# # ChangeLog for bsps/powerpc/mvme3100/start/bspstart.c in rtems # # Generated by Trac 1.2.1.dev0 # Jan 28, 2021, 9:49:53 AM Fri, 20 Apr 2018 08:35:35 GMT Sebastian Huber [9964895] * bsps/arm/altera-cyclone-v/start/bsp_specs (moved) * bsps/arm/altera-cyclone-v/start/bspclean.c (moved) * bsps/arm/altera-cyclone-v/start/bspgetworkarea.c (moved) * bsps/arm/altera-cyclone-v/start/bspreset.c (moved) * bsps/arm/altera-cyclone-v/start/bspsmp.c (moved) * bsps/arm/altera-cyclone-v/start/bspstart.c (moved) * bsps/arm/altera-cyclone-v/start/bspstarthooks.c (moved) * bsps/arm/altera-cyclone-v/start/linkcmds.altcycv (moved) * bsps/arm/altera-cyclone-v/start/linkcmds.altcycv_devkit (moved) * bsps/arm/altera-cyclone-v/start/linkcmds.altcycv_devkit_smp (moved) * bsps/arm/altera-cyclone-v/start/mmu-config.c (moved) * bsps/arm/atsam/start/bsp_specs (moved) * bsps/arm/atsam/start/bspstart.c (moved) * bsps/arm/atsam/start/bspstarthooks.c (moved) * bsps/arm/atsam/start/getentropy-trng.c (moved) * bsps/arm/atsam/start/linkcmds (moved) * bsps/arm/atsam/start/linkcmds.intsram (moved) * bsps/arm/atsam/start/linkcmds.memory.in (moved) * bsps/arm/atsam/start/linkcmds.qspiflash (moved) * bsps/arm/atsam/start/linkcmds.sdram (moved) * bsps/arm/atsam/start/pin-config.c (moved) * bsps/arm/atsam/start/pmc-config.c (moved) * bsps/arm/atsam/start/power-clock.c (moved) * bsps/arm/atsam/start/power-rtc.c (moved) * bsps/arm/atsam/start/power.c (moved) * bsps/arm/atsam/start/restart.c (moved) * bsps/arm/atsam/start/sdram-config.c (moved) * bsps/arm/beagle/start/bsp_specs (moved) * bsps/arm/beagle/start/bspreset.c (moved) * bsps/arm/beagle/start/bspstart.c (moved) * bsps/arm/beagle/start/bspstarthooks.c (moved) * bsps/arm/beagle/start/bspstartmmu.c (moved) * bsps/arm/beagle/start/linkcmds.beagle (moved) * bsps/arm/csb336/start/bsp_specs (moved) * bsps/arm/csb336/start/bspstart.c (moved) * bsps/arm/csb336/start/linkcmds (moved) * bsps/arm/csb336/start/memmap.c (moved) * bsps/arm/csb337/start/bsp_specs (moved) * bsps/arm/csb337/start/bspreset.c (moved) * bsps/arm/csb337/start/bspstart.c (moved) * bsps/arm/csb337/start/linkcmds.csb337 (moved) * bsps/arm/csb337/start/linkcmds.csb637 (moved) * bsps/arm/csb337/start/memmap.c (moved) * bsps/arm/csb337/start/pmc.c (moved) * bsps/arm/csb337/start/umonsupp.c (moved) * bsps/arm/edb7312/start/bsp_specs (moved) * bsps/arm/edb7312/start/bspreset.c (moved) * bsps/arm/edb7312/start/bspstart.c (moved) * bsps/arm/edb7312/start/linkcmds (moved) * bsps/arm/gdbarmsim/start/bsp_specs (moved) * bsps/arm/gdbarmsim/start/bspreset.c (moved) * bsps/arm/gdbarmsim/start/bspstart.c (moved) * bsps/arm/gdbarmsim/start/bspstarthooks.c (moved) * bsps/arm/gdbarmsim/start/linkcmds (moved) * bsps/arm/gdbarmsim/start/syscalls.c (moved) * bsps/arm/gumstix/start/bsp_specs (moved) * bsps/arm/gumstix/start/bspreset.c (moved) * bsps/arm/gumstix/start/bspstart.c (moved) * bsps/arm/gumstix/start/linkcmds (moved) * bsps/arm/gumstix/start/memmap.c (moved) * bsps/arm/imx/start/bsp_specs (moved) * bsps/arm/imx/start/bspreset.c (moved) * bsps/arm/imx/start/bspsmp.c (moved) * bsps/arm/imx/start/bspstart.c (moved) * bsps/arm/imx/start/bspstarthooks.c (moved) * bsps/arm/imx/start/ccm.c (moved) * bsps/arm/imx/start/imx_iomux.c (moved) * bsps/arm/imx/start/linkcmds.imx7 (moved) * bsps/arm/lm3s69xx/start/bsp_specs (moved) * bsps/arm/lm3s69xx/start/bspstart.c (moved) * bsps/arm/lm3s69xx/start/bspstarthook.c (moved) * bsps/arm/lm3s69xx/start/io.c (moved) * bsps/arm/lm3s69xx/start/linkcmds.lm3s3749 (moved) * bsps/arm/lm3s69xx/start/linkcmds.lm3s6965 (moved) * bsps/arm/lm3s69xx/start/linkcmds.lm3s6965_qemu (moved) * bsps/arm/lm3s69xx/start/linkcmds.lm4f120 (moved) * bsps/arm/lm3s69xx/start/syscon.c (moved) * bsps/arm/lpc176x/start/bsp_specs (moved) * bsps/arm/lpc176x/start/bspstart.c (moved) * bsps/arm/lpc176x/start/bspstarthooks.c (moved) * bsps/arm/lpc176x/start/linkcmds.lpc1768_mbed (moved) * bsps/arm/lpc176x/start/linkcmds.lpc1768_mbed_ahb_ram (moved) * bsps/arm/lpc176x/start/linkcmds.lpc1768_mbed_ahb_ram_eth (moved) * bsps/arm/lpc24xx/start/bsp_specs (moved) * bsps/arm/lpc24xx/start/bspreset-armv4.c (moved) * bsps/arm/lpc24xx/start/bspstart.c (moved) * bsps/arm/lpc24xx/start/bspstarthooks.c (moved) * bsps/arm/lpc24xx/start/fb-config.c (moved) * bsps/arm/lpc24xx/start/linkcmds.lpc17xx_ea_ram (moved) * bsps/arm/lpc24xx/start/linkcmds.lpc17xx_ea_rom_int (moved) * bsps/arm/lpc24xx/start/linkcmds.lpc17xx_plx800_ram (moved) * bsps/arm/lpc24xx/start/linkcmds.lpc17xx_plx800_rom_int (moved) * bsps/arm/lpc24xx/start/linkcmds.lpc2362 (moved) * bsps/arm/lpc24xx/start/linkcmds.lpc23xx_tli800 (moved) * bsps/arm/lpc24xx/start/linkcmds.lpc24xx_ea (moved) * bsps/arm/lpc24xx/start/linkcmds.lpc24xx_ncs_ram (moved) * bsps/arm/lpc24xx/start/linkcmds.lpc24xx_ncs_rom_ext (moved) * bsps/arm/lpc24xx/start/linkcmds.lpc24xx_ncs_rom_int (moved) * bsps/arm/lpc24xx/start/linkcmds.lpc24xx_plx800_ram (moved) * bsps/arm/lpc24xx/start/linkcmds.lpc24xx_plx800_rom_int (moved) * bsps/arm/lpc24xx/start/linkcmds.lpc40xx_ea_ram (moved) * bsps/arm/lpc24xx/start/linkcmds.lpc40xx_ea_rom_int (moved) * bsps/arm/lpc24xx/start/start-config-emc-dynamic.c (moved) * bsps/arm/lpc24xx/start/start-config-emc-static.c (moved) * bsps/arm/lpc24xx/start/start-config-mpu.c (moved) * bsps/arm/lpc24xx/start/start-config-pinsel.c (moved) * bsps/arm/lpc32xx/start/bsp_specs (moved) * bsps/arm/lpc32xx/start/bspreset.c (moved) * bsps/arm/lpc32xx/start/bspstart.c (moved) * bsps/arm/lpc32xx/start/bspstarthooks.c (moved) * bsps/arm/lpc32xx/start/linkcmds.lpc32xx (moved) * bsps/arm/lpc32xx/start/linkcmds.lpc32xx_mzx (moved) * bsps/arm/lpc32xx/start/linkcmds.lpc32xx_mzx_stage_1 (moved) * bsps/arm/lpc32xx/start/linkcmds.lpc32xx_mzx_stage_2 (moved) * bsps/arm/lpc32xx/start/linkcmds.lpc32xx_phycore (moved) * bsps/arm/raspberrypi/start/bsp_specs (moved) * bsps/arm/raspberrypi/start/bspgetworkarea.c (moved) * bsps/arm/raspberrypi/start/bspreset.c (moved) * bsps/arm/raspberrypi/start/bspsmp.c (moved) * bsps/arm/raspberrypi/start/bspsmp_init.c (moved) * bsps/arm/raspberrypi/start/bspstart.c (moved) * bsps/arm/raspberrypi/start/bspstarthooks.c (moved) * bsps/arm/raspberrypi/start/cmdline.c (moved) * bsps/arm/raspberrypi/start/linkcmds.in (moved) * bsps/arm/raspberrypi/start/mm_config_table.c (moved) * bsps/arm/realview-pbx-a9/start/bsp_specs (moved) * bsps/arm/realview-pbx-a9/start/bspreset.c (moved) * bsps/arm/realview-pbx-a9/start/bspsmp.c (moved) * bsps/arm/realview-pbx-a9/start/bspstart.c (moved) * bsps/arm/realview-pbx-a9/start/bspstarthooks.c (moved) * bsps/arm/realview-pbx-a9/start/fb-config.c (moved) * bsps/arm/realview-pbx-a9/start/linkcmds.realview_pbx_a9_qemu (moved) * bsps/arm/realview-pbx-a9/start/linkcmds.realview_pbx_a9_qemu_smp (moved) * bsps/arm/rtl22xx/start/bsp_specs (moved) * bsps/arm/rtl22xx/start/bspreset.c (moved) * bsps/arm/rtl22xx/start/bspstart.c (moved) * bsps/arm/rtl22xx/start/linkcmds (moved) * bsps/arm/shared/start/bsp-start-in-hyp-support.S (moved) * bsps/arm/shared/start/bsp-start-init-registers.S (moved) * bsps/arm/shared/start/bsp-start-memcpy.S (moved) * bsps/arm/shared/start/linkcmds.armv4 (moved) * bsps/arm/shared/start/linkcmds.armv7m (moved) * bsps/arm/shared/start/linkcmds.base (moved) * bsps/arm/smdk2410/start/bsp_specs (moved) * bsps/arm/smdk2410/start/bspidle.c (moved) * bsps/arm/smdk2410/start/bspreset.c (moved) * bsps/arm/smdk2410/start/bspstart.c (moved) * bsps/arm/smdk2410/start/linkcmds (moved) * bsps/arm/smdk2410/start/memmap.c (moved) * bsps/arm/stm32f4/start/bsp_specs (moved) * bsps/arm/stm32f4/start/bspreset.c (moved) * bsps/arm/stm32f4/start/bspstart.c (moved) * bsps/arm/stm32f4/start/bspstarthook.c (moved) * bsps/arm/stm32f4/start/io.c (moved) * bsps/arm/stm32f4/start/linkcmds.stm32f105rc (moved) * bsps/arm/stm32f4/start/linkcmds.stm32f4 (moved) * bsps/arm/stm32f4/start/rcc.c (moved) * bsps/arm/stm32f4/start/start-config-io.c (moved) * bsps/arm/tms570/start/bsp_specs (moved) * bsps/arm/tms570/start/bspreset.c (moved) * bsps/arm/tms570/start/bspstart.c (moved) * bsps/arm/tms570/start/bspstarthooks.c (moved) * bsps/arm/tms570/start/linkcmds.tms570ls3137_hdk (moved) * bsps/arm/tms570/start/linkcmds.tms570ls3137_hdk_intram (moved) * bsps/arm/tms570/start/linkcmds.tms570ls3137_hdk_sdram (moved) * bsps/arm/tms570/start/linkcmds.tms570ls3137_hdk_with_loader (moved) * bsps/arm/xilinx-zynq/start/bsp_specs (moved) * bsps/arm/xilinx-zynq/start/bspreset.c (moved) * bsps/arm/xilinx-zynq/start/bspsmp.c (moved) * bsps/arm/xilinx-zynq/start/bspstart.c (moved) * bsps/arm/xilinx-zynq/start/bspstarthooks.c (moved) * bsps/arm/xilinx-zynq/start/bspstartmmu.c (moved) * bsps/arm/xilinx-zynq/start/linkcmds.in (moved) * bsps/bfin/TLL6527M/start/bsp_specs (moved) * bsps/bfin/TLL6527M/start/bspstart.c (moved) * bsps/bfin/TLL6527M/start/linkcmds (moved) * bsps/bfin/bf537Stamp/start/bsp_specs (moved) * bsps/bfin/bf537Stamp/start/bspstart.c (moved) * bsps/bfin/bf537Stamp/start/linkcmds (moved) * bsps/bfin/eZKit533/start/bsp_specs (moved) * bsps/bfin/eZKit533/start/bspstart.c (moved) * bsps/bfin/eZKit533/start/linkcmds (moved) * bsps/epiphany/epiphany_sim/start/bsp_specs (moved) * bsps/epiphany/epiphany_sim/start/linkcmds (moved) * bsps/i386/pc386/start/bsp_fatal_halt.c (moved) * bsps/i386/pc386/start/bsp_specs (moved) * bsps/i386/pc386/start/bspcmdline.c (moved) * bsps/i386/pc386/start/bspgetworkarea.c (moved) * bsps/i386/pc386/start/bspidle.S (moved) * bsps/i386/pc386/start/bspreset.c (moved) * bsps/i386/pc386/start/bspstart.c (moved) * bsps/i386/pc386/start/ldsegs.S (moved) * bsps/i386/pc386/start/linkcmds (moved) * bsps/lm32/lm32_evr/start/bsp_specs (moved) * bsps/lm32/lm32_evr/start/linkcmds (moved) * bsps/lm32/milkymist/start/bsp_specs (moved) * bsps/lm32/milkymist/start/bspclean.c (moved) * bsps/lm32/milkymist/start/linkcmds (moved) * bsps/lm32/shared/start/bspreset.c (moved) * bsps/lm32/shared/start/bspstart.c (moved) * bsps/m32c/m32cbsp/start/bsp_specs (moved) * bsps/m32c/m32cbsp/start/bspstart.c (moved) * bsps/m32c/m32cbsp/start/crtn.S (moved) * bsps/m32c/m32cbsp/start/linkcmds (moved) * bsps/m68k/av5282/start/bsp_specs (moved) * bsps/m68k/av5282/start/bspstart.c (moved) * bsps/m68k/av5282/start/init5282.c (moved) * bsps/m68k/av5282/start/linkcmds (moved) * bsps/m68k/av5282/start/linkcmdsflash (moved) * bsps/m68k/av5282/start/linkcmdsram (moved) * bsps/m68k/csb360/start/bsp_specs (moved) * bsps/m68k/csb360/start/init5272.c (moved) * bsps/m68k/csb360/start/linkcmds (moved) * bsps/m68k/gen68340/start/bsp_specs (moved) * bsps/m68k/gen68340/start/dumpanic.c (moved) * bsps/m68k/gen68340/start/init68340.c (moved) * bsps/m68k/gen68340/start/linkcmds (moved) * bsps/m68k/gen68360/start/alloc360.c (moved) * bsps/m68k/gen68360/start/bsp_specs (moved) * bsps/m68k/gen68360/start/init68360.c (moved) * bsps/m68k/gen68360/start/linkcmds (moved) * bsps/m68k/gen68360/start/linkcmds.bootp (moved) * bsps/m68k/gen68360/start/linkcmds.prom (moved) * bsps/m68k/genmcf548x/start/bsp_specs (moved) * bsps/m68k/genmcf548x/start/bspstart.c (moved) * bsps/m68k/genmcf548x/start/init548x.c (moved) * bsps/m68k/genmcf548x/start/linkcmds.COBRA5475 (moved) * bsps/m68k/genmcf548x/start/linkcmds.m5484FireEngine (moved) * bsps/m68k/genmcf548x/start/linkcmds.m5484FireEngine.flash (moved) * bsps/m68k/mcf5206elite/start/bsp_specs (moved) * bsps/m68k/mcf5206elite/start/gdbinit (moved) * bsps/m68k/mcf5206elite/start/init5206e.c (moved) * bsps/m68k/mcf5206elite/start/linkcmds (moved) * bsps/m68k/mcf5206elite/start/linkcmds.flash (moved) * bsps/m68k/mcf52235/start/bsp_specs (moved) * bsps/m68k/mcf52235/start/bspgetcpuclockspeed.c (moved) * bsps/m68k/mcf52235/start/cfinit.c (moved) * bsps/m68k/mcf52235/start/init52235.c (moved) * bsps/m68k/mcf52235/start/linkcmds (moved) * bsps/m68k/mcf5225x/start/bsp_specs (moved) * bsps/m68k/mcf5225x/start/bspclean.c (moved) * bsps/m68k/mcf5225x/start/bspstart.c (moved) * bsps/m68k/mcf5225x/start/init5225x.c (moved) * bsps/m68k/mcf5225x/start/linkcmds (moved) * bsps/m68k/mcf5235/start/bsp_specs (moved) * bsps/m68k/mcf5235/start/bspgetcpuclockspeed.c (moved) * bsps/m68k/mcf5235/start/bspstart.c (moved) * bsps/m68k/mcf5235/start/copyvectors.c (moved) * bsps/m68k/mcf5235/start/init5235.c (moved) * bsps/m68k/mcf5235/start/linkcmds (moved) * bsps/m68k/mcf5235/start/linkcmdsflash (moved) * bsps/m68k/mcf5235/start/linkcmdsram (moved) * bsps/m68k/mcf5329/start/bsp_specs (moved) * bsps/m68k/mcf5329/start/bspstart.c (moved) * bsps/m68k/mcf5329/start/cfinit.c (moved) * bsps/m68k/mcf5329/start/init5329.c (moved) * bsps/m68k/mcf5329/start/linkcmds (moved) * bsps/m68k/mcf5329/start/linkcmdsflash (moved) * bsps/m68k/mrm332/start/bsp_specs (moved) * bsps/m68k/mrm332/start/linkcmds (moved) * bsps/m68k/mrm332/start/start_c.c (moved) * bsps/m68k/mvme147/start/bsp_specs (moved) * bsps/m68k/mvme147/start/bspclean.c (moved) * bsps/m68k/mvme147/start/bspstart.c (moved) * bsps/m68k/mvme147/start/linkcmds (moved) * bsps/m68k/mvme147s/start/bsp_specs (moved) * bsps/m68k/mvme147s/start/bspstart.c (moved) * bsps/m68k/mvme147s/start/linkcmds (moved) * bsps/m68k/mvme162/start/bsp_specs (moved) * bsps/m68k/mvme162/start/bspclean.c (moved) * bsps/m68k/mvme162/start/bspstart.c (moved) * bsps/m68k/mvme162/start/linkcmds (moved) * bsps/m68k/mvme162/start/page_table.c (moved) * bsps/m68k/mvme167/start/bsp_specs (moved) * bsps/m68k/mvme167/start/bspclean.c (moved) * bsps/m68k/mvme167/start/bspstart.c (moved) * bsps/m68k/mvme167/start/linkcmds (moved) * bsps/m68k/mvme167/start/page_table.c (moved) * bsps/m68k/shared/start/linkcmds.base (moved) * bsps/m68k/uC5282/start/bsp_specs (moved) * bsps/m68k/uC5282/start/bspclean.c (moved) * bsps/m68k/uC5282/start/bspreset.c (moved) * bsps/m68k/uC5282/start/bspstart.c (moved) * bsps/m68k/uC5282/start/init5282.c (moved) * bsps/m68k/uC5282/start/linkcmds (moved) * bsps/mips/csb350/start/bsp_specs (moved) * bsps/mips/csb350/start/bspreset.c (moved) * bsps/mips/csb350/start/bspstart.c (moved) * bsps/mips/csb350/start/linkcmds (moved) * bsps/mips/hurricane/start/bsp_specs (moved) * bsps/mips/hurricane/start/bspstart.c (moved) * bsps/mips/hurricane/start/ghlinkcmds (moved) * bsps/mips/hurricane/start/inittlb.c (moved) * bsps/mips/hurricane/start/linkcmds (moved) * bsps/mips/hurricane/start/usc.S (moved) * bsps/mips/jmr3904/start/bsp_specs (moved) * bsps/mips/jmr3904/start/bspstart.c (moved) * bsps/mips/jmr3904/start/linkcmds (moved) * bsps/mips/malta/start/bsp_specs (moved) * bsps/mips/malta/start/bspreset.c (moved) * bsps/mips/malta/start/bspstart.c (moved) * bsps/mips/malta/start/inittlb.c (moved) * bsps/mips/malta/start/linkcmds (moved) * bsps/mips/malta/start/simple_access.c (moved) * bsps/mips/rbtx4925/start/bsp_specs (moved) * bsps/mips/rbtx4925/start/bspstart.c (moved) * bsps/mips/rbtx4925/start/idttlb.S (moved) * bsps/mips/rbtx4925/start/inittlb.c (moved) * bsps/mips/rbtx4925/start/linkcmds (moved) * bsps/mips/rbtx4938/start/bsp_specs (moved) * bsps/mips/rbtx4938/start/bspstart.c (moved) * bsps/mips/rbtx4938/start/inittlb.c (moved) * bsps/mips/rbtx4938/start/linkcmds (moved) * bsps/mips/shared/start/idtmem.S (moved) * bsps/mips/shared/start/idttlb.S (moved) * bsps/moxie/moxiesim/start/bsp_specs (moved) * bsps/moxie/moxiesim/start/linkcmds (moved) * bsps/nios2/nios2_iss/start/bsp_specs (moved) * bsps/nios2/nios2_iss/start/bspstart.c (moved) * bsps/nios2/nios2_iss/start/linkcmds (moved) * bsps/nios2/nios2_iss/start/main.c (moved) * bsps/nios2/nios2_iss/start/setvec.c (moved) * bsps/no_cpu/no_bsp/start/bsp_specs (moved) * bsps/no_cpu/no_bsp/start/bspstart.c (moved) * bsps/no_cpu/no_bsp/start/linkcmds (moved) * bsps/no_cpu/no_bsp/start/setvec.c (moved) * bsps/or1k/generic_or1k/start/bsp_specs (moved) * bsps/or1k/generic_or1k/start/bspstart.c (moved) * bsps/or1k/generic_or1k/start/linkcmds (moved) * bsps/or1k/shared/start/linkcmds.base (moved) * bsps/powerpc/beatnik/start/bsp_specs (moved) * bsps/powerpc/beatnik/start/bspclean.c (moved) * bsps/powerpc/beatnik/start/bspreset.c (moved) * bsps/powerpc/beatnik/start/bspstart.c (moved) * bsps/powerpc/beatnik/start/i2c_init.c (moved) * bsps/powerpc/beatnik/start/linkcmds (moved) * bsps/powerpc/gen5200/start/bestcomm.c (moved) * bsps/powerpc/gen5200/start/bsp_specs (moved) * bsps/powerpc/gen5200/start/bspreset.c (moved) * bsps/powerpc/gen5200/start/bspstart.c (moved) * bsps/powerpc/gen5200/start/cpuinit.c (moved) * bsps/powerpc/gen5200/start/linkcmds.brs5l (moved) * bsps/powerpc/gen5200/start/linkcmds.brs6l (moved) * bsps/powerpc/gen5200/start/linkcmds.dp2 (moved) * bsps/powerpc/gen5200/start/linkcmds.gen5200_base (moved) * bsps/powerpc/gen5200/start/linkcmds.icecube (moved) * bsps/powerpc/gen5200/start/linkcmds.pm520_cr825 (moved) * bsps/powerpc/gen5200/start/linkcmds.pm520_ze30 (moved) * bsps/powerpc/gen5200/start/uboot_support.c (moved) * bsps/powerpc/gen83xx/start/bsp_specs (moved) * bsps/powerpc/gen83xx/start/bspreset.c (moved) * bsps/powerpc/gen83xx/start/bsprestart.c (moved) * bsps/powerpc/gen83xx/start/bspstart.c (moved) * bsps/powerpc/gen83xx/start/cpuinit.c (moved) * bsps/powerpc/gen83xx/start/linkcmds (moved) * bsps/powerpc/gen83xx/start/linkcmds.br_uid (moved) * bsps/powerpc/gen83xx/start/linkcmds.hsc_cm01 (moved) * bsps/powerpc/gen83xx/start/linkcmds.mpc8309som (moved) * bsps/powerpc/gen83xx/start/linkcmds.mpc8313erdb (moved) * bsps/powerpc/gen83xx/start/linkcmds.mpc8349eamds (moved) * bsps/powerpc/gen83xx/start/linkcmds.mpc83xx (moved) * bsps/powerpc/gen83xx/start/uboot_support.c (moved) * bsps/powerpc/haleakala/start/bsp_specs (moved) * bsps/powerpc/haleakala/start/bspstart.c (moved) * bsps/powerpc/haleakala/start/linkcmds (moved) * bsps/powerpc/motorola_powerpc/start/bsp_specs (moved) * bsps/powerpc/motorola_powerpc/start/bspreset.c (moved) * bsps/powerpc/motorola_powerpc/start/linkcmds (moved) * bsps/powerpc/mpc55xxevb/start/bsp_specs (moved) * bsps/powerpc/mpc55xxevb/start/bspgetworkarea.c (moved) * bsps/powerpc/mpc55xxevb/start/bspreset.c (moved) * bsps/powerpc/mpc55xxevb/start/bspstart.c (moved) * bsps/powerpc/mpc55xxevb/start/exc-vector-base.S (moved) * bsps/powerpc/mpc55xxevb/start/get-system-clock.c (moved) * bsps/powerpc/mpc55xxevb/start/idle-thread.c (moved) * bsps/powerpc/mpc55xxevb/start/linkcmds (moved) * bsps/powerpc/mpc55xxevb/start/linkcmds.gwlcfm (moved) * bsps/powerpc/mpc55xxevb/start/linkcmds.mpc5566evb (moved) * bsps/powerpc/mpc55xxevb/start/linkcmds.mpc5566evb_spe (moved) * bsps/powerpc/mpc55xxevb/start/linkcmds.mpc55xx (moved) * bsps/powerpc/mpc55xxevb/start/linkcmds.mpc5643l_dpu (moved) * bsps/powerpc/mpc55xxevb/start/linkcmds.mpc5643l_evb (moved) * bsps/powerpc/mpc55xxevb/start/linkcmds.mpc5668g (moved) * bsps/powerpc/mpc55xxevb/start/linkcmds.mpc5674f_ecu508 (moved) * bsps/powerpc/mpc55xxevb/start/linkcmds.mpc5674f_ecu508_app (moved) * bsps/powerpc/mpc55xxevb/start/linkcmds.mpc5674f_ecu508_boot (moved) * bsps/powerpc/mpc55xxevb/start/linkcmds.mpc5674f_rsm6 (moved) * bsps/powerpc/mpc55xxevb/start/linkcmds.mpc5674f_rsm6_base (moved) * bsps/powerpc/mpc55xxevb/start/linkcmds.mpc5674fevb (moved) * bsps/powerpc/mpc55xxevb/start/linkcmds.mpc5674fevb_spe (moved) * bsps/powerpc/mpc55xxevb/start/linkcmds.phycore_mpc5554 (moved) * bsps/powerpc/mpc55xxevb/start/restart.c (moved) * bsps/powerpc/mpc55xxevb/start/sd-card-init.c (moved) * bsps/powerpc/mpc55xxevb/start/start-cache.S (moved) * bsps/powerpc/mpc55xxevb/start/start-clock.c (moved) * bsps/powerpc/mpc55xxevb/start/start-config-clock.c (moved) * bsps/powerpc/mpc55xxevb/start/start-config-ebi-cs-cal.c (moved) * bsps/powerpc/mpc55xxevb/start/start-config-ebi-cs.c (moved) * bsps/powerpc/mpc55xxevb/start/start-config-ebi.c (moved) * bsps/powerpc/mpc55xxevb/start/start-config-mmu-early.c (moved) * bsps/powerpc/mpc55xxevb/start/start-config-mmu.c (moved) * bsps/powerpc/mpc55xxevb/start/start-config-siu-pcr.c (moved) * bsps/powerpc/mpc55xxevb/start/start-early.c (moved) * bsps/powerpc/mpc55xxevb/start/start-flash.S (moved) * bsps/powerpc/mpc55xxevb/start/start-prologue.c (moved) * bsps/powerpc/mpc55xxevb/start/start-watchdog.c (moved) * bsps/powerpc/mpc8260ads/start/bsp_specs (moved) * bsps/powerpc/mpc8260ads/start/bspstart.c (moved) * bsps/powerpc/mpc8260ads/start/cpuinit.c (moved) * bsps/powerpc/mpc8260ads/start/linkcmds (moved) * bsps/powerpc/mvme3100/start/bsp_specs (moved) * bsps/powerpc/mvme3100/start/bspstart.c (moved) * bsps/powerpc/mvme3100/start/linkcmds (moved) * bsps/powerpc/mvme3100/start/misc.c (moved) * bsps/powerpc/mvme5500/start/bootpstuff.c (moved) * bsps/powerpc/mvme5500/start/bsp_specs (moved) * bsps/powerpc/mvme5500/start/bspclean.c (moved) * bsps/powerpc/mvme5500/start/bspreset.c (moved) * bsps/powerpc/mvme5500/start/bspstart.c (moved) * bsps/powerpc/mvme5500/start/linkcmds (moved) * bsps/powerpc/mvme5500/start/pgtbl_activate.c (moved) * bsps/powerpc/psim/start/bsp_specs (moved) * bsps/powerpc/psim/start/bspstart.c (moved) * bsps/powerpc/psim/start/device-tree (moved) * bsps/powerpc/psim/start/linkcmds (moved) * bsps/powerpc/qemuppc/start/bsp_specs (moved) * bsps/powerpc/qemuppc/start/bspstart.c (moved) * bsps/powerpc/qemuppc/start/cmain.c (moved) * bsps/powerpc/qemuppc/start/linkcmds (moved) * bsps/powerpc/qoriq/start/bsp_specs (moved) * bsps/powerpc/qoriq/start/bspreset.c (moved) * bsps/powerpc/qoriq/start/bsprestart.c (moved) * bsps/powerpc/qoriq/start/bspsmp.c (moved) * bsps/powerpc/qoriq/start/bspstart.c (moved) * bsps/powerpc/qoriq/start/epapr_hcalls.S (moved) * bsps/powerpc/qoriq/start/l1cache.S (moved) * bsps/powerpc/qoriq/start/l2cache.S (moved) * bsps/powerpc/qoriq/start/linkcmds.qoriq_core_0 (moved) * bsps/powerpc/qoriq/start/linkcmds.qoriq_core_1 (moved) * bsps/powerpc/qoriq/start/linkcmds.qoriq_e500 (moved) * bsps/powerpc/qoriq/start/linkcmds.qoriq_e6500_32 (moved) * bsps/powerpc/qoriq/start/linkcmds.qoriq_e6500_64 (moved) * bsps/powerpc/qoriq/start/mmu-config.c (moved) * bsps/powerpc/qoriq/start/mmu-tlb1.S (moved) * bsps/powerpc/qoriq/start/mmu.c (moved) * bsps/powerpc/qoriq/start/portal.c (moved) * bsps/powerpc/qoriq/start/restart.S (moved) * bsps/powerpc/shared/start/bspgetworkarea.c (moved) * bsps/powerpc/shared/start/bspidle.c (moved) * bsps/powerpc/shared/start/linkcmds.base (moved) * bsps/powerpc/shared/start/linkcmds.share (moved) * bsps/powerpc/shared/start/pgtbl_activate.c (moved) * bsps/powerpc/shared/start/pgtbl_setup.c (moved) * bsps/powerpc/shared/start/ppc_idle.c (moved) * bsps/powerpc/shared/start/probeMemEnd.c (moved) * bsps/powerpc/shared/start/sbrk.c (moved) * bsps/powerpc/shared/start/zerobss.c (moved) * bsps/powerpc/ss555/start/bsp_specs (moved) * bsps/powerpc/ss555/start/bspstart.c (moved) * bsps/powerpc/ss555/start/iss555.c (moved) * bsps/powerpc/ss555/start/linkcmds (moved) * bsps/powerpc/ss555/start/tm27supp.c (moved) * bsps/powerpc/t32mppc/start/bsp_specs (moved) * bsps/powerpc/t32mppc/start/bspreset.c (moved) * bsps/powerpc/t32mppc/start/bspstart.c (moved) * bsps/powerpc/t32mppc/start/linkcmds.t32mppc (moved) * bsps/powerpc/tqm8xx/start/bsp_specs (moved) * bsps/powerpc/tqm8xx/start/bspgetworkarea.c (moved) * bsps/powerpc/tqm8xx/start/bspstart.c (moved) * bsps/powerpc/tqm8xx/start/cpuinit.c (moved) * bsps/powerpc/tqm8xx/start/linkcmds (moved) * bsps/powerpc/tqm8xx/start/mmutlbtab.c (moved) * bsps/powerpc/virtex/start/bsp_specs (moved) * bsps/powerpc/virtex/start/bspstart.c (moved) * bsps/powerpc/virtex/start/linkcmds.in (moved) * bsps/powerpc/virtex4/start/bsp_specs (moved) * bsps/powerpc/virtex4/start/bspclean.c (moved) * bsps/powerpc/virtex4/start/bspstart.c (moved) * bsps/powerpc/virtex4/start/dummy_console.c (moved) * bsps/powerpc/virtex4/start/linkcmds (moved) * bsps/powerpc/virtex5/start/bsp_specs (moved) * bsps/powerpc/virtex5/start/bspclean.c (moved) * bsps/powerpc/virtex5/start/bspstart.c (moved) * bsps/powerpc/virtex5/start/dummy_console.c (moved) * bsps/powerpc/virtex5/start/linkcmds (moved) * bsps/riscv/riscv_generic/start/bsp_fatal_halt.c (moved) * bsps/riscv/riscv_generic/start/bsp_specs (moved) * bsps/riscv/riscv_generic/start/linkcmds (moved) * bsps/sh/gensh1/start/bsp_specs (moved) * bsps/sh/gensh1/start/cpu_asm.c (moved) * bsps/sh/gensh1/start/ispsh7032.c (moved) * bsps/sh/gensh1/start/linkcmds (moved) * bsps/sh/gensh2/start/bsp_specs (moved) * bsps/sh/gensh2/start/cpu_asm.c (moved) * bsps/sh/gensh2/start/hw_init.c (moved) * bsps/sh/gensh2/start/ispsh7045.c (moved) * bsps/sh/gensh2/start/linkcmds (moved) * bsps/sh/gensh2/start/linkcmds.ram (moved) * bsps/sh/gensh2/start/linkcmds.rom (moved) * bsps/sh/gensh4/start/bsp_specs (moved) * bsps/sh/gensh4/start/cpu_asm.c (moved) * bsps/sh/gensh4/start/ispsh7750.c (moved) * bsps/sh/gensh4/start/linkcmds (moved) * bsps/sh/gensh4/start/linkcmds.rom (moved) * bsps/sh/gensh4/start/linkcmds.rom2ram (moved) * bsps/sh/shared/start/bspstart.c (moved) * bsps/sh/shsim/start/bsp_specs (moved) * bsps/sh/shsim/start/cpu_asm.c (moved) * bsps/sh/shsim/start/ispshgdb.c (moved) * bsps/sh/shsim/start/linkcmds (moved) * bsps/sh/shsim/start/sysexit.c (moved) * bsps/sparc/erc32/start/boardinit.S (moved) * bsps/sparc/erc32/start/bsp_specs (moved) * bsps/sparc/erc32/start/bspdelay.c (moved) * bsps/sparc/erc32/start/bspidle.c (moved) * bsps/sparc/erc32/start/erc32mec.c (moved) * bsps/sparc/erc32/start/linkcmds (moved) * bsps/sparc/erc32/start/setvec.c (moved) * bsps/sparc/erc32/start/spurious.c (moved) * bsps/sparc/leon2/start/bsp_specs (moved) * bsps/sparc/leon2/start/bspdelay.c (moved) * bsps/sparc/leon2/start/bspidle.c (moved) * bsps/sparc/leon2/start/bspstart.c (moved) * bsps/sparc/leon2/start/linkcmds (moved) * bsps/sparc/leon2/start/linkcmds.at697f (moved) * bsps/sparc/leon2/start/linkcmds.leon2 (moved) * bsps/sparc/leon2/start/setvec.c (moved) * bsps/sparc/leon2/start/spurious.c (moved) * bsps/sparc/leon3/start/bsp_fatal_halt.c (moved) * bsps/sparc/leon3/start/bsp_specs (moved) * bsps/sparc/leon3/start/bspclean.c (moved) * bsps/sparc/leon3/start/bspdelay.c (moved) * bsps/sparc/leon3/start/bspidle.S (moved) * bsps/sparc/leon3/start/bspsmp.c (moved) * bsps/sparc/leon3/start/bspstart.c (moved) * bsps/sparc/leon3/start/cpucounter.c (moved) * bsps/sparc/leon3/start/eirq.c (moved) * bsps/sparc/leon3/start/linkcmds.gr712rc (moved) * bsps/sparc/leon3/start/linkcmds.gr740 (moved) * bsps/sparc/leon3/start/linkcmds.leon3 (moved) * bsps/sparc/leon3/start/linkcmds.ut699 (moved) * bsps/sparc/leon3/start/linkcmds.ut700 (moved) * bsps/sparc/leon3/start/setvec.c (moved) * bsps/sparc/leon3/start/spurious.c (moved) * bsps/sparc/shared/start/bsp_fatal_exit.c (moved) * bsps/sparc/shared/start/bsp_fatal_halt.c (moved) * bsps/sparc/shared/start/bspgetworkarea.c (moved) * bsps/sparc/shared/start/linkcmds.base (moved) * bsps/sparc64/niagara/start/bsp_specs (moved) * bsps/sparc64/niagara/start/bspclean.c (moved) * bsps/sparc64/niagara/start/m5op.h (moved) * bsps/sparc64/niagara/start/m5op_sparc.S (moved) * bsps/sparc64/niagara/start/m5ops.h (moved) * bsps/sparc64/shared/start/linkcmds (moved) * bsps/sparc64/shared/start/setvec.c (moved) * bsps/sparc64/usiii/start/bsp_specs (moved) * bsps/v850/gdbv850sim/start/bsp_specs (moved) * bsps/v850/gdbv850sim/start/bspreset.c (moved) * bsps/v850/gdbv850sim/start/linkcmds (moved) * bsps/v850/gdbv850sim/start/trap.S (moved) * c/src/aclocal/bsp-linkcmds.m4 (modified) * c/src/aclocal/prog-cc.m4 (modified) * c/src/lib/libbsp/arm/Makefile.am (modified) * c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am (modified) * c/src/lib/libbsp/arm/atsam/Makefile.am (modified) * c/src/lib/libbsp/arm/atsam/configure.ac (modified) * c/src/lib/libbsp/arm/beagle/Makefile.am (modified) * c/src/lib/libbsp/arm/csb336/Makefile.am (modified) * c/src/lib/libbsp/arm/csb337/Makefile.am (modified) * c/src/lib/libbsp/arm/edb7312/Makefile.am (modified) * c/src/lib/libbsp/arm/gdbarmsim/Makefile.am (modified) * c/src/lib/libbsp/arm/gumstix/Makefile.am (modified) * c/src/lib/libbsp/arm/imx/Makefile.am (modified) * c/src/lib/libbsp/arm/lm3s69xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc176x/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc24xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc32xx/Makefile.am (modified) * c/src/lib/libbsp/arm/raspberrypi/Makefile.am (modified) * c/src/lib/libbsp/arm/raspberrypi/configure.ac (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am (modified) * c/src/lib/libbsp/arm/rtl22xx/Makefile.am (modified) * c/src/lib/libbsp/arm/smdk2410/Makefile.am (modified) * c/src/lib/libbsp/arm/stm32f4/Makefile.am (modified) * c/src/lib/libbsp/arm/tms570/Makefile.am (modified) * c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am (modified) * c/src/lib/libbsp/arm/xilinx-zynq/configure.ac (modified) * c/src/lib/libbsp/bfin/TLL6527M/Makefile.am (modified) * c/src/lib/libbsp/bfin/bf537Stamp/Makefile.am (modified) * c/src/lib/libbsp/bfin/eZKit533/Makefile.am (modified) * c/src/lib/libbsp/epiphany/epiphany_sim/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/lm32/lm32_evr/Makefile.am (modified) * c/src/lib/libbsp/lm32/milkymist/Makefile.am (modified) * c/src/lib/libbsp/m32c/m32cbsp/Makefile.am (modified) * c/src/lib/libbsp/m68k/Makefile.am (modified) * c/src/lib/libbsp/m68k/av5282/Makefile.am (modified) * c/src/lib/libbsp/m68k/csb360/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/Makefile.am (modified) * c/src/lib/libbsp/m68k/genmcf548x/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5206elite/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf52235/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5225x/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5235/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5329/Makefile.am (modified) * c/src/lib/libbsp/m68k/mrm332/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/Makefile.am (modified) * c/src/lib/libbsp/m68k/uC5282/Makefile.am (modified) * c/src/lib/libbsp/mips/csb350/Makefile.am (modified) * c/src/lib/libbsp/mips/hurricane/Makefile.am (modified) * c/src/lib/libbsp/mips/jmr3904/Makefile.am (modified) * c/src/lib/libbsp/mips/malta/Makefile.am (modified) * c/src/lib/libbsp/mips/rbtx4925/Makefile.am (modified) * c/src/lib/libbsp/mips/rbtx4938/Makefile.am (modified) * c/src/lib/libbsp/moxie/moxiesim/Makefile.am (modified) * c/src/lib/libbsp/nios2/nios2_iss/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/Makefile.am (modified) * c/src/lib/libbsp/or1k/generic_or1k/Makefile.am (modified) * c/src/lib/libbsp/powerpc/beatnik/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen5200/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen83xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/haleakala/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme3100/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme5500/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qemuppc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qoriq/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ss555/Makefile.am (modified) * c/src/lib/libbsp/powerpc/t32mppc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/tqm8xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex/configure.ac (modified) * c/src/lib/libbsp/powerpc/virtex4/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex5/Makefile.am (modified) * c/src/lib/libbsp/riscv/riscv_generic/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh4/Makefile.am (modified) * c/src/lib/libbsp/sh/shsim/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/lib/libbsp/sparc64/niagara/Makefile.am (modified) * c/src/lib/libbsp/sparc64/usiii/Makefile.am (modified) * c/src/lib/libbsp/v850/gdbv850sim/Makefile.am (modified) * testsuites/aclocal/prog-cc.m4 (modified) * testsuites/aclocal/rtems-bsp-linkcmds.m4 (modified) bsps: Move startup files to bsps Adjust build support files to new ...
