# # ChangeLog for bsps in rtems # # Generated by Trac 1.2.1.dev0 # 04/25/24 09:30:04 Wed, 17 Oct 2018 07:43:55 GMT Sebastian Huber [143c8d0] * bsps/shared/dev/serial/ns16550-context.c (modified) serial/ns16550: Fix precision clock synthesizer The precision clock ... Tue, 16 Oct 2018 12:34:38 GMT Sebastian Huber [d7c13c8] * bsps/arm/imx/console/console-config.c (modified) bsp/imx7: Add getchark() support Mon, 15 Oct 2018 08:38:49 GMT Sebastian Huber [186a0b1] * bsps/arm/shared/start/linkcmds.base (modified) bsps/arm: Recognize .tm_clone_table input section Mon, 15 Oct 2018 06:44:52 GMT Pavel Pisa [1822649] * bsps/arm/tms570/include/bsp/ti_herc/reg_sys.h (modified) bsp/tms570: Simple fix to resolve macro redefinitions. closes #3347 Fri, 31 Aug 2018 06:21:05 GMT Daniel Hellstrom [dc32b6a] * bsps/sparc/leon3/config/gr712rc.cfg (modified) * bsps/sparc/leon3/config/gr740.cfg (modified) leon: do not use -mfix-{device} with Clang Clang do not support ... Fri, 21 Jul 2017 12:18:50 GMT Javier Jalle [6dc0b5f] * bsps/sparc/headers.am (modified) * bsps/sparc/include/bsp/spwtdp.h (added) * bsps/sparc/include/drvmgr/ambapp_bus.h (modified) * bsps/sparc/shared/spw/spwtdp.c (added) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * cpukit/include/drvmgr/drvmgr_confdefs.h (modified) leon, spwtdp: Initial driver commit Tue, 09 Oct 2018 09:59:48 GMT Sebastian Huber [511ef83c] * bsps/arm/shared/start/linkcmds.base (modified) bsps/arm: Fix ctor/dtor invocation order Remove obsolete .ctor and ... Thu, 04 Oct 2018 12:35:00 GMT Sebastian Huber [b131cb2] * bsps/arm/atsam/start/linkcmds.sdram (modified) bsp/atsam: Use internal SRAM for stack area Tue, 02 Oct 2018 08:22:15 GMT Sebastian Huber [f004b2b8] * bsps/powerpc/mpc55xxevb/net/smsc9218i.c (modified) * bsps/powerpc/mvme5500/net/if_100MHz/GT64260eth.c (modified) * bsps/powerpc/mvme5500/net/if_1GHz/if_wm.c (modified) * bsps/powerpc/shared/net/tsec.c (modified) * bsps/shared/dev/ide/ata.c (modified) * bsps/sparc/shared/spw/grspw_pkt.c (modified) * cpukit/ftpd/ftpd.c (modified) * cpukit/include/rtems/rtems/event.h (modified) * cpukit/include/rtems/status-checks.h (modified) * cpukit/libblock/src/bdbuf.c (modified) * cpukit/libcsupport/src/termios.c (modified) * cpukit/libdebugger/rtems-debugger-server.c (modified) * cpukit/libfs/src/nfsclient/src/nfs.c (modified) * cpukit/libmisc/cpuuse/cpuusagetop.c (modified) * cpukit/libmisc/monitor/mon-server.c (modified) * cpukit/libmisc/redirector/stdio-redirect.c (modified) * cpukit/libmisc/shell/shell.c (modified) * cpukit/libnetworking/rtems/rtems_dhcp.c (modified) * cpukit/libnetworking/rtems/rtems_dhcp_failsafe.c (modified) * cpukit/librpc/src/rpc/rtems_portmapper.c (modified) * cpukit/pppd/rtemspppd.c (modified) * cpukit/score/cpu/i386/sse_test.c (modified) * cpukit/telnetd/telnetd.c (modified) Use rtems_task_exit() Update #3530. Update #3533. Mon, 01 Oct 2018 06:59:14 GMT Sebastian Huber [5cb23f4b] * bsps/arm/atsam/i2c/atsam_i2c_bus.c (modified) * bsps/arm/atsam/include/bsp/atsam-i2c.h (modified) bsp/atsam: Use binary semaphore for I2C Remove superfluous sleep ... Fri, 28 Sep 2018 12:45:16 GMT Sebastian Huber [fca9132] * bsps/arm/atsam/spi/atsam_spi_bus.c (modified) bsp/atsam: Use binary semaphore for SPI Update #3534. Fri, 21 Sep 2018 05:38:23 GMT Sebastian Huber [69a24c3] * bsps/arm/imx/start/ccm.c (modified) * c/src/lib/libbsp/arm/imx/configure.ac (modified) bsp/imx: Add imx_ccm_sdhci_hz() Update #3525. Wed, 19 Sep 2018 13:18:38 GMT Daniel Hellstrom [9ed109c] * bsps/sparc/shared/uart/cons.c (modified) leon: remove warning missing string.h Wed, 21 Feb 2018 18:23:35 GMT Martin Aberg [c2011b47] * bsps/sparc/include/bsp/grspw_pkt.h (modified) * bsps/sparc/shared/spw/grspw_pkt.c (modified) leon, grspw_pkt: support CCSDS/ISO16 data CRC When the CCSDS/CCITT ... Mon, 13 Aug 2018 09:36:03 GMT Daniel Hellstrom [0aae151] * bsps/sparc/shared/spw/grspw_pkt.c (modified) leon,grspw_pkt: protect TX descriptor from bad input (hdrlen) Fri, 15 Jun 2018 10:54:32 GMT Martin Aberg [ddc95ab0] * bsps/sparc/shared/l2c/l2c.c (modified) leon, l2cache: workaround for scrubber This is a workaround for a ... Tue, 