# # ChangeLog for bsps/sparc/shared in rtems # # Generated by Trac 1.2.1.dev0 # 04/19/24 13:09:32 Tue, 23 Jan 2018 09:12:36 GMT Daniel Hellstrom [56a7540] * bsps/sparc/shared/iommu/griommu.c (modified) * bsps/sparc/shared/l2c/l2c.c (modified) * bsps/sparc/shared/pci/gr_701.c (modified) * bsps/sparc/shared/pci/gr_cpci_gr740.c (modified) * bsps/sparc/shared/pci/gr_leon4_n2x.c (modified) * bsps/sparc/shared/pci/gr_rasta_adcdac.c (modified) * bsps/sparc/shared/pci/gr_rasta_io.c (modified) * bsps/sparc/shared/pci/gr_rasta_spw_router.c (modified) * bsps/sparc/shared/pci/gr_rasta_tmtc.c (modified) * bsps/sparc/shared/pci/gr_tmtc_1553.c (modified) * bsps/sparc/shared/pci/grpci.c (modified) * bsps/sparc/shared/pci/grpci2.c (modified) * bsps/sparc/shared/pci/pcif.c (modified) * bsps/sparc/shared/spi/spictrl.c (modified) leon: substitute printf with printk in driver init Tue, 21 Nov 2017 12:19:05 GMT Daniel Hellstrom [68a0012] * bsps/sparc/shared/btimer/tlib_ckinit.c (modified) leon3, ckinit: avoid unsued code warnings when drvmgr is enabled Fri, 07 Sep 2018 04:19:02 GMT Sebastian Huber [cb68253] * bsps/arm/atsam/net/if_atsam.c (modified) * bsps/arm/csb336/net/lan91c11x.c (modified) * bsps/arm/csb336/net/network.c (modified) * bsps/arm/csb337/net/network.c (modified) * bsps/arm/edb7312/net/network.c (modified) * bsps/arm/gumstix/net/rtl8019.c (modified) * bsps/arm/rtl22xx/net/network.c (modified) * bsps/arm/shared/net/lpc-ethernet.c (modified) * bsps/bfin/bf537Stamp/net/ethernet.c (modified) * bsps/bfin/bf537Stamp/net/networkconfig.c (modified) * bsps/i386/pc386/net/3c509.c (modified) * bsps/i386/pc386/net/elink.c (modified) * bsps/i386/pc386/net/ne2000.c (modified) * bsps/i386/pc386/net/wd8003.c (modified) * bsps/lm32/shared/net/network.c (modified) * bsps/lm32/shared/net/tsmac.c (modified) * bsps/m68k/av5282/net/network.c (modified) * bsps/m68k/csb360/net/network.c (modified) * bsps/m68k/gen68360/net/network.c (modified) * bsps/m68k/genmcf548x/net/network.c (modified) * bsps/m68k/mcf5235/net/network.c (modified) * bsps/m68k/mcf5329/net/network.c (modified) * bsps/m68k/mvme167/net/network.c (modified) * bsps/m68k/uC5282/net/network.c (modified) * bsps/mips/csb350/net/network.c (modified) * bsps/powerpc/beatnik/net/porting/rtemscompat.h (modified) * bsps/powerpc/gen5200/net/network.c (modified) * bsps/powerpc/gen83xx/net/network.c (modified) * bsps/powerpc/haleakala/net/network.c (modified) * bsps/powerpc/mpc55xxevb/net/smsc9218i.c (modified) * bsps/powerpc/mpc8260ads/net/if_hdlcsubr.c (modified) * bsps/powerpc/mpc8260ads/net/network.c (modified) * bsps/powerpc/mvme3100/net/tsec.c (modified) * bsps/powerpc/mvme5500/net/if_100MHz/GT64260eth.c (modified) * bsps/powerpc/mvme5500/net/if_1GHz/if_wm.c (modified) * bsps/powerpc/qoriq/net/if_intercom.c (modified) * bsps/powerpc/qoriq/net/network.c (modified) * bsps/powerpc/shared/net/tsec.c (modified) * bsps/powerpc/tqm8xx/net/network_fec.c (modified) * bsps/powerpc/tqm8xx/net/network_scc.c (modified) * bsps/powerpc/virtex/net/xiltemac.c (modified) * bsps/shared/net/cs8900.c (modified) * bsps/shared/net/dec21140.c (modified) * bsps/shared/net/elnk.c (modified) * bsps/shared/net/greth2.c (modified) * bsps/shared/net/i82586.c (modified) * bsps/shared/net/if_dc.c (modified) * bsps/shared/net/if_fxp.c (modified) * bsps/shared/net/open_eth.c (modified) * bsps/shared/net/smc91111.c (modified) * bsps/shared/net/sonic.c (modified) * bsps/sparc/erc32/net/erc32sonic.c (modified) * bsps/sparc/leon2/net/leon_open_eth.c (modified) * bsps/sparc/leon2/net/leon_smc91111.c (modified) * bsps/sparc/leon3/net/leon_greth.c (modified) * bsps/sparc/leon3/net/leon_open_eth.c (modified) * bsps/sparc/leon3/net/leon_smc91111.c (modified) * bsps/sparc/shared/net/greth.c (modified) * cpukit/libfs/src/nfsclient/src/sock_mbuf.c (modified) * cpukit/libnetworking/Makefile.am (modified) * cpukit/libnetworking/kern/kern_mib.c (modified) * cpukit/libnetworking/kern/kern_subr.c (modified) * cpukit/libnetworking/kern/kern_sysctl.c (modified) * cpukit/libnetworking/kern/uipc_domain.c (modified) * cpukit/libnetworking/kern/uipc_mbuf.c (modified) * cpukit/libnetworking/kern/uipc_socket.c (modified) * cpukit/libnetworking/kern/uipc_socket2.c (modified) * cpukit/libnetworking/lib/getprotoby.c (modified) * cpukit/libnetworking/lib/rtems_bsdnet_ntp.c (modified) * cpukit/libnetworking/lib/syslog.c (modified) * cpukit/libnetworking/libc/base64.c (modified) * cpukit/libnetworking/libc/gethostbydns.c (modified) * cpukit/libnetworking/libc/gethostbyht.c (modified) * cpukit/libnetworking/libc/gethostbynis.c (modified) * cpukit/libnetworking/libc/gethostnamadr.c (modified) * cpukit/libnetworking/libc/getifaddrs.c (modified) * cpukit/libnetworking/libc/getnameinfo.c (modified) * cpukit/libnetworking/libc/getnetbydns.c (modified) * cpukit/libnetworking/libc/getnetbyht.c (modified) * cpukit/libnetworking/libc/getnetbynis.c (modified) * cpukit/libnetworking/libc/getnetnamadr.c (modified) * cpukit/libnetworking/libc/getproto.c (modified) * cpukit/libnetworking/libc/getprotoent.c (modified) * cpukit/libnetworking/libc/getprotoname.c (modified) * cpukit/libnetworking/libc/getservbyname.c (modified) * cpukit/libnetworking/libc/getservbyport.c (modified) * cpukit/libnetworking/libc/getservent.c (modified) * cpukit/libnetworking/libc/herror.c (modified) * cpukit/libnetworking/libc/if_indextoname.c (modified) * cpukit/libnetworking/libc/if_nameindex.c (modified) * cpukit/libnetworking/libc/inet_addr.c (modified) * cpukit/libnetworking/libc/inet_lnaof.c (modified) * cpukit/libnetworking/libc/inet_makeaddr.c (modified) * cpukit/libnetworking/libc/inet_netof.c (modified) * cpukit/libnetworking/libc/inet_network.c (modified) * cpukit/libnetworking/libc/inet_ntoa.c (modified) * cpukit/libnetworking/libc/inet_ntop.c (modified) * cpukit/libnetworking/libc/inet_pton.c (modified) * cpukit/libnetworking/libc/linkaddr.c (modified) * cpukit/libnetworking/libc/map_v4v6.c (modified) * cpukit/libnetworking/libc/ns_name.c (modified) * cpukit/libnetworking/libc/ns_netint.c (modified) * cpukit/libnetworking/libc/ns_parse.c (modified) * cpukit/libnetworking/libc/ns_print.c (modified) * cpukit/libnetworking/libc/ns_ttl.c (modified) * cpukit/libnetworking/libc/nsap_addr.c (modified) * cpukit/libnetworking/libc/rcmd.c (modified) * cpukit/libnetworking/libc/recv.c (modified) * cpukit/libnetworking/libc/res_comp.c (modified) * cpukit/libnetworking/libc/res_data.c (modified) * cpukit/libnetworking/libc/res_debug.c (modified) * cpukit/libnetworking/libc/res_init.c (modified) * cpukit/libnetworking/libc/res_mkquery.c (modified) * cpukit/libnetworking/libc/res_mkupdate.c (modified) * cpukit/libnetworking/libc/res_query.c (modified) * cpukit/libnetworking/libc/res_send.c (modified) * cpukit/libnetworking/libc/res_stubs.c (modified) * cpukit/libnetworking/libc/res_update.c (modified) * cpukit/libnetworking/libc/send.c (modified) * cpukit/libnetworking/libc/strsep.c (modified) * cpukit/libnetworking/machine/rtems-bsd-kernel-space.h (added) * cpukit/libnetworking/machine/rtems-bsd-user-space.h (added) * cpukit/libnetworking/net/if.c (modified) * cpukit/libnetworking/net/if_ethersubr.c (modified) * cpukit/libnetworking/net/if_loop.c (modified) * cpukit/libnetworking/net/if_ppp.c (modified) * cpukit/libnetworking/net/ppp_tty.c (modified) * cpukit/libnetworking/net/radix.c (modified) * cpukit/libnetworking/net/raw_cb.c (modified) * cpukit/libnetworking/net/raw_usrreq.c (modified) * cpukit/libnetworking/net/route.c (modified) * cpukit/libnetworking/net/rtsock.c (modified) * cpukit/libnetworking/net/slcompress.c (modified) * cpukit/libnetworking/netinet/if_ether.c (modified) * cpukit/libnetworking/netinet/igmp.c (modified) * cpukit/libnetworking/netinet/in.c (modified) * cpukit/libnetworking/netinet/in_cksum.c (modified) * cpukit/libnetworking/netinet/in_pcb.c (modified) * cpukit/libnetworking/netinet/in_proto.c (modified) * cpukit/libnetworking/netinet/in_rmx.c (modified) * cpukit/libnetworking/netinet/ip_divert.c (modified) * cpukit/libnetworking/netinet/ip_fw.c (modified) * cpukit/libnetworking/netinet/ip_icmp.c (modified) * cpukit/libnetworking/netinet/ip_input.c (modified) * cpukit/libnetworking/netinet/ip_mroute.c (modified) * cpukit/libnetworking/netinet/ip_output.c (modified) * cpukit/libnetworking/netinet/raw_ip.c (modified) * cpukit/libnetworking/netinet/tcp_debug.c (modified) * cpukit/libnetworking/netinet/tcp_input.c (modified) * cpukit/libnetworking/netinet/tcp_output.c (modified) * cpukit/libnetworking/netinet/tcp_subr.c (modified) * cpukit/libnetworking/netinet/tcp_timer.c (modified) * cpukit/libnetworking/netinet/tcp_usrreq.c (modified) * cpukit/libnetworking/netinet/udp_usrreq.c (modified) * cpukit/libnetworking/nfs/bootp_subr.c (modified) * cpukit/libnetworking/rtems/mkrootfs.c (modified) * cpukit/libnetworking/rtems/rtems_bootp.c (modified) * cpukit/libnetworking/rtems/rtems_bsdnet.h (modified) * cpukit/libnetworking/rtems/rtems_bsdnet_malloc_starvation.c (modified) * cpukit/libnetworking/rtems/rtems_dhcp.c (modified) * cpukit/libnetworking/rtems/rtems_dhcp_failsafe.c (modified) * cpukit/libnetworking/rtems/rtems_glue.c (modified) * cpukit/libnetworking/rtems/rtems_malloc_mbuf.c (modified) * cpukit/libnetworking/rtems/rtems_mii_ioctl.c (modified) * cpukit/libnetworking/rtems/rtems_mii_ioctl_kern.c (modified) * cpukit/libnetworking/rtems/rtems_select.c (modified) * cpukit/libnetworking/rtems/rtems_showicmpstat.c (modified) * cpukit/libnetworking/rtems/rtems_showifstat.c (modified) * cpukit/libnetworking/rtems/rtems_showipstat.c (modified) * cpukit/libnetworking/rtems/rtems_showmbuf.c (modified) * cpukit/libnetworking/rtems/rtems_showroute.c (modified) * cpukit/libnetworking/rtems/rtems_showtcpstat.c (modified) * cpukit/libnetworking/rtems/rtems_showudpstat.c (modified) * cpukit/libnetworking/rtems/rtems_socketpair.c (modified) * cpukit/libnetworking/rtems/rtems_syscall.c (modified) * cpukit/libnetworking/rtems/rtems_syscall_api.c (modified) * cpukit/libnetworking/rtems/sghostname.c (modified) * cpukit/wrapup/Makefile.am (modified) network: Use kernel/user space header files Add and use ... Wed, 20 Jun 2018 07:23:31 GMT Daniel Hellstrom [408fad3] * bsps/sparc/shared/spw/grspw_pkt.c (modified) leon,grspw_pkt: remove incorrect comment on SMP not being tested To ... Fri, 15 Jun 2018 06:49:31 GMT Daniel Hellstrom [aea3134e] * bsps/sparc/shared/uart/apbuart_cons.c (modified) leon,apbuart: replace termios c_cflag & CBAUD with c_{i,o}speed ... Fri, 15 Jun 2018 12:28:36 GMT Daniel Hellstrom [243ddb52] * bsps/sparc/include/bsp/greth.h (modified) * bsps/sparc/shared/net/greth.c (modified) leon,greth: enable MAC filtering (promiscous mode, multicast) It ... Tue, 13 Feb 2018 06:47:14 GMT Daniel Hellstrom [2fbe2ef3] * bsps/sparc/shared/net/greth.c (modified) leon, greth: 10/100 MAC enable TX BD interrupt Missed to enable ... Thu, 23 Aug 2018 09:13:44 GMT Daniel Hellstrom [a87964d] * bsps/sparc/shared/start/start.S (modified) sparc,smp: typo in start.S causing SMP not working Thu, 09 Aug 2018 07:20:33 GMT Sebastian Huber [f4424cfb] * bsps/sparc/include/bsp/apbuart.h (modified) * bsps/sparc/include/bsp/apbuart_termios.h (modified) * bsps/sparc/leon3/console/printk_support.c (modified) * bsps/sparc/shared/uart/apbuart_cons.c (modified) * bsps/sparc/shared/uart/apbuart_polled.c (added) * bsps/sparc/shared/uart/apbuart_termios.c (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) bsps/sparc: Move polled APBUART functions This reduces the ... Wed, 01 Aug 2018 05:41:49 GMT Sebastian Huber [71284ce] * bsps/sparc/shared/start/start.S (modified) bsps/sparc: Fix typo in start.S Fix typo in start.S introduced by ... Tue, 24 Jul 2018 08:50:39 GMT Sebastian Huber [4678d1a] * bsps/include/bsp/bootcard.h (modified) * bsps/powerpc/qoriq/include/bsp.h (modified) * bsps/powerpc/qoriq/start/bspsmp.c (modified) * bsps/powerpc/qoriq/start/start.S (modified) * bsps/sparc/leon3/start/bspsmp.c (modified) * bsps/sparc/shared/start/start.S (modified) * testsuites/smptests/smpfatal08/init.c (modified) bsps: bsp_start_on_secondary_processor() Pass current processor ... Tue, 19 Jun 2018 07:09:51 GMT Sebastian Huber [511dc4b] * bsps/arm/altera-cyclone-v/config/altcycv_devkit_smp.cfg (deleted) * bsps/arm/altera-cyclone-v/start/linkcmds.altcycv_devkit_smp (deleted) * bsps/arm/csb336/start/start.S (modified) * bsps/arm/csb337/start/start.S (modified) * bsps/arm/edb7312/start/start.S (modified) * bsps/arm/gumstix/start/start.S (modified) * bsps/arm/imx/start/linkcmds.imx7 (modified) * bsps/arm/include/bsp/linker-symbols.h (modified) * bsps/arm/raspberrypi/start/bspsmp.c (modified) * bsps/arm/raspberrypi/start/linkcmds (moved) * bsps/arm/realview-pbx-a9/config/realview_pbx_a9_qemu_smp.cfg (deleted) * bsps/arm/realview-pbx-a9/start/linkcmds.realview_pbx_a9_qemu_smp (deleted) * bsps/arm/rtl22xx/start/start.S (modified) * bsps/arm/shared/start/arm-a9mpcore-smp.c (modified) * bsps/arm/shared/start/linkcmds.base (modified) * bsps/arm/shared/start/start.S (modified) * bsps/arm/smdk2410/start/start.S (modified) * bsps/arm/xilinx-zynq/start/linkcmds.in (modified) * bsps/bfin/TLL6527M/start/linkcmds (modified) * bsps/bfin/bf537Stamp/start/linkcmds (modified) * bsps/bfin/eZKit533/start/linkcmds (modified) * bsps/lm32/lm32_evr/start/linkcmds (modified) * bsps/lm32/milkymist/start/linkcmds (modified) * bsps/lm32/shared/start/start.S (modified) * bsps/m32c/m32cbsp/start/linkcmds (modified) * bsps/m32c/m32cbsp/start/start.S (modified) * bsps/m68k/gen68340/start/linkcmds (modified) * bsps/m68k/gen68340/start/start.S (modified) * bsps/m68k/gen68360/start/linkcmds (modified) * bsps/m68k/gen68360/start/linkcmds.bootp (modified) * bsps/m68k/gen68360/start/linkcmds.prom (modified) * bsps/m68k/gen68360/start/start.S (modified) * bsps/m68k/genmcf548x/start/linkcmds.COBRA5475 (modified) * bsps/m68k/genmcf548x/start/linkcmds.m5484FireEngine (modified) * bsps/m68k/genmcf548x/start/linkcmds.m5484FireEngine.flash (modified) * bsps/m68k/genmcf548x/start/start.S (modified) * bsps/m68k/mcf52235/start/linkcmds (modified) * bsps/m68k/mcf52235/start/start.S (modified) * bsps/m68k/mcf5225x/start/linkcmds (modified) * bsps/m68k/mcf5225x/start/start.S (modified) * bsps/m68k/mcf5329/start/linkcmds (modified) * bsps/m68k/mcf5329/start/linkcmdsflash (modified) * bsps/m68k/mcf5329/start/start.S (modified) * bsps/m68k/mrm332/start/linkcmds (modified) * bsps/m68k/mrm332/start/start.S (modified) * bsps/m68k/shared/start/linkcmds.base (modified) * bsps/m68k/shared/start/start.S (modified) * bsps/mips/csb350/start/linkcmds (modified) * bsps/mips/csb350/start/start.S (modified) * bsps/mips/hurricane/start/linkcmds (modified) * bsps/mips/jmr3904/start/linkcmds (modified) * bsps/mips/jmr3904/start/start.S (modified) * bsps/mips/malta/start/linkcmds (modified) * bsps/mips/malta/start/start.S (modified) * bsps/mips/rbtx4925/start/linkcmds (modified) * bsps/mips/rbtx4938/start/linkcmds (modified) * bsps/mips/shared/irq/exception.S (modified) * bsps/nios2/nios2_iss/start/linkcmds (modified) * bsps/powerpc/beatnik/start/bspstart.c (modified) * bsps/powerpc/gen5200/include/bsp.h (modified) * bsps/powerpc/gen5200/start/bspstart.c (modified) * bsps/powerpc/gen5200/start/linkcmds.gen5200_base (modified) * bsps/powerpc/gen83xx/include/bsp.h (modified) * bsps/powerpc/gen83xx/start/start.S (modified) * bsps/powerpc/haleakala/start/bspstart.c (modified) * bsps/powerpc/haleakala/start/dlentry.S (modified) * bsps/powerpc/haleakala/start/linkcmds (modified) * bsps/powerpc/motorola_powerpc/start/bspstart.c (modified) * bsps/powerpc/mpc55xxevb/start/start.S (modified) * bsps/powerpc/mpc8260ads/start/bspstart.c (modified) * bsps/powerpc/mpc8260ads/start/linkcmds (modified) * bsps/powerpc/mvme3100/start/bspstart.c (modified) * bsps/powerpc/mvme5500/start/bspstart.c (modified) * bsps/powerpc/psim/start/start.S (modified) * bsps/powerpc/qemuppc/start/bspstart.c (modified) * bsps/powerpc/qemuppc/start/start.S (modified) * bsps/powerpc/qoriq/start/start.S (modified) * bsps/powerpc/shared/start/linkcmds.base (modified) * bsps/powerpc/ss555/start/bspstart.c (modified) * bsps/powerpc/ss555/start/linkcmds (modified) * bsps/powerpc/ss555/start/start.S (modified) * bsps/powerpc/t32mppc/start/start.S (modified) * bsps/powerpc/tqm8xx/include/bsp.h (modified) * bsps/powerpc/tqm8xx/start/bspstart.c (modified) * bsps/powerpc/tqm8xx/start/start.S (modified) * bsps/powerpc/virtex4/start/bspstart.c (modified) * bsps/powerpc/virtex4/start/linkcmds (modified) * bsps/powerpc/virtex4/start/start.S (modified) * bsps/powerpc/virtex5/start/bspstart.c (modified) * bsps/powerpc/virtex5/start/linkcmds (modified) * bsps/powerpc/virtex5/start/start.S (modified) * bsps/riscv/riscv_generic/start/start.S (modified) * bsps/sh/gensh1/include/bsp.h (modified) * bsps/sh/gensh1/start/cpu_asm.c (modified) * bsps/sh/gensh1/start/linkcmds (modified) * bsps/sh/gensh1/start/start.S (modified) * bsps/sh/gensh2/include/bsp.h (modified) * bsps/sh/gensh2/start/cpu_asm.c (modified) * bsps/sh/gensh2/start/linkcmds (modified) * bsps/sh/gensh2/start/linkcmds.ram (modified) * bsps/sh/gensh2/start/linkcmds.rom (modified) * bsps/sh/gensh2/start/start.S (modified) * bsps/sh/gensh2/start/start.ram (modified) * bsps/sh/gensh2/start/start.rom (modified) * bsps/sh/gensh4/include/bsp.h (modified) * bsps/sh/gensh4/start/cpu_asm.c (modified) * bsps/sh/gensh4/start/linkcmds (modified) * bsps/sh/gensh4/start/linkcmds.rom (modified) * bsps/sh/gensh4/start/linkcmds.rom2ram (modified) * bsps/sh/gensh4/start/start.S (modified) * bsps/sh/shared/start/bspstart.c (modified) * bsps/sh/shsim/include/bsp.h (modified) * bsps/sh/shsim/start/cpu_asm.c (modified) * bsps/sh/shsim/start/linkcmds (modified) * bsps/sh/shsim/start/start.S (modified) * bsps/sparc/shared/start/bspgetworkarea.c (modified) * bsps/sparc/shared/start/start.S (modified) * bsps/v850/gdbv850sim/start/linkcmds (modified) * bsps/v850/gdbv850sim/start/start.S (modified) * c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am (modified) * c/src/lib/libbsp/arm/raspberrypi/configure.ac (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am (modified) * c/src/lib/libbsp/arm/xilinx-zynq/configure.ac (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/config.h (modified) * cpukit/include/rtems/score/percpu.h (modified) * cpukit/libmisc/stackchk/check.c (modified) * cpukit/score/cpu/arm/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/bfin/cpu.c (modified) * cpukit/score/cpu/bfin/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/epiphany/cpu.c (modified) * cpukit/score/cpu/epiphany/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/i386/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/lm32/cpu.c (modified) * cpukit/score/cpu/lm32/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/lm32/irq.c (modified) * cpukit/score/cpu/m32c/cpu.c (modified) * cpukit/score/cpu/m32c/cpu_asm.c (modified) * cpukit/score/cpu/m32c/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/m68k/cpu.c (modified) * cpukit/score/cpu/m68k/cpu_asm.S (modified) * cpukit/score/cpu/m68k/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/mips/cpu.c (modified) * cpukit/score/cpu/mips/cpu_asm.S (modified) * cpukit/score/cpu/mips/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/moxie/cpu.c (modified) * cpukit/score/cpu/moxie/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/nios2/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/nios2/nios2-iic-irq.c (modified) * cpukit/score/cpu/no_cpu/cpu.c (modified) * cpukit/score/cpu/no_cpu/cpu_asm.c (modified) * cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/or1k/cpu.c (modified) * cpukit/score/cpu/or1k/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/riscv/cpu.c (modified) * cpukit/score/cpu/riscv/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/sh/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc64/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/v850/cpu_asm.S (modified) * cpukit/score/cpu/v850/include/rtems/score/cpu.h (modified) * cpukit/score/src/isr.c (modified) * cpukit/score/src/percpuasm.c (modified) * testsuites/sptests/spfatal07/testcase.h (modified) * testsuites/sptests/spsize/size.c (modified) Rework initialization and interrupt stack support Statically ... Tue, 19 Jun 2018 13:10:36 GMT Sebastian Huber [715d616] * bsps/arm/shared/start/linkcmds.base (modified) * bsps/bfin/TLL6527M/start/linkcmds (modified) * bsps/bfin/bf537Stamp/start/linkcmds (modified) * bsps/bfin/eZKit533/start/linkcmds (modified) * bsps/epiphany/epiphany_sim/start/linkcmds (modified) * bsps/i386/pc386/start/linkcmds (modified) * bsps/lm32/lm32_evr/start/linkcmds (modified) * bsps/lm32/milkymist/start/linkcmds (modified) * bsps/m32c/m32cbsp/start/linkcmds (modified) * bsps/m68k/av5282/start/linkcmds (modified) * bsps/m68k/av5282/start/linkcmdsflash (modified) * bsps/m68k/av5282/start/linkcmdsram (modified) * bsps/m68k/csb360/start/linkcmds (modified) * bsps/m68k/gen68340/start/linkcmds (modified) * bsps/m68k/gen68360/start/linkcmds (modified) * bsps/m68k/gen68360/start/linkcmds.bootp (modified) * bsps/m68k/gen68360/start/linkcmds.prom (modified) * bsps/m68k/mcf5206elite/start/linkcmds (modified) * bsps/m68k/mcf5206elite/start/linkcmds.flash (modified) * bsps/m68k/mcf52235/start/linkcmds (modified) * bsps/m68k/mcf5225x/start/linkcmds (modified) * bsps/m68k/mcf5235/start/linkcmds (modified) * bsps/m68k/mcf5235/start/linkcmdsflash (modified) * bsps/m68k/mcf5235/start/linkcmdsram (modified) * bsps/m68k/mcf5329/start/linkcmds (modified) * bsps/m68k/mcf5329/start/linkcmdsflash (modified) * bsps/m68k/mrm332/start/linkcmds (modified) * bsps/m68k/shared/start/linkcmds.base (modified) * bsps/m68k/uC5282/start/linkcmds (modified) * bsps/mips/csb350/start/linkcmds (modified) * bsps/mips/hurricane/start/linkcmds (modified) * bsps/mips/jmr3904/start/linkcmds (modified) * bsps/mips/malta/start/linkcmds (modified) * bsps/mips/rbtx4925/start/linkcmds (modified) * bsps/mips/rbtx4938/start/linkcmds (modified) * bsps/moxie/moxiesim/start/linkcmds (modified) * bsps/nios2/nios2_iss/start/linkcmds (modified) * bsps/or1k/shared/start/linkcmds.base (modified) * bsps/powerpc/gen5200/start/linkcmds.gen5200_base (modified) * bsps/powerpc/gen83xx/start/linkcmds.mpc83xx (modified) * bsps/powerpc/haleakala/start/linkcmds (modified) * bsps/powerpc/include/bsp/linker-symbols.h (modified) * bsps/powerpc/mpc55xxevb/start/linkcmds.gwlcfm (modified) * bsps/powerpc/mpc55xxevb/start/linkcmds.mpc5566evb (modified) * bsps/powerpc/mpc55xxevb/start/linkcmds.mpc5643l_evb (modified) * bsps/powerpc/mpc55xxevb/start/linkcmds.mpc5668g (modified) * bsps/powerpc/mpc55xxevb/start/linkcmds.mpc5674f_ecu508 (modified) * bsps/powerpc/mpc55xxevb/start/linkcmds.mpc5674f_rsm6_base (modified) * bsps/powerpc/mpc55xxevb/start/linkcmds.mpc5674fevb (modified) * bsps/powerpc/mpc55xxevb/start/linkcmds.phycore_mpc5554 (modified) * bsps/powerpc/mpc8260ads/start/linkcmds (modified) * bsps/powerpc/psim/start/linkcmds (modified) * bsps/powerpc/qemuppc/start/linkcmds (modified) * bsps/powerpc/qoriq/start/linkcmds.qoriq_core_0 (modified) * bsps/powerpc/qoriq/start/linkcmds.qoriq_core_1 (modified) * bsps/powerpc/qoriq/start/linkcmds.qoriq_e500 (modified) * bsps/powerpc/qoriq/start/linkcmds.qoriq_e6500_32 (modified) * bsps/powerpc/qoriq/start/mmu-config.c (modified) * bsps/powerpc/shared/start/linkcmds.base (modified) * bsps/powerpc/shared/start/linkcmds.share (modified) * bsps/powerpc/ss555/start/linkcmds (modified) * bsps/powerpc/t32mppc/start/linkcmds.t32mppc (modified) * bsps/powerpc/tqm8xx/start/linkcmds (modified) * bsps/powerpc/virtex/start/linkcmds.in (modified) * bsps/powerpc/virtex4/start/linkcmds (modified) * bsps/powerpc/virtex5/start/linkcmds (modified) * bsps/riscv/riscv_generic/start/linkcmds (modified) * bsps/sh/gensh1/start/linkcmds (modified) * bsps/sh/gensh2/start/linkcmds (modified) * bsps/sh/gensh2/start/linkcmds.ram (modified) * bsps/sh/gensh2/start/linkcmds.rom (modified) * bsps/sh/gensh4/start/linkcmds (modified) * bsps/sh/gensh4/start/linkcmds.rom (modified) * bsps/sh/gensh4/start/linkcmds.rom2ram (modified) * bsps/sh/shsim/start/linkcmds (modified) * bsps/sparc/shared/start/linkcmds.base (modified) * bsps/sparc64/shared/start/linkcmds (modified) * bsps/v850/gdbv850sim/start/linkcmds (modified) bsps: Support .rtemsstack.* linker input sections Use a dedicated ... Fri, 01 Jun 2018 05:11:12 GMT Sebastian Huber [7ee59313] * bsps/arm/beagle/clock/clock.c (modified) * bsps/arm/csb336/clock/clockdrv.c (modified) * bsps/arm/csb337/clock/clock.c (modified) * bsps/arm/edb7312/clock/clockdrv.c (modified) * bsps/arm/gumstix/clock/clock.c (modified) * bsps/arm/raspberrypi/clock/clockdrv.c (modified) * bsps/arm/rtl22xx/clock/clockdrv.c (modified) * bsps/arm/shared/clock/clock-a9mpcore.c (modified) * bsps/arm/shared/clock/clock-armv7m.c (modified) * bsps/arm/shared/clock/clock-nxp-lpc.c (modified) * bsps/arm/smdk2410/clock/clockdrv.c (modified) * bsps/arm/tms570/clock/clock.c (modified) * bsps/i386/pc386/clock/ckinit.c (modified) * bsps/lm32/shared/clock/ckinit.c (modified) * bsps/lm32/shared/milkymist_clock/ckinit.c (modified) * bsps/m68k/av5282/clock/clock.c (modified) * bsps/m68k/gen68360/clock/clock.c (modified) * bsps/m68k/genmcf548x/clock/clock.c (modified) * bsps/m68k/mcf52235/clock/clock.c (modified) * bsps/m68k/mcf5225x/clock/clock.c (modified) * bsps/m68k/mcf5235/clock/clock.c (modified) * bsps/m68k/mcf5329/clock/clock.c (modified) * bsps/m68k/uC5282/clock/clock.c (modified) * bsps/mips/csb350/clock/clockdrv.c (modified) * bsps/mips/jmr3904/clock/clockdrv.c (modified) * bsps/mips/rbtx4925/clock/clockdrv.c (modified) * bsps/mips/rbtx4938/clock/clockdrv.c (modified) * bsps/mips/shared/clock/clockdrv.c (modified) * bsps/nios2/nios2_iss/clock/clock.c (modified) * bsps/or1k/generic_or1k/clock/clockdrv.c (modified) * bsps/powerpc/mpc55xxevb/clock/clock-config.c (modified) * bsps/powerpc/qoriq/clock/clock-config.c (modified) * bsps/riscv/riscv_generic/clock/clockdrv.c (modified) * bsps/shared/dev/clock/clock-simidle.c (modified) * bsps/shared/dev/clock/clockimpl.h (modified) * bsps/sparc/erc32/clock/ckinit.c (modified) * bsps/sparc/leon2/clock/ckinit.c (modified) * bsps/sparc/leon3/clock/ckinit.c (modified) * bsps/sparc/shared/btimer/tlib_ckinit.c (modified) * bsps/sparc64/shared/clock/ckinit.c (modified) Remove Clock_driver_support_shutdown_hardware() The aim of this ... Fri, 20 Apr 2018 11:33:24 GMT Sebastian Huber [d60d303c] * bsps/sparc/shared/1553/b1553brm.c (moved) * bsps/sparc/shared/1553/b1553rt.c (moved) * bsps/sparc/shared/1553/gr1553b.c (moved) * bsps/sparc/shared/1553/gr1553bc.c (moved) * bsps/sparc/shared/1553/gr1553bm.c (moved) * bsps/sparc/shared/1553/gr1553rt.c (moved) * bsps/sparc/shared/amba/ahbstat.c (moved) * bsps/sparc/shared/amba/ambapp.c (moved) * bsps/sparc/shared/amba/ambapp_alloc.c (moved) * bsps/sparc/shared/amba/ambapp_count.c (moved) * bsps/sparc/shared/amba/ambapp_depth.c (moved) * bsps/sparc/shared/amba/ambapp_find_by_idx.c (moved) * bsps/sparc/shared/amba/ambapp_freq.c (moved) * bsps/sparc/shared/amba/ambapp_names.c (moved) * bsps/sparc/shared/amba/ambapp_old.c (moved) * bsps/sparc/shared/amba/ambapp_parent.c (moved) * bsps/sparc/shared/amba/ambapp_show.c (moved) * bsps/sparc/shared/analog/gradcdac.c (moved) * bsps/sparc/shared/ascs/grascs.c (moved) * bsps/sparc/shared/can/canmux.c (moved) * bsps/sparc/shared/can/grcan.c (moved) * bsps/sparc/shared/can/occan.c (moved) * bsps/sparc/shared/can/satcan.c (moved) * bsps/sparc/shared/drvmgr/ambapp_bus.c (moved) * bsps/sparc/shared/drvmgr/ambapp_bus_grlib.c (moved) * bsps/sparc/shared/drvmgr/ambapp_bus_leon2.c (moved) * bsps/sparc/shared/drvmgr/get_resarray_count.c (moved) * bsps/sparc/shared/drvmgr/leon2_amba_bus.c (moved) * bsps/sparc/shared/gnatcommon.c (moved) * bsps/sparc/shared/gpio/gpiolib.c (moved) * bsps/sparc/shared/gpio/grgpio.c (moved) * bsps/sparc/shared/i2c/i2cmst.c (moved) * bsps/sparc/shared/iommu/griommu.c (moved) * bsps/sparc/shared/irq/bsp_isr_handler.c (moved) * bsps/sparc/shared/irq/genirq.c (moved) * bsps/sparc/shared/irq/irq-shared.c (moved) * bsps/sparc/shared/l2c/l2c.c (moved) * bsps/sparc/shared/mem/mctrl.c (moved) * bsps/sparc/shared/net/README (moved) * bsps/sparc/shared/net/greth.c (moved) * bsps/sparc/shared/net/network_interface_add.c (moved) * bsps/sparc/shared/pci/gr_701.c (moved) * bsps/sparc/shared/pci/gr_cpci_gr740.c (moved) * bsps/sparc/shared/pci/gr_leon4_n2x.c (moved) * bsps/sparc/shared/pci/gr_rasta_adcdac.c (moved) * bsps/sparc/shared/pci/gr_rasta_io.c (moved) * bsps/sparc/shared/pci/gr_rasta_spw_router.c (moved) * bsps/sparc/shared/pci/gr_rasta_tmtc.c (moved) * bsps/sparc/shared/pci/gr_tmtc_1553.c (moved) * bsps/sparc/shared/pci/grpci.c (moved) * bsps/sparc/shared/pci/grpci2.c (moved) * bsps/sparc/shared/pci/grpci2dma.c (moved) * bsps/sparc/shared/pci/pci_memreg_sparc_be.c (moved) * bsps/sparc/shared/pci/pci_memreg_sparc_le.c (moved) * bsps/sparc/shared/pci/pcif.c (moved) * bsps/sparc/shared/pwm/grpwm.c (moved) * bsps/sparc/shared/scrub/memscrub.c (moved) * bsps/sparc/shared/slink/grslink.c (moved) * bsps/sparc/shared/spi/spictrl.c (moved) * bsps/sparc/shared/spw/grspw.c (moved) * bsps/sparc/shared/spw/grspw_pkt.c (moved) * bsps/sparc/shared/spw/grspw_router.c (moved) * bsps/sparc/shared/stat/l4stat.c (moved) * bsps/sparc/shared/time/grctm.c (moved) * bsps/sparc/shared/time/spwcuc.c (moved) * bsps/sparc/shared/tmtc/grtc.c (moved) * bsps/sparc/shared/tmtc/grtm.c (moved) * bsps/sparc/shared/uart/apbuart_cons.c (moved) * bsps/sparc/shared/uart/apbuart_termios.c (moved) * bsps/sparc/shared/uart/cons.c (moved) * c/src/lib/libbsp/sparc/configure.ac (modified) * c/src/lib/libbsp/sparc/erc32/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) bsps/sparc: Move shared files to bsps This patch is a part of the ... Fri, 20 Apr 2018 10:08:42 GMT Sebastian Huber [e0dd8a5a] * bsps/arm/csb336/btimer/btimer.c (moved) * bsps/arm/csb337/btimer/btimer.c (moved) * bsps/arm/edb7312/btimer/btimer.c (moved) * bsps/arm/gumstix/btimer/btimer.c (moved) * bsps/arm/lpc176x/btimer/btimer.c (moved) * bsps/arm/rtl22xx/btimer/btimer.c (moved) * bsps/arm/rtl22xx/btimer/lpc_timer.h (moved) * bsps/arm/smdk2410/btimer/btimer.c (moved) * bsps/epiphany/epiphany_sim/btimer/btimer.c (moved) * bsps/i386/pc386/btimer/btimer.c (moved) * bsps/i386/pc386/btimer/timerisr.S (moved) * bsps/lm32/shared/btimer/btimer.c (moved) * bsps/m32c/m32cbsp/btimer/btimer.c (moved) * bsps/m68k/av5282/btimer/btimer.c (moved) * bsps/m68k/gen68340/btimer/btimer.c (moved) * bsps/m68k/gen68360/btimer/btimer.c (moved) * bsps/m68k/genmcf548x/btimer/btimer.c (moved) * bsps/m68k/mcf52235/btimer/btimer.c (moved) * bsps/m68k/mcf5225x/btimer/btimer.c (moved) * bsps/m68k/mcf5235/btimer/btimer.c (moved) * bsps/m68k/mcf5329/btimer/btimer.c (moved) * bsps/m68k/mrm332/btimer/btimer.c (moved) * bsps/m68k/mvme147/btimer/btimer.c (moved) * bsps/m68k/mvme147/btimer/timerisr.S (moved) * bsps/m68k/mvme162/btimer/btimer.c (moved) * bsps/m68k/mvme162/btimer/timerisr.S (moved) * bsps/m68k/mvme167/btimer/btimer.c (moved) * bsps/m68k/mvme167/btimer/timerisr.S (moved) * bsps/m68k/uC5282/btimer/btimer.c (moved) * bsps/mips/csb350/btimer/btimer.c (moved) * bsps/mips/jmr3904/btimer/btimer.c (moved) * bsps/nios2/nios2_iss/btimer/btimer.c (moved) * bsps/no_cpu/no_bsp/btimer/btimer.c (moved) * bsps/no_cpu/no_bsp/btimer/timerisr.c (moved) * bsps/or1k/generic_or1k/btimer/btimer.c (moved) * bsps/powerpc/qoriq/btimer/btimer.c (moved) * bsps/powerpc/tqm8xx/btimer/btimer.c (moved) * bsps/riscv/riscv_generic/btimer/btimer.c (moved) * bsps/sh/gensh1/btimer/btimer.c (moved) * bsps/sh/gensh2/btimer/btimer.c (moved) * bsps/sh/gensh4/btimer/btimer.c (moved) * bsps/sparc/erc32/btimer/btimer.c (moved) * bsps/sparc/leon2/btimer/btimer.c (moved) * bsps/sparc/leon3/btimer/btimer.c (moved) * bsps/sparc/leon3/btimer/watchdog.c (moved) * bsps/sparc/shared/btimer/gptimer.c (moved) * bsps/sparc/shared/btimer/tlib.c (moved) * bsps/sparc/shared/btimer/tlib_ckinit.c (moved) * c/src/lib/libbsp/arm/csb336/Makefile.am (modified) * c/src/lib/libbsp/arm/csb337/Makefile.am (modified) * c/src/lib/libbsp/arm/edb7312/Makefile.am (modified) * c/src/lib/libbsp/arm/gumstix/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc176x/Makefile.am (modified) * c/src/lib/libbsp/arm/rtl22xx/Makefile.am (modified) * c/src/lib/libbsp/arm/smdk2410/Makefile.am (modified) * c/src/lib/libbsp/epiphany/epiphany_sim/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/lm32/lm32_evr/Makefile.am (modified) * c/src/lib/libbsp/m32c/m32cbsp/Makefile.am (modified) * c/src/lib/libbsp/m68k/av5282/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/Makefile.am (modified) * c/src/lib/libbsp/m68k/genmcf548x/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf52235/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5225x/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5235/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5329/Makefile.am (modified) * c/src/lib/libbsp/m68k/mrm332/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/Makefile.am (modified) * c/src/lib/libbsp/m68k/uC5282/Makefile.am (modified) * c/src/lib/libbsp/mips/csb350/Makefile.am (modified) * c/src/lib/libbsp/mips/jmr3904/Makefile.am (modified) * c/src/lib/libbsp/nios2/nios2_iss/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/Makefile.am (modified) * c/src/lib/libbsp/or1k/generic_or1k/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qoriq/Makefile.am (modified) * c/src/lib/libbsp/powerpc/tqm8xx/Makefile.am (modified) * c/src/lib/libbsp/riscv/riscv_generic/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh4/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) bsps: Move benchmark timer to bsps This patch is a part of the BSP ... Fri, 20 Apr 2018 08:35:35 GMT Sebastian Huber [9964895] * bsps/arm/altera-cyclone-v/start/bsp_specs (moved) * bsps/arm/altera-cyclone-v/start/bspclean.c (moved) * bsps/arm/altera-cyclone-v/start/bspgetworkarea.c (moved) * bsps/arm/altera-cyclone-v/start/bspreset.c (moved) * bsps/arm/altera-cyclone-v/start/bspsmp.c (moved) * bsps/arm/altera-cyclone-v/start/bspstart.c (moved) * bsps/arm/altera-cyclone-v/start/bspstarthooks.c (moved) * bsps/arm/altera-cyclone-v/start/linkcmds.altcycv (moved) * bsps/arm/altera-cyclone-v/start/linkcmds.altcycv_devkit (moved) * bsps/arm/altera-cyclone-v/start/linkcmds.altcycv_devkit_smp (moved) * bsps/arm/altera-cyclone-v/start/mmu-config.c (moved) * bsps/arm/atsam/start/bsp_specs (moved) * bsps/arm/atsam/start/bspstart.c (moved) * bsps/arm/atsam/start/bspstarthooks.c (moved) * bsps/arm/atsam/start/getentropy-trng.c (moved) * bsps/arm/atsam/start/linkcmds (moved) * bsps/arm/atsam/start/linkcmds.intsram (moved) * bsps/arm/atsam/start/linkcmds.memory.in (moved) * bsps/arm/atsam/start/linkcmds.qspiflash (moved) * bsps/arm/atsam/start/linkcmds.sdram (moved) * bsps/arm/atsam/start/pin-config.c (moved) * bsps/arm/atsam/start/pmc-config.c (moved) * bsps/arm/atsam/start/power-clock.c (moved) * bsps/arm/atsam/start/power-rtc.c (moved) * bsps/arm/atsam/start/power.c (moved) * bsps/arm/atsam/start/restart.c (moved) * bsps/arm/atsam/start/sdram-config.c (moved) * bsps/arm/beagle/start/bsp_specs (moved) * bsps/arm/beagle/start/bspreset.c (moved) * bsps/arm/beagle/start/bspstart.c (moved) * bsps/arm/beagle/start/bspstarthooks.c (moved) * bsps/arm/beagle/start/bspstartmmu.c (moved) * bsps/arm/beagle/start/linkcmds.beagle (moved) * bsps/arm/csb336/start/bsp_specs (moved) * bsps/arm/csb336/start/bspstart.c (moved) * bsps/arm/csb336/start/linkcmds (moved) * bsps/arm/csb336/start/memmap.c (moved) * bsps/arm/csb337/start/bsp_specs (moved) * bsps/arm/csb337/start/bspreset.c (moved) * bsps/arm/csb337/start/bspstart.c (moved) * bsps/arm/csb337/start/linkcmds.csb337 (moved) * bsps/arm/csb337/start/linkcmds.csb637 (moved) * bsps/arm/csb337/start/memmap.c (moved) * bsps/arm/csb337/start/pmc.c (moved) * bsps/arm/csb337/start/umonsupp.c (moved) * bsps/arm/edb7312/start/bsp_specs (moved) * bsps/arm/edb7312/start/bspreset.c (moved) * bsps/arm/edb7312/start/bspstart.c (moved) * bsps/arm/edb7312/start/linkcmds (moved) * bsps/arm/gdbarmsim/start/bsp_specs (moved) * bsps/arm/gdbarmsim/start/bspreset.c (moved) * bsps/arm/gdbarmsim/start/bspstart.c (moved) * bsps/arm/gdbarmsim/start/bspstarthooks.c (moved) * bsps/arm/gdbarmsim/start/linkcmds (moved) * bsps/arm/gdbarmsim/start/syscalls.c (moved) * bsps/arm/gumstix/start/bsp_specs (moved) * bsps/arm/gumstix/start/bspreset.c (moved) * bsps/arm/gumstix/start/bspstart.c (moved) * bsps/arm/gumstix/start/linkcmds (moved) * bsps/arm/gumstix/start/memmap.c (moved) * bsps/arm/imx/start/bsp_specs (moved) * bsps/arm/imx/start/bspreset.c (moved) * bsps/arm/imx/start/bspsmp.c (moved) * bsps/arm/imx/start/bspstart.c (moved) * bsps/arm/imx/start/bspstarthooks.c (moved) * bsps/arm/imx/start/ccm.c (moved) * bsps/arm/imx/start/imx_iomux.c (moved) * bsps/arm/imx/start/linkcmds.imx7 (moved) * bsps/arm/lm3s69xx/start/bsp_specs (moved) * bsps/arm/lm3s69xx/start/bspstart.c (moved) * bsps/arm/lm3s69xx/start/bspstarthook.c (moved) * bsps/arm/lm3s69xx/start/io.c (moved) * bsps/arm/lm3s69xx/start/linkcmds.lm3s3749 (moved) * bsps/arm/lm3s69xx/start/linkcmds.lm3s6965 (moved) * bsps/arm/lm3s69xx/start/linkcmds.lm3s6965_qemu (moved) * bsps/arm/lm3s69xx/start/linkcmds.lm4f120 (moved) * bsps/arm/lm3s69xx/start/syscon.c (moved) * bsps/arm/lpc176x/start/bsp_specs (moved) * bsps/arm/lpc176x/start/bspstart.c (moved) * bsps/arm/lpc176x/start/bspstarthooks.c (moved) * bsps/arm/lpc176x/start/linkcmds.lpc1768_mbed (moved) * bsps/arm/lpc176x/start/linkcmds.lpc1768_mbed_ahb_ram (moved) * bsps/arm/lpc176x/start/linkcmds.lpc1768_mbed_ahb_ram_eth (moved) * bsps/arm/lpc24xx/start/bsp_specs (moved) * bsps/arm/lpc24xx/start/bspreset-armv4.c (moved) * bsps/arm/lpc24xx/start/bspstart.c (moved) * bsps/arm/lpc24xx/start/bspstarthooks.c (moved) * bsps/arm/lpc24xx/start/fb-config.c (moved) * bsps/arm/lpc24xx/start/linkcmds.lpc17xx_ea_ram (moved) * bsps/arm/lpc24xx/start/linkcmds.lpc17xx_ea_rom_int (moved) * bsps/arm/lpc24xx/start/linkcmds.lpc17xx_plx800_ram (moved) * bsps/arm/lpc24xx/start/linkcmds.lpc17xx_plx800_rom_int (moved) * bsps/arm/lpc24xx/start/linkcmds.lpc2362 (moved) * bsps/arm/lpc24xx/start/linkcmds.lpc23xx_tli800 (moved) * bsps/arm/lpc24xx/start/linkcmds.lpc24xx_ea (moved) * bsps/arm/lpc24xx/start/linkcmds.lpc24xx_ncs_ram (moved) * bsps/arm/lpc24xx/start/linkcmds.lpc24xx_ncs_rom_ext (moved) * bsps/arm/lpc24xx/start/linkcmds.lpc24xx_ncs_rom_int (moved) * bsps/arm/lpc24xx/start/linkcmds.lpc24xx_plx800_ram (moved) * bsps/arm/lpc24xx/start/linkcmds.lpc24xx_plx800_rom_int (moved) * bsps/arm/lpc24xx/start/linkcmds.lpc40xx_ea_ram (moved) * bsps/arm/lpc24xx/start/linkcmds.lpc40xx_ea_rom_int (moved) * bsps/arm/lpc24xx/start/start-config-emc-dynamic.c (moved) * bsps/arm/lpc24xx/start/start-config-emc-static.c (moved) * bsps/arm/lpc24xx/start/start-config-mpu.c (moved) * bsps/arm/lpc24xx/start/start-config-pinsel.c (moved) * bsps/arm/lpc32xx/start/bsp_specs (moved) * bsps/arm/lpc32xx/start/bspreset.c (moved) * bsps/arm/lpc32xx/start/bspstart.c (moved) * bsps/arm/lpc32xx/start/bspstarthooks.c (moved) * bsps/arm/lpc32xx/start/linkcmds.lpc32xx (moved) * bsps/arm/lpc32xx/start/linkcmds.lpc32xx_mzx (moved) * bsps/arm/lpc32xx/start/linkcmds.lpc32xx_mzx_stage_1 (moved) * bsps/arm/lpc32xx/start/linkcmds.lpc32xx_mzx_stage_2 (moved) * bsps/arm/lpc32xx/start/linkcmds.lpc32xx_phycore (moved) * bsps/arm/raspberrypi/start/bsp_specs (moved) * bsps/arm/raspberrypi/start/bspgetworkarea.c (moved) * bsps/arm/raspberrypi/start/bspreset.c (moved) * bsps/arm/raspberrypi/start/bspsmp.c (moved) * bsps/arm/raspberrypi/start/bspsmp_init.c (moved) * bsps/arm/raspberrypi/start/bspstart.c (moved) * bsps/arm/raspberrypi/start/bspstarthooks.c (moved) * bsps/arm/raspberrypi/start/cmdline.c (moved) * bsps/arm/raspberrypi/start/linkcmds.in (moved) * bsps/arm/raspberrypi/start/mm_config_table.c (moved) * bsps/arm/realview-pbx-a9/start/bsp_specs (moved) * bsps/arm/realview-pbx-a9/start/bspreset.c (moved) * bsps/arm/realview-pbx-a9/start/bspsmp.c (moved) * bsps/arm/realview-pbx-a9/start/bspstart.c (moved) * bsps/arm/realview-pbx-a9/start/bspstarthooks.c (moved) * bsps/arm/realview-pbx-a9/start/fb-config.c (moved) * bsps/arm/realview-pbx-a9/start/linkcmds.realview_pbx_a9_qemu (moved) * bsps/arm/realview-pbx-a9/start/linkcmds.realview_pbx_a9_qemu_smp (moved) * bsps/arm/rtl22xx/start/bsp_specs (moved) * bsps/arm/rtl22xx/start/bspreset.c (moved) * bsps/arm/rtl22xx/start/bspstart.c (moved) * bsps/arm/rtl22xx/start/linkcmds (moved) * bsps/arm/shared/start/bsp-start-in-hyp-support.S (moved) * bsps/arm/shared/start/bsp-start-init-registers.S (moved) * bsps/arm/shared/start/bsp-start-memcpy.S (moved) * bsps/arm/shared/start/linkcmds.armv4 (moved) * bsps/arm/shared/start/linkcmds.armv7m (moved) * bsps/arm/shared/start/linkcmds.base (moved) * bsps/arm/smdk2410/start/bsp_specs (moved) * bsps/arm/smdk2410/start/bspidle.c (moved) * bsps/arm/smdk2410/start/bspreset.c (moved) * bsps/arm/smdk2410/start/bspstart.c (moved) * bsps/arm/smdk2410/start/linkcmds (moved) * bsps/arm/smdk2410/start/memmap.c (moved) * bsps/arm/stm32f4/start/bsp_specs (moved) * bsps/arm/stm32f4/start/bspreset.c (moved) * bsps/arm/stm32f4/start/bspstart.c (moved) * bsps/arm/stm32f4/start/bspstarthook.c (moved) * bsps/arm/stm32f4/start/io.c (moved) * bsps/arm/stm32f4/start/linkcmds.stm32f105rc (moved) * bsps/arm/stm32f4/start/linkcmds.stm32f4 (moved) * bsps/arm/stm32f4/start/rcc.c (moved) * bsps/arm/stm32f4/start/start-config-io.c (moved) * bsps/arm/tms570/start/bsp_specs (moved) * bsps/arm/tms570/start/bspreset.c (moved) * bsps/arm/tms570/start/bspstart.c (moved) * bsps/arm/tms570/start/bspstarthooks.c (moved) * bsps/arm/tms570/start/linkcmds.tms570ls3137_hdk (moved) * bsps/arm/tms570/start/linkcmds.tms570ls3137_hdk_intram (moved) * bsps/arm/tms570/start/linkcmds.tms570ls3137_hdk_sdram (moved) * bsps/arm/tms570/start/linkcmds.tms570ls3137_hdk_with_loader (moved) * bsps/arm/xilinx-zynq/start/bsp_specs (moved) * bsps/arm/xilinx-zynq/start/bspreset.c (moved) * bsps/arm/xilinx-zynq/start/bspsmp.c (moved) * bsps/arm/xilinx-zynq/start/bspstart.c (moved) * bsps/arm/xilinx-zynq/start/bspstarthooks.c (moved) * bsps/arm/xilinx-zynq/start/bspstartmmu.c (moved) * bsps/arm/xilinx-zynq/start/linkcmds.in (moved) * bsps/bfin/TLL6527M/start/bsp_specs (moved) * bsps/bfin/TLL6527M/start/bspstart.c (moved) * bsps/bfin/TLL6527M/start/linkcmds (moved) * bsps/bfin/bf537Stamp/start/bsp_specs (moved) * bsps/bfin/bf537Stamp/start/bspstart.c (moved) * bsps/bfin/bf537Stamp/start/linkcmds (moved) * bsps/bfin/eZKit533/start/bsp_specs (moved) * bsps/bfin/eZKit533/start/bspstart.c (moved) * bsps/bfin/eZKit533/start/linkcmds (moved) * bsps/epiphany/epiphany_sim/start/bsp_specs (moved) * bsps/epiphany/epiphany_sim/start/linkcmds (moved) * bsps/i386/pc386/start/bsp_fatal_halt.c (moved) * bsps/i386/pc386/start/bsp_specs (moved) * bsps/i386/pc386/start/bspcmdline.c (moved) * bsps/i386/pc386/start/bspgetworkarea.c (moved) * bsps/i386/pc386/start/bspidle.S (moved) * bsps/i386/pc386/start/bspreset.c (moved) * bsps/i386/pc386/start/bspstart.c (moved) * bsps/i386/pc386/start/ldsegs.S (moved) * bsps/i386/pc386/start/linkcmds (moved) * bsps/lm32/lm32_evr/start/bsp_specs (moved) * bsps/lm32/lm32_evr/start/linkcmds (moved) * bsps/lm32/milkymist/start/bsp_specs (moved) * bsps/lm32/milkymist/start/bspclean.c (moved) * bsps/lm32/milkymist/start/linkcmds (moved) * bsps/lm32/shared/start/bspreset.c (moved) * bsps/lm32/shared/start/bspstart.c (moved) * bsps/m32c/m32cbsp/start/bsp_specs (moved) * bsps/m32c/m32cbsp/start/bspstart.c (moved) * bsps/m32c/m32cbsp/start/crtn.S (moved) * bsps/m32c/m32cbsp/start/linkcmds (moved) * bsps/m68k/av5282/start/bsp_specs (moved) * bsps/m68k/av5282/start/bspstart.c (moved) * bsps/m68k/av5282/start/init5282.c (moved) * bsps/m68k/av5282/start/linkcmds (moved) * bsps/m68k/av5282/start/linkcmdsflash (moved) * bsps/m68k/av5282/start/linkcmdsram (moved) * bsps/m68k/csb360/start/bsp_specs (moved) * bsps/m68k/csb360/start/init5272.c (moved) * bsps/m68k/csb360/start/linkcmds (moved) * bsps/m68k/gen68340/start/bsp_specs (moved) * bsps/m68k/gen68340/start/dumpanic.c (moved) * bsps/m68k/gen68340/start/init68340.c (moved) * bsps/m68k/gen68340/start/linkcmds (moved) * bsps/m68k/gen68360/start/alloc360.c (moved) * bsps/m68k/gen68360/start/bsp_specs (moved) * bsps/m68k/gen68360/start/init68360.c (moved) * bsps/m68k/gen68360/start/linkcmds (moved) * bsps/m68k/gen68360/start/linkcmds.bootp (moved) * bsps/m68k/gen68360/start/linkcmds.prom (moved) * bsps/m68k/genmcf548x/start/bsp_specs (moved) * bsps/m68k/genmcf548x/start/bspstart.c (moved) * bsps/m68k/genmcf548x/start/init548x.c (moved) * bsps/m68k/genmcf548x/start/linkcmds.COBRA5475 (moved) * bsps/m68k/genmcf548x/start/linkcmds.m5484FireEngine (moved) * bsps/m68k/genmcf548x/start/linkcmds.m5484FireEngine.flash (moved) * bsps/m68k/mcf5206elite/start/bsp_specs (moved) * bsps/m68k/mcf5206elite/start/gdbinit (moved) * bsps/m68k/mcf5206elite/start/init5206e.c (moved) * bsps/m68k/mcf5206elite/start/linkcmds (moved) * bsps/m68k/mcf5206elite/start/linkcmds.flash (moved) * bsps/m68k/mcf52235/start/bsp_specs (moved) * bsps/m68k/mcf52235/start/bspgetcpuclockspeed.c (moved) * bsps/m68k/mcf52235/start/cfinit.c (moved) * bsps/m68k/mcf52235/start/init52235.c (moved) * bsps/m68k/mcf52235/start/linkcmds (moved) * bsps/m68k/mcf5225x/start/bsp_specs (moved) * bsps/m68k/mcf5225x/start/bspclean.c (moved) * bsps/m68k/mcf5225x/start/bspstart.c (moved) * bsps/m68k/mcf5225x/start/init5225x.c (moved) * bsps/m68k/mcf5225x/start/linkcmds (moved) * bsps/m68k/mcf5235/start/bsp_specs (moved) * bsps/m68k/mcf5235/start/bspgetcpuclockspeed.c (moved) * bsps/m68k/mcf5235/start/bspstart.c (moved) * bsps/m68k/mcf5235/start/copyvectors.c (moved) * bsps/m68k/mcf5235/start/init5235.c (moved) * bsps/m68k/mcf5235/start/linkcmds (moved) * bsps/m68k/mcf5235/start/linkcmdsflash (moved) * bsps/m68k/mcf5235/start/linkcmdsram (moved) * bsps/m68k/mcf5329/start/bsp_specs (moved) * bsps/m68k/mcf5329/start/bspstart.c (moved) * bsps/m68k/mcf5329/start/cfinit.c (moved) * bsps/m68k/mcf5329/start/init5329.c (moved) * bsps/m68k/mcf5329/start/linkcmds (moved) * bsps/m68k/mcf5329/start/linkcmdsflash (moved) * bsps/m68k/mrm332/start/bsp_specs (moved) * bsps/m68k/mrm332/start/linkcmds (moved) * bsps/m68k/mrm332/start/start_c.c (moved) * bsps/m68k/mvme147/start/bsp_specs (moved) * bsps/m68k/mvme147/start/bspclean.c (moved) * bsps/m68k/mvme147/start/bspstart.c (moved) * bsps/m68k/mvme147/start/linkcmds (moved) * bsps/m68k/mvme147s/start/bsp_specs (moved) * bsps/m68k/mvme147s/start/bspstart.c (moved) * bsps/m68k/mvme147s/start/linkcmds (moved) * bsps/m68k/mvme162/start/bsp_specs (moved) * bsps/m68k/mvme162/start/bspclean.c (moved) * bsps/m68k/mvme162/start/bspstart.c (moved) * bsps/m68k/mvme162/start/linkcmds (moved) * bsps/m68k/mvme162/start/page_table.c (moved) * bsps/m68k/mvme167/start/bsp_specs (moved) * bsps/m68k/mvme167/start/bspclean.c (moved) * bsps/m68k/mvme167/start/bspstart.c (moved) * bsps/m68k/mvme167/start/linkcmds (moved) * bsps/m68k/mvme167/start/page_table.c (moved) * bsps/m68k/shared/start/linkcmds.base (moved) * bsps/m68k/uC5282/start/bsp_specs (moved) * bsps/m68k/uC5282/start/bspclean.c (moved) * bsps/m68k/uC5282/start/bspreset.c (moved) * bsps/m68k/uC5282/start/bspstart.c (moved) * bsps/m68k/uC5282/start/init5282.c (moved) * bsps/m68k/uC5282/start/linkcmds (moved) * bsps/mips/csb350/start/bsp_specs (moved) * bsps/mips/csb350/start/bspreset.c (moved) * bsps/mips/csb350/start/bspstart.c (moved) * bsps/mips/csb350/start/linkcmds (moved) * bsps/mips/hurricane/start/bsp_specs (moved) * bsps/mips/hurricane/start/bspstart.c (moved) * bsps/mips/hurricane/start/ghlinkcmds (moved) * bsps/mips/hurricane/start/inittlb.c (moved) * bsps/mips/hurricane/start/linkcmds (moved) * bsps/mips/hurricane/start/usc.S (moved) * bsps/mips/jmr3904/start/bsp_specs (moved) * bsps/mips/jmr3904/start/bspstart.c (moved) * bsps/mips/jmr3904/start/linkcmds (moved) * bsps/mips/malta/start/bsp_specs (moved) * bsps/mips/malta/start/bspreset.c (moved) * bsps/mips/malta/start/bspstart.c (moved) * bsps/mips/malta/start/inittlb.c (moved) * bsps/mips/malta/start/linkcmds (moved) * bsps/mips/malta/start/simple_access.c (moved) * bsps/mips/rbtx4925/start/bsp_specs (moved) * bsps/mips/rbtx4925/start/bspstart.c (moved) * bsps/mips/rbtx4925/start/idttlb.S (moved) * bsps/mips/rbtx4925/start/inittlb.c (moved) * bsps/mips/rbtx4925/start/linkcmds (moved) * bsps/mips/rbtx4938/start/bsp_specs (moved) * bsps/mips/rbtx4938/start/bspstart.c (moved) * bsps/mips/rbtx4938/start/inittlb.c (moved) * bsps/mips/rbtx4938/start/linkcmds (moved) * bsps/mips/shared/start/idtmem.S (moved) * bsps/mips/shared/start/idttlb.S (moved) * bsps/moxie/moxiesim/start/bsp_specs (moved) * bsps/moxie/moxiesim/start/linkcmds (moved) * bsps/nios2/nios2_iss/start/bsp_specs (moved) * bsps/nios2/nios2_iss/start/bspstart.c (moved) * bsps/nios2/nios2_iss/start/linkcmds (moved) * bsps/nios2/nios2_iss/start/main.c (moved) * bsps/nios2/nios2_iss/start/setvec.c (moved) * bsps/no_cpu/no_bsp/start/bsp_specs (moved) * bsps/no_cpu/no_bsp/start/bspstart.c (moved) * bsps/no_cpu/no_bsp/start/linkcmds (moved) * bsps/no_cpu/no_bsp/start/setvec.c (moved) * bsps/or1k/generic_or1k/start/bsp_specs (moved) * bsps/or1k/generic_or1k/start/bspstart.c (moved) * bsps/or1k/generic_or1k/start/linkcmds (moved) * bsps/or1k/shared/start/linkcmds.base (moved) * bsps/powerpc/beatnik/start/bsp_specs (moved) * bsps/powerpc/beatnik/start/bspclean.c (moved) * bsps/powerpc/beatnik/start/bspreset.c (moved) * bsps/powerpc/beatnik/start/bspstart.c (moved) * bsps/powerpc/beatnik/start/i2c_init.c (moved) * bsps/powerpc/beatnik/start/linkcmds (moved) * bsps/powerpc/gen5200/start/bestcomm.c (moved) * bsps/powerpc/gen5200/start/bsp_specs (moved) * bsps/powerpc/gen5200/start/bspreset.c (moved) * bsps/powerpc/gen5200/start/bspstart.c (moved) * bsps/powerpc/gen5200/start/cpuinit.c (moved) * bsps/powerpc/gen5200/start/linkcmds.brs5l (moved) * bsps/powerpc/gen5200/start/linkcmds.brs6l (moved) * bsps/powerpc/gen5200/start/linkcmds.dp2 (moved) * bsps/powerpc/gen5200/start/linkcmds.gen5200_base (moved) * bsps/powerpc/gen5200/start/linkcmds.icecube (moved) * bsps/powerpc/gen5200/start/linkcmds.pm520_cr825 (moved) * bsps/powerpc/gen5200/start/linkcmds.pm520_ze30 (moved) * bsps/powerpc/gen5200/start/uboot_support.c (moved) * bsps/powerpc/gen83xx/start/bsp_specs (moved) * bsps/powerpc/gen83xx/start/bspreset.c (moved) * bsps/powerpc/gen83xx/start/bsprestart.c (moved) * bsps/powerpc/gen83xx/start/bspstart.c (moved) * bsps/powerpc/gen83xx/start/cpuinit.c (moved) * bsps/powerpc/gen83xx/start/linkcmds (moved) * bsps/powerpc/gen83xx/start/linkcmds.br_uid (moved) * bsps/powerpc/gen83xx/start/linkcmds.hsc_cm01 (moved) * bsps/powerpc/gen83xx/start/linkcmds.mpc8309som (moved) * bsps/powerpc/gen83xx/start/linkcmds.mpc8313erdb (moved) * bsps/powerpc/gen83xx/start/linkcmds.mpc8349eamds (moved) * bsps/powerpc/gen83xx/start/linkcmds.mpc83xx (moved) * bsps/powerpc/gen83xx/start/uboot_support.c (moved) * bsps/powerpc/haleakala/start/bsp_specs (moved) * bsps/powerpc/haleakala/start/bspstart.c (moved) * bsps/powerpc/haleakala/start/linkcmds (moved) * bsps/powerpc/motorola_powerpc/start/bsp_specs (moved) * bsps/powerpc/motorola_powerpc/start/bspreset.c (moved) * bsps/powerpc/motorola_powerpc/start/linkcmds (moved) * bsps/powerpc/mpc55xxevb/start/bsp_specs (moved) * bsps/powerpc/mpc55xxevb/start/bspgetworkarea.c (moved) * bsps/powerpc/mpc55xxevb/start/bspreset.c (moved) * bsps/powerpc/mpc55xxevb/start/bspstart.c (moved) * bsps/powerpc/mpc55xxevb/start/exc-vector-base.S (moved) * bsps/powerpc/mpc55xxevb/start/get-system-clock.c (moved) * bsps/powerpc/mpc55xxevb/start/idle-thread.c (moved) * bsps/powerpc/mpc55xxevb/start/linkcmds (moved) * bsps/powerpc/mpc55xxevb/start/linkcmds.gwlcfm (moved) * bsps/powerpc/mpc55xxevb/start/linkcmds.mpc5566evb (moved) * bsps/powerpc/mpc55xxevb/start/linkcmds.mpc5566evb_spe (moved) * bsps/powerpc/mpc55xxevb/start/linkcmds.mpc55xx (moved) * bsps/powerpc/mpc55xxevb/start/linkcmds.mpc5643l_dpu (moved) * bsps/powerpc/mpc55xxevb/start/linkcmds.mpc5643l_evb (moved) * bsps/powerpc/mpc55xxevb/start/linkcmds.mpc5668g (moved) * bsps/powerpc/mpc55xxevb/start/linkcmds.mpc5674f_ecu508 (moved) * bsps/powerpc/mpc55xxevb/start/linkcmds.mpc5674f_ecu508_app (moved) * bsps/powerpc/mpc55xxevb/start/linkcmds.mpc5674f_ecu508_boot (moved) * bsps/powerpc/mpc55xxevb/start/linkcmds.mpc5674f_rsm6 (moved) * bsps/powerpc/mpc55xxevb/start/linkcmds.mpc5674f_rsm6_base (moved) * bsps/powerpc/mpc55xxevb/start/linkcmds.mpc5674fevb (moved) * bsps/powerpc/mpc55xxevb/start/linkcmds.mpc5674fevb_spe (moved) * bsps/powerpc/mpc55xxevb/start/linkcmds.phycore_mpc5554 (moved) * bsps/powerpc/mpc55xxevb/start/restart.c (moved) * bsps/powerpc/mpc55xxevb/start/sd-card-init.c (moved) * bsps/powerpc/mpc55xxevb/start/start-cache.S (moved) * bsps/powerpc/mpc55xxevb/start/start-clock.c (moved) * bsps/powerpc/mpc55xxevb/start/start-config-clock.c (moved) * bsps/powerpc/mpc55xxevb/start/start-config-ebi-cs-cal.c (moved) * bsps/powerpc/mpc55xxevb/start/start-config-ebi-cs.c (moved) * bsps/powerpc/mpc55xxevb/start/start-config-ebi.c (moved) * bsps/powerpc/mpc55xxevb/start/start-config-mmu-early.c (moved) * bsps/powerpc/mpc55xxevb/start/start-config-mmu.c (moved) * bsps/powerpc/mpc55xxevb/start/start-config-siu-pcr.c (moved) * bsps/powerpc/mpc55xxevb/start/start-early.c (moved) * bsps/powerpc/mpc55xxevb/start/start-flash.S (moved) * bsps/powerpc/mpc55xxevb/start/start-prologue.c (moved) * bsps/powerpc/mpc55xxevb/start/start-watchdog.c (moved) * bsps/powerpc/mpc8260ads/start/bsp_specs (moved) * bsps/powerpc/mpc8260ads/start/bspstart.c (moved) * bsps/powerpc/mpc8260ads/start/cpuinit.c (moved) * bsps/powerpc/mpc8260ads/start/linkcmds (moved) * bsps/powerpc/mvme3100/start/bsp_specs (moved) * bsps/powerpc/mvme3100/start/bspstart.c (moved) * bsps/powerpc/mvme3100/start/linkcmds (moved) * bsps/powerpc/mvme3100/start/misc.c (moved) * bsps/powerpc/mvme5500/start/bootpstuff.c (moved) * bsps/powerpc/mvme5500/start/bsp_specs (moved) * bsps/powerpc/mvme5500/start/bspclean.c (moved) * bsps/powerpc/mvme5500/start/bspreset.c (moved) * bsps/powerpc/mvme5500/start/bspstart.c (moved) * bsps/powerpc/mvme5500/start/linkcmds (moved) * bsps/powerpc/mvme5500/start/pgtbl_activate.c (moved) * bsps/powerpc/psim/start/bsp_specs (moved) * bsps/powerpc/psim/start/bspstart.c (moved) * bsps/powerpc/psim/start/device-tree (moved) * bsps/powerpc/psim/start/linkcmds (moved) * bsps/powerpc/qemuppc/start/bsp_specs (moved) * bsps/powerpc/qemuppc/start/bspstart.c (moved) * bsps/powerpc/qemuppc/start/cmain.c (moved) * bsps/powerpc/qemuppc/start/linkcmds (moved) * bsps/powerpc/qoriq/start/bsp_specs (moved) * bsps/powerpc/qoriq/start/bspreset.c (moved) * bsps/powerpc/qoriq/start/bsprestart.c (moved) * bsps/powerpc/qoriq/start/bspsmp.c (moved) * bsps/powerpc/qoriq/start/bspstart.c (moved) * bsps/powerpc/qoriq/start/epapr_hcalls.S (moved) * bsps/powerpc/qoriq/start/l1cache.S (moved) * bsps/powerpc/qoriq/start/l2cache.S (moved) * bsps/powerpc/qoriq/start/linkcmds.qoriq_core_0 (moved) * bsps/powerpc/qoriq/start/linkcmds.qoriq_core_1 (moved) * bsps/powerpc/qoriq/start/linkcmds.qoriq_e500 (moved) * bsps/powerpc/qoriq/start/linkcmds.qoriq_e6500_32 (moved) * bsps/powerpc/qoriq/start/linkcmds.qoriq_e6500_64 (moved) * bsps/powerpc/qoriq/start/mmu-config.c (moved) * bsps/powerpc/qoriq/start/mmu-tlb1.S (moved) * bsps/powerpc/qoriq/start/mmu.c (moved) * bsps/powerpc/qoriq/start/portal.c (moved) * bsps/powerpc/qoriq/start/restart.S (moved) * bsps/powerpc/shared/start/bspgetworkarea.c (moved) * bsps/powerpc/shared/start/bspidle.c (moved) * bsps/powerpc/shared/start/linkcmds.base (moved) * bsps/powerpc/shared/start/linkcmds.share (moved) * bsps/powerpc/shared/start/pgtbl_activate.c (moved) * bsps/powerpc/shared/start/pgtbl_setup.c (moved) * bsps/powerpc/shared/start/ppc_idle.c (moved) * bsps/powerpc/shared/start/probeMemEnd.c (moved) * bsps/powerpc/shared/start/sbrk.c (moved) * bsps/powerpc/shared/start/zerobss.c (moved) * bsps/powerpc/ss555/start/bsp_specs (moved) * bsps/powerpc/ss555/start/bspstart.c (moved) * bsps/powerpc/ss555/start/iss555.c (moved) * bsps/powerpc/ss555/start/linkcmds (moved) * bsps/powerpc/ss555/start/tm27supp.c (moved) * bsps/powerpc/t32mppc/start/bsp_specs (moved) * bsps/powerpc/t32mppc/start/bspreset.c (moved) * bsps/powerpc/t32mppc/start/bspstart.c (moved) * bsps/powerpc/t32mppc/start/linkcmds.t32mppc (moved) * bsps/powerpc/tqm8xx/start/bsp_specs (moved) * bsps/powerpc/tqm8xx/start/bspgetworkarea.c (moved) * bsps/powerpc/tqm8xx/start/bspstart.c (moved) * bsps/powerpc/tqm8xx/start/cpuinit.c (moved) * bsps/powerpc/tqm8xx/start/linkcmds (moved) * bsps/powerpc/tqm8xx/start/mmutlbtab.c (moved) * bsps/powerpc/virtex/start/bsp_specs (moved) * bsps/powerpc/virtex/start/bspstart.c (moved) * bsps/powerpc/virtex/start/linkcmds.in (moved) * bsps/powerpc/virtex4/start/bsp_specs (moved) * bsps/powerpc/virtex4/start/bspclean.c (moved) * bsps/powerpc/virtex4/start/bspstart.c (moved) * bsps/powerpc/virtex4/start/dummy_console.c (moved) * bsps/powerpc/virtex4/start/linkcmds (moved) * bsps/powerpc/virtex5/start/bsp_specs (moved) * bsps/powerpc/virtex5/start/bspclean.c (moved) * bsps/powerpc/virtex5/start/bspstart.c (moved) * bsps/powerpc/virtex5/start/dummy_console.c (moved) * bsps/powerpc/virtex5/start/linkcmds (moved) * bsps/riscv/riscv_generic/start/bsp_fatal_halt.c (moved) * bsps/riscv/riscv_generic/start/bsp_specs (moved) * bsps/riscv/riscv_generic/start/linkcmds (moved) * bsps/sh/gensh1/start/bsp_specs (moved) * bsps/sh/gensh1/start/cpu_asm.c (moved) * bsps/sh/gensh1/start/ispsh7032.c (moved) * bsps/sh/gensh1/start/linkcmds (moved) * bsps/sh/gensh2/start/bsp_specs (moved) * bsps/sh/gensh2/start/cpu_asm.c (moved) * bsps/sh/gensh2/start/hw_init.c (moved) * bsps/sh/gensh2/start/ispsh7045.c (moved) * bsps/sh/gensh2/start/linkcmds (moved) * bsps/sh/gensh2/start/linkcmds.ram (moved) * bsps/sh/gensh2/start/linkcmds.rom (moved) * bsps/sh/gensh4/start/bsp_specs (moved) * bsps/sh/gensh4/start/cpu_asm.c (moved) * bsps/sh/gensh4/start/ispsh7750.c (moved) * bsps/sh/gensh4/start/linkcmds (moved) * bsps/sh/gensh4/start/linkcmds.rom (moved) * bsps/sh/gensh4/start/linkcmds.rom2ram (moved) * bsps/sh/shared/start/bspstart.c (moved) * bsps/sh/shsim/start/bsp_specs (moved) * bsps/sh/shsim/start/cpu_asm.c (moved) * bsps/sh/shsim/start/ispshgdb.c (moved) * bsps/sh/shsim/start/linkcmds (moved) * bsps/sh/shsim/start/sysexit.c (moved) * bsps/sparc/erc32/start/boardinit.S (moved) * bsps/sparc/erc32/start/bsp_specs (moved) * bsps/sparc/erc32/start/bspdelay.c (moved) * bsps/sparc/erc32/start/bspidle.c (moved) * bsps/sparc/erc32/start/erc32mec.c (moved) * bsps/sparc/erc32/start/linkcmds (moved) * bsps/sparc/erc32/start/setvec.c (moved) * bsps/sparc/erc32/start/spurious.c (moved) * bsps/sparc/leon2/start/bsp_specs (moved) * bsps/sparc/leon2/start/bspdelay.c (moved) * bsps/sparc/leon2/start/bspidle.c (moved) * bsps/sparc/leon2/start/bspstart.c (moved) * bsps/sparc/leon2/start/linkcmds (moved) * bsps/sparc/leon2/start/linkcmds.at697f (moved) * bsps/sparc/leon2/start/linkcmds.leon2 (moved) * bsps/sparc/leon2/start/setvec.c (moved) * bsps/sparc/leon2/start/spurious.c (moved) * bsps/sparc/leon3/start/bsp_fatal_halt.c (moved) * bsps/sparc/leon3/start/bsp_specs (moved) * bsps/sparc/leon3/start/bspclean.c (moved) * bsps/sparc/leon3/start/bspdelay.c (moved) * bsps/sparc/leon3/start/bspidle.S (moved) * bsps/sparc/leon3/start/bspsmp.c (moved) * bsps/sparc/leon3/start/bspstart.c (moved) * bsps/sparc/leon3/start/cpucounter.c (moved) * bsps/sparc/leon3/start/eirq.c (moved) * bsps/sparc/leon3/start/linkcmds.gr712rc (moved) * bsps/sparc/leon3/start/linkcmds.gr740 (moved) * bsps/sparc/leon3/start/linkcmds.leon3 (moved) * bsps/sparc/leon3/start/linkcmds.ut699 (moved) * bsps/sparc/leon3/start/linkcmds.ut700 (moved) * bsps/sparc/leon3/start/setvec.c (moved) * bsps/sparc/leon3/start/spurious.c (moved) * bsps/sparc/shared/start/bsp_fatal_exit.c (moved) * bsps/sparc/shared/start/bsp_fatal_halt.c (moved) * bsps/sparc/shared/start/bspgetworkarea.c (moved) * bsps/sparc/shared/start/linkcmds.base (moved) * bsps/sparc64/niagara/start/bsp_specs (moved) * bsps/sparc64/niagara/start/bspclean.c (moved) * bsps/sparc64/niagara/start/m5op.h (moved) * bsps/sparc64/niagara/start/m5op_sparc.S (moved) * bsps/sparc64/niagara/start/m5ops.h (moved) * bsps/sparc64/shared/start/linkcmds (moved) * bsps/sparc64/shared/start/setvec.c (moved) * bsps/sparc64/usiii/start/bsp_specs (moved) * bsps/v850/gdbv850sim/start/bsp_specs (moved) * bsps/v850/gdbv850sim/start/bspreset.c (moved) * bsps/v850/gdbv850sim/start/linkcmds (moved) * bsps/v850/gdbv850sim/start/trap.S (moved) * c/src/aclocal/bsp-linkcmds.m4 (modified) * c/src/aclocal/prog-cc.m4 (modified) * c/src/lib/libbsp/arm/Makefile.am (modified) * c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am (modified) * c/src/lib/libbsp/arm/atsam/Makefile.am (modified) * c/src/lib/libbsp/arm/atsam/configure.ac (modified) * c/src/lib/libbsp/arm/beagle/Makefile.am (modified) * c/src/lib/libbsp/arm/csb336/Makefile.am (modified) * c/src/lib/libbsp/arm/csb337/Makefile.am (modified) * c/src/lib/libbsp/arm/edb7312/Makefile.am (modified) * c/src/lib/libbsp/arm/gdbarmsim/Makefile.am (modified) * c/src/lib/libbsp/arm/gumstix/Makefile.am (modified) * c/src/lib/libbsp/arm/imx/Makefile.am (modified) * c/src/lib/libbsp/arm/lm3s69xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc176x/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc24xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc32xx/Makefile.am (modified) * c/src/lib/libbsp/arm/raspberrypi/Makefile.am (modified) * c/src/lib/libbsp/arm/raspberrypi/configure.ac (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am (modified) * c/src/lib/libbsp/arm/rtl22xx/Makefile.am (modified) * c/src/lib/libbsp/arm/smdk2410/Makefile.am (modified) * c/src/lib/libbsp/arm/stm32f4/Makefile.am (modified) * c/src/lib/libbsp/arm/tms570/Makefile.am (modified) * c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am (modified) * c/src/lib/libbsp/arm/xilinx-zynq/configure.ac (modified) * c/src/lib/libbsp/bfin/TLL6527M/Makefile.am (modified) * c/src/lib/libbsp/bfin/bf537Stamp/Makefile.am (modified) * c/src/lib/libbsp/bfin/eZKit533/Makefile.am (modified) * c/src/lib/libbsp/epiphany/epiphany_sim/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/lm32/lm32_evr/Makefile.am (modified) * c/src/lib/libbsp/lm32/milkymist/Makefile.am (modified) * c/src/lib/libbsp/m32c/m32cbsp/Makefile.am (modified) * c/src/lib/libbsp/m68k/Makefile.am (modified) * c/src/lib/libbsp/m68k/av5282/Makefile.am (modified) * c/src/lib/libbsp/m68k/csb360/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/Makefile.am (modified) * c/src/lib/libbsp/m68k/genmcf548x/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5206elite/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf52235/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5225x/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5235/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5329/Makefile.am (modified) * c/src/lib/libbsp/m68k/mrm332/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/Makefile.am (modified) * c/src/lib/libbsp/m68k/uC5282/Makefile.am (modified) * c/src/lib/libbsp/mips/csb350/Makefile.am (modified) * c/src/lib/libbsp/mips/hurricane/Makefile.am (modified) * c/src/lib/libbsp/mips/jmr3904/Makefile.am (modified) * c/src/lib/libbsp/mips/malta/Makefile.am (modified) * c/src/lib/libbsp/mips/rbtx4925/Makefile.am (modified) * c/src/lib/libbsp/mips/rbtx4938/Makefile.am (modified) * c/src/lib/libbsp/moxie/moxiesim/Makefile.am (modified) * c/src/lib/libbsp/nios2/nios2_iss/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/Makefile.am (modified) * c/src/lib/libbsp/or1k/generic_or1k/Makefile.am (modified) * c/src/lib/libbsp/powerpc/beatnik/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen5200/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen83xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/haleakala/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme3100/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme5500/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qemuppc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qoriq/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ss555/Makefile.am (modified) * c/src/lib/libbsp/powerpc/t32mppc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/tqm8xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex/configure.ac (modified) * c/src/lib/libbsp/powerpc/virtex4/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex5/Makefile.am (modified) * c/src/lib/libbsp/riscv/riscv_generic/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh4/Makefile.am (modified) * c/src/lib/libbsp/sh/shsim/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/lib/libbsp/sparc64/niagara/Makefile.am (modified) * c/src/lib/libbsp/sparc64/usiii/Makefile.am (modified) * c/src/lib/libbsp/v850/gdbv850sim/Makefile.am (modified) * testsuites/aclocal/prog-cc.m4 (modified) * testsuites/aclocal/rtems-bsp-linkcmds.m4 (modified) bsps: Move startup files to bsps Adjust build support files to new ... Fri, 20 Apr 2018 08:19:28 GMT Sebastian Huber [fbcd7c8f] * bsps/arm/csb336/start/start.S (moved) * bsps/arm/csb337/start/start.S (moved) * bsps/arm/edb7312/start/start.S (moved) * bsps/arm/gumstix/start/start.S (moved) * bsps/arm/rtl22xx/start/start.S (moved) * bsps/arm/shared/start/start.S (moved) * bsps/arm/smdk2410/start/start.S (moved) * bsps/bfin/bf537Stamp/start/start.S (moved) * bsps/bfin/shared/start/start.S (moved) * bsps/epiphany/epiphany_sim/start/start.S (moved) * bsps/i386/pc386/start/start.S (moved) * bsps/i386/pc386/start/start16.S (moved) * bsps/lm32/shared/start/start.S (moved) * bsps/m32c/m32cbsp/start/start.S (moved) * bsps/m68k/av5282/start/start.S (moved) * bsps/m68k/csb360/start/start.S (moved) * bsps/m68k/gen68340/start/start.S (moved) * bsps/m68k/gen68360/start/start.S (moved) * bsps/m68k/genmcf548x/start/start.S (moved) * bsps/m68k/mcf5206elite/start/start.S (moved) * bsps/m68k/mcf52235/start/start.S (moved) * bsps/m68k/mcf5225x/start/start.S (moved) * bsps/m68k/mcf5235/start/start.S (moved) * bsps/m68k/mcf5329/start/start.S (moved) * bsps/m68k/mrm332/start/start.S (moved) * bsps/m68k/shared/start/start.S (moved) * bsps/m68k/uC5282/start/start.S (moved) * bsps/mips/csb350/start/start.S (moved) * bsps/mips/hurricane/start/start.S (moved) * bsps/mips/jmr3904/start/start.S (moved) * bsps/mips/malta/start/start.S (moved) * bsps/mips/rbtx4925/start/start.S (moved) * bsps/mips/rbtx4938/start/start.S (moved) * bsps/moxie/moxiesim/start/start.S (moved) * bsps/nios2/nios2_iss/start/crtnn.S (moved) * bsps/nios2/nios2_iss/start/start.S (moved) * bsps/or1k/generic_or1k/start/start.S (moved) * bsps/powerpc/gen5200/start/start.S (moved) * bsps/powerpc/gen83xx/start/start.S (moved) * bsps/powerpc/mpc55xxevb/start/start.S (moved) * bsps/powerpc/mpc8260ads/start/start.S (moved) * bsps/powerpc/mvme3100/start/start.S (moved) * bsps/powerpc/mvme5500/start/start.S (moved) * bsps/powerpc/psim/start/start.S (moved) * bsps/powerpc/qemuppc/start/start.S (moved) * bsps/powerpc/qoriq/start/start.S (moved) * bsps/powerpc/shared/start/preload.S (moved) * bsps/powerpc/shared/start/rtems_crti.S (moved) * bsps/powerpc/shared/start/rtems_crtn.S (moved) * bsps/powerpc/shared/start/start.S (moved) * bsps/powerpc/shared/start/vectors_entry.S (moved) * bsps/powerpc/ss555/start/start.S (moved) * bsps/powerpc/t32mppc/start/start.S (moved) * bsps/powerpc/tqm8xx/start/start.S (moved) * bsps/powerpc/virtex/start/start.S (moved) * bsps/powerpc/virtex4/start/start.S (moved) * bsps/powerpc/virtex5/start/start.S (moved) * bsps/riscv/riscv_generic/start/start.S (moved) * bsps/sh/gensh1/start/start.S (moved) * bsps/sh/gensh2/start/start.S (moved) * bsps/sh/gensh2/start/start.ram (moved) * bsps/sh/gensh2/start/start.rom (moved) * bsps/sh/gensh4/start/start.S (moved) * bsps/sh/shsim/start/start.S (moved) * bsps/sparc/shared/start/start.S (moved) * bsps/sparc64/niagara/start/bspinit.S (moved) * bsps/sparc64/shared/start/start.S (moved) * bsps/sparc64/shared/start/trap_table.S (moved) * bsps/sparc64/usiii/start/bspinit.S (moved) * bsps/v850/gdbv850sim/start/start.S (moved) * c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am (modified) * c/src/lib/libbsp/arm/atsam/Makefile.am (modified) * c/src/lib/libbsp/arm/beagle/Makefile.am (modified) * c/src/lib/libbsp/arm/csb336/Makefile.am (modified) * c/src/lib/libbsp/arm/csb337/Makefile.am (modified) * c/src/lib/libbsp/arm/edb7312/Makefile.am (modified) * c/src/lib/libbsp/arm/gdbarmsim/Makefile.am (modified) * c/src/lib/libbsp/arm/gumstix/Makefile.am (modified) * c/src/lib/libbsp/arm/imx/Makefile.am (modified) * c/src/lib/libbsp/arm/lm3s69xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc176x/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc24xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc32xx/Makefile.am (modified) * c/src/lib/libbsp/arm/raspberrypi/Makefile.am (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am (modified) * c/src/lib/libbsp/arm/rtl22xx/Makefile.am (modified) * c/src/lib/libbsp/arm/smdk2410/Makefile.am (modified) * c/src/lib/libbsp/arm/stm32f4/Makefile.am (modified) * c/src/lib/libbsp/arm/tms570/Makefile.am (modified) * c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am (modified) * c/src/lib/libbsp/bfin/TLL6527M/Makefile.am (modified) * c/src/lib/libbsp/bfin/bf537Stamp/Makefile.am (modified) * c/src/lib/libbsp/bfin/eZKit533/Makefile.am (modified) * c/src/lib/libbsp/epiphany/epiphany_sim/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/lm32/lm32_evr/Makefile.am (modified) * c/src/lib/libbsp/lm32/milkymist/Makefile.am (modified) * c/src/lib/libbsp/m32c/m32cbsp/Makefile.am (modified) * c/src/lib/libbsp/m68k/av5282/Makefile.am (modified) * c/src/lib/libbsp/m68k/csb360/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/Makefile.am (modified) * c/src/lib/libbsp/m68k/genmcf548x/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5206elite/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf52235/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5225x/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5235/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5329/Makefile.am (modified) * c/src/lib/libbsp/m68k/mrm332/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/Makefile.am (modified) * c/src/lib/libbsp/m68k/uC5282/Makefile.am (modified) * c/src/lib/libbsp/mips/csb350/Makefile.am (modified) * c/src/lib/libbsp/mips/hurricane/Makefile.am (modified) * c/src/lib/libbsp/mips/jmr3904/Makefile.am (modified) * c/src/lib/libbsp/mips/malta/Makefile.am (modified) * c/src/lib/libbsp/mips/rbtx4925/Makefile.am (modified) * c/src/lib/libbsp/mips/rbtx4938/Makefile.am (modified) * c/src/lib/libbsp/moxie/moxiesim/Makefile.am (modified) * c/src/lib/libbsp/nios2/nios2_iss/Makefile.am (modified) * c/src/lib/libbsp/or1k/generic_or1k/Makefile.am (modified) * c/src/lib/libbsp/powerpc/beatnik/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen5200/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen83xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/haleakala/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme3100/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme5500/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qemuppc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qoriq/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ss555/Makefile.am (modified) * c/src/lib/libbsp/powerpc/t32mppc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/tqm8xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex4/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex5/Makefile.am (modified) * c/src/lib/libbsp/riscv/riscv_generic/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh4/Makefile.am (modified) * c/src/lib/libbsp/sh/shsim/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/lib/libbsp/sparc64/niagara/Makefile.am (modified) * c/src/lib/libbsp/sparc64/usiii/Makefile.am (modified) * c/src/lib/libbsp/v850/gdbv850sim/Makefile.am (modified) bsps: Move start files to bsps This patch is a part of the BSP ... Wed, 18 Apr 2018 04:35:03 GMT Sebastian Huber [0510cd50] * bsps/arm/shared/doxygen.h (moved) * bsps/bfin/shared/doxygen.h (moved) * bsps/i386/shared/doxygen.h (moved) * bsps/lm32/shared/doxygen.h (moved) * bsps/m32c/m32cbsp/doxygen.h (moved) * bsps/m68k/gen68360/doxygen.h (moved) * bsps/m68k/shared/doxygen.h (moved) * bsps/mips/shared/doxygen.h (moved) * bsps/powerpc/mvme3100/doxygen.h (moved) * bsps/powerpc/shared/doxygen.h (moved) * bsps/shared/doxygen.h (moved) * bsps/sparc/shared/doxygen.h (moved) * c/src/lib/libbsp/shared/include/doxygen.h (deleted) bsps: Move doxygen.h files to bsps This patch is a part of the BSP ...
