# # ChangeLog for bsps/powerpc/beatnik/config in rtems # # Generated by Trac 1.2.1.dev0 # 04/25/24 06:12:56 Fri, 15 Jun 2018 06:07:17 GMT Sebastian Huber [1f283f17] * bsps/powerpc/beatnik/config/beatnik.cfg (modified) bsp/beatnik: Remove CFLAGS_DEBUG_V This was the only BSP setting ... Wed, 16 May 2018 14:43:24 GMT Joel Sherrill [b1b5afba] * bsps/powerpc/beatnik/config/beatnik.cfg (modified) * c/src/lib/libbsp/powerpc/beatnik/configure.ac (modified) beatnik: Move -Dxxx to configure.ac Updates #3425. Sat, 21 Apr 2018 08:22:08 GMT Sebastian Huber [adb85dd] * aclocal/bsp-alias.m4 (modified) * aclocal/check-bsps.m4 (modified) * aclocal/check-custom-bsp.m4 (modified) * aclocal/enable-rtemsbsp.m4 (modified) * bootstrap (modified) * bsps/arm/altera-cyclone-v/config/altcycv.inc (moved) * bsps/arm/altera-cyclone-v/config/altcycv_devkit.cfg (moved) * bsps/arm/altera-cyclone-v/config/altcycv_devkit_smp.cfg (moved) * bsps/arm/atsam/config/atsamv-testsuite.tcfg (moved) * bsps/arm/atsam/config/atsamv.cfg (moved) * bsps/arm/beagle/config/beagle.inc (moved) * bsps/arm/beagle/config/beagleboardorig.cfg (moved) * bsps/arm/beagle/config/beagleboardxm.cfg (moved) * bsps/arm/beagle/config/beagleboneblack.cfg (moved) * bsps/arm/beagle/config/beaglebonewhite.cfg (moved) * bsps/arm/csb336/config/csb336.cfg (moved) * bsps/arm/csb337/config/csb337.cfg (moved) * bsps/arm/csb337/config/csb637.cfg (moved) * bsps/arm/csb337/config/kit637_v6.cfg (moved) * bsps/arm/edb7312/config/edb7312.cfg (moved) * bsps/arm/gdbarmsim/config/arm1136jfs-testsuite.tcfg (moved) * bsps/arm/gdbarmsim/config/arm1136jfs.cfg (moved) * bsps/arm/gdbarmsim/config/arm1136js-testsuite.tcfg (moved) * bsps/arm/gdbarmsim/config/arm1136js.cfg (moved) * bsps/arm/gdbarmsim/config/arm7tdmi-testsuite.tcfg (moved) * bsps/arm/gdbarmsim/config/arm7tdmi.cfg (moved) * bsps/arm/gdbarmsim/config/arm920-testsuite.tcfg (moved) * bsps/arm/gdbarmsim/config/arm920.cfg (moved) * bsps/arm/gdbarmsim/config/armcortexa9-testsuite.tcfg (moved) * bsps/arm/gdbarmsim/config/armcortexa9.cfg (moved) * bsps/arm/gumstix/config/gumstix.cfg (moved) * bsps/arm/imx/config/imx7.cfg (moved) * bsps/arm/lm3s69xx/config/lm3s3749-testsuite.tcfg (moved) * bsps/arm/lm3s69xx/config/lm3s3749.cfg (moved) * bsps/arm/lm3s69xx/config/lm3s6965-testsuite.tcfg (moved) * bsps/arm/lm3s69xx/config/lm3s6965.cfg (moved) * bsps/arm/lm3s69xx/config/lm3s6965_qemu.cfg (moved) * bsps/arm/lm3s69xx/config/lm3s69xx.inc (moved) * bsps/arm/lm3s69xx/config/lm4f120-testsuite.tcfg (moved) * bsps/arm/lm3s69xx/config/lm4f120.cfg (moved) * bsps/arm/lpc176x/config/lpc1768_mbed-testsuite.tcfg (moved) * bsps/arm/lpc176x/config/lpc1768_mbed.cfg (moved) * bsps/arm/lpc176x/config/lpc1768_mbed_ahb_ram-testsuite.tcfg (moved) * bsps/arm/lpc176x/config/lpc1768_mbed_ahb_ram.cfg (moved) * bsps/arm/lpc176x/config/lpc1768_mbed_ahb_ram_eth-testsuite.tcfg (moved) * bsps/arm/lpc176x/config/lpc1768_mbed_ahb_ram_eth.cfg (moved) * bsps/arm/lpc24xx/config/lpc17xx.inc (moved) * bsps/arm/lpc24xx/config/lpc17xx_ea_ram.cfg (moved) * bsps/arm/lpc24xx/config/lpc17xx_ea_rom_int-testsuite.tcfg (moved) * bsps/arm/lpc24xx/config/lpc17xx_ea_rom_int.cfg (moved) * bsps/arm/lpc24xx/config/lpc17xx_plx800_ram.cfg (moved) * bsps/arm/lpc24xx/config/lpc17xx_plx800_rom_int-testsuite.tcfg (moved) * bsps/arm/lpc24xx/config/lpc17xx_plx800_rom_int.cfg (moved) * bsps/arm/lpc24xx/config/lpc2362-testsuite.tcfg (moved) * bsps/arm/lpc24xx/config/lpc2362.cfg (moved) * bsps/arm/lpc24xx/config/lpc23xx_tli800-testsuite.tcfg (moved) * bsps/arm/lpc24xx/config/lpc23xx_tli800.cfg (moved) * bsps/arm/lpc24xx/config/lpc24xx.inc (moved) * bsps/arm/lpc24xx/config/lpc24xx_ea.cfg (moved) * bsps/arm/lpc24xx/config/lpc24xx_ncs_ram.cfg (moved) * bsps/arm/lpc24xx/config/lpc24xx_ncs_rom_ext.cfg (moved) * bsps/arm/lpc24xx/config/lpc24xx_ncs_rom_int-testsuite.tcfg (moved) * bsps/arm/lpc24xx/config/lpc24xx_ncs_rom_int.cfg (moved) * bsps/arm/lpc24xx/config/lpc24xx_plx800_ram.cfg (moved) * bsps/arm/lpc24xx/config/lpc24xx_plx800_rom_int-testsuite.tcfg (moved) * bsps/arm/lpc24xx/config/lpc24xx_plx800_rom_int.cfg (moved) * bsps/arm/lpc24xx/config/lpc40xx.inc (moved) * bsps/arm/lpc24xx/config/lpc40xx_ea_ram.cfg (moved) * bsps/arm/lpc24xx/config/lpc40xx_ea_rom_int-testsuite.tcfg (moved) * bsps/arm/lpc24xx/config/lpc40xx_ea_rom_int.cfg (moved) * bsps/arm/lpc32xx/config/lpc32xx.inc (moved) * bsps/arm/lpc32xx/config/lpc32xx_mzx.cfg (moved) * bsps/arm/lpc32xx/config/lpc32xx_mzx_stage_1-testsuite.tcfg (moved) * bsps/arm/lpc32xx/config/lpc32xx_mzx_stage_1.cfg (moved) * bsps/arm/lpc32xx/config/lpc32xx_mzx_stage_2.cfg (moved) * bsps/arm/lpc32xx/config/lpc32xx_phycore.cfg (moved) * bsps/arm/raspberrypi/config/raspberrypi.cfg (moved) * bsps/arm/raspberrypi/config/raspberrypi.inc (moved) * bsps/arm/raspberrypi/config/raspberrypi2.cfg (moved) * bsps/arm/realview-pbx-a9/config/realview_pbx_a9_qemu.cfg (moved) * bsps/arm/realview-pbx-a9/config/realview_pbx_a9_qemu_smp.cfg (moved) * bsps/arm/rtl22xx/config/rtl22xx-testsuite.tcfg (moved) * bsps/arm/rtl22xx/config/rtl22xx.cfg (moved) * bsps/arm/rtl22xx/config/rtl22xx_t-testsuite.tcfg (moved) * bsps/arm/rtl22xx/config/rtl22xx_t.cfg (moved) * bsps/arm/smdk2410/config/smdk2410.cfg (moved) * bsps/arm/stm32f4/config/stm32f105rc-testsuite.tcfg (moved) * bsps/arm/stm32f4/config/stm32f105rc.cfg (moved) * bsps/arm/stm32f4/config/stm32f4-testsuite.tcfg (moved) * bsps/arm/stm32f4/config/stm32f4.cfg (moved) * bsps/arm/tms570/config/tms570ls3137.inc (moved) * bsps/arm/tms570/config/tms570ls3137_hdk-testsuite.tcfg (moved) * bsps/arm/tms570/config/tms570ls3137_hdk.cfg (moved) * bsps/arm/tms570/config/tms570ls3137_hdk_intram-testsuite.tcfg (moved) * bsps/arm/tms570/config/tms570ls3137_hdk_intram.cfg (moved) * bsps/arm/tms570/config/tms570ls3137_hdk_sdram.cfg (moved) * bsps/arm/tms570/config/tms570ls3137_hdk_with_loader-testsuite.tcfg (moved) * bsps/arm/tms570/config/tms570ls3137_hdk_with_loader.cfg (moved) * bsps/arm/xilinx-zynq/config/xilinx_zynq.inc (moved) * bsps/arm/xilinx-zynq/config/xilinx_zynq_a9_qemu.cfg (moved) * bsps/arm/xilinx-zynq/config/xilinx_zynq_zc702.cfg (moved) * bsps/arm/xilinx-zynq/config/xilinx_zynq_zc706.cfg (moved) * bsps/arm/xilinx-zynq/config/xilinx_zynq_zedboard.cfg (moved) * bsps/bfin/TLL6527M/config/TLL6527M.cfg (moved) * bsps/bfin/bf537Stamp/config/bf537Stamp.cfg (moved) * bsps/bfin/eZKit533/config/eZKit533.cfg (moved) * bsps/epiphany/epiphany_sim/config/epiphany_sim.cfg (moved) * bsps/i386/pc386/config/pc386.cfg (moved) * bsps/i386/pc386/config/pc486.cfg (moved) * bsps/i386/pc386/config/pc586-sse.cfg (moved) * bsps/i386/pc386/config/pc586.cfg (moved) * bsps/i386/pc386/config/pc686.cfg (moved) * bsps/i386/pc386/config/pcp4.cfg (moved) * bsps/lm32/lm32_evr/config/lm32_evr.cfg (moved) * bsps/lm32/lm32_evr/config/lm32_evr_gdbsim-testsuite.tcfg (moved) * bsps/lm32/lm32_evr/config/lm32_evr_gdbsim.cfg (moved) * bsps/lm32/milkymist/config/milkymist.cfg (moved) * bsps/m32c/m32cbsp/config/m32csim-testsuite.tcfg (moved) * bsps/m32c/m32cbsp/config/m32csim.cfg (moved) * bsps/m68k/av5282/config/av5282.cfg (moved) * bsps/m68k/csb360/config/csb360.cfg (moved) * bsps/m68k/gen68340/config/gen68340.cfg (moved) * bsps/m68k/gen68360/config/gen68360.cfg (moved) * bsps/m68k/gen68360/config/gen68360_040.cfg (moved) * bsps/m68k/gen68360/config/pgh360.cfg (moved) * bsps/m68k/genmcf548x/config/COBRA5475.cfg (moved) * bsps/m68k/genmcf548x/config/genmcf548x.inc (moved) * bsps/m68k/genmcf548x/config/m5484FireEngine.cfg (moved) * bsps/m68k/mcf5206elite/config/mcf5206elite-testsuite.tcfg (moved) * bsps/m68k/mcf5206elite/config/mcf5206elite.cfg (moved) * bsps/m68k/mcf52235/config/mcf52235-testsuite.tcfg (moved) * bsps/m68k/mcf52235/config/mcf52235.cfg (moved) * bsps/m68k/mcf5225x/config/mcf5225x-testsuite.tcfg (moved) * bsps/m68k/mcf5225x/config/mcf5225x.cfg (moved) * bsps/m68k/mcf5235/config/mcf5235.cfg (moved) * bsps/m68k/mcf5329/config/mcf5329.cfg (moved) * bsps/m68k/mrm332/config/mrm332-testsuite.tcfg (moved) * bsps/m68k/mrm332/config/mrm332.cfg (moved) * bsps/m68k/mvme147/config/mvme147.cfg (moved) * bsps/m68k/mvme147s/config/mvme147s.cfg (moved) * bsps/m68k/mvme162/config/mvme162-testsuite.tcfg (moved) * bsps/m68k/mvme162/config/mvme162.cfg (moved) * bsps/m68k/mvme162/config/mvme162lx-testsuite.tcfg (moved) * bsps/m68k/mvme162/config/mvme162lx.cfg (moved) * bsps/m68k/mvme167/config/mvme167.cfg (moved) * bsps/m68k/uC5282/config/uC5282.cfg (moved) * bsps/mips/csb350/config/csb350.cfg (moved) * bsps/mips/hurricane/config/hurricane-testsuite.tcfg (moved) * bsps/mips/hurricane/config/hurricane.cfg (moved) * bsps/mips/jmr3904/config/jmr3904-testsuite.tcfg (moved) * bsps/mips/jmr3904/config/jmr3904.cfg (moved) * bsps/mips/malta/config/malta.cfg (moved) * bsps/mips/rbtx4925/config/rbtx4925-testsuite.tcfg (moved) * bsps/mips/rbtx4925/config/rbtx4925.cfg (moved) * bsps/mips/rbtx4938/config/rbtx4938-testsuite.tcfg (moved) * bsps/mips/rbtx4938/config/rbtx4938.cfg (moved) * bsps/moxie/moxiesim/config/moxiesim-testsuite.tcfg (moved) * bsps/moxie/moxiesim/config/moxiesim.cfg (moved) * bsps/nios2/nios2_iss/config/nios2_iss.cfg (moved) * bsps/no_cpu/no_bsp/config/no_bsp.cfg (moved) * bsps/or1k/generic_or1k/config/generic_or1k-testsuite.tcfg (moved) * bsps/or1k/generic_or1k/config/generic_or1k.cfg (moved) * bsps/powerpc/beatnik/config/beatnik.cfg (moved) * bsps/powerpc/gen5200/config/brs5l.cfg (moved) * bsps/powerpc/gen5200/config/brs6l.cfg (moved) * bsps/powerpc/gen5200/config/dp2.cfg (moved) * bsps/powerpc/gen5200/config/gen5200.inc (moved) * bsps/powerpc/gen5200/config/icecube.cfg (moved) * bsps/powerpc/gen5200/config/pm520_cr825.cfg (moved) * bsps/powerpc/gen5200/config/pm520_ze30.cfg (moved) * bsps/powerpc/gen83xx/config/br_uid.cfg (moved) * bsps/powerpc/gen83xx/config/gen83xx.inc (moved) * bsps/powerpc/gen83xx/config/hsc_cm01.cfg (moved) * bsps/powerpc/gen83xx/config/mpc8309som.cfg (moved) * bsps/powerpc/gen83xx/config/mpc8313erdb.cfg (moved) * bsps/powerpc/gen83xx/config/mpc8349eamds.cfg (moved) * bsps/powerpc/haleakala/config/haleakala.cfg (moved) * bsps/powerpc/motorola_powerpc/config/mcp750.cfg (moved) * bsps/powerpc/motorola_powerpc/config/mtx603e.cfg (moved) * bsps/powerpc/motorola_powerpc/config/mvme2100.cfg (moved) * bsps/powerpc/motorola_powerpc/config/mvme2307.cfg (moved) * bsps/powerpc/motorola_powerpc/config/qemuprep-altivec.cfg (moved) * bsps/powerpc/motorola_powerpc/config/qemuprep.cfg (moved) * bsps/powerpc/mpc55xxevb/config/gwlcfm-testsuite.tcfg (moved) * bsps/powerpc/mpc55xxevb/config/gwlcfm.cfg (moved) * bsps/powerpc/mpc55xxevb/config/mpc5566evb-testsuite.tcfg (moved) * bsps/powerpc/mpc55xxevb/config/mpc5566evb.cfg (moved) * bsps/powerpc/mpc55xxevb/config/mpc5566evb_spe-testsuite.tcfg (moved) * bsps/powerpc/mpc55xxevb/config/mpc5566evb_spe.cfg (moved) * bsps/powerpc/mpc55xxevb/config/mpc55xx.inc (moved) * bsps/powerpc/mpc55xxevb/config/mpc55xx_spe.inc (moved) * bsps/powerpc/mpc55xxevb/config/mpc5643l_dpu-testsuite.tcfg (moved) * bsps/powerpc/mpc55xxevb/config/mpc5643l_dpu.cfg (moved) * bsps/powerpc/mpc55xxevb/config/mpc5643l_evb-testsuite.tcfg (moved) * bsps/powerpc/mpc55xxevb/config/mpc5643l_evb.cfg (moved) * bsps/powerpc/mpc55xxevb/config/mpc5668g-testsuite.tcfg (moved) * bsps/powerpc/mpc55xxevb/config/mpc5668g.cfg (moved) * bsps/powerpc/mpc55xxevb/config/mpc5674f_ecu508_app-testsuite.tcfg (moved) * bsps/powerpc/mpc55xxevb/config/mpc5674f_ecu508_app.cfg (moved) * bsps/powerpc/mpc55xxevb/config/mpc5674f_ecu508_boot-testsuite.tcfg (moved) * bsps/powerpc/mpc55xxevb/config/mpc5674f_ecu508_boot.cfg (moved) * bsps/powerpc/mpc55xxevb/config/mpc5674f_rsm6-testsuite.tcfg (moved) * bsps/powerpc/mpc55xxevb/config/mpc5674f_rsm6.cfg (moved) * bsps/powerpc/mpc55xxevb/config/mpc5674fevb-testsuite.tcfg (moved) * bsps/powerpc/mpc55xxevb/config/mpc5674fevb.cfg (moved) * bsps/powerpc/mpc55xxevb/config/mpc5674fevb_spe-testsuite.tcfg (moved) * bsps/powerpc/mpc55xxevb/config/mpc5674fevb_spe.cfg (moved) * bsps/powerpc/mpc55xxevb/config/phycore_mpc5554-testsuite.tcfg (moved) * bsps/powerpc/mpc55xxevb/config/phycore_mpc5554.cfg (moved) * bsps/powerpc/mpc8260ads/config/mpc8260ads.cfg (moved) * bsps/powerpc/mvme3100/config/mvme3100.cfg (moved) * bsps/powerpc/mvme5500/config/mvme5500.cfg (moved) * bsps/powerpc/psim/config/psim.cfg (moved) * bsps/powerpc/qemuppc/config/qemuppc.cfg (moved) * bsps/powerpc/qoriq/config/qoriq.inc (moved) * bsps/powerpc/qoriq/config/qoriq_core_0-testsuite.tcfg (moved) * bsps/powerpc/qoriq/config/qoriq_core_0.cfg (moved) * bsps/powerpc/qoriq/config/qoriq_core_1-testsuite.tcfg (moved) * bsps/powerpc/qoriq/config/qoriq_core_1.cfg (moved) * bsps/powerpc/qoriq/config/qoriq_e500-testsuite.tcfg (moved) * bsps/powerpc/qoriq/config/qoriq_e500.cfg (moved) * bsps/powerpc/qoriq/config/qoriq_e6500_32-testsuite.tcfg (moved) * bsps/powerpc/qoriq/config/qoriq_e6500_32.cfg (moved) * bsps/powerpc/qoriq/config/qoriq_e6500_64-testsuite.tcfg (moved) * bsps/powerpc/qoriq/config/qoriq_e6500_64.cfg (moved) * bsps/powerpc/ss555/config/ss555.cfg (moved) * bsps/powerpc/t32mppc/config/t32mppc.cfg (moved) * bsps/powerpc/tqm8xx/config/pghplus.cfg (moved) * bsps/powerpc/tqm8xx/config/tqm8xx.inc (moved) * bsps/powerpc/tqm8xx/config/tqm8xx_stk8xx.cfg (moved) * bsps/powerpc/virtex/config/virtex.cfg (moved) * bsps/powerpc/virtex4/config/virtex4.cfg (moved) * bsps/powerpc/virtex5/config/virtex5.cfg (moved) * bsps/riscv/riscv_generic/config/riscv64_generic.cfg (moved) * bsps/riscv/riscv_generic/config/riscv_generic.cfg (moved) * bsps/sh/gensh1/config/gensh1-testsuite.tcfg (moved) * bsps/sh/gensh1/config/gensh1.cfg (moved) * bsps/sh/gensh2/config/gensh2-testsuite.tcfg (moved) * bsps/sh/gensh2/config/gensh2.cfg (moved) * bsps/sh/gensh4/config/gensh4.cfg (moved) * bsps/sh/shsim/config/simsh1-testsuite.tcfg (moved) * bsps/sh/shsim/config/simsh1.cfg (moved) * bsps/sh/shsim/config/simsh2-testsuite.tcfg (moved) * bsps/sh/shsim/config/simsh2.cfg (moved) * bsps/sh/shsim/config/simsh2e-testsuite.tcfg (moved) * bsps/sh/shsim/config/simsh2e.cfg (moved) * bsps/sh/shsim/config/simsh4-testsuite.tcfg (moved) * bsps/sh/shsim/config/simsh4.cfg (moved) * bsps/sparc/erc32/config/erc32.cfg (moved) * bsps/sparc/leon2/config/at697f.cfg (moved) * bsps/sparc/leon2/config/leon2.cfg (moved) * bsps/sparc/leon3/config/gr712rc.cfg (moved) * bsps/sparc/leon3/config/gr740.cfg (moved) * bsps/sparc/leon3/config/leon3.cfg (moved) * bsps/sparc/leon3/config/ut699.cfg (moved) * bsps/sparc/leon3/config/ut700.cfg (moved) * bsps/sparc64/niagara/config/niagara.cfg (moved) * bsps/sparc64/usiii/config/usiii.cfg (moved) * bsps/v850/gdbv850sim/config/v850e1sim-testsuite.tcfg (moved) * bsps/v850/gdbv850sim/config/v850e1sim.cfg (moved) * bsps/v850/gdbv850sim/config/v850e2sim-testsuite.tcfg (moved) * bsps/v850/gdbv850sim/config/v850e2sim.cfg (moved) * bsps/v850/gdbv850sim/config/v850e2v3sim-testsuite.tcfg (moved) * bsps/v850/gdbv850sim/config/v850e2v3sim.cfg (moved) * bsps/v850/gdbv850sim/config/v850esim-testsuite.tcfg (moved) * bsps/v850/gdbv850sim/config/v850esim.cfg (moved) * bsps/v850/gdbv850sim/config/v850essim-testsuite.tcfg (moved) * bsps/v850/gdbv850sim/config/v850essim.cfg (moved) * bsps/v850/gdbv850sim/config/v850sim-testsuite.tcfg (moved) * bsps/v850/gdbv850sim/config/v850sim.cfg (moved) * bsps/v850/gdbv850sim/config/v850sim.inc (moved) * c/configure.ac (modified) * c/src/aclocal/bsp-alias.m4 (modified) * c/src/aclocal/check-custom-bsp.m4 (modified) * rtems-bsps (modified) * testsuites/aclocal/rtems-test-check.m4 (modified) bsps: Move make/custom/* files to bsps Adjust various build files. ...
