# # ChangeLog for bsps/shared/net/elnk.c in rtems # # Generated by Trac 1.2.1.dev0 # 03/29/24 01:47:55 Tue, 03 Apr 2018 05:20:11 GMT Sebastian Huber [27de4e1f] * bsps/powerpc/gen5200/dev/mpc5200-ata.c (moved) * bsps/shared/dev/display/disp_fonts.h (moved) * bsps/shared/dev/display/disp_hcms29xx.c (moved) * bsps/shared/dev/display/font_hcms29xx.c (moved) * bsps/shared/dev/display/font_hcms29xx.h (moved) * bsps/shared/dev/flash/am29lv160.c (moved) * bsps/shared/dev/i2c/i2c-2b-eeprom.c (moved) * bsps/shared/dev/i2c/i2c-ds1621.c (moved) * bsps/shared/dev/i2c/i2c-sc620.c (moved) * bsps/shared/dev/i2c/spi-flash-m25p40.c (moved) * bsps/shared/dev/i2c/spi-fram-fm25l256.c (moved) * bsps/shared/dev/i2c/spi-memdrv.c (moved) * bsps/shared/dev/i2c/spi-sd-card.c (moved) * bsps/shared/dev/ide/ata.c (moved) * bsps/shared/dev/ide/ata_util.c (moved) * bsps/shared/dev/ide/ide_controller.c (moved) * bsps/shared/dev/rtc/README.ds1643 (moved) * bsps/shared/dev/rtc/README.icm7170 (moved) * bsps/shared/dev/rtc/README.m48t08 (moved) * bsps/shared/dev/rtc/README.m48t18 (moved) * bsps/shared/dev/rtc/README.mc146818a (moved) * bsps/shared/dev/rtc/STATUS (moved) * bsps/shared/dev/rtc/ds1375.c (moved) * bsps/shared/dev/rtc/icm7170.c (moved) * bsps/shared/dev/rtc/icm7170_reg.c (moved) * bsps/shared/dev/rtc/icm7170_reg2.c (moved) * bsps/shared/dev/rtc/icm7170_reg4.c (moved) * bsps/shared/dev/rtc/icm7170_reg8.c (moved) * bsps/shared/dev/rtc/m48t08.c (moved) * bsps/shared/dev/rtc/m48t08_reg.c (moved) * bsps/shared/dev/rtc/m48t08_reg2.c (moved) * bsps/shared/dev/rtc/m48t08_reg4.c (moved) * bsps/shared/dev/rtc/m48t08_reg8.c (moved) * bsps/shared/dev/rtc/mc146818a.c (moved) * bsps/shared/dev/rtc/mc146818a_ioreg.c (moved) * bsps/shared/dev/rtc/rtcprobe.c (moved) * bsps/shared/dev/serial/README (moved) * bsps/shared/dev/serial/README.mc68681 (moved) * bsps/shared/dev/serial/README.ns16550 (moved) * bsps/shared/dev/serial/README.xr88681 (moved) * bsps/shared/dev/serial/README.z85c30 (moved) * bsps/shared/dev/serial/STATUS (moved) * bsps/shared/dev/serial/mc68681.c (moved) * bsps/shared/dev/serial/mc68681_baud.c (moved) * bsps/shared/dev/serial/mc68681_p.h (moved) * bsps/shared/dev/serial/mc68681_reg.c (moved) * bsps/shared/dev/serial/mc68681_reg2.c (moved) * bsps/shared/dev/serial/mc68681_reg4.c (moved) * bsps/shared/dev/serial/mc68681_reg8.c (moved) * bsps/shared/dev/serial/ns16550-context.c (moved) * bsps/shared/dev/serial/ns16550.c (moved) * bsps/shared/dev/serial/serprobe.c (moved) * bsps/shared/dev/serial/z85c30.c (moved) * bsps/shared/dev/serial/z85c30_p.h (moved) * bsps/shared/dev/serial/z85c30_reg.c (moved) * bsps/shared/net/README (moved) * bsps/shared/net/README.3com (moved) * bsps/shared/net/README.cs8900 (moved) * bsps/shared/net/README.dec21140 (moved) * bsps/shared/net/README.i82586 (moved) * bsps/shared/net/README.open_eth (moved) * bsps/shared/net/README.sonic (moved) * bsps/shared/net/README.tulipclone (moved) * bsps/shared/net/cs8900.c (moved) * bsps/shared/net/cs8900.c.bsp (moved) * bsps/shared/net/cs8900.h.bsp (moved) * bsps/shared/net/dec21140.c (moved) * bsps/shared/net/elnk.c (moved) * bsps/shared/net/greth2.c (moved) * bsps/shared/net/i82586.c (moved) * bsps/shared/net/i82586reg.h (moved) * bsps/shared/net/if_dc.c (moved) * bsps/shared/net/if_fxp.c (moved) * bsps/shared/net/if_fxpreg.h (moved) * bsps/shared/net/open_eth.c (moved) * bsps/shared/net/smc91111.c (moved) * bsps/shared/net/smc91111config.h (moved) * bsps/shared/net/sonic.c (moved) * bsps/shared/shared-sources.am (modified) * c/src/configure.ac (modified) * c/src/lib/libbsp/powerpc/gen5200/Makefile.am (modified) * c/src/libchip/Makefile.am (modified) * c/src/wrapup/Makefile.am (modified) bsps: Move libchip to bsps This patch is a part of the BSP source ...
