# # ChangeLog for bsps/shared/shared-sources.am in rtems # # Generated by Trac 1.2.1.dev0 # 04/19/24 03:39:35 Tue, 03 Apr 2018 05:20:11 GMT Sebastian Huber [27de4e1f] * bsps/powerpc/gen5200/dev/mpc5200-ata.c (moved) * bsps/shared/dev/display/disp_fonts.h (moved) * bsps/shared/dev/display/disp_hcms29xx.c (moved) * bsps/shared/dev/display/font_hcms29xx.c (moved) * bsps/shared/dev/display/font_hcms29xx.h (moved) * bsps/shared/dev/flash/am29lv160.c (moved) * bsps/shared/dev/i2c/i2c-2b-eeprom.c (moved) * bsps/shared/dev/i2c/i2c-ds1621.c (moved) * bsps/shared/dev/i2c/i2c-sc620.c (moved) * bsps/shared/dev/i2c/spi-flash-m25p40.c (moved) * bsps/shared/dev/i2c/spi-fram-fm25l256.c (moved) * bsps/shared/dev/i2c/spi-memdrv.c (moved) * bsps/shared/dev/i2c/spi-sd-card.c (moved) * bsps/shared/dev/ide/ata.c (moved) * bsps/shared/dev/ide/ata_util.c (moved) * bsps/shared/dev/ide/ide_controller.c (moved) * bsps/shared/dev/rtc/README.ds1643 (moved) * bsps/shared/dev/rtc/README.icm7170 (moved) * bsps/shared/dev/rtc/README.m48t08 (moved) * bsps/shared/dev/rtc/README.m48t18 (moved) * bsps/shared/dev/rtc/README.mc146818a (moved) * bsps/shared/dev/rtc/STATUS (moved) * bsps/shared/dev/rtc/ds1375.c (moved) * bsps/shared/dev/rtc/icm7170.c (moved) * bsps/shared/dev/rtc/icm7170_reg.c (moved) * bsps/shared/dev/rtc/icm7170_reg2.c (moved) * bsps/shared/dev/rtc/icm7170_reg4.c (moved) * bsps/shared/dev/rtc/icm7170_reg8.c (moved) * bsps/shared/dev/rtc/m48t08.c (moved) * bsps/shared/dev/rtc/m48t08_reg.c (moved) * bsps/shared/dev/rtc/m48t08_reg2.c (moved) * bsps/shared/dev/rtc/m48t08_reg4.c (moved) * bsps/shared/dev/rtc/m48t08_reg8.c (moved) * bsps/shared/dev/rtc/mc146818a.c (moved) * bsps/shared/dev/rtc/mc146818a_ioreg.c (moved) * bsps/shared/dev/rtc/rtcprobe.c (moved) * bsps/shared/dev/serial/README (moved) * bsps/shared/dev/serial/README.mc68681 (moved) * bsps/shared/dev/serial/README.ns16550 (moved) * bsps/shared/dev/serial/README.xr88681 (moved) * bsps/shared/dev/serial/README.z85c30 (moved) * bsps/shared/dev/serial/STATUS (moved) * bsps/shared/dev/serial/mc68681.c (moved) * bsps/shared/dev/serial/mc68681_baud.c (moved) * bsps/shared/dev/serial/mc68681_p.h (moved) * bsps/shared/dev/serial/mc68681_reg.c (moved) * bsps/shared/dev/serial/mc68681_reg2.c (moved) * bsps/shared/dev/serial/mc68681_reg4.c (moved) * bsps/shared/dev/serial/mc68681_reg8.c (moved) * bsps/shared/dev/serial/ns16550-context.c (moved) * bsps/shared/dev/serial/ns16550.c (moved) * bsps/shared/dev/serial/serprobe.c (moved) * bsps/shared/dev/serial/z85c30.c (moved) * bsps/shared/dev/serial/z85c30_p.h (moved) * bsps/shared/dev/serial/z85c30_reg.c (moved) * bsps/shared/net/README (moved) * bsps/shared/net/README.3com (moved) * bsps/shared/net/README.cs8900 (moved) * bsps/shared/net/README.dec21140 (moved) * bsps/shared/net/README.i82586 (moved) * bsps/shared/net/README.open_eth (moved) * bsps/shared/net/README.sonic (moved) * bsps/shared/net/README.tulipclone (moved) * bsps/shared/net/cs8900.c (moved) * bsps/shared/net/cs8900.c.bsp (moved) * bsps/shared/net/cs8900.h.bsp (moved) * bsps/shared/net/dec21140.c (moved) * bsps/shared/net/elnk.c (moved) * bsps/shared/net/greth2.c (moved) * bsps/shared/net/i82586.c (moved) * bsps/shared/net/i82586reg.h (moved) * bsps/shared/net/if_dc.c (moved) * bsps/shared/net/if_fxp.c (moved) * bsps/shared/net/if_fxpreg.h (moved) * bsps/shared/net/open_eth.c (moved) * bsps/shared/net/smc91111.c (moved) * bsps/shared/net/smc91111config.h (moved) * bsps/shared/net/sonic.c (moved) * bsps/shared/shared-sources.am (modified) * c/src/configure.ac (modified) * c/src/lib/libbsp/powerpc/gen5200/Makefile.am (modified) * c/src/libchip/Makefile.am (modified) * c/src/wrapup/Makefile.am (modified) bsps: Move libchip to bsps This patch is a part of the BSP source ... Tue, 03 Apr 2018 05:09:11 GMT Sebastian Huber [4f0dca3a] * bsps/shared/rtems-version.c (moved) * bsps/shared/shared-sources.am (modified) * c/src/configure.ac (modified) * c/src/support/Makefile.am (deleted) * c/src/wrapup/Makefile.am (modified) bsps: Move version.c and use bspopts.h This patch is a part of