source: rtems/aclocal
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
(edit) @fdb37e8   08/02/99 15:33:26 Joel Sherrill New file from Ralf Corsepius <corsepiu@…> missed being … 4.104.114.84.95
(edit) @1896a650   07/30/99 17:52:50 Joel Sherrill Patch from Ralf Corsepius <corsepiu@…>: The main topic … 4.104.114.84.95
(edit) @eb299afc   07/26/99 20:20:22 Joel Sherrill This is part of a major patch from Ralf Corsepius … 4.104.114.84.95
(edit) @83f62bf   07/26/99 20:19:49 Joel Sherrill This is part of a major patch from Ralf Corsepius … 4.104.114.84.95
(edit) @6693a68   07/26/99 20:00:37 Joel Sherrill This is part of a major patch from Ralf Corsepius … 4.104.114.84.95
(edit) @8c92fa3   06/16/99 14:55:28 Joel Sherrill Patcg from Ralf Corsepius <corsepiu@…>: -- configure … 4.104.114.84.95
(edit) @d2d22780   06/15/99 22:46:44 Joel Sherrill Patch from Ralf Corsepius <corsepiu@…>: > When I run … 4.104.114.84.95
(edit) @15aa5ffb   06/14/99 18:54:24 Joel Sherrill Patch ("FIX: no_cpu/no_bsp") from Ralf Corsepius … 4.104.114.84.95
(edit) @817466c   06/14/99 18:29:09 Joel Sherrill Patch ("FIX: MKDIR/INSTALL_VARIANT") from Ralf Corsepius … 4.104.114.84.95
(edit) @6b7ab9bf   04/16/99 18:23:48 Joel Sherrill Patch from Ralf Corsepius <corsepiu@…>: FYI: I am … 4.104.114.84.95
(edit) @82f490f   04/12/99 20:24:56 Joel Sherrill Patch from Ralf Corsepius <corsepiu@…> to correct the … 4.104.114.84.95
(edit) @8cdb582   04/12/99 15:41:33 Joel Sherrill Patch from Ralf Corsepius <corsepiu@…>: This patch … 4.104.114.84.95
(edit) @a37be5c4   04/06/99 20:25:40 Joel Sherrill Eric Norum <eric@…> noticed that the documentation and … 4.104.114.84.95
(edit) @7e03d10   03/29/99 21:08:04 Joel Sherrill Patch from Ralf Corsepius <corsepiu@…>: Yet some … 4.104.114.84.95
(edit) @9b8baa1   03/23/99 18:02:17 Joel Sherrill Automake II patch from Ralf Corsepius <corsepiu@…>. … 4.104.114.84.95
(edit) @04c308c   03/19/99 23:11:36 Joel Sherrill Incorporated automake I patch from Ralf Corsepius … 4.104.114.84.95
(edit) @9ec96478   03/19/99 21:54:36 Joel Sherrill Towards automake VIII patch from Ralf Corsepius … 4.104.114.84.95
(edit) @b64b1ed   03/18/99 22:36:28 Joel Sherrill Patch from Ralf Corsepius <corsepiu@…>: Moves some … 4.104.114.84.95
(edit) @dfe7746e   03/17/99 23:43:32 Joel Sherrill Patch from Ralf Corsepius <corsepiu@…> 4.104.114.84.95
(edit) @2e26bbd   11/19/98 20:09:01 Joel Sherrill Patch from Ralf Corsepius <corsepiu@…>: Here is a … 4.104.114.84.95
(edit) @692b9f7   10/28/98 19:17:16 Joel Sherrill Merged Vista SCORE603e, Radstone PPCn_60x, and DY-4 DMV177 BSPs along … 4.104.114.84.95
(edit) @bf1ef5b   10/05/98 13:50:53 Joel Sherrill Regenerated after fixing a typo. 4.104.114.84.95
(edit) @f44a81b   10/05/98 12:52:31 Joel Sherrill Modifed i386 gas test to put each directive on its own line per … 4.104.114.84.95
(edit) @2c3840b   09/30/98 20:58:39 Joel Sherrill Added new autoconf test for i386 code16/code32 support. The guts of … 4.104.114.84.95
(edit) @b931d05a   09/30/98 19:51:39 Joel Sherrill Added Id's. 4.104.114.84.95
(edit) @5620149   09/30/98 19:51:31 Joel Sherrill New configure test from Ian Lance Taylor <ian@…>: If the … 4.104.114.84.95
(edit) @06fa582   08/19/98 12:56:20 Joel Sherrill Patches from Ralf Corsepius <corsepiu@…> and myself to … 4.104.114.84.95
(edit) @613ab62   07/23/98 19:39:25 Joel Sherrill Patch from Dario Alcocer <alcocer@…> and Ralf Corsepius … 4.104.114.84.95
(edit) @8555ddb   07/10/98 13:22:23 Joel Sherrill Patch from David Fiddes <D.J.Fiddes@…>. Comments below: … 4.104.114.84.95
(edit) @98100d2   06/27/98 17:09:47 Joel Sherrill Monstrous patch from Ralf Corsepius <corsepiu@…>. I have … 4.104.114.84.95
(edit) @232429f6   05/22/98 12:26:47 Joel Sherrill Removed SIZE_FOR_TARGET change after Ralf pointed out that gcc does … 4.104.114.84.95
(edit) @31668a6   05/21/98 18:46:36 Joel Sherrill Use gcc to look for size also 4.104.114.84.95
(edit) @6207ea2   05/21/98 16:46:24 Joel Sherrill New file from Ralf Corsepius 4.104.114.84.95
(edit) @2efdd08   05/20/98 17:06:57 Joel Sherrill Patch from Ralf Corseipus to fix latent configure problems suddenly … 4.104.114.84.95
(edit) @38093c0   05/18/98 16:36:31 Joel Sherrill Modified to find C++ compilers. 4.104.114.84.95
(edit) @d53130be   03/23/98 19:54:35 Joel Sherrill Updated now that the phony crt0.c in newlib defines all odd symbols … 4.104.114.84.95
(edit) @5b3cf09   03/21/98 15:25:47 Joel Sherrill Added enough symbols to the conftest.c program to make sure it would … 4.104.114.84.95
(edit) @a7a08713   03/20/98 16:52:10 Joel Sherrill Patch from Ralf Corsepius to properly detect that Cygwin32 does not … 4.104.114.84.95
(edit) @51c195d5   02/19/98 16:23:56 Joel Sherrill New files missed in previous merge. 4.104.114.84.95
(edit) @81e0232   02/17/98 13:49:06 Joel Sherrill Update from Ralf Corsepius: 6) The macro files from aclocal/*.m4 … 4.104.114.84.95
(add) @6c77bba   02/04/98 14:54:27 Joel Sherrill New autoconf feature from Ralf Corsepius: It adds make rules for … 4.104.114.84.95
