# # ChangeLog for aclocal in rtems # # Generated by Trac 1.2.1.dev0 # 04/20/24 00:05:55 Mon, 23 Mar 1998 19:54:35 GMT Joel Sherrill [d53130be] * aclocal.m4 (modified) * aclocal/prog-cc.m4 (modified) * aclocal/prog-cxx.m4 (modified) Updated now that the phony crt0.c in newlib defines all odd symbols ... Sat, 21 Mar 1998 15:25:47 GMT Joel Sherrill [5b3cf09] * aclocal/prog-cc.m4 (modified) * aclocal/prog-cxx.m4 (modified) Added enough symbols to the conftest.c program to make sure it would ... Fri, 20 Mar 1998 16:52:10 GMT Joel Sherrill [a7a08713] * aclocal.m4 (modified) * aclocal/gcc-pipe.m4 (modified) * configure (modified) Patch from Ralf Corsepius to properly detect that Cygwin32 does not ... Thu, 19 Feb 1998 16:23:56 GMT Joel Sherrill [51c195d5] * aclocal/canonicalize-tools.m4 (added) * aclocal/gcc-pipe.m4 (added) * aclocal/gcc-specs.m4 (added) * aclocal/prog-cc.m4 (added) * aclocal/prog-cxx.m4 (added) New files missed in previous merge. Tue, 17 Feb 1998 13:49:06 GMT Joel Sherrill [81e0232] * aclocal/check-files-in.m4 (modified) * aclocal/check-makefile.m4 (modified) Update from Ralf Corsepius: 6) The macro files from aclocal/*.m4 ... Wed, 04 Feb 1998 14:54:27 GMT Joel Sherrill [6c77bba] * Makefile.in (modified) * aclocal/canonical-target-name.m4 (added) * aclocal/check-files-in.m4 (added) * aclocal/check-makefile.m4 (added) * aclocal/mkdir.m4 (added) New autoconf feature from Ralf Corsepius: It adds make rules for ...
