# # ChangeLog for aclocal in rtems # # Generated by Trac 1.2.1.dev0 # 04/20/24 00:47:22 Tue, 06 Aug 2002 07:31:47 GMT Ralf Corsepius [d3f954e] * ChangeLog (modified) * aclocal/env-rtemsbsp.m4 (modified) 2002-08-06 Ralf Corsepius * ... Wed, 31 Jul 2002 13:32:27 GMT Joel Sherrill [79b15c1d] * ChangeLog (modified) * aclocal/rtems-cpu-subdirs.m4 (modified) * cpukit/ChangeLog (modified) * cpukit/aclocal/rtems-cpu-subdirs.m4 (modified) 2002-07-31 Joel Sherrill * ... Mon, 22 Jul 2002 16:07:34 GMT Ralf Corsepius [b4cde04] * ChangeLog (modified) * acinclude.m4 (moved) 2002-07-22 Ralf Corsepius * ... Mon, 22 Jul 2002 10:13:20 GMT Ralf Corsepius [0e08a3c3] * ChangeLog (modified) * aclocal/check-cpu.m4 (modified) 2002-07-22 Ralf Corsepius * ... Mon, 22 Jul 2002 09:17:40 GMT Ralf Corsepius [35b2275] * ChangeLog (modified) * aclocal/bsp-configure.m4 (modified) * automake/compile.am (modified) * automake/lib.am (modified) 2002-07-22 Ralf Corsepius * ... Fri, 19 Jul 2002 04:04:49 GMT Ralf Corsepius [cca5631] * ChangeLog (modified) * aclocal/env-rtemsbsp.m4 (modified) 2002-07-18 Ralf Corsepius * ... Wed, 17 Jul 2002 17:21:49 GMT Joel Sherrill [76af1fc] * ChangeLog (modified) * aclocal/version.m4 (modified) 2002-07-17 Joel Sherrill * ... Sun, 30 Jun 2002 06:27:36 GMT Ralf Corsepius [0f8ae13c] * ChangeLog (modified) * aclocal/check-multiprocessing.m4 (modified) * aclocal/enable-multiprocessing.m4 (modified) 2002-06-30 Ralf Corsepius * ... Fri, 28 Jun 2002 19:28:49 GMT Joel Sherrill [f610f0c5] * ChangeLog (modified) * aclocal/version.m4 (modified) 2002-06-28 Joel Sherrill * ... Mon, 17 Jun 2002 14:58:21 GMT Ralf Corsepius [ba2df911] * ChangeLog (modified) * aclocal/env-rtemscpu.m4 (deleted) * aclocal/multi.m4 (deleted) * aclocal/multilib.m4 (modified) 2002-06-17 Ralf Corsepius * ... Tue, 28 May 2002 13:13:29 GMT Joel Sherrill [28311188] * ChangeLog (modified) * aclocal/version.m4 (modified) 2002-05-28 Joel Sherrill * ... Wed, 17 Apr 2002 13:27:29 GMT Joel Sherrill [53eb191] * ChangeLog (modified) * aclocal/prog-cc.m4 (modified) * aclocal/prog-cxx.m4 (modified) 2002-04-15 Ralf Corsepius * ... Tue, 16 Apr 2002 17:37:03 GMT Joel Sherrill [fd2bc17a] * ChangeLog (modified) * aclocal/enable-gcc28.m4 (deleted) * aclocal/enable-libcdir.m4 (deleted) 2002-04-16 Ralf Corsepius * ... Thu, 28 Mar 2002 14:25:50 GMT Joel Sherrill [321f5ff] * ChangeLog (modified) * aclocal/version.m4 (added) 2002-03-27 Ralf Corsepius * ... Thu, 28 Mar 2002 13:53:19 GMT Joel Sherrill [76d527ec] * aclocal/rtems-top.m4 (modified) * bootstrap (modified) * configure.ac (modified) 2002-03-27 Ralf Corsepius * ... Fri, 15 Mar 2002 18:57:17 GMT Joel Sherrill [dee576c0] * ChangeLog (modified) * aclocal/env-rtemscpu.m4 (modified) 2002-03-14 Ralf Corsepius * ... Wed, 06 Feb 2002 16:41:37 GMT Joel Sherrill [9b11632] * ChangeLog (modified) * aclocal/subdirs.m4 (modified) 2002-02-06 Ralf Corsepius * ... Thu, 24 Jan 2002 14:14:55 GMT Joel Sherrill [d7aabb7c] * ChangeLog (modified) * aclocal/sysv-ipc.m4 (modified) * bootstrap (modified) 2002-01-23 