# # ChangeLog for bsps/arm in rtems # # Generated by Trac 1.2.1.dev0 # 06/04/24 03:32:11 Wed, 08 Jul 2020 08:53:26 GMT Christian Mauderer [6014fad] * bsps/arm/beagle/i2c/bbb-i2c.c (modified) bsps/beagle: Remove some debug output from I2C. Fri, 17 Jul 2020 05:54:44 GMT Christian Mauderer [29a73d8] * bsps/arm/imx/spi/imx-ecspi.c (modified) bsp/imx: Use GPIOs for SPI CS The chip select lines of the iMX SPI ... Fri, 17 Jul 2020 05:54:43 GMT Christian Mauderer [0f4b911c] * bsps/arm/imx/gpio/imx-gpio.c (added) * bsps/arm/imx/headers.am (modified) * bsps/arm/imx/include/bsp/imx-gpio.h (added) * bsps/arm/imx/include/bsp/irq.h (modified) * bsps/arm/imx/start/bspstart.c (modified) * bsps/include/bsp/fatal.h (modified) * c/src/lib/libbsp/arm/imx/Makefile.am (modified) bsp/imx: Add a GPIO driver Update 3869 Sun, 05 Jul 2020 10:39:37 GMT James Fitzsimons [a3b86d6c] * bsps/arm/beagle/pwm/pwm.c (modified) Fix for Beaglebone BSP PWM bug Wed, 06 May 2020 08:30:51 GMT Chris Johns [084ea83] * bsps/arm/beagle/config/beagleboneblack-testsuite.tcfg (added) testsuite: Add expected-fail to beagleboneblack Updates #2962 Wed, 06 May 2020 05:19:15 GMT Chris Johns [7e3af67] * bsps/arm/xilinx-zynq/config/xilinx_zynq-testsuite.tcfg (added) * bsps/arm/xilinx-zynq/config/xilinx_zynq_a9_qemu-testsuite.tcfg (added) * bsps/arm/xilinx-zynq/config/xilinx_zynq_zc702-testsuite.tcfg (added) * bsps/arm/xilinx-zynq/config/xilinx_zynq_zc706-testsuite.tcfg (added) * bsps/arm/xilinx-zynq/config/xilinx_zynq_zedboard-testsuite.tcfg (added) testsuite: Add expected-fail to xilinx's zedboard, a9_qemu, zc702 and ... Thu, 16 Apr 2020 12:14:12 GMT Christian Mauderer [222d6879] * bsps/arm/shared/clock/clock-generic-timer.c (modified) bsps/arm: Fix uninitialized value in generic timer ... Mon, 30 Mar 2020 14:38:22 GMT Christian Mauderer [01219541] * bsps/arm/imx/include/arm/freescale/imx/imx_ccmvar.h (modified) * bsps/arm/imx/spi/imx-ecspi.c (modified) * bsps/arm/imx/start/ccm.c (modified) * c/src/lib/libbsp/arm/imx/configure.ac (modified) bsp/imx: Add an extra ecspi clock. Some imx chips or boards don't ... Sat, 28 Mar 2020 18:24:07 GMT G S Niteesh Babu [19efa9a0] * bsps/arm/raspberrypi/irq/irq.c (modified) * bsps/arm/raspberrypi/start/bspstarthooks.c (modified) bsp/raspberrypi: Fix build warnings. 1) _Memory_Initialize makes ... Tue, 07 Apr 2020 22:08:34 GMT Joel Sherrill [f493534] * bsps/arm/lpc24xx/config/lpc23xx_tli800-testsuite.tcfg (modified) lpc23xx_tli800-testsuite.tcfg: Add psxaoi03 and psxsignal07 Updates ... Tue, 07 Apr 2020 22:07:08 GMT Joel Sherrill [a7ea726f] * bsps/arm/lpc176x/config/lpc1768_mbed-testsuite.tcfg (modified) lpc1768_mbed-testsuite.tcfg: Add psxaoi03 and psxsignal07 Updates #3938. Tue, 07 Apr 2020 22:06:37 GMT Joel Sherrill [dcb097a] * bsps/arm/lpc24xx/config/lpc2362-testsuite.tcfg (modified) lpc2362-testsuite.tcfg: Add psxaoi03 and psxsignal07 Updates #3938. Tue, 07 Apr 2020 22:05:52 GMT Joel Sherrill [fe5d50ed] * bsps/arm/lpc176x/config/lpc1768_mbed_ahb_ram_eth-testsuite.tcfg (modified) lpc1768_mbed_ahb_ram_eth-testsuite.tcfg: Add psxsignal07 Updates #3938. Tue, 07 Apr 2020 22:05:00 GMT Joel Sherrill [f74d70e6] * bsps/arm/lm3s69xx/config/lm4f120-testsuite.tcfg (modified) lm4f120-testsuite.tcfg: Add psxsignal07 Updates #3938. Mon, 06 Apr 2020 19:21:26 GMT Sebastian Huber [92a3a19c] * bsps/arm/atsam/config/atsamv-testsuite.tcfg (modified) * bsps/arm/lpc24xx/config/lpc24xx_ncs_rom_int-testsuite.tcfg (modified) * bsps/arm/lpc24xx/config/lpc24xx_plx800_rom_int-testsuite.tcfg (modified) * bsps/arm/rtl22xx/config/rtl22xx-testsuite.tcfg (modified) * bsps/arm/rtl22xx/config/rtl22xx_t-testsuite.tcfg (modified) * bsps/m68k/mrm332/config/mrm332-testsuite.tcfg (modified) * bsps/powerpc/mpc55xxevb/config/gwlcfm-testsuite.tcfg (modified) * bsps/sh/gensh1/config/gensh1-testsuite.tcfg (modified) * bsps/sh/gensh2/config/gensh2-testsuite.tcfg (modified) * bsps/sh/shsim/config/simsh1-testsuite.tcfg (modified) * bsps/sh/shsim/config/simsh2-testsuite.tcfg (modified) * bsps/sh/shsim/config/simsh2e-testsuite.tcfg (modified) * bsps/sh/shsim/config/simsh4-testsuite.tcfg (modified) tests: Exclude record02 for some BSPs Update #3938. Mon, 09 Mar 2020 22:00:58 GMT Christian Mauderer [bb8ae78] * bsps/arm/raspberrypi/include/bsp/irq.h (modified) * bsps/arm/raspberrypi/start/bspstart.c (modified) bsp/raspberry: Add a bsp_fdt_map_intr(). Fixes #3903 Fri, 20 Mar 2020 08:12:26 GMT Sebastian Huber [51307919] * bsps/arm/shared/clock/clock-armv7m.c (modified) * bsps/arm/shared/irq/irq-armv7m.c (modified) * bsps/arm/shared/start/start.S (modified) * cpukit/score/cpu/arm/armv7m-initialize.c (modified) * cpukit/score/cpu/arm/include/rtems/score/armv7m.h (modified) arm: ARMv7-M statically initialized vector table Statically ... Thu, 19 Mar 2020 20:55:26 GMT Joel Sherrill [37e7cc5] * bsps/arm/gdbarmsim/config/arm1136jfs-testsuite.tcfg (deleted) * bsps/arm/gdbarmsim/config/arm1136jfs.cfg (deleted) * bsps/arm/gdbarmsim/config/arm1136js-testsuite.tcfg (deleted) * bsps/arm/gdbarmsim/config/arm1136js.cfg (deleted) * bsps/arm/gdbarmsim/config/arm7tdmi-testsuite.tcfg (deleted) * bsps/arm/gdbarmsim/config/arm7tdmi.cfg (deleted) * bsps/arm/gdbarmsim/config/arm920-testsuite.tcfg (deleted) * bsps/arm/gdbarmsim/config/arm920.cfg (deleted) * bsps/arm/gdbarmsim/config/armcortexa9-testsuite.tcfg (deleted) * bsps/arm/gdbarmsim/config/armcortexa9.cfg (deleted) * bsps/arm/gdbarmsim/console/console-io.c (deleted) * bsps/arm/gdbarmsim/headers.am (deleted) * bsps/arm/gdbarmsim/include/bsp.h (deleted) * bsps/arm/gdbarmsim/include/bsp/irq.h (deleted) * bsps/arm/gdbarmsim/include/bsp/swi.h (deleted) * bsps/arm/gdbarmsim/include/tm27.h (deleted) * bsps/arm/gdbarmsim/irq/irq-dispatch.c (deleted) * bsps/arm/gdbarmsim/irq/irq.c (deleted) * bsps/arm/gdbarmsim/start/bsp_specs (deleted) * bsps/arm/gdbarmsim/start/bspreset.c (deleted) * bsps/arm/gdbarmsim/start/bspstart.c (deleted) * bsps/arm/gdbarmsim/start/bspstarthooks.c (deleted) * bsps/arm/gdbarmsim/start/linkcmds (deleted) * bsps/arm/gdbarmsim/start/syscalls.c (deleted) * c/src/lib/libbsp/arm/acinclude.m4 (modified) * c/src/lib/libbsp/arm/gdbarmsim/Makefile.am (deleted) * c/src/lib/libbsp/arm/gdbarmsim/configure.ac (deleted) gdbarmsim: Remove Closes #3611. Thu, 12 Mar 2020 21:00:05 GMT Joel Sherrill [a5187956] * bsps/arm/rtl22xx/config/rtl22xx-testsuite.tcfg (modified) rtl22xx-testsuite.tcfg: Add dl10 and ttest01 Thu, 12 Mar 2020 20:59:35 GMT Joel Sherrill [9bbfb2b6] * bsps/arm/lpc24xx/config/lpc23xx_tli800-testsuite.tcfg (modified) lpc23xx_tli800-testsuite.tcfg: Add ttest01 Thu, 12 Mar 2020 20:59:10 GMT Joel Sherrill [ae6597f] * bsps/arm/lpc24xx/config/lpc2362-testsuite.tcfg (modified) lpc2362-testsuite.tcfg: Add ttest01 Thu, 12 Mar 2020 20:53:51 GMT Joel Sherrill [16ed7f64] * bsps/arm/lm3s69xx/config/lm3s3749-testsuite.tcfg (modified) lm3s3749-testsuite.tcfg: Add ttest01 Fri, 21 Feb 2020 13:21:33 GMT Sebastian Huber [e58ecb84] * bsps/arm/shared/irq/irq-gic.c (modified) bsps/arm: Initialize priorities of PPIs At least on GICv1 the ... Sun, 09 Feb 2020 19:21:44 GMT G S Niteesh [f53473f] * bsps/arm/raspberrypi/console/console-config.c (modified) * bsps/arm/raspberrypi/include/bsp/usart.h (modified) bsp/raspberrypi: Mini UART driver This patch adds driver for Mini ... Mon, 09 Dec 2019 15:03:11 GMT Sebastian Huber [32991495] * bsps/arm/shared/start/linkcmds.base (modified) * bsps/sh/gensh1/start/linkcmds (modified) * bsps/sh/gensh2/start/linkcmds (modified) * bsps/sh/gensh2/start/linkcmds.ram (modified) * bsps/sh/gensh2/start/linkcmds.rom (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/score/mpci.h (modified) * cpukit/include/rtems/score/thread.h (modified) * cpukit/score/src/mpci.c (modified) * cpukit/score/src/mpcidefault.c (modified) * cpukit/score/src/threadcreateidle.c (modified) * testsuites/sptests/spstkalloc/init.c (modified) score: Statically allocate idle/MPCI stacks Place idle and MPCI ... Wed, 12 Feb 2020 07:53:35 GMT Sebastian Huber [b900f507] * bsps/arm/shared/serial/zynq-uart-polled.c (added) * bsps/arm/shared/serial/zynq-uart.c (modified) * bsps/arm/xilinx-zynq/console/console-config.c (modified) * bsps/arm/xilinx-zynq/console/console-init.c (added) * c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am (modified) * c/src/lib/libbsp/arm/xilinx-zynqmp/Makefile.am (modified) arm/xilinx-zynq: Split console driver files This avoids to pull in ... Mon, 10 Feb 2020 09:35:17 GMT Christian Mauderer [adf7e753] * bsps/arm/imx/start/imx_iomux.c (modified) bsp/imx: Parse fdt pinctrl values and setup iomux Update #3869. Mon, 10 Feb 2020 09:35:16 GMT Christian Mauderer [b58f994] * bsps/arm/imx/start/imx_iomux.c (modified) bsp/imx: Support imx6ul iomux. Update #3869. Mon, 10 Feb 2020 09:35:15 GMT Christian Mauderer [d00d690] * bsps/arm/imx/spi/imx-ecspi.c (modified) bsp/imx: Allow gapless SPI transfers. This uses the tx-threshold to ... Mon, 10 Feb 2020 09:35:14 GMT Christian Mauderer [9c7bffb] * bsps/arm/imx/console/console-config.c (modified) bsp/imx: Use muxed mode for serials. Update #3869. Mon, 10 Feb 2020 09:35:13 GMT Sebastian Huber [65e51e9f] * bsps/arm/imx/start/bspstarthooks.c (modified) bsp/imx: Increase device memory area The new area is used by the ... Mon, 10 Feb 2020 09:35:12 GMT Christian Mauderer [c561bf4c] * bsps/arm/imx/start/bspstart.c (modified) bsp/imx: Allow GIC in different device tree node. Update #3869. Mon, 10 Feb 2020 09:35:11 GMT Sebastian Huber [8854a2b5] * bsps/arm/imx/include/bsp.h (modified) * bsps/arm/imx/start/bspstart.c (modified) bsp/imx: Avoid hard-coded GIC base address Update #3869. Sun, 02 Feb 2020 10:00:54 GMT Sebastian Huber [c344e58] * bsps/arm/atsam/console/debug-console.c (modified) * bsps/arm/atsam/contrib/libraries/libchip/source/pio_it.c (modified) * bsps/arm/atsam/contrib/libraries/libchip/source/xdmad.c (modified) * bsps/arm/atsam/start/getentropy-trng.c (modified) * bsps/arm/beagle/start/bspstart.c (modified) * bsps/arm/imx/console/console-config.c (modified) * bsps/arm/raspberrypi/console/console-config.c (modified) * bsps/arm/tms570/console/printk-support.c (modified) * bsps/arm/xilinx-zynq/console/debug-console.c (modified) * bsps/arm/xilinx-zynqmp/console/console-config.c (modified) * bsps/riscv/riscv/console/console-config.c (modified) * bsps/shared/dev/getentropy/getentropy-cpucounter.c (modified) * bsps/sparc/erc32/start/bspsmp.c (modified) * bsps/sparc/leon3/start/bspstart.c (modified) * cpukit/libtrace/record/record-sysinit.c (modified) * cpukit/sapi/src/cpucounterconverter.c (modified) Use RTEMS_SYSINIT_ORDER_LAST_BUT_5 Use ... Fri, 13 Dec 2019 05:18:36 GMT Sebastian Huber [eea21eac] * bsps/arm/altera-cyclone-v/start/bspgetworkarea.c (modified) * bsps/arm/imx/start/bspstarthooks.c (modified) * bsps/arm/raspberrypi/start/bspstarthooks.c (modified) * bsps/i386/pc386/start/bspgetworkarea.c (modified) * bsps/include/bsp/bootcard.h (modified) * bsps/powerpc/mpc55xxevb/start/bspgetworkarea.c (modified) * bsps/powerpc/qoriq/start/mmu-config.c (modified) * bsps/powerpc/shared/start/bspgetworkarea.c (modified) * bsps/powerpc/shared/start/sbrk.c (modified) * bsps/powerpc/tqm8xx/start/bspgetworkarea.c (modified) * bsps/shared/start/bootcard.c (modified) * bsps/shared/start/bspgetworkarea-default.c (modified) * bsps/sparc/shared/start/bspgetworkarea.c (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/malloc.h (modified) * cpukit/include/rtems/score/wkspace.h (modified) * cpukit/include/rtems/sysinit.h (modified) * cpukit/libcsupport/src/malloc_initialize.c (modified) * cpukit/sapi/src/exinit.c (modified) * cpukit/score/src/smp.c (modified) * cpukit/score/src/wkspace.c (modified) * testsuites/libtests/malloc04/init.c (modified) * testsuites/smptests/smpfatal09/init.c (modified) * testsuites/sptests/spfatal09/init.c (modified) * testsuites/sptests/spfatal12/init.c (modified) * testsuites/sptests/spsysinit01/init.c (modified) bsps: Rework work area initialization The work area initialization ... Fri, 13 Dec 2019 13:22:16 GMT Sebastian Huber [07e2eac] * bsps/arm/gdbarmsim/include/bsp.h (modified) * bsps/include/bsp/bootcard.h (modified) * bsps/sparc/shared/start/bspgetworkarea.c (modified) bsps: Remove uses of BSP_GET_WORK_AREA_DEBUG The code covered by ... Sat, 14 Dec 2019 20:36:09 GMT Sebastian Huber [ffa1153] * bsps/arm/shared/start/linkcmds.base (modified) * bsps/bfin/TLL6527M/start/linkcmds (modified) * bsps/bfin/bf537Stamp/start/linkcmds (modified) * bsps/bfin/eZKit533/start/linkcmds (modified) * bsps/epiphany/epiphany_sim/start/linkcmds (modified) * bsps/lm32/lm32_evr/start/linkcmds (modified) * bsps/lm32/milkymist/start/linkcmds (modified) * bsps/m68k/av5282/start/linkcmds (modified) * bsps/m68k/av5282/start/linkcmdsflash (modified) * bsps/m68k/av5282/start/linkcmdsram (modified) * bsps/m68k/csb360/start/linkcmds (modified) * bsps/m68k/gen68340/start/linkcmds (modified) * bsps/m68k/gen68360/start/linkcmds (modified) * bsps/m68k/gen68360/start/linkcmds.bootp (modified) * bsps/m68k/gen68360/start/linkcmds.prom (modified) * bsps/m68k/mcf5206elite/start/linkcmds (modified) * bsps/m68k/mcf52235/start/linkcmds (modified) * bsps/m68k/mcf5225x/start/linkcmds (modified) * bsps/m68k/mcf5235/start/linkcmds (modified) * bsps/m68k/mcf5235/start/linkcmdsflash (modified) * bsps/m68k/mcf5235/start/linkcmdsram (modified) * bsps/m68k/mcf5329/start/linkcmds (modified) * bsps/m68k/mcf5329/start/linkcmdsflash (modified) * bsps/m68k/mrm332/start/linkcmds (modified) * bsps/m68k/mvme162/start/linkcmds (modified) * bsps/m68k/mvme167/start/linkcmds (modified) * bsps/m68k/shared/start/linkcmds.base (modified) * bsps/m68k/uC5282/start/linkcmds (modified) * bsps/mips/csb350/start/linkcmds (modified) * bsps/mips/hurricane/start/linkcmds (modified) * bsps/mips/jmr3904/start/linkcmds (modified) * bsps/mips/malta/start/linkcmds (modified) * bsps/mips/rbtx4925/start/linkcmds (modified) * bsps/mips/rbtx4938/start/linkcmds (modified) * bsps/moxie/moxiesim/start/linkcmds (modified) * bsps/nios2/nios2_iss/start/linkcmds (modified) * bsps/or1k/shared/start/linkcmds.base (modified) * bsps/powerpc/gen5200/start/linkcmds.gen5200_base (modified) * bsps/powerpc/haleakala/start/linkcmds (modified) * bsps/powerpc/mpc8260ads/start/linkcmds (modified) * bsps/powerpc/shared/start/linkcmds.base (modified) * bsps/powerpc/ss555/start/linkcmds (modified) * bsps/powerpc/virtex4/start/linkcmds (modified) * bsps/powerpc/virtex5/start/linkcmds (modified) * bsps/riscv/shared/start/linkcmds.base.in (modified) * bsps/sh/gensh1/start/linkcmds (modified) * bsps/sh/gensh2/start/linkcmds (modified) * bsps/sh/gensh2/start/linkcmds.ram (modified) * bsps/sh/gensh2/start/linkcmds.rom (modified) * bsps/sh/gensh4/start/linkcmds (modified) * bsps/sh/gensh4/start/linkcmds.rom (modified) * bsps/sh/gensh4/start/linkcmds.rom2ram (modified) * bsps/sh/shsim/start/linkcmds (modified) * bsps/sparc64/shared/start/linkcmds (modified) * bsps/v850/gdbv850sim/start/linkcmds (modified) * bsps/x86_64/amd64/start/linkcmds (modified) bsps: Add RamEnd to linker command files Update #3838. Fri, 16 Aug 2019 19:14:33 GMT Kinsey Moore [ebf0f8f] * bsps/arm/include/bsp/arm-gic-irq.h (modified) * bsps/arm/include/bsp/arm-gic-regs.h (modified) * bsps/arm/shared/irq/irq-gic.c (modified) * bsps/arm/shared/irq/irq-gicv3.c (added) bsps/arm/shared: Add GICv3 implementation This adds support for the ... Sat, 04 Jan 2020 19:50:46 GMT G S Niteesh [362cf319] * bsps/arm/raspberrypi/console/console-config.c (modified) * bsps/arm/raspberrypi/console/console_select.c (deleted) * bsps/arm/raspberrypi/console/fbcons.c (modified) * bsps/arm/raspberrypi/console/usart.c (deleted) * bsps/arm/raspberrypi/include/bsp.h (modified) * bsps/arm/raspberrypi/include/bsp/fbcons.h (modified) * bsps/arm/raspberrypi/include/bsp/raspberrypi.h (modified) * bsps/arm/raspberrypi/include/bsp/usart.h (modified) * bsps/arm/raspberrypi/start/bspstart.c (modified) * c/src/lib/libbsp/arm/raspberrypi/Makefile.am (modified) bsp/raspberrypi: Updated the console API. Replaces the legacy ... Fri, 