# # ChangeLog for bsps in rtems # # Generated by Trac 1.2.1.dev0 # 04/23/24 12:45:56 Mon, 26 Nov 2018 13:04:59 GMT Sebastian Huber [0a75a4aa] * bsps/shared/cache/cacheimpl.h (modified) * cpukit/include/rtems/rtems/cache.h (modified) * testsuites/smptests/smpcache01/init.c (modified) Remove rtems_cache_*_processor_set() functions The following ... Sun, 25 Nov 2018 20:17:54 GMT Shashvat Jain [1947449] * bsps/m68k/uC5282/config/uC5282.cfg (modified) m68k/uC5282: Add per-section compilation and linking (GCI 2018) The ... Sun, 25 Nov 2018 07:37:01 GMT Shashvat Jain [ffe9e7a] * bsps/m68k/gen68360/config/gen68360.cfg (modified) * bsps/m68k/gen68360/config/gen68360_040.cfg (modified) * bsps/m68k/gen68360/config/pgh360.cfg (modified) m68k/gen68360:Add per-section compilation and linking support The ... Sat, 24 Nov 2018 20:55:07 GMT pritishjain [1b2124d] * bsps/m68k/gen68340/config/gen68340.cfg (modified) m68k/gen68340:Add per-section compilation and linking support The ... Thu, 22 Nov 2018 01:25:43 GMT zehata [2ce44de] * bsps/x86_64/amd64/start/linkcmds (modified) Changed slightly awkward sentence structure Tue, 20 Nov 2018 12:09:53 GMT Sebastian Huber [e0caabe] * bsps/arm/shared/start/start.S (modified) bsps/arm: Avoid short range branch in start.S Tue, 20 Nov 2018 12:06:04 GMT Sebastian Huber [faafc229] * bsps/arm/shared/start/start.S (modified) bsps/arm: Use local labels in start.S Tue, 20 Nov 2018 12:03:20 GMT Sebastian Huber [94529131] * bsps/arm/shared/start/start.S (modified) bsps/arm: Simplify start.S The boot_card() function does not return. Fri, 16 Nov 2018 06:46:16 GMT Sebastian Huber [0a6a4ddb] * bsps/moxie/moxiesim/start/linkcmds (modified) * bsps/moxie/moxiesim/start/start.S (modified) bsps/moxie: Use interrupt stack for init stack Update #3459. Fri, 16 Nov 2018 07:01:24 GMT Sebastian Huber [38f81bfc] * bsps/nios2/nios2_iss/start/start.S (modified) bsps/nios2: Use interrupt stack for init stack Update #3459. Thu, 15 Nov 2018 05:40:35 GMT Sebastian Huber [0989001] * bsps/sparc64/shared/start/start.S (modified) bsps/sparc64: Use interrupt stack for init stack Update #3459. Fri, 16 Nov 2018 07:55:30 GMT Sebastian Huber [5f5bbd1] * bsps/x86_64/amd64/start/linkcmds (modified) * bsps/x86_64/amd64/start/start.S (added) * bsps/x86_64/amd64/start/start.c (deleted) * c/src/lib/libbsp/x86_64/amd64/Makefile.am (modified) bsps/x86_64: Use interrupt stack for init stack Update #3459. Fri, 16 Nov 2018 05:39:49 GMT Sebastian Huber [0ce6bf3] * bsps/epiphany/epiphany_sim/start/start.S (modified) bsps/epiphany: Use interrupt stack for init stack Update #3459. Fri, 16 Nov 2018 05:36:28 GMT Sebastian Huber [a74ee417] * bsps/bfin/bf537Stamp/start/start.S (modified) * bsps/bfin/shared/start/start.S (modified) bsps/bfin: Use interrupt stack for init stack Update #3459. Fri, 16 Nov 2018 06:43:51 GMT Sebastian Huber [508f319e] * bsps/mips/hurricane/start/start.S (modified) * bsps/mips/rbtx4925/start/start.S (modified) * bsps/mips/rbtx4938/start/start.S (modified) bsps/mips: Use interrupt stack for init stack Update #3459. Thu, 15 Nov 2018 19:47:22 GMT Sebastian Huber [84e59b7c] * bsps/powerpc/gen5200/start/start.S (modified) * bsps/powerpc/gen83xx/start/start.S (modified) * bsps/powerpc/haleakala/start/linkcmds (modified) * bsps/powerpc/haleakala/start/start.S (moved) * bsps/powerpc/mpc8260ads/start/start.S (modified) * bsps/powerpc/mvme3100/start/start.S (modified) * bsps/powerpc/mvme5500/start/start.S (modified) * bsps/powerpc/shared/start/linkcmds.share (modified) * bsps/powerpc/shared/start/start.S (modified) * bsps/powerpc/ss555/start/linkcmds (modified) * bsps/powerpc/virtex/start/start.S (modified) * bsps/powerpc/virtex4/start/linkcmds (modified) * bsps/powerpc/virtex5/start/linkcmds (modified) * c/src/lib/libbsp/powerpc/haleakala/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ss555/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex/configure.ac (modified) * c/src/lib/libbsp/powerpc/virtex4/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex5/Makefile.am (modified) bsps/powerpc: Use interrupt stack for init stack Move start.o to ... Fri, 16 Nov 2018 06:36:04 GMT Sebastian Huber [cc61d5c] * bsps/m68k/av5282/start/start.S (modified) * bsps/m68k/csb360/start/start.S (modified) * bsps/m68k/mcf5206elite/start/start.S (modified) * bsps/m68k/mcf5235/start/start.S (modified) * bsps/m68k/uC5282/start/start.S (modified) bsps/m68k: Use interrupt stack for init stack Update #3459. Wed, 14 Nov 2018 22:48:56 GMT Pavel Pisa [5247a214] * bsps/arm/tms570/console/tms570-sci.c (modified) bsp/tms570: correct baudrate calculation. Wed, 14 Nov 2018 22:46:43 GMT Pavel Pisa [aefd4a2] * bsps/arm/tms570/start/bspstarthooks-hwinit.c (modified) * bsps/arm/tms570/start/fail_notification.c (modified) * bsps/arm/tms570/start/init_emif_sdram.c (modified) * bsps/arm/tms570/start/init_esm.c (modified) * bsps/arm/tms570/start/init_pinmux.c (modified) * bsps/arm/tms570/start/init_system.c (modified) * bsps/arm/tms570/start/tms570_selftest.c (modified) * bsps/arm/tms570/start/tms570_selftest_par_can.c (modified) * bsps/arm/tms570/start/tms570_selftest_par_mibspi.c (modified) * bsps/arm/tms570/start/tms570_selftest_par_std.c (modified) * bsps/arm/tms570/start/tms570_selftest_parity.c (modified) * bsps/arm/tms570/start/tms570_tcram_tests.c (modified) bsp/tms570: correct inclusion of header files for build with HW init. ... Wed, 14 Nov 2018 07:42:22 GMT Sebastian Huber [a13b89b] * bsps/i386/pc386/start/bspgetworkarea.c (modified) * bsps/i386/pc386/start/start.S (modified) bsp/i386: Use interrupt stack for init stack Update #3459. Wed, 14 Nov 2018 06:58:38 GMT Sebastian Huber [5f32da0] * bsps/or1k/generic_or1k/start/start.S (modified) bsp/or1k: Use interrupt stack for init stack Update #3459. Wed, 14 Nov 2018 06:00:59 GMT Sebastian Huber [28bf4ca] * bsps/or1k/generic_or1k/start/bsp_specs (modified) * cpukit/libcsupport/src/newlibc_exit.c (modified) * cpukit/score/src/threadhandler.c (modified) or1k: Support GCC 9 Close #3602. Fri, 09 Nov 2018 12:06:52 GMT Sebastian Huber [9a029ce] * bsps/shared/irq/irq-generic.c (modified) bsps/irq: Use rtems_malloc() Thu, 08 Nov 2018 14:31:03 GMT Sebastian Huber [510fbfc3] * bsps/sh/gensh1/start/cpu_asm.c (modified) * bsps/sh/gensh1/start/ispsh7032.c (modified) * bsps/sh/gensh2/start/cpu_asm.c (modified) * bsps/sh/gensh2/start/ispsh7045.c (modified) * bsps/sh/gensh4/start/cpu_asm.c (modified) * bsps/sh/shared/start/setvec.c (modified) * bsps/sh/shsim/start/ispshgdb.c (modified) * cpukit/score/cpu/sh/cpu.c (modified) * cpukit/score/cpu/sh/include/rtems/score/cpu.h (modified) sh: Remove use of proc_ptr Update #3585. Thu, 08 Nov 2018 14:05:22 GMT Sebastian Huber [54c5ffc] * bsps/or1k/generic_or1k/clock/clockdrv.c (modified) * cpukit/score/cpu/or1k/cpu.c (modified) * cpukit/score/cpu/or1k/include/rtems/score/cpu.h (modified) or1k: Remove use of proc_ptr Update #3585. Thu, 08 Nov 2018 14:44:56 GMT Sebastian Huber [5c6edee] * bsps/m68k/gen68340/console/console.c (modified) * bsps/m68k/shared/fpsp/rtems_fpsp.c (modified) * cpukit/score/cpu/m68k/cpu.c (modified) * cpukit/score/cpu/m68k/include/rtems/score/cpu.h (modified) m68k: Remove use of proc_ptr Update #3585. Thu, 08 Nov 2018 14:14:32 GMT Sebastian Huber [3c6a6e8] * bsps/i386/shared/irq/idt.c (modified) * cpukit/score/cpu/i386/cpu.c (modified) * cpukit/score/cpu/i386/include/rtems/score/cpu.h (modified) i386: Remove use of proc_ptr Update #3585. Thu, 08 Nov 2018 14:33:47 GMT Sebastian Huber [a043ff8] * bsps/epiphany/epiphany_sim/btimer/btimer.c (modified) * cpukit/score/cpu/epiphany/cpu.c (modified) * cpukit/score/cpu/epiphany/include/rtems/score/cpu.h (modified) epiphany: Remove use of proc_ptr Update #3585. Mon, 12 Nov 2018 08:33:04 GMT Sebastian Huber [93fae332] * bsps/arm/csb336/net/lan91c11x.c (modified) * bsps/i386/shared/irq/elcr.h (modified) * bsps/m68k/gen68340/include/m340uart.h (modified) * cpukit/include/rtems/media.h (modified) Include missing Update #3598. Thu, 08 Nov 2018 15:21:48 GMT Sebastian Huber [bfcf1473] * bsps/m32c/m32cbsp/README (deleted) * bsps/m32c/m32cbsp/btimer/btimer.c (deleted) * bsps/m32c/m32cbsp/config/m32csim-testsuite.tcfg (deleted) * bsps/m32c/m32cbsp/config/m32csim.cfg (deleted) * bsps/m32c/m32cbsp/console/console-io.c (deleted) * bsps/m32c/m32cbsp/console/syscalls.S (deleted) * bsps/m32c/m32cbsp/doxygen.h (deleted) * bsps/m32c/m32cbsp/headers.am (deleted) * bsps/m32c/m32cbsp/include/bsp.h (deleted) * bsps/m32c/m32cbsp/include/tm27.h (deleted) * bsps/m32c/m32cbsp/start/bsp_specs (deleted) * bsps/m32c/m32cbsp/start/bspstart.c (deleted) * bsps/m32c/m32cbsp/start/crtn.S (deleted) * bsps/m32c/m32cbsp/start/linkcmds (deleted) * bsps/m32c/m32cbsp/start/start.S (deleted) * c/src/aclocal/check-networking.m4 (modified) * c/src/aclocal/rtems-cpu-subdirs.m4 (modified) * c/src/lib/libbsp/m32c/Makefile.am (deleted) * c/src/lib/libbsp/m32c/acinclude.m4 (deleted) * c/src/lib/libbsp/m32c/configure.ac (deleted) * c/src/lib/libbsp/m32c/m32cbsp/Makefile.am (deleted) * c/src/lib/libbsp/m32c/m32cbsp/configure.ac (deleted) * cpukit/Makefile.am (modified) * cpukit/aclocal/check-networking.m4 (modified) * cpukit/configure.ac (modified) * cpukit/libmisc/dummy/default-configuration.c (modified) * cpukit/score/cpu/m32c/context_init.c (deleted) * cpukit/score/cpu/m32c/context_switch.S (deleted) * cpukit/score/cpu/m32c/cpu.c (deleted) * cpukit/score/cpu/m32c/headers.am (deleted) * cpukit/score/cpu/m32c/include/rtems/asm.h (deleted) * cpukit/score/cpu/m32c/include/rtems/score/cpu.h (deleted) * cpukit/score/cpu/m32c/include/rtems/score/cpu_asm.h (deleted) * cpukit/score/cpu/m32c/include/rtems/score/cpuatomic.h (deleted) * cpukit/score/cpu/m32c/include/rtems/score/cpuimpl.h (deleted) * cpukit/score/cpu/m32c/include/rtems/score/m32c.h (deleted) * cpukit/score/cpu/m32c/include/varvects.h (deleted) * cpukit/score/cpu/m32c/m32c-exception-frame-print.c (deleted) * cpukit/score/cpu/m32c/varvects.S (deleted) * testsuites/sptests/sptask_err03/init.c (modified) * testsuites/sptests/sptimer_err02/init.c (modified) m32c: Remove this target Update #3599. Fri, 09 Nov 2018 18:16:27 GMT shashvatjain [7ea7178] * bsps/arm/csb337/include/at91rm9200.h (modified) * bsps/arm/csb337/include/at91rm9200_dbgu.h (modified) * bsps/arm/csb337/include/at91rm9200_emac.h (modified) * bsps/arm/csb337/include/at91rm9200_gpio.h (modified) * bsps/arm/csb337/include/at91rm9200_mem.h (modified) * bsps/arm/csb337/include/at91rm9200_pmc.h (modified) * bsps/arm/csb337/include/at91rm9200_usart.h (modified) * bsps/arm/csb337/include/bits.h (modified) * bsps/arm/csb337/include/bsp/irq.h (modified) * bsps/arm/csb337/include/tm27.h (modified) arm/csb337: Update Doxygen (GCI 2018) Thu, 08 Nov 2018 00:47:49 GMT shashvatjain [b3c624d8] * bsps/arm/altera-cyclone-v/i2c/i2cdrv-config.h (modified) * bsps/arm/altera-cyclone-v/include/bsp.h (modified) * bsps/arm/altera-cyclone-v/include/bsp/hwlib.h (modified) * bsps/arm/altera-cyclone-v/include/bsp/i2cdrv.h (modified) * bsps/arm/altera-cyclone-v/include/bsp/irq.h (modified) arm/altera cyclone v: Update Doxygen (GCI 2018) Thu, 08 Nov 2018 12:49:38 GMT Sebastian Huber [84aedcae] * bsps/powerpc/shared/clock/clock-ppc-dec.c (modified) * bsps/powerpc/shared/exceptions/ppc_exc_print.c (modified) * cpukit/libdebugger/rtems-debugger-threads.h (modified) Include missing Update #3598. Fri, 09 Nov 2018 12:47:20 GMT Sebastian Huber [5841e0b] * bsps/arm/lpc32xx/rtc/rtc-config.c (modified) bsp/lpc32xx: Include missing Update #3598. Fri, 09 Nov 2018 09:46:50 GMT Sebastian Huber [fdd3b85] * bsps/powerpc/motorola_powerpc/bootloader/misc.c (modified) * bsps/powerpc/motorola_powerpc/bootloader/mm.c (modified) * bsps/powerpc/motorola_powerpc/bootloader/pci.c (modified) * bsps/powerpc/motorola_powerpc/console/polled_io.c (modified) bsp/motorola_powerpc: Include Update #3598. Fri, 09 Nov 2018 08:40:45 GMT Sebastian Huber [0288536] * bsps/shared/dev/clock/clockimpl.h (modified) bsps: Include missing header files Update #3598. Fri, 09 Nov 2018 08:37:53 GMT Sebastian Huber [efdb4a7] * bsps/powerpc/beatnik/include/bsp.h (modified) * bsps/powerpc/beatnik/include/bsp/if_mve_pub.h (modified) * bsps/powerpc/beatnik/net/if_em/if_em_hw.c (modified) * bsps/powerpc/beatnik/net/if_gfe/if_gfe.c (modified) * bsps/powerpc/beatnik/net/porting/rtemscompat.h (modified) * bsps/powerpc/shared/start/pgtbl_setup.c (modified) * bsps/shared/net/if_dc.c (modified) bsp/beatnik: Fix warnings Thu, 08 Nov 2018 07:38:24 GMT Sebastian Huber [32953f90] * bsps/arm/realview-pbx-a9/headers.am (modified) bsp/realview-pbx-a9: Update headers.am Tue, 06 Nov 2018 18:34:15 GMT Sebastian Huber [4fea054c] * bsps/mips/shared/irq/exception.S (modified) * cpukit/Makefile.am (modified) * cpukit/include/rtems/score/isr.h (modified) * cpukit/score/cpu/m32c/cpu_asm.c (deleted) * cpukit/score/cpu/m68k/cpu_asm.S (modified) * cpukit/score/cpu/mips/cpu_asm.S (modified) * cpukit/score/cpu/moxie/cpu_asm.S (modified) * cpukit/score/cpu/no_cpu/cpu_asm.c (modified) * cpukit/score/cpu/sparc/cpu.c (modified) * cpukit/score/cpu/sparc64/cpu.c (modified) * cpukit/score/cpu/sparc64/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc64/interrupt.S (modified) score: Remove _ISR_Dispatch() This function was only used on some ... Tue, 06 Nov 2018 15:58:02 GMT Sebastian Huber [ff081aee] * bsps/arm/csb336/start/start.S (modified) * bsps/arm/csb337/start/start.S (modified) * bsps/arm/edb7312/start/start.S (modified) * bsps/arm/gumstix/start/start.S (modified) * bsps/arm/rtl22xx/start/start.S (modified) * bsps/arm/shared/start/start.S (modified) * bsps/arm/smdk2410/start/start.S (modified) * bsps/lm32/shared/start/start.S (modified) * bsps/m32c/m32cbsp/start/start.S (modified) * bsps/m68k/gen68340/start/start.S (modified) * bsps/m68k/gen68360/start/start.S (modified) * bsps/m68k/genmcf548x/start/start.S (modified) * bsps/m68k/mcf52235/start/start.S (modified) * bsps/m68k/mcf5225x/start/start.S (modified) * bsps/m68k/mcf5329/start/start.S (modified) * bsps/m68k/mrm332/start/start.S (modified) * bsps/m68k/shared/start/start.S (modified) * bsps/mips/csb350/start/start.S (modified) * bsps/mips/jmr3904/start/start.S (modified) * bsps/mips/malta/start/start.S (modified) * bsps/powerpc/gen83xx/start/start.S (modified) * bsps/powerpc/haleakala/start/dlentry.S (modified) * bsps/powerpc/include/bsp/vectors.h (modified) * bsps/powerpc/mpc55xxevb/start/bspstart.c (modified) * bsps/powerpc/mpc55xxevb/start/start.S (modified) * bsps/powerpc/psim/start/bspstart.c (modified) * bsps/powerpc/psim/start/start.S (modified) * bsps/powerpc/qemuppc/start/start.S (modified) * bsps/powerpc/qoriq/start/bspstart.c (modified) * bsps/powerpc/qoriq/start/start.S (modified) * bsps/powerpc/ss555/start/bspstart.c (modified) * bsps/powerpc/ss555/start/start.S (modified) * bsps/powerpc/t32mppc/start/bspstart.c (modified) * bsps/powerpc/t32mppc/start/start.S (modified) * bsps/powerpc/tqm8xx/start/start.S (modified) * bsps/powerpc/virtex/start/bspstart.c (modified) * bsps/powerpc/virtex4/start/start.S (modified) * bsps/powerpc/virtex5/start/start.S (modified) * bsps/riscv/riscv/start/start.S (modified) * bsps/sh/gensh1/start/start.S (modified) * bsps/sh/gensh2/start/start.S (modified) * bsps/sh/gensh2/start/start.ram (modified) * bsps/sh/gensh2/start/start.rom (modified) * bsps/sh/gensh4/start/start.S (modified) * bsps/sh/shsim/start/start.S (modified) * bsps/sparc/shared/start/start.S (modified) * bsps/v850/gdbv850sim/start/start.S (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/config.h (modified) * cpukit/include/rtems/score/isr.h (modified) * cpukit/libmisc/stackchk/check.c (modified) * cpukit/score/cpu/m68k/cpu.c (modified) * cpukit/score/src/isr.c (modified) score: Rename interrupt stack symbols Rename * ... Wed, 07 Nov 2018 10:08:50 GMT Sebastian Huber [2faea99] * bsps/arm/realview-pbx-a9/console/console-config.c (modified) * bsps/arm/realview-pbx-a9/console/console-polled.c (added) * bsps/arm/realview-pbx-a9/include/bsp/console.h (added) * c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am (modified) bsp/realview-pbx-a9: Fix printk() support Avoid dependencies on the ... Mon, 05 Nov 2018 20:48:20 GMT Gedare Bloom [d7c51da] * bsps/arm/altera-cyclone-v/include/tm27.h (modified) altera-cyclone-v: tweak ingroup Sat, 03 Nov 2018 20:45:50 GMT ABR290B <44733601+ABR290B@…> [3b930548] * bsps/arm/altera-cyclone-v/include/tm27.h (modified) arm/altera-cyclone-v: update doxygen (GCI 2018) Wed, 24 Oct 2018 08:17:58 GMT Sebastian Huber [01595a4] * bsps/arm/imx/start/bspstarthooks.c (modified) * c/src/lib/libbsp/arm/imx/Makefile.am (modified) bsp/imx: Adjust workspace according to device tree Wed, 05 Sep 2018 23:02:30 GMT Joel Sherrill [28fb5b71] * bsps/powerpc/mpc8260ads/start/bspstart.c (modified) mpc8260ads/start/bspstart.c: Fix unused function warning Tue, 04 Sep 2018 13:35:37 GMT Joel Sherrill [c1233a33] * bsps/powerpc/qemuppc/start/cmain.c (modified) qemuppc/start/cmain.c: Cast args to memcpy and bzero to fix warnings Tue, 04 Sep 2018 13:35:07 GMT Joel Sherrill [156b77a] * bsps/powerpc/gen5200/mscan/mscan.c (modified) gen5200/mscan/mscan.c: Fix printf() format warning Tue, 04 Sep 2018 13:34:42 GMT Joel Sherrill [023bd1d] * bsps/or1k/shared/cache/cache.c (modified) or1k/shared/cache/cache.c: Remove unused methods Tue, 04 Sep 2018 13:34:22 GMT Joel Sherrill [35eab84] * bsps/arm/gdbarmsim/include/bsp.h (modified) gdbarmsim/include/bsp.h: Include to fix warning Thu, 18 Oct 2018 05:22:44 GMT Sebastian Huber [68799dac] * bsps/arm/atsam/contrib/libraries/libchip/source/aes.c (modified) * bsps/arm/atsam/include/libchip/include/aes.h (modified) bsp/atsam: Add const qualifier to AES_SetInput() Wed, 17 Oct 2018 07:43:55 GMT Sebastian Huber [143c8d0] * bsps/shared/dev/serial/ns16550-context.c (modified) serial/ns16550: Fix precision clock synthesizer The precision clock ... Tue, 16 Oct 2018 12:34:38 GMT Sebastian Huber [d7c13c8] * bsps/arm/imx/console/console-config.c (modified) bsp/imx7: Add getchark() support Mon, 15 Oct 2018 08:38:49 GMT Sebastian Huber [186a0b1] * bsps/arm/shared/start/linkcmds.base (modified) bsps/arm: Recognize .tm_clone_table input section Mon, 15 Oct 2018 06:44:52 GMT Pavel Pisa [1822649] * bsps/arm/tms570/include/bsp/ti_herc/reg_sys.h (modified) bsp/tms570: Simple fix to resolve macro redefinitions. closes #3347 Fri, 31 Aug 2018 06:21:05 GMT Daniel Hellstrom [dc32b6a] * bsps/sparc/leon3/config/gr712rc.cfg (modified) * bsps/sparc/leon3/config/gr740.cfg (modified) leon: do not use -mfix-{device} with Clang Clang do not support ... Fri, 21 Jul 2017 12:18:50 GMT Javier Jalle [6dc0b5f] * bsps/sparc/headers.am (modified) * bsps/sparc/include/bsp/spwtdp.h (added) * bsps/sparc/include/drvmgr/ambapp_bus.h (modified) * bsps/sparc/shared/spw/spwtdp.c (added) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * cpukit/include/drvmgr/drvmgr_confdefs.h (modified) leon, spwtdp: Initial driver commit Tue, 09 Oct 2018 09:59:48 GMT Sebastian Huber [511ef83c] * bsps/arm/shared/start/linkcmds.base (modified) bsps/arm: Fix ctor/dtor invocation order Remove obsolete .ctor and ... Thu, 04 Oct 2018 12:35:00 GMT Sebastian Huber [b131cb2] * bsps/arm/atsam/start/linkcmds.sdram (modified) bsp/atsam: Use internal SRAM for stack area Tue, 02 Oct 2018 08:22:15 GMT Sebastian Huber [f004b2b8] * bsps/powerpc/mpc55xxevb/net/smsc9218i.c (modified) * bsps/powerpc/mvme5500/net/if_100MHz/GT64260eth.c (modified) * bsps/powerpc/mvme5500/net/if_1GHz/if_wm.c (modified) * bsps/powerpc/shared/net/tsec.c (modified) * bsps/shared/dev/ide/ata.c (modified) * bsps/sparc/shared/spw/grspw_pkt.c (modified) * cpukit/ftpd/ftpd.c (modified) * cpukit/include/rtems/rtems/event.h (modified) * cpukit/include/rtems/status-checks.h (modified) * cpukit/libblock/src/bdbuf.c (modified) * cpukit/libcsupport/src/termios.c (modified) * cpukit/libdebugger/rtems-debugger-server.c (modified) * cpukit/libfs/src/nfsclient/src/nfs.c (modified) * cpukit/libmisc/cpuuse/cpuusagetop.c (modified) * cpukit/libmisc/monitor/mon-server.c (modified) * cpukit/libmisc/redirector/stdio-redirect.c (modified) * cpukit/libmisc/shell/shell.c (modified) * cpukit/libnetworking/rtems/rtems_dhcp.c (modified) * cpukit/libnetworking/rtems/rtems_dhcp_failsafe.c (modified) * cpukit/librpc/src/rpc/rtems_portmapper.c (modified) * cpukit/pppd/rtemspppd.c (modified) * cpukit/score/cpu/i386/sse_test.c (modified) * cpukit/telnetd/telnetd.c (modified) Use rtems_task_exit() Update #3530. Update #3533. Mon, 01 Oct 2018 06:59:14 GMT Sebastian Huber [5cb23f4b] * bsps/arm/atsam/i2c/atsam_i2c_bus.c (modified) * bsps/arm/atsam/include/bsp/atsam-i2c.h (modified) bsp/atsam: Use binary semaphore for I2C Remove superfluous sleep ... Fri, 28 Sep 2018 12:45:16 GMT Sebastian Huber [fca9132] * bsps/arm/atsam/spi/atsam_spi_bus.c (modified) bsp/atsam: Use binary semaphore for SPI Update #3534. Fri, 21 Sep 2018 05:38:23 GMT Sebastian Huber [69a24c3] * bsps/arm/imx/start/ccm.c (modified) * c/src/lib/libbsp/arm/imx/configure.ac (modified) bsp/imx: Add imx_ccm_sdhci_hz() Update #3525. Wed, 19 Sep 2018 13:18:38 GMT Daniel Hellstrom [9ed109c] * bsps/sparc/shared/uart/cons.c (modified) leon: remove warning missing string.h Wed, 21 Feb 2018 18:23:35 GMT Martin Aberg [c2011b47] * bsps/sparc/include/bsp/grspw_pkt.h (modified) * bsps/sparc/shared/spw/grspw_pkt.c (modified) leon, grspw_pkt: support CCSDS/ISO16 data CRC When the CCSDS/CCITT ... Mon, 13 Aug 2018 09:36:03 GMT Daniel Hellstrom [0aae151] * bsps/sparc/shared/spw/grspw_pkt.c (modified) leon,grspw_pkt: protect TX descriptor from bad input (hdrlen) Fri, 15 Jun 2018 10:54:32 GMT Martin Aberg [ddc95ab0] * bsps/sparc/shared/l2c/l2c.c (modified) leon, l2cache: workaround for scrubber This is a workaround for a ... Tue, 23 Jan 2018 09:12:36 GMT Daniel Hellstrom [56a7540] * bsps/sparc/shared/iommu/griommu.c (modified) * bsps/sparc/shared/l2c/l2c.c (modified) * bsps/sparc/shared/pci/gr_701.c (modified) * bsps/sparc/shared/pci/gr_cpci_gr740.c (modified) * bsps/sparc/shared/pci/gr_leon4_n2x.c (modified) * bsps/sparc/shared/pci/gr_rasta_adcdac.c (modified) * bsps/sparc/shared/pci/gr_rasta_io.c (modified) * bsps/sparc/shared/pci/gr_rasta_spw_router.c (modified) * bsps/sparc/shared/pci/gr_rasta_tmtc.c (modified) * bsps/sparc/shared/pci/gr_tmtc_1553.c (modified) * bsps/sparc/shared/pci/grpci.c (modified) * bsps/sparc/shared/pci/grpci2.c (modified) * bsps/sparc/shared/pci/pcif.c (modified) * bsps/sparc/shared/spi/spictrl.c (modified) leon: substitute printf with printk in driver init Tue, 21 Nov 2017 12:19:05 GMT Daniel Hellstrom [68a0012] * bsps/sparc/shared/btimer/tlib_ckinit.c (modified) leon3, ckinit: avoid unsued code warnings when drvmgr is enabled Tue, 21 Nov 2017 10:09:58 GMT Daniel Hellstrom [d952d73] * bsps/sparc/leon3/clock/ckinit.c (modified) leon3: fix warning when SMP is enabled Thu, 20 Sep 2018 05:27:28 GMT Sebastian Huber [b3cf79b] * bsps/sparc/leon3/start/cpucounter.c (modified) bsp/leon3: Fix typo which breaks the CPU counter Update #3456. Mon, 17 Sep 2018 12:12:07 GMT Hesham Almatary [9cda6f29] * bsps/riscv/riscv/irq/irq.c (modified) riscv: Allow platforms with no PLIC to proceed Spike simulator and ... Mon, 17 Sep 2018 06:28:29 GMT Sebastian Huber [62cb39d7] * bsps/powerpc/tqm8xx/dev/clock.c (deleted) * bsps/powerpc/tqm8xx/dev/console-generic.c (deleted) * c/src/lib/libbsp/powerpc/tqm8xx/Makefile.am (modified) bsp/tqm8xx: Remove unused files Close #3513. Fri, 14 Sep 2018 05:30:46 GMT Sebastian Huber [688e101a] * bsps/powerpc/include/mpc8xx.h (modified) * bsps/powerpc/tqm8xx/console/console.c (modified) bsp/tqm8xx: Fix polled vs. interrupt output Update #3513. Wed, 12 Sep 2018 09:47:19 GMT Sebastian Huber [d22147e] * bsps/powerpc/tqm8xx/console/console.c (modified) * c/src/lib/libbsp/powerpc/tqm8xx/Makefile.am (modified) bsp/tqm8xx: Convert console to new Termios API Update #3513. Wed, 12 Sep 2018 08:43:02 GMT Sebastian Huber [68920e7f] * bsps/powerpc/tqm8xx/console/console.c (modified) bsp/tqm8xx: Move DMA support to channel descriptor Update #3513. Wed, 12 Sep 2018 08:24:56 GMT Sebastian Huber [53fb03fe] * bsps/powerpc/tqm8xx/console/console.c (modified) bsp/tqm8xx: Move rxBuf to channel descriptor Update #3513. Wed, 12 Sep 2018 08:08:50 GMT Sebastian Huber [7b93d857] * bsps/powerpc/tqm8xx/console/console.c (modified) bsp/tqm8xx: Use IRQ extensions API Update #3513. Thu, 13 Sep 2018 09:34:23 GMT Sebastian Huber [94ea8a8] * bsps/powerpc/tqm8xx/start/start.S (modified) bsp/tqm8xx: Clear sbss section Thu, 13 Sep 2018 09:33:50 GMT Sebastian Huber [7916139] * bsps/powerpc/tqm8xx/start/bspstart.c (modified) bsp/tqm8xx: Use custom string to uint32_t Avoid C locale support ... Fri, 07 Sep 2018 04:19:02 GMT Sebastian Huber [cb68253] * bsps/arm/atsam/net/if_atsam.c (modified) * bsps/arm/csb336/net/lan91c11x.c (modified) * bsps/arm/csb336/net/network.c (modified) * bsps/arm/csb337/net/network.c (modified) * bsps/arm/edb7312/net/network.c (modified) * bsps/arm/gumstix/net/rtl8019.c (modified) * bsps/arm/rtl22xx/net/network.c (modified) * bsps/arm/shared/net/lpc-ethernet.c (modified) * bsps/bfin/bf537Stamp/net/ethernet.c (modified) * bsps/bfin/bf537Stamp/net/networkconfig.c (modified) * bsps/i386/pc386/net/3c509.c (modified) * bsps/i386/pc386/net/elink.c (modified) * bsps/i386/pc386/net/ne2000.c (modified) * bsps/i386/pc386/net/wd8003.c (modified) * bsps/lm32/shared/net/network.c (modified) * bsps/lm32/shared/net/tsmac.c (modified) * bsps/m68k/av5282/net/network.c (modified) * bsps/m68k/csb360/net/network.c (modified) * bsps/m68k/gen68360/net/network.c (modified) * bsps/m68k/genmcf548x/net/network.c (modified) * bsps/m68k/mcf5235/net/network.c (modified) * bsps/m68k/mcf5329/net/network.c (modified) * bsps/m68k/mvme167/net/network.c (modified) * bsps/m68k/uC5282/net/network.c (modified) * bsps/mips/csb350/net/network.c (modified) * bsps/powerpc/beatnik/net/porting/rtemscompat.h (modified) * bsps/powerpc/gen5200/net/network.c (modified) * bsps/powerpc/gen83xx/net/network.c (modified) * bsps/powerpc/haleakala/net/network.c (modified) * bsps/powerpc/mpc55xxevb/net/smsc9218i.c (modified) * bsps/powerpc/mpc8260ads/net/if_hdlcsubr.c (modified) * bsps/powerpc/mpc8260ads/net/network.c (modified) * bsps/powerpc/mvme3100/net/tsec.c (modified) * bsps/powerpc/mvme5500/net/if_100MHz/GT64260eth.c (modified) * bsps/powerpc/mvme5500/net/if_1GHz/if_wm.c (modified) * bsps/powerpc/qoriq/net/if_intercom.c (modified) * bsps/powerpc/qoriq/net/network.c (modified) * bsps/powerpc/shared/net/tsec.c (modified) * bsps/powerpc/tqm8xx/net/network_fec.c (modified) * bsps/powerpc/tqm8xx/net/network_scc.c (modified) * bsps/powerpc/virtex/net/xiltemac.c (modified) * bsps/shared/net/cs8900.c (modified) * bsps/shared/net/dec21140.c (modified) * bsps/shared/net/elnk.c (modified) * bsps/shared/net/greth2.c (modified) * bsps/shared/net/i82586.c (modified) * bsps/shared/net/if_dc.c (modified) * bsps/shared/net/if_fxp.c (modified) * bsps/shared/net/open_eth.c (modified) * bsps/shared/net/smc91111.c (modified) * bsps/shared/net/sonic.c (modified) * bsps/sparc/erc32/net/erc32sonic.c (modified) * bsps/sparc/leon2/net/leon_open_eth.c (modified) * bsps/sparc/leon2/net/leon_smc91111.c (modified) * bsps/sparc/leon3/net/leon_greth.c (modified) * bsps/sparc/leon3/net/leon_open_eth.c (modified) * bsps/sparc/leon3/net/leon_smc91111.c (modified) * bsps/sparc/shared/net/greth.c (modified) * cpukit/libfs/src/nfsclient/src/sock_mbuf.c (modified) * cpukit/libnetworking/Makefile.am (modified) * cpukit/libnetworking/kern/kern_mib.c (modified) * cpukit/libnetworking/kern/kern_subr.c (modified) * cpukit/libnetworking/kern/kern_sysctl.c (modified) * cpukit/libnetworking/kern/uipc_domain.c (modified) * cpukit/libnetworking/kern/uipc_mbuf.c (modified) * cpukit/libnetworking/kern/uipc_socket.c (modified) * cpukit/libnetworking/kern/uipc_socket2.c (modified) * cpukit/libnetworking/lib/getprotoby.c (modified) * cpukit/libnetworking/lib/rtems_bsdnet_ntp.c (modified) * cpukit/libnetworking/lib/syslog.c (modified) * cpukit/libnetworking/libc/base64.c (modified) * cpukit/libnetworking/libc/gethostbydns.c (modified) * cpukit/libnetworking/libc/gethostbyht.c (modified) * cpukit/libnetworking/libc/gethostbynis.c (modified) * cpukit/libnetworking/libc/gethostnamadr.c (modified) * cpukit/libnetworking/libc/getifaddrs.c (modified) * cpukit/libnetworking/libc/getnameinfo.c (modified) * cpukit/libnetworking/libc/getnetbydns.c (modified) * cpukit/libnetworking/libc/getnetbyht.c (modified) * cpukit/libnetworking/libc/getnetbynis.c (modified) * cpukit/libnetworking/libc/getnetnamadr.c (modified) * cpukit/libnetworking/libc/getproto.c (modified) * cpukit/libnetworking/libc/getprotoent.c (modified) * cpukit/libnetworking/libc/getprotoname.c (modified) * cpukit/libnetworking/libc/getservbyname.c (modified) * cpukit/libnetworking/libc/getservbyport.c (modified) * cpukit/libnetworking/libc/getservent.c (modified) * cpukit/libnetworking/libc/herror.c (modified) * cpukit/libnetworking/libc/if_indextoname.c (modified) * cpukit/libnetworking/libc/if_nameindex.c (modified) * cpukit/libnetworking/libc/inet_addr.c (modified) * cpukit/libnetworking/libc/inet_lnaof.c (modified) * cpukit/libnetworking/libc/inet_makeaddr.c (modified) * cpukit/libnetworking/libc/inet_netof.c (modified) * cpukit/libnetworking/libc/inet_network.c (modified) * cpukit/libnetworking/libc/inet_ntoa.c (modified) * cpukit/libnetworking/libc/inet_ntop.c (modified) * cpukit/libnetworking/libc/inet_pton.c (modified) * cpukit/libnetworking/libc/linkaddr.c (modified) * cpukit/libnetworking/libc/map_v4v6.c (modified) * cpukit/libnetworking/libc/ns_name.c (modified) * cpukit/libnetworking/libc/ns_netint.c (modified) * cpukit/libnetworking/libc/ns_parse.c (modified) * cpukit/libnetworking/libc/ns_print.c (modified) * cpukit/libnetworking/libc/ns_ttl.c (modified) * cpukit/libnetworking/libc/nsap_addr.c (modified) * cpukit/libnetworking/libc/rcmd.c (modified) * cpukit/libnetworking/libc/recv.c (modified) * cpukit/libnetworking/libc/res_comp.c (modified) * cpukit/libnetworking/libc/res_data.c (modified) * cpukit/libnetworking/libc/res_debug.c (modified) * cpukit/libnetworking/libc/res_init.c (modified) * cpukit/libnetworking/libc/res_mkquery.c (modified) * cpukit/libnetworking/libc/res_mkupdate.c (modified) * cpukit/libnetworking/libc/res_query.c (modified) * cpukit/libnetworking/libc/res_send.c (modified) * cpukit/libnetworking/libc/res_stubs.c (modified) * cpukit/libnetworking/libc/res_update.c (modified) * cpukit/libnetworking/libc/send.c (modified) * cpukit/libnetworking/libc/strsep.c (modified) * cpukit/libnetworking/machine/rtems-bsd-kernel-space.h (added) * cpukit/libnetworking/machine/rtems-bsd-user-space.h (added) * cpukit/libnetworking/net/if.c (modified) * cpukit/libnetworking/net/if_ethersubr.c (modified) * cpukit/libnetworking/net/if_loop.c (modified) * cpukit/libnetworking/net/if_ppp.c (modified) * cpukit/libnetworking/net/ppp_tty.c (modified) * cpukit/libnetworking/net/radix.c (modified) * cpukit/libnetworking/net/raw_cb.c (modified) * cpukit/libnetworking/net/raw_usrreq.c (modified) * cpukit/libnetworking/net/route.c (modified) * cpukit/libnetworking/net/rtsock.c (modified) * cpukit/libnetworking/net/slcompress.c (modified) * cpukit/libnetworking/netinet/if_ether.c (modified) * cpukit/libnetworking/netinet/igmp.c (modified) * cpukit/libnetworking/netinet/in.c (modified) * cpukit/libnetworking/netinet/in_cksum.c (modified) * cpukit/libnetworking/netinet/in_pcb.c (modified) * cpukit/libnetworking/netinet/in_proto.c (modified) * cpukit/libnetworking/netinet/in_rmx.c (modified) * cpukit/libnetworking/netinet/ip_divert.c (modified) * cpukit/libnetworking/netinet/ip_fw.c (modified) * cpukit/libnetworking/netinet/ip_icmp.c (modified) * cpukit/libnetworking/netinet/ip_input.c (modified) * cpukit/libnetworking/netinet/ip_mroute.c (modified) * cpukit/libnetworking/netinet/ip_output.c (modified) * cpukit/libnetworking/netinet/raw_ip.c (modified) * cpukit/libnetworking/netinet/tcp_debug.c (modified) * cpukit/libnetworking/netinet/tcp_input.c (modified) * cpukit/libnetworking/netinet/tcp_output.c (modified) * cpukit/libnetworking/netinet/tcp_subr.c (modified) * cpukit/libnetworking/netinet/tcp_timer.c (modified) * cpukit/libnetworking/netinet/tcp_usrreq.c (modified) * cpukit/libnetworking/netinet/udp_usrreq.c (modified) * cpukit/libnetworking/nfs/bootp_subr.c (modified) * cpukit/libnetworking/rtems/mkrootfs.c (modified) * cpukit/libnetworking/rtems/rtems_bootp.c (modified) * cpukit/libnetworking/rtems/rtems_bsdnet.h (modified) * cpukit/libnetworking/rtems/rtems_bsdnet_malloc_starvation.c (modified) * cpukit/libnetworking/rtems/rtems_dhcp.c (modified) * cpukit/libnetworking/rtems/rtems_dhcp_failsafe.c (modified) * cpukit/libnetworking/rtems/rtems_glue.c (modified) * cpukit/libnetworking/rtems/rtems_malloc_mbuf.c (modified) * cpukit/libnetworking/rtems/rtems_mii_ioctl.c (modified) * cpukit/libnetworking/rtems/rtems_mii_ioctl_kern.c (modified) * cpukit/libnetworking/rtems/rtems_select.c (modified) * cpukit/libnetworking/rtems/rtems_showicmpstat.c (modified) * cpukit/libnetworking/rtems/rtems_showifstat.c (modified) * cpukit/libnetworking/rtems/rtems_showipstat.c (modified) * cpukit/libnetworking/rtems/rtems_showmbuf.c (modified) * cpukit/libnetworking/rtems/rtems_showroute.c (modified) * cpukit/libnetworking/rtems/rtems_showtcpstat.c (modified) * cpukit/libnetworking/rtems/rtems_showudpstat.c (modified) * cpukit/libnetworking/rtems/rtems_socketpair.c (modified) * cpukit/libnetworking/rtems/rtems_syscall.c (modified) * cpukit/libnetworking/rtems/rtems_syscall_api.c (modified) * cpukit/libnetworking/rtems/sghostname.c (modified) * cpukit/wrapup/Makefile.am (modified) network: Use kernel/user space header files Add and use ... Thu, 06 Sep 2018 05:03:49 GMT Sebastian Huber [2f61eb21] * bsps/powerpc/qoriq/include/bsp/qoriq.h (modified) bsp/qoriq: Add struct qoriq to allow forward decls Tue, 04 Sep 2018 16:28:57 GMT Sebastian Huber [54d87f2] * bsps/powerpc/beatnik/start/bspstart.c (modified) * bsps/powerpc/gen5200/start/bspstart.c (modified) * bsps/powerpc/gen83xx/start/bspstart.c (modified) * bsps/powerpc/haleakala/start/bspstart.c (modified) * bsps/powerpc/include/bsp/vectors.h (modified) * bsps/powerpc/motorola_powerpc/start/bspstart.c (modified) * bsps/powerpc/mpc55xxevb/start/bspstart.c (modified) * bsps/powerpc/mpc8260ads/start/bspstart.c (modified) * bsps/powerpc/mvme3100/start/bspstart.c (modified) * bsps/powerpc/mvme5500/start/bspstart.c (modified) * bsps/powerpc/psim/start/bspstart.c (modified) * bsps/powerpc/qemuppc/start/bspstart.c (modified) * bsps/powerpc/qoriq/start/bspsmp.c (modified) * bsps/powerpc/qoriq/start/bspstart.c (modified) * bsps/powerpc/shared/exceptions/ppc_exc_initialize.c (modified) * bsps/powerpc/shared/start/bspgetworkarea.c (modified) * bsps/powerpc/t32mppc/start/bspstart.c (modified) * bsps/powerpc/tqm8xx/start/bspstart.c (modified) * bsps/powerpc/virtex/start/bspstart.c (modified) * bsps/powerpc/virtex4/start/bspstart.c (modified) * bsps/powerpc/virtex5/start/bspstart.c (modified) bsps/powerpc: Simplify ppc_exc_initialize() Remove parameters from ... Wed, 05 Sep 2018 05:38:13 GMT Sebastian Huber [9a21fc7] * bsps/powerpc/mpc55xxevb/dev/dspi.c (modified) bsp/mpc55xxevb: Fix format warning Close #3504. Wed, 05 Sep 2018 05:31:23 GMT Sebastian Huber [ccdce9d8] * bsps/include/libchip/ata.h (modified) libchip/ata: Fix ATA_DRIVER_TABLE_ENTRY Drop unused and deprecated ... Fri, 31 Aug 2018 05:44:53 GMT Sebastian Huber [fad3f79b] * bsps/arm/raspberrypi/start/bspgetworkarea.c (modified) * bsps/powerpc/gen83xx/start/bspstart.c (modified) * bsps/powerpc/mpc55xxevb/include/bsp.h (modified) * bsps/powerpc/mpc55xxevb/start/bspgetworkarea.c (modified) * bsps/powerpc/mpc55xxevb/start/bspstart.c (modified) * bsps/powerpc/psim/start/bspstart.c (modified) * bsps/powerpc/qoriq/start/bspstart.c (modified) * bsps/powerpc/qoriq/start/mmu-config.c (modified) * bsps/powerpc/t32mppc/start/bspstart.c (modified) * bsps/powerpc/virtex/include/bsp.h (modified) * bsps/powerpc/virtex/start/bspstart.c (modified) * bsps/shared/start/bspgetworkarea-default.c (modified) * c/src/lib/libbsp/powerpc/gen83xx/configure.ac (modified) * c/src/lib/libbsp/powerpc/psim/configure.ac (modified) * c/src/lib/libbsp/powerpc/qoriq/configure.ac (modified) bsps: BSP_INTERRUPT_STACK_AT_WORK_AREA_BEGIN Remove the ... Wed, 29 Aug 2018 17:51:50 GMT Joel Sherrill [66e78854] * bsps/sparc64/shared/helenos/boot/generic/string.c (deleted) * c/src/lib/libbsp/sparc64/niagara/Makefile.am (modified) * c/src/lib/libbsp/sparc64/usiii/Makefile.am (modified) Remove bsps/sparc64/shared/helenos/boot/generic/string.c Wed, 29 Aug 2018 17:39:17 GMT Joel Sherrill [5da1593] * bsps/powerpc/psim/include/tm27.h (modified) psim/include/tm27.h: Fix not a prototype warnings Wed, 29 Aug 2018 17:39:01 GMT Joel Sherrill [a8d3f10] * bsps/powerpc/mvme5500/include/tm27.h (modified) mvme5500/include/tm27.h: Fix not a prototype warnings Wed, 29 Aug 2018 17:37:29 GMT Joel Sherrill [a5c3bfb] * bsps/m68k/uC5282/clock/clock.c (modified) uC5282/clock/clock.c: Correct bsp_idle_thread() prototype Wed, 29 Aug 2018 17:36:50 GMT Joel Sherrill [34e959fa] * bsps/m68k/gen68340/include/m340timer.h (modified) gen68340/include/m340timer.h: Fix not a prototype warnings Wed, 29 Aug 2018 17:36:18 GMT Joel Sherrill [76ac42ff] * bsps/arm/lpc32xx/include/bsp.h (modified) lpc32xx/include/bsp.h: Resolve set but not used warning Wed, 29 Aug 2018 17:34:58 GMT Joel Sherrill [350b07a0] * bsps/arm/csb337/umon/monlib.c (modified) * bsps/include/umon/monlib.h (modified) monlib.[ch]: Fix warnings for external vs internal use of .h Wed, 22 Aug 2018 16:58:12 GMT Joel Sherrill [60702ab] * bsps/powerpc/qoriq/include/tm27.h (modified) qoriq/include/tm27.h: Fix warnings Wed, 22 Aug 2018 16:57:57 GMT Joel Sherrill [126a454] * bsps/powerpc/gen5200/include/tm27.h (modified) gen5200/include/tm27.h: Fix warnings Wed, 22 Aug 2018 16:50:19 GMT Joel Sherrill [c80f5afc] * bsps/powerpc/mpc55xxevb/clock/clock-config.c (modified) mpc55xxevb/clock/clock-config.c: Remove unused ... Wed, 22 Aug 2018 14:30:44 GMT Joel Sherrill [76b3f8c] * bsps/powerpc/gen5200/include/bsp/bestcomm.h (modified) gen5200/include/bsp/bestcomm.h: Fix unused variable warning Tue, 21 Aug 2018 15:35:26 GMT Joel Sherrill [bb6eeabf] * bsps/i386/shared/cache/cache.c (modified) bsps/i386/shared/cache/cache.c: Fix warnings Tue, 21 Aug 2018 15:35:16 GMT Joel Sherrill [c2e8ed6] * bsps/arm/gdbarmsim/include/bsp.h (modified) gdbarmsim/include/bsp.h: Fix warnings Fri, 17 Aug 2018 18:30:19 GMT Joel Sherrill [cba349c] * bsps/m68k/shared/cache/cache.h (modified) bsps/m68k/shared/cache/cache.h: Fix warnings and clean up Wed, 29 Aug 2018 05:46:31 GMT Sebastian Huber [a6fca76] * bsps/powerpc/qoriq/README (deleted) bsp/qoriq: Remove README Update #2854.