Ralf Corsepius * ... Tue, 22 Jan 2002 18:03:19 GMT Joel Sherrill [cbc4e6fa] * ChangeLog (modified) * aclocal/env-rtemsbsp.m4 (modified) 2002-01-22 Ralf Corsepius * ... Tue, 08 Jan 2002 12:06:18 GMT Joel Sherrill [36202ec] * ChangeLog (modified) * aclocal/check-tool.m4 (modified) 2002-02-07 Ralf Corsepius * ... Sun, 06 Jan 2002 20:12:13 GMT Joel Sherrill [a0ea6f1] * ChangeLog (modified) * aclocal/check-newlib.m4 (modified) * aclocal/config-subdirs.m4 (modified) * aclocal/subdirs.m4 (modified) * aclocal/sysv-ipc.m4 (modified) * aclocal/target.m4 (modified) * automake/compile.am (modified) 2002-02-05 Ralf Corsepius * ... Thu, 20 Dec 2001 17:33:23 GMT Joel Sherrill [ba748523] * ChangeLog (modified) * aclocal/check-posix.m4 (modified) * aclocal/config-subdirs.m4 (modified) * aclocal/env-rtemsbsp.m4 (modified) * aclocal/env-rtemscpu.m4 (modified) * aclocal/multi.m4 (added) * aclocal/multilib.m4 (modified) * aclocal/project-root.m4 (modified) * aclocal/rtems-debug.m4 (modified) * aclocal/rtems-top.m4 (modified) * aclocal/subdirs.m4 (added) * automake/compile.am (modified) * configure.ac (modified) 2001-12-20 Ralf Corsepius * ... Mon, 03 Dec 2001 16:09:08 GMT Joel Sherrill [1a457f5] * ChangeLog (modified) * Makefile.am (modified) * aclocal/bsp-configure.m4 (added) 2001-11-30 Ralf Corsepius * ... Wed, 21 Nov 2001 18:36:51 GMT Joel Sherrill [8e541868] * ChangeLog (modified) * aclocal/bsp-alias.m4 (modified) * aclocal/check-bsps.m4 (modified) * aclocal/prog-cc.m4 (modified) 2001-11-21 Ralf Corsepius * ... Tue, 20 Nov 2001 18:50:12 GMT Joel Sherrill [466e590] * ChangeLog (modified) * aclocal/ppc.m4 (added) * automake/force-preinstall.am (added) 2001-11-15 Ralf Corsepius * ... Thu, 15 Nov 2001 16:50:33 GMT Joel Sherrill [9c392aa2] * ChangeLog (modified) * aclocal/bsp-alias.m4 (modified) * aclocal/check-bsps.m4 (modified) 2001-11-14 Ralf Corsepius * ... Wed, 14 Nov 2001 18:57:26 GMT Joel Sherrill [7ee86ba7] * ChangeLog (modified) * aclocal/bspopts.m4 (added) 2001-11-14 Ralf Corsepius * ... Wed, 17 Oct 2001 20:30:38 GMT Joel Sherrill [60c7524] * ChangeLog (modified) * aclocal/check-rdbg.m4 (modified) 2001-10-17 Ralf Corsepius * ... Wed, 17 Oct 2001 13:15:11 GMT Joel Sherrill [080afec] * ChangeLog (modified) * Makefile.am (modified) * aclocal/rtems-cpu-subdirs.m4 (modified) * aclocal/target.m4 (modified) 2001-10-16 Ralf Corsepius * ... Wed, 10 Oct 2001 00:38:56 GMT Joel Sherrill [083b72a] * ChangeLog (modified) * aclocal/rtems-cpu-subdirs.m4 (added) 2001-10-09 Ralf Corsepius * ... Fri, 14 Sep 2001 17:30:22 GMT Joel Sherrill [37b5d78] * ChangeLog (modified) * aclocal/canonical-target-name.m4 (modified) * aclocal/config-subdirs.m4 (modified) * aclocal/target.m4 (modified) * make/custom/mbx8xx.cfg (modified) 2001-09-14 Ralf Corsepius * ... Thu, 13 Sep 2001 13:14:30 GMT Joel Sherrill [e712997] * ChangeLog (modified) * aclocal/enable-bare.m4 (modified) * aclocal/enable-cxx.m4 (modified) * aclocal/enable-gcc28.m4 (modified) * aclocal/enable-inlines.m4 (modified) * aclocal/enable-itron.m4 (modified) * aclocal/enable-libcdir.m4 (modified) * aclocal/enable-multiprocessing.m4 (modified) * aclocal/enable-networking.m4 (modified) * aclocal/enable-posix.m4 (modified) * aclocal/enable-rdbg.m4 (modified) * aclocal/enable-rtemsbsp.m4 (modified) * aclocal/enable-tests.m4 (modified) * aclocal/env-rtemsbsp.m4 (modified) * aclocal/multilib.m4 (modified) * aclocal/rtems-debug.m4 (modified) * aclocal/rtems-test-no-pause.m4 (modified) * aclocal/rtems-top.m4 (modified) * bootstrap (modified) * configure.in (modified) 2001-07-19 Ralf Corsepius * ... Thu, 24 May 2001 20:01:10 GMT Joel Sherrill [a86c171] * ChangeLog (modified) * aclocal/canonical-target-name.m4 (modified) * aclocal/config-subdirs.m4 (modified) 2001-05-16 Ralf Corsepius * ... Mon, 07 May 2001 13:15:49 GMT Joel Sherrill [f1d08c98] * ChangeLog (modified) * aclocal/prog-cc.m4 (modified) 2001-04-27 Ralf Corsepius * ... Fri, 20 Apr 2001 17:27:55 GMT Joel Sherrill [084556d] * ChangeLog (modified) * aclocal/check-rdbg.m4 (modified) 2001-04-20 Eric Valette * ... Wed, 21 Feb 2001 14:20:50 GMT Joel Sherrill [b50b3c8] * ChangeLog (modified) * aclocal/bsp-alias.m4 (modified) * aclocal/check-bsps.m4 (modified) * aclocal/config-subdirs.m4 (modified) * aclocal/enable-rtemsbsp.m4 (modified) 2001-02-20 Ralf Corsepius * ... Mon, 05 Feb 2001 18:04:57 GMT Joel Sherrill [f5c58361] * aclocal/config-subdirs.m4 (added) * aclocal/target.m4 (modified) 2001-02-03 Ralf Corsepius * ... Fri, 02 Feb 2001 18:32:12 GMT Joel Sherrill [2608a535] * aclocal/env-rtemsbsp.m4 (modified) * aclocal/env-rtemscpu.m4 (modified) 2001-02-02 Ralf Corsepius * ... Fri, 02 Feb 2001 18:30:42 GMT Joel Sherrill [21d7de3a] * ChangeLog (modified) * aclocal/bsp-arg-enable.m4 (modified) * aclocal/check-bsps.m4 (modified) * configure.in (modified) 2001-02-02 Ralf Corsepius * ... Mon, 29 Jan 2001 15:27:25 GMT Joel Sherrill [560aae24] * ChangeLog (modified) * aclocal/bsp-arg-enable.m4 (added) * aclocal/enable-rtemsbsp.m4 (modified) * aclocal/env-rtemsbsp.m4 (added) * aclocal/env-rtemscpu.m4 (added) * aclocal/prog-cc.m4 (modified) * automake/compile.am (modified) 2001-01-26 Ralf Corsepius * ... Mon, 22 Jan 2001 14:03:44 GMT Joel Sherrill [227ae749] * ChangeLog (modified) * aclocal/bsp-alias.m4 (modified) * aclocal/check-bsps.m4 (modified) * make/ChangeLog (modified) * make/custom/shsim.cfg (modified) * make/custom/simsh7032.cfg (added) * make/custom/simsh7045.cfg (added) 2001-01-22 Ralf Corsepius * ... Wed, 15 Nov 2000 21:56:52 GMT Joel Sherrill [1033e27] * ChangeLog (modified) * aclocal/canonical-host.m4 (modified) * aclocal/check-newlib.m4 (modified) * aclocal/rtems-debug.m4 (modified) * aclocal/rtems-top.m4 (modified) 2000-11-13 Ralf Corsepius * ... Mon, 13 Nov 2000 22:51:54 GMT Joel Sherrill [a44f9ca5] * ChangeLog (modified) * README.configure (modified) * aclocal/bsp-alias.m4 (modified) * aclocal/check-bsps.m4 (modified) 2000-11-13 Jiri Gaisler * ... Thu, 09 Nov 2000 17:04:53 GMT Joel Sherrill [2dbd07f8] * ChangeLog (modified) * aclocal/check-bsp-cache.m4 (modified) * aclocal/gcc-pipe.m4 (modified) * aclocal/gcc-specs.m4 (modified) * aclocal/multilib.m4 (modified) * aclocal/prog-cc.m4 (modified) 2000-11-09 Ralf Corsepius * ... Thu, 09 Nov 2000 17:01:25 GMT Joel Sherrill [5913d94] * ChangeLog (modified) * aclocal/check-newlib.m4 (modified) * aclocal/enable-itron.m4 (modified) * aclocal/enable-posix.m4 (modified) * aclocal/sysv-ipc.m4 (modified) * configure.in (modified) 2000-11-09 Ralf Corsepius * ... Fri, 03 Nov 2000 14:15:29 GMT Joel Sherrill [6870384] * aclocal/check-tool.m4 (added) 2000-11-02 Ralf Corsepius * ... Thu, 02 Nov 2000 22:51:12 GMT Joel Sherrill [4686e5d9] * ChangeLog (modified) * aclocal/canonicalize-tools.m4 (modified) * aclocal/prog-cc.m4 (modified) * aclocal/prog-cxx.m4 (modified) 2000-11-02 Ralf Corsepius * ... Thu, 02 Nov 2000 15:55:26 GMT Joel Sherrill [2f17d74] * ChangeLog (modified) * aclocal/canonicalize-tools.m4 (modified) 2000-11-02 Ralf Corsepius * ... Thu, 02 Nov 2000 15:44:04 GMT Joel Sherrill [2e0fd427] * ChangeLog (modified) * Makefile.am (modified) * aclocal/ar-s.m4 (deleted) * aclocal/canonicalize-tools.m4 (modified) * aclocal/check-cxx.m4 (modified) * aclocal/check-newlib.m4 (modified) * aclocal/enable-rtemsbsp.m4 (modified) * aclocal/gcc-pipe.m4 (modified) * aclocal/gcc-specs.m4 (modified) * aclocal/i386-gas-code16.m4 (modified) * aclocal/multilib.m4 (modified) * aclocal/prog-cc.m4 (modified) * aclocal/prog-cxx.m4 (modified) * aclocal/project-root.m4 (modified) * aclocal/rtems-top.m4 (modified) * aclocal/target.m4 (modified) * aclocal/tool-prefix.m4 (deleted) * macros/bsp-alias.m4 (deleted) * macros/canonical-host.m4 (deleted) * macros/canonical-target-name.m4 (deleted) * macros/canonicalize-tools.m4 (deleted) * macros/check-bsp-cache.m4 (deleted) * macros/check-bsps.m4 (deleted) * macros/check-cpu.m4 (deleted) * macros/check-cxx.m4 (deleted) * macros/check-itron.m4 (deleted) * macros/check-multiprocessing.m4 (deleted) * macros/check-networking.m4 (deleted) * macros/check-newlib.m4 (deleted) * macros/check-posix.m4 (deleted) * macros/check-rdbg.m4 (deleted) * macros/enable-bare.m4 (deleted) * macros/enable-cxx.m4 (deleted) * macros/enable-gcc28.m4 (deleted) * macros/enable-inlines.m4 (deleted) * macros/enable-itron.m4 (deleted) * macros/enable-libcdir.m4 (deleted) * macros/enable-multiprocessing.m4 (deleted) * macros/enable-networking.m4 (deleted) * macros/enable-posix.m4 (deleted) * macros/enable-rdbg.m4 (deleted) * macros/enable-rtemsbsp.m4 (deleted) * macros/enable-tests.m4 (deleted) * macros/gcc-pipe.m4 (deleted) * macros/gcc-specs.m4 (deleted) * macros/i386-gas-code16.m4 (deleted) * macros/multilib.m4 (deleted) * macros/path-ksh.m4 (deleted) * macros/path-perl.m4 (deleted) * macros/prog-cc.m4 (deleted) * macros/prog-cxx.m4 (deleted) * macros/project-root.m4 (deleted) * macros/rtems-debug.m4 (deleted) * macros/rtems-test-no-pause.m4 (deleted) * macros/rtems-top.m4 (deleted) * macros/sysv-ipc.m4 (deleted) * macros/target.m4 (deleted) * macros/tool-paths.m4 (deleted) 2000-11-02 Ralf Corsepius * ... Tue, 24 Oct 