source: rtems/aclocal
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
(edit) @8c92fa3   Jun 16, 1999, 2:55:28 PM Joel Sherrill Patcg from Ralf Corsepius <corsepiu@…>: -- configure … 4.104.114.84.9
(edit) @d2d22780   Jun 15, 1999, 10:46:44 PM Joel Sherrill Patch from Ralf Corsepius <corsepiu@…>: > When I run … 4.104.114.84.9
(edit) @15aa5ffb   Jun 14, 1999, 6:54:24 PM Joel Sherrill Patch ("FIX: no_cpu/no_bsp") from Ralf Corsepius … 4.104.114.84.9
(edit) @817466c   Jun 14, 1999, 6:29:09 PM Joel Sherrill Patch ("FIX: MKDIR/INSTALL_VARIANT") from Ralf Corsepius … 4.104.114.84.9
(edit) @6b7ab9bf   Apr 16, 1999, 6:23:48 PM Joel Sherrill Patch from Ralf Corsepius <corsepiu@…>: FYI: I am … 4.104.114.84.9
(edit) @82f490f   Apr 12, 1999, 8:24:56 PM Joel Sherrill Patch from Ralf Corsepius <corsepiu@…> to correct the … 4.104.114.84.9
(edit) @8cdb582   Apr 12, 1999, 3:41:33 PM Joel Sherrill Patch from Ralf Corsepius <corsepiu@…>: This patch … 4.104.114.84.9
(edit) @a37be5c4   Apr 6, 1999, 8:25:40 PM Joel Sherrill Eric Norum <eric@…> noticed that the documentation and … 4.104.114.84.9
(edit) @7e03d10   Mar 29, 1999, 9:08:04 PM Joel Sherrill Patch from Ralf Corsepius <corsepiu@…>: Yet some … 4.104.114.84.9
(edit) @9b8baa1   Mar 23, 1999, 6:02:17 PM Joel Sherrill Automake II patch from Ralf Corsepius <corsepiu@…>. … 4.104.114.84.9
(edit) @04c308c   Mar 19, 1999, 11:11:36 PM Joel Sherrill Incorporated automake I patch from Ralf Corsepius … 4.104.114.84.9
(edit) @9ec96478   Mar 19, 1999, 9:54:36 PM Joel Sherrill Towards automake VIII patch from Ralf Corsepius … 4.104.114.84.9
(edit) @b64b1ed   Mar 18, 1999, 10:36:28 PM Joel Sherrill Patch from Ralf Corsepius <corsepiu@…>: Moves some … 4.104.114.84.9
(edit) @dfe7746   Mar 17, 1999, 11:43:32 PM Joel Sherrill Patch from Ralf Corsepius <corsepiu@…> 4.104.114.84.9
(edit) @2e26bbd   Nov 19, 1998, 8:09:01 PM Joel Sherrill Patch from Ralf Corsepius <corsepiu@…>: Here is a … 4.104.114.84.9
(edit) @692b9f7   Oct 28, 1998, 7:17:16 PM Joel Sherrill Merged Vista SCORE603e, Radstone PPCn_60x, and DY-4 DMV177 BSPs along … 4.104.114.84.9
(edit) @bf1ef5b   Oct 5, 1998, 1:50:53 PM Joel Sherrill Regenerated after fixing a typo. 4.104.114.84.9
(edit) @f44a81b   Oct 5, 1998, 12:52:31 PM Joel Sherrill Modifed i386 gas test to put each directive on its own line per … 4.104.114.84.9
(edit) @2c3840b   Sep 30, 1998, 8:58:39 PM Joel Sherrill Added new autoconf test for i386 code16/code32 support. The guts of … 4.104.114.84.9
(edit) @b931d05a   Sep 30, 1998, 7:51:39 PM Joel Sherrill Added Id's. 4.104.114.84.9
(edit) @5620149   Sep 30, 1998, 7:51:31 PM Joel Sherrill New configure test from Ian Lance Taylor <ian@…>: If the … 4.104.114.84.9
(edit) @06fa582   Aug 19, 1998, 12:56:20 PM Joel Sherrill Patches from Ralf Corsepius <corsepiu@…> and myself to … 4.104.114.84.9
(edit) @613ab62   Jul 23, 1998, 7:39:25 PM Joel Sherrill Patch from Dario Alcocer <alcocer@…> and Ralf Corsepius … 4.104.114.84.9
(edit) @8555ddb   Jul 10, 1998, 1:22:23 PM Joel Sherrill Patch from David Fiddes <D.J.Fiddes@…>. Comments below: … 4.104.114.84.9
(edit) @98100d2   Jun 27, 1998, 5:09:47 PM Joel Sherrill Monstrous patch from Ralf Corsepius <corsepiu@…>. I have … 4.104.114.84.9
(edit) @232429f6   May 22, 1998, 12:26:47 PM Joel Sherrill Removed SIZE_FOR_TARGET change after Ralf pointed out that gcc does … 4.104.114.84.9
(edit) @31668a6   May 21, 1998, 6:46:36 PM Joel Sherrill Use gcc to look for size also 4.104.114.84.9
(edit) @6207ea2   May 21, 1998, 4:46:24 PM Joel Sherrill New file from Ralf Corsepius 4.104.114.84.9
(edit) @2efdd08   May 20, 1998, 5:06:57 PM Joel Sherrill Patch from Ralf Corseipus to fix latent configure problems suddenly … 4.104.114.84.9
(edit) @38093c0   May 18, 1998, 4:36:31 PM Joel Sherrill Modified to find C++ compilers. 4.104.114.84.9
(edit) @d53130b   Mar 23, 1998, 7:54:35 PM Joel Sherrill Updated now that the phony crt0.c in newlib defines all odd symbols … 4.104.114.84.9
(edit) @5b3cf09   Mar 21, 1998, 3:25:47 PM Joel Sherrill Added enough symbols to the conftest.c program to make sure it would … 4.104.114.84.9
(edit) @a7a0871   Mar 20, 1998, 4:52:10 PM Joel Sherrill Patch from Ralf Corsepius to properly detect that Cygwin32 does not … 4.104.114.84.9
(edit) @51c195d5   Feb 19, 1998, 4:23:56 PM Joel Sherrill New files missed in previous merge. 4.104.114.84.9
(edit) @81e0232   Feb 17, 1998, 1:49:06 PM Joel Sherrill Update from Ralf Corsepius: 6) The macro files from aclocal/*.m4 … 4.104.114.84.9
(add) @6c77bba   Feb 4, 1998, 2:54:27 PM Joel Sherrill New autoconf feature from Ralf Corsepius: It adds make rules for … 4.104.114.84.9