03 Jan 2020 03:26:14 GMT G S Niteesh [eca25ef] * bsps/arm/raspberrypi/include/bsp.h (modified) * c/src/lib/libbsp/arm/raspberrypi/Makefile.am (modified) * c/src/lib/libbsp/arm/raspberrypi/configure.ac (modified) bsp/raspberrypi: Enable FDT support. This commit adds FDT support ... Fri, 27 Dec 2019 21:08:12 GMT Christian Mauderer [f1f6cd95] * bsps/arm/raspberrypi/include/bsp/vc.h (modified) * bsps/arm/raspberrypi/start/bspgetworkarea.c (deleted) * bsps/arm/raspberrypi/start/bspstarthooks.c (modified) * bsps/arm/raspberrypi/start/mm_config_table.c (deleted) * c/src/lib/libbsp/arm/raspberrypi/Makefile.am (modified) bsp/raspberrypi: Fix size of work area. The BSP tried to get the ... Fri, 27 Dec 2019 21:08:11 GMT Christian Mauderer [c51f1fc5] * bsps/arm/imx/start/bspstarthooks.c (modified) * bsps/arm/include/bsp/arm-cp15-start.h (modified) bsps/arm: Define index of the workspace entry. The imx BSP ... Thu, 19 Dec 2019 09:59:20 GMT Sebastian Huber [2497da06] * bsps/arm/shared/start/start.S (modified) bsps/arm: Export bsp_start_hook_0_done Close #3789. Thu, 05 Dec 2019 06:51:12 GMT Sebastian Huber [1380c822] * bsps/arm/xen/start/linkcmds.in (modified) * c/src/lib/libbsp/arm/xen/configure.ac (modified) bsp/xen: Use BSP options for all linkcmds vars Update #3818. Wed, 04 Dec 2019 14:29:33 GMT Jeff Kubascik [4c30acf] * bsps/arm/xen/config/xen_virtual.cfg (added) * bsps/arm/xen/console/console.c (added) * bsps/arm/xen/headers.am (added) * bsps/arm/xen/include/bsp.h (added) * bsps/arm/xen/include/bsp/irq.h (added) * bsps/arm/xen/include/tm27.h (added) * bsps/arm/xen/start/bsp_specs (added) * bsps/arm/xen/start/bspstart.c (added) * bsps/arm/xen/start/bspstarthooks.c (added) * bsps/arm/xen/start/bspstartmmu.c (added) * bsps/arm/xen/start/linkcmds.in (added) * c/src/lib/libbsp/arm/acinclude.m4 (modified) * c/src/lib/libbsp/arm/xen/Makefile.am (added) * c/src/lib/libbsp/arm/xen/configure.ac (added) bsp/xen: Create BSP Create the Xen BSP for Xen on ARM. Wed, 04 Dec 2019 14:29:32 GMT Jeff Kubascik [b51a1d0] * bsps/arm/shared/clock/clock-generic-timer.c (modified) bsps/arm: Unmask generic timer in interrupt handler Xen will mask ... Wed, 04 Dec 2019 14:29:31 GMT Jeff Kubascik [001cd9bd] * bsps/arm/shared/start/start.S (modified) bsps/arm: Add zImage boot header Xen currently only supports the ... Tue, 19 Nov 2019 15:02:50 GMT Sebastian Huber [741fe47] * bsps/arm/lpc32xx/start/linkcmds.lpc32xx_phycore (modified) bsp/lpc32xx: Fix linker command file Tue, 19 Nov 2019 14:22:14 GMT Sebastian Huber [a52d6174] * bsps/arm/imx/start/linkcmds (moved) * c/src/lib/libbsp/arm/imx/Makefile.am (modified) bsp/imx7: Rename linker command file This BSP family uses only one ... Tue, 19 Nov 2019 13:49:43 GMT Sebastian Huber [af321aa] * bsps/arm/altera-cyclone-v/start/linkcmds (moved) * c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am (modified) bsp/altcycv_devkit: Rename linker command file This BSP family uses ... Mon, 18 Nov 2019 14:24:05 GMT Sebastian Huber [12a263bb] * bsps/arm/atsam/contrib/libraries/libchip/source/pio_it.c (modified) bsp/atsamv: Fix warning Thu, 14 Nov 2019 14:02:03 GMT Sebastian Huber [bc28b65] * bsps/arm/beagle/start/linkcmds (moved) * c/src/lib/libbsp/arm/beagle/Makefile.am (modified) bsp/beagle: Rename linker command file This BSP family uses only ... Thu, 14 Nov 2019 09:29:24 GMT Sebastian Huber [3dcfee37] * bsps/arm/gumstix/net/rtl8019.c (modified) bsp/gumstix: Fix warning Mon, 28 Oct 2019 09:15:28 GMT Sebastian Huber [f9648ba] * bsps/arm/include/bsp/arm-cp15-start.h (modified) * bsps/arm/realview-pbx-a9/start/linkcmds.realview_pbx_a9_qemu (modified) * bsps/arm/shared/cp15/arm-cp15-set-ttb-entries.c (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/configure.ac (modified) bsps/arm: Add support for small pages MMU The small page MMU ... Wed, 23 Oct 2019 12:16:47 GMT Sebastian Huber [d2efc968] * bsps/arm/xilinx-zynq/start/linkcmds.in (modified) * c/src/lib/libbsp/arm/xilinx-zynq/configure.ac (modified) bsp/xilinx-zynq: Simplify linkcmds config Use NULL-pointer ... Wed, 23 Oct 2019 12:03:39 GMT Sebastian Huber [1e1afa37] * bsps/arm/xilinx-zynqmp/start/linkcmds.in (modified) * c/src/lib/libbsp/arm/xilinx-zynqmp/configure.ac (modified) bsp/xilinx-zynqmp: Simplify linkcmds config Do all calculations in ... Tue, 15 Oct 2019 15:10:01 GMT Christian Mauderer [9620dfa4] * bsps/arm/atsam/include/bsp/sc16is752.h (modified) * bsps/arm/atsam/spi/sc16is752.c (modified) bsp/atsam: Use PIO for SC16IS752. This allows to mix SC16IS752 ... Tue, 15 Oct 2019 15:10:00 GMT Christian Mauderer [d60b6d7c] * bsps/arm/atsam/contrib/libraries/libchip/source/pio_it.c (modified) * bsps/arm/atsam/include/libchip/include/pio_it.h (modified) bsp/atsam: Add additional PIO helper. Tue, 15 Oct 2019 15:09:59 GMT Christian Mauderer [d4b92da2] * bsps/arm/atsam/contrib/libraries/libchip/source/pio_it.c (modified) bsps/atsam: Improve case for level triggered IRQs. For level ... Sat, 19 Oct 2019 04:53:50 GMT Chris Johns [2fdbdbc] * bsps/arm/beagle/i2c/bbb-i2c.c (modified) arm/beanglebone: Fix i2c build error. Tue, 17 Sep 2019 20:46:05 GMT Vijay Kumar Banerjee [a4e96cf] * bsps/arm/beagle/i2c/bbb-i2c.c (modified) * bsps/arm/beagle/include/bsp/i2c.h (modified) * bsps/arm/beagle/start/bspstart.c (modified) bsps/beagle: register i2c device at initialization Mon, 12 Aug 2019 03:58:31 GMT Chris Johns [15b6f44d] * bsps/arm/shared/cp15/arm-cp15-set-ttb-entries.c (modified) arm/tlb: Fix the MP affinity check to invalidate ASIDs. - The TI's ... Tue, 06 Aug 2019 10:00:56 GMT Chris Johns [a4d7e4ce] * bsps/arm/raspberrypi/start/bspgetworkarea.c (modified) * bsps/arm/raspberrypi/start/bspstart.c (modified) * bsps/arm/raspberrypi/start/linkcmds.in (modified) * c/src/lib/libbsp/arm/raspberrypi/configure.ac (modified) arm/raspberry: Set the workspace based on the mailbox version. - ... Sun, 04 Aug 2019 23:58:07 GMT Chris Johns [9cb19ded] * bsps/arm/raspberrypi/start/linkcmds.in (moved) * cpukit/libdl/rtl-debugger.c (modified) * cpukit/libdl/rtl-elf.c (modified) libdl/debugger: Fix the broken list delete when unloading an object ... Fri, 02 Aug 2019 20:57:01 GMT Vijay Kumar Banerjee [886956a] * bsps/arm/beagle/start/bspstart.c (modified) * bsps/arm/beagle/start/linkcmds.beagle (modified) bsp/beagle: Add nocache section Closes #3780 Tue, 30 Jul 2019 19:14:16 GMT Christian Mauderer [163927e5] * bsps/arm/beagle/gpio/bbb-gpio.c (modified) bsps/beagle: Remove dead code from GPIO. Remove static stuff that ... Tue, 25 Jun 2019 11:16:27 GMT Chris Johns [7d4f74e] * bsps/arm/beagle/start/bspdebug.c (added) * bsps/arm/beagle/start/bspdebug.h (added) * bsps/arm/beagle/start/bspstart.c (modified) * c/src/lib/libbsp/arm/beagle/Makefile.am (modified) arm/beagle: Add libdebugger support. - Port the jbang code from C++ ... Tue, 25 Jun 2019 10:48:51 GMT Chris Johns [98d6792] * bsps/arm/shared/cp15/arm-cp15-set-ttb-entries.c (modified) arm: Select the TLB invalidate based on the core's Id variant. ... Mon, 29 Jul 2019 05:22:03 GMT Sebastian Huber [c5fd79cd] * bsps/arm/raspberrypi/start/bspstarthooks.c (modified) * bsps/arm/raspberrypi/start/linkcmds (modified) arm/raspberrypi: Fix linker map Add NULL-pointer protection. Make ... Fri, 26 Jul 2019 06:12:20 GMT Sebastian Huber [1e6380b] * bsps/arm/shared/start/bsp-start-in-hyp-support.S (deleted) * bsps/arm/shared/start/start.S (modified) * c/src/lib/libbsp/arm/raspberrypi/Makefile.am (modified) bsps/arm: Move HYP to SVC change to start.S This fixes the ... Fri, 26 Jul 2019 05:59:27 GMT Sebastian Huber [0ee2125] * bsps/arm/shared/start/bsp-start-init-registers.S (deleted) * bsps/arm/shared/start/start.S (modified) * c/src/lib/libbsp/arm/tms570/Makefile.am (modified) bsps/arm: Move register init to start.S This makes it easier to ... Fri, 26 Jul 2019 05:54:05 GMT Sebastian Huber [0f5c1d53] * bsps/arm/shared/start/start.S (modified) bsps/arm: Remove register init for ARMv7-M There are no known ... Mon, 24 Jun 2019 20:16:59 GMT Christian Mauderer [b89d6cc] * bsps/arm/beagle/i2c/bbb-i2c.c (modified) * bsps/arm/beagle/include/bsp/i2c.h (modified) * bsps/arm/include/libcpu/am335x.h (modified) bsp/beagle: Partial re-write of I2C driver. The old driver worked ... Tue, 25 Jun 2019 08:43:55 GMT Chris Johns [c43071f] * bsps/arm/shared/cp15/arm-cp15-set-exception-handler.c (modified) * cpukit/score/cpu/arm/include/libcpu/arm-cp15.h (modified) arm: Return the current handler from arm_cp15_set_exception_handler ... Fri, 21 Jun 2019 04:58:19 GMT Sebastian Huber [dc581f2] * bsps/arm/atsam/contrib/libraries/libboard/source/board_memories.c (modified) * bsps/arm/atsam/include/bsp/atsam-clock-config.h (modified) * bsps/arm/atsam/start/sdram-config.c (modified) bsp/atsam: Enable configuration of SDRAMC_LPR Tue, 18 Jun 2019 10:52:53 GMT Sebastian Huber [a67b9b06] * bsps/arm/atsam/include/bsp/power.h (modified) * bsps/arm/atsam/start/power-wait.c (added) * c/src/lib/libbsp/arm/atsam/Makefile.am (modified) atsam: Add ATSAM_POWER_WAIT_MODE Tue, 18 Jun 2019 09:31:48 GMT Sebastian Huber [522cde4] * bsps/arm/atsam/start/power-rtc.c (modified) atsam: Enable fast startup via RTC alarm Tue, 18 Jun 2019 09:10:55 GMT Sebastian Huber [bb24892] * bsps/arm/atsam/start/power.c (modified) bsp/atsam: Use proper API Thu, 13 Jun 2019 06:44:04 GMT Sebastian Huber [d7d0bba] * bsps/arm/atsam/net/if_atsam.c (modified) * bsps/arm/atsam/start/bspstarthooks.c (modified) bsp/atsam: Do not disable the WDT The watchdog timer (WDT) can be ... Wed, 12 Jun 2019 10:53:22 GMT Sebastian Huber [ee36616] * bsps/arm/atsam/include/bsp/power.h (modified) * bsps/arm/atsam/start/power-rtc.c (modified) bsp/atsam: Improve RTC power driver Accept a time interval up to 24h. Wed, 12 Jun 2019 10:51:20 GMT Sebastian Huber [5d4a81f5] * bsps/arm/atsam/contrib/libraries/libchip/source/rtc.c (modified) bsp/atsam: Fix RTC_SetTimeAlarm() Set the alarm time according to ... Tue, 04 Jun 2019 10:04:55 GMT Sebastian Huber [98fc6014] * bsps/arm/lpc24xx/include/bsp/io.h (modified) bsp/lpc24xx: Fix LPC24XX_IO_PORT_COUNT Sun, 28 Apr 2019 12:29:21 GMT Sebastian Huber [7fdf48a] * bsps/arm/shared/clock/clock-a9mpcore.c (modified) * bsps/arm/shared/clock/clock-generic-timer.c (modified) * cpukit/include/rtems/score/smpimpl.h (modified) * cpukit/score/src/smpmulticastaction.c (modified) score: Add _SMP_Othercast_action() Thu, 18 Apr 2019 04:47:01 GMT Sebastian Huber [65870044] * bsps/arm/shared/clock/clock-a9mpcore.c (modified) * bsps/arm/shared/clock/clock-generic-timer.c (modified) * bsps/shared/cache/cacheimpl.h (modified) * cpukit/include/rtems/score/smpimpl.h (modified) * cpukit/score/src/smpmulticastaction.c (modified) * testsuites/smptests/smpmulticast01/init.c (modified) score: Add _SMP_Broadcast_action() Tue, 14 May 2019 07:04:05 GMT Sebastian Huber [b446457] * bsps/arm/lm3s69xx/config/lm3s69xx.inc (modified) * bsps/arm/lpc176x/config/lpc1768_mbed.cfg (modified) * bsps/arm/lpc24xx/config/lpc17xx.inc (modified) * bsps/arm/lpc24xx/config/lpc40xx.inc (modified) * bsps/arm/stm32f4/config/stm32f105rc.cfg (modified) * bsps/arm/stm32f4/config/stm32f4.cfg (modified) bsps/arm: Adjust machine flags for ARMv7-M Update machine flags for ... Tue, 09 Apr 2019 09:18:50 GMT Andreas Dachsberger [0cdcb27] * bsps/arm/atsam/contrib/libraries/libboard/board_v71_xult.h (modified) Removed entry from Related Pages SAM V71 Xplained Ultra - Board ... Thu, 09 May 2019 10:31:31 GMT Sebastian Huber [cf5d5d80] * bsps/arm/lpc24xx/start/start-config-emc-dynamic.c (modified) bsp/lpc24xx: Fix dynamic EMC configurations Thu, 09 May 2019 07:54:48 GMT Sebastian Huber [50d8d32] * bsps/arm/lpc24xx/include/bsp/io.h (modified) bsp/lpc24xx: Use fast slew rate for EMC pins Thu, 09 May 2019 07:53:55 GMT Sebastian Huber [0a6b81a] * bsps/arm/lpc24xx/include/bsp/io.h (modified) * bsps/arm/lpc24xx/start/io.c (modified) bsp/lpc24xx: Add LPC17XX_PIN_TYPE_FAST_SLEW_RATE Thu, 09 May 2019 07:16:20 GMT Sebastian Huber [6cad529] * bsps/arm/lpc24xx/start/start-config-emc-dynamic.c (modified) bsp/lpc24xx: Add SDRAM mode settings