23 Jan 2018 09:12:36 GMT Daniel Hellstrom [56a7540] * bsps/sparc/shared/iommu/griommu.c (modified) * bsps/sparc/shared/l2c/l2c.c (modified) * bsps/sparc/shared/pci/gr_701.c (modified) * bsps/sparc/shared/pci/gr_cpci_gr740.c (modified) * bsps/sparc/shared/pci/gr_leon4_n2x.c (modified) * bsps/sparc/shared/pci/gr_rasta_adcdac.c (modified) * bsps/sparc/shared/pci/gr_rasta_io.c (modified) * bsps/sparc/shared/pci/gr_rasta_spw_router.c (modified) * bsps/sparc/shared/pci/gr_rasta_tmtc.c (modified) * bsps/sparc/shared/pci/gr_tmtc_1553.c (modified) * bsps/sparc/shared/pci/grpci.c (modified) * bsps/sparc/shared/pci/grpci2.c (modified) * bsps/sparc/shared/pci/pcif.c (modified) * bsps/sparc/shared/spi/spictrl.c (modified) leon: substitute printf with printk in driver init Tue, 21 Nov 2017 12:19:05 GMT Daniel Hellstrom [68a0012] * bsps/sparc/shared/btimer/tlib_ckinit.c (modified) leon3, ckinit: avoid unsued code warnings when drvmgr is enabled Tue, 21 Nov 2017 10:09:58 GMT Daniel Hellstrom [d952d73] * bsps/sparc/leon3/clock/ckinit.c (modified) leon3: fix warning when SMP is enabled Thu, 20 Sep 2018 05:27:28 GMT Sebastian Huber [b3cf79b] * bsps/sparc/leon3/start/cpucounter.c (modified) bsp/leon3: Fix typo which breaks the CPU counter Update #3456. Mon, 17 Sep 2018 12:12:07 GMT Hesham Almatary [9cda6f29] * bsps/riscv/riscv/irq/irq.c (modified) riscv: Allow platforms with no PLIC to proceed Spike simulator and ... Mon, 17 Sep 2018 06:28:29 GMT Sebastian Huber [62cb39d7] * bsps/powerpc/tqm8xx/dev/clock.c (deleted) * bsps/powerpc/tqm8xx/dev/console-generic.c (deleted) * c/src/lib/libbsp/powerpc/tqm8xx/Makefile.am (modified) bsp/tqm8xx: Remove unused files Close #3513. Fri, 14 Sep 2018 05:30:46 GMT Sebastian Huber [688e101a] * bsps/powerpc/include/mpc8xx.h (modified) * bsps/powerpc/tqm8xx/console/console.c (modified) bsp/tqm8xx: Fix polled vs. interrupt output Update #3513. Wed, 12 Sep 2018 09:47:19 GMT Sebastian Huber [d22147e] * bsps/powerpc/tqm8xx/console/console.c (modified) * c/src/lib/libbsp/powerpc/tqm8xx/Makefile.am (modified) bsp/tqm8xx: Convert console to new Termios API Update #3513. Wed, 12 Sep 2018 08:43:02 GMT Sebastian Huber [68920e7f] * bsps/powerpc/tqm8xx/console/console.c (modified) bsp/tqm8xx: Move DMA support to channel descriptor Update #3513. Wed, 12 Sep 2018 08:24:56 GMT Sebastian Huber [53fb03fe] * bsps/powerpc/tqm8xx/console/console.c (modified) bsp/tqm8xx: Move rxBuf to channel descriptor Update #3513. Wed, 12 Sep 2018 08:08:50 GMT Sebastian Huber [7b93d857] * bsps/powerpc/tqm8xx/console/console.c (modified) bsp/tqm8xx: Use IRQ extensions API Update #3513. Thu, 13 Sep 2018 09:34:23 GMT Sebastian Huber [94ea8a8] * bsps/powerpc/tqm8xx/start/start.S (modified) bsp/tqm8xx: Clear sbss section Thu, 13 Sep 2018 09:33:50 GMT Sebastian Huber [7916139] * bsps/powerpc/tqm8xx/start/bspstart.c (modified) bsp/tqm8xx: Use custom string to uint32_t Avoid C locale support ... Fri, 07 Sep 2018 04:19:02 GMT Sebastian Huber [cb68253] * bsps/arm/atsam/net/if_atsam.c (modified) * bsps/arm/csb336/net/lan91c11x.c (modified) * bsps/arm/csb336/net/network.c (modified) * bsps/arm/csb337/net/network.c (modified) * bsps/arm/edb7312/net/network.c (modified) * bsps/arm/gumstix/net/rtl8019.c (modified) * bsps/arm/rtl22xx/net/network.c (modified) * bsps/arm/shared/net/lpc-ethernet.c (modified) * bsps/bfin/bf537Stamp/net/ethernet.c (modified) * bsps/bfin/bf537Stamp/net/networkconfig.c (modified) * bsps/i386/pc386/net/3c509.c (modified) * bsps/i386/pc386/net/elink.c (modified) * bsps/i386/pc386/net/ne2000.c (modified) * bsps/i386/pc386/net/wd8003.c (modified) * bsps/lm32/shared/net/network.c (modified) * bsps/lm32/shared/net/tsmac.c (modified) * bsps/m68k/av5282/net/network.c (modified) * bsps/m68k/csb360/net/network.c (modified) * bsps/m68k/gen68360/net/network.c (modified) * bsps/m68k/genmcf548x/net/network.c (modified) * bsps/m68k/mcf5235/net/network.c (modified) * bsps/m68k/mcf5329/net/network.c (modified) * bsps/m68k/mvme167/net/network.c (modified) * bsps/m68k/uC5282/net/network.c (modified) * bsps/mips/csb350/net/network.c (modified) * bsps/powerpc/beatnik/net/porting/rtemscompat.h (modified) * bsps/powerpc/gen5200/net/network.c (modified) * bsps/powerpc/gen83xx/net/network.c (modified) * bsps/powerpc/haleakala/net/network.c (modified) * bsps/powerpc/mpc55xxevb/net/smsc9218i.c (modified) * bsps/powerpc/mpc8260ads/net/if_hdlcsubr.c (modified) * bsps/powerpc/mpc8260ads/net/network.c (modified) * bsps/powerpc/mvme3100/net/tsec.c (modified) * bsps/powerpc/mvme5500/net/if_100MHz/GT64260eth.c (modified) * bsps/powerpc/mvme5500/net/if_1GHz/if_wm.c (modified) * bsps/powerpc/qoriq/net/if_intercom.c (modified) * bsps/powerpc/qoriq/net/network.c (modified) * bsps/powerpc/shared/net/tsec.c (modified) * bsps/powerpc/tqm8xx/net/network_fec.c (modified) * bsps/powerpc/tqm8xx/net/network_scc.c (modified) * bsps/powerpc/virtex/net/xiltemac.c (modified) * bsps/shared/net/cs8900.c (modified) * bsps/shared/net/dec21140.c (modified) * bsps/shared/net/elnk.c (modified) * bsps/shared/net/greth2.c (modified) * bsps/shared/net/i82586.c (modified) * bsps/shared/net/if_dc.c (modified) * bsps/shared/net/if_fxp.c (modified) * bsps/shared/net/open_eth.c (modified) * bsps/shared/net/smc91111.c (modified) * bsps/shared/net/sonic.c (modified) * bsps/sparc/erc32/net/erc32sonic.c (modified) * bsps/sparc/leon2/net/leon_open_eth.c (modified) * bsps/sparc/leon2/net/leon_smc91111.c (modified) * bsps/sparc/leon3/net/leon_greth.c (modified) * bsps/sparc/leon3/net/leon_open_eth.c (modified) * bsps/sparc/leon3/net/leon_smc91111.c (modified) * bsps/sparc/shared/net/greth.c (modified) * cpukit/libfs/src/nfsclient/src/sock_mbuf.c (modified) * cpukit/libnetworking/Makefile.am (modified) * cpukit/libnetworking/kern/kern_mib.c (modified) * cpukit/libnetworking/kern/kern_subr.c (modified) * cpukit/libnetworking/kern/kern_sysctl.c (modified) * cpukit/libnetworking/kern/uipc_domain.c (modified) * cpukit/libnetworking/kern/uipc_mbuf.c (modified) * cpukit/libnetworking/kern/uipc_socket.c (modified) * cpukit/libnetworking/kern/uipc_socket2.c (modified) * cpukit/libnetworking/lib/getprotoby.c (modified) * cpukit/libnetworking/lib/rtems_bsdnet_ntp.c (modified) * cpukit/libnetworking/lib/syslog.c (modified) * cpukit/libnetworking/libc/base64.c (modified) * cpukit/libnetworking/libc/gethostbydns.c (modified) * cpukit/libnetworking/libc/gethostbyht.c (modified) * cpukit/libnetworking/libc/gethostbynis.c (modified) * cpukit/libnetworking/libc/gethostnamadr.c (modified) * cpukit/libnetworking/libc/getifaddrs.c (modified) * cpukit/libnetworking/libc/getnameinfo.c (modified) * cpukit/libnetworking/libc/getnetbydns.c (modified) * cpukit/libnetworking/libc/getnetbyht.c (modified) * cpukit/libnetworking/libc/getnetbynis.c (modified) * cpukit/libnetworking/libc/getnetnamadr.c (modified) * cpukit/libnetworking/libc/getproto.c (modified) * cpukit/libnetworking/libc/getprotoent.c (modified) * cpukit/libnetworking/libc/getprotoname.c (modified) * cpukit/libnetworking/libc/getservbyname.c (modified) * cpukit/libnetworking/libc/getservbyport.c (modified) * cpukit/libnetworking/libc/getservent.c (modified) * cpukit/libnetworking/libc/herror.c (modified) * cpukit/libnetworking/libc/if_indextoname.c (modified) * cpukit/libnetworking/libc/if_nameindex.c (modified) * cpukit/libnetworking/libc/inet_addr.c (modified) * cpukit/libnetworking/libc/inet_lnaof.c (modified) * cpukit/libnetworking/libc/inet_makeaddr.c (modified) * cpukit/libnetworking/libc/inet_netof.c (modified) * cpukit/libnetworking/libc/inet_network.c (modified) * cpukit/libnetworking/libc/inet_ntoa.c (modified) * cpukit/libnetworking/libc/inet_ntop.c (modified) * cpukit/libnetworking/libc/inet_pton.c (modified) * cpukit/libnetworking/libc/linkaddr.c (modified) * cpukit/libnetworking/libc/map_v4v6.c (modified) * cpukit/libnetworking/libc/ns_name.c (modified) * cpukit/libnetworking/libc/ns_netint.c (modified) * cpukit/libnetworking/libc/ns_parse.c (modified) * cpukit/libnetworking/libc/ns_print.c (modified) * cpukit/libnetworking/libc/ns_ttl.c (modified) * cpukit/libnetworking/libc/nsap_addr.c (modified) * cpukit/libnetworking/libc/rcmd.c (modified) * cpukit/libnetworking/libc/recv.c (modified) * cpukit/libnetworking/libc/res_comp.c (modified) * cpukit/libnetworking/libc/res_data.c (modified) * cpukit/libnetworking/libc/res_debug.c (modified) * cpukit/libnetworking/libc/res_init.c (modified) * cpukit/libnetworking/libc/res_mkquery.c (modified) * cpukit/libnetworking/libc/res_mkupdate.c (modified) * cpukit/libnetworking/libc/res_query.c (modified) * cpukit/libnetworking/libc/res_send.c (modified) * cpukit/libnetworking/libc/res_stubs.c (modified) * cpukit/libnetworking/libc/res_update.c (modified) * cpukit/libnetworking/libc/send.c (modified) * cpukit/libnetworking/libc/strsep.c (modified) * cpukit/libnetworking/machine/rtems-bsd-kernel-space.h (added) * cpukit/libnetworking/machine/rtems-bsd-user-space.h (added) * cpukit/libnetworking/net/if.c (modified) * cpukit/libnetworking/net/if_ethersubr.c (modified) * cpukit/libnetworking/net/if_loop.c (modified) * cpukit/libnetworking/net/if_ppp.c (modified) * cpukit/libnetworking/net/ppp_tty.c (modified) * cpukit/libnetworking/net/radix.c (modified) * cpukit/libnetworking/net/raw_cb.c (modified) * cpukit/libnetworking/net/raw_usrreq.c (modified) * cpukit/libnetworking/net/route.c (modified) * cpukit/libnetworking/net/rtsock.c (modified) * cpukit/libnetworking/net/slcompress.c (modified) * cpukit/libnetworking/netinet/if_ether.c (modified) * cpukit/libnetworking/netinet/igmp.c (modified) * cpukit/libnetworking/netinet/in.c (modified) * cpukit/libnetworking/netinet/in_cksum.c (modified) * cpukit/libnetworking/netinet/in_pcb.c (modified) * cpukit/libnetworking/netinet/in_proto.c (modified) * cpukit/libnetworking/netinet/in_rmx.c (modified) * cpukit/libnetworking/netinet/ip_divert.c (modified) * cpukit/libnetworking/netinet/ip_fw.c (modified) * cpukit/libnetworking/netinet/ip_icmp.c (modified) * cpukit/libnetworking/netinet/ip_input.c (modified) * cpukit/libnetworking/netinet/ip_mroute.c (modified) * cpukit/libnetworking/netinet/ip_output.c (modified) * cpukit/libnetworking/netinet/raw_ip.c (modified) * cpukit/libnetworking/netinet/tcp_debug.c (modified) * cpukit/libnetworking/netinet/tcp_input.c (modified) * cpukit/libnetworking/netinet/tcp_output.c (modified) * cpukit/libnetworking/netinet/tcp_subr.c (modified) * cpukit/libnetworking/netinet/tcp_timer.c (modified) * cpukit/libnetworking/netinet/tcp_usrreq.c (modified) * cpukit/libnetworking/netinet/udp_usrreq.c (modified) * cpukit/libnetworking/nfs/bootp_subr.c (modified) * cpukit/libnetworking/rtems/mkrootfs.c (modified) * cpukit/libnetworking/rtems/rtems_bootp.c (modified) * cpukit/libnetworking/rtems/rtems_bsdnet.h (modified) * cpukit/libnetworking/rtems/rtems_bsdnet_malloc_starvation.c (modified) * cpukit/libnetworking/rtems/rtems_dhcp.c (modified) * cpukit/libnetworking/rtems/rtems_dhcp_failsafe.c (modified) * cpukit/libnetworking/rtems/rtems_glue.c (modified) * cpukit/libnetworking/rtems/rtems_malloc_mbuf.c (modified) * cpukit/libnetworking/rtems/rtems_mii_ioctl.c (modified) * cpukit/libnetworking/rtems/rtems_mii_ioctl_kern.c (modified) * cpukit/libnetworking/rtems/rtems_select.c (modified) * cpukit/libnetworking/rtems/rtems_showicmpstat.c (modified) * cpukit/libnetworking/rtems/rtems_showifstat.c (modified) * cpukit/libnetworking/rtems/rtems_showipstat.c (modified) * cpukit/libnetworking/rtems/rtems_showmbuf.c (modified) * cpukit/libnetworking/rtems/rtems_showroute.c (modified) * cpukit/libnetworking/rtems/rtems_showtcpstat.c (modified) * cpukit/libnetworking/rtems/rtems_showudpstat.c (modified) * cpukit/libnetworking/rtems/rtems_socketpair.c (modified) * cpukit/libnetworking/rtems/rtems_syscall.c (modified) * cpukit/libnetworking/rtems/rtems_syscall_api.c (modified) * cpukit/libnetworking/rtems/sghostname.c (modified) * cpukit/wrapup/Makefile.am (modified) network: Use kernel/user space header files Add and use ... Thu, 06 Sep 2018 05:03:49 GMT Sebastian Huber [2f61eb21] * bsps/powerpc/qoriq/include/bsp/qoriq.h (modified) bsp/qoriq: Add struct qoriq to allow forward decls Tue, 04 Sep 2018 16:28:57 GMT Sebastian Huber [54d87f2] * bsps/powerpc/beatnik/start/bspstart.c (modified) * bsps/powerpc/gen5200/start/bspstart.c (modified) * bsps/powerpc/gen83xx/start/bspstart.c (modified) * bsps/powerpc/haleakala/start/bspstart.c (modified) * bsps/powerpc/include/bsp/vectors.h (modified) * bsps/powerpc/motorola_powerpc/start/bspstart.c (modified) * bsps/powerpc/mpc55xxevb/start/bspstart.c (modified) * bsps/powerpc/mpc8260ads/start/bspstart.c (modified) * bsps/powerpc/mvme3100/start/bspstart.c (modified) * bsps/powerpc/mvme5500/start/bspstart.c (modified) * bsps/powerpc/psim/start/bspstart.c (modified) * bsps/powerpc/qemuppc/start/bspstart.c (modified) * bsps/powerpc/qoriq/start/bspsmp.c (modified) * bsps/powerpc/qoriq/start/bspstart.c (modified) * bsps/powerpc/shared/exceptions/ppc_exc_initialize.c (modified) * bsps/powerpc/shared/start/bspgetworkarea.c (modified) * bsps/powerpc/t32mppc/start/bspstart.c (modified) * bsps/powerpc/tqm8xx/start/bspstart.c (modified) * bsps/powerpc/virtex/start/bspstart.c (modified) * bsps/powerpc/virtex4/start/bspstart.c (modified) * bsps/powerpc/virtex5/start/bspstart.c (modified) bsps/powerpc: Simplify ppc_exc_initialize() Remove parameters from ... Wed, 05 Sep 2018 05:38:13 GMT Sebastian Huber [9a21fc7] * bsps/powerpc/mpc55xxevb/dev/dspi.c (modified) bsp/mpc55xxevb: Fix format warning Close #3504. Wed, 05 Sep 2018 05:31:23 GMT Sebastian Huber [ccdce9d8] * bsps/include/libchip/ata.h (modified) libchip/ata: Fix ATA_DRIVER_TABLE_ENTRY Drop unused and deprecated ... Fri, 31 Aug 2018 05:44:53 GMT Sebastian Huber [fad3f79b] * bsps/arm/raspberrypi/start/bspgetworkarea.c (modified) * bsps/powerpc/gen83xx/start/bspstart.c (modified) * bsps/powerpc/mpc55xxevb/include/bsp.h (modified) * bsps/powerpc/mpc55xxevb/start/bspgetworkarea.c (modified) * bsps/powerpc/mpc55xxevb/start/bspstart.c (modified) * bsps/powerpc/psim/start/bspstart.c (modified) * bsps/powerpc/qoriq/start/bspstart.c (modified) * bsps/powerpc/qoriq/start/mmu-config.c (modified) * bsps/powerpc/t32mppc/start/bspstart.c (modified) * bsps/powerpc/virtex/include/bsp.h (modified) * bsps/powerpc/virtex/start/bspstart.c (modified) * bsps/shared/start/bspgetworkarea-default.c (modified) * c/src/lib/libbsp/powerpc/gen83xx/configure.ac (modified) * c/src/lib/libbsp/powerpc/psim/configure.ac (modified) * c/src/lib/libbsp/powerpc/qoriq/configure.ac (modified) bsps: BSP_INTERRUPT_STACK_AT_WORK_AREA_BEGIN Remove the ... Wed, 29 Aug 2018 17:51:50 GMT Joel Sherrill [66e78854] * bsps/sparc64/shared/helenos/boot/generic/string.c (deleted) * c/src/lib/libbsp/sparc64/niagara/Makefile.am (modified) * c/src/lib/libbsp/sparc64/usiii/Makefile.am (modified) Remove bsps/sparc64/shared/helenos/boot/generic/string.c Wed, 29 Aug 2018 17:39:17 GMT Joel Sherrill [5da1593] * bsps/powerpc/psim/include/tm27.h (modified) psim/include/tm27.h: Fix not a prototype warnings Wed, 29 Aug 2018 17:39:01 GMT Joel Sherrill [a8d3f10] * bsps/powerpc/mvme5500/include/tm27.h (modified) mvme5500/include/tm27.h: Fix not a prototype warnings Wed, 29 Aug 2018 17:37:29 GMT Joel Sherrill [a5c3bfb] * bsps/m68k/uC5282/clock/clock.c (modified) uC5282/clock/clock.c: Correct bsp_idle_thread() prototype Wed, 29 Aug 2018 17:36:50 GMT Joel Sherrill [34e959fa] * bsps/m68k/gen68340/include/m340timer.h (modified) gen68340/include/m340timer.h: Fix not a prototype warnings Wed, 29 Aug 2018 17:36:18 GMT Joel Sherrill [76ac42ff] * bsps/arm/lpc32xx/include/bsp.h (modified) lpc32xx/include/bsp.h: Resolve set but not used warning Wed, 29 Aug 2018 17:34:58 GMT Joel Sherrill [350b07a0] * bsps/arm/csb337/umon/monlib.c (modified) * bsps/include/umon/monlib.h (modified) monlib.[ch]: Fix warnings for external vs internal use of .h Wed, 22 Aug 2018 16:58:12 GMT Joel Sherrill [60702ab] * bsps/powerpc/qoriq/include/tm27.h (modified) qoriq/include/tm27.h: Fix warnings Wed, 22 Aug 2018 16:57:57 GMT Joel Sherrill [126a454] * bsps/powerpc/gen5200/include/tm27.h (modified) gen5200/include/tm27.h: Fix warnings Wed, 22 Aug 2018 16:50:19 GMT Joel Sherrill [c80f5afc] * bsps/powerpc/mpc55xxevb/clock/clock-config.c (modified) mpc55xxevb/clock/clock-config.c: Remove unused ... Wed, 22 Aug 2018 14:30:44 GMT Joel Sherrill [76b3f8c] * bsps/powerpc/gen5200/include/bsp/bestcomm.h (modified) gen5200/include/bsp/bestcomm.h: Fix unused variable warning Tue, 21 Aug 2018 