@82f490f
04/12/99 20:24:56 |
Joel Sherrill |
Patch from Ralf Corsepius <corsepiu@…> to correct the …
4.104.114.84.95
@8cdb582
04/12/99 15:41:33 |
Joel Sherrill |
Patch from Ralf Corsepius <corsepiu@…>:
This patch …
4.104.114.84.95
@a37be5c4
04/06/99 20:25:40 |
Joel Sherrill |
Eric Norum <eric@…> noticed that the documentation and …
4.104.114.84.95
@7e03d10
03/29/99 21:08:04 |
Joel Sherrill |
Yet some …
4.104.114.84.95
@9b8baa1
03/23/99 18:02:17 |
Joel Sherrill |
Automake II patch from Ralf Corsepius <corsepiu@…>. …
4.104.114.84.95
@04c308c
03/19/99 23:11:36 |
Joel Sherrill |
Incorporated automake I patch from Ralf Corsepius …
4.104.114.84.95
@9ec96478
03/19/99 21:54:36 |
Joel Sherrill |
Towards automake VIII patch from Ralf Corsepius …
4.104.114.84.95
@b64b1ed
03/18/99 22:36:28 |
Joel Sherrill |
Moves some …
4.104.114.84.95
@dfe7746e
03/17/99 23:43:32 |
Joel Sherrill |
4.104.114.84.95
@2e26bbd
11/19/98 20:09:01 |
Joel Sherrill |
Here is a …
4.104.114.84.95
@692b9f7
10/28/98 19:17:16 |
Joel Sherrill |
Merged Vista SCORE603e, Radstone PPCn_60x, and DY-4 DMV177 BSPs along …
4.104.114.84.95
@bf1ef5b
10/05/98 13:50:53 |
Joel Sherrill |
Regenerated after fixing a typo.
4.104.114.84.95
@f44a81b
10/05/98 12:52:31 |
Joel Sherrill |
Modifed i386 gas test to put each directive on its own line per …
4.104.114.84.95
@2c3840b
09/30/98 20:58:39 |
Joel Sherrill |
Added new autoconf test for i386 code16/code32 support. The guts of …
4.104.114.84.95
@b931d05a
09/30/98 19:51:39 |
Joel Sherrill |
Added Id's.
4.104.114.84.95
@5620149
09/30/98 19:51:31 |
Joel Sherrill |
New configure test from Ian Lance Taylor <ian@…>:
If the …
4.104.114.84.95
@06fa582
08/19/98 12:56:20 |
Joel Sherrill |
Patches from Ralf Corsepius <corsepiu@…> and myself to …
4.104.114.84.95
@613ab62
07/23/98 19:39:25 |
Joel Sherrill |
Patch from Dario Alcocer <alcocer@…> and Ralf Corsepius …
4.104.114.84.95
@8555ddb
07/10/98 13:22:23 |
Joel Sherrill |
Patch from David Fiddes <D.J.Fiddes@…>. Comments below:
4.104.114.84.95
@98100d2
06/27/98 17:09:47 |
Joel Sherrill |
Monstrous patch from Ralf Corsepius <corsepiu@…>. I have …
4.104.114.84.95
@232429f6
05/22/98 12:26:47 |
Joel Sherrill |
Removed SIZE_FOR_TARGET change after Ralf pointed out that gcc does …
4.104.114.84.95
@31668a6
05/21/98 18:46:36 |
Joel Sherrill |
Use gcc to look for size also
4.104.114.84.95
@6207ea2
05/21/98 16:46:24 |
Joel Sherrill |
New file from Ralf Corsepius
4.104.114.84.95
@2efdd08
05/20/98 17:06:57 |
Joel Sherrill |
Patch from Ralf Corseipus to fix latent configure problems suddenly …
4.104.114.84.95
@38093c0
05/18/98 16:36:31 |
Joel Sherrill |
Modified to find C++ compilers.
4.104.114.84.95
@d53130be
03/23/98 19:54:35 |
Joel Sherrill |
Updated now that the phony crt0.c in newlib defines all odd symbols …
4.104.114.84.95
@5b3cf09
03/21/98 15:25:47 |
Joel Sherrill |
Added enough symbols to the conftest.c program to make sure it would …
4.104.114.84.95
@a7a08713
03/20/98 16:52:10 |
Joel Sherrill |
Patch from Ralf Corsepius to properly detect that Cygwin32 does not …
4.104.114.84.95
@51c195d5
02/19/98 16:23:56 |
Joel Sherrill |
New files missed in previous merge.
4.104.114.84.95
@81e0232
02/17/98 13:49:06 |
Joel Sherrill |
Update from Ralf Corsepius:
6) The macro files from aclocal/*.m4 …
4.104.114.84.95
@6c77bba
02/04/98 14:54:27 |
Joel Sherrill |
New autoconf feature from Ralf Corsepius:
It adds make rules for …
4.104.114.84.95