comment Wed, 08 May 2019 11:37:06 GMT Sebastian Huber [0b74d8f0] * bsps/arm/lpc24xx/start/start-config-mpu.c (modified) bsp/lpc24xx: Fix LPC24XX_EMC_MT48LC4M16A2 MPU cfg Wed, 08 May 2019 11:02:47 GMT Sebastian Huber [2ffbc4d] * bsps/arm/lpc24xx/start/start-config-emc-dynamic.c (modified) bsp/lpc24xx: Flexible LPC24XX_EMC_MT48LC4M16A2 cfg Wed, 08 May 2019 11:02:04 GMT Sebastian Huber [d49ff3e] * bsps/arm/lpc24xx/start/start-config-mpu.c (modified) bsp/lpc24xx: LPC24XX_EMC_MT48LC4M16A2 MPU support Wed, 08 May 2019 11:01:07 GMT Sebastian Huber [a6c08e8d] * bsps/arm/lpc24xx/start/start-config-pinsel.c (modified) bsp/lpc24xx: Support LPC24XX_EMC_SST39VF3201 pins Mon, 06 May 2019 05:56:01 GMT Sebastian Huber [8bd4f61c] * bsps/arm/csb336/include/bsp.h (modified) * bsps/arm/csb337/include/bsp.h (modified) * bsps/mips/csb350/include/bsp.h (modified) bsps: Remove bogus config declaration Replace it with a proper ... Fri, 12 Apr 2019 05:55:31 GMT Sebastian Huber [ad40d05e] * bsps/arm/shared/clock/clock-a9mpcore.c (modified) * bsps/arm/shared/clock/clock-generic-timer.c (modified) * cpukit/include/rtems/score/percpu.h (modified) * cpukit/include/rtems/score/smpimpl.h (modified) * cpukit/score/src/percpu.c (modified) * cpukit/score/src/smp.c (modified) score: Remove _SMP_Before_multitasking_action() Use ... Wed, 10 Apr 2019 23:38:55 GMT Jeff Kubascik [77f9a1b] * bsps/arm/xilinx-zynqmp/README (modified) * bsps/arm/xilinx-zynqmp/config/xilinx_zynqmp.inc (moved) * bsps/arm/xilinx-zynqmp/config/xilinx_zynqmp_ultra96.cfg (added) * bsps/arm/xilinx-zynqmp/console/console-config.c (modified) * bsps/arm/xilinx-zynqmp/headers.am (modified) * bsps/arm/xilinx-zynqmp/include/bsp.h (modified) * bsps/arm/xilinx-zynqmp/include/bsp/irq.h (modified) * bsps/arm/xilinx-zynqmp/include/tm27.h (modified) * bsps/arm/xilinx-zynqmp/start/bspreset.c (modified) * bsps/arm/xilinx-zynqmp/start/bspsmp.c (modified) * bsps/arm/xilinx-zynqmp/start/bspstart.c (modified) * bsps/arm/xilinx-zynqmp/start/bspstarthooks.c (modified) * bsps/arm/xilinx-zynqmp/start/bspstartmmu.c (modified) * bsps/arm/xilinx-zynqmp/start/linkcmds.in (modified) * c/src/lib/libbsp/arm/acinclude.m4 (modified) * c/src/lib/libbsp/arm/xilinx-zynqmp/Makefile.am (modified) * c/src/lib/libbsp/arm/xilinx-zynqmp/configure.ac (modified) bsp/xilinx-zynqmp: Implement Ultra96 target Modifications to get ... Wed, 10 Apr 2019 23:38:54 GMT Jeff Kubascik [677d5167] * bsps/arm/xilinx-zynqmp/README (added) * bsps/arm/xilinx-zynqmp/config/xilinx_zynq.inc (added) * bsps/arm/xilinx-zynqmp/console/console-config.c (added) * bsps/arm/xilinx-zynqmp/headers.am (added) * bsps/arm/xilinx-zynqmp/include/bsp.h (added) * bsps/arm/xilinx-zynqmp/include/bsp/irq.h (added) * bsps/arm/xilinx-zynqmp/include/tm27.h (added) * bsps/arm/xilinx-zynqmp/start/bsp_specs (added) * bsps/arm/xilinx-zynqmp/start/bspreset.c (added) * bsps/arm/xilinx-zynqmp/start/bspsmp.c (added) * bsps/arm/xilinx-zynqmp/start/bspstart.c (added) * bsps/arm/xilinx-zynqmp/start/bspstarthooks.c (added) * bsps/arm/xilinx-zynqmp/start/bspstartmmu.c (added) * bsps/arm/xilinx-zynqmp/start/linkcmds.in (added) * c/src/lib/libbsp/arm/xilinx-zynqmp/Makefile.am (added) * c/src/lib/libbsp/arm/xilinx-zynqmp/configure.ac (added) bsp/xilinx-zynqmp: Stub out Xilinx MPSoC BSP Source files were ... Wed, 10 Apr 2019 23:38:53 GMT Jeff Kubascik [b004430] * bsps/arm/headers.am (modified) * bsps/arm/include/bsp/zynq-uart-regs.h (moved) * bsps/arm/include/bsp/zynq-uart.h (moved) * bsps/arm/shared/serial/zynq-uart.c (moved) * bsps/arm/xilinx-zynq/headers.am (modified) * c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am (modified) bsp/zynq-uart: Move Zynq UART driver to shared directory This ... Wed, 10 Apr 2019 23:38:52 GMT Jeff Kubascik [b0c420b9] * bsps/arm/xilinx-zynq/console/debug-console.c (modified) * bsps/arm/xilinx-zynq/include/bsp.h (modified) * bsps/arm/xilinx-zynq/include/bsp/zynq-uart.h (modified) bsp/zynq-uart: Remove zynq_uart_instances from header This variable ...