15:35:26 GMT Joel Sherrill [bb6eeabf] * bsps/i386/shared/cache/cache.c (modified) bsps/i386/shared/cache/cache.c: Fix warnings Tue, 21 Aug 2018 15:35:16 GMT Joel Sherrill [c2e8ed6] * bsps/arm/gdbarmsim/include/bsp.h (modified) gdbarmsim/include/bsp.h: Fix warnings Fri, 17 Aug 2018 18:30:19 GMT Joel Sherrill [cba349c] * bsps/m68k/shared/cache/cache.h (modified) bsps/m68k/shared/cache/cache.h: Fix warnings and clean up Wed, 29 Aug 2018 05:46:31 GMT Sebastian Huber [a6fca76] * bsps/powerpc/qoriq/README (deleted) bsp/qoriq: Remove README Update #2854. Wed, 20 Jun 2018 07:23:31 GMT Daniel Hellstrom [408fad3] * bsps/sparc/shared/spw/grspw_pkt.c (modified) leon,grspw_pkt: remove incorrect comment on SMP not being tested To ... Fri, 15 Jun 2018 06:49:31 GMT Daniel Hellstrom [aea3134e] * bsps/sparc/shared/uart/apbuart_cons.c (modified) leon,apbuart: replace termios c_cflag & CBAUD with c_{i,o}speed ... Fri, 15 Jun 2018 12:28:36 GMT Daniel Hellstrom [243ddb52] * bsps/sparc/include/bsp/greth.h (modified) * bsps/sparc/shared/net/greth.c (modified) leon,greth: enable MAC filtering (promiscous mode, multicast) It ... Tue, 13 Feb 2018 06:47:14 GMT Daniel Hellstrom [2fbe2ef3] * bsps/sparc/shared/net/greth.c (modified) leon, greth: 10/100 MAC enable TX BD interrupt Missed to enable ... Thu, 23 Aug 2018 09:13:44 GMT Daniel Hellstrom [a87964d] * bsps/sparc/shared/start/start.S (modified) sparc,smp: typo in start.S causing SMP not working Mon, 20 Aug 2018 06:35:26 GMT Sebastian Huber [2cd3716] * bsps/arm/include/bsp/arm-pl111-regs.h (modified) * bsps/arm/lpc24xx/start/fb-config.c (modified) bsps/arm: Fix PL111 register define re-definition Close #3502. Mon, 13 Aug 2018 10:55:34 GMT Amaan Cheval [bc731313] * bsps/x86_64/amd64/clock/clock.c (added) * bsps/x86_64/amd64/headers.am (modified) * bsps/x86_64/amd64/include/apic.h (added) * bsps/x86_64/amd64/include/clock.h (added) * bsps/x86_64/amd64/include/pic.h (added) * bsps/x86_64/amd64/interrupts/pic.c (added) * c/src/lib/libbsp/x86_64/amd64/Makefile.am (modified) * cpukit/score/cpu/x86_64/include/rtems/score/cpu_asm.h (modified) bsps/x86_64: Add APIC timer based clock driver The APIC timer is ... Mon, 13 Aug 2018 10:50:38 GMT Amaan Cheval [6869321] * bsps/x86_64/amd64/interrupts/idt.c (added) * bsps/x86_64/amd64/interrupts/isr_handler.S (added) * bsps/x86_64/amd64/start/bspstart.c (modified) * bsps/x86_64/headers.am (modified) * bsps/x86_64/include/bsp/irq.h (added) * c/src/lib/libbsp/x86_64/amd64/Makefile.am (modified) * cpukit/score/cpu/x86_64/cpu.c (modified) * cpukit/score/cpu/x86_64/headers.am (modified) * cpukit/score/cpu/x86_64/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/x86_64/include/rtems/score/cpu_asm.h (modified) * cpukit/score/cpu/x86_64/include/rtems/score/idt.h (added) * cpukit/score/cpu/x86_64/x86_64-context-initialize.c (modified) bsps/x86_64: Add support for RTEMS interrupts Updates #2898. Mon, 13 Aug 2018 10:33:12 GMT Amaan Cheval [4544749e] * bsps/x86_64/amd64/start/bspstart.c (modified) * bsps/x86_64/amd64/start/page.c (added) * bsps/x86_64/headers.am (added) * bsps/x86_64/include/libcpu/page.h (added) * c/src/lib/libbsp/x86_64/amd64/Makefile.am (modified) * cpukit/score/cpu/x86_64/include/rtems/score/cpu_asm.h (modified) bsps/x86_64: Add paging support with 1GiB super pages Updates #2898. Mon, 13 Aug 2018 10:25:51 GMT Amaan Cheval [6eccd0c] * bsps/x86_64/amd64/start/linkcmds (modified) bsps/x86_64: Reduce default RamSize to 1GiB Simulators may not ... Mon, 13 Aug 2018 10:21:47 GMT Amaan Cheval [ab971bf5] * bsps/x86_64/amd64/config/amd64.cfg (modified) * cpukit/score/cpu/x86_64/headers.am (modified) * cpukit/score/cpu/x86_64/include/rtems/asm.h (modified) * cpukit/score/cpu/x86_64/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/x86_64/include/rtems/score/cpu_asm.h (added) * cpukit/score/cpu/x86_64/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/x86_64/include/rtems/score/x86_64.h (modified) * cpukit/score/cpu/x86_64/x86_64-context-switch.S (modified) bsps/x86_64: Reorganize header files and compile-options Updates #2898. Fri, 10 Aug 2018 13:22:49 GMT Joel Sherrill [b3693f5] * bsps/sparc/include/bsp/gradcdac.h (modified) bsps/sparc/include/bsp/gradcdac.h: Fix nested comment warning Fri, 10 Aug 2018 13:22:02 GMT Joel Sherrill [d071d9a] * bsps/powerpc/qoriq/include/tm27.h (modified) qoriq/include/tm27.h: Fix prototype warning Fri, 10 Aug 2018 13:21:36 GMT Joel Sherrill [ebd1937] * bsps/powerpc/motorola_powerpc/include/tm27.h (modified) motorola_powerpc/include/tm27.h: Fix prototype warning Fri, 10 Aug 2018 13:21:09 GMT Joel Sherrill [3cff531f] * bsps/powerpc/include/mpc83xx/mpc83xx.h (modified) bsps/powerpc/include/mpc83xx/mpc83xx.h: Fix nested comment warning Fri, 10 Aug 2018 13:20:38 GMT Joel Sherrill [5896da4] * bsps/powerpc/include/bsp/tictac.h (modified) bsps/powerpc/include/bsp/tictac.h: Fix protototype warnings Fri, 10 Aug 2018 13:20:07 GMT Joel Sherrill [ae4fbf3b] * bsps/powerpc/gen83xx/include/tm27.h (modified) gen83xx/include/tm27.h: Fix prototype warning Fri, 10 Aug 2018 13:19:40 GMT Joel Sherrill [ec8c955d] * bsps/powerpc/gen5200/include/tm27.h (modified) gen5200/include/tm27.h: Fix prototype warning Fri, 10 Aug 2018 13:18:59 GMT Joel Sherrill [7de51829] * bsps/powerpc/gen5200/include/bsp/ata.h (modified) gen5200/include/bsp/ata.h: Fix warning Fri, 10 Aug 2018 13:18:40 GMT Joel Sherrill [0fc87d47] * bsps/arm/csb337/include/at91rm9200_dbgu.h (modified) csb337/include/at91rm9200_dbgu.h: Fix nested comment warning Fri, 10 Aug 2018 05:10:20 GMT Sebastian Huber [0e6f7dc4] * bsps/sparc/include/bsp/apbuart_termios.h (modified) bsps/sparc: Fix external variable declarations Thu, 09 Aug 2018 07:20:33 GMT Sebastian Huber [f4424cfb] * bsps/sparc/include/bsp/apbuart.h (modified) * bsps/sparc/include/bsp/apbuart_termios.h (modified) * bsps/sparc/leon3/console/printk_support.c (modified) * bsps/sparc/shared/uart/apbuart_cons.c (modified) * bsps/sparc/shared/uart/apbuart_polled.c (added) * bsps/sparc/shared/uart/apbuart_termios.c (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) bsps/sparc: Move polled APBUART functions This reduces the ... Mon, 06 Aug 2018 08:29:14 GMT Christian Mauderer [8e6cfcc] * bsps/arm/atsam/spi/atsam_spi_bus.c (modified) bsp/atsam: Fix handling of slow SPI speeds. This patch fixes an ... Sat, 04 Aug 2018 08:45:19 GMT Sebastian Huber [1836c6a] * bsps/powerpc/gen5200/ata/ata-instance.c (modified) bsp/gen5200: Avoid deprecated routine Update #3358. Fri, 03 Aug 2018 20:53:40 GMT Sebastian Huber [f7cecc33] * bsps/include/libchip/ata_internal.h (modified) * bsps/shared/dev/ide/ata.c (modified) libchip/ata: Use rtems_blkdev_create() Update #3358. Wed, 01 Aug 2018 04:14:14 GMT Sebastian Huber [d279e74] * bsps/arm/smdk2410/smc/smc.c (modified) bsp/smdk2410: Use rtems_blkdev_create() Update #3358. Tue, 31 Jul 2018 14:05:49 GMT Sebastian Huber [1dec54f9] * bsps/lm32/shared/milkymist_memcard/memcard.c (modified) bsps/lm32: Use rtems_blkdev_create() Update #3358. Fri, 03 Aug 2018 12:03:39 GMT Sebastian Huber [32ccc01] * bsps/shared/irq-sources.am (modified) * bsps/shared/irq/irq-generic.c (modified) * bsps/shared/irq/irq-lock.c (added) * c/src/lib/libbsp/m68k/genmcf548x/Makefile.am (modified) bsps: Fix the generic IRQ support The genmcf548x partly uses is own ... Thu, 02 Aug 2018 11:23:26 GMT Sebastian Huber [141d502] * bsps/riscv/riscv/config/rv32imafdc.cfg (added) bsp/riscv: Add missing BSP variant Update #3433. Thu, 02 Aug 2018 12:13:25 GMT Sebastian Huber [4c740de] * bsps/riscv/riscv/include/bsp/riscv.h (modified) * bsps/riscv/riscv/irq/irq.c (modified) * bsps/riscv/riscv/start/bspstart.c (modified) bsp/riscv: Fix build with RTEMS_SMP undefined Update #3433. Wed, 01 Aug 2018 08:06:37 GMT Sebastian Huber [3d11c1e] * bsps/riscv/riscv/irq/irq.c (modified) bsp/riscv: Fix a synchronization issue for PLIC Update #3433. Wed, 01 Aug 2018 09:15:55 GMT Sebastian Huber [dee2ebb] * bsps/riscv/riscv/irq/irq.c (modified) bsp/riscv: Remove unused variable Update #3433. Wed, 01 Aug 2018 06:13:39 GMT Sebastian Huber [56b0387] * bsps/riscv/riscv/console/console-config.c (modified) bsp/riscv: Add NS16750 support to console driver Update #3433. Tue, 31 Jul 2018 09:38:56 GMT Sebastian Huber [a7cd4b73] * bsps/include/libchip/ns16550.h (modified) * bsps/shared/dev/serial/ns16550-context.c (modified) serial/ns16550: Precision clock synthesizer Set the FIFO control ... Tue, 31 Jul 2018 08:45:41 GMT Sebastian Huber [8a78b784] * bsps/shared/dev/serial/ns16550-context.c (modified) serial/ns16550: Use standard register names Use the standard ... Tue, 31 Jul 2018 07:15:00 GMT Sebastian Huber [529154b] * bsps/riscv/riscv/start/start.S (modified) bsp/riscv: Initialize FPU depending on ISA Initialize fcsr to zero ... Tue, 31 Jul 2018 05:19:33 GMT Sebastian Huber [48cbd63] * bsps/riscv/riscv/clock/clockdrv.c (modified) bsp/riscv: Fix clock driver Do not assume that mtime is zero at ... Wed, 01 Aug 2018 05:41:49 GMT Sebastian Huber [71284ce] * bsps/sparc/shared/start/start.S (modified) bsps/sparc: Fix typo in start.S Fix typo in start.S introduced by ... Fri, 27 Jul 2018 13:04:38 GMT Sebastian Huber [44c2d393] * bsps/riscv/riscv/irq/irq.c (modified) bsp/riscv: Fix inter-processor interrupts The previous version ... Fri, 27 Jul 2018 12:47:17 GMT Sebastian Huber [cfc9573] * bsps/riscv/riscv/clock/clockdrv.c (modified) * cpukit/score/cpu/riscv/Makefile.am (modified) * cpukit/score/cpu/riscv/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/riscv/include/rtems/score/cpuimpl.h (modified) * cpukit/score/cpu/riscv/riscv-counter.S (added) riscv: Rework CPU counter support Update #3433. Tue, 24 Jul 2018 12:47:05 GMT Sebastian Huber [581a0f88] * bsps/include/bsp/fatal.h (modified) * bsps/riscv/riscv/console/console-config.c (modified) bsp/riscv: Use interrupt driven NS16550 driver Update #3433. Tue, 24 Jul 2018 11:27:54 GMT Sebastian Huber [adede135] * bsps/include/bsp/fatal.h (modified) * bsps/riscv/riscv/include/bsp.h (modified) * bsps/riscv/riscv/include/bsp/irq.h (modified) * bsps/riscv/riscv/irq/irq.c (modified) * bsps/riscv/riscv/start/bspsmp.c (modified) bsp/riscv: Add PLIC support Update #3433. Mon, 23 Jul 2018 11:50:02 GMT Sebastian Huber [bd560386] * bsps/riscv/riscv/clock/clockdrv.c (modified) bsp/riscv: Add simple SMP support to clock driver This is a hack. ... Tue, 24 Jul 2018 08:10:12 GMT Sebastian Huber [6552ba8] * bsps/riscv/riscv/btimer/btimer.c (deleted) * c/src/lib/libbsp/riscv/riscv/Makefile.am (modified) bsp/riscv: Use CPU counter btimer Update #3433. Fri, 20 Jul 2018 11:11:04 GMT Sebastian Huber [447fd89] * bsps/include/bsp/fatal.h (modified) * bsps/riscv/riscv/clock/clockdrv.c (modified) * bsps/riscv/riscv/include/bsp/riscv.h (modified) * bsps/riscv/riscv/irq/irq.c (modified) * bsps/riscv/riscv/start/bspsmp.c (added) * bsps/riscv/riscv/start/bspstart.c (modified) * bsps/riscv/riscv/start/start.S (modified) * c/src/lib/libbsp/riscv/riscv/Makefile.am (modified) bsp/riscv: Add basic SMP startup Update #3433. Fri, 20 Jul 2018 08:57:59 GMT Sebastian Huber [6b9ef09] * bsps/riscv/riscv/clock/clockdrv.c (modified) * bsps/riscv/riscv/headers.am (modified) * bsps/riscv/riscv/include/dev/irq/clint.h (deleted) * cpukit/score/cpu/riscv/include/rtems/score/cpuimpl.h (modified) riscv: Add CLINT and PLIC support The CLINT and PLIC need some ... Thu, 19 Jul 2018 13:12:11 GMT Sebastian Huber [f5fd8eb] * bsps/riscv/include/bsp/linker-symbols.h (modified) * c/src/lib/libbsp/riscv/riscv/Makefile.am (modified) bsps/riscv: Update linker-symbols.h Update #3433. Thu, 19 Jul 2018 12:45:47 GMT Sebastian Huber [dda6e06] * bsps/riscv/riscv/start/bsp_fatal_halt.c (modified) bsp/riscv: Add reset via for SiFive Test Finisher Update #3433. Thu, 19 Jul 2018 12:38:44 GMT Sebastian Huber [3a263a9b] * bsps/include/bsp/fatal.h (modified) * bsps/riscv/riscv/clock/clockdrv.c (modified) * bsps/riscv/riscv/console/console-config.c (modified) * bsps/riscv/riscv/include/bsp/riscv.h (modified) * bsps/riscv/riscv/start/bspstart.c (modified) bsp/riscv: Add and use riscv_fdt_get_address() Update #3433. Thu, 19 Jul 2018 11:58:12 GMT Sebastian Huber [7fe4855] * bsps/riscv/riscv/console/console-config.c (modified) * bsps/riscv/riscv/console/htif.c (modified) * bsps/riscv/riscv/headers.am (modified) * bsps/riscv/riscv/include/bsp/riscv.h (added) * bsps/riscv/riscv/start/bsp_fatal_halt.c (modified) bsp/riscv: Fix HTIF warnings Update #3433.
