c (added) * spec/build/bsps/sparc/erc32/bsperc32.yml (modified) * spec/build/bsps/sparc/leon2/obj.yml (modified) * spec/build/bsps/sparc/leon3/obj.yml (modified) * spec/build/cpukit/cpusparc.yml (modified) sparc: More reliable bad trap handling Statically initialize the ... Fri, 18 Jun 2021 17:28:28 GMT Sebastian Huber [7a140e2e] * bsps/sparc/shared/start/start.S (modified) bsps/sparc: Add a symbol for each trap table entry This makes it ... Sat, 19 Jun 2021 12:24:26 GMT Sebastian Huber [6b7a3858] * bsps/arm/atsam/include/bsp/irq.h (modified) bsp/atsam: Fix BSP_INTERRUPT_VECTOR_COUNT Fix an off by one error. ... Sat, 19 Jun 2021 12:15:27 GMT Sebastian Huber [fdf2ee7] * bsps/include/bsp/irq-default.h (modified) bsps/irq: Default BSP_INTERRUPT_VECTOR_COUNT == 0 Change the ... Sat, 19 Jun 2021 10:48:27 GMT Sebastian Huber [94cf67c] * bsps/aarch64/a53/include/bsp/irq.h (modified) * bsps/aarch64/a72/include/bsp/irq.h (modified) * bsps/aarch64/xilinx-zynqmp/include/bsp/irq.h (modified) * bsps/arm/altera-cyclone-v/include/bsp/irq.h (modified) * bsps/arm/atsam/include/bsp/irq.h (modified) * bsps/arm/beagle/include/bsp/irq.h (modified) * bsps/arm/csb336/include/bsp/irq.h (modified) * bsps/arm/csb337/include/bsp/irq.h (modified) * bsps/arm/edb7312/include/bsp/irq.h (modified) * bsps/arm/fvp/include/bsp/irq.h (modified) * bsps/arm/gumstix/include/bsp/irq.h (modified) * bsps/arm/imx/include/bsp/irq.h (modified) * bsps/arm/imxrt/include/bsp/irq.h (modified) * bsps/arm/lm3s69xx/include/bsp/irq.h (modified) * bsps/arm/lpc176x/include/bsp/irq.h (modified) * bsps/arm/lpc24xx/include/bsp/irq.h (modified) * bsps/arm/lpc32xx/include/bsp/irq.h (modified) * bsps/arm/raspberrypi/include/bsp/irq.h (modified) * bsps/arm/realview-pbx-a9/include/bsp/irq.h (modified) * bsps/arm/rtl22xx/include/bsp/irq.h (modified) * bsps/arm/smdk2410/include/bsp/irq.h (modified) * bsps/arm/stm32f4/include/bsp/irq.h (modified) * bsps/arm/stm32h7/include/bsp/irq.h (modified) * bsps/arm/tms570/include/bsp/irq.h (modified) * bsps/arm/xen/include/bsp/irq.h (modified) * bsps/arm/xilinx-zynq/include/bsp/irq.h (modified) * bsps/arm/xilinx-zynqmp/include/bsp/irq.h (modified) * bsps/i386/include/bsp/irq.h (modified) * bsps/include/bsp/irq-default.h (modified) * bsps/include/bsp/irq-generic.h (modified) * bsps/lm32/include/bsp/irq.h (modified) * bsps/m68k/genmcf548x/include/bsp/irq.h (modified) * bsps/mips/csb350/include/bsp/irq.h (modified) * bsps/mips/hurricane/include/bsp/irq.h (modified) * bsps/mips/jmr3904/include/bsp/irq.h (modified) * bsps/mips/malta/include/bsp/irq.h (modified) * bsps/mips/rbtx4925/include/bsp/irq.h (modified) * bsps/mips/rbtx4938/include/bsp/irq.h (modified) * bsps/powerpc/gen5200/include/bsp/irq.h (modified) * bsps/powerpc/gen83xx/include/bsp/irq.h (modified) * bsps/powerpc/motorola_powerpc/include/bsp/irq.h (modified) * bsps/powerpc/mpc55xxevb/include/bsp/irq.h (modified) * bsps/powerpc/mpc8260ads/include/bsp/irq.h (modified) * bsps/powerpc/psim/include/bsp/irq.h (modified) * bsps/powerpc/qemuppc/include/bsp/irq.h (modified) * bsps/powerpc/qoriq/include/bsp/irq.h (modified) * bsps/powerpc/t32mppc/include/bsp/irq.h (modified) * bsps/powerpc/tqm8xx/include/bsp/irq.h (modified) * bsps/powerpc/virtex/include/bsp/irq.h (modified) * bsps/riscv/griscv/include/bsp/irq.h (modified) * bsps/riscv/riscv/include/bsp/irq.h (modified) * bsps/sparc/erc32/include/bsp/irq.h (modified) * bsps/sparc/leon2/include/bsp/irq.h (modified) * bsps/sparc/leon3/include/bsp/irq.h (modified) * bsps/x86_64/include/bsp/irq.h (modified) bsps/irq: Remove BSP_INTERRUPT_VECTOR_MAX This define is no longer ... Sat, 19 Jun 2021 10:51:58 GMT Sebastian Huber [3fee6620] * bsps/arm/atsam/start/bspstart.c (modified) * bsps/arm/beagle/irq/irq.c (modified) * bsps/arm/lpc176x/irq/irq.c (modified) * bsps/arm/lpc24xx/irq/irq.c (modified) * bsps/arm/lpc32xx/include/bsp/irq.h (modified) * bsps/arm/shared/irq/irq-armv7m.c (modified) * bsps/arm/shared/start/start.S (modified) * bsps/arm/tms570/irq/irq.c (modified) * bsps/include/bsp/irq-generic.h (modified) * bsps/m68k/genmcf548x/include/bsp/irq.h (modified) * bsps/m68k/genmcf548x/irq/irq.c (modified) * bsps/mips/shared/irq/irq.c (modified) * bsps/powerpc/qoriq/irq/irq.c (modified) * bsps/shared/irq/irq-info.c (modified) * bsps/shared/irq/irq-server.c (modified) * testsuites/smptests/smpcapture02/init.c (modified) bsps/irq: Use BSP_INTERRUPT_VECTOR_COUNT Use ... Sat, 19 Jun 2021 10:53:27 GMT Sebastian Huber [049e2b6] * bsps/include/bsp/irq-generic.h (modified) * bsps/shared/irq/irq-generic.c (modified) bsps/irq: Remove BSP_INTERRUPT_VECTOR_NUMBER Replace it with ... Sat, 19 Jun 2021 10:40:57 GMT Sebastian Huber [cd5573c] * bsps/aarch64/a53/include/bsp/irq.h (modified) * bsps/aarch64/a72/include/bsp/irq.h (modified) * bsps/aarch64/xilinx-zynqmp/include/bsp/irq.h (modified) * bsps/arm/altera-cyclone-v/include/bsp/irq.h (modified) * bsps/arm/atsam/include/bsp/irq.h (modified) * bsps/arm/beagle/include/bsp/irq.h (modified) * bsps/arm/csb336/include/bsp/irq.h (modified) * bsps/arm/csb337/include/bsp/irq.h (modified) * bsps/arm/edb7312/include/bsp/irq.h (modified) * bsps/arm/fvp/include/bsp/irq.h (modified) * bsps/arm/gumstix/include/bsp/irq.h (modified) * bsps/arm/imx/include/bsp/irq.h (modified) * bsps/arm/imxrt/include/bsp/irq.h (modified) * bsps/arm/lm3s69xx/include/bsp/irq.h (modified) * bsps/arm/lpc176x/include/bsp/irq.h (modified) * bsps/arm/lpc24xx/include/bsp/irq.h (modified) * bsps/arm/lpc32xx/include/bsp/irq.h (modified) * bsps/arm/raspberrypi/include/bsp/irq.h (modified) * bsps/arm/realview-pbx-a9/include/bsp/irq.h (modified) * bsps/arm/rtl22xx/include/bsp/irq.h (modified) * bsps/arm/smdk2410/include/bsp/irq.h (modified) * bsps/arm/stm32f4/include/bsp/irq.h (modified) * bsps/arm/stm32h7/include/bsp/irq.h (modified) * bsps/arm/tms570/include/bsp/irq.h (modified) * bsps/arm/xen/include/bsp/irq.h (modified) * bsps/arm/xilinx-zynq/include/bsp/irq.h (modified) * bsps/arm/xilinx-zynqmp/include/bsp/irq.h (modified) * bsps/i386/include/bsp/irq.h (modified) * bsps/include/bsp/irq-default.h (modified) * bsps/include/bsp/irq-generic.h (modified) * bsps/lm32/include/bsp/irq.h (modified) * bsps/m68k/genmcf548x/include/bsp/irq.h (modified) * bsps/mips/csb350/include/bsp/irq.h (modified) * bsps/mips/hurricane/include/bsp/irq.h (modified) * bsps/mips/jmr3904/include/bsp/irq.h (modified) * bsps/mips/malta/include/bsp/irq.h (modified) * bsps/mips/rbtx4925/include/bsp/irq.h (modified) * bsps/mips/rbtx4938/include/bsp/irq.h (modified) * bsps/powerpc/gen5200/include/bsp/irq.h (modified) * bsps/powerpc/gen83xx/include/bsp/irq.h (modified) * bsps/powerpc/motorola_powerpc/include/bsp/irq.h (modified) * bsps/powerpc/mpc55xxevb/include/bsp/irq.h (modified) * bsps/powerpc/mpc8260ads/include/bsp/irq.h (modified) * bsps/powerpc/psim/include/bsp/irq.h (modified) * bsps/powerpc/qemuppc/include/bsp/irq.h (modified) * bsps/powerpc/qoriq/include/bsp/irq.h (modified) * bsps/powerpc/t32mppc/include/bsp/irq.h (modified) * bsps/powerpc/tqm8xx/include/bsp/irq.h (modified) * bsps/powerpc/virtex/include/bsp/irq.h (modified) * bsps/riscv/griscv/include/bsp/irq.h (modified) * bsps/riscv/riscv/include/bsp/irq.h (modified) * bsps/sparc/erc32/include/bsp/irq.h (modified) * bsps/sparc/leon2/include/bsp/irq.h (modified) * bsps/sparc/leon3/include/bsp/irq.h (modified) * bsps/x86_64/include/bsp/irq.h (modified) bsps/irq: Add BSP_INTERRUPT_VECTOR_COUNT Assert ... Fri, 18 Jun 2021 05:37:18 GMT Sebastian Huber [af73b7b6] * bsps/aarch64/a53/include/bsp/irq.h (modified) * bsps/aarch64/a72/include/bsp/irq.h (modified) * bsps/aarch64/xilinx-zynqmp/include/bsp/irq.h (modified) * bsps/arm/altera-cyclone-v/include/bsp/irq.h (modified) * bsps/arm/atsam/include/bsp/irq.h (modified) * bsps/arm/beagle/include/bsp/irq.h (modified) * bsps/arm/beagle/irq/irq.c (modified) * bsps/arm/csb336/include/bsp/irq.h (modified) * bsps/arm/csb337/include/bsp/irq.h (modified) * bsps/arm/edb7312/include/bsp/irq.h (modified) * bsps/arm/fvp/include/bsp/irq.h (modified) * bsps/arm/gumstix/include/bsp/irq.h (modified) * bsps/arm/imx/include/bsp/irq.h (modified) * bsps/arm/imxrt/include/bsp/irq.h (modified) * bsps/arm/lm3s69xx/include/bsp/irq.h (modified) * bsps/arm/lpc176x/include/bsp/irq.h (modified) * bsps/arm/lpc24xx/include/bsp/irq.h (modified) * bsps/arm/lpc24xx/irq/irq.c (modified) * bsps/arm/lpc32xx/include/bsp/irq.h (modified) * bsps/arm/raspberrypi/include/bsp/irq.h (modified) * bsps/arm/realview-pbx-a9/include/bsp/irq.h (modified) * bsps/arm/rtl22xx/include/bsp/irq.h (modified) * bsps/arm/shared/irq/irq-armv7m.c (modified) * bsps/arm/smdk2410/include/bsp/irq.h (modified) * bsps/arm/stm32f4/include/bsp/irq.h (modified) * bsps/arm/stm32h7/include/bsp/irq.h (modified) * bsps/arm/tms570/include/bsp/irq.h (modified) * bsps/arm/xen/include/bsp/irq.h (modified) * bsps/arm/xilinx-zynq/include/bsp/irq.h (modified) * bsps/arm/xilinx-zynqmp/include/bsp/irq.h (modified) * bsps/i386/include/bsp/irq.h (modified) * bsps/include/bsp/irq-default.h (modified) * bsps/include/bsp/irq-generic.h (modified) * bsps/lm32/include/bsp/irq.h (modified) * bsps/m68k/genmcf548x/include/bsp/irq.h (modified) * bsps/mips/csb350/include/bsp/irq.h (modified) * bsps/mips/hurricane/include/bsp/irq.h (modified) * bsps/mips/jmr3904/include/bsp/irq.h (modified) * bsps/mips/malta/include/bsp/irq.h (modified) * bsps/mips/rbtx4925/include/bsp/irq.h (modified) * bsps/mips/rbtx4938/include/bsp/irq.h (modified) * bsps/powerpc/gen5200/include/bsp/irq.h (modified) * bsps/powerpc/gen83xx/include/bsp/irq.h (modified) * bsps/powerpc/motorola_powerpc/include/bsp/irq.h (modified) * bsps/powerpc/mpc55xxevb/include/bsp/irq.h (modified) * bsps/powerpc/mpc8260ads/include/bsp/irq.h (modified) * bsps/powerpc/psim/include/bsp/irq.h (modified) * bsps/powerpc/qemuppc/include/bsp/irq.h (modified) * bsps/powerpc/qoriq/include/bsp/irq.h (modified) * bsps/powerpc/qoriq/irq/irq.c (modified) * bsps/powerpc/t32mppc/include/bsp/irq.h (modified) * bsps/powerpc/tqm8xx/include/bsp/irq.h (modified) * bsps/powerpc/virtex/include/bsp/irq.h (modified) * bsps/riscv/griscv/include/bsp/irq.h (modified) * bsps/riscv/riscv/include/bsp/irq.h (modified) * bsps/shared/irq/irq-info.c (modified) * bsps/sparc/erc32/include/bsp/irq.h (modified) * bsps/sparc/leon2/include/bsp/irq.h (modified) * bsps/sparc/leon3/include/bsp/irq.h (modified) * bsps/x86_64/include/bsp/irq.h (modified) * testsuites/smptests/smpcapture02/init.c (modified) bsps/irq: Remove BSP_INTERRUPT_VECTOR_MIN Remove ... Sat, 19 Jun 2021 09:31:12 GMT Sebastian Huber [f3acb8b] * bsps/include/bsp/irq-generic.h (modified) bsps/irq: Assert BSP_INTERRUPT_VECTOR_MIN == 0 After building all ... Sat, 19 Jun 2021 09:25:34 GMT Sebastian Huber [5210c7c] * bsps/or1k/generic_or1k/include/bsp/irq.h (modified) * bsps/or1k/generic_or1k/irq/irq.c (deleted) * c/src/lib/libbsp/or1k/generic_or1k/Makefile.am (modified) * spec/build/bsps/or1k/generic_or1k/bspgenericor1k.yml (modified) bsp/generic_or1k: Remove incomplete IRQ support Update #3269. Sat, 19 Jun 2021 09:20:02 GMT Sebastian Huber [4146d39] * bsps/m68k/genmcf548x/include/bsp/irq.h (modified) bsp/genmcf548x: Change BSP_INTERRUPT_VECTOR_MIN This BSP uses a ... Thu, 17 Jun 2021 15:35:12 GMT Sebastian Huber [61d0be72] * bsps/include/bsp/irq-generic.h (modified) * bsps/powerpc/mpc55xxevb/include/bsp/irq.h (modified) * bsps/shared/irq/irq-generic.c (modified) bsps/irq: Remove BSP_INTERRUPT_NO_HEAP_USAGE Remove the support for ... Thu, 24 Jun 2021 06:26:02 GMT Sebastian Huber [499a89b] * bsps/shared/grlib/uart/cons.c (modified) grlib: Register system console as /dev/console Close #4461. Wed, 23 Jun 2021 19:20:19 GMT Vijay Kumar Banerjee [8416e7c] * bsps/headers.am (modified) * bsps/include/grlib/greth.h (deleted) * bsps/include/grlib/network_interface_add.h (deleted) * bsps/powerpc/beatnik/headers.am (modified) * bsps/powerpc/beatnik/include/bsp/if_em_pub.h (deleted) * bsps/powerpc/beatnik/include/bsp/if_gfe_pub.h (deleted) * bsps/powerpc/beatnik/include/bsp/if_mve_pub.h (deleted) * bsps/shared/grlib/net/greth.c (deleted) * spec/build/bsps/objgrlib.yml (modified) * spec/build/bsps/powerpc/beatnik/bspbeatnik.yml (modified) bsps/powerpc, bsps/shared: Move remaining legacy networking header files Wed, 23 Jun 2021 06:11:49 GMT Sebastian Huber [a0a8262] * bsps/sparc/leon3/start/amba.c (modified) bsp/leon3: Fix compile error Fix compile error with ... Fri, 11 Jun 2021 07:35:30 GMT Jan Sommer [93f96455] * bsps/i386/pc386/clock/ckinit.c (modified) bsps/i386: Update calibration of TSC to be more accurate Closes #4455 Thu, 17 Jun 2021 14:01:48 GMT Sebastian Huber [3ee19b7a] * bsps/include/bsp/irq-default.h (modified) * bsps/include/bsp/irq-generic.h (modified) * bsps/include/bsp/irq-info.h (modified) * bsps/shared/irq/irq-default-handler.c (modified) * bsps/shared/irq/irq-default.c (modified) * bsps/shared/irq/irq-generic.c (modified) * bsps/shared/irq/irq-info.c (modified) * bsps/shared/irq/irq-legacy.c (modified) * bsps/shared/irq/irq-lock.c (modified) * bsps/shared/irq/irq-server.c (modified) * bsps/shared/irq/irq-shell.c (modified) bsps/irq: Change license to BSD-2-Clause Change license to ... Thu, 10 Jun 2021 13:14:37 GMT Sebastian Huber [11cf6ae3] * bsps/shared/grlib/uart/apbuart_polled.c (modified) grlib: Simplify apbuart_inbyte_nonblocking() Thu, 10 Jun 2021 13:02:36 GMT Sebastian Huber [3af1e5e] * bsps/include/grlib/apbuart.h (modified) * bsps/shared/grlib/uart/apbuart_polled.c (modified) grlib: Fix apbuart_outbyte_polled() prototype Callers usually want ... Thu, 10 Jun 2021 13:01:49 GMT Sebastian Huber [af69a869] * bsps/include/grlib/apbuart.h (modified) * bsps/riscv/griscv/console/printk_support.c (modified) * bsps/shared/grlib/uart/apbuart_cons.c (modified) * bsps/shared/grlib/uart/apbuart_polled.c (modified) * bsps/shared/grlib/uart/apbuart_termios.c (modified) * bsps/sparc/leon3/console/printk_support.c (modified) grlib: Add apbuart_outbyte_wait() Thu, 10 Jun 2021 12:51:38 GMT Sebastian Huber [85febe7b] * bsps/include/grlib/apbuart.h (modified) * bsps/riscv/griscv/console/printk_support.c (modified) * bsps/shared/grlib/uart/apbuart_cons.c (modified) * bsps/shared/grlib/uart/apbuart_polled.c (modified) * bsps/shared/grlib/uart/apbuart_termios.c (modified) * bsps/sparc/leon3/console/printk_support.c (modified) grlib: Remove NL -> CR in apbuart_outbyte_polled() This is already ... Thu, 10 Jun 2021 11:42:18 GMT Sebastian Huber [634a2c06] * bsps/sparc/leon3/console/printk_support.c (modified) bsps/leon3: Auto initialization for printk() Get rid of the hack to ... Thu, 10 Jun 2021 11:04:13 GMT Sebastian Huber [2c07f24] * bsps/include/grlib/ambapp.h (modified) * bsps/include/grlib/grlib_impl.h (modified) * bsps/riscv/griscv/console/console.c (modified) * bsps/riscv/griscv/console/printk_support.c (modified) * bsps/riscv/griscv/include/amba.h (modified) * bsps/riscv/griscv/start/amba.c (modified) * bsps/riscv/griscv/start/bspstart.c (modified) * bsps/shared/grlib/ascs/grascs.c (modified) * bsps/shared/grlib/can/canmux.c (modified) * bsps/shared/grlib/can/satcan.c (modified) * bsps/shared/grlib/slink/grslink.c (modified) * bsps/sparc/leon3/clock/ckinit.c (modified) * bsps/sparc/leon3/console/console.c (modified) * bsps/sparc/leon3/console/printk_support.c (modified) * bsps/sparc/leon3/include/amba.h (modified) * bsps/sparc/leon3/include/leon.h (modified) * bsps/sparc/leon3/start/amba.c (modified) * bsps/sparc/leon3/start/cache.c (modified) * bsps/sparc/leon3/start/cpucounter.c (modified) grlib: Add ambapp_plb() Replace the global variable ambapp_plb with ... Thu, 10 Jun 2021 11:25:26 GMT Sebastian Huber [c4c8d3fd] * bsps/include/grlib/ambapp.h (modified) * bsps/shared/grlib/amba/ambapp.c (modified) grlib: Customizable allocation in ambapp_scan() Make the memory ... Tue, 08 Jun 2021 07:21:30 GMT Sebastian Huber [93afcff7] * bsps/sparc/shared/start/bspgetworkarea.c (modified) * bsps/sparc/shared/start/start.S (modified) bsps/sparc: Simplify memory initialization Directly initialize the ... Tue, 08 Jun 2021 06:53:35 GMT Sebastian Huber [ef5a53b] * bsps/sparc/shared/start/start.S (modified) bsps/sparc: Simplify stack initialization Initialize the stacks for ... Tue, 08 Jun 2021 06:08:43 GMT Sebastian Huber [b823c98] * bsps/sparc/shared/start/start.S (modified) bsps/sparc: Unify stack initialization Initialize the stacks in ... Tue, 08 Jun 2021 06:13:54 GMT Sebastian Huber [07f6a61d] * bsps/sparc/shared/start/start.S (modified) bsps/sparc: Remove support to load data section Remove the support ... Tue, 08 Jun 2021 07:32:08 GMT Sebastian Huber [7b8119a] * bsps/sparc/shared/start/start.S (modified) bsps/sparc: Remove unused __bsp_mem_init symbol Tue, 08 Jun 2021 19:59:35 GMT Gedare Bloom [8299b79] * bsps/aarch64/a72/console/console.c (added) * bsps/aarch64/a72/include/bsp.h (added) * bsps/aarch64/a72/include/bsp/irq.h (added) * bsps/aarch64/a72/include/tm27.h (added) * bsps/aarch64/a72/start/bspstart.c (added) * bsps/aarch64/a72/start/bspstarthooks.c (added) * spec/build/bsps/aarch64/a72/abi.yml (added) * spec/build/bsps/aarch64/a72/bspa72ilp32qemu.yml (added) * spec/build/bsps/aarch64/a72/bspa72lp64qemu.yml (added) * spec/build/bsps/aarch64/a72/grp.yml (added) * spec/build/bsps/aarch64/a72/linkcmds_ilp32.yml (added) * spec/build/bsps/aarch64/a72/linkcmds_lp64.yml (added) * spec/build/bsps/aarch64/a72/obj.yml (added) * spec/build/bsps/aarch64/a72/optloadoff.yml (added) * spec/build/bsps/aarch64/a72/optnocachelen.yml (added) * spec/build/bsps/aarch64/a72/optramlen.yml (added) * spec/build/bsps/aarch64/a72/optramori.yml (added) * spec/build/bsps/aarch64/a72/tsta72.yml (added) aarch64: add qemu bsps for cortex-a72 The a72 BSPs are identical to ... Mon, 07 Jun 2021 07:37:51 GMT Sebastian Huber [55ce66ca] * bsps/arm/fvp/start/bspstarthooks.c (modified) arm/fvp: Fix integer from pointer without a cast Update #4202. Fri, 30 Apr 2021 17:14:48 GMT Ryan Long [ea41722c] * bsps/arm/csb337/umon/tfsDriver.c (modified) * cpukit/Makefile.am (modified) * cpukit/include/rtems/confdefs/libio.h (modified) * cpukit/include/rtems/imfs.h (modified) * cpukit/include/rtems/libio.h (modified) * cpukit/libcsupport/src/__usrenv.c (modified) * cpukit/libcsupport/src/futimens.c (modified) * cpukit/libcsupport/src/utimensat.c (modified) * cpukit/libfs/src/defaults/default_ops.c (modified) * cpukit/libfs/src/defaults/default_utime.c (deleted) * cpukit/libfs/src/defaults/default_utimens.c (added) * cpukit/libfs/src/dosfs/msdos_init.c (modified) * cpukit/libfs/src/ftpfs/ftpfs.c (modified) * cpukit/libfs/src/ftpfs/tftpDriver.c (modified) * cpukit/libfs/src/imfs/imfs_init.c (modified) * cpukit/libfs/src/imfs/imfs_utime.c (deleted) * cpukit/libfs/src/imfs/imfs_utimens.c (added) * cpukit/libfs/src/jffs2/src/fs-rtems.c (modified) * cpukit/libfs/src/rfs/rtems-rfs-rtems.c (modified) * spec/build/cpukit/librtemscpu.yml (modified) Change filesystem utime_h handler to utimens_h Also updated ... Tue, 18 May 2021 19:51:46 GMT Kinsey Moore [5fe49a08] * bsps/aarch64/include/bsp/aarch64-mmu.h (added) * bsps/aarch64/include/bsp/linker-symbols.h (modified) * bsps/aarch64/xilinx-zynqmp/include/bsp.h (modified) * bsps/aarch64/xilinx-zynqmp/start/bspstarthooks.c (modified) * bsps/aarch64/xilinx-zynqmp/start/bspstartmmu.c (added) * cpukit/score/cpu/aarch64/aarch64-exception-default.S (modified) * spec/build/bsps/aarch64/optmmupages.yml (added) * spec/build/bsps/aarch64/xilinx-zynqmp/grp.yml (modified) * spec/build/bsps/aarch64/xilinx-zynqmp/linkcmds_ilp32.yml (modified) * spec/build/bsps/aarch64/xilinx-zynqmp/linkcmds_lp64.yml (modified) * spec/build/bsps/aarch64/xilinx-zynqmp/obj.yml (modified) bsps/aarch64: Add MMU driver to relax alignment Currently, the ... Tue, 18 May 2021 19:49:20 GMT Kinsey Moore [8810e08] * bsps/aarch64/shared/cache/cache.c (modified) bsps/aarch64: Advertise cache function support Ensure that cache ... Tue, 18 May 2021 12:56:54 GMT Kinsey Moore [12ec459] * bsps/aarch64/shared/cache/cache.c (modified) bsps/aarch64: Align MVAs consistently This fixes a bug where ... Tue, 18 May 2021 12:55:11 GMT Kinsey Moore [25ca2ec] * bsps/aarch64/shared/cache/cache.c (modified) * cpukit/score/cpu/aarch64/include/rtems/score/aarch64-system-registers.h (added) * spec/build/cpukit/cpuaarch64.yml (modified) bsps/aarch64: Break out system registers Break out system register ... Fri, 21 May 2021 21:29:42 GMT Joel Sherrill [402a206a] * bsps/powerpc/shared/start/sbrk.c (modified) powerpc/.../sbrk.c: Do not reference errno. Closes #4r37. Fri, 21 May 2021 21:29:00 GMT Joel Sherrill [f9d59075] * bsps/powerpc/shared/irq/ppc-irq-legacy.c (modified) ppc-irq-legacy.c: Use rtems_malloc() instead of malloc(). Closes #4438. Mon, 17 May 2021 11:35:42 GMT Sebastian Huber [d45f87cf] * bsps/powerpc/shared/cpu_asm.S (modified) * cpukit/score/cpu/arm/cpu_asm.S (modified) * cpukit/score/cpu/arm/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/riscv/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/riscv/riscv-context-switch.S (modified) * cpukit/score/cpu/sparc/cpu_asm.S (modified) * cpukit/score/cpu/sparc/include/rtems/score/cpu.h (modified) * cpukit/score/src/threadstartmultitasking.c (modified) score: Add _CPU_Context_switch_no_return() The ... Wed, 12 May 2021 09:34:52 GMT Christian Mauderer [15e26f4] * bsps/arm/imxrt/start/bspstarthooks.c (modified) bsps/imxrt: Enable DMA clock The EDMA is intialized so make sure ... Tue, 11 May 2021 11:46:56 GMT Christian Mauderer [691fec40] * bsps/arm/imxrt/include/imxrt/memory.h (modified) * bsps/arm/imxrt/start/linkcmds.ocram (added) * bsps/arm/imxrt/start/mpu-config.c (modified) * spec/build/bsps/arm/imxrt/bspimxrt.yml (modified) * spec/build/bsps/arm/imxrt/linkcmdsmemory.yml (modified) * spec/build/bsps/arm/imxrt/optlinkcmds.yml (modified) * spec/build/bsps/arm/imxrt/optmemdtcmsz.yml (added) * spec/build/bsps/arm/imxrt/optmemitcmsz.yml (added) * spec/build/bsps/arm/imxrt/optmemocramnocachesz.yml (added) * spec/build/bsps/arm/imxrt/optmemocramsz.yml (added) bsps/imxrt: Fix OCRAM, ITCM and DTCM sizes The sizes are ... Mon, 12 Apr 2021 14:53:43 GMT Christian Mauderer [988cc1a] * bsps/arm/imxrt/dts/imxrt1050-evkb.c (modified) * bsps/arm/imxrt/include/imxrt/imxrt1050.dtsi (modified) bsps/imxrt: Add addresses and interrupts to dts Add addresses and ... Wed, 12 May 2021 06:46:30 GMT Christian Mauderer [c3056666] * bsps/arm/imxrt/dts/imxrt1050-evkb.c (modified) * bsps/arm/imxrt/dts/imxrt1050-evkb.dts (modified) bsps/imxrt: Reduce devicetree size Remove symbols that would be ... Wed, 07 Apr 2021 13:05:26 GMT Christian Mauderer [08e4e6f2] * bsps/arm/imxrt/include/fsl_qtmr.h (modified) bsps/imxrt: Fix documentation error Update #4180 Mon, 17 May 2021 06:04:07 GMT Sebastian Huber [98cb84e] * bsps/arm/altera-cyclone-v/rtc/rtc.c (modified) arm/altera-cyclone-v: Fix compile error Update #4406. Tue, 11 May 2021 15:27:20 GMT Sebastian Huber [523867d] * bsps/arm/altera-cyclone-v/rtc/rtc.c (modified) * bsps/shared/dev/rtc/rtc-support.c (modified) * cpukit/include/rtems/rtems/clockimpl.h (modified) * cpukit/include/rtems/rtems/tasks.h (modified) * cpukit/rtems/src/clockset.c (modified) * cpukit/rtems/src/clocktodvalidate.c (modified) * cpukit/rtems/src/taskwakewhen.c (modified) * cpukit/rtems/src/timercreate.c (modified) * testsuites/sptests/sp2038/init.c (modified) rtems: Constify rtems_task_wake_when() Add a parameter to ... Tue, 11 May 2021 14:26:55 GMT Frank Kühndel [3af2dc7] * bsps/arm/altera-cyclone-v/rtc/rtc.c (modified) * bsps/shared/dev/rtc/rtc-support.c (modified) * cpukit/include/rtems/rtems/clockimpl.h (modified) * cpukit/rtems/src/clockset.c (modified) * cpukit/rtems/src/clocktodvalidate.c (modified) * cpukit/rtems/src/taskwakewhen.c (modified) * cpukit/rtems/src/timercreate.c (modified) * testsuites/sptests/sp2038/init.c (modified) _TOD_Validate(): Fix incorrect return code This patch fixes bug ... Thu, 06 May 2021 08:06:02 GMT G S Niteesh Babu [b391affc] * bsps/shared/ofw/ofw.c (modified) bsps/shared/ofw: Fix coverity defects This patch adds asserts to ... Fri, 30 Apr 2021 13:47:10 GMT Sebastian Huber [e10dec0] * bsps/arm/include/bsp/arm-cp15-start.h (modified) * bsps/arm/include/bsp/linker-symbols.h (modified) * bsps/arm/shared/start/linkcmds.base (modified) * bsps/bfin/TLL6527M/start/linkcmds (modified) * bsps/bfin/bf537Stamp/start/linkcmds (modified) * bsps/bfin/eZKit533/start/linkcmds (modified) * bsps/i386/pc386/start/linkcmds (modified) * bsps/lm32/lm32_evr/start/linkcmds (modified) * bsps/lm32/milkymist/start/linkcmds (modified) * bsps/m68k/av5282/start/linkcmds (modified) * bsps/m68k/av5282/start/linkcmdsflash (modified) * bsps/m68k/av5282/start/linkcmdsram (modified) * bsps/m68k/csb360/start/linkcmds (modified) * bsps/m68k/gen68340/start/linkcmds (modified) * bsps/m68k/gen68360/start/linkcmds (modified) * bsps/m68k/gen68360/start/linkcmds.bootp (modified) * bsps/m68k/gen68360/start/linkcmds.prom (modified) * bsps/m68k/mcf5206elite/start/linkcmds (modified) * bsps/m68k/mcf5206elite/start/linkcmds.flash (modified) * bsps/m68k/mcf52235/start/linkcmds (modified) * bsps/m68k/mcf5225x/start/linkcmds (modified) * bsps/m68k/mcf5235/start/linkcmds (modified) * bsps/m68k/mcf5235/start/linkcmdsflash (modified) * bsps/m68k/mcf5235/start/linkcmdsram (modified) * bsps/m68k/mcf5329/start/linkcmds (modified) * bsps/m68k/mcf5329/start/linkcmdsflash (modified) * bsps/m68k/mrm332/start/linkcmds (modified) * bsps/m68k/shared/start/linkcmds.base (modified) * bsps/m68k/uC5282/start/linkcmds (modified) * bsps/mips/csb350/start/linkcmds (modified) * bsps/mips/hurricane/start/linkcmds (modified) * bsps/mips/jmr3904/start/linkcmds (modified) * bsps/mips/malta/start/linkcmds (modified) * bsps/mips/rbtx4925/start/linkcmds (modified) * bsps/mips/rbtx4938/start/linkcmds (modified) * bsps/moxie/moxiesim/start/linkcmds (modified) * bsps/nios2/nios2_iss/start/linkcmds (modified) * bsps/or1k/shared/start/linkcmds.base (modified) * bsps/powerpc/gen5200/start/linkcmds.gen5200_base (modified) * bsps/powerpc/haleakala/start/linkcmds (modified) * bsps/powerpc/include/bsp/linker-symbols.h (modified) * bsps/powerpc/mpc8260ads/start/linkcmds (modified) * bsps/powerpc/qoriq/start/mmu-config.c (modified) * bsps/powerpc/shared/start/linkcmds.base (modified) * bsps/powerpc/shared/start/linkcmds.share (modified) * bsps/powerpc/ss555/start/linkcmds (modified) * bsps/powerpc/virtex4/start/linkcmds (modified) * bsps/powerpc/virtex5/start/linkcmds (modified) * bsps/riscv/include/bsp/linker-symbols.h (modified) * bsps/riscv/shared/start/linkcmds.base.in (modified) * bsps/sh/gensh1/start/linkcmds (modified) * bsps/sh/gensh2/start/linkcmds (modified) * bsps/sh/gensh2/start/linkcmds.ram (modified) * bsps/sh/gensh2/start/linkcmds.rom (modified) * bsps/sh/gensh4/start/linkcmds (modified) * bsps/sh/gensh4/start/linkcmds.rom (modified) * bsps/sh/gensh4/start/linkcmds.rom2ram (modified) * bsps/sh/shsim/start/linkcmds (modified) * bsps/sparc/shared/start/linkcmds.base (modified) * bsps/sparc64/shared/start/linkcmds (modified) * bsps/v850/gdbv850sim/start/linkcmds (modified) * bsps/x86_64/amd64/start/linkcmds (modified) bsps: Support RTEMS_NOINIT in linkcmds Update #3866. Thu, 29 Apr 2021 11:42:00 GMT Sebastian Huber [263e00b] * bsps/arm/include/bsp/arm-cp15-start.h (modified) bsps/arm: ARMV7_CP15_START_WORKSPACE_ENTRY_INDEX Change the ... Tue, 27 Apr 2021 17:48:47 GMT Peter Dufault [f8b91c9] * bsps/powerpc/shared/console/uart.c (modified) powerpc/shared/console: "termios" first open sets console baud to ... Tue, 27 Apr 2021 17:48:46 GMT Peter Dufault [9c13e52] * bsps/powerpc/shared/console/console.c (modified) * bsps/powerpc/shared/console/uart.c (modified) * c/src/lib/libbsp/powerpc/beatnik/configure.ac (modified) * c/src/lib/libbsp/powerpc/haleakala/configure.ac (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/configure.ac (modified) * c/src/lib/libbsp/powerpc/mvme3100/configure.ac (modified) * c/src/lib/libbsp/powerpc/mvme5500/configure.ac (modified) * spec/build/bsps/optconsolebaud.yml (modified) * spec/build/bsps/powerpc/beatnik/bspbeatnik.yml (modified) * spec/build/bsps/powerpc/haleakala/bsphaleakala.yml (modified) * spec/build/bsps/powerpc/motorola_powerpc/obj.yml (modified) * spec/build/bsps/powerpc/mvme3100/bspmvme3100.yml (modified) * spec/build/bsps/powerpc/mvme5500/bspmvme5500.yml (modified) powerpc/shared/console: Make console baud rate configurable. The ... Sun, 25 Apr 2021 04:26:45 GMT Vijay Kumar Banerjee [e29d5cd] * bsps/headers.am (modified) * bsps/shared/grlib-sources.am (modified) * bsps/shared/shared-sources.am (modified) * c/src/lib/libbsp/arm/atsam/Makefile.am (modified) * c/src/lib/libbsp/arm/csb336/Makefile.am (modified) * c/src/lib/libbsp/arm/csb337/Makefile.am (modified) * c/src/lib/libbsp/arm/edb7312/Makefile.am (modified) * c/src/lib/libbsp/arm/gumstix/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc24xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc32xx/Makefile.am (modified) * c/src/lib/libbsp/arm/rtl22xx/Makefile.am (modified) * c/src/lib/libbsp/bfin/bf537Stamp/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/lm32/lm32_evr/Makefile.am (modified) * c/src/lib/libbsp/lm32/milkymist/Makefile.am (modified) * c/src/lib/libbsp/m68k/av5282/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/Makefile.am (modified) * c/src/lib/libbsp/m68k/genmcf548x/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5235/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5329/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/Makefile.am (modified) * c/src/lib/libbsp/m68k/uC5282/Makefile.am (modified) * c/src/lib/libbsp/mips/csb350/Makefile.am (modified) * c/src/lib/libbsp/powerpc/beatnik/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen5200/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen83xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/haleakala/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme3100/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme5500/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qoriq/Makefile.am (modified) * c/src/lib/libbsp/powerpc/tqm8xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex/Makefile.am (modified) * c/src/lib/libbsp/riscv/griscv/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/make/Makefile.am (modified) * cpukit/Makefile.am (modified) * cpukit/headers.am (modified) * testsuites/libtests/Makefile.am (modified) * testsuites/samples/Makefile.am (modified) Makefile.am: Remove legacy networking files Mon, 26 Apr 2021 09:20:32 GMT Robin Mueller [3764935] * bsps/arm/stm32h7/start/bspstart.c (modified) Implementation for STM32 HAL_GetTick using RTEMS Uses configured ... Sat, 10 Apr 2021 19:15:27 GMT G S Niteesh Babu [d75b29d] * bsps/arm/beagle/i2c/bbb-i2c.c (modified) * bsps/arm/beagle/include/bsp.h (modified) * bsps/arm/beagle/include/bsp/i2c.h (modified) * bsps/arm/beagle/start/bspstart.c (modified) bsps/beagle: Refactored i2c driver Refactored the i2c driver to ... Fri, 16 Apr 2021 05:50:21 GMT Sebastian Huber [2a24f99d] * bsps/arm/shared/start/start.S (modified) bsps/arm: Set MSP in ARMv7-M start code Set the Main Stack Pointer ... Tue, 20 Apr 2021 07:33:52 GMT Sebastian Huber [2b32146] * bsps/include/bsp/bootcard.h (modified) * cpukit/libcsupport/src/newlibc_reent.c (modified) * cpukit/posix/src/psignal.c (modified) * cpukit/posix/src/psignalclearsignals.c (modified) * cpukit/posix/src/psignalsetprocesssignals.c (modified) * cpukit/posix/src/psignalunblockthread.c (modified) * cpukit/sapi/src/exinit.c (modified) * cpukit/score/cpu/bfin/cpu.c (modified) * cpukit/score/cpu/lm32/cpu.c (modified) * cpukit/score/cpu/mips/cpu.c (modified) * cpukit/score/cpu/moxie/cpu.c (modified) * cpukit/score/cpu/no_cpu/cpu.c (modified) * cpukit/score/cpu/or1k/cpu.c (modified) * cpukit/score/cpu/v850/cpu.c (modified) * cpukit/score/cpu/x86_64/cpu.c (modified) * cpukit/score/src/coremsgflushwait.c (modified) * cpukit/score/src/coremsgsubmit.c (modified) * cpukit/score/src/objectinitializeinformation.c (modified) * cpukit/score/src/schedulercbscleanup.c (modified) * cpukit/score/src/schedulercbsdestroyserver.c (modified) * cpukit/score/src/threaddispatch.c (modified) * cpukit/score/src/threadrestart.c (modified) Remove superfluous includes Tue, 20 Apr 2021 16:31:31 GMT Robin Mueller [100c050c] * bsps/arm/stm32h7/start/bspstart.c (modified) Updated tick implementation for HAL_GetTick This now uses ... Fri, 12 Mar 2021 15:59:40 GMT Kinsey Moore [3ea43bc] * bsps/aarch64/xilinx-zynqmp/console/console.c (modified) * bsps/shared/dev/serial/zynq-uart-polled.c (modified) bsps/xilinx-zynqmp: Avoid constant UART reinit Constantly ... Fri, 09 Apr 2021 06:28:40 GMT Moyano, Gabriel [5728e8e3] * bsps/shared/grlib/irq/genirq.c (modified) grlib/genirq: Taking into account that it could be more than one ISR ... Mon, 15 Mar 2021 16:39:27 GMT Ryan Long [3cd58bd] * bsps/shared/dev/display/disp_hcms29xx.c (modified) disp_hcms29xx.c: Unused value (CID #1399752) CID 1399752: Unused ... Thu, 25 Feb 2021 02:09:56 GMT Vijay Kumar Banerjee [c90fa83] * bsps/arm/atsam/net/if_atsam.c (deleted) * bsps/arm/csb336/net/lan91c11x.c (deleted) * bsps/arm/csb336/net/lan91c11x.h (deleted) * bsps/arm/csb336/net/network.c (deleted) * bsps/arm/csb337/net/network.c (deleted) * bsps/arm/edb7312/net/network.c (deleted) * bsps/arm/gumstix/net/rtl8019.c (deleted) * bsps/arm/gumstix/net/wd80x3.h (deleted) * bsps/arm/rtl22xx/net/network.c (deleted) * bsps/arm/shared/net/lpc-ethernet.c (deleted) * bsps/bfin/bf537Stamp/net/ethernet.c (deleted) * bsps/bfin/bf537Stamp/net/networkconfig.c (deleted) * bsps/i386/pc386/net/3c509.c (deleted) * bsps/i386/pc386/net/3c509.h (deleted) * bsps/i386/pc386/net/elink.c (deleted) * bsps/i386/pc386/net/elink.h (deleted) * bsps/i386/pc386/net/ne2000.c (deleted) * bsps/i386/pc386/net/wd8003.c (deleted) * bsps/include/libchip/cs8900.h (deleted) * bsps/include/libchip/i82586var.h (deleted) * bsps/include/libchip/if_dcreg.h (deleted) * bsps/include/libchip/if_fxpvar.h (deleted) * bsps/include/libchip/open_eth.h (deleted) * bsps/include/libchip/smc91111.h (deleted) * bsps/include/libchip/smc91111exp.h (deleted) * bsps/include/libchip/sonic.h (deleted) * bsps/lm32/shared/net/dp83848phy.h (deleted) * bsps/lm32/shared/net/network.c (deleted) * bsps/lm32/shared/net/network.h (deleted) * bsps/lm32/shared/net/tsmac.c (deleted) * bsps/lm32/shared/net/tsmac.h (deleted) * bsps/m68k/av5282/net/network.c (deleted) * bsps/m68k/csb360/net/network.c (deleted) * bsps/m68k/gen68360/net/network.c (deleted) * bsps/m68k/genmcf548x/net/network.c (deleted) * bsps/m68k/mcf5235/net/network.c (deleted) * bsps/m68k/mcf5329/net/network.c (deleted) * bsps/m68k/mvme167/net/network.c (deleted) * bsps/m68k/mvme167/net/uti596.h (deleted) * bsps/m68k/uC5282/net/network.c (deleted) * bsps/mips/csb350/net/network.c (deleted) * bsps/powerpc/beatnik/net/if_em/LICENSE (deleted) * bsps/powerpc/beatnik/net/if_em/README (deleted) * bsps/powerpc/beatnik/net/if_em/if_em.c (deleted) * bsps/powerpc/beatnik/net/if_em/if_em.h (deleted) * bsps/powerpc/beatnik/net/if_em/if_em_hw.c (deleted) * bsps/powerpc/beatnik/net/if_em/if_em_hw.h (deleted) * bsps/powerpc/beatnik/net/if_em/if_em_osdep.h (deleted) * bsps/powerpc/beatnik/net/if_em/if_em_rtems.c (deleted) * bsps/powerpc/beatnik/net/if_em/rtemscompat_defs.h (deleted) * bsps/powerpc/beatnik/net/if_gfe/gtethreg.h (deleted) * bsps/powerpc/beatnik/net/if_gfe/gtvar.h (deleted) * bsps/powerpc/beatnik/net/if_gfe/if_gfe.c (deleted) * bsps/powerpc/beatnik/net/if_gfe/if_gfe_rtems.c (deleted) * bsps/powerpc/beatnik/net/if_gfe/if_gfevar.h (deleted) * bsps/powerpc/beatnik/net/if_gfe/rtemscompat_defs.h (deleted) * bsps/powerpc/beatnik/net/if_mve/mv643xx_eth.c (deleted) * bsps/powerpc/beatnik/net/if_mve/mve_smallbuf_tst.c (deleted) * bsps/powerpc/beatnik/net/if_mve/testing.c (deleted) * bsps/powerpc/beatnik/net/porting/LICENSE (deleted) * bsps/powerpc/beatnik/net/porting/Makefile.template (deleted) * bsps/powerpc/beatnik/net/porting/README (deleted) * bsps/powerpc/beatnik/net/porting/if_xxx.modini.c (deleted) * bsps/powerpc/beatnik/net/porting/if_xxx_rtems.c (deleted) * bsps/powerpc/beatnik/net/porting/pcireg.h (deleted) * bsps/powerpc/beatnik/net/porting/rtemscompat.h (deleted) * bsps/powerpc/beatnik/net/porting/rtemscompat1.h (deleted) * bsps/powerpc/beatnik/net/porting/rtemscompat_defs.h.template (deleted) * bsps/powerpc/beatnik/net/support/bsp_attach.c (deleted) * bsps/powerpc/beatnik/net/support/early_link_status.c (deleted) * bsps/powerpc/gen5200/net/network.c (deleted) * bsps/powerpc/gen83xx/net/network.c (deleted) * bsps/powerpc/haleakala/net/network.c (deleted) * bsps/powerpc/mpc55xxevb/net/if_smc.c (deleted) * bsps/powerpc/mpc55xxevb/net/smsc9218i.c (deleted) * bsps/powerpc/mpc8260ads/net/README (deleted) * bsps/powerpc/mpc8260ads/net/if_hdlcsubr.c (deleted) * bsps/powerpc/mpc8260ads/net/if_hdlcsubr.h (deleted) * bsps/powerpc/mpc8260ads/net/network.c (deleted) * bsps/powerpc/mvme3100/net/tsec.c (deleted) * bsps/powerpc/mvme5500/net/if_100MHz/GT64260eth.c (deleted) * bsps/powerpc/mvme5500/net/if_1GHz/if_wm.c (deleted) * bsps/powerpc/mvme5500/net/if_1GHz/pci_map.c (deleted) * bsps/powerpc/psim/net/README (deleted) * bsps/powerpc/psim/net/gdb-6.8-psim-hw_ethtap.diff (deleted) * bsps/powerpc/psim/net/if_sim.c (deleted) * bsps/powerpc/qoriq/net/if_intercom.c (deleted) * bsps/powerpc/qoriq/net/network.c (deleted) * bsps/powerpc/shared/net/tsec.c (deleted) * bsps/powerpc/tqm8xx/net/network_fec.c (deleted) * bsps/powerpc/tqm8xx/net/network_scc.c (deleted) * bsps/powerpc/virtex/net/xiltemac.c (deleted) * bsps/riscv/griscv/net/griscv_greth.c (deleted) * bsps/shared/grlib/net/README (deleted) * bsps/shared/grlib/net/network_interface_add.c (deleted) * bsps/shared/net/README (deleted) * bsps/shared/net/README.3com (deleted) * bsps/shared/net/README.cs8900 (deleted) * bsps/shared/net/README.dec21140 (deleted) * bsps/shared/net/README.i82586 (deleted) * bsps/shared/net/README.open_eth (deleted) * bsps/shared/net/README.sonic (deleted) * bsps/shared/net/README.tulipclone (deleted) * bsps/shared/net/cs8900.c (deleted) * bsps/shared/net/cs8900.c.bsp (deleted) * bsps/shared/net/cs8900.h.bsp (deleted) * bsps/shared/net/dec21140.c (deleted) * bsps/shared/net/elnk.c (deleted) * bsps/shared/net/greth2.c (deleted) * bsps/shared/net/i82586.c (deleted) * bsps/shared/net/i82586reg.h (deleted) * bsps/shared/net/if_dc.c (deleted) * bsps/shared/net/if_fxp.c (deleted) * bsps/shared/net/if_fxpreg.h (deleted) * bsps/shared/net/open_eth.c (deleted) * bsps/shared/net/smc91111.c (deleted) * bsps/shared/net/smc91111config.h (deleted) * bsps/shared/net/sonic.c (deleted) * bsps/sparc/erc32/net/erc32sonic.c (deleted) * bsps/sparc/leon2/net/leon_open_eth.c (deleted) * bsps/sparc/leon2/net/leon_smc91111.c (deleted) * bsps/sparc/leon3/net/leon_greth.c (deleted) * bsps/sparc/leon3/net/leon_open_eth.c (deleted) * bsps/sparc/leon3/net/leon_smc91111.c (deleted) * spec/build/bsps/objgrlib.yml (modified) * spec/build/bsps/objgrlibnet.yml (deleted) * spec/build/bsps/sparc/leon3/objnetnosmp.yml (deleted) bsps: Remove networking drivers Update #3850 Tue, 06 Apr 2021 07:56:41 GMT Sebastian Huber [05cd707d] * bsps/arm/stm32h7/console/console-usart3-cfg.c (modified) * spec/build/bsps/arm/stm32h7/grp.yml (modified) * spec/build/bsps/arm/stm32h7/optusart3gpiopins.yml (added) * spec/build/bsps/arm/stm32h7/optusart3gpioregs.yml (added) arm/stm32h7: Add STM32H7_USART3_GPIO_* Tue, 06 Apr 2021 07:43:23 GMT Sebastian Huber [6bb6b69b] * bsps/arm/stm32h7/include/stm32h7xx_hal_conf.h (modified) * spec/build/bsps/arm/stm32h7/grp.yml (modified) * spec/build/bsps/arm/stm32h7/opthse.yml (added) arm/stm32h7: Add STM32H7_HSE_FREQUENCY Tue, 02 Mar 2021 15:14:41 GMT Christian Mauderer [8fd29cfb] * bsps/arm/stm32h7/hal/stm32h7xx_hal_sd.c (modified) * bsps/arm/stm32h7/start/stm32h7-hal-sdmmc.c (added) * spec/build/bsps/arm/stm32h7/bspstm32h7.yml (modified) stm32h7: Add init for sdmmc pins Update #4372 Tue, 02 Mar 2021 13:00:50 GMT Christian Mauderer [aa9e3c62] * bsps/arm/stm32h7/include/stm32h7/hal.h (modified) * bsps/arm/stm32h7/start/stm32h7-hal.c (modified) stm32h7: Add SDMMC modules to clock Update #4372 Wed, 02 Dec 2020 12:42:00 GMT Jan Sommer [33fd915] * bsps/headers.am (modified) * c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am (modified) * c/src/lib/libbsp/arm/xilinx-zynqmp/Makefile.am (modified) bsps/xilinx_zynq: Add Xilinx AXI SPI driver to autotools build ... Thu, 25 Feb 2021 16:52:03 GMT Jan Sommer [70667b55] * bsps/include/dev/spi/xilinx-axi-spi-regs.h (added) * bsps/include/dev/spi/xilinx-axi-spi.h (added) * bsps/shared/dev/spi/xilinx-axi-spi.c (added) bsps/xilinx_zynq: Add SPI driver for xilinx-axi-spi Updates #4321 Fri, 19 Mar 2021 11:12:09 GMT Jan Sommer [1343fb5f] * bsps/include/bsp/fatal.h (modified) * bsps/riscv/riscv/clock/clockdrv.c (modified) bsps/riscv: Add per cpu clock interrupt - Fixes failure of test ... Sat, 13 Mar 2021 11:02:03 GMT G S Niteesh Babu [5607464] * bsps/arm/beagle/start/bspstart.c (modified) * bsps/include/arm/ti/ti_pinmux.h (modified) * bsps/shared/freebsd/sys/arm/ti/am335x/am335x_scm_padconf.c (modified) * bsps/shared/freebsd/sys/arm/ti/ti_pinmux.c (modified) * spec/build/bsps/obj.yml (modified) bsp/beagle: Ported Beagle pinmux driver to RTEMS The following ... Sat, 13 Mar 2021 11:02:02 GMT G S Niteesh Babu [7589f1e0] * bsps/arm/beagle/start/bsp-soc-detect.c (added) * bsps/arm/beagle/start/bsp-soc-detect.h (added) * bsps/arm/beagle/start/bspstart.c (modified) * bsps/include/arm/ti/ti_cpuid.h (added) * spec/build/bsps/arm/beagle/obj.yml (modified) bsps/beagle: Added SOC detection using FDT Detects the SOC type ... Sat, 13 Mar 2021 11:02:01 GMT G S Niteesh Babu [5c656ead] * bsps/include/arm/ti/am335x/am335x_scm_padconf.h (added) * bsps/include/arm/ti/ti_pinmux.h (added) * bsps/shared/freebsd/sys/arm/ti/am335x/am335x_scm_padconf.c (added) * bsps/shared/freebsd/sys/arm/ti/ti_pinmux.c (added) bsp/beagle: Import Beagle pinmux from FreeBSD This patch imports ... Sat, 13 Mar 2021 11:02:00 GMT G S Niteesh Babu [fc712906] * bsps/include/ofw/ofw.h (modified) * bsps/shared/ofw/ofw.c (modified) bsps/shared/ofw: Add rtems_ofw_is_node_compatible This patch ... Thu, 04 Feb 2021 13:27:50 GMT Christian Mauderer [65ab1cda] * bsps/arm/imxrt/dts/imxrt1050-evkb.c (modified) * bsps/arm/imxrt/include/fsl_qtmr.h (modified) * bsps/arm/imxrt/include/imxrt/imxrt1050.dtsi (modified) * bsps/arm/imxrt/nxp/devices/MIMXRT1052/drivers/fsl_qtmr.c (modified) bsps/arm/imxrt: Add FDT and FDT helper for QTMR Makes it simpler to ... Mon, 18 Nov 2019 13:15:02 GMT Daniel Hellstrom [6caff4d6] * bsps/include/grlib/grspw_pkt.h (modified) grlib,grspw_pkt: correct link state enum numbering Not used by the ... Thu, 14 Nov 2019 10:47:21 GMT Martin Aberg [4e0735c6] * bsps/shared/grlib/l2c/l2c.c (modified) leon, l2cache: prevent unused diagnostic access Tue, 11 Dec 2018 16:55:39 GMT Martin Aberg [51564f63] * bsps/include/grlib/ahbstat.h (modified) * bsps/shared/grlib/amba/ahbstat.c (modified) leon, ahbstat: register definitions for AHBSTAT version 1 Fri, 08 Feb 2019 15:30:15 GMT Martin Aberg [8660602] * bsps/include/grlib/grspw_router.h (modified) * bsps/shared/grlib/spw/grspw_router.c (modified) leon, grspw_router: added router_port_link_div() Allows user to set ... Tue, 29 Oct 2019 14:17:57 GMT Daniel Hellstrom [dfe7901c] * bsps/sparc/leon3/start/cpucounter.c (modified) leon: restart and load timer counter at initialization Without this ... Fri, 12 Apr 2019 10:20:07 GMT Daniel Hellstrom [9c00cc1] * bsps/shared/grlib/btimer/tlib_ckinit.c (modified) leon,ckinit: avoid assuming 1MHz timer pre-scaler clock Thu, 12 Sep 2019 12:48:29 GMT Daniel Hellstrom [b57436c] * bsps/sparc/leon3/start/amba.c (modified) * bsps/sparc/leon3/start/drvmgr_def_drivers.c (added) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * spec/build/bsps/sparc/leon3/obj.yml (modified) leon3: avoid dependency on apbuart/timer driver Moves ... Fri, 26 Apr 2019 13:18:11 GMT Daniel Hellstrom [053b17ce] * bsps/include/grlib/greth.h (modified) * bsps/shared/grlib/net/greth.c (modified) leon,greth: added support for variable sized descriptor table sizes ... Fri, 12 Apr 2019 20:49:45 GMT Daniel Hellstrom [9bf8a9d1] * bsps/shared/grlib-sources.am (modified) * bsps/shared/grlib/can/grcan.c (modified) * bsps/shared/grlib/can/grcanstd.c (added) * spec/build/bsps/objgrlib.yml (modified) leon,grcan: split out GRCAN non-FD specific support in separate file ... Fri, 12 Apr 2019 20:41:04 GMT Daniel Hellstrom [9c76ca0] * bsps/shared/grlib-sources.am (modified) * bsps/shared/grlib/can/grcan.c (modified) * bsps/shared/grlib/can/grcan_internal.h (added) * bsps/shared/grlib/can/grcanfd.c (added) * spec/build/bsps/objgrlib.yml (modified) leon,grcanfd: split out GRCANFD specific support in separate file ...