the ... Tue, 03 Apr 2018 05:08:24 GMT Sebastian Huber [ce0ea6f] * bsps/shared/shared-sources.am (added) * c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am (modified) * c/src/lib/libbsp/arm/atsam/Makefile.am (modified) * c/src/lib/libbsp/arm/beagle/Makefile.am (modified) * c/src/lib/libbsp/arm/csb336/Makefile.am (modified) * c/src/lib/libbsp/arm/csb337/Makefile.am (modified) * c/src/lib/libbsp/arm/edb7312/Makefile.am (modified) * c/src/lib/libbsp/arm/gdbarmsim/Makefile.am (modified) * c/src/lib/libbsp/arm/gumstix/Makefile.am (modified) * c/src/lib/libbsp/arm/imx/Makefile.am (modified) * c/src/lib/libbsp/arm/lm3s69xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc176x/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc24xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc32xx/Makefile.am (modified) * c/src/lib/libbsp/arm/raspberrypi/Makefile.am (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am (modified) * c/src/lib/libbsp/arm/rtl22xx/Makefile.am (modified) * c/src/lib/libbsp/arm/smdk2410/Makefile.am (modified) * c/src/lib/libbsp/arm/stm32f4/Makefile.am (modified) * c/src/lib/libbsp/arm/tms570/Makefile.am (modified) * c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am (modified) * c/src/lib/libbsp/bfin/TLL6527M/Makefile.am (modified) * c/src/lib/libbsp/bfin/bf537Stamp/Makefile.am (modified) * c/src/lib/libbsp/bfin/eZKit533/Makefile.am (modified) * c/src/lib/libbsp/epiphany/epiphany_sim/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/lm32/lm32_evr/Makefile.am (modified) * c/src/lib/libbsp/lm32/milkymist/Makefile.am (modified) * c/src/lib/libbsp/m32c/m32cbsp/Makefile.am (modified) * c/src/lib/libbsp/m68k/av5282/Makefile.am (modified) * c/src/lib/libbsp/m68k/csb360/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/Makefile.am (modified) * c/src/lib/libbsp/m68k/genmcf548x/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5206elite/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf52235/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5225x/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5235/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5329/Makefile.am (modified) * c/src/lib/libbsp/m68k/mrm332/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/Makefile.am (modified) * c/src/lib/libbsp/m68k/uC5282/Makefile.am (modified) * c/src/lib/libbsp/mips/csb350/Makefile.am (modified) * c/src/lib/libbsp/mips/hurricane/Makefile.am (modified) * c/src/lib/libbsp/mips/jmr3904/Makefile.am (modified) * c/src/lib/libbsp/mips/malta/Makefile.am (modified) * c/src/lib/libbsp/mips/rbtx4925/Makefile.am (modified) * c/src/lib/libbsp/mips/rbtx4938/Makefile.am (modified) * c/src/lib/libbsp/moxie/moxiesim/Makefile.am (modified) * c/src/lib/libbsp/nios2/nios2_iss/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/Makefile.am (modified) * c/src/lib/libbsp/or1k/generic_or1k/Makefile.am (modified) * c/src/lib/libbsp/powerpc/beatnik/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen5200/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen83xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/haleakala/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme3100/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme5500/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qemuppc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qoriq/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ss555/Makefile.am (modified) * c/src/lib/libbsp/powerpc/t32mppc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/tqm8xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex4/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex5/Makefile.am (modified) * c/src/lib/libbsp/riscv/riscv_generic/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh4/Makefile.am (modified) * c/src/lib/libbsp/sh/shsim/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/lib/libbsp/sparc64/niagara/Makefile.am (modified) * c/src/lib/libbsp/sparc64/usiii/Makefile.am (modified) * c/src/lib/libbsp/v850/gdbv850sim/Makefile.am (modified) bsps: Add shared-sources.am This patch is a part of the BSP source ...
