# # ChangeLog for bsps/arm/lpc24xx in rtems # # Generated by Trac 1.2.1.dev0 # 04/19/24 20:56:45 Fri, 20 Apr 2018 08:35:35 GMT Sebastian Huber [9964895] * bsps/arm/altera-cyclone-v/start/bsp_specs (moved) * bsps/arm/altera-cyclone-v/start/bspclean.c (moved) * bsps/arm/altera-cyclone-v/start/bspgetworkarea.c (moved) * bsps/arm/altera-cyclone-v/start/bspreset.c (moved) * bsps/arm/altera-cyclone-v/start/bspsmp.c (moved) * bsps/arm/altera-cyclone-v/start/bspstart.c (moved) * bsps/arm/altera-cyclone-v/start/bspstarthooks.c (moved) * bsps/arm/altera-cyclone-v/start/linkcmds.altcycv (moved) * bsps/arm/altera-cyclone-v/start/linkcmds.altcycv_devkit (moved) * bsps/arm/altera-cyclone-v/start/linkcmds.altcycv_devkit_smp (moved) * bsps/arm/altera-cyclone-v/start/mmu-config.c (moved) * bsps/arm/atsam/start/bsp_specs (moved) * bsps/arm/atsam/start/bspstart.c (moved) * bsps/arm/atsam/start/bspstarthooks.c (moved) * bsps/arm/atsam/start/getentropy-trng.c (moved) * bsps/arm/atsam/start/linkcmds (moved) * bsps/arm/atsam/start/linkcmds.intsram (moved) * bsps/arm/atsam/start/linkcmds.memory.in (moved) * bsps/arm/atsam/start/linkcmds.qspiflash (moved) * bsps/arm/atsam/start/linkcmds.sdram (moved) * bsps/arm/atsam/start/pin-config.c (moved) * bsps/arm/atsam/start/pmc-config.c (moved) * bsps/arm/atsam/start/power-clock.c (moved) * bsps/arm/atsam/start/power-rtc.c (moved) * bsps/arm/atsam/start/power.c (moved) * bsps/arm/atsam/start/restart.c (moved) * bsps/arm/atsam/start/sdram-config.c (moved) * bsps/arm/beagle/start/bsp_specs (moved) * bsps/arm/beagle/start/bspreset.c (moved) * bsps/arm/beagle/start/bspstart.c (moved) * bsps/arm/beagle/start/bspstarthooks.c (moved) * bsps/arm/beagle/start/bspstartmmu.c (moved) * bsps/arm/beagle/start/linkcmds.beagle (moved) * bsps/arm/csb336/start/bsp_specs (moved) * bsps/arm/csb336/start/bspstart.c (moved) * bsps/arm/csb336/start/linkcmds (moved) * bsps/arm/csb336/start/memmap.c (moved) * bsps/arm/csb337/start/bsp_specs (moved) * bsps/arm/csb337/start/bspreset.c (moved) * bsps/arm/csb337/start/bspstart.c (moved) * bsps/arm/csb337/start/linkcmds.csb337 (moved) * bsps/arm/csb337/start/linkcmds.csb637 (moved) * bsps/arm/csb337/start/memmap.c (moved) * bsps/arm/csb337/start/pmc.c (moved) * bsps/arm/csb337/start/umonsupp.c (moved) * bsps/arm/edb7312/start/bsp_specs (moved) * bsps/arm/edb7312/start/bspreset.c (moved) * bsps/arm/edb7312/start/bspstart.c (moved) * bsps/arm/edb7312/start/linkcmds (moved) * bsps/arm/gdbarmsim/start/bsp_specs (moved) * bsps/arm/gdbarmsim/start/bspreset.c (moved) * bsps/arm/gdbarmsim/start/bspstart.c (moved) * bsps/arm/gdbarmsim/start/bspstarthooks.c (moved) * bsps/arm/gdbarmsim/start/linkcmds (moved) * bsps/arm/gdbarmsim/start/syscalls.c (moved) * bsps/arm/gumstix/start/bsp_specs (moved) * bsps/arm/gumstix/start/bspreset.c (moved) * bsps/arm/gumstix/start/bspstart.c (moved) * bsps/arm/gumstix/start/linkcmds (moved) * bsps/arm/gumstix/start/memmap.c (moved) * bsps/arm/imx/start/bsp_specs (moved) * bsps/arm/imx/start/bspreset.c (moved) * bsps/arm/imx/start/bspsmp.c (moved) * bsps/arm/imx/start/bspstart.c (moved) * bsps/arm/imx/start/bspstarthooks.c (moved) * bsps/arm/imx/start/ccm.c (moved) * bsps/arm/imx/start/imx_iomux.c (moved) * bsps/arm/imx/start/linkcmds.imx7 (moved) * bsps/arm/lm3s69xx/start/bsp_specs (moved) * bsps/arm/lm3s69xx/start/bspstart.c (moved) * bsps/arm/lm3s69xx/start/bspstarthook.c (moved) * bsps/arm/lm3s69xx/start/io.c (moved) * bsps/arm/lm3s69xx/start/linkcmds.lm3s3749 (moved) * bsps/arm/lm3s69xx/start/linkcmds.lm3s6965 (moved) * bsps/arm/lm3s69xx/start/linkcmds.lm3s6965_qemu (moved) * bsps/arm/lm3s69xx/start/linkcmds.lm4f120 (moved) * bsps/arm/lm3s69xx/start/syscon.c (moved) * bsps/arm/lpc176x/start/bsp_specs (moved) * bsps/arm/lpc176x/start/bspstart.c (moved) * bsps/arm/lpc176x/start/bspstarthooks.c (moved) * bsps/arm/lpc176x/start/linkcmds.lpc1768_mbed (moved) * bsps/arm/lpc176x/start/linkcmds.lpc1768_mbed_ahb_ram (moved) * bsps/arm/lpc176x/start/linkcmds.lpc1768_mbed_ahb_ram_eth (moved) * bsps/arm/lpc24xx/start/bsp_specs (moved) * bsps/arm/lpc24xx/start/bspreset-armv4.c (moved) * bsps/arm/lpc24xx/start/bspstart.c (moved) * bsps/arm/lpc24xx/start/bspstarthooks.c (moved) * bsps/arm/lpc24xx/start/fb-config.c (moved) * bsps/arm/lpc24xx/start/linkcmds.lpc17xx_ea_ram (moved) * bsps/arm/lpc24xx/start/linkcmds.lpc17xx_ea_rom_int (moved) * bsps/arm/lpc24xx/start/linkcmds.lpc17xx_plx800_ram (moved) * bsps/arm/lpc24xx/start/linkcmds.lpc17xx_plx800_rom_int (moved) * bsps/arm/lpc24xx/start/linkcmds.lpc2362 (moved) * bsps/arm/lpc24xx/start/linkcmds.lpc23xx_tli800 (moved) * bsps/arm/lpc24xx/start/linkcmds.lpc24xx_ea (moved) * bsps/arm/lpc24xx/start/linkcmds.lpc24xx_ncs_ram (moved) * bsps/arm/lpc24xx/start/linkcmds.lpc24xx_ncs_rom_ext (moved) * bsps/arm/lpc24xx/start/linkcmds.lpc24xx_ncs_rom_int (moved) * bsps/arm/lpc24xx/start/linkcmds.lpc24xx_plx800_ram (moved) * bsps/arm/lpc24xx/start/linkcmds.lpc24xx_plx800_rom_int (moved) * bsps/arm/lpc24xx/start/linkcmds.lpc40xx_ea_ram (moved) * bsps/arm/lpc24xx/start/linkcmds.lpc40xx_ea_rom_int (moved) * bsps/arm/lpc24xx/start/start-config-emc-dynamic.c (moved) * bsps/arm/lpc24xx/start/start-config-emc-static.c (moved) * bsps/arm/lpc24xx/start/start-config-mpu.c (moved) * bsps/arm/lpc24xx/start/start-config-pinsel.c (moved) * bsps/arm/lpc32xx/start/bsp_specs (moved) * bsps/arm/lpc32xx/start/bspreset.c (moved) * bsps/arm/lpc32xx/start/bspstart.c (moved) * bsps/arm/lpc32xx/start/bspstarthooks.c (moved) * bsps/arm/lpc32xx/start/linkcmds.lpc32xx (moved) * bsps/arm/lpc32xx/start/linkcmds.lpc32xx_mzx (moved) * bsps/arm/lpc32xx/start/linkcmds.lpc32xx_mzx_stage_1 (moved) * bsps/arm/lpc32xx/start/linkcmds.lpc32xx_mzx_stage_2 (moved) * bsps/arm/lpc32xx/start/linkcmds.lpc32xx_phycore (moved) * bsps/arm/raspberrypi/start/bsp_specs (moved) * bsps/arm/raspberrypi/start/bspgetworkarea.c (moved) * bsps/arm/raspberrypi/start/bspreset.c (moved) * bsps/arm/raspberrypi/start/bspsmp.c (moved) * bsps/arm/raspberrypi/start/bspsmp_init.c (moved) * bsps/arm/raspberrypi/start/bspstart.c (moved) * bsps/arm/raspberrypi/start/bspstarthooks.c (moved) * bsps/arm/raspberrypi/start/cmdline.c (moved) * bsps/arm/raspberrypi/start/linkcmds.in (moved) * bsps/arm/raspberrypi/start/mm_config_table.c (moved) * bsps/arm/realview-pbx-a9/start/bsp_specs (moved) * bsps/arm/realview-pbx-a9/start/bspreset.c (moved) * bsps/arm/realview-pbx-a9/start/bspsmp.c (moved) * bsps/arm/realview-pbx-a9/start/bspstart.c (moved) * bsps/arm/realview-pbx-a9/start/bspstarthooks.c (moved) * bsps/arm/realview-pbx-a9/start/fb-config.c (moved) * bsps/arm/realview-pbx-a9/start/linkcmds.realview_pbx_a9_qemu (moved) * bsps/arm/realview-pbx-a9/start/linkcmds.realview_pbx_a9_qemu_smp (moved) * bsps/arm/rtl22xx/start/bsp_specs (moved) * bsps/arm/rtl22xx/start/bspreset.c (moved) * bsps/arm/rtl22xx/start/bspstart.c (moved) * bsps/arm/rtl22xx/start/linkcmds (moved) * bsps/arm/shared/start/bsp-start-in-hyp-support.S (moved) * bsps/arm/shared/start/bsp-start-init-registers.S (moved) * bsps/arm/shared/start/bsp-start-memcpy.S (moved) * bsps/arm/shared/start/linkcmds.armv4 (moved) * bsps/arm/shared/start/linkcmds.armv7m (moved) * bsps/arm/shared/start/linkcmds.base (moved) * bsps/arm/smdk2410/start/bsp_specs (moved) * bsps/arm/smdk2410/start/bspidle.c (moved) * bsps/arm/smdk2410/start/bspreset.c (moved) * bsps/arm/smdk2410/start/bspstart.c (moved) * bsps/arm/smdk2410/start/linkcmds (moved) * bsps/arm/smdk2410/start/memmap.c (moved) * bsps/arm/stm32f4/start/bsp_specs (moved) * bsps/arm/stm32f4/start/bspreset.c (moved) * bsps/arm/stm32f4/start/bspstart.c (moved) * bsps/arm/stm32f4/start/bspstarthook.c (moved) * bsps/arm/stm32f4/start/io.c (moved) * bsps/arm/stm32f4/start/linkcmds.stm32f105rc (moved) * bsps/arm/stm32f4/start/linkcmds.stm32f4 (moved) * bsps/arm/stm32f4/start/rcc.c (moved) * bsps/arm/stm32f4/start/start-config-io.c (moved) * bsps/arm/tms570/start/bsp_specs (moved) * bsps/arm/tms570/start/bspreset.c (moved) * bsps/arm/tms570/start/bspstart.c (moved) * bsps/arm/tms570/start/bspstarthooks.c (moved) * bsps/arm/tms570/start/linkcmds.tms570ls3137_hdk (moved) * bsps/arm/tms570/start/linkcmds.tms570ls3137_hdk_intram (moved) * bsps/arm/tms570/start/linkcmds.tms570ls3137_hdk_sdram (moved) * bsps/arm/tms570/start/linkcmds.tms570ls3137_hdk_with_loader (moved) * bsps/arm/xilinx-zynq/start/bsp_specs (moved) * bsps/arm/xilinx-zynq/start/bspreset.c (moved) * bsps/arm/xilinx-zynq/start/bspsmp.c (moved) * bsps/arm/xilinx-zynq/start/bspstart.c (moved) * bsps/arm/xilinx-zynq/start/bspstarthooks.c (moved) * bsps/arm/xilinx-zynq/start/bspstartmmu.c (moved) * bsps/arm/xilinx-zynq/start/linkcmds.in (moved) * bsps/bfin/TLL6527M/start/bsp_specs (moved) * bsps/bfin/TLL6527M/start/bspstart.c (moved) * bsps/bfin/TLL6527M/start/linkcmds (moved) * bsps/bfin/bf537Stamp/start/bsp_specs (moved) * bsps/bfin/bf537Stamp/start/bspstart.c (moved) * bsps/bfin/bf537Stamp/start/linkcmds (moved) * bsps/bfin/eZKit533/start/bsp_specs (moved) * bsps/bfin/eZKit533/start/bspstart.c (moved) * bsps/bfin/eZKit533/start/linkcmds (moved) * bsps/epiphany/epiphany_sim/start/bsp_specs (moved) * bsps/epiphany/epiphany_sim/start/linkcmds (moved) * bsps/i386/pc386/start/bsp_fatal_halt.c (moved) * bsps/i386/pc386/start/bsp_specs (moved) * bsps/i386/pc386/start/bspcmdline.c (moved) * bsps/i386/pc386/start/bspgetworkarea.c (moved) * bsps/i386/pc386/start/bspidle.S (moved) * bsps/i386/pc386/start/bspreset.c (moved) * bsps/i386/pc386/start/bspstart.c (moved) * bsps/i386/pc386/start/ldsegs.S (moved) * bsps/i386/pc386/start/linkcmds (moved) * bsps/lm32/lm32_evr/start/bsp_specs (moved) * bsps/lm32/lm32_evr/start/linkcmds (moved) * bsps/lm32/milkymist/start/bsp_specs (moved) * bsps/lm32/milkymist/start/bspclean.c (moved) * bsps/lm32/milkymist/start/linkcmds (moved) * bsps/lm32/shared/start/bspreset.c (moved) * bsps/lm32/shared/start/bspstart.c (moved) * bsps/m32c/m32cbsp/start/bsp_specs (moved) * bsps/m32c/m32cbsp/start/bspstart.c (moved) * bsps/m32c/m32cbsp/start/crtn.S (moved) * bsps/m32c/m32cbsp/start/linkcmds (moved) * bsps/m68k/av5282/start/bsp_specs (moved) * bsps/m68k/av5282/start/bspstart.c (moved) * bsps/m68k/av5282/start/init5282.c (moved) * bsps/m68k/av5282/start/linkcmds (moved) * bsps/m68k/av5282/start/linkcmdsflash (moved) * bsps/m68k/av5282/start/linkcmdsram (moved) * bsps/m68k/csb360/start/bsp_specs (moved) * bsps/m68k/csb360/start/init5272.c (moved) * bsps/m68k/csb360/start/linkcmds (moved) * bsps/m68k/gen68340/start/bsp_specs (moved) * bsps/m68k/gen68340/start/dumpanic.c (moved) * bsps/m68k/gen68340/start/init68340.c (moved) * bsps/m68k/gen68340/start/linkcmds (moved) * bsps/m68k/gen68360/start/alloc360.c (moved) * bsps/m68k/gen68360/start/bsp_specs (moved) * bsps/m68k/gen68360/start/init68360.c (moved) * bsps/m68k/gen68360/start/linkcmds (moved) * bsps/m68k/gen68360/start/linkcmds.bootp (moved) * bsps/m68k/gen68360/start/linkcmds.prom (moved) * bsps/m68k/genmcf548x/start/bsp_specs (moved) * bsps/m68k/genmcf548x/start/bspstart.c (moved) * bsps/m68k/genmcf548x/start/init548x.c (moved) * bsps/m68k/genmcf548x/start/linkcmds.COBRA5475 (moved) * bsps/m68k/genmcf548x/start/linkcmds.m5484FireEngine (moved) * bsps/m68k/genmcf548x/start/linkcmds.m5484FireEngine.flash (moved) * bsps/m68k/mcf5206elite/start/bsp_specs (moved) * bsps/m68k/mcf5206elite/start/gdbinit (moved) * bsps/m68k/mcf5206elite/start/init5206e.c (moved) * bsps/m68k/mcf5206elite/start/linkcmds (moved) * bsps/m68k/mcf5206elite/start/linkcmds.flash (moved) * bsps/m68k/mcf52235/start/bsp_specs (moved) * bsps/m68k/mcf52235/start/bspgetcpuclockspeed.c (moved) * bsps/m68k/mcf52235/start/cfinit.c (moved) * bsps/m68k/mcf52235/start/init52235.c (moved) * bsps/m68k/mcf52235/start/linkcmds (moved) * bsps/m68k/mcf5225x/start/bsp_specs (moved) * bsps/m68k/mcf5225x/start/bspclean.c (moved) * bsps/m68k/mcf5225x/start/bspstart.c (moved) * bsps/m68k/mcf5225x/start/init5225x.c (moved) * bsps/m68k/mcf5225x/start/linkcmds (moved) * bsps/m68k/mcf5235/start/bsp_specs (moved) * bsps/m68k/mcf5235/start/bspgetcpuclockspeed.c (moved) * bsps/m68k/mcf5235/start/bspstart.c (moved) * bsps/m68k/mcf5235/start/copyvectors.c (moved) * bsps/m68k/mcf5235/start/init5235.c (moved) * bsps/m68k/mcf5235/start/linkcmds (moved) * bsps/m68k/mcf5235/start/linkcmdsflash (moved) * bsps/m68k/mcf5235/start/linkcmdsram (moved) * bsps/m68k/mcf5329/start/bsp_specs (moved) * bsps/m68k/mcf5329/start/bspstart.c (moved) * bsps/m68k/mcf5329/start/cfinit.c (moved) * bsps/m68k/mcf5329/start/init5329.c (moved) * bsps/m68k/mcf5329/start/linkcmds (moved) * bsps/m68k/mcf5329/start/linkcmdsflash (moved) * bsps/m68k/mrm332/start/bsp_specs (moved) * bsps/m68k/mrm332/start/linkcmds (moved) * bsps/m68k/mrm332/start/start_c.c (moved) * bsps/m68k/mvme147/start/bsp_specs (moved) * bsps/m68k/mvme147/start/bspclean.c (moved) * bsps/m68k/mvme147/start/bspstart.c (moved) * bsps/m68k/mvme147/start/linkcmds (moved) * bsps/m68k/mvme147s/start/bsp_specs (moved) * bsps/m68k/mvme147s/start/bspstart.c (moved) * bsps/m68k/mvme147s/start/linkcmds (moved) * bsps/m68k/mvme162/start/bsp_specs (moved) * bsps/m68k/mvme162/start/bspclean.c (moved) * bsps/m68k/mvme162/start/bspstart.c (moved) * bsps/m68k/mvme162/start/linkcmds (moved) * bsps/m68k/mvme162/start/page_table.c (moved) * bsps/m68k/mvme167/start/bsp_specs (moved) * bsps/m68k/mvme167/start/bspclean.c (moved) * bsps/m68k/mvme167/start/bspstart.c (moved) * bsps/m68k/mvme167/start/linkcmds (moved) * bsps/m68k/mvme167/start/page_table.c (moved) * bsps/m68k/shared/start/linkcmds.base (moved) * bsps/m68k/uC5282/start/bsp_specs (moved) * bsps/m68k/uC5282/start/bspclean.c (moved) * bsps/m68k/uC5282/start/bspreset.c (moved) * bsps/m68k/uC5282/start/bspstart.c (moved) * bsps/m68k/uC5282/start/init5282.c (moved) * bsps/m68k/uC5282/start/linkcmds (moved) * bsps/mips/csb350/start/bsp_specs (moved) * bsps/mips/csb350/start/bspreset.c (moved) * bsps/mips/csb350/start/bspstart.c (moved) * bsps/mips/csb350/start/linkcmds (moved) * bsps/mips/hurricane/start/bsp_specs (moved) * bsps/mips/hurricane/start/bspstart.c (moved) * bsps/mips/hurricane/start/ghlinkcmds (moved) * bsps/mips/hurricane/start/inittlb.c (moved) * bsps/mips/hurricane/start/linkcmds (moved) * bsps/mips/hurricane/start/usc.S (moved) * bsps/mips/jmr3904/start/bsp_specs (moved) * bsps/mips/jmr3904/start/bspstart.c (moved) * bsps/mips/jmr3904/start/linkcmds (moved) * bsps/mips/malta/start/bsp_specs (moved) * bsps/mips/malta/start/bspreset.c (moved) * bsps/mips/malta/start/bspstart.c (moved) * bsps/mips/malta/start/inittlb.c (moved) * bsps/mips/malta/start/linkcmds (moved) * bsps/mips/malta/start/simple_access.c (moved) * bsps/mips/rbtx4925/start/bsp_specs (moved) * bsps/mips/rbtx4925/start/bspstart.c (moved) * bsps/mips/rbtx4925/start/idttlb.S (moved) * bsps/mips/rbtx4925/start/inittlb.c (moved) * bsps/mips/rbtx4925/start/linkcmds (moved) * bsps/mips/rbtx4938/start/bsp_specs (moved) * bsps/mips/rbtx4938/start/bspstart.c (moved) * bsps/mips/rbtx4938/start/inittlb.c (moved) * bsps/mips/rbtx4938/start/linkcmds (moved) * bsps/mips/shared/start/idtmem.S (moved) * bsps/mips/shared/start/idttlb.S (moved) * bsps/moxie/moxiesim/start/bsp_specs (moved) * bsps/moxie/moxiesim/start/linkcmds (moved) * bsps/nios2/nios2_iss/start/bsp_specs (moved) * bsps/nios2/nios2_iss/start/bspstart.c (moved) * bsps/nios2/nios2_iss/start/linkcmds (moved) * bsps/nios2/nios2_iss/start/main.c (moved) * bsps/nios2/nios2_iss/start/setvec.c (moved) * bsps/no_cpu/no_bsp/start/bsp_specs (moved) * bsps/no_cpu/no_bsp/start/bspstart.c (moved) * bsps/no_cpu/no_bsp/start/linkcmds (moved) * bsps/no_cpu/no_bsp/start/setvec.c (moved) * bsps/or1k/generic_or1k/start/bsp_specs (moved) * bsps/or1k/generic_or1k/start/bspstart.c (moved) * bsps/or1k/generic_or1k/start/linkcmds (moved) * bsps/or1k/shared/start/linkcmds.base (moved) * bsps/powerpc/beatnik/start/bsp_specs (moved) * bsps/powerpc/beatnik/start/bspclean.c (moved) * bsps/powerpc/beatnik/start/bspreset.c (moved) * bsps/powerpc/beatnik/start/bspstart.c (moved) * bsps/powerpc/beatnik/start/i2c_init.c (moved) * bsps/powerpc/beatnik/start/linkcmds (moved) * bsps/powerpc/gen5200/start/bestcomm.c (moved) * bsps/powerpc/gen5200/start/bsp_specs (moved) * bsps/powerpc/gen5200/start/bspreset.c (moved) * bsps/powerpc/gen5200/start/bspstart.c (moved) * bsps/powerpc/gen5200/start/cpuinit.c (moved) * bsps/powerpc/gen5200/start/linkcmds.brs5l (moved) * bsps/powerpc/gen5200/start/linkcmds.brs6l (moved) * bsps/powerpc/gen5200/start/linkcmds.dp2 (moved) * bsps/powerpc/gen5200/start/linkcmds.gen5200_base (moved) * bsps/powerpc/gen5200/start/linkcmds.icecube (moved) * bsps/powerpc/gen5200/start/linkcmds.pm520_cr825 (moved) * bsps/powerpc/gen5200/start/linkcmds.pm520_ze30 (moved) * bsps/powerpc/gen5200/start/uboot_support.c (moved) * bsps/powerpc/gen83xx/start/bsp_specs (moved) * bsps/powerpc/gen83xx/start/bspreset.c (moved) * bsps/powerpc/gen83xx/start/bsprestart.c (moved) * bsps/powerpc/gen83xx/start/bspstart.c (moved) * bsps/powerpc/gen83xx/start/cpuinit.c (moved) * bsps/powerpc/gen83xx/start/linkcmds (moved) * bsps/powerpc/gen83xx/start/linkcmds.br_uid (moved) * bsps/powerpc/gen83xx/start/linkcmds.hsc_cm01 (moved) * bsps/powerpc/gen83xx/start/linkcmds.mpc8309som (moved) * bsps/powerpc/gen83xx/start/linkcmds.mpc8313erdb (moved) * bsps/powerpc/gen83xx/start/linkcmds.mpc8349eamds (moved) * bsps/powerpc/gen83xx/start/linkcmds.mpc83xx (moved) * bsps/powerpc/gen83xx/start/uboot_support.c (moved) * bsps/powerpc/haleakala/start/bsp_specs (moved) * bsps/powerpc/haleakala/start/bspstart.c (moved) * bsps/powerpc/haleakala/start/linkcmds (moved) * bsps/powerpc/motorola_powerpc/start/bsp_specs (moved) * bsps/powerpc/motorola_powerpc/start/bspreset.c (moved) * bsps/powerpc/motorola_powerpc/start/linkcmds (moved) * bsps/powerpc/mpc55xxevb/start/bsp_specs (moved) * bsps/powerpc/mpc55xxevb/start/bspgetworkarea.c (moved) * bsps/powerpc/mpc55xxevb/start/bspreset.c (moved) * bsps/powerpc/mpc55xxevb/start/bspstart.c (moved) * bsps/powerpc/mpc55xxevb/start/exc-vector-base.S (moved) * bsps/powerpc/mpc55xxevb/start/get-system-clock.c (moved) * bsps/powerpc/mpc55xxevb/start/idle-thread.c (moved) * bsps/powerpc/mpc55xxevb/start/linkcmds (moved) * bsps/powerpc/mpc55xxevb/start/linkcmds.gwlcfm (moved) * bsps/powerpc/mpc55xxevb/start/linkcmds.mpc5566evb (moved) * bsps/powerpc/mpc55xxevb/start/linkcmds.mpc5566evb_spe (moved) * bsps/powerpc/mpc55xxevb/start/linkcmds.mpc55xx (moved) * bsps/powerpc/mpc55xxevb/start/linkcmds.mpc5643l_dpu (moved) * bsps/powerpc/mpc55xxevb/start/linkcmds.mpc5643l_evb (moved) * bsps/powerpc/mpc55xxevb/start/linkcmds.mpc5668g (moved) * bsps/powerpc/mpc55xxevb/start/linkcmds.mpc5674f_ecu508 (moved) * bsps/powerpc/mpc55xxevb/start/linkcmds.mpc5674f_ecu508_app (moved) * bsps/powerpc/mpc55xxevb/start/linkcmds.mpc5674f_ecu508_boot (moved) * bsps/powerpc/mpc55xxevb/start/linkcmds.mpc5674f_rsm6 (moved) * bsps/powerpc/mpc55xxevb/start/linkcmds.mpc5674f_rsm6_base (moved) * bsps/powerpc/mpc55xxevb/start/linkcmds.mpc5674fevb (moved) * bsps/powerpc/mpc55xxevb/start/linkcmds.mpc5674fevb_spe (moved) * bsps/powerpc/mpc55xxevb/start/linkcmds.phycore_mpc5554 (moved) * bsps/powerpc/mpc55xxevb/start/restart.c (moved) * bsps/powerpc/mpc55xxevb/start/sd-card-init.c (moved) * bsps/powerpc/mpc55xxevb/start/start-cache.S (moved) * bsps/powerpc/mpc55xxevb/start/start-clock.c (moved) * bsps/powerpc/mpc55xxevb/start/start-config-clock.c (moved) * bsps/powerpc/mpc55xxevb/start/start-config-ebi-cs-cal.c (moved) * bsps/powerpc/mpc55xxevb/start/start-config-ebi-cs.c (moved) * bsps/powerpc/mpc55xxevb/start/start-config-ebi.c (moved) * bsps/powerpc/mpc55xxevb/start/start-config-mmu-early.c (moved) * bsps/powerpc/mpc55xxevb/start/start-config-mmu.c (moved) * bsps/powerpc/mpc55xxevb/start/start-config-siu-pcr.c (moved) * bsps/powerpc/mpc55xxevb/start/start-early.c (moved) * bsps/powerpc/mpc55xxevb/start/start-flash.S (moved) * bsps/powerpc/mpc55xxevb/start/start-prologue.c (moved) * bsps/powerpc/mpc55xxevb/start/start-watchdog.c (moved) * bsps/powerpc/mpc8260ads/start/bsp_specs (moved) * bsps/powerpc/mpc8260ads/start/bspstart.c (moved) * bsps/powerpc/mpc8260ads/start/cpuinit.c (moved) * bsps/powerpc/mpc8260ads/start/linkcmds (moved) * bsps/powerpc/mvme3100/start/bsp_specs (moved) * bsps/powerpc/mvme3100/start/bspstart.c (moved) * bsps/powerpc/mvme3100/start/linkcmds (moved) * bsps/powerpc/mvme3100/start/misc.c (moved) * bsps/powerpc/mvme5500/start/bootpstuff.c (moved) * bsps/powerpc/mvme5500/start/bsp_specs (moved) * bsps/powerpc/mvme5500/start/bspclean.c (moved) * bsps/powerpc/mvme5500/start/bspreset.c (moved) * bsps/powerpc/mvme5500/start/bspstart.c (moved) * bsps/powerpc/mvme5500/start/linkcmds (moved) * bsps/powerpc/mvme5500/start/pgtbl_activate.c (moved) * bsps/powerpc/psim/start/bsp_specs (moved) * bsps/powerpc/psim/start/bspstart.c (moved) * bsps/powerpc/psim/start/device-tree (moved) * bsps/powerpc/psim/start/linkcmds (moved) * bsps/powerpc/qemuppc/start/bsp_specs (moved) * bsps/powerpc/qemuppc/start/bspstart.c (moved) * bsps/powerpc/qemuppc/start/cmain.c (moved) * bsps/powerpc/qemuppc/start/linkcmds (moved) * bsps/powerpc/qoriq/start/bsp_specs (moved) * bsps/powerpc/qoriq/start/bspreset.c (moved) * bsps/powerpc/qoriq/start/bsprestart.c (moved) * bsps/powerpc/qoriq/start/bspsmp.c (moved) * bsps/powerpc/qoriq/start/bspstart.c (moved) * bsps/powerpc/qoriq/start/epapr_hcalls.S (moved) * bsps/powerpc/qoriq/start/l1cache.S (moved) * bsps/powerpc/qoriq/start/l2cache.S (moved) * bsps/powerpc/qoriq/start/linkcmds.qoriq_core_0 (moved) * bsps/powerpc/qoriq/start/linkcmds.qoriq_core_1 (moved) * bsps/powerpc/qoriq/start/linkcmds.qoriq_e500 (moved) * bsps/powerpc/qoriq/start/linkcmds.qoriq_e6500_32 (moved) * bsps/powerpc/qoriq/start/linkcmds.qoriq_e6500_64 (moved) * bsps/powerpc/qoriq/start/mmu-config.c (moved) * bsps/powerpc/qoriq/start/mmu-tlb1.S (moved) * bsps/powerpc/qoriq/start/mmu.c (moved) * bsps/powerpc/qoriq/start/portal.c (moved) * bsps/powerpc/qoriq/start/restart.S (moved) * bsps/powerpc/shared/start/bspgetworkarea.c (moved) * bsps/powerpc/shared/start/bspidle.c (moved) * bsps/powerpc/shared/start/linkcmds.base (moved) * bsps/powerpc/shared/start/linkcmds.share (moved) * bsps/powerpc/shared/start/pgtbl_activate.c (moved) * bsps/powerpc/shared/start/pgtbl_setup.c (moved) * bsps/powerpc/shared/start/ppc_idle.c (moved) * bsps/powerpc/shared/start/probeMemEnd.c (moved) * bsps/powerpc/shared/start/sbrk.c (moved) * bsps/powerpc/shared/start/zerobss.c (moved) * bsps/powerpc/ss555/start/bsp_specs (moved) * bsps/powerpc/ss555/start/bspstart.c (moved) * bsps/powerpc/ss555/start/iss555.c (moved) * bsps/powerpc/ss555/start/linkcmds (moved) * bsps/powerpc/ss555/start/tm27supp.c (moved) * bsps/powerpc/t32mppc/start/bsp_specs (moved) * bsps/powerpc/t32mppc/start/bspreset.c (moved) * bsps/powerpc/t32mppc/start/bspstart.c (moved) * bsps/powerpc/t32mppc/start/linkcmds.t32mppc (moved) * bsps/powerpc/tqm8xx/start/bsp_specs (moved) * bsps/powerpc/tqm8xx/start/bspgetworkarea.c (moved) * bsps/powerpc/tqm8xx/start/bspstart.c (moved) * bsps/powerpc/tqm8xx/start/cpuinit.c (moved) * bsps/powerpc/tqm8xx/start/linkcmds (moved) * bsps/powerpc/tqm8xx/start/mmutlbtab.c (moved) * bsps/powerpc/virtex/start/bsp_specs (moved) * bsps/powerpc/virtex/start/bspstart.c (moved) * bsps/powerpc/virtex/start/linkcmds.in (moved) * bsps/powerpc/virtex4/start/bsp_specs (moved) * bsps/powerpc/virtex4/start/bspclean.c (moved) * bsps/powerpc/virtex4/start/bspstart.c (moved) * bsps/powerpc/virtex4/start/dummy_console.c (moved) * bsps/powerpc/virtex4/start/linkcmds (moved) * bsps/powerpc/virtex5/start/bsp_specs (moved) * bsps/powerpc/virtex5/start/bspclean.c (moved) * bsps/powerpc/virtex5/start/bspstart.c (moved) * bsps/powerpc/virtex5/start/dummy_console.c (moved) * bsps/powerpc/virtex5/start/linkcmds (moved) * bsps/riscv/riscv_generic/start/bsp_fatal_halt.c (moved) * bsps/riscv/riscv_generic/start/bsp_specs (moved) * bsps/riscv/riscv_generic/start/linkcmds (moved) * bsps/sh/gensh1/start/bsp_specs (moved) * bsps/sh/gensh1/start/cpu_asm.c (moved) * bsps/sh/gensh1/start/ispsh7032.c (moved) * bsps/sh/gensh1/start/linkcmds (moved) * bsps/sh/gensh2/start/bsp_specs (moved) * bsps/sh/gensh2/start/cpu_asm.c (moved) * bsps/sh/gensh2/start/hw_init.c (moved) * bsps/sh/gensh2/start/ispsh7045.c (moved) * bsps/sh/gensh2/start/linkcmds (moved) * bsps/sh/gensh2/start/linkcmds.ram (moved) * bsps/sh/gensh2/start/linkcmds.rom (moved) * bsps/sh/gensh4/start/bsp_specs (moved) * bsps/sh/gensh4/start/cpu_asm.c (moved) * bsps/sh/gensh4/start/ispsh7750.c (moved) * bsps/sh/gensh4/start/linkcmds (moved) * bsps/sh/gensh4/start/linkcmds.rom (moved) * bsps/sh/gensh4/start/linkcmds.rom2ram (moved) * bsps/sh/shared/start/bspstart.c (moved) * bsps/sh/shsim/start/bsp_specs (moved) * bsps/sh/shsim/start/cpu_asm.c (moved) * bsps/sh/shsim/start/ispshgdb.c (moved) * bsps/sh/shsim/start/linkcmds (moved) * bsps/sh/shsim/start/sysexit.c (moved) * bsps/sparc/erc32/start/boardinit.S (moved) * bsps/sparc/erc32/start/bsp_specs (moved) * bsps/sparc/erc32/start/bspdelay.c (moved) * bsps/sparc/erc32/start/bspidle.c (moved) * bsps/sparc/erc32/start/erc32mec.c (moved) * bsps/sparc/erc32/start/linkcmds (moved) * bsps/sparc/erc32/start/setvec.c (moved) * bsps/sparc/erc32/start/spurious.c (moved) * bsps/sparc/leon2/start/bsp_specs (moved) * bsps/sparc/leon2/start/bspdelay.c (moved) * bsps/sparc/leon2/start/bspidle.c (moved) * bsps/sparc/leon2/start/bspstart.c (moved) * bsps/sparc/leon2/start/linkcmds (moved) * bsps/sparc/leon2/start/linkcmds.at697f (moved) * bsps/sparc/leon2/start/linkcmds.leon2 (moved) * bsps/sparc/leon2/start/setvec.c (moved) * bsps/sparc/leon2/start/spurious.c (moved) * bsps/sparc/leon3/start/bsp_fatal_halt.c (moved) * bsps/sparc/leon3/start/bsp_specs (moved) * bsps/sparc/leon3/start/bspclean.c (moved) * bsps/sparc/leon3/start/bspdelay.c (moved) * bsps/sparc/leon3/start/bspidle.S (moved) * bsps/sparc/leon3/start/bspsmp.c (moved) * bsps/sparc/leon3/start/bspstart.c (moved) * bsps/sparc/leon3/start/cpucounter.c (moved) * bsps/sparc/leon3/start/eirq.c (moved) * bsps/sparc/leon3/start/linkcmds.gr712rc (moved) * bsps/sparc/leon3/start/linkcmds.gr740 (moved) * bsps/sparc/leon3/start/linkcmds.leon3 (moved) * bsps/sparc/leon3/start/linkcmds.ut699 (moved) * bsps/sparc/leon3/start/linkcmds.ut700 (moved) * bsps/sparc/leon3/start/setvec.c (moved) * bsps/sparc/leon3/start/spurious.c (moved) * bsps/sparc/shared/start/bsp_fatal_exit.c (moved) * bsps/sparc/shared/start/bsp_fatal_halt.c (moved) * bsps/sparc/shared/start/bspgetworkarea.c (moved) * bsps/sparc/shared/start/linkcmds.base (moved) * bsps/sparc64/niagara/start/bsp_specs (moved) * bsps/sparc64/niagara/start/bspclean.c (moved) * bsps/sparc64/niagara/start/m5op.h (moved) * bsps/sparc64/niagara/start/m5op_sparc.S (moved) * bsps/sparc64/niagara/start/m5ops.h (moved) * bsps/sparc64/shared/start/linkcmds (moved) * bsps/sparc64/shared/start/setvec.c (moved) * bsps/sparc64/usiii/start/bsp_specs (moved) * bsps/v850/gdbv850sim/start/bsp_specs (moved) * bsps/v850/gdbv850sim/start/bspreset.c (moved) * bsps/v850/gdbv850sim/start/linkcmds (moved) * bsps/v850/gdbv850sim/start/trap.S (moved) * c/src/aclocal/bsp-linkcmds.m4 (modified) * c/src/aclocal/prog-cc.m4 (modified) * c/src/lib/libbsp/arm/Makefile.am (modified) * c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am (modified) * c/src/lib/libbsp/arm/atsam/Makefile.am (modified) * c/src/lib/libbsp/arm/atsam/configure.ac (modified) * c/src/lib/libbsp/arm/beagle/Makefile.am (modified) * c/src/lib/libbsp/arm/csb336/Makefile.am (modified) * c/src/lib/libbsp/arm/csb337/Makefile.am (modified) * c/src/lib/libbsp/arm/edb7312/Makefile.am (modified) * c/src/lib/libbsp/arm/gdbarmsim/Makefile.am (modified) * c/src/lib/libbsp/arm/gumstix/Makefile.am (modified) * c/src/lib/libbsp/arm/imx/Makefile.am (modified) * c/src/lib/libbsp/arm/lm3s69xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc176x/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc24xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc32xx/Makefile.am (modified) * c/src/lib/libbsp/arm/raspberrypi/Makefile.am (modified) * c/src/lib/libbsp/arm/raspberrypi/configure.ac (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am (modified) * c/src/lib/libbsp/arm/rtl22xx/Makefile.am (modified) * c/src/lib/libbsp/arm/smdk2410/Makefile.am (modified) * c/src/lib/libbsp/arm/stm32f4/Makefile.am (modified) * c/src/lib/libbsp/arm/tms570/Makefile.am (modified) * c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am (modified) * c/src/lib/libbsp/arm/xilinx-zynq/configure.ac (modified) * c/src/lib/libbsp/bfin/TLL6527M/Makefile.am (modified) * c/src/lib/libbsp/bfin/bf537Stamp/Makefile.am (modified) * c/src/lib/libbsp/bfin/eZKit533/Makefile.am (modified) * c/src/lib/libbsp/epiphany/epiphany_sim/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/lm32/lm32_evr/Makefile.am (modified) * c/src/lib/libbsp/lm32/milkymist/Makefile.am (modified) * c/src/lib/libbsp/m32c/m32cbsp/Makefile.am (modified) * c/src/lib/libbsp/m68k/Makefile.am (modified) * c/src/lib/libbsp/m68k/av5282/Makefile.am (modified) * c/src/lib/libbsp/m68k/csb360/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/Makefile.am (modified) * c/src/lib/libbsp/m68k/genmcf548x/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5206elite/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf52235/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5225x/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5235/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5329/Makefile.am (modified) * c/src/lib/libbsp/m68k/mrm332/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/Makefile.am (modified) * c/src/lib/libbsp/m68k/uC5282/Makefile.am (modified) * c/src/lib/libbsp/mips/csb350/Makefile.am (modified) * c/src/lib/libbsp/mips/hurricane/Makefile.am (modified) * c/src/lib/libbsp/mips/jmr3904/Makefile.am (modified) * c/src/lib/libbsp/mips/malta/Makefile.am (modified) * c/src/lib/libbsp/mips/rbtx4925/Makefile.am (modified) * c/src/lib/libbsp/mips/rbtx4938/Makefile.am (modified) * c/src/lib/libbsp/moxie/moxiesim/Makefile.am (modified) * c/src/lib/libbsp/nios2/nios2_iss/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/Makefile.am (modified) * c/src/lib/libbsp/or1k/generic_or1k/Makefile.am (modified) * c/src/lib/libbsp/powerpc/beatnik/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen5200/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen83xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/haleakala/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme3100/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme5500/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qemuppc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qoriq/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ss555/Makefile.am (modified) * c/src/lib/libbsp/powerpc/t32mppc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/tqm8xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex/configure.ac (modified) * c/src/lib/libbsp/powerpc/virtex4/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex5/Makefile.am (modified) * c/src/lib/libbsp/riscv/riscv_generic/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh4/Makefile.am (modified) * c/src/lib/libbsp/sh/shsim/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/lib/libbsp/sparc64/niagara/Makefile.am (modified) * c/src/lib/libbsp/sparc64/usiii/Makefile.am (modified) * c/src/lib/libbsp/v850/gdbv850sim/Makefile.am (modified) * testsuites/aclocal/prog-cc.m4 (modified) * testsuites/aclocal/rtems-bsp-linkcmds.m4 (modified) bsps: Move startup files to bsps Adjust build support files to new ... Thu, 19 Apr 2018 04:28:01 GMT Sebastian Huber [d7d66d7] * bsps/arm/altera-cyclone-v/console/console-config.c (moved) * bsps/arm/atsam/console/console.c (moved) * bsps/arm/atsam/console/debug-console.c (moved) * bsps/arm/beagle/console/console-config.c (moved) * bsps/arm/csb336/console/uart.c (moved) * bsps/arm/csb337/console/dbgu.c (moved) * bsps/arm/csb337/console/fbcons.c (moved) * bsps/arm/csb337/console/sed1356.c (moved) * bsps/arm/csb337/console/uarts.c (moved) * bsps/arm/csb337/console/usart.c (moved) * bsps/arm/edb7312/console/uart.c (moved) * bsps/arm/gdbarmsim/console/console-io.c (moved) * bsps/arm/gumstix/console/ffuart.c (moved) * bsps/arm/gumstix/console/uarts.c (moved) * bsps/arm/imx/console/console-config.c (moved) * bsps/arm/lm3s69xx/console/console-config.c (moved) * bsps/arm/lm3s69xx/console/uart.c (moved) * bsps/arm/lpc176x/console/console-config.c (moved) * bsps/arm/lpc24xx/console/console-config.c (moved) * bsps/arm/lpc24xx/console/uart-probe-1.c (moved) * bsps/arm/lpc24xx/console/uart-probe-2.c (moved) * bsps/arm/lpc24xx/console/uart-probe-3.c (moved) * bsps/arm/lpc32xx/console/console-config.c (moved) * bsps/arm/lpc32xx/console/hsu.c (moved) * bsps/arm/raspberrypi/console/console-config.c (moved) * bsps/arm/raspberrypi/console/console_select.c (moved) * bsps/arm/raspberrypi/console/fb.c (moved) * bsps/arm/raspberrypi/console/fbcons.c (moved) * bsps/arm/raspberrypi/console/font_data.h (moved) * bsps/arm/raspberrypi/console/outch.c (moved) * bsps/arm/raspberrypi/console/usart.c (moved) * bsps/arm/realview-pbx-a9/console/console-config.c (moved) * bsps/arm/rtl22xx/console/lpc22xx_uart.h (moved) * bsps/arm/rtl22xx/console/uart.c (moved) * bsps/arm/smdk2410/console/uart.c (moved) * bsps/arm/stm32f4/console/console-config.c (moved) * bsps/arm/stm32f4/console/usart.c (moved) * bsps/arm/tms570/console/printk-support.c (moved) * bsps/arm/tms570/console/tms570-sci.c (moved) * bsps/arm/xilinx-zynq/console/console-config.c (moved) * bsps/arm/xilinx-zynq/console/debug-console.c (moved) * bsps/arm/xilinx-zynq/console/zynq-uart.c (moved) * bsps/bfin/TLL6527M/console/console.c (moved) * bsps/bfin/bf537Stamp/console/console.c (moved) * bsps/bfin/eZKit533/console/console-io.c (moved) * bsps/epiphany/epiphany_sim/console/console-io.c (moved) * bsps/i386/pc386/console/conscfg.c (moved) * bsps/i386/pc386/console/console_control.c (moved) * bsps/i386/pc386/console/console_select.c (moved) * bsps/i386/pc386/console/defkeymap.c (moved) * bsps/i386/pc386/console/exar17d15x.c (moved) * bsps/i386/pc386/console/fb_cirrus.c (moved) * bsps/i386/pc386/console/fb_vesa_rm.c (moved) * bsps/i386/pc386/console/fb_vga.c (moved) * bsps/i386/pc386/console/gdb_select.c (moved) * bsps/i386/pc386/console/i386kbd.h (moved) * bsps/i386/pc386/console/inch.c (moved) * bsps/i386/pc386/console/kbd_parser.c (moved) * bsps/i386/pc386/console/keyboard.c (moved) * bsps/i386/pc386/console/outch.c (moved) * bsps/i386/pc386/console/pc_keyb.c (moved) * bsps/i386/pc386/console/printk_support.c (moved) * bsps/i386/pc386/console/ps2_mouse.c (moved) * bsps/i386/pc386/console/ps2_mouse.h (moved) * bsps/i386/pc386/console/rtd316.c (moved) * bsps/i386/pc386/console/serial_mouse_config.c (moved) * bsps/i386/pc386/console/uart_bus_pci.c (moved) * bsps/i386/pc386/console/vgacons.c (moved) * bsps/i386/pc386/console/vgainit.c (moved) * bsps/i386/pc386/console/videoAsm.S (moved) * bsps/i386/pc386/console/vt.c (moved) * bsps/lm32/shared/console/console.c (moved) * bsps/lm32/shared/console/uart.c (moved) * bsps/lm32/shared/console/uart.h (moved) * bsps/m32c/m32cbsp/console/console-io.c (moved) * bsps/m32c/m32cbsp/console/syscalls.S (moved) * bsps/m68k/av5282/console/console.c (moved) * bsps/m68k/csb360/console/console-io.c (moved) * bsps/m68k/gen68340/console/console.c (moved) * bsps/m68k/gen68340/console/m340uart.c (moved) * bsps/m68k/gen68360/console/console.c (moved) * bsps/m68k/genmcf548x/console/console.c (moved) * bsps/m68k/mcf5206elite/console/console.c (moved) * bsps/m68k/mcf52235/console/console.c (moved) * bsps/m68k/mcf52235/console/debugio.c (moved) * bsps/m68k/mcf5225x/console/console.c (moved) * bsps/m68k/mcf5225x/console/debugio.c (moved) * bsps/m68k/mcf5235/console/console.c (moved) * bsps/m68k/mcf5329/console/console.c (moved) * bsps/m68k/mrm332/console/console.c (moved) * bsps/m68k/mrm332/console/sci.c (moved) * bsps/m68k/mrm332/console/sci.h (moved) * bsps/m68k/mvme147/console/console.c (moved) * bsps/m68k/mvme162/console/console.c (moved) * bsps/m68k/mvme167/console/console-recording.h (moved) * bsps/m68k/mvme167/console/console.c (moved) * bsps/m68k/uC5282/console/console.c (moved) * bsps/mips/csb350/console/console-io.c (moved) * bsps/mips/hurricane/console/console.c (moved) * bsps/mips/jmr3904/console/console-io.c (moved) * bsps/mips/malta/console/conscfg.c (moved) * bsps/mips/malta/console/printk_support.c (moved) * bsps/mips/rbtx4925/console/console-io.c (moved) * bsps/mips/rbtx4938/console/console-io.c (moved) * bsps/mips/rbtx4938/console/yamon_api.h (moved) * bsps/moxie/moxiesim/console/console-io.c (moved) * bsps/moxie/moxiesim/console/syscalls.S (moved) * bsps/nios2/nios2_iss/console/console.c (moved) * bsps/no_cpu/no_bsp/console/console.c (moved) * bsps/or1k/generic_or1k/console/console-config.c (moved) * bsps/or1k/generic_or1k/console/uart.c (moved) * bsps/powerpc/gen5200/console/console.c (moved) * bsps/powerpc/gen83xx/console/console-config.c (moved) * bsps/powerpc/mpc55xxevb/console/console-config.c (moved) * bsps/powerpc/mpc55xxevb/console/console-esci.c (moved) * bsps/powerpc/mpc55xxevb/console/console-generic.c (moved) * bsps/powerpc/mpc55xxevb/console/console-linflex.c (moved) * bsps/powerpc/mpc8260ads/console/console.c (moved) * bsps/powerpc/psim/console/console-io.c (moved) * bsps/powerpc/psim/console/consupp.S (moved) * bsps/powerpc/qemuppc/console/console-io.c (moved) * bsps/powerpc/qoriq/console/console-config.c (moved) * bsps/powerpc/qoriq/console/uart-bridge-master.c (moved) * bsps/powerpc/qoriq/console/uart-bridge-slave.c (moved) * bsps/powerpc/shared/console/console.c (moved) * bsps/powerpc/shared/console/uart.c (moved) * bsps/powerpc/ss555/console/console.c (moved) * bsps/powerpc/t32mppc/console/console.c (moved) * bsps/powerpc/tqm8xx/console/console.c (moved) * bsps/powerpc/virtex/console/consolelite.c (moved) * bsps/riscv/riscv_generic/console/console-io.c (moved) * bsps/sh/gensh1/console/sci.c (moved) * bsps/sh/gensh2/console/config.c (moved) * bsps/sh/gensh2/console/sci.c (moved) * bsps/sh/gensh2/console/sci_termios.c (moved) * bsps/sh/gensh4/console/console.c (moved) * bsps/sh/gensh4/console/sh4uart.c (moved) * bsps/sh/shsim/console/console-debugio.c (moved) * bsps/sh/shsim/console/console-io.c (moved) * bsps/sh/shsim/console/console-support.S (moved) * bsps/shared/dev/serial/console-output-char.c (moved) * bsps/shared/dev/serial/console-polled.c (moved) * bsps/shared/dev/serial/console-termios-init.c (moved) * bsps/shared/dev/serial/console-termios.c (moved) * bsps/shared/dev/serial/getserialmouseps2.c (moved) * bsps/shared/dev/serial/printk-dummy.c (moved) * bsps/sparc/erc32/console/debugputs.c (moved) * bsps/sparc/erc32/console/erc32_console.c (moved) * bsps/sparc/leon2/console/console.c (moved) * bsps/sparc/leon2/console/debugputs.c (moved) * bsps/sparc/leon3/console/console.c (moved) * bsps/sparc/leon3/console/printk_support.c (moved) * bsps/sparc64/shared/console/conscfg.c (moved) * bsps/v850/gdbv850sim/console/console-io.c (moved) * c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am (modified) * c/src/lib/libbsp/arm/atsam/Makefile.am (modified) * c/src/lib/libbsp/arm/beagle/Makefile.am (modified) * c/src/lib/libbsp/arm/csb336/Makefile.am (modified) * c/src/lib/libbsp/arm/csb337/Makefile.am (modified) * c/src/lib/libbsp/arm/edb7312/Makefile.am (modified) * c/src/lib/libbsp/arm/gdbarmsim/Makefile.am (modified) * c/src/lib/libbsp/arm/gumstix/Makefile.am (modified) * c/src/lib/libbsp/arm/imx/Makefile.am (modified) * c/src/lib/libbsp/arm/lm3s69xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc176x/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc24xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc32xx/Makefile.am (modified) * c/src/lib/libbsp/arm/raspberrypi/Makefile.am (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am (modified) * c/src/lib/libbsp/arm/rtl22xx/Makefile.am (modified) * c/src/lib/libbsp/arm/smdk2410/Makefile.am (modified) * c/src/lib/libbsp/arm/stm32f4/Makefile.am (modified) * c/src/lib/libbsp/arm/tms570/Makefile.am (modified) * c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am (modified) * c/src/lib/libbsp/bfin/TLL6527M/Makefile.am (modified) * c/src/lib/libbsp/bfin/bf537Stamp/Makefile.am (modified) * c/src/lib/libbsp/bfin/eZKit533/Makefile.am (modified) * c/src/lib/libbsp/epiphany/epiphany_sim/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/lm32/lm32_evr/Makefile.am (modified) * c/src/lib/libbsp/m32c/m32cbsp/Makefile.am (modified) * c/src/lib/libbsp/m68k/av5282/Makefile.am (modified) * c/src/lib/libbsp/m68k/csb360/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/Makefile.am (modified) * c/src/lib/libbsp/m68k/genmcf548x/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5206elite/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf52235/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5225x/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5235/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5329/Makefile.am (modified) * c/src/lib/libbsp/m68k/mrm332/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/Makefile.am (modified) * c/src/lib/libbsp/m68k/uC5282/Makefile.am (modified) * c/src/lib/libbsp/mips/csb350/Makefile.am (modified) * c/src/lib/libbsp/mips/hurricane/Makefile.am (modified) * c/src/lib/libbsp/mips/jmr3904/Makefile.am (modified) * c/src/lib/libbsp/mips/malta/Makefile.am (modified) * c/src/lib/libbsp/mips/rbtx4925/Makefile.am (modified) * c/src/lib/libbsp/mips/rbtx4938/Makefile.am (modified) * c/src/lib/libbsp/moxie/moxiesim/Makefile.am (modified) * c/src/lib/libbsp/nios2/nios2_iss/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/Makefile.am (modified) * c/src/lib/libbsp/or1k/generic_or1k/Makefile.am (modified) * c/src/lib/libbsp/powerpc/beatnik/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen5200/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen83xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/haleakala/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme3100/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme5500/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qemuppc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qoriq/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ss555/Makefile.am (modified) * c/src/lib/libbsp/powerpc/t32mppc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/tqm8xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex4/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex5/Makefile.am (modified) * c/src/lib/libbsp/riscv/riscv_generic/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh4/Makefile.am (modified) * c/src/lib/libbsp/sh/shsim/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/lib/libbsp/sparc64/niagara/Makefile.am (modified) * c/src/lib/libbsp/sparc64/usiii/Makefile.am (modified) * c/src/lib/libbsp/v850/gdbv850sim/Makefile.am (modified) bsps: Move console drivers to bsps This patch is a part of the BSP ... Sat, 23 Dec 2017 07:18:56 GMT Chris Johns [2afb22b] * aclocal/rtems-bsp-includes.m4 (added) * aclocal/rtems-build-top.m4 (added) * aclocal/rtems-includes.m4 (added) * aclocal/rtems-source-top.m4 (added) * automake/host.am (modified) * automake/local.am (modified) * automake/subdirs.am (modified) * bootstrap (modified) * bsps/arm/altera-cyclone-v/headers.am (added) * bsps/arm/altera-cyclone-v/include/bsp.h (moved) * bsps/arm/altera-cyclone-v/include/bsp/alt_16550_uart.h (moved) * bsps/arm/altera-cyclone-v/include/bsp/alt_address_space.h (moved) * bsps/arm/altera-cyclone-v/include/bsp/alt_cache.h (moved) * bsps/arm/altera-cyclone-v/include/bsp/alt_clock_group.h (moved) * bsps/arm/altera-cyclone-v/include/bsp/alt_clock_manager.h (moved) * bsps/arm/altera-cyclone-v/include/bsp/alt_dma.h (moved) * bsps/arm/altera-cyclone-v/include/bsp/alt_dma_common.h (moved) * bsps/arm/altera-cyclone-v/include/bsp/alt_dma_program.h (moved) * bsps/arm/altera-cyclone-v/include/bsp/alt_generalpurpose_io.h (moved) * bsps/arm/altera-cyclone-v/include/bsp/alt_hwlibs_ver.h (moved) * bsps/arm/altera-cyclone-v/include/bsp/alt_i2c.h (moved) * bsps/arm/altera-cyclone-v/include/bsp/alt_interrupt_common.h (moved) * bsps/arm/altera-cyclone-v/include/bsp/alt_mpu_registers.h (moved) * bsps/arm/altera-cyclone-v/include/bsp/alt_qspi_private.h (moved) * bsps/arm/altera-cyclone-v/include/bsp/alt_reset_manager.h (moved) * bsps/arm/altera-cyclone-v/include/bsp/hwlib.h (moved) * bsps/arm/altera-cyclone-v/include/bsp/i2cdrv.h (moved) * bsps/arm/altera-cyclone-v/include/bsp/irq.h (moved) * bsps/arm/altera-cyclone-v/include/bsp/socal/alt_acpidmap.h (moved) * bsps/arm/altera-cyclone-v/include/bsp/socal/alt_clkmgr.h (moved) * bsps/arm/altera-cyclone-v/include/bsp/socal/alt_dmanonsecure.h (moved) * bsps/arm/altera-cyclone-v/include/bsp/socal/alt_dmasecure.h (moved) * bsps/arm/altera-cyclone-v/include/bsp/socal/alt_gpio.h (moved) * bsps/arm/altera-cyclone-v/include/bsp/socal/alt_i2c.h (moved) * bsps/arm/altera-cyclone-v/include/bsp/socal/alt_l3.h (moved) * bsps/arm/altera-cyclone-v/include/bsp/socal/alt_qspi.h (moved) * bsps/arm/altera-cyclone-v/include/bsp/socal/alt_qspidata.h (moved) * bsps/arm/altera-cyclone-v/include/bsp/socal/alt_rstmgr.h (moved) * bsps/arm/altera-cyclone-v/include/bsp/socal/alt_sdr.h (moved) * bsps/arm/altera-cyclone-v/include/bsp/socal/alt_sysmgr.h (moved) * bsps/arm/altera-cyclone-v/include/bsp/socal/alt_uart.h (moved) * bsps/arm/altera-cyclone-v/include/bsp/socal/hps.h (moved) * bsps/arm/altera-cyclone-v/include/bsp/socal/socal.h (moved) * bsps/arm/altera-cyclone-v/include/tm27.h (moved) * bsps/arm/atsam/headers.am (added) * bsps/arm/atsam/include/bsp.h (moved) * bsps/arm/atsam/include/bsp/atsam-clock-config.h (moved) * bsps/arm/atsam/include/bsp/atsam-i2c.h (moved) * bsps/arm/atsam/include/bsp/atsam-spi.h (moved) * bsps/arm/atsam/include/bsp/i2c.h (moved) * bsps/arm/atsam/include/bsp/irq.h (moved) * bsps/arm/atsam/include/bsp/pin-config.h (moved) * bsps/arm/atsam/include/bsp/power.h (moved) * bsps/arm/atsam/include/bsp/sc16is752.h (moved) * bsps/arm/atsam/include/bsp/spi.h (moved) * bsps/arm/atsam/include/libchip/chip.h (moved) * bsps/arm/atsam/include/libchip/compiler.h (moved) * bsps/arm/atsam/include/libchip/include/acc.h (moved) * bsps/arm/atsam/include/libchip/include/adc.h (moved) * bsps/arm/atsam/include/libchip/include/aes.h (moved) * bsps/arm/atsam/include/libchip/include/afe_dma.h (moved) * bsps/arm/atsam/include/libchip/include/afec.h (moved) * bsps/arm/atsam/include/libchip/include/chip.h (moved) * bsps/arm/atsam/include/libchip/include/dac_dma.h (moved) * bsps/arm/atsam/include/libchip/include/efc.h (moved) * bsps/arm/atsam/include/libchip/include/exceptions.h (moved) * bsps/arm/atsam/include/libchip/include/flashd.h (moved) * bsps/arm/atsam/include/libchip/include/gmac.h (moved) * bsps/arm/atsam/include/libchip/include/gmacd.h (moved) * bsps/arm/atsam/include/libchip/include/hsmci.h (moved) * bsps/arm/atsam/include/libchip/include/icm.h (moved) * bsps/arm/atsam/include/libchip/include/isi.h (moved) * bsps/arm/atsam/include/libchip/include/iso7816_4.h (moved) * bsps/arm/atsam/include/libchip/include/mcan.h (moved) * bsps/arm/atsam/include/libchip/include/mcid.h (moved) * bsps/arm/atsam/include/libchip/include/mediaLB.h (moved) * bsps/arm/atsam/include/libchip/include/mpu.h (moved) * bsps/arm/atsam/include/libchip/include/pio.h (moved) * bsps/arm/atsam/include/libchip/include/pio_capture.h (moved) * bsps/arm/atsam/include/libchip/include/pio_it.h (moved) * bsps/arm/atsam/include/libchip/include/pmc.h (moved) * bsps/arm/atsam/include/libchip/include/pwmc.h (moved) * bsps/arm/atsam/include/libchip/include/qspi.h (moved) * bsps/arm/atsam/include/libchip/include/qspi_dma.h (moved) * bsps/arm/atsam/include/libchip/include/rstc.h (moved) * bsps/arm/atsam/include/libchip/include/rtc.h (moved) * bsps/arm/atsam/include/libchip/include/rtt.h (moved) * bsps/arm/atsam/include/libchip/include/same70/component/component_acc.h (moved) * bsps/arm/atsam/include/libchip/include/same70/component/component_aes.h (moved) * bsps/arm/atsam/include/libchip/include/same70/component/component_afec.h (moved) * bsps/arm/atsam/include/libchip/include/same70/component/component_chipid.h (moved) * bsps/arm/atsam/include/libchip/include/same70/component/component_dacc.h (moved) * bsps/arm/atsam/include/libchip/include/same70/component/component_efc.h (moved) * bsps/arm/atsam/include/libchip/include/same70/component/component_gmac.h (moved) * bsps/arm/atsam/include/libchip/include/same70/component/component_gpbr.h (moved) * bsps/arm/atsam/include/libchip/include/same70/component/component_hsmci.h (moved) * bsps/arm/atsam/include/libchip/include/same70/component/component_icm.h (moved) * bsps/arm/atsam/include/libchip/include/same70/component/component_isi.h (moved) * bsps/arm/atsam/include/libchip/include/same70/component/component_matrix.h (moved) * bsps/arm/atsam/include/libchip/include/same70/component/component_mcan.h (moved) * bsps/arm/atsam/include/libchip/include/same70/component/component_pio.h (moved) * bsps/arm/atsam/include/libchip/include/same70/component/component_pmc.h (moved) * bsps/arm/atsam/include/libchip/include/same70/component/component_pwm.h (moved) * bsps/arm/atsam/include/libchip/include/same70/component/component_qspi.h (moved) * bsps/arm/atsam/include/libchip/include/same70/component/component_rstc.h (moved) * bsps/arm/atsam/include/libchip/include/same70/component/component_rswdt.h (moved) * bsps/arm/atsam/include/libchip/include/same70/component/component_rtc.h (moved) * bsps/arm/atsam/include/libchip/include/same70/component/component_rtt.h (moved) * bsps/arm/atsam/include/libchip/include/same70/component/component_sdramc.h (moved) * bsps/arm/atsam/include/libchip/include/same70/component/component_smc.h (moved) * bsps/arm/atsam/include/libchip/include/same70/component/component_spi.h (moved) * bsps/arm/atsam/include/libchip/include/same70/component/component_ssc.h (moved) * bsps/arm/atsam/include/libchip/include/same70/component/component_supc.h (moved) * bsps/arm/atsam/include/libchip/include/same70/component/component_tc.h (moved) * bsps/arm/atsam/include/libchip/include/same70/component/component_trng.h (moved) * bsps/arm/atsam/include/libchip/include/same70/component/component_twihs.h (moved) * bsps/arm/atsam/include/libchip/include/same70/component/component_uart.h (moved) * bsps/arm/atsam/include/libchip/include/same70/component/component_usart.h (moved) * bsps/arm/atsam/include/libchip/include/same70/component/component_usbhs.h (moved) * bsps/arm/atsam/include/libchip/include/same70/component/component_utmi.h (moved) * bsps/arm/atsam/include/libchip/include/same70/component/component_wdt.h (moved) * bsps/arm/atsam/include/libchip/include/same70/component/component_xdmac.h (moved) * bsps/arm/atsam/include/libchip/include/same70/pio/pio_same70j19.h (moved) * bsps/arm/atsam/include/libchip/include/same70/pio/pio_same70j20.h (moved) * bsps/arm/atsam/include/libchip/include/same70/pio/pio_same70j21.h (moved) * bsps/arm/atsam/include/libchip/include/same70/pio/pio_same70n19.h (moved) * bsps/arm/atsam/include/libchip/include/same70/pio/pio_same70n20.h (moved) * bsps/arm/atsam/include/libchip/include/same70/pio/pio_same70n21.h (moved) * bsps/arm/atsam/include/libchip/include/same70/pio/pio_same70q19.h (moved) * bsps/arm/atsam/include/libchip/include/same70/pio/pio_same70q20.h (moved) * bsps/arm/atsam/include/libchip/include/same70/pio/pio_same70q21.h (moved) * bsps/arm/atsam/include/libchip/include/same70/same70.h (moved) * bsps/arm/atsam/include/libchip/include/same70/same70j19.h (moved) * bsps/arm/atsam/include/libchip/include/same70/same70j20.h (moved) * bsps/arm/atsam/include/libchip/include/same70/same70j21.h (moved) * bsps/arm/atsam/include/libchip/include/same70/same70n19.h (moved) * bsps/arm/atsam/include/libchip/include/same70/same70n20.h (moved) * bsps/arm/atsam/include/libchip/include/same70/same70n21.h (moved) * bsps/arm/atsam/include/libchip/include/same70/same70q19.h (moved) * bsps/arm/atsam/include/libchip/include/same70/same70q20.h (moved) * bsps/arm/atsam/include/libchip/include/same70/same70q21.h (moved) * bsps/arm/atsam/include/libchip/include/same70/system_same70.h (moved) * bsps/arm/atsam/include/libchip/include/sams70/component/component_acc.h (moved) * bsps/arm/atsam/include/libchip/include/sams70/component/component_aes.h (moved) * bsps/arm/atsam/include/libchip/include/sams70/component/component_afec.h (moved) * bsps/arm/atsam/include/libchip/include/sams70/component/component_chipid.h (moved) * bsps/arm/atsam/include/libchip/include/sams70/component/component_dacc.h (moved) * bsps/arm/atsam/include/libchip/include/sams70/component/component_efc.h (moved) * bsps/arm/atsam/include/libchip/include/sams70/component/component_gpbr.h (moved) * bsps/arm/atsam/include/libchip/include/sams70/component/component_hsmci.h (moved) * bsps/arm/atsam/include/libchip/include/sams70/component/component_icm.h (moved) * bsps/arm/atsam/include/libchip/include/sams70/component/component_isi.h (moved) * bsps/arm/atsam/include/libchip/include/sams70/component/component_matrix.h (moved) * bsps/arm/atsam/include/libchip/include/sams70/component/component_pio.h (moved) * bsps/arm/atsam/include/libchip/include/sams70/component/component_pmc.h (moved) * bsps/arm/atsam/include/libchip/include/sams70/component/component_pwm.h (moved) * bsps/arm/atsam/include/libchip/include/sams70/component/component_qspi.h (moved) * bsps/arm/atsam/include/libchip/include/sams70/component/component_rstc.h (moved) * bsps/arm/atsam/include/libchip/include/sams70/component/component_rswdt.h (moved) * bsps/arm/atsam/include/libchip/include/sams70/component/component_rtc.h (moved) * bsps/arm/atsam/include/libchip/include/sams70/component/component_rtt.h (moved) * bsps/arm/atsam/include/libchip/include/sams70/component/component_sdramc.h (moved) * bsps/arm/atsam/include/libchip/include/sams70/component/component_smc.h (moved) * bsps/arm/atsam/include/libchip/include/sams70/component/component_spi.h (moved) * bsps/arm/atsam/include/libchip/include/sams70/component/component_ssc.h (moved) * bsps/arm/atsam/include/libchip/include/sams70/component/component_supc.h (moved) * bsps/arm/atsam/include/libchip/include/sams70/component/component_tc.h (moved) * bsps/arm/atsam/include/libchip/include/sams70/component/component_trng.h (moved) * bsps/arm/atsam/include/libchip/include/sams70/component/component_twihs.h (moved) * bsps/arm/atsam/include/libchip/include/sams70/component/component_uart.h (moved) * bsps/arm/atsam/include/libchip/include/sams70/component/component_usart.h (moved) * bsps/arm/atsam/include/libchip/include/sams70/component/component_usbhs.h (moved) * bsps/arm/atsam/include/libchip/include/sams70/component/component_utmi.h (moved) * bsps/arm/atsam/include/libchip/include/sams70/component/component_wdt.h (moved) * bsps/arm/atsam/include/libchip/include/sams70/component/component_xdmac.h (moved) * bsps/arm/atsam/include/libchip/include/sams70/pio/pio_sams70j19.h (moved) * bsps/arm/atsam/include/libchip/include/sams70/pio/pio_sams70j20.h (moved) * bsps/arm/atsam/include/libchip/include/sams70/pio/pio_sams70j21.h (moved) * bsps/arm/atsam/include/libchip/include/sams70/pio/pio_sams70n19.h (moved) * bsps/arm/atsam/include/libchip/include/sams70/pio/pio_sams70n20.h (moved) * bsps/arm/atsam/include/libchip/include/sams70/pio/pio_sams70n21.h (moved) * bsps/arm/atsam/include/libchip/include/sams70/pio/pio_sams70q19.h (moved) * bsps/arm/atsam/include/libchip/include/sams70/pio/pio_sams70q20.h (moved) * bsps/arm/atsam/include/libchip/include/sams70/pio/pio_sams70q21.h (moved) * bsps/arm/atsam/include/libchip/include/sams70/sams70.h (moved) * bsps/arm/atsam/include/libchip/include/sams70/sams70j19.h (moved) * bsps/arm/atsam/include/libchip/include/sams70/sams70j20.h (moved) * bsps/arm/atsam/include/libchip/include/sams70/sams70j21.h (moved) * bsps/arm/atsam/include/libchip/include/sams70/sams70n19.h (moved) * bsps/arm/atsam/include/libchip/include/sams70/sams70n20.h (moved) * bsps/arm/atsam/include/libchip/include/sams70/sams70n21.h (moved) * bsps/arm/atsam/include/libchip/include/sams70/sams70q19.h (moved) * bsps/arm/atsam/include/libchip/include/sams70/sams70q20.h (moved) * bsps/arm/atsam/include/libchip/include/sams70/sams70q21.h (moved) * bsps/arm/atsam/include/libchip/include/sams70/system_sams70.h (moved) * bsps/arm/atsam/include/libchip/include/samv71/component/component_acc.h (moved) * bsps/arm/atsam/include/libchip/include/samv71/component/component_aes.h (moved) * bsps/arm/atsam/include/libchip/include/samv71/component/component_afec.h (moved) * bsps/arm/atsam/include/libchip/include/samv71/component/component_chipid.h (moved) * bsps/arm/atsam/include/libchip/include/samv71/component/component_dacc.h (moved) * bsps/arm/atsam/include/libchip/include/samv71/component/component_efc.h (moved) * bsps/arm/atsam/include/libchip/include/samv71/component/component_gmac.h (moved) * bsps/arm/atsam/include/libchip/include/samv71/component/component_gpbr.h (moved) * bsps/arm/atsam/include/libchip/include/samv71/component/component_hsmci.h (moved) * bsps/arm/atsam/include/libchip/include/samv71/component/component_icm.h (moved) * bsps/arm/atsam/include/libchip/include/samv71/component/component_isi.h (moved) * bsps/arm/atsam/include/libchip/include/samv71/component/component_matrix.h (moved) * bsps/arm/atsam/include/libchip/include/samv71/component/component_mcan.h (moved) * bsps/arm/atsam/include/libchip/include/samv71/component/component_mlb.h (moved) * bsps/arm/atsam/include/libchip/include/samv71/component/component_pio.h (moved) * bsps/arm/atsam/include/libchip/include/samv71/component/component_pmc.h (moved) * bsps/arm/atsam/include/libchip/include/samv71/component/component_pwm.h (moved) * bsps/arm/atsam/include/libchip/include/samv71/component/component_qspi.h (moved) * bsps/arm/atsam/include/libchip/include/samv71/component/component_rstc.h (moved) * bsps/arm/atsam/include/libchip/include/samv71/component/component_rswdt.h (moved) * bsps/arm/atsam/include/libchip/include/samv71/component/component_rtc.h (moved) * bsps/arm/atsam/include/libchip/include/samv71/component/component_rtt.h (moved) * bsps/arm/atsam/include/libchip/include/samv71/component/component_sdramc.h (moved) * bsps/arm/atsam/include/libchip/include/samv71/component/component_smc.h (moved) * bsps/arm/atsam/include/libchip/include/samv71/component/component_spi.h (moved) * bsps/arm/atsam/include/libchip/include/samv71/component/component_ssc.h (moved) * bsps/arm/atsam/include/libchip/include/samv71/component/component_supc.h (moved) * bsps/arm/atsam/include/libchip/include/samv71/component/component_tc.h (moved) * bsps/arm/atsam/include/libchip/include/samv71/component/component_trng.h (moved) * bsps/arm/atsam/include/libchip/include/samv71/component/component_twihs.h (moved) * bsps/arm/atsam/include/libchip/include/samv71/component/component_uart.h (moved) * bsps/arm/atsam/include/libchip/include/samv71/component/component_usart.h (moved) * bsps/arm/atsam/include/libchip/include/samv71/component/component_usbhs.h (moved) * bsps/arm/atsam/include/libchip/include/samv71/component/component_utmi.h (moved) * bsps/arm/atsam/include/libchip/include/samv71/component/component_wdt.h (moved) * bsps/arm/atsam/include/libchip/include/samv71/component/component_xdmac.h (moved) * bsps/arm/atsam/include/libchip/include/samv71/pio/pio_samv71j19.h (moved) * bsps/arm/atsam/include/libchip/include/samv71/pio/pio_samv71j20.h (moved) * bsps/arm/atsam/include/libchip/include/samv71/pio/pio_samv71j21.h (moved) * bsps/arm/atsam/include/libchip/include/samv71/pio/pio_samv71n19.h (moved) * bsps/arm/atsam/include/libchip/include/samv71/pio/pio_samv71n20.h (moved) * bsps/arm/atsam/include/libchip/include/samv71/pio/pio_samv71n21.h (moved) * bsps/arm/atsam/include/libchip/include/samv71/pio/pio_samv71q19.h (moved) * bsps/arm/atsam/include/libchip/include/samv71/pio/pio_samv71q20.h (moved) * bsps/arm/atsam/include/libchip/include/samv71/pio/pio_samv71q21.h (moved) * bsps/arm/atsam/include/libchip/include/samv71/samv71.h (moved) * bsps/arm/atsam/include/libchip/include/samv71/samv71j19.h (moved) * bsps/arm/atsam/include/libchip/include/samv71/samv71j20.h (moved) * bsps/arm/atsam/include/libchip/include/samv71/samv71j21.h (moved) * bsps/arm/atsam/include/libchip/include/samv71/samv71n19.h (moved) * bsps/arm/atsam/include/libchip/include/samv71/samv71n20.h (moved) * bsps/arm/atsam/include/libchip/include/samv71/samv71n21.h (moved) * bsps/arm/atsam/include/libchip/include/samv71/samv71q19.h (moved) * bsps/arm/atsam/include/libchip/include/samv71/samv71q20.h (moved) * bsps/arm/atsam/include/libchip/include/samv71/samv71q21.h (moved) * bsps/arm/atsam/include/libchip/include/samv71/system_samv71.h (moved) * bsps/arm/atsam/include/libchip/include/sdramc.h (moved) * bsps/arm/atsam/include/libchip/include/smc.h (moved) * bsps/arm/atsam/include/libchip/include/spi.h (moved) * bsps/arm/atsam/include/libchip/include/spi_dma.h (moved) * bsps/arm/atsam/include/libchip/include/ssc.h (moved) * bsps/arm/atsam/include/libchip/include/supc.h (moved) * bsps/arm/atsam/include/libchip/include/tc.h (moved) * bsps/arm/atsam/include/libchip/include/timetick.h (moved) * bsps/arm/atsam/include/libchip/include/trace.h (moved) * bsps/arm/atsam/include/libchip/include/trng.h (moved) * bsps/arm/atsam/include/libchip/include/twi.h (moved) * bsps/arm/atsam/include/libchip/include/twid.h (moved) * bsps/arm/atsam/include/libchip/include/uart.h (moved) * bsps/arm/atsam/include/libchip/include/uart_dma.h (moved) * bsps/arm/atsam/include/libchip/include/usart.h (moved) * bsps/arm/atsam/include/libchip/include/usart_dma.h (moved) * bsps/arm/atsam/include/libchip/include/usbhs.h (moved) * bsps/arm/atsam/include/libchip/include/video.h (moved) * bsps/arm/atsam/include/libchip/include/wdt.h (moved) * bsps/arm/atsam/include/libchip/include/xdma_hardware_interface.h (moved) * bsps/arm/atsam/include/libchip/include/xdmac.h (moved) * bsps/arm/atsam/include/libchip/include/xdmad.h (moved) * bsps/arm/atsam/include/tm27.h (moved) * bsps/arm/beagle/headers.am (added) * bsps/arm/beagle/include/bsp.h (moved) * bsps/arm/beagle/include/bsp/bbb-gpio.h (moved) * bsps/arm/beagle/include/bsp/bbb-pwm.h (moved) * bsps/arm/beagle/include/bsp/beagleboneblack.h (moved) * bsps/arm/beagle/include/bsp/i2c.h (moved) * bsps/arm/beagle/include/bsp/irq.h (moved) * bsps/arm/beagle/include/tm27.h (moved) * bsps/arm/csb336/headers.am (added) * bsps/arm/csb336/include/bsp.h (moved) * bsps/arm/csb336/include/bsp/irq.h (moved) * bsps/arm/csb336/include/mc9328mxl.h (moved) * bsps/arm/csb336/include/tm27.h (moved) * bsps/arm/csb337/headers.am (added) * bsps/arm/csb337/include/at91rm9200.h (moved) * bsps/arm/csb337/include/at91rm9200_dbgu.h (moved) * bsps/arm/csb337/include/at91rm9200_emac.h (moved) * bsps/arm/csb337/include/at91rm9200_gpio.h (moved) * bsps/arm/csb337/include/at91rm9200_mem.h (moved) * bsps/arm/csb337/include/at91rm9200_pmc.h (moved) * bsps/arm/csb337/include/at91rm9200_usart.h (moved) * bsps/arm/csb337/include/bits.h (moved) * bsps/arm/csb337/include/bsp.h (moved) * bsps/arm/csb337/include/bsp/irq.h (moved) * bsps/arm/csb337/include/font8x16.h (moved) * bsps/arm/csb337/include/sed1356.h (moved) * bsps/arm/csb337/include/sed1356_16bit.h (moved) * bsps/arm/csb337/include/tm27.h (moved) * bsps/arm/edb7312/headers.am (added) * bsps/arm/edb7312/include/bsp.h (moved) * bsps/arm/edb7312/include/bsp/irq.h (moved) * bsps/arm/edb7312/include/ep7312.h (moved) * bsps/arm/edb7312/include/tm27.h (moved) * bsps/arm/gdbarmsim/headers.am (added) * bsps/arm/gdbarmsim/include/bsp.h (moved) * bsps/arm/gdbarmsim/include/bsp/irq.h (moved) * bsps/arm/gdbarmsim/include/bsp/swi.h (moved) * bsps/arm/gdbarmsim/include/tm27.h (moved) * bsps/arm/gumstix/headers.am (added) * bsps/arm/gumstix/include/bsp.h (moved) * bsps/arm/gumstix/include/bsp/irq.h (moved) * bsps/arm/gumstix/include/ffuart.h (moved) * bsps/arm/gumstix/include/pxa255.h (moved) * bsps/arm/gumstix/include/tm27.h (moved) * bsps/arm/headers.am (added) * bsps/arm/imx/headers.am (added) * bsps/arm/imx/include/arm/freescale/imx/imx_ccmvar.h (moved) * bsps/arm/imx/include/arm/freescale/imx/imx_ecspireg.h (moved) * bsps/arm/imx/include/arm/freescale/imx/imx_gpcreg.h (moved) * bsps/arm/imx/include/arm/freescale/imx/imx_i2creg.h (moved) * bsps/arm/imx/include/arm/freescale/imx/imx_iomuxreg.h (moved) * bsps/arm/imx/include/arm/freescale/imx/imx_iomuxvar.h (moved) * bsps/arm/imx/include/arm/freescale/imx/imx_srcreg.h (moved) * bsps/arm/imx/include/arm/freescale/imx/imx_uartreg.h (moved) * bsps/arm/imx/include/arm/freescale/imx/imx_wdogreg.h (moved) * bsps/arm/imx/include/bsp.h (moved) * bsps/arm/imx/include/bsp/irq.h (moved) * bsps/arm/imx/include/tm27.h (moved) * bsps/arm/include/bsp/arm-a8core-start.h (moved) * bsps/arm/include/bsp/arm-a9mpcore-clock.h (moved) * bsps/arm/include/bsp/arm-a9mpcore-irq.h (moved) * bsps/arm/include/bsp/arm-a9mpcore-regs.h (moved) * bsps/arm/include/bsp/arm-a9mpcore-start.h (moved) * bsps/arm/include/bsp/arm-cp15-start.h (moved) * bsps/arm/include/bsp/arm-errata.h (moved) * bsps/arm/include/bsp/arm-gic-irq.h (moved) * bsps/arm/include/bsp/arm-gic-regs.h (moved) * bsps/arm/include/bsp/arm-gic-tm27.h (moved) * bsps/arm/include/bsp/arm-gic.h (moved) * bsps/arm/include/bsp/arm-pl011-regs.h (moved) * bsps/arm/include/bsp/arm-pl011.h (moved) * bsps/arm/include/bsp/arm-pl050-regs.h (moved) * bsps/arm/include/bsp/arm-pl050.h (moved) * bsps/arm/include/bsp/arm-pl111-fb.h (moved) * bsps/arm/include/bsp/arm-pl111-regs.h (moved) * bsps/arm/include/bsp/arm-release-id.h (moved) * bsps/arm/include/bsp/armv7m-irq.h (moved) * bsps/arm/include/bsp/linker-symbols.h (moved) * bsps/arm/include/bsp/lpc-dma.h (moved) * bsps/arm/include/bsp/lpc-emc.h (moved) * bsps/arm/include/bsp/lpc-i2s.h (moved) * bsps/arm/include/bsp/lpc-lcd.h (moved) * bsps/arm/include/bsp/lpc-timer.h (moved) * bsps/arm/include/bsp/start.h (moved) * bsps/arm/include/cmsis_gcc.h (moved) * bsps/arm/include/core_cm7.h (moved) * bsps/arm/include/core_cmFunc.h (moved) * bsps/arm/include/core_cmInstr.h (moved) * bsps/arm/include/core_cmSimd.h (moved) * bsps/arm/include/libcpu/am335x.h (moved) * bsps/arm/include/libcpu/mmu.h (moved) * bsps/arm/include/libcpu/omap3.h (moved) * bsps/arm/include/libcpu/omap_timer.h (moved) * bsps/arm/include/uart.h (moved) * bsps/arm/lm3s69xx/headers.am (added) * bsps/arm/lm3s69xx/include/bsp.h (moved) * bsps/arm/lm3s69xx/include/bsp/io.h (moved) * bsps/arm/lm3s69xx/include/bsp/irq.h (moved) * bsps/arm/lm3s69xx/include/bsp/lm3s69xx.h (moved) * bsps/arm/lm3s69xx/include/bsp/ssi.h (moved) * bsps/arm/lm3s69xx/include/bsp/syscon.h (moved) * bsps/arm/lm3s69xx/include/bsp/uart.h (moved) * bsps/arm/lm3s69xx/include/tm27.h (moved) * bsps/arm/lpc176x/headers.am (added) * bsps/arm/lpc176x/include/bsp.h (moved) * bsps/arm/lpc176x/include/bsp/adc-defs.h (moved) * bsps/arm/lpc176x/include/bsp/adc.h (moved) * bsps/arm/lpc176x/include/bsp/can-defs.h (moved) * bsps/arm/lpc176x/include/bsp/can.h (moved) * bsps/arm/lpc176x/include/bsp/common-types.h (moved) * bsps/arm/lpc176x/include/bsp/dma.h (moved) * bsps/arm/lpc176x/include/bsp/gpio-defs.h (moved) * bsps/arm/lpc176x/include/bsp/io-defs.h (moved) * bsps/arm/lpc176x/include/bsp/io.h (moved) * bsps/arm/lpc176x/include/bsp/irq.h (moved) * bsps/arm/lpc176x/include/bsp/lpc-clock-config.h (moved) * bsps/arm/lpc176x/include/bsp/lpc-gpio.h (moved) * bsps/arm/lpc176x/include/bsp/lpc176x.h (moved) * bsps/arm/lpc176x/include/bsp/mbed-pinmap.h (moved) * bsps/arm/lpc176x/include/bsp/pwmout-defs.h (moved) * bsps/arm/lpc176x/include/bsp/pwmout.h (moved) * bsps/arm/lpc176x/include/bsp/system-clocks.h (moved) * bsps/arm/lpc176x/include/bsp/timer-defs.h (moved) * bsps/arm/lpc176x/include/bsp/timer.h (moved) * bsps/arm/lpc176x/include/bsp/watchdog-defs.h (moved) * bsps/arm/lpc176x/include/bsp/watchdog.h (moved) * bsps/arm/lpc176x/include/tm27.h (moved) * bsps/arm/lpc24xx/headers.am (added) * bsps/arm/lpc24xx/include/bsp.h (moved) * bsps/arm/lpc24xx/include/bsp/dma.h (moved) * bsps/arm/lpc24xx/include/bsp/i2c.h (moved) * bsps/arm/lpc24xx/include/bsp/io.h (moved) * bsps/arm/lpc24xx/include/bsp/irq.h (moved) * bsps/arm/lpc24xx/include/bsp/lcd.h (moved) * bsps/arm/lpc24xx/include/bsp/lpc-clock-config.h (moved) * bsps/arm/lpc24xx/include/bsp/lpc-ethernet-config.h (moved) * bsps/arm/lpc24xx/include/bsp/lpc17xx.h (moved) * bsps/arm/lpc24xx/include/bsp/lpc24xx.h (moved) * bsps/arm/lpc24xx/include/bsp/ssp.h (moved) * bsps/arm/lpc24xx/include/bsp/start-config.h (moved) * bsps/arm/lpc24xx/include/bsp/system-clocks.h (moved) * bsps/arm/lpc24xx/include/tm27.h (moved) * bsps/arm/lpc32xx/headers.am (added) * bsps/arm/lpc32xx/include/bsp.h (moved) * bsps/arm/lpc32xx/include/bsp/boot.h (moved) * bsps/arm/lpc32xx/include/bsp/emc.h (moved) * bsps/arm/lpc32xx/include/bsp/hsu.h (moved) * bsps/arm/lpc32xx/include/bsp/i2c.h (moved) * bsps/arm/lpc32xx/include/bsp/irq.h (moved) * bsps/arm/lpc32xx/include/bsp/lpc-clock-config.h (moved) * bsps/arm/lpc32xx/include/bsp/lpc-ethernet-config.h (moved) * bsps/arm/lpc32xx/include/bsp/lpc32xx.h (moved) * bsps/arm/lpc32xx/include/bsp/mmu.h (moved) * bsps/arm/lpc32xx/include/bsp/nand-mlc.h (moved) * bsps/arm/lpc32xx/include/tm27.h (moved) * bsps/arm/raspberrypi/headers.am (added) * bsps/arm/raspberrypi/include/bsp.h (moved) * bsps/arm/raspberrypi/include/bsp/fbcons.h (moved) * bsps/arm/raspberrypi/include/bsp/i2c.h (moved) * bsps/arm/raspberrypi/include/bsp/irq.h (moved) * bsps/arm/raspberrypi/include/bsp/mailbox.h (moved) * bsps/arm/raspberrypi/include/bsp/mmu.h (moved) * bsps/arm/raspberrypi/include/bsp/raspberrypi.h (moved) * bsps/arm/raspberrypi/include/bsp/rpi-fb.h (moved) * bsps/arm/raspberrypi/include/bsp/rpi-gpio.h (moved) * bsps/arm/raspberrypi/include/bsp/spi.h (moved) * bsps/arm/raspberrypi/include/bsp/usart.h (moved) * bsps/arm/raspberrypi/include/bsp/vc.h (moved) * bsps/arm/raspberrypi/include/tm27.h (moved) * bsps/arm/realview-pbx-a9/headers.am (added) * bsps/arm/realview-pbx-a9/include/bsp.h (moved) * bsps/arm/realview-pbx-a9/include/bsp/irq.h (moved) * bsps/arm/realview-pbx-a9/include/tm27.h (moved) * bsps/arm/rtl22xx/headers.am (added) * bsps/arm/rtl22xx/include/bsp.h (moved) * bsps/arm/rtl22xx/include/bsp/irq.h (moved) * bsps/arm/rtl22xx/include/lpc22xx.h (moved) * bsps/arm/rtl22xx/include/tm27.h (moved) * bsps/arm/smdk2410/headers.am (added) * bsps/arm/smdk2410/include/bsp.h (moved) * bsps/arm/smdk2410/include/bsp/irq.h (moved) * bsps/arm/smdk2410/include/s3c2400.h (moved) * bsps/arm/smdk2410/include/s3c2410.h (moved) * bsps/arm/smdk2410/include/s3c24xx.h (moved) * bsps/arm/smdk2410/include/smc.h (moved) * bsps/arm/smdk2410/include/tm27.h (moved) * bsps/arm/stm32f4/headers.am (added) * bsps/arm/stm32f4/include/bsp.h (moved) * bsps/arm/stm32f4/include/bsp/i2c.h (moved) * bsps/arm/stm32f4/include/bsp/io.h (moved) * bsps/arm/stm32f4/include/bsp/irq.h (moved) * bsps/arm/stm32f4/include/bsp/rcc.h (moved) * bsps/arm/stm32f4/include/bsp/stm32_i2c.h (moved) * bsps/arm/stm32f4/include/bsp/stm32_usart.h (moved) * bsps/arm/stm32f4/include/bsp/stm32f10xxx_exti.h (moved) * bsps/arm/stm32f4/include/bsp/stm32f10xxx_gpio.h (moved) * bsps/arm/stm32f4/include/bsp/stm32f10xxx_rcc.h (moved) * bsps/arm/stm32f4/include/bsp/stm32f4.h (moved) * bsps/arm/stm32f4/include/bsp/stm32f4xxxx_adc.h (moved) * bsps/arm/stm32f4/include/bsp/stm32f4xxxx_exti.h (moved) * bsps/arm/stm32f4/include/bsp/stm32f4xxxx_flash.h (moved) * bsps/arm/stm32f4/include/bsp/stm32f4xxxx_gpio.h (moved) * bsps/arm/stm32f4/include/bsp/stm32f4xxxx_otgfs.h (moved) * bsps/arm/stm32f4/include/bsp/stm32f4xxxx_pwr.h (moved) * bsps/arm/stm32f4/include/bsp/stm32f4xxxx_rcc.h (moved) * bsps/arm/stm32f4/include/bsp/stm32f4xxxx_syscfg.h (moved) * bsps/arm/stm32f4/include/bsp/stm32f4xxxx_tim.h (moved) * bsps/arm/stm32f4/include/bsp/usart.h (moved) * bsps/arm/stm32f4/include/tm27.h (moved) * bsps/arm/tms570/headers.am (added) * bsps/arm/tms570/include/bsp.h (moved) * bsps/arm/tms570/include/bsp/irq.h (moved) * bsps/arm/tms570/include/bsp/system-clocks.h (moved) * bsps/arm/tms570/include/bsp/ti_herc/reg_adc.h (moved) * bsps/arm/tms570/include/bsp/ti_herc/reg_ccmsr.h (moved) * bsps/arm/tms570/include/bsp/ti_herc/reg_crc.h (moved) * bsps/arm/tms570/include/bsp/ti_herc/reg_dcan.h (moved) * bsps/arm/tms570/include/bsp/ti_herc/reg_dcc.h (moved) * bsps/arm/tms570/include/bsp/ti_herc/reg_dma.h (moved) * bsps/arm/tms570/include/bsp/ti_herc/reg_dmm.h (moved) * bsps/arm/tms570/include/bsp/ti_herc/reg_efuse.h (moved) * bsps/arm/tms570/include/bsp/ti_herc/reg_emacc.h (moved) * bsps/arm/tms570/include/bsp/ti_herc/reg_emacm.h (moved) * bsps/arm/tms570/include/bsp/ti_herc/reg_emif.h (moved) * bsps/arm/tms570/include/bsp/ti_herc/reg_esm.h (moved) * bsps/arm/tms570/include/bsp/ti_herc/reg_flash.h (moved) * bsps/arm/tms570/include/bsp/ti_herc/reg_flex_ray.h (moved) * bsps/arm/tms570/include/bsp/ti_herc/reg_gio.h (moved) * bsps/arm/tms570/include/bsp/ti_herc/reg_htu.h (moved) * bsps/arm/tms570/include/bsp/ti_herc/reg_i2c.h (moved) * bsps/arm/tms570/include/bsp/ti_herc/reg_iomm.h (moved) * bsps/arm/tms570/include/bsp/ti_herc/reg_lin.h (moved) * bsps/arm/tms570/include/bsp/ti_herc/reg_mdio.h (moved) * bsps/arm/tms570/include/bsp/ti_herc/reg_n2het.h (moved) * bsps/arm/tms570/include/bsp/ti_herc/reg_pbist.h (moved) * bsps/arm/tms570/include/bsp/ti_herc/reg_pcr.h (moved) * bsps/arm/tms570/include/bsp/ti_herc/reg_pll.h (moved) * bsps/arm/tms570/include/bsp/ti_herc/reg_pmm.h (moved) * bsps/arm/tms570/include/bsp/ti_herc/reg_pom.h (moved) * bsps/arm/tms570/include/bsp/ti_herc/reg_rti.h (moved) * bsps/arm/tms570/include/bsp/ti_herc/reg_rtp.h (moved) * bsps/arm/tms570/include/bsp/ti_herc/reg_sci.h (moved) * bsps/arm/tms570/include/bsp/ti_herc/reg_spi.h (moved) * bsps/arm/tms570/include/bsp/ti_herc/reg_stc.h (moved) * bsps/arm/tms570/include/bsp/ti_herc/reg_sys.h (moved) * bsps/arm/tms570/include/bsp/ti_herc/reg_sys2.h (moved) * bsps/arm/tms570/include/bsp/ti_herc/reg_tcr.h (moved) * bsps/arm/tms570/include/bsp/ti_herc/reg_tcram.h (moved) * bsps/arm/tms570/include/bsp/ti_herc/reg_vim.h (moved) * bsps/arm/tms570/include/bsp/tms570-pinmux.h (moved) * bsps/arm/tms570/include/bsp/tms570-pins.h (moved) * bsps/arm/tms570/include/bsp/tms570-pom.h (moved) * bsps/arm/tms570/include/bsp/tms570-rti.h (moved) * bsps/arm/tms570/include/bsp/tms570-sci-driver.h (moved) * bsps/arm/tms570/include/bsp/tms570-sci.h (moved) * bsps/arm/tms570/include/bsp/tms570-vim.h (moved) * bsps/arm/tms570/include/bsp/tms570.h (moved) * bsps/arm/tms570/include/bsp/tms570_hwinit.h (moved) * bsps/arm/tms570/include/bsp/tms570_selftest.h (moved) * bsps/arm/tms570/include/bsp/tms570_selftest_parity.h (moved) * bsps/arm/tms570/include/bsp/tms570lc4357-pins.h (moved) * bsps/arm/tms570/include/bsp/tms570ls3137zwt-pins.h (moved) * bsps/arm/tms570/include/tm27.h (moved) * bsps/arm/xilinx-zynq/headers.am (added) * bsps/arm/xilinx-zynq/include/bsp.h (moved) * bsps/arm/xilinx-zynq/include/bsp/cadence-i2c-regs.h (moved) * bsps/arm/xilinx-zynq/include/bsp/cadence-i2c.h (moved) * bsps/arm/xilinx-zynq/include/bsp/i2c.h (moved) * bsps/arm/xilinx-zynq/include/bsp/irq.h (moved) * bsps/arm/xilinx-zynq/include/bsp/zynq-uart-regs.h (moved) * bsps/arm/xilinx-zynq/include/bsp/zynq-uart.h (moved) * bsps/arm/xilinx-zynq/include/tm27.h (moved) * bsps/bfin/TLL6527M/headers.am (added) * bsps/bfin/TLL6527M/include/bsp.h (moved) * bsps/bfin/TLL6527M/include/cplb.h (moved) * bsps/bfin/TLL6527M/include/tm27.h (moved) * bsps/bfin/bf537Stamp/headers.am (added) * bsps/bfin/bf537Stamp/include/bsp.h (moved) * bsps/bfin/bf537Stamp/include/tm27.h (moved) * bsps/bfin/eZKit533/headers.am (added) * bsps/bfin/eZKit533/include/bsp.h (moved) * bsps/bfin/eZKit533/include/cplb.h (moved) * bsps/bfin/eZKit533/include/tm27.h (moved) * bsps/bfin/headers.am (added) * bsps/bfin/include/bf52x.h (moved) * bsps/bfin/include/bsp/interrupt.h (moved) * bsps/bfin/include/libcpu/bf533.h (moved) * bsps/bfin/include/libcpu/bf537.h (moved) * bsps/bfin/include/libcpu/cecRegs.h (moved) * bsps/bfin/include/libcpu/coreTimerRegs.h (moved) * bsps/bfin/include/libcpu/dmaRegs.h (moved) * bsps/bfin/include/libcpu/ebiuRegs.h (moved) * bsps/bfin/include/libcpu/ethernet.h (moved) * bsps/bfin/include/libcpu/ethernetRegs.h (moved) * bsps/bfin/include/libcpu/gpioRegs.h (moved) * bsps/bfin/include/libcpu/interrupt.h (moved) * bsps/bfin/include/libcpu/memoryRegs.h (moved) * bsps/bfin/include/libcpu/mmu.h (moved) * bsps/bfin/include/libcpu/mmuRegs.h (moved) * bsps/bfin/include/libcpu/ppiRegs.h (moved) * bsps/bfin/include/libcpu/rtcRegs.h (moved) * bsps/bfin/include/libcpu/sicRegs.h (moved) * bsps/bfin/include/libcpu/spi.h (moved) * bsps/bfin/include/libcpu/spiRegs.h (moved) * bsps/bfin/include/libcpu/sport.h (moved) * bsps/bfin/include/libcpu/sportRegs.h (moved) * bsps/bfin/include/libcpu/timerRegs.h (moved) * bsps/bfin/include/libcpu/twi.h (moved) * bsps/bfin/include/libcpu/twiRegs.h (moved) * bsps/bfin/include/libcpu/uart.h (moved) * bsps/bfin/include/libcpu/uartRegs.h (moved) * bsps/bfin/include/libcpu/wdogRegs.h (moved) * bsps/epiphany/epiphany_sim/headers.am (added) * bsps/epiphany/epiphany_sim/include/bsp.h (moved) * bsps/epiphany/epiphany_sim/include/bsp/irq.h (moved) * bsps/epiphany/epiphany_sim/include/tm27.h (moved) * bsps/epiphany/headers.am (added) * bsps/epiphany/include/bsp/linker-symbols.h (moved) * bsps/headers.am (added) * bsps/i386/headers.am (added) * bsps/i386/include/bsp/apic.h (moved) * bsps/i386/include/bsp/irq.h (moved) * bsps/i386/include/bsp/irq_asm.h (moved) * bsps/i386/include/bsp/realmode_int.h (moved) * bsps/i386/include/bsp/smp-imps.h (moved) * bsps/i386/include/bsp/tty_drv.h (moved) * bsps/i386/include/i386_io.h (moved) * bsps/i386/include/libcpu/byteorder.h (moved) * bsps/i386/include/libcpu/cpuModel.h (moved) * bsps/i386/include/libcpu/page.h (moved) * bsps/i386/include/uart.h (moved) * bsps/i386/pc386/headers.am (added) * bsps/i386/pc386/include/bsp.h (moved) * bsps/i386/pc386/include/bsp/bspimpl.h (moved) * bsps/i386/pc386/include/bsp/exar17d15x.h (moved) * bsps/i386/pc386/include/bsp/fb_default_mode.h (moved) * bsps/i386/pc386/include/bsp/fb_vesa.h (moved) * bsps/i386/pc386/include/bsp/rtd316.h (moved) * bsps/i386/pc386/include/bsp/tblsizes.h (moved) * bsps/i386/pc386/include/bsp/vbe3.h (moved) * bsps/i386/pc386/include/crt.h (moved) * bsps/i386/pc386/include/edid.h (moved) * bsps/i386/pc386/include/rtems/kd.h (moved) * bsps/i386/pc386/include/rtems/keyboard.h (moved) * bsps/i386/pc386/include/rtems/ps2_drv.h (moved) * bsps/i386/pc386/include/rtems/vgacons.h (moved) * bsps/i386/pc386/include/tm27.h (moved) * bsps/include/bsp/VME.h (moved) * bsps/include/bsp/VMEDMA.h (moved) * bsps/include/bsp/bootcard.h (moved) * bsps/include/bsp/bspVmeDmaList.h (moved) * bsps/include/bsp/console-polled.h (moved) * bsps/include/bsp/console-termios.h (moved) * bsps/include/bsp/default-initial-extension.h (moved) * bsps/include/bsp/fatal.h (moved) * bsps/include/bsp/fdt.h (moved) * bsps/include/bsp/gpio.h (moved) * bsps/include/bsp/irq-generic.h (moved) * bsps/include/bsp/irq-info.h (moved) * bsps/include/bsp/mm.h (moved) * bsps/include/bsp/stackalloc.h (moved) * bsps/include/bsp/u-boot.h (moved) * bsps/include/bsp/uart-output-char.h (moved) * bsps/include/bsp/utility.h (moved) * bsps/include/bsp/vmeTsi148.h (moved) * bsps/include/bsp/vmeTsi148DMA.h (moved) * bsps/include/bsp/vmeUniverse.h (moved) * bsps/include/bsp/vmeUniverseDMA.h (moved) * bsps/include/bsp/vme_am_defs.h (moved) * bsps/include/libchip/am29lv160.h (moved) * bsps/include/libchip/ata.h (moved) * bsps/include/libchip/ata_internal.h (moved) * bsps/include/libchip/cs8900.h (moved) * bsps/include/libchip/disp_hcms29xx.h (moved) * bsps/include/libchip/ds1375-rtc.h (moved) * bsps/include/libchip/greth.h (moved) * bsps/include/libchip/i2c-2b-eeprom.h (moved) * bsps/include/libchip/i2c-ds1621.h (moved) * bsps/include/libchip/i2c-sc620.h (moved) * bsps/include/libchip/i82586var.h (moved) * bsps/include/libchip/icm7170.h (moved) * bsps/include/libchip/ide_ctrl.h (moved) * bsps/include/libchip/ide_ctrl_cfg.h (moved) * bsps/include/libchip/ide_ctrl_io.h (moved) * bsps/include/libchip/if_dcreg.h (moved) * bsps/include/libchip/if_fxpvar.h (moved) * bsps/include/libchip/m48t08.h (moved) * bsps/include/libchip/mc146818a.h (moved) * bsps/include/libchip/mc68681.h (moved) * bsps/include/libchip/ns16550.h (moved) * bsps/include/libchip/ns16550_p.h (moved) * bsps/include/libchip/open_eth.h (moved) * bsps/include/libchip/rtc.h (moved) * bsps/include/libchip/serial.h (moved) * bsps/include/libchip/sersupp.h (moved) * bsps/include/libchip/smc91111.h (moved) * bsps/include/libchip/smc91111exp.h (moved) * bsps/include/libchip/sonic.h (moved) * bsps/include/libchip/spi-flash-m25p40.h (moved) * bsps/include/libchip/spi-fram-fm25l256.h (moved) * bsps/include/libchip/spi-memdrv.h (moved) * bsps/include/libchip/spi-sd-card.h (moved) * bsps/include/libchip/wd80x3.h (moved) * bsps/include/libchip/z85c30.h (moved) * bsps/include/mpci.h (moved) * bsps/include/rtems/umon.h (moved) * bsps/include/rtems/zilog/z8036.h (moved) * bsps/include/rtems/zilog/z8530.h (moved) * bsps/include/shm_driver.h (moved) * bsps/include/umon/cli.h (moved) * bsps/include/umon/monlib.h (moved) * bsps/include/umon/tfs.h (moved) * bsps/lm32/headers.am (added) * bsps/lm32/include/bsp/irq.h (moved) * bsps/lm32/include/bsp/milkymist_ac97.h (moved) * bsps/lm32/include/bsp/milkymist_buttons.h (moved) * bsps/lm32/include/bsp/milkymist_dmx.h (moved) * bsps/lm32/include/bsp/milkymist_flash.h (moved) * bsps/lm32/include/bsp/milkymist_gpio.h (moved) * bsps/lm32/include/bsp/milkymist_ir.h (moved) * bsps/lm32/include/bsp/milkymist_memcard.h (moved) * bsps/lm32/include/bsp/milkymist_midi.h (moved) * bsps/lm32/include/bsp/milkymist_pfpu.h (moved) * bsps/lm32/include/bsp/milkymist_tmu.h (moved) * bsps/lm32/include/bsp/milkymist_usbinput.h (moved) * bsps/lm32/include/bsp/milkymist_versions.h (moved) * bsps/lm32/include/bsp/milkymist_video.h (moved) * bsps/lm32/lm32_evr/headers.am (added) * bsps/lm32/lm32_evr/include/bsp.h (moved) * bsps/lm32/lm32_evr/include/system_conf.h (moved) * bsps/lm32/lm32_evr/include/tm27.h (moved) * bsps/lm32/milkymist/headers.am (added) * bsps/lm32/milkymist/include/bsp.h (moved) * bsps/lm32/milkymist/include/system_conf.h (moved) * bsps/lm32/milkymist/include/tm27.h (moved) * bsps/m32c/m32cbsp/headers.am (added) * bsps/m32c/m32cbsp/include/bsp.h (moved) * bsps/m32c/m32cbsp/include/tm27.h (moved) * bsps/m68k/av5282/headers.am (added) * bsps/m68k/av5282/include/bsp.h (moved) * bsps/m68k/av5282/include/tm27.h (moved) * bsps/m68k/csb360/headers.am (added) * bsps/m68k/csb360/include/bsp.h (moved) * bsps/m68k/csb360/include/tm27.h (moved) * bsps/m68k/gen68340/headers.am (added) * bsps/m68k/gen68340/include/bsp.h (moved) * bsps/m68k/gen68340/include/m340timer.h (moved) * bsps/m68k/gen68340/include/m340uart.h (moved) * bsps/m68k/gen68340/include/m68340.h (moved) * bsps/m68k/gen68340/include/m68340.inc (moved) * bsps/m68k/gen68340/include/m68349.inc (moved) * bsps/m68k/gen68340/include/tm27.h (moved) * bsps/m68k/gen68360/headers.am (added) * bsps/m68k/gen68360/include/bsp.h (moved) * bsps/m68k/gen68360/include/tm27.h (moved) * bsps/m68k/genmcf548x/headers.am (added) * bsps/m68k/genmcf548x/include/bsp.h (moved) * bsps/m68k/genmcf548x/include/bsp/irq.h (moved) * bsps/m68k/genmcf548x/include/tm27.h (moved) * bsps/m68k/headers.am (added) * bsps/m68k/include/bsp/linker-symbols.h (moved) * bsps/m68k/include/mcf5206/mcf5206e.h (moved) * bsps/m68k/include/mcf5206/mcfmbus.h (moved) * bsps/m68k/include/mcf5206/mcfuart.h (moved) * bsps/m68k/include/mcf5223x/mcf5223x.h (moved) * bsps/m68k/include/mcf5225x/fec.h (moved) * bsps/m68k/include/mcf5225x/mcf5225x.h (moved) * bsps/m68k/include/mcf5235/mcf5235.h (moved) * bsps/m68k/include/mcf5272/mcf5272.h (moved) * bsps/m68k/include/mcf5282/mcf5282.h (moved) * bsps/m68k/include/mcf532x/mcf532x.h (moved) * bsps/m68k/include/mcf548x/MCD_dma.h (moved) * bsps/m68k/include/mcf548x/MCD_progCheck.h (moved) * bsps/m68k/include/mcf548x/MCD_tasksInit.h (moved) * bsps/m68k/include/mcf548x/mcdma_glue.h (moved) * bsps/m68k/include/mcf548x/mcf548x.h (moved) * bsps/m68k/include/mvme16x_hw.h (moved) * bsps/m68k/mcf5206elite/headers.am (added) * bsps/m68k/mcf5206elite/include/bsp.h (moved) * bsps/m68k/mcf5206elite/include/ds1307.h (moved) * bsps/m68k/mcf5206elite/include/i2c.h (moved) * bsps/m68k/mcf5206elite/include/i2cdrv.h (moved) * bsps/m68k/mcf5206elite/include/nvram.h (moved) * bsps/m68k/mcf5206elite/include/tm27.h (moved) * bsps/m68k/mcf52235/headers.am (added) * bsps/m68k/mcf52235/include/bsp.h (moved) * bsps/m68k/mcf52235/include/tm27.h (moved) * bsps/m68k/mcf5225x/headers.am (added) * bsps/m68k/mcf5225x/include/bsp.h (moved) * bsps/m68k/mcf5225x/include/tm27.h (moved) * bsps/m68k/mcf5235/headers.am (added) * bsps/m68k/mcf5235/include/bsp.h (moved) * bsps/m68k/mcf5235/include/tm27.h (moved) * bsps/m68k/mcf5329/headers.am (added) * bsps/m68k/mcf5329/include/bsp.h (moved) * bsps/m68k/mcf5329/include/tm27.h (moved) * bsps/m68k/mrm332/headers.am (added) * bsps/m68k/mrm332/include/bsp.h (moved) * bsps/m68k/mrm332/include/mrm332.h (moved) * bsps/m68k/mrm332/include/tm27.h (moved) * bsps/m68k/mvme147/headers.am (added) * bsps/m68k/mvme147/include/bsp.h (moved) * bsps/m68k/mvme147/include/tm27.h (moved) * bsps/m68k/mvme147s/headers.am (added) * bsps/m68k/mvme147s/include/bsp.h (moved) * bsps/m68k/mvme147s/include/tm27.h (moved) * bsps/m68k/mvme162/headers.am (added) * bsps/m68k/mvme162/include/bsp.h (moved) * bsps/m68k/mvme162/include/page_table.h (moved) * bsps/m68k/mvme162/include/tm27.h (moved) * bsps/m68k/mvme167/headers.am (added) * bsps/m68k/mvme167/include/bsp.h (moved) * bsps/m68k/mvme167/include/page_table.h (moved) * bsps/m68k/mvme167/include/tm27.h (moved) * bsps/m68k/uC5282/headers.am (added) * bsps/m68k/uC5282/include/bsp.h (moved) * bsps/m68k/uC5282/include/tm27.h (moved) * bsps/mips/csb350/headers.am (added) * bsps/mips/csb350/include/bsp.h (moved) * bsps/mips/csb350/include/bsp/irq.h (moved) * bsps/mips/csb350/include/tm27.h (moved) * bsps/mips/headers.am (added) * bsps/mips/hurricane/headers.am (added) * bsps/mips/hurricane/include/bsp.h (moved) * bsps/mips/hurricane/include/bsp/irq.h (moved) * bsps/mips/hurricane/include/tm27.h (moved) * bsps/mips/hurricane/include/usc.h (moved) * bsps/mips/include/bsp/i8259.h (moved) * bsps/mips/include/bsp/regs.h (moved) * bsps/mips/include/libcpu/au1x00.h (moved) * bsps/mips/include/libcpu/isr_entries.h (moved) * bsps/mips/include/libcpu/rm5231.h (moved) * bsps/mips/include/libcpu/tx3904.h (moved) * bsps/mips/include/libcpu/tx4925.h (moved) * bsps/mips/include/libcpu/tx4938.h (moved) * bsps/mips/jmr3904/headers.am (added) * bsps/mips/jmr3904/include/bsp.h (moved) * bsps/mips/jmr3904/include/bsp/irq.h (moved) * bsps/mips/jmr3904/include/tm27.h (moved) * bsps/mips/malta/headers.am (added) * bsps/mips/malta/include/bsp.h (moved) * bsps/mips/malta/include/bsp/irq.h (moved) * bsps/mips/malta/include/bsp/pci.h (moved) * bsps/mips/malta/include/tm27.h (moved) * bsps/mips/rbtx4925/headers.am (added) * bsps/mips/rbtx4925/include/bsp.h (moved) * bsps/mips/rbtx4925/include/bsp/irq.h (moved) * bsps/mips/rbtx4925/include/tm27.h (moved) * bsps/mips/rbtx4938/headers.am (added) * bsps/mips/rbtx4938/include/bsp.h (moved) * bsps/mips/rbtx4938/include/bsp/irq.h (moved) * bsps/mips/rbtx4938/include/tm27.h (moved) * bsps/moxie/moxiesim/headers.am (added) * bsps/moxie/moxiesim/include/bsp.h (moved) * bsps/moxie/moxiesim/include/tm27.h (moved) * bsps/nios2/nios2_iss/headers.am (added) * bsps/nios2/nios2_iss/include/bsp.h (moved) * bsps/nios2/nios2_iss/include/tm27.h (moved) * bsps/no_cpu/no_bsp/headers.am (added) * bsps/no_cpu/no_bsp/include/bsp.h (moved) * bsps/no_cpu/no_bsp/include/tm27.h (moved) * bsps/or1k/generic_or1k/headers.am (added) * bsps/or1k/generic_or1k/include/bsp.h (moved) * bsps/or1k/generic_or1k/include/bsp/generic_or1k.h (moved) * bsps/or1k/generic_or1k/include/bsp/irq.h (moved) * bsps/or1k/generic_or1k/include/bsp/uart.h (moved) * bsps/or1k/generic_or1k/include/tm27.h (moved) * bsps/or1k/headers.am (added) * bsps/or1k/include/bsp/cache_.h (moved) * bsps/or1k/include/bsp/linker-symbols.h (moved) * bsps/powerpc/beatnik/headers.am (added) * bsps/powerpc/beatnik/include/bsp.h (moved) * bsps/powerpc/beatnik/include/bsp/VMEConfig.h (moved) * bsps/powerpc/beatnik/include/bsp/bsp_bsdnet_attach.h (moved) * bsps/powerpc/beatnik/include/bsp/early_enet_link_status.h (moved) * bsps/powerpc/beatnik/include/bsp/gt_timer.h (moved) * bsps/powerpc/beatnik/include/bsp/gti2c_busdrv.h (moved) * bsps/powerpc/beatnik/include/bsp/gti2creg.h (moved) * bsps/powerpc/beatnik/include/bsp/gtintrreg.h (moved) * bsps/powerpc/beatnik/include/bsp/gtpcireg.h (moved) * bsps/powerpc/beatnik/include/bsp/gtreg.h (moved) * bsps/powerpc/beatnik/include/bsp/if_em_pub.h (moved) * bsps/powerpc/beatnik/include/bsp/if_gfe_pub.h (moved) * bsps/powerpc/beatnik/include/bsp/if_mve_pub.h (moved) * bsps/powerpc/beatnik/include/bsp/irq.h (moved) * bsps/powerpc/beatnik/include/tm27.h (moved) * bsps/powerpc/gen5200/headers.am (added) * bsps/powerpc/gen5200/include/bsp.h (moved) * bsps/powerpc/gen5200/include/bsp/ata.h (moved) * bsps/powerpc/gen5200/include/bsp/bestcomm.h (moved) * bsps/powerpc/gen5200/include/bsp/bestcomm/bestcomm_api.h (moved) * bsps/powerpc/gen5200/include/bsp/bestcomm/bestcomm_glue.h (moved) * bsps/powerpc/gen5200/include/bsp/bestcomm/bestcomm_priv.h (moved) * bsps/powerpc/gen5200/include/bsp/bestcomm/dma_image.capi.h (moved) * bsps/powerpc/gen5200/include/bsp/bestcomm/dma_image.h (moved) * bsps/powerpc/gen5200/include/bsp/bestcomm/include/mgt5200/mgt5200.h (moved) * bsps/powerpc/gen5200/include/bsp/bestcomm/include/mgt5200/sdma.h (moved) * bsps/powerpc/gen5200/include/bsp/bestcomm/include/ppctypes.h (moved) * bsps/powerpc/gen5200/include/bsp/bestcomm/task_api/bestcomm_api_mem.h (moved) * bsps/powerpc/gen5200/include/bsp/bestcomm/task_api/bestcomm_cntrl.h (moved) * bsps/powerpc/gen5200/include/bsp/bestcomm/task_api/tasksetup_bdtable.h (moved) * bsps/powerpc/gen5200/include/bsp/bestcomm/task_api/tasksetup_general.h (moved) * bsps/powerpc/gen5200/include/bsp/bestcomm_ops.h (moved) * bsps/powerpc/gen5200/include/bsp/i2c.h (moved) * bsps/powerpc/gen5200/include/bsp/i2cdrv.h (moved) * bsps/powerpc/gen5200/include/bsp/irq.h (moved) * bsps/powerpc/gen5200/include/bsp/mpc5200.h (moved) * bsps/powerpc/gen5200/include/bsp/mscan-base.h (moved) * bsps/powerpc/gen5200/include/bsp/mscan.h (moved) * bsps/powerpc/gen5200/include/bsp/nvram.h (moved) * bsps/powerpc/gen5200/include/bsp/slicetimer.h (moved) * bsps/powerpc/gen5200/include/bsp/u-boot-config.h (moved) * bsps/powerpc/gen5200/include/tm27.h (moved) * bsps/powerpc/gen83xx/headers.am (added) * bsps/powerpc/gen83xx/include/bsp.h (moved) * bsps/powerpc/gen83xx/include/bsp/hwreg_vals.h (moved) * bsps/powerpc/gen83xx/include/bsp/irq.h (moved) * bsps/powerpc/gen83xx/include/bsp/tsec-config.h (moved) * bsps/powerpc/gen83xx/include/bsp/u-boot-config.h (moved) * bsps/powerpc/gen83xx/include/tm27.h (moved) * bsps/powerpc/haleakala/headers.am (added) * bsps/powerpc/haleakala/include/bsp.h (moved) * bsps/powerpc/haleakala/include/bsp/irq.h (moved) * bsps/powerpc/haleakala/include/mmu_405.h (moved) * bsps/powerpc/haleakala/include/tm27.h (moved) * bsps/powerpc/headers.am (added) * bsps/powerpc/include/bsp/consoleIo.h (moved) * bsps/powerpc/include/bsp/flashPgm.h (moved) * bsps/powerpc/include/bsp/flashPgmPvt.h (moved) * bsps/powerpc/include/bsp/irq_supp.h (moved) * bsps/powerpc/include/bsp/linker-symbols.h (moved) * bsps/powerpc/include/bsp/motorola.h (moved) * bsps/powerpc/include/bsp/openpic.h (moved) * bsps/powerpc/include/bsp/pci.h (moved) * bsps/powerpc/include/bsp/pnp.h (moved) * bsps/powerpc/include/bsp/residual.h (moved) * bsps/powerpc/include/bsp/start.h (moved) * bsps/powerpc/include/bsp/tictac.h (moved) * bsps/powerpc/include/bsp/tsec.h (moved) * bsps/powerpc/include/bsp/u-boot-board-info.h (moved) * bsps/powerpc/include/bsp/uart.h (moved) * bsps/powerpc/include/bsp/vectors.h (moved) * bsps/powerpc/include/bsp/vpd.h (moved) * bsps/powerpc/include/ictrl.h (moved) * bsps/powerpc/include/libcpu/bat.h (moved) * bsps/powerpc/include/libcpu/byteorder.h (moved) * bsps/powerpc/include/libcpu/c_clock.h (moved) * bsps/powerpc/include/libcpu/cpuIdent.h (moved) * bsps/powerpc/include/libcpu/e500_mmu.h (moved) * bsps/powerpc/include/libcpu/io.h (moved) * bsps/powerpc/include/libcpu/irq.h (moved) * bsps/powerpc/include/libcpu/mmu.h (moved) * bsps/powerpc/include/libcpu/page.h (moved) * bsps/powerpc/include/libcpu/pgtable.h (moved) * bsps/powerpc/include/libcpu/powerpc-utility.h (moved) * bsps/powerpc/include/libcpu/pte121.h (moved) * bsps/powerpc/include/libcpu/raw_exception.h (moved) * bsps/powerpc/include/libcpu/spr.h (moved) * bsps/powerpc/include/libcpu/stackTrace.h (moved) * bsps/powerpc/include/libcpu/vectors.h (moved) * bsps/powerpc/include/mpc55xx/dspi.h (moved) * bsps/powerpc/include/mpc55xx/edma.h (moved) * bsps/powerpc/include/mpc55xx/emios.h (moved) * bsps/powerpc/include/mpc55xx/fsl-mpc551x.h (moved) * bsps/powerpc/include/mpc55xx/fsl-mpc555x.h (moved) * bsps/powerpc/include/mpc55xx/fsl-mpc556x.h (moved) * bsps/powerpc/include/mpc55xx/fsl-mpc564xL.h (moved) * bsps/powerpc/include/mpc55xx/fsl-mpc5668.h (moved) * bsps/powerpc/include/mpc55xx/fsl-mpc567x.h (moved) * bsps/powerpc/include/mpc55xx/mpc55xx.h (moved) * bsps/powerpc/include/mpc55xx/reg-defs.h (moved) * bsps/powerpc/include/mpc55xx/regs-edma.h (moved) * bsps/powerpc/include/mpc55xx/regs-mmu.h (moved) * bsps/powerpc/include/mpc55xx/regs.h (moved) * bsps/powerpc/include/mpc55xx/siu.h (moved) * bsps/powerpc/include/mpc55xx/watchdog.h (moved) * bsps/powerpc/include/mpc5xx.h (moved) * bsps/powerpc/include/mpc5xx/console.h (moved) * bsps/powerpc/include/mpc8260.h (moved) * bsps/powerpc/include/mpc8260/console.h (moved) * bsps/powerpc/include/mpc8260/cpm.h (moved) * bsps/powerpc/include/mpc8260/mmu.h (moved) * bsps/powerpc/include/mpc83xx/gtm.h (moved) * bsps/powerpc/include/mpc83xx/mpc83xx.h (moved) * bsps/powerpc/include/mpc83xx/mpc83xx_i2cdrv.h (moved) * bsps/powerpc/include/mpc83xx/mpc83xx_spidrv.h (moved) * bsps/powerpc/include/mpc8xx.h (moved) * bsps/powerpc/include/mpc8xx/console.h (moved) * bsps/powerpc/include/mpc8xx/cpm.h (moved) * bsps/powerpc/include/mpc8xx/mmu.h (moved) * bsps/powerpc/include/nvram.h (moved) * bsps/powerpc/include/ppc4xx/ppc405ex.h (moved) * bsps/powerpc/include/ppc4xx/ppc405gp.h (moved) * bsps/powerpc/include/rtems/powerpc/cache.h (moved) * bsps/powerpc/include/rtems/powerpc/debugmod.h (moved) * bsps/powerpc/include/rtems/powerpc/powerpc.h (moved) * bsps/powerpc/include/tty_drv.h (moved) * bsps/powerpc/motorola_powerpc/headers.am (added) * bsps/powerpc/motorola_powerpc/include/bsp.h (moved) * bsps/powerpc/motorola_powerpc/include/bsp/VMEConfig.h (moved) * bsps/powerpc/motorola_powerpc/include/bsp/irq.h (moved) * bsps/powerpc/motorola_powerpc/include/tm27.h (moved) * bsps/powerpc/mpc55xxevb/headers.am (added) * bsps/powerpc/mpc55xxevb/include/bsp.h (moved) * bsps/powerpc/mpc55xxevb/include/bsp/console-esci.h (moved) * bsps/powerpc/mpc55xxevb/include/bsp/console-generic.h (moved) * bsps/powerpc/mpc55xxevb/include/bsp/console-linflex.h (moved) * bsps/powerpc/mpc55xxevb/include/bsp/irq.h (moved) * bsps/powerpc/mpc55xxevb/include/bsp/mpc55xx-config.h (moved) * bsps/powerpc/mpc55xxevb/include/bsp/smsc9218i.h (moved) * bsps/powerpc/mpc55xxevb/include/tm27.h (moved) * bsps/powerpc/mpc8260ads/headers.am (added) * bsps/powerpc/mpc8260ads/include/bsp.h (moved) * bsps/powerpc/mpc8260ads/include/bsp/irq.h (moved) * bsps/powerpc/mpc8260ads/include/tm27.h (moved) * bsps/powerpc/mvme3100/headers.am (added) * bsps/powerpc/mvme3100/include/bsp.h (moved) * bsps/powerpc/mvme3100/include/bsp/VMEConfig.h (moved) * bsps/powerpc/mvme3100/include/bsp/if_tsec_pub.h (moved) * bsps/powerpc/mvme3100/include/bsp/irq.h (moved) * bsps/powerpc/mvme3100/include/bsp/mpc8540_i2c_busdrv.h (moved) * bsps/powerpc/mvme3100/include/tm27.h (moved) * bsps/powerpc/mvme5500/headers.am (added) * bsps/powerpc/mvme5500/include/bsp.h (moved) * bsps/powerpc/mvme5500/include/bsp/GT64260TWSI.h (moved) * bsps/powerpc/mvme5500/include/bsp/GT64260eth.h (moved) * bsps/powerpc/mvme5500/include/bsp/GT64260ethreg.h (moved) * bsps/powerpc/mvme5500/include/bsp/VMEConfig.h (moved) * bsps/powerpc/mvme5500/include/bsp/VPD.h (moved) * bsps/powerpc/mvme5500/include/bsp/bspException.h (moved) * bsps/powerpc/mvme5500/include/bsp/bspMvme5500.h (moved) * bsps/powerpc/mvme5500/include/bsp/gtpcireg.h (moved) * bsps/powerpc/mvme5500/include/bsp/gtreg.h (moved) * bsps/powerpc/mvme5500/include/bsp/if_wmreg.h (moved) * bsps/powerpc/mvme5500/include/bsp/irq.h (moved) * bsps/powerpc/mvme5500/include/bsp/pcireg.h (moved) * bsps/powerpc/mvme5500/include/tm27.h (moved) * bsps/powerpc/psim/headers.am (added) * bsps/powerpc/psim/include/bsp.h (moved) * bsps/powerpc/psim/include/bsp/irq.h (moved) * bsps/powerpc/psim/include/psim.h (moved) * bsps/powerpc/psim/include/tm27.h (moved) * bsps/powerpc/qemuppc/headers.am (added) * bsps/powerpc/qemuppc/include/bsp.h (moved) * bsps/powerpc/qemuppc/include/bsp/irq.h (moved) * bsps/powerpc/qemuppc/include/tm27.h (moved) * bsps/powerpc/qoriq/headers.am (added) * bsps/powerpc/qoriq/include/asm/epapr_hcalls.h (moved) * bsps/powerpc/qoriq/include/asm/fsl_hcalls.h (moved) * bsps/powerpc/qoriq/include/bsp.h (moved) * bsps/powerpc/qoriq/include/bsp/intercom.h (moved) * bsps/powerpc/qoriq/include/bsp/irq.h (moved) * bsps/powerpc/qoriq/include/bsp/mmu.h (moved) * bsps/powerpc/qoriq/include/bsp/qoriq.h (moved) * bsps/powerpc/qoriq/include/bsp/tsec-config.h (moved) * bsps/powerpc/qoriq/include/bsp/uart-bridge.h (moved) * bsps/powerpc/qoriq/include/tm27.h (moved) * bsps/powerpc/qoriq/include/uapi/asm/epapr_hcalls.h (moved) * bsps/powerpc/ss555/headers.am (added) * bsps/powerpc/ss555/include/bsp.h (moved) * bsps/powerpc/ss555/include/bsp/irq.h (moved) * bsps/powerpc/ss555/include/tm27.h (moved) * bsps/powerpc/t32mppc/headers.am (added) * bsps/powerpc/t32mppc/include/bsp.h (moved) * bsps/powerpc/t32mppc/include/bsp/irq.h (moved) * bsps/powerpc/t32mppc/include/tm27.h (moved) * bsps/powerpc/tqm8xx/headers.am (added) * bsps/powerpc/tqm8xx/include/bsp.h (moved) * bsps/powerpc/tqm8xx/include/bsp/8xx_immap.h (moved) * bsps/powerpc/tqm8xx/include/bsp/irq.h (moved) * bsps/powerpc/tqm8xx/include/bsp/spi.h (moved) * bsps/powerpc/tqm8xx/include/bsp/tqm.h (moved) * bsps/powerpc/tqm8xx/include/tm27.h (moved) * bsps/powerpc/virtex/headers.am (added) * bsps/powerpc/virtex/include/bsp.h (moved) * bsps/powerpc/virtex/include/bsp/irq.h (moved) * bsps/powerpc/virtex/include/bsp/opbintctrl.h (moved) * bsps/powerpc/virtex/include/tm27.h (moved) * bsps/powerpc/virtex/include/xiltemac.h (moved) * bsps/powerpc/virtex/include/xparameters_dflt.h (moved) * bsps/powerpc/virtex4/headers.am (added) * bsps/powerpc/virtex4/include/bsp.h (moved) * bsps/powerpc/virtex4/include/bsp/irq.h (moved) * bsps/powerpc/virtex4/include/bsp/mmu.h (moved) * bsps/powerpc/virtex4/include/tm27.h (moved) * bsps/powerpc/virtex5/headers.am (added) * bsps/powerpc/virtex5/include/bsp.h (moved) * bsps/powerpc/virtex5/include/bsp/irq.h (moved) * bsps/powerpc/virtex5/include/bsp/mmu.h (moved) * bsps/powerpc/virtex5/include/tm27.h (moved) * bsps/riscv/headers.am (added) * bsps/riscv/include/bsp/linker-symbols.h (moved) * bsps/riscv/riscv_generic/headers.am (added) * bsps/riscv/riscv_generic/include/bsp.h (moved) * bsps/riscv/riscv_generic/include/bsp/irq.h (moved) * bsps/riscv/riscv_generic/include/tm27.h (moved) * bsps/sh/gensh1/headers.am (added) * bsps/sh/gensh1/include/bsp.h (moved) * bsps/sh/gensh1/include/rtems/score/iosh7032.h (moved) * bsps/sh/gensh1/include/rtems/score/ispsh7032.h (moved) * bsps/sh/gensh1/include/sh/sci.h (moved) * bsps/sh/gensh1/include/sh/sh7_pfc.h (moved) * bsps/sh/gensh1/include/sh/sh7_sci.h (moved) * bsps/sh/gensh1/include/tm27.h (moved) * bsps/sh/gensh2/headers.am (added) * bsps/sh/gensh2/include/bsp.h (moved) * bsps/sh/gensh2/include/rtems/score/iosh7045.h (moved) * bsps/sh/gensh2/include/rtems/score/ispsh7045.h (moved) * bsps/sh/gensh2/include/sh/io_types.h (moved) * bsps/sh/gensh2/include/sh/sci.h (moved) * bsps/sh/gensh2/include/sh/sci_termios.h (moved) * bsps/sh/gensh2/include/sh/sh7_pfc.h (moved) * bsps/sh/gensh2/include/sh/sh7_sci.h (moved) * bsps/sh/gensh2/include/tm27.h (moved) * bsps/sh/gensh4/headers.am (added) * bsps/sh/gensh4/include/bsp.h (moved) * bsps/sh/gensh4/include/rtems/score/iosh7750.h (moved) * bsps/sh/gensh4/include/rtems/score/ipl.h (moved) * bsps/sh/gensh4/include/rtems/score/ispsh7750.h (moved) * bsps/sh/gensh4/include/rtems/score/sh4_regs.h (moved) * bsps/sh/gensh4/include/rtems/score/sh7750_regs.h (moved) * bsps/sh/gensh4/include/sdram.h (moved) * bsps/sh/gensh4/include/sh/sh4uart.h (moved) * bsps/sh/gensh4/include/tm27.h (moved) * bsps/sh/shsim/headers.am (added) * bsps/sh/shsim/include/bsp.h (moved) * bsps/sh/shsim/include/bsp/syscall.h (moved) * bsps/sh/shsim/include/tm27.h (moved) * bsps/sparc/erc32/headers.am (added) * bsps/sparc/erc32/include/bsp.h (moved) * bsps/sparc/erc32/include/bsp/irq.h (moved) * bsps/sparc/erc32/include/erc32.h (moved) * bsps/sparc/erc32/include/tm27.h (moved) * bsps/sparc/headers.am (added) * bsps/sparc/include/ambapp.h (moved) * bsps/sparc/include/ambapp_ids.h (moved) * bsps/sparc/include/bsp/ahbstat.h (moved) * bsps/sparc/include/bsp/apbuart.h (moved) * bsps/sparc/include/bsp/apbuart_cons.h (moved) * bsps/sparc/include/bsp/apbuart_termios.h (moved) * bsps/sparc/include/bsp/b1553brm.h (moved) * bsps/sparc/include/bsp/b1553rt.h (moved) * bsps/sparc/include/bsp/canmux.h (moved) * bsps/sparc/include/bsp/cons.h (moved) * bsps/sparc/include/bsp/debug_defs.h (moved) * bsps/sparc/include/bsp/genirq.h (moved) * bsps/sparc/include/bsp/gnatcommon.h (moved) * bsps/sparc/include/bsp/gpiolib.h (moved) * bsps/sparc/include/bsp/gptimer.h (moved) * bsps/sparc/include/bsp/gr1553b.h (moved) * bsps/sparc/include/bsp/gr1553bc.h (moved) * bsps/sparc/include/bsp/gr1553bc_list.h (moved) * bsps/sparc/include/bsp/gr1553bm.h (moved) * bsps/sparc/include/bsp/gr1553rt.h (moved) * bsps/sparc/include/bsp/gr_701.h (moved) * bsps/sparc/include/bsp/gr_cpci_gr740.h (moved) * bsps/sparc/include/bsp/gr_leon4_n2x.h (moved) * bsps/sparc/include/bsp/gr_rasta_adcdac.h (moved) * bsps/sparc/include/bsp/gr_rasta_io.h (moved) * bsps/sparc/include/bsp/gr_rasta_spw_router.h (moved) * bsps/sparc/include/bsp/gr_rasta_tmtc.h (moved) * bsps/sparc/include/bsp/gr_tmtc_1553.h (moved) * bsps/sparc/include/bsp/gradcdac.h (moved) * bsps/sparc/include/bsp/grascs.h (moved) * bsps/sparc/include/bsp/grcan.h (moved) * bsps/sparc/include/bsp/grctm.h (moved) * bsps/sparc/include/bsp/greth.h (moved) * bsps/sparc/include/bsp/grgpio.h (moved) * bsps/sparc/include/bsp/griommu.h (moved) * bsps/sparc/include/bsp/grpci.h (moved) * bsps/sparc/include/bsp/grpci2.h (moved) * bsps/sparc/include/bsp/grpci2dma.h (moved) * bsps/sparc/include/bsp/grpwm.h (moved) * bsps/sparc/include/bsp/grslink.h (moved) * bsps/sparc/include/bsp/grspw.h (moved) * bsps/sparc/include/bsp/grspw_pkt.h (moved) * bsps/sparc/include/bsp/grspw_router.h (moved) * bsps/sparc/include/bsp/grtc.h (moved) * bsps/sparc/include/bsp/grtm.h (moved) * bsps/sparc/include/bsp/i2cmst.h (moved) * bsps/sparc/include/bsp/l2c.h (moved) * bsps/sparc/include/bsp/l4stat.h (moved) * bsps/sparc/include/bsp/mctrl.h (moved) * bsps/sparc/include/bsp/memscrub.h (moved) * bsps/sparc/include/bsp/network_interface_add.h (moved) * bsps/sparc/include/bsp/occan.h (moved) * bsps/sparc/include/bsp/pcif.h (moved) * bsps/sparc/include/bsp/satcan.h (moved) * bsps/sparc/include/bsp/spictrl.h (moved) * bsps/sparc/include/bsp/spwcuc.h (moved) * bsps/sparc/include/bsp/tlib.h (moved) * bsps/sparc/include/drvmgr/ambapp_bus.h (moved) * bsps/sparc/include/drvmgr/ambapp_bus_grlib.h (moved) * bsps/sparc/include/drvmgr/bspcommon.h (moved) * bsps/sparc/include/drvmgr/leon2_amba_bus.h (moved) * bsps/sparc/include/grlib.h (moved) * bsps/sparc/include/libcpu/access.h (moved) * bsps/sparc/leon2/headers.am (added) * bsps/sparc/leon2/include/bsp.h (moved) * bsps/sparc/leon2/include/bsp/at697_pci.h (moved) * bsps/sparc/leon2/include/bsp/irq.h (moved) * bsps/sparc/leon2/include/leon.h (moved) * bsps/sparc/leon2/include/tm27.h (moved) * bsps/sparc/leon3/headers.am (added) * bsps/sparc/leon3/include/amba.h (moved) * bsps/sparc/leon3/include/bsp.h (moved) * bsps/sparc/leon3/include/bsp/irq.h (moved) * bsps/sparc/leon3/include/bsp/watchdog.h (moved) * bsps/sparc/leon3/include/leon.h (moved) * bsps/sparc/leon3/include/tm27.h (moved) * bsps/sparc64/headers.am (added) * bsps/sparc64/include/arch/arch.h (moved) * bsps/sparc64/include/arch/boot.h (moved) * bsps/sparc64/include/arch/mm/cache_spec.h (moved) * bsps/sparc64/include/arch/mm/frame.h (moved) * bsps/sparc64/include/arch/mm/mmu.h (moved) * bsps/sparc64/include/arch/mm/page.h (moved) * bsps/sparc64/include/arch/mm/sun4u/frame.h (moved) * bsps/sparc64/include/arch/mm/sun4u/mmu.h (moved) * bsps/sparc64/include/arch/mm/sun4u/page.h (moved) * bsps/sparc64/include/arch/mm/sun4u/tlb.h (moved) * bsps/sparc64/include/arch/mm/sun4u/tte.h (moved) * bsps/sparc64/include/arch/mm/tlb.h (moved) * bsps/sparc64/include/arch/mm/tte.h (moved) * bsps/sparc64/include/arch/regdef.h (moved) * bsps/sparc64/include/arch/stack.h (moved) * bsps/sparc64/include/arch/sun4u/arch.h (moved) * bsps/sparc64/include/asm.h (moved) * bsps/sparc64/include/boot/align.h (moved) * bsps/sparc64/include/boot/balloc.h (moved) * bsps/sparc64/include/boot/gentypes.h (moved) * bsps/sparc64/include/boot/main.h (moved) * bsps/sparc64/include/boot/ofw.h (moved) * bsps/sparc64/include/boot/ofw_tree.h (moved) * bsps/sparc64/include/boot/ofwarch.h (moved) * bsps/sparc64/include/boot/register.h (moved) * bsps/sparc64/include/boot/stack.h (moved) * bsps/sparc64/include/boot/types.h (moved) * bsps/sparc64/include/genarch/ofw/ofw_tree.h (moved) * bsps/sparc64/include/kernel/align.h (moved) * bsps/sparc64/include/traptable.h (moved) * bsps/sparc64/niagara/headers.am (added) * bsps/sparc64/niagara/include/bsp.h (moved) * bsps/sparc64/niagara/include/tm27.h (moved) * bsps/sparc64/usiii/headers.am (added) * bsps/sparc64/usiii/include/bsp.h (moved) * bsps/sparc64/usiii/include/tm27.h (moved) * bsps/v850/gdbv850sim/headers.am (added) * bsps/v850/gdbv850sim/include/bsp.h (moved) * bsps/v850/gdbv850sim/include/bsp/syscall.h (moved) * bsps/v850/gdbv850sim/include/tm27.h (moved) * c/Makefile.am (modified) * c/configure.ac (modified) * c/src/Makefile.am (modified) * c/src/aclocal/bsp-configure.m4 (modified) * c/src/aclocal/bsp-linkcmds.m4 (modified) * c/src/aclocal/check-networking.m4 (modified) * c/src/aclocal/prog-cc.m4 (modified) * c/src/aclocal/rtems-bsp-includes.m4 (added) * c/src/aclocal/rtems-build-top.m4 (added) * c/src/aclocal/rtems-includes.m4 (added) * c/src/aclocal/rtems-source-top.m4 (added) * c/src/automake/compile.am (modified) * c/src/automake/host.am (modified) * c/src/automake/local.am (modified) * c/src/automake/subdirs.am (modified) * c/src/configure.ac (modified) * c/src/lib/libbsp/Makefile.am (modified) * c/src/lib/libbsp/arm/Makefile.am (modified) * c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am (modified) * c/src/lib/libbsp/arm/altera-cyclone-v/configure.ac (modified) * c/src/lib/libbsp/arm/altera-cyclone-v/preinstall.am (deleted) * c/src/lib/libbsp/arm/altera-cyclone-v/startup/bsp_specs (moved) * c/src/lib/libbsp/arm/atsam/Makefile.am (modified) * c/src/lib/libbsp/arm/atsam/configure.ac (modified) * c/src/lib/libbsp/arm/atsam/preinstall.am (deleted) * c/src/lib/libbsp/arm/atsam/startup/bsp_specs (moved) * c/src/lib/libbsp/arm/beagle/Makefile.am (modified) * c/src/lib/libbsp/arm/beagle/configure.ac (modified) * c/src/lib/libbsp/arm/beagle/preinstall.am (deleted) * c/src/lib/libbsp/arm/beagle/startup/bsp_specs (moved) * c/src/lib/libbsp/arm/configure.ac (modified) * c/src/lib/libbsp/arm/csb336/Makefile.am (modified) * c/src/lib/libbsp/arm/csb336/configure.ac (modified) * c/src/lib/libbsp/arm/csb336/preinstall.am (deleted) * c/src/lib/libbsp/arm/csb336/startup/bsp_specs (moved) * c/src/lib/libbsp/arm/csb337/Makefile.am (modified) * c/src/lib/libbsp/arm/csb337/configure.ac (modified) * c/src/lib/libbsp/arm/csb337/preinstall.am (deleted) * c/src/lib/libbsp/arm/csb337/startup/bsp_specs (moved) * c/src/lib/libbsp/arm/edb7312/Makefile.am (modified) * c/src/lib/libbsp/arm/edb7312/configure.ac (modified) * c/src/lib/libbsp/arm/edb7312/preinstall.am (deleted) * c/src/lib/libbsp/arm/edb7312/startup/bsp_specs (moved) * c/src/lib/libbsp/arm/gdbarmsim/Makefile.am (modified) * c/src/lib/libbsp/arm/gdbarmsim/configure.ac (modified) * c/src/lib/libbsp/arm/gdbarmsim/preinstall.am (deleted) * c/src/lib/libbsp/arm/gdbarmsim/startup/bsp_specs (moved) * c/src/lib/libbsp/arm/gumstix/Makefile.am (modified) * c/src/lib/libbsp/arm/gumstix/configure.ac (modified) * c/src/lib/libbsp/arm/gumstix/preinstall.am (deleted) * c/src/lib/libbsp/arm/gumstix/startup/bsp_specs (moved) * c/src/lib/libbsp/arm/imx/Makefile.am (modified) * c/src/lib/libbsp/arm/imx/configure.ac (modified) * c/src/lib/libbsp/arm/imx/preinstall.am (deleted) * c/src/lib/libbsp/arm/imx/startup/bsp_specs (moved) * c/src/lib/libbsp/arm/lm3s69xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lm3s69xx/configure.ac (modified) * c/src/lib/libbsp/arm/lm3s69xx/preinstall.am (deleted) * c/src/lib/libbsp/arm/lm3s69xx/startup/bsp_specs (moved) * c/src/lib/libbsp/arm/lpc176x/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc176x/configure.ac (modified) * c/src/lib/libbsp/arm/lpc176x/preinstall.am (deleted) * c/src/lib/libbsp/arm/lpc176x/startup/bsp_specs (moved) * c/src/lib/libbsp/arm/lpc24xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc24xx/configure.ac (modified) * c/src/lib/libbsp/arm/lpc24xx/preinstall.am (deleted) * c/src/lib/libbsp/arm/lpc24xx/startup/bsp_specs (moved) * c/src/lib/libbsp/arm/lpc32xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc32xx/configure.ac (modified) * c/src/lib/libbsp/arm/lpc32xx/preinstall.am (deleted) * c/src/lib/libbsp/arm/lpc32xx/startup/bsp_specs (moved) * c/src/lib/libbsp/arm/preinstall.am (deleted) * c/src/lib/libbsp/arm/raspberrypi/Makefile.am (modified) * c/src/lib/libbsp/arm/raspberrypi/configure.ac (modified) * c/src/lib/libbsp/arm/raspberrypi/preinstall.am (deleted) * c/src/lib/libbsp/arm/raspberrypi/startup/bsp_specs (moved) * c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/configure.ac (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/preinstall.am (deleted) * c/src/lib/libbsp/arm/realview-pbx-a9/startup/bsp_specs (moved) * c/src/lib/libbsp/arm/rtl22xx/Makefile.am (modified) * c/src/lib/libbsp/arm/rtl22xx/configure.ac (modified) * c/src/lib/libbsp/arm/rtl22xx/preinstall.am (deleted) * c/src/lib/libbsp/arm/rtl22xx/startup/bsp_specs (moved) * c/src/lib/libbsp/arm/smdk2410/Makefile.am (modified) * c/src/lib/libbsp/arm/smdk2410/configure.ac (modified) * c/src/lib/libbsp/arm/smdk2410/preinstall.am (deleted) * c/src/lib/libbsp/arm/smdk2410/startup/bsp_specs (moved) * c/src/lib/libbsp/arm/stm32f4/Makefile.am (modified) * c/src/lib/libbsp/arm/stm32f4/configure.ac (modified) * c/src/lib/libbsp/arm/stm32f4/preinstall.am (deleted) * c/src/lib/libbsp/arm/stm32f4/startup/bsp_specs (moved) * c/src/lib/libbsp/arm/tms570/Makefile.am (modified) * c/src/lib/libbsp/arm/tms570/configure.ac (modified) * c/src/lib/libbsp/arm/tms570/preinstall.am (deleted) * c/src/lib/libbsp/arm/tms570/startup/bsp_specs (moved) * c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am (modified) * c/src/lib/libbsp/arm/xilinx-zynq/configure.ac (modified) * c/src/lib/libbsp/arm/xilinx-zynq/preinstall.am (deleted) * c/src/lib/libbsp/arm/xilinx-zynq/startup/bsp_specs (moved) * c/src/lib/libbsp/bfin/Makefile.am (modified) * c/src/lib/libbsp/bfin/TLL6527M/Makefile.am (modified) * c/src/lib/libbsp/bfin/TLL6527M/configure.ac (modified) * c/src/lib/libbsp/bfin/TLL6527M/preinstall.am (deleted) * c/src/lib/libbsp/bfin/TLL6527M/startup/bsp_specs (moved) * c/src/lib/libbsp/bfin/bf537Stamp/Makefile.am (modified) * c/src/lib/libbsp/bfin/bf537Stamp/configure.ac (modified) * c/src/lib/libbsp/bfin/bf537Stamp/preinstall.am (deleted) * c/src/lib/libbsp/bfin/bf537Stamp/startup/bsp_specs (moved) * c/src/lib/libbsp/bfin/configure.ac (modified) * c/src/lib/libbsp/bfin/eZKit533/Makefile.am (modified) * c/src/lib/libbsp/bfin/eZKit533/configure.ac (modified) * c/src/lib/libbsp/bfin/eZKit533/preinstall.am (deleted) * c/src/lib/libbsp/bfin/eZKit533/startup/bsp_specs (moved) * c/src/lib/libbsp/epiphany/Makefile.am (modified) * c/src/lib/libbsp/epiphany/configure.ac (modified) * c/src/lib/libbsp/epiphany/epiphany_sim/Makefile.am (modified) * c/src/lib/libbsp/epiphany/epiphany_sim/configure.ac (modified) * c/src/lib/libbsp/epiphany/epiphany_sim/include/bspopts.h (deleted) * c/src/lib/libbsp/epiphany/epiphany_sim/preinstall.am (deleted) * c/src/lib/libbsp/epiphany/epiphany_sim/startup/bsp_specs (moved) * c/src/lib/libbsp/epiphany/preinstall.am (deleted) * c/src/lib/libbsp/i386/Makefile.am (modified) * c/src/lib/libbsp/i386/configure.ac (modified) * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/configure.ac (modified) * c/src/lib/libbsp/i386/pc386/preinstall.am (deleted) * c/src/lib/libbsp/i386/pc386/startup/bsp_specs (moved) * c/src/lib/libbsp/i386/pc386/tools/configure.ac (modified) * c/src/lib/libbsp/lm32/Makefile.am (modified) * c/src/lib/libbsp/lm32/configure.ac (modified) * c/src/lib/libbsp/lm32/lm32_evr/Makefile.am (modified) * c/src/lib/libbsp/lm32/lm32_evr/configure.ac (modified) * c/src/lib/libbsp/lm32/lm32_evr/preinstall.am (deleted) * c/src/lib/libbsp/lm32/lm32_evr/startup/bsp_specs (moved) * c/src/lib/libbsp/lm32/milkymist/Makefile.am (modified) * c/src/lib/libbsp/lm32/milkymist/configure.ac (modified) * c/src/lib/libbsp/lm32/milkymist/preinstall.am (deleted) * c/src/lib/libbsp/lm32/milkymist/startup/bsp_specs (moved) * c/src/lib/libbsp/m32c/configure.ac (modified) * c/src/lib/libbsp/m32c/m32cbsp/Makefile.am (modified) * c/src/lib/libbsp/m32c/m32cbsp/configure.ac (modified) * c/src/lib/libbsp/m32c/m32cbsp/preinstall.am (deleted) * c/src/lib/libbsp/m32c/m32cbsp/startup/bsp_specs (moved) * c/src/lib/libbsp/m68k/Makefile.am (modified) * c/src/lib/libbsp/m68k/av5282/Makefile.am (modified) * c/src/lib/libbsp/m68k/av5282/configure.ac (modified) * c/src/lib/libbsp/m68k/av5282/preinstall.am (deleted) * c/src/lib/libbsp/m68k/av5282/startup/bsp_specs (moved) * c/src/lib/libbsp/m68k/configure.ac (modified) * c/src/lib/libbsp/m68k/csb360/Makefile.am (modified) * c/src/lib/libbsp/m68k/csb360/configure.ac (modified) * c/src/lib/libbsp/m68k/csb360/preinstall.am (deleted) * c/src/lib/libbsp/m68k/csb360/startup/bsp_specs (moved) * c/src/lib/libbsp/m68k/gen68340/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/configure.ac (modified) * c/src/lib/libbsp/m68k/gen68340/preinstall.am (deleted) * c/src/lib/libbsp/m68k/gen68340/startup/bsp_specs (moved) * c/src/lib/libbsp/m68k/gen68360/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/configure.ac (modified) * c/src/lib/libbsp/m68k/gen68360/preinstall.am (deleted) * c/src/lib/libbsp/m68k/gen68360/startup/bsp_specs (moved) * c/src/lib/libbsp/m68k/genmcf548x/Makefile.am (modified) * c/src/lib/libbsp/m68k/genmcf548x/configure.ac (modified) * c/src/lib/libbsp/m68k/genmcf548x/preinstall.am (deleted) * c/src/lib/libbsp/m68k/genmcf548x/startup/bsp_specs (moved) * c/src/lib/libbsp/m68k/mcf5206elite/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5206elite/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5206elite/preinstall.am (deleted) * c/src/lib/libbsp/m68k/mcf5206elite/startup/bsp_specs (moved) * c/src/lib/libbsp/m68k/mcf5206elite/tools/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf52235/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf52235/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf52235/preinstall.am (deleted) * c/src/lib/libbsp/m68k/mcf52235/startup/bsp_specs (moved) * c/src/lib/libbsp/m68k/mcf5225x/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5225x/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5225x/preinstall.am (deleted) * c/src/lib/libbsp/m68k/mcf5225x/startup/bsp_specs (moved) * c/src/lib/libbsp/m68k/mcf5235/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5235/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5235/preinstall.am (deleted) * c/src/lib/libbsp/m68k/mcf5235/startup/bsp_specs (moved) * c/src/lib/libbsp/m68k/mcf5329/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5329/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5329/preinstall.am (deleted) * c/src/lib/libbsp/m68k/mcf5329/startup/bsp_specs (moved) * c/src/lib/libbsp/m68k/mrm332/Makefile.am (modified) * c/src/lib/libbsp/m68k/mrm332/configure.ac (modified) * c/src/lib/libbsp/m68k/mrm332/preinstall.am (deleted) * c/src/lib/libbsp/m68k/mrm332/startup/bsp_specs (moved) * c/src/lib/libbsp/m68k/mvme147/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme147/preinstall.am (deleted) * c/src/lib/libbsp/m68k/mvme147/startup/bsp_specs (moved) * c/src/lib/libbsp/m68k/mvme147s/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme147s/preinstall.am (deleted) * c/src/lib/libbsp/m68k/mvme147s/startup/bsp_specs (moved) * c/src/lib/libbsp/m68k/mvme162/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme162/preinstall.am (deleted) * c/src/lib/libbsp/m68k/mvme162/startup/bsp_specs (moved) * c/src/lib/libbsp/m68k/mvme167/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme167/preinstall.am (deleted) * c/src/lib/libbsp/m68k/mvme167/startup/bsp_specs (moved) * c/src/lib/libbsp/m68k/preinstall.am (deleted) * c/src/lib/libbsp/m68k/uC5282/Makefile.am (modified) * c/src/lib/libbsp/m68k/uC5282/configure.ac (modified) * c/src/lib/libbsp/m68k/uC5282/preinstall.am (deleted) * c/src/lib/libbsp/m68k/uC5282/startup/bsp_specs (moved) * c/src/lib/libbsp/mips/Makefile.am (modified) * c/src/lib/libbsp/mips/configure.ac (modified) * c/src/lib/libbsp/mips/csb350/Makefile.am (modified) * c/src/lib/libbsp/mips/csb350/configure.ac (modified) * c/src/lib/libbsp/mips/csb350/preinstall.am (deleted) * c/src/lib/libbsp/mips/csb350/startup/bsp_specs (moved) * c/src/lib/libbsp/mips/hurricane/Makefile.am (modified) * c/src/lib/libbsp/mips/hurricane/configure.ac (modified) * c/src/lib/libbsp/mips/hurricane/preinstall.am (deleted) * c/src/lib/libbsp/mips/hurricane/startup/bsp_specs (moved) * c/src/lib/libbsp/mips/jmr3904/Makefile.am (modified) * c/src/lib/libbsp/mips/jmr3904/configure.ac (modified) * c/src/lib/libbsp/mips/jmr3904/preinstall.am (deleted) * c/src/lib/libbsp/mips/jmr3904/startup/bsp_specs (moved) * c/src/lib/libbsp/mips/malta/Makefile.am (modified) * c/src/lib/libbsp/mips/malta/configure.ac (modified) * c/src/lib/libbsp/mips/malta/preinstall.am (deleted) * c/src/lib/libbsp/mips/malta/startup/bsp_specs (moved) * c/src/lib/libbsp/mips/rbtx4925/Makefile.am (modified) * c/src/lib/libbsp/mips/rbtx4925/configure.ac (modified) * c/src/lib/libbsp/mips/rbtx4925/preinstall.am (deleted) * c/src/lib/libbsp/mips/rbtx4925/startup/bsp_specs (moved) * c/src/lib/libbsp/mips/rbtx4938/Makefile.am (modified) * c/src/lib/libbsp/mips/rbtx4938/configure.ac (modified) * c/src/lib/libbsp/mips/rbtx4938/preinstall.am (deleted) * c/src/lib/libbsp/mips/rbtx4938/startup/bsp_specs (moved) * c/src/lib/libbsp/moxie/configure.ac (modified) * c/src/lib/libbsp/moxie/moxiesim/Makefile.am (modified) * c/src/lib/libbsp/moxie/moxiesim/configure.ac (modified) * c/src/lib/libbsp/moxie/moxiesim/preinstall.am (deleted) * c/src/lib/libbsp/moxie/moxiesim/startup/bsp_specs (moved) * c/src/lib/libbsp/nios2/configure.ac (modified) * c/src/lib/libbsp/nios2/nios2_iss/Makefile.am (modified) * c/src/lib/libbsp/nios2/nios2_iss/configure.ac (modified) * c/src/lib/libbsp/nios2/nios2_iss/preinstall.am (deleted) * c/src/lib/libbsp/nios2/nios2_iss/startup/bsp_specs (moved) * c/src/lib/libbsp/no_cpu/configure.ac (modified) * c/src/lib/libbsp/no_cpu/no_bsp/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/configure.ac (modified) * c/src/lib/libbsp/no_cpu/no_bsp/preinstall.am (deleted) * c/src/lib/libbsp/no_cpu/no_bsp/startup/bsp_specs (moved) * c/src/lib/libbsp/or1k/Makefile.am (modified) * c/src/lib/libbsp/or1k/configure.ac (modified) * c/src/lib/libbsp/or1k/generic_or1k/Makefile.am (modified) * c/src/lib/libbsp/or1k/generic_or1k/configure.ac (modified) * c/src/lib/libbsp/or1k/generic_or1k/preinstall.am (deleted) * c/src/lib/libbsp/or1k/generic_or1k/startup/bsp_specs (moved) * c/src/lib/libbsp/or1k/preinstall.am (deleted) * c/src/lib/libbsp/powerpc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/beatnik/Makefile.am (modified) * c/src/lib/libbsp/powerpc/beatnik/configure.ac (modified) * c/src/lib/libbsp/powerpc/beatnik/preinstall.am (deleted) * c/src/lib/libbsp/powerpc/beatnik/startup/bsp_specs (moved) * c/src/lib/libbsp/powerpc/configure.ac (modified) * c/src/lib/libbsp/powerpc/gen5200/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen5200/configure.ac (modified) * c/src/lib/libbsp/powerpc/gen5200/preinstall.am (deleted) * c/src/lib/libbsp/powerpc/gen5200/startup/bsp_specs (moved) * c/src/lib/libbsp/powerpc/gen83xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen83xx/configure.ac (modified) * c/src/lib/libbsp/powerpc/gen83xx/preinstall.am (deleted) * c/src/lib/libbsp/powerpc/gen83xx/startup/bsp_specs (moved) * c/src/lib/libbsp/powerpc/haleakala/Makefile.am (modified) * c/src/lib/libbsp/powerpc/haleakala/configure.ac (modified) * c/src/lib/libbsp/powerpc/haleakala/preinstall.am (deleted) * c/src/lib/libbsp/powerpc/haleakala/startup/bsp_specs (moved) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/configure.ac (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/preinstall.am (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/startup/bsp_specs (moved) * c/src/lib/libbsp/powerpc/mpc55xxevb/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/configure.ac (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/preinstall.am (deleted) * c/src/lib/libbsp/powerpc/mpc55xxevb/startup/bsp_specs (moved) * c/src/lib/libbsp/powerpc/mpc8260ads/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/configure.ac (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/preinstall.am (deleted) * c/src/lib/libbsp/powerpc/mpc8260ads/startup/bsp_specs (moved) * c/src/lib/libbsp/powerpc/mvme3100/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme3100/configure.ac (modified) * c/src/lib/libbsp/powerpc/mvme3100/preinstall.am (deleted) * c/src/lib/libbsp/powerpc/mvme3100/startup/bsp_specs (moved) * c/src/lib/libbsp/powerpc/mvme5500/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme5500/configure.ac (modified) * c/src/lib/libbsp/powerpc/mvme5500/preinstall.am (deleted) * c/src/lib/libbsp/powerpc/mvme5500/startup/bsp_specs (moved) * c/src/lib/libbsp/powerpc/psim/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/configure.ac (modified) * c/src/lib/libbsp/powerpc/psim/preinstall.am (deleted) * c/src/lib/libbsp/powerpc/psim/startup/bsp_specs (moved) * c/src/lib/libbsp/powerpc/qemuppc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qemuppc/configure.ac (modified) * c/src/lib/libbsp/powerpc/qemuppc/preinstall.am (deleted) * c/src/lib/libbsp/powerpc/qemuppc/startup/bsp_specs (moved) * c/src/lib/libbsp/powerpc/qoriq/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qoriq/configure.ac (modified) * c/src/lib/libbsp/powerpc/qoriq/preinstall.am (deleted) * c/src/lib/libbsp/powerpc/qoriq/startup/bsp_specs (moved) * c/src/lib/libbsp/powerpc/ss555/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ss555/configure.ac (modified) * c/src/lib/libbsp/powerpc/ss555/preinstall.am (deleted) * c/src/lib/libbsp/powerpc/ss555/startup/bsp_specs (moved) * c/src/lib/libbsp/powerpc/t32mppc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/t32mppc/configure.ac (modified) * c/src/lib/libbsp/powerpc/t32mppc/preinstall.am (deleted) * c/src/lib/libbsp/powerpc/t32mppc/startup/bsp_specs (moved) * c/src/lib/libbsp/powerpc/tqm8xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/tqm8xx/configure.ac (modified) * c/src/lib/libbsp/powerpc/tqm8xx/preinstall.am (deleted) * c/src/lib/libbsp/powerpc/tqm8xx/startup/bsp_specs (moved) * c/src/lib/libbsp/powerpc/virtex/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex/configure.ac (modified) * c/src/lib/libbsp/powerpc/virtex/preinstall.am (deleted) * c/src/lib/libbsp/powerpc/virtex/startup/bsp_specs (moved) * c/src/lib/libbsp/powerpc/virtex4/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex4/configure.ac (modified) * c/src/lib/libbsp/powerpc/virtex4/preinstall.am (deleted) * c/src/lib/libbsp/powerpc/virtex4/startup/bsp_specs (moved) * c/src/lib/libbsp/powerpc/virtex5/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex5/configure.ac (modified) * c/src/lib/libbsp/powerpc/virtex5/preinstall.am (deleted) * c/src/lib/libbsp/powerpc/virtex5/startup/bsp_specs (moved) * c/src/lib/libbsp/preinstall.am (deleted) * c/src/lib/libbsp/riscv/Makefile.am (modified) * c/src/lib/libbsp/riscv/configure.ac (modified) * c/src/lib/libbsp/riscv/preinstall.am (deleted) * c/src/lib/libbsp/riscv/riscv_generic/Makefile.am (modified) * c/src/lib/libbsp/riscv/riscv_generic/configure.ac (modified) * c/src/lib/libbsp/riscv/riscv_generic/include/bspopts.h (deleted) * c/src/lib/libbsp/riscv/riscv_generic/preinstall.am (deleted) * c/src/lib/libbsp/riscv/riscv_generic/startup/bsp_specs (moved) * c/src/lib/libbsp/sh/configure.ac (modified) * c/src/lib/libbsp/sh/gensh1/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/configure.ac (modified) * c/src/lib/libbsp/sh/gensh1/preinstall.am (deleted) * c/src/lib/libbsp/sh/gensh1/startup/bsp_specs (moved) * c/src/lib/libbsp/sh/gensh2/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/configure.ac (modified) * c/src/lib/libbsp/sh/gensh2/preinstall.am (deleted) * c/src/lib/libbsp/sh/gensh2/startup/bsp_specs (moved) * c/src/lib/libbsp/sh/gensh4/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh4/configure.ac (modified) * c/src/lib/libbsp/sh/gensh4/preinstall.am (deleted) * c/src/lib/libbsp/sh/gensh4/startup/bsp_specs (moved) * c/src/lib/libbsp/sh/shsim/Makefile.am (modified) * c/src/lib/libbsp/sh/shsim/configure.ac (modified) * c/src/lib/libbsp/sh/shsim/preinstall.am (deleted) * c/src/lib/libbsp/sh/shsim/startup/bsp_specs (moved) * c/src/lib/libbsp/sparc/Makefile.am (modified) * c/src/lib/libbsp/sparc/configure.ac (modified) * c/src/lib/libbsp/sparc/erc32/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/configure.ac (modified) * c/src/lib/libbsp/sparc/erc32/preinstall.am (deleted) * c/src/lib/libbsp/sparc/erc32/startup/bsp_specs (moved) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/configure.ac (modified) * c/src/lib/libbsp/sparc/leon2/preinstall.am (deleted) * c/src/lib/libbsp/sparc/leon2/startup/bsp_specs (moved) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/configure.ac (modified) * c/src/lib/libbsp/sparc/leon3/preinstall.am (deleted) * c/src/lib/libbsp/sparc/leon3/startup/bsp_specs (moved) * c/src/lib/libbsp/sparc64/Makefile.am (modified) * c/src/lib/libbsp/sparc64/configure.ac (modified) * c/src/lib/libbsp/sparc64/niagara/Makefile.am (modified) * c/src/lib/libbsp/sparc64/niagara/configure.ac (modified) * c/src/lib/libbsp/sparc64/niagara/preinstall.am (deleted) * c/src/lib/libbsp/sparc64/niagara/startup/bsp_specs (moved) * c/src/lib/libbsp/sparc64/usiii/Makefile.am (modified) * c/src/lib/libbsp/sparc64/usiii/configure.ac (modified) * c/src/lib/libbsp/sparc64/usiii/preinstall.am (deleted) * c/src/lib/libbsp/sparc64/usiii/startup/bsp_specs (moved) * c/src/lib/libbsp/v850/Makefile.am (modified) * c/src/lib/libbsp/v850/configure.ac (modified) * c/src/lib/libbsp/v850/gdbv850sim/Makefile.am (modified) * c/src/lib/libbsp/v850/gdbv850sim/configure.ac (modified) * c/src/lib/libbsp/v850/gdbv850sim/preinstall.am (deleted) * c/src/lib/libbsp/v850/gdbv850sim/startup/bsp_specs (moved) * c/src/lib/libbsp/v850/preinstall.am (deleted) * c/src/lib/libcpu/Makefile.am (modified) * c/src/lib/libcpu/arm/Makefile.am (modified) * c/src/lib/libcpu/arm/configure.ac (modified) * c/src/lib/libcpu/arm/preinstall.am (deleted) * c/src/lib/libcpu/bfin/Makefile.am (modified) * c/src/lib/libcpu/bfin/configure.ac (modified) * c/src/lib/libcpu/bfin/preinstall.am (deleted) * c/src/lib/libcpu/i386/Makefile.am (modified) * c/src/lib/libcpu/i386/configure.ac (modified) * c/src/lib/libcpu/i386/preinstall.am (deleted) * c/src/lib/libcpu/lm32/Makefile.am (modified) * c/src/lib/libcpu/lm32/configure.ac (modified) * c/src/lib/libcpu/lm32/preinstall.am (deleted) * c/src/lib/libcpu/m68k/Makefile.am (modified) * c/src/lib/libcpu/m68k/configure.ac (modified) * c/src/lib/libcpu/m68k/preinstall.am (deleted) * c/src/lib/libcpu/mips/Makefile.am (modified) * c/src/lib/libcpu/mips/configure.ac (modified) * c/src/lib/libcpu/mips/preinstall.am (deleted) * c/src/lib/libcpu/nios2/Makefile.am (modified) * c/src/lib/libcpu/nios2/configure.ac (modified) * c/src/lib/libcpu/nios2/preinstall.am (deleted) * c/src/lib/libcpu/or1k/Makefile.am (modified) * c/src/lib/libcpu/or1k/configure.ac (modified) * c/src/lib/libcpu/or1k/preinstall.am (deleted) * c/src/lib/libcpu/powerpc/Makefile.am (modified) * c/src/lib/libcpu/powerpc/configure.ac (modified) * c/src/lib/libcpu/powerpc/preinstall.am (deleted) * c/src/lib/libcpu/sparc/Makefile.am (modified) * c/src/lib/libcpu/sparc/configure.ac (modified) * c/src/lib/libcpu/sparc/preinstall.am (deleted) * c/src/lib/libcpu/sparc64/Makefile.am (modified) * c/src/lib/libcpu/sparc64/configure.ac (modified) * c/src/lib/libcpu/sparc64/preinstall.am (deleted) * c/src/libchip/Makefile.am (modified) * c/src/libchip/preinstall.am (deleted) * c/src/make/configure.ac (modified) * c/src/wrapup/Makefile.am (modified) * c/src/wrapup/preinstall.am (deleted) * configure.ac (modified) * cpukit/Makefile.am (modified) * cpukit/acinclude.m4 (modified) * cpukit/aclocal/check-networking.m4 (modified) * cpukit/aclocal/prog-cc.m4 (modified) * cpukit/aclocal/rtems-bsp-includes.m4 (added) * cpukit/aclocal/rtems-build-top.m4 (added) * cpukit/aclocal/rtems-includes.m4 (added) * cpukit/aclocal/rtems-source-top.m4 (added) * cpukit/automake/compile.am (modified) * cpukit/automake/local.am (modified) * cpukit/automake/subdirs.am (modified) * cpukit/configure.ac (modified) * cpukit/dev/Makefile.am (modified) * cpukit/dev/preinstall.am (deleted) * cpukit/dtc/libfdt/Makefile.am (modified) * cpukit/dtc/libfdt/preinstall.am (deleted) * cpukit/ftpd/Makefile.am (modified) * cpukit/ftpd/preinstall.am (deleted) * cpukit/headers.am (added) * cpukit/include/adainclude/preinstall.am (deleted) * cpukit/include/aio.h (moved) * cpukit/include/dev/i2c/eeprom.h (moved) * cpukit/include/dev/i2c/fpga-i2c-slave.h (moved) * cpukit/include/dev/i2c/gpio-nxp-pca9535.h (moved) * cpukit/include/dev/i2c/i2c.h (moved) * cpukit/include/dev/i2c/sensor-lm75a.h (moved) * cpukit/include/dev/i2c/switch-nxp-pca9548a.h (moved) * cpukit/include/dev/i2c/ti-ads-16bit-adc.h (moved) * cpukit/include/dev/i2c/ti-lm25066a.h (moved) * cpukit/include/dev/i2c/ti-tmp112.h (moved) * cpukit/include/dev/i2c/xilinx-axi-i2c.h (moved) * cpukit/include/dev/serial/sc16is752.h (moved) * cpukit/include/dev/spi/spi.h (moved) * cpukit/include/dlfcn.h (moved) * cpukit/include/drvmgr/drvmgr.h (moved) * cpukit/include/drvmgr/drvmgr_confdefs.h (moved) * cpukit/include/drvmgr/drvmgr_list.h (moved) * cpukit/include/drvmgr/pci_bus.h (moved) * cpukit/include/fdt.h (moved) * cpukit/include/libfdt.h (moved) * cpukit/include/libfdt_env.h (moved) * cpukit/include/librtemsNfs.h (moved) * cpukit/include/link.h (moved) * cpukit/include/link_elf.h (moved) * cpukit/include/linux/i2c-dev.h (moved) * cpukit/include/linux/i2c.h (moved) * cpukit/include/linux/spi/spidev.h (moved) * cpukit/include/machine/_kernel_cpuset.h (moved) * cpukit/include/machine/_kernel_param.h (moved) * cpukit/include/machine/_kernel_time.h (moved) * cpukit/include/machine/_kernel_types.h (moved) * cpukit/include/machine/_timecounter.h (moved) * cpukit/include/md4.h (moved) * cpukit/include/md5.h (moved) * cpukit/include/mghttpd/mongoose.h (moved) * cpukit/include/mqueue.h (moved) * cpukit/include/pci.h (moved) * cpukit/include/pci/access.h (moved) * cpukit/include/pci/cfg.h (moved) * cpukit/include/pci/cfg_auto.h (moved) * cpukit/include/pci/cfg_peripheral.h (moved) * cpukit/include/pci/cfg_read.h (moved) * cpukit/include/pci/cfg_static.h (moved) * cpukit/include/pci/ids.h (moved) * cpukit/include/pci/ids_extra.h (moved) * cpukit/include/pci/irq.h (moved) * cpukit/include/pci/pcireg.h (moved) * cpukit/include/rpc/auth.h (moved) * cpukit/include/rpc/auth_unix.h (moved) * cpukit/include/rpc/clnt.h (moved) * cpukit/include/rpc/clnt_soc.h (moved) * cpukit/include/rpc/clnt_stat.h (moved) * cpukit/include/rpc/pmap_clnt.h (moved) * cpukit/include/rpc/pmap_prot.h (moved) * cpukit/include/rpc/pmap_rmt.h (moved) * cpukit/include/rpc/rpc.h (moved) * cpukit/include/rpc/rpc_com.h (moved) * cpukit/include/rpc/rpc_msg.h (moved) * cpukit/include/rpc/rpcent.h (moved) * cpukit/include/rpc/svc.h (moved) * cpukit/include/rpc/svc_auth.h (moved) * cpukit/include/rpc/svc_soc.h (moved) * cpukit/include/rpc/types.h (moved) * cpukit/include/rpc/xdr.h (moved) * cpukit/include/rtems.h (moved) * cpukit/include/rtems/assoc.h (moved) * cpukit/include/rtems/bdbuf.h (moved) * cpukit/include/rtems/bdpart.h (moved) * cpukit/include/rtems/blkdev.h (moved) * cpukit/include/rtems/bsd.h (moved) * cpukit/include/rtems/bspcmdline.h (moved) * cpukit/include/rtems/capture-cli.h (moved) * cpukit/include/rtems/capture.h (moved) * cpukit/include/rtems/captureimpl.h (moved) * cpukit/include/rtems/cbs.h (moved) * cpukit/include/rtems/chain.h (moved) * cpukit/include/rtems/confdefs.h (moved) * cpukit/include/rtems/config.h (moved) * cpukit/include/rtems/counter.h (moved) * cpukit/include/rtems/cpuuse.h (moved) * cpukit/include/rtems/debugger/rtems-debugger-remote.h (moved) * cpukit/include/rtems/debugger/rtems-debugger-server.h (moved) * cpukit/include/rtems/devfs.h (moved) * cpukit/include/rtems/deviceio.h (moved) * cpukit/include/rtems/devnull.h (moved) * cpukit/include/rtems/devzero.h (moved) * cpukit/include/rtems/diskdevs.h (moved) * cpukit/include/rtems/dosfs.h (moved) * cpukit/include/rtems/dumpbuf.h (moved) * cpukit/include/rtems/error.h (moved) * cpukit/include/rtems/extension.h (moved) * cpukit/include/rtems/extensionimpl.h (moved) * cpukit/include/rtems/fatal.h (moved) * cpukit/include/rtems/fb.h (moved) * cpukit/include/rtems/flashdisk.h (moved) * cpukit/include/rtems/fsmount.h (moved) * cpukit/include/rtems/ftpd.h (moved) * cpukit/include/rtems/gxx_wrappers.h (moved) * cpukit/include/rtems/ide_part_table.h (moved) * cpukit/include/rtems/imfs.h (moved) * cpukit/include/rtems/init.h (moved) * cpukit/include/rtems/io.h (moved) * cpukit/include/rtems/ioimpl.h (moved) * cpukit/include/rtems/iosupp.h (moved) * cpukit/include/rtems/jffs2.h (moved) * cpukit/include/rtems/libcsupport.h (moved) * cpukit/include/rtems/libi2c.h (moved) * cpukit/include/rtems/libio.h (moved) * cpukit/include/rtems/libio_.h (moved) * cpukit/include/rtems/linkersets.h (moved) * cpukit/include/rtems/malloc.h (moved) * cpukit/include/rtems/media.h (moved) * cpukit/include/rtems/monitor.h (moved) * cpukit/include/rtems/mouse_parser.h (moved) * cpukit/include/rtems/mptables.h (moved) * cpukit/include/rtems/mw_uid.h (moved) * cpukit/include/rtems/nvdisk-sram.h (moved) * cpukit/include/rtems/nvdisk.h (moved) * cpukit/include/rtems/passwd.h (moved) * cpukit/include/rtems/pipe.h (moved) * cpukit/include/rtems/posix/aio_misc.h (moved) * cpukit/include/rtems/posix/barrierimpl.h (moved) * cpukit/include/rtems/posix/condimpl.h (moved) * cpukit/include/rtems/posix/config.h (moved) * cpukit/include/rtems/posix/key.h (moved) * cpukit/include/rtems/posix/keyimpl.h (moved) * cpukit/include/rtems/posix/mmanimpl.h (moved) * cpukit/include/rtems/posix/mqueue.h (moved) * cpukit/include/rtems/posix/mqueueimpl.h (moved) * cpukit/include/rtems/posix/muteximpl.h (moved) * cpukit/include/rtems/posix/posixapi.h (moved) * cpukit/include/rtems/posix/priorityimpl.h (moved) * cpukit/include/rtems/posix/psignal.h (moved) * cpukit/include/rtems/posix/psignalimpl.h (moved) * cpukit/include/rtems/posix/pthread.h (moved) * cpukit/include/rtems/posix/pthreadattrimpl.h (moved) * cpukit/include/rtems/posix/pthreadimpl.h (moved) * cpukit/include/rtems/posix/ptimer.h (moved) * cpukit/include/rtems/posix/rwlockimpl.h (moved) * cpukit/include/rtems/posix/semaphore.h (moved) * cpukit/include/rtems/posix/semaphoreimpl.h (moved) * cpukit/include/rtems/posix/shm.h (moved) * cpukit/include/rtems/posix/shmimpl.h (moved) * cpukit/include/rtems/posix/sigset.h (moved) * cpukit/include/rtems/posix/spinlockimpl.h (moved) * cpukit/include/rtems/posix/threadsup.h (moved) * cpukit/include/rtems/posix/timer.h (moved) * cpukit/include/rtems/posix/timerimpl.h (moved) * cpukit/include/rtems/profiling.h (moved) * cpukit/include/rtems/pty.h (moved) * cpukit/include/rtems/qreslib.h (moved) * cpukit/include/rtems/ramdisk.h (moved) * cpukit/include/rtems/rbheap.h (moved) * cpukit/include/rtems/rbtree.h (moved) * cpukit/include/rtems/rfs/rtems-rfs-bitmaps.h (moved) * cpukit/include/rtems/rfs/rtems-rfs-block-pos.h (moved) * cpukit/include/rtems/rfs/rtems-rfs-block.h (moved) * cpukit/include/rtems/rfs/rtems-rfs-buffer.h (moved) * cpukit/include/rtems/rfs/rtems-rfs-data.h (moved) * cpukit/include/rtems/rfs/rtems-rfs-dir-hash.h (moved) * cpukit/include/rtems/rfs/rtems-rfs-dir.h (moved) * cpukit/include/rtems/rfs/rtems-rfs-file-system-fwd.h (moved) * cpukit/include/rtems/rfs/rtems-rfs-file-system.h (moved) * cpukit/include/rtems/rfs/rtems-rfs-file.h (moved) * cpukit/include/rtems/rfs/rtems-rfs-group.h (moved) * cpukit/include/rtems/rfs/rtems-rfs-inode.h (moved) * cpukit/include/rtems/rfs/rtems-rfs-link.h (moved) * cpukit/include/rtems/rfs/rtems-rfs-mutex.h (moved) * cpukit/include/rtems/rfs/rtems-rfs-trace.h (moved) * cpukit/include/rtems/ringbuf.h (moved) * cpukit/include/rtems/rtems-debugger.h (moved) * cpukit/include/rtems/rtems-fdt-shell.h (moved) * cpukit/include/rtems/rtems-fdt.h (moved) * cpukit/include/rtems/rtems-rfs-format.h (moved) * cpukit/include/rtems/rtems-rfs-shell.h (moved) * cpukit/include/rtems/rtems-rfs.h (moved) * cpukit/include/rtems/rtems/asr.h (moved) * cpukit/include/rtems/rtems/asrimpl.h (moved) * cpukit/include/rtems/rtems/attr.h (moved) * cpukit/include/rtems/rtems/attrimpl.h (moved) * cpukit/include/rtems/rtems/barrier.h (moved) * cpukit/include/rtems/rtems/barrierimpl.h (moved) * cpukit/include/rtems/rtems/cache.h (moved) * cpukit/include/rtems/rtems/clock.h (moved) * cpukit/include/rtems/rtems/config.h (moved) * cpukit/include/rtems/rtems/dpmem.h (moved) * cpukit/include/rtems/rtems/dpmemimpl.h (moved) * cpukit/include/rtems/rtems/event.h (moved) * cpukit/include/rtems/rtems/eventimpl.h (moved) * cpukit/include/rtems/rtems/eventmp.h (moved) * cpukit/include/rtems/rtems/intr.h (moved) * cpukit/include/rtems/rtems/mainpage.h (moved) * cpukit/include/rtems/rtems/message.h (moved) * cpukit/include/rtems/rtems/messageimpl.h (moved) * cpukit/include/rtems/rtems/modes.h (moved) * cpukit/include/rtems/rtems/modesimpl.h (moved) * cpukit/include/rtems/rtems/mp.h (moved) * cpukit/include/rtems/rtems/msgmp.h (moved) * cpukit/include/rtems/rtems/object.h (moved) * cpukit/include/rtems/rtems/options.h (moved) * cpukit/include/rtems/rtems/optionsimpl.h (moved) * cpukit/include/rtems/rtems/part.h (moved) * cpukit/include/rtems/rtems/partimpl.h (moved) * cpukit/include/rtems/rtems/partmp.h (moved) * cpukit/include/rtems/rtems/ratemon.h (moved) * cpukit/include/rtems/rtems/ratemonimpl.h (moved) * cpukit/include/rtems/rtems/region.h (moved) * cpukit/include/rtems/rtems/regionimpl.h (moved) * cpukit/include/rtems/rtems/sem.h (moved) * cpukit/include/rtems/rtems/semimpl.h (moved) * cpukit/include/rtems/rtems/semmp.h (moved) * cpukit/include/rtems/rtems/signal.h (moved) * cpukit/include/rtems/rtems/signalimpl.h (moved) * cpukit/include/rtems/rtems/signalmp.h (moved) * cpukit/include/rtems/rtems/smp.h (moved) * cpukit/include/rtems/rtems/status.h (moved) * cpukit/include/rtems/rtems/statusimpl.h (moved) * cpukit/include/rtems/rtems/support.h (moved) * cpukit/include/rtems/rtems/taskmp.h (moved) * cpukit/include/rtems/rtems/tasks.h (moved) * cpukit/include/rtems/rtems/tasksimpl.h (moved) * cpukit/include/rtems/rtems/timer.h (moved) * cpukit/include/rtems/rtems/timerimpl.h (moved) * cpukit/include/rtems/rtems/types.h (moved) * cpukit/include/rtems/rtemsdialer.h (moved) * cpukit/include/rtems/rtemspppd.h (moved) * cpukit/include/rtems/rtl/dlfcn-shell.h (moved) * cpukit/include/rtems/rtl/rap-shell.h (moved) * cpukit/include/rtems/rtl/rap.h (moved) * cpukit/include/rtems/rtl/rtl-allocator.h (moved) * cpukit/include/rtems/rtl/rtl-fwd.h (moved) * cpukit/include/rtems/rtl/rtl-indirect-ptr.h (moved) * cpukit/include/rtems/rtl/rtl-obj-cache.h (moved) * cpukit/include/rtems/rtl/rtl-obj-comp.h (moved) * cpukit/include/rtems/rtl/rtl-obj-fwd.h (moved) * cpukit/include/rtems/rtl/rtl-obj.h (moved) * cpukit/include/rtems/rtl/rtl-sym.h (moved) * cpukit/include/rtems/rtl/rtl-trace.h (moved) * cpukit/include/rtems/rtl/rtl-unresolved.h (moved) * cpukit/include/rtems/rtl/rtl.h (moved) * cpukit/include/rtems/scheduler.h (moved) * cpukit/include/rtems/score/address.h (moved) * cpukit/include/rtems/score/apimutex.h (moved) * cpukit/include/rtems/score/assert.h (moved) * cpukit/include/rtems/score/atomic.h (moved) * cpukit/include/rtems/score/basedefs.h (moved) * cpukit/include/rtems/score/chain.h (moved) * cpukit/include/rtems/score/chainimpl.h (moved) * cpukit/include/rtems/score/context.h (moved) * cpukit/include/rtems/score/copyrt.h (moved) * cpukit/include/rtems/score/corebarrier.h (moved) * cpukit/include/rtems/score/corebarrierimpl.h (moved) * cpukit/include/rtems/score/coremsg.h (moved) * cpukit/include/rtems/score/coremsgimpl.h (moved) * cpukit/include/rtems/score/coremutex.h (moved) * cpukit/include/rtems/score/coremuteximpl.h (moved) * cpukit/include/rtems/score/corerwlockimpl.h (moved) * cpukit/include/rtems/score/coresem.h (moved) * cpukit/include/rtems/score/coresemimpl.h (moved) * cpukit/include/rtems/score/cpustdatomic.h (moved) * cpukit/include/rtems/score/freechain.h (moved) * cpukit/include/rtems/score/heap.h (moved) * cpukit/include/rtems/score/heapimpl.h (moved) * cpukit/include/rtems/score/interr.h (moved) * cpukit/include/rtems/score/io.h (moved) * cpukit/include/rtems/score/isr.h (moved) * cpukit/include/rtems/score/isrlevel.h (moved) * cpukit/include/rtems/score/isrlock.h (moved) * cpukit/include/rtems/score/mpci.h (moved) * cpukit/include/rtems/score/mpciimpl.h (moved) * cpukit/include/rtems/score/mppkt.h (moved) * cpukit/include/rtems/score/mrsp.h (moved) * cpukit/include/rtems/score/mrspimpl.h (moved) * cpukit/include/rtems/score/muteximpl.h (moved) * cpukit/include/rtems/score/object.h (moved) * cpukit/include/rtems/score/objectimpl.h (moved) * cpukit/include/rtems/score/objectmp.h (moved) * cpukit/include/rtems/score/onceimpl.h (moved) * cpukit/include/rtems/score/percpu.h (moved) * cpukit/include/rtems/score/priority.h (moved) * cpukit/include/rtems/score/prioritybitmap.h (moved) * cpukit/include/rtems/score/prioritybitmapimpl.h (moved) * cpukit/include/rtems/score/priorityimpl.h (moved) * cpukit/include/rtems/score/processormask.h (moved) * cpukit/include/rtems/score/profiling.h (moved) * cpukit/include/rtems/score/protectedheap.h (moved) * cpukit/include/rtems/score/rbtree.h (moved) * cpukit/include/rtems/score/rbtreeimpl.h (moved) * cpukit/include/rtems/score/scheduler.h (moved) * cpukit/include/rtems/score/schedulercbs.h (moved) * cpukit/include/rtems/score/schedulercbsimpl.h (moved) * cpukit/include/rtems/score/scheduleredf.h (moved) * cpukit/include/rtems/score/scheduleredfimpl.h (moved) * cpukit/include/rtems/score/scheduleredfsmp.h (moved) * cpukit/include/rtems/score/schedulerimpl.h (moved) * cpukit/include/rtems/score/schedulernode.h (moved) * cpukit/include/rtems/score/schedulernodeimpl.h (moved) * cpukit/include/rtems/score/schedulerpriority.h (moved) * cpukit/include/rtems/score/schedulerpriorityaffinitysmp.h (moved) * cpukit/include/rtems/score/schedulerpriorityimpl.h (moved) * cpukit/include/rtems/score/schedulerprioritysmp.h (moved) * cpukit/include/rtems/score/schedulerprioritysmpimpl.h (moved) * cpukit/include/rtems/score/schedulersimple.h (moved) * cpukit/include/rtems/score/schedulersimpleimpl.h (moved) * cpukit/include/rtems/score/schedulersimplesmp.h (moved) * cpukit/include/rtems/score/schedulersmp.h (moved) * cpukit/include/rtems/score/schedulersmpimpl.h (moved) * cpukit/include/rtems/score/schedulerstrongapa.h (moved) * cpukit/include/rtems/score/semaphoreimpl.h (moved) * cpukit/include/rtems/score/smp.h (moved) * cpukit/include/rtems/score/smpbarrier.h (moved) * cpukit/include/rtems/score/smpimpl.h (moved) * cpukit/include/rtems/score/smplock.h (moved) * cpukit/include/rtems/score/smplockmcs.h (moved) * cpukit/include/rtems/score/smplockseq.h (moved) * cpukit/include/rtems/score/smplockstats.h (moved) * cpukit/include/rtems/score/smplockticket.h (moved) * cpukit/include/rtems/score/stack.h (moved) * cpukit/include/rtems/score/stackimpl.h (moved) * cpukit/include/rtems/score/states.h (moved) * cpukit/include/rtems/score/statesimpl.h (moved) * cpukit/include/rtems/score/status.h (moved) * cpukit/include/rtems/score/sysstate.h (moved) * cpukit/include/rtems/score/thread.h (moved) * cpukit/include/rtems/score/threaddispatch.h (moved) * cpukit/include/rtems/score/threadimpl.h (moved) * cpukit/include/rtems/score/threadmp.h (moved) * cpukit/include/rtems/score/threadq.h (moved) * cpukit/include/rtems/score/threadqimpl.h (moved) * cpukit/include/rtems/score/timecounter.h (moved) * cpukit/include/rtems/score/timecounterimpl.h (moved) * cpukit/include/rtems/score/timespec.h (moved) * cpukit/include/rtems/score/timestamp.h (moved) * cpukit/include/rtems/score/tls.h (moved) * cpukit/include/rtems/score/tod.h (moved) * cpukit/include/rtems/score/todimpl.h (moved) * cpukit/include/rtems/score/userext.h (moved) * cpukit/include/rtems/score/userextimpl.h (moved) * cpukit/include/rtems/score/watchdog.h (moved) * cpukit/include/rtems/score/watchdogimpl.h (moved) * cpukit/include/rtems/score/wkspace.h (moved) * cpukit/include/rtems/serdbg.h (moved) * cpukit/include/rtems/serdbgcnf.h (moved) * cpukit/include/rtems/serial_mouse.h (moved) * cpukit/include/rtems/seterr.h (moved) * cpukit/include/rtems/shell.h (moved) * cpukit/include/rtems/shellconfig.h (moved) * cpukit/include/rtems/sparse-disk.h (moved) * cpukit/include/rtems/spurious.h (moved) * cpukit/include/rtems/stackchk.h (moved) * cpukit/include/rtems/stdio-redirect.h (moved) * cpukit/include/rtems/stringto.h (moved) * cpukit/include/rtems/sysinit.h (moved) * cpukit/include/rtems/system.h (moved) * cpukit/include/rtems/telnetd.h (moved) * cpukit/include/rtems/termios_printk.h (moved) * cpukit/include/rtems/termios_printk_cnf.h (moved) * cpukit/include/rtems/termiostypes.h (moved) * cpukit/include/rtems/test.h (moved) * cpukit/include/rtems/timecounter.h (moved) * cpukit/include/rtems/timespec.h (moved) * cpukit/include/rtems/tod.h (moved) * cpukit/include/rtems/trace/rtems-trace-buffer-vars.h (moved) * cpukit/include/rtems/untar.h (moved) * cpukit/include/rtems/version.h (moved) * cpukit/include/rtems/vmeintr.h (moved) * cpukit/include/sha256.h (moved) * cpukit/include/sha512.h (moved) * cpukit/include/sys/_ffcounter.h (moved) * cpukit/include/sys/cdefs_elf.h (moved) * cpukit/include/sys/event.h (moved) * cpukit/include/sys/exec_elf.h (moved) * cpukit/include/sys/poll.h (moved) * cpukit/include/sys/statvfs.h (moved) * cpukit/include/sys/timeffc.h (moved) * cpukit/include/sys/timepps.h (moved) * cpukit/include/sys/timetc.h (moved) * cpukit/include/sys/timex.h (moved) * cpukit/include/sys/utsname.h (moved) * cpukit/include/utf8proc/utf8proc.h (moved) * cpukit/include/uuid/uuid.h (moved) * cpukit/include/xz.h (moved) * cpukit/include/zlib.h (moved) * cpukit/libcrypt/Makefile.am (modified) * cpukit/libcrypt/preinstall.am (deleted) * cpukit/libcsupport/Makefile.am (modified) * cpukit/libcsupport/preinstall.am (deleted) * cpukit/libdebugger/Makefile.am (modified) * cpukit/libdebugger/preinstall.am (deleted) * cpukit/libdl/Makefile.am (modified) * cpukit/libdl/preinstall.am (deleted) * cpukit/libfs/Makefile.am (modified) * cpukit/libfs/preinstall.am (deleted) * cpukit/libfs/src/nfsclient/Makefile.am (modified) * cpukit/libfs/src/nfsclient/preinstall.am (deleted) * cpukit/libmd/Makefile.am (modified) * cpukit/libmd/preinstall.am (deleted) * cpukit/libmisc/Makefile.am (modified) * cpukit/libmisc/preinstall.am (deleted) * cpukit/libnetworking/Makefile.am (modified) * cpukit/libnetworking/headers.am (added) * cpukit/libnetworking/preinstall.am (deleted) * cpukit/libnetworking/sys/poll.h (deleted) * cpukit/libpci/Makefile.am (modified) * cpukit/libpci/preinstall.am (deleted) * cpukit/librpc/Makefile.am (modified) * cpukit/librpc/preinstall.am (deleted) * cpukit/libstdthreads/Makefile.am (modified) * cpukit/mghttpd/Makefile.am (modified) * cpukit/mghttpd/preinstall.am (deleted) * cpukit/posix/Makefile.am (modified) * cpukit/posix/preinstall.am (deleted) * cpukit/pppd/Makefile.am (modified) * cpukit/pppd/preinstall.am (deleted) * cpukit/preinstall.am (deleted) * cpukit/rtems/Makefile.am (modified) * cpukit/rtems/preinstall.am (deleted) * cpukit/sapi/Makefile.am (modified) * cpukit/sapi/preinstall.am (deleted) * cpukit/score/Makefile.am (modified) * cpukit/score/cpu/arm/Makefile.am (modified) * cpukit/score/cpu/arm/headers.am (added) * cpukit/score/cpu/arm/include/machine/elf_machdep.h (moved) * cpukit/score/cpu/arm/include/rtems/asm.h (moved) * cpukit/score/cpu/arm/include/rtems/score/arm.h (moved) * cpukit/score/cpu/arm/include/rtems/score/armv4.h (moved) * cpukit/score/cpu/arm/include/rtems/score/armv7m.h (moved) * cpukit/score/cpu/arm/include/rtems/score/cpu.h (moved) * cpukit/score/cpu/arm/include/rtems/score/cpu_asm.h (moved) * cpukit/score/cpu/arm/include/rtems/score/cpuatomic.h (moved) * cpukit/score/cpu/arm/include/rtems/score/cpuimpl.h (moved) * cpukit/score/cpu/arm/include/rtems/score/types.h (moved) * cpukit/score/cpu/arm/preinstall.am (deleted) * cpukit/score/cpu/bfin/Makefile.am (modified) * cpukit/score/cpu/bfin/headers.am (added) * cpukit/score/cpu/bfin/include/machine/elf_machdep.h (moved) * cpukit/score/cpu/bfin/include/rtems/asm.h (moved) * cpukit/score/cpu/bfin/include/rtems/bfin/bf52x.h (moved) * cpukit/score/cpu/bfin/include/rtems/bfin/bf533.h (moved) * cpukit/score/cpu/bfin/include/rtems/bfin/bfin.h (moved) * cpukit/score/cpu/bfin/include/rtems/score/bfin.h (moved) * cpukit/score/cpu/bfin/include/rtems/score/cpu.h (moved) * cpukit/score/cpu/bfin/include/rtems/score/cpu_asm.h (moved) * cpukit/score/cpu/bfin/include/rtems/score/cpuatomic.h (moved) * cpukit/score/cpu/bfin/include/rtems/score/cpuimpl.h (moved) * cpukit/score/cpu/bfin/include/rtems/score/types.h (moved) * cpukit/score/cpu/bfin/preinstall.am (deleted) * cpukit/score/cpu/epiphany/Makefile.am (modified) * cpukit/score/cpu/epiphany/headers.am (added) * cpukit/score/cpu/epiphany/include/rtems/asm.h (moved) * cpukit/score/cpu/epiphany/include/rtems/score/cpu.h (moved) * cpukit/score/cpu/epiphany/include/rtems/score/cpu_asm.h (moved) * cpukit/score/cpu/epiphany/include/rtems/score/cpuatomic.h (moved) * cpukit/score/cpu/epiphany/include/rtems/score/cpuimpl.h (moved) * cpukit/score/cpu/epiphany/include/rtems/score/epiphany-utility.h (moved) * cpukit/score/cpu/epiphany/include/rtems/score/epiphany.h (moved) * cpukit/score/cpu/epiphany/include/rtems/score/types.h (moved) * cpukit/score/cpu/epiphany/preinstall.am (deleted) * cpukit/score/cpu/h8300/headers.am (added) * cpukit/score/cpu/h8300/include/machine/elf_machdep.h (moved) * cpukit/score/cpu/i386/Makefile.am (modified) * cpukit/score/cpu/i386/headers.am (added) * cpukit/score/cpu/i386/include/machine/elf_machdep.h (moved) * cpukit/score/cpu/i386/include/rtems/asm.h (moved) * cpukit/score/cpu/i386/include/rtems/score/cpu.h (moved) * cpukit/score/cpu/i386/include/rtems/score/cpuatomic.h (moved) * cpukit/score/cpu/i386/include/rtems/score/cpuimpl.h (moved) * cpukit/score/cpu/i386/include/rtems/score/i386.h (moved) * cpukit/score/cpu/i386/include/rtems/score/idtr.h (moved) * cpukit/score/cpu/i386/include/rtems/score/interrupts.h (moved) * cpukit/score/cpu/i386/include/rtems/score/registers.h (moved) * cpukit/score/cpu/i386/include/rtems/score/types.h (moved) * cpukit/score/cpu/i386/preinstall.am (deleted) * cpukit/score/cpu/lm32/Makefile.am (modified) * cpukit/score/cpu/lm32/headers.am (added) * cpukit/score/cpu/lm32/include/machine/elf_machdep.h (moved) * cpukit/score/cpu/lm32/include/rtems/asm.h (moved) * cpukit/score/cpu/lm32/include/rtems/score/cpu.h (moved) * cpukit/score/cpu/lm32/include/rtems/score/cpu_asm.h (moved) * cpukit/score/cpu/lm32/include/rtems/score/cpuatomic.h (moved) * cpukit/score/cpu/lm32/include/rtems/score/cpuimpl.h (moved) * cpukit/score/cpu/lm32/include/rtems/score/lm32.h (moved) * cpukit/score/cpu/lm32/include/rtems/score/types.h (moved) * cpukit/score/cpu/lm32/preinstall.am (deleted) * cpukit/score/cpu/m32c/Makefile.am (modified) * cpukit/score/cpu/m32c/headers.am (added) * cpukit/score/cpu/m32c/include/rtems/asm.h (moved) * cpukit/score/cpu/m32c/include/rtems/score/cpu.h (moved) * cpukit/score/cpu/m32c/include/rtems/score/cpu_asm.h (moved) * cpukit/score/cpu/m32c/include/rtems/score/cpuatomic.h (moved) * cpukit/score/cpu/m32c/include/rtems/score/cpuimpl.h (moved) * cpukit/score/cpu/m32c/include/rtems/score/m32c.h (moved) * cpukit/score/cpu/m32c/include/rtems/score/types.h (moved) * cpukit/score/cpu/m32c/include/varvects.h (moved) * cpukit/score/cpu/m32c/preinstall.am (deleted) * cpukit/score/cpu/m68k/Makefile.am (modified) * cpukit/score/cpu/m68k/headers.am (added) * cpukit/score/cpu/m68k/include/machine/elf_machdep.h (moved) * cpukit/score/cpu/m68k/include/rtems/asm.h (moved) * cpukit/score/cpu/m68k/include/rtems/m68k/m68302.h (moved) * cpukit/score/cpu/m68k/include/rtems/m68k/m68360.h (moved) * cpukit/score/cpu/m68k/include/rtems/m68k/qsm.h (moved) * cpukit/score/cpu/m68k/include/rtems/m68k/sim.h (moved) * cpukit/score/cpu/m68k/include/rtems/score/cpu.h (moved) * cpukit/score/cpu/m68k/include/rtems/score/cpuatomic.h (moved) * cpukit/score/cpu/m68k/include/rtems/score/cpuimpl.h (moved) * cpukit/score/cpu/m68k/include/rtems/score/m68k.h (moved) * cpukit/score/cpu/m68k/include/rtems/score/types.h (moved) * cpukit/score/cpu/m68k/preinstall.am (deleted) * cpukit/score/cpu/mips/Makefile.am (modified) * cpukit/score/cpu/mips/headers.am (added) * cpukit/score/cpu/mips/include/machine/elf_machdep.h (moved) * cpukit/score/cpu/mips/include/rtems/asm.h (moved) * cpukit/score/cpu/mips/include/rtems/mips/idtcpu.h (moved) * cpukit/score/cpu/mips/include/rtems/mips/iregdef.h (moved) * cpukit/score/cpu/mips/include/rtems/score/cpu.h (moved) * cpukit/score/cpu/mips/include/rtems/score/cpuatomic.h (moved) * cpukit/score/cpu/mips/include/rtems/score/cpuimpl.h (moved) * cpukit/score/cpu/mips/include/rtems/score/mips.h (moved) * cpukit/score/cpu/mips/include/rtems/score/types.h (moved) * cpukit/score/cpu/mips/preinstall.am (deleted) * cpukit/score/cpu/moxie/Makefile.am (modified) * cpukit/score/cpu/moxie/headers.am (added) * cpukit/score/cpu/moxie/include/machine/elf_machdep.h (moved) * cpukit/score/cpu/moxie/include/rtems/asm.h (moved) * cpukit/score/cpu/moxie/include/rtems/score/cpu.h (moved) * cpukit/score/cpu/moxie/include/rtems/score/cpuatomic.h (moved) * cpukit/score/cpu/moxie/include/rtems/score/cpuimpl.h (moved) * cpukit/score/cpu/moxie/include/rtems/score/moxie.h (moved) * cpukit/score/cpu/moxie/include/rtems/score/types.h (moved) * cpukit/score/cpu/moxie/preinstall.am (deleted) * cpukit/score/cpu/nios2/Makefile.am (modified) * cpukit/score/cpu/nios2/headers.am (added) * cpukit/score/cpu/nios2/include/machine/elf_machdep.h (moved) * cpukit/score/cpu/nios2/include/rtems/asm.h (moved) * cpukit/score/cpu/nios2/include/rtems/score/cpu.h (moved) * cpukit/score/cpu/nios2/include/rtems/score/cpu_asm.h (moved) * cpukit/score/cpu/nios2/include/rtems/score/cpuatomic.h (moved) * cpukit/score/cpu/nios2/include/rtems/score/cpuimpl.h (moved) * cpukit/score/cpu/nios2/include/rtems/score/nios2-count-zeros.h (moved) * cpukit/score/cpu/nios2/include/rtems/score/nios2-utility.h (moved) * cpukit/score/cpu/nios2/include/rtems/score/nios2.h (moved) * cpukit/score/cpu/nios2/include/rtems/score/types.h (moved) * cpukit/score/cpu/nios2/preinstall.am (deleted) * cpukit/score/cpu/no_cpu/Makefile.am (modified) * cpukit/score/cpu/no_cpu/headers.am (added) * cpukit/score/cpu/no_cpu/include/rtems/asm.h (moved) * cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h (moved) * cpukit/score/cpu/no_cpu/include/rtems/score/cpu_asm.h (moved) * cpukit/score/cpu/no_cpu/include/rtems/score/cpuimpl.h (moved) * cpukit/score/cpu/no_cpu/include/rtems/score/no_cpu.h (moved) * cpukit/score/cpu/no_cpu/include/rtems/score/types.h (moved) * cpukit/score/cpu/no_cpu/preinstall.am (deleted) * cpukit/score/cpu/or1k/Makefile.am (modified) * cpukit/score/cpu/or1k/headers.am (added) * cpukit/score/cpu/or1k/include/rtems/asm.h (moved) * cpukit/score/cpu/or1k/include/rtems/score/cpu.h (moved) * cpukit/score/cpu/or1k/include/rtems/score/cpu_asm.h (moved) * cpukit/score/cpu/or1k/include/rtems/score/cpuatomic.h (moved) * cpukit/score/cpu/or1k/include/rtems/score/cpuimpl.h (moved) * cpukit/score/cpu/or1k/include/rtems/score/or1k-utility.h (moved) * cpukit/score/cpu/or1k/include/rtems/score/or1k.h (moved) * cpukit/score/cpu/or1k/include/rtems/score/types.h (moved) * cpukit/score/cpu/or1k/preinstall.am (deleted) * cpukit/score/cpu/powerpc/Makefile.am (modified) * cpukit/score/cpu/powerpc/headers.am (added) * cpukit/score/cpu/powerpc/include/machine/elf_machdep.h (moved) * cpukit/score/cpu/powerpc/include/rtems/asm.h (moved) * cpukit/score/cpu/powerpc/include/rtems/powerpc/registers.h (moved) * cpukit/score/cpu/powerpc/include/rtems/score/cpu.h (moved) * cpukit/score/cpu/powerpc/include/rtems/score/cpuatomic.h (moved) * cpukit/score/cpu/powerpc/include/rtems/score/cpuimpl.h (moved) * cpukit/score/cpu/powerpc/include/rtems/score/powerpc.h (moved) * cpukit/score/cpu/powerpc/include/rtems/score/types.h (moved) * cpukit/score/cpu/powerpc/preinstall.am (deleted) * cpukit/score/cpu/riscv/Makefile.am (modified) * cpukit/score/cpu/riscv/headers.am (added) * cpukit/score/cpu/riscv/include/rtems/asm.h (moved) * cpukit/score/cpu/riscv/include/rtems/score/cpu.h (moved) * cpukit/score/cpu/riscv/include/rtems/score/cpu_asm.h (moved) * cpukit/score/cpu/riscv/include/rtems/score/cpuatomic.h (moved) * cpukit/score/cpu/riscv/include/rtems/score/cpuimpl.h (moved) * cpukit/score/cpu/riscv/include/rtems/score/riscv-utility.h (moved) * cpukit/score/cpu/riscv/include/rtems/score/riscv.h (moved) * cpukit/score/cpu/riscv/include/rtems/score/types.h (moved) * cpukit/score/cpu/riscv/preinstall.am (deleted) * cpukit/score/cpu/sh/Makefile.am (modified) * cpukit/score/cpu/sh/headers.am (added) * cpukit/score/cpu/sh/include/rtems/asm.h (moved) * cpukit/score/cpu/sh/include/rtems/score/cpu.h (moved) * cpukit/score/cpu/sh/include/rtems/score/cpuatomic.h (moved) * cpukit/score/cpu/sh/include/rtems/score/cpuimpl.h (moved) * cpukit/score/cpu/sh/include/rtems/score/sh.h (moved) * cpukit/score/cpu/sh/include/rtems/score/sh_io.h (moved) * cpukit/score/cpu/sh/include/rtems/score/types.h (moved) * cpukit/score/cpu/sh/preinstall.am (deleted) * cpukit/score/cpu/sparc/Makefile.am (modified) * cpukit/score/cpu/sparc/headers.am (added) * cpukit/score/cpu/sparc/include/machine/elf_machdep.h (moved) * cpukit/score/cpu/sparc/include/rtems/asm.h (moved) * cpukit/score/cpu/sparc/include/rtems/score/cpu.h (moved) * cpukit/score/cpu/sparc/include/rtems/score/cpuatomic.h (moved) * cpukit/score/cpu/sparc/include/rtems/score/cpuimpl.h (moved) * cpukit/score/cpu/sparc/include/rtems/score/sparc.h (moved) * cpukit/score/cpu/sparc/include/rtems/score/sparcimpl.h (moved) * cpukit/score/cpu/sparc/include/rtems/score/types.h (moved) * cpukit/score/cpu/sparc/preinstall.am (deleted) * cpukit/score/cpu/sparc64/Makefile.am (modified) * cpukit/score/cpu/sparc64/headers.am (added) * cpukit/score/cpu/sparc64/include/rtems/asm.h (moved) * cpukit/score/cpu/sparc64/include/rtems/score/cpu.h (moved) * cpukit/score/cpu/sparc64/include/rtems/score/cpuatomic.h (moved) * cpukit/score/cpu/sparc64/include/rtems/score/cpuimpl.h (moved) * cpukit/score/cpu/sparc64/include/rtems/score/sparc64.h (moved) * cpukit/score/cpu/sparc64/include/rtems/score/types.h (moved) * cpukit/score/cpu/sparc64/preinstall.am (deleted) * cpukit/score/cpu/v850/Makefile.am (modified) * cpukit/score/cpu/v850/headers.am (added) * cpukit/score/cpu/v850/include/machine/elf_machdep.h (moved) * cpukit/score/cpu/v850/include/rtems/asm.h (moved) * cpukit/score/cpu/v850/include/rtems/score/cpu.h (moved) * cpukit/score/cpu/v850/include/rtems/score/cpu_asm.h (moved) * cpukit/score/cpu/v850/include/rtems/score/cpuatomic.h (moved) * cpukit/score/cpu/v850/include/rtems/score/cpuimpl.h (moved) * cpukit/score/cpu/v850/include/rtems/score/types.h (moved) * cpukit/score/cpu/v850/include/rtems/score/v850.h (moved) * cpukit/score/cpu/v850/preinstall.am (deleted) * cpukit/score/preinstall.am (deleted) * cpukit/telnetd/Makefile.am (modified) * cpukit/telnetd/preinstall.am (deleted) * cpukit/wrapup/Makefile.am (modified) * cpukit/wrapup/preinstall.am (deleted) * cpukit/zlib/Makefile.am (modified) * cpukit/zlib/preinstall.am (deleted) * testsuites/aclocal/check-cpuopts.m4 (modified) * testsuites/aclocal/prog-cc.m4 (modified) * testsuites/aclocal/rtems-bsp-includes.m4 (added) * testsuites/aclocal/rtems-bsp-linkcmds.m4 (added) * testsuites/aclocal/rtems-build-top.m4 (added) * testsuites/aclocal/rtems-includes.m4 (added) * testsuites/aclocal/rtems-source-top.m4 (added) * testsuites/ada/ada.am (modified) * testsuites/ada/configure.ac (modified) * testsuites/ada/samples/base_mp/node1/Makefile.am (modified) * testsuites/ada/samples/base_mp/node2/Makefile.am (modified) * testsuites/ada/samples/base_sp/Makefile.am (modified) * testsuites/ada/samples/hello/Makefile.am (modified) * testsuites/ada/samples/nsecs/Makefile.am (modified) * testsuites/ada/samples/ticker/Makefile.am (modified) * testsuites/ada/sptests/spname01/Makefile.am (modified) * testsuites/automake/compile.am (modified) * testsuites/automake/host.am (modified) * testsuites/automake/local.am (modified) * testsuites/benchmarks/configure.ac (modified) * testsuites/configure.ac (modified) * testsuites/fstests/configure.ac (modified) * testsuites/libtests/POSIX/Makefile.am (modified) * testsuites/libtests/configure.ac (modified) * testsuites/libtests/ftp01/Makefile.am (modified) * testsuites/libtests/mghttpd01/Makefile.am (modified) * testsuites/libtests/networking01/Makefile.am (modified) * testsuites/libtests/syscall01/Makefile.am (modified) * testsuites/mptests/configure.ac (modified) * testsuites/psxtests/configure.ac (modified) * testsuites/psxtmtests/configure.ac (modified) * testsuites/rhealstone/configure.ac (modified) * testsuites/samples/configure.ac (modified) * testsuites/samples/loopback/Makefile.am (modified) * testsuites/samples/pppd/Makefile.am (modified) * testsuites/smptests/configure.ac (modified) * testsuites/sptests/configure.ac (modified) * testsuites/tmtests/configure.ac (modified) * testsuites/tools/configure.ac (modified) * testsuites/tools/generic/configure.ac (modified) * tools/build/configure.ac (modified) * tools/cpu/configure.ac (modified) * tools/cpu/generic/configure.ac (modified) * tools/cpu/nios2/configure.ac (modified) * tools/cpu/sh/configure.ac (modified) Remove make preinstall A speciality of the RTEMS build system was ...
