# # ChangeLog for bsps/arm/shared/cp15 in rtems # # Generated by Trac 1.2.1.dev0 # 04/18/24 17:21:56 Tue, 24 Apr 2018 05:49:25 GMT Sebastian Huber [891754f7] * bsps/arm/shared/cp15/arm-cp15-set-ttb-entries.c (moved) * c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am (modified) * c/src/lib/libbsp/arm/beagle/Makefile.am (modified) * c/src/lib/libbsp/arm/gdbarmsim/Makefile.am (modified) * c/src/lib/libbsp/arm/imx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc32xx/Makefile.am (modified) * c/src/lib/libbsp/arm/raspberrypi/Makefile.am (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am (modified) * c/src/lib/libbsp/arm/tms570/Makefile.am (modified) * c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am (modified) bsps: Move arm-cp15-set-ttb-entries.c to bsps This patch is a part ... Tue, 24 Apr 2018 05:49:12 GMT Sebastian Huber [aa705fe] * bsps/arm/shared/cp15/arm-cp15-set-exception-handler.c (moved) * c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am (modified) * c/src/lib/libbsp/arm/beagle/Makefile.am (modified) * c/src/lib/libbsp/arm/gdbarmsim/Makefile.am (modified) * c/src/lib/libbsp/arm/imx/Makefile.am (modified) * c/src/lib/libbsp/arm/raspberrypi/Makefile.am (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am (modified) * c/src/lib/libbsp/arm/tms570/Makefile.am (modified) * c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am (modified) bsps: Move arm-cp15-set-exception-handler.c to bsps This patch is a ... Sat, 10 Mar 2018 09:17:35 GMT Sebastian Huber [c4905d8d] * bsps/arm/shared/cp15/arm920-mmu.c (moved) * c/src/lib/libbsp/arm/csb336/Makefile.am (modified) * c/src/lib/libbsp/arm/csb336/make/custom/csb336.cfg (modified) * c/src/lib/libbsp/arm/csb337/Makefile.am (modified) * c/src/lib/libbsp/arm/csb337/make/custom/csb337.cfg (modified) * c/src/lib/libbsp/arm/edb7312/make/custom/edb7312.cfg (modified) * c/src/lib/libbsp/arm/gdbarmsim/Makefile.am (modified) * c/src/lib/libbsp/arm/gdbarmsim/make/custom/arm1136jfs.cfg (modified) * c/src/lib/libbsp/arm/gdbarmsim/make/custom/arm1136js.cfg (modified) * c/src/lib/libbsp/arm/gdbarmsim/make/custom/arm7tdmi.cfg (modified) * c/src/lib/libbsp/arm/gdbarmsim/make/custom/arm920.cfg (modified) * c/src/lib/libbsp/arm/gdbarmsim/make/custom/armcortexa9.cfg (modified) * c/src/lib/libbsp/arm/gumstix/Makefile.am (modified) * c/src/lib/libbsp/arm/gumstix/make/custom/gumstix.cfg (modified) * c/src/lib/libbsp/arm/smdk2410/Makefile.am (modified) * c/src/lib/libbsp/arm/smdk2410/make/custom/smdk2410.cfg (modified) * c/src/lib/libcpu/arm/Makefile.am (deleted) * c/src/lib/libcpu/arm/configure.ac (deleted) * c/src/lib/libcpu/arm/lpc22xx/irq/bsp_irq_asm.S (deleted) * c/src/lib/libcpu/arm/lpc22xx/irq/bsp_irq_init.c (deleted) * c/src/lib/libcpu/arm/pxa255/irq/bsp_irq_asm.S (deleted) * c/src/lib/libcpu/arm/pxa255/irq/bsp_irq_init.c (deleted) bsps/arm: Move libcpu content to bsps This patch is a part of the ...