2000 21:59:16 GMT Joel Sherrill [509f8351] * ChangeLog (modified) * aclocal/rtems-top.m4 (modified) * automake/compile.am (modified) * automake/lib.am (modified) 2000-10-24 Ralf Corsepius * ... Thu, 14 Sep 2000 16:54:39 GMT Joel Sherrill [c9782f9] * ChangeLog (modified) * aclocal/enable-hwapi.m4 (deleted) 2000-09-14 Joel Sherrill * ... Wed, 13 Sep 2000 13:08:11 GMT Joel Sherrill [372e4e2] * ChangeLog (modified) * aclocal/rtems-top.m4 (modified) * automake/compile.am (modified) 2000-09-13 Ralf Corsepius * ... Tue, 12 Sep 2000 20:54:13 GMT Joel Sherrill [1ea70d78] * ChangeLog (modified) * aclocal/check-cxx.m4 (modified) * aclocal/prog-cc.m4 (modified) * automake/compile.am (modified) * automake/local.am (modified) 2000-09-12 Ralf Corsepius * ... Tue, 12 Sep 2000 12:52:12 GMT Joel Sherrill [03d5706] * ChangeLog (modified) * aclocal/enable-rtemsbsp.m4 (modified) * aclocal/i386-gas-code16.m4 (modified) * aclocal/target.m4 (modified) * automake/compile.am (modified) 2000-09-12 Ralf Corsepius * ... Wed, 06 Sep 2000 15:29:57 GMT Joel Sherrill [9322194] * ChangeLog (modified) * aclocal/project-root.m4 (modified) 2000-09-06 Ralf Corsepius * ... Fri, 01 Sep 2000 07:12:52 GMT Joel Sherrill [be28778] * ChangeLog (modified) * aclocal/check-bsps.m4 (modified) 2000-08-31 Ralf Corsepius * ... Fri, 25 Aug 2000 17:27:52 GMT Joel Sherrill [8e57762] * ChangeLog (modified) * aclocal/bsp-alias.m4 (modified) * aclocal/check-bsps.m4 (modified) 2000-08-17 Ralf Corsepius * ... Tue, 01 Aug 2000 20:01:14 GMT Joel Sherrill [b812f84] * aclocal/bsp-alias.m4 (modified) * aclocal/check-bsps.m4 (modified) * c/ACKNOWLEDGEMENTS (modified) * c/TESTED (modified) * c/src/lib/libbsp/m68k/shared/bspspuriousinit.c (added) * c/src/lib/libbsp/m68k/shared/m68000spurious.c (added) * c/src/lib/libbsp/m68k/sim68000/.cvsignore (added) * c/src/lib/libbsp/m68k/sim68000/Makefile.am (added) * c/src/lib/libbsp/m68k/sim68000/README (added) * c/src/lib/libbsp/m68k/sim68000/bsp_specs (added) * c/src/lib/libbsp/m68k/sim68000/clock/.cvsignore (added) * c/src/lib/libbsp/m68k/sim68000/clock/Makefile.am (added) * c/src/lib/libbsp/m68k/sim68000/clock/clockdrv.c (added) * c/src/lib/libbsp/m68k/sim68000/configure.in (added) * c/src/lib/libbsp/m68k/sim68000/console/.cvsignore (added) * c/src/lib/libbsp/m68k/sim68000/console/Makefile.am (added) * c/src/lib/libbsp/m68k/sim68000/console/conscfg.c (added) * c/src/lib/libbsp/m68k/sim68000/include/.cvsignore (added) * c/src/lib/libbsp/m68k/sim68000/include/Makefile.am (added) * c/src/lib/libbsp/m68k/sim68000/include/bsp.h (added) * c/src/lib/libbsp/m68k/sim68000/sim68000.setup (added) * c/src/lib/libbsp/m68k/sim68000/start/.cvsignore (added) * c/src/lib/libbsp/m68k/sim68000/start/Makefile.am (added) * c/src/lib/libbsp/m68k/sim68000/start/start.S (added) * c/src/lib/libbsp/m68k/sim68000/startup/.cvsignore (added) * c/src/lib/libbsp/m68k/sim68000/startup/Makefile.am (added) * c/src/lib/libbsp/m68k/sim68000/startup/bspstart.c (added) * c/src/lib/libbsp/m68k/sim68000/startup/linkcmds (added) * c/src/lib/libbsp/m68k/sim68000/startup/spurious_assistant.c (added) * c/src/lib/libbsp/m68k/sim68000/wrapup/.cvsignore (added) * c/src/lib/libbsp/m68k/sim68000/wrapup/Makefile.am (added) * make/custom/sim68000.cfg (added) * make/custom/simcpu32.cfg (added) Added sim68000 BSP for the BSVC simulator. This BSP includes the ... Tue, 25 Jul 2000 13:33:08 GMT Joel Sherrill [7496d9c] * aclocal/rtems-top.m4 (modified) Patch rtems-rc-20000725-1-cvs.diff from Ralf Corsepius [dbe50fd] * aclocal/bsp-alias.m4 (modified) * aclocal/check-bsps.m4 (modified) Added c3xsim as alias of c4xsim. Mon, 17 Jul 2000 01:54:14 GMT Joel Sherrill [237c259] * aclocal/rtems-test-no-pause.m4 (modified) Changed default value to "pause". Thu, 13 Jul 2000 15:05:38 GMT Joel Sherrill [b8a30d07] * Makefile.am (modified) * aclocal/check-itron.m4 (modified) * aclocal/check-multiprocessing.m4 (modified) * aclocal/check-posix.m4 (modified) * aclocal/rtems-debug.m4 (modified) * aclocal/rtems-test-no-pause.m4 (added) * c/src/exec/configure.in (modified) * c/src/exec/itron/configure.in (modified) * c/src/exec/posix/configure.in (modified) * c/src/exec/score/cpu/unix/configure.in (modified) * c/src/lib/configure.in (modified) * c/src/lib/libbsp/a29k/portsw/configure.in (modified) * c/src/lib/libbsp/configure.in (modified) * c/src/lib/libbsp/h8300/h8sim/configure.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/configure.in (modified) * c/src/lib/libbsp/i960/cvme961/configure.in (modified) * c/src/lib/libbsp/i960/i960sim/configure.in (modified) * c/src/lib/libbsp/i960/rxgen960/configure.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/configure.in (modified) * c/src/lib/libbsp/powerpc/dmv177/configure.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/configure.in (modified) * c/src/lib/libbsp/powerpc/helas403/configure.in (modified) * c/src/lib/libbsp/powerpc/mbx8xx/configure.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/configure.in (modified) * c/src/lib/libbsp/powerpc/papyrus/configure.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/configure.in (modified) * c/src/lib/libbsp/powerpc/psim/configure.in (modified) * c/src/lib/libbsp/unix/posix/configure.in (modified) * c/src/libmisc/configure.in (modified) * c/src/tests/configure.in (modified) * c/src/tests/itrontests/configure.in (modified) * c/src/tests/itrontests/itrontests.am (modified) * c/src/tests/libtests/configure.in (modified) * c/src/tests/libtests/libtests.am (modified) * c/src/tests/mptests/configure.in (modified) * c/src/tests/mptests/mp01/node1/Makefile.am (modified) * c/src/tests/mptests/mp01/node2/Makefile.am (modified) * c/src/tests/mptests/mp02/node1/Makefile.am (modified) * c/src/tests/mptests/mp02/node2/Makefile.am (modified) * c/src/tests/mptests/mp03/node1/Makefile.am (modified) * c/src/tests/mptests/mp03/node2/Makefile.am (modified) * c/src/tests/mptests/mp04/node1/Makefile.am (modified) * c/src/tests/mptests/mp04/node2/Makefile.am (modified) * c/src/tests/mptests/mp05/node1/Makefile.am (modified) * c/src/tests/mptests/mp05/node2/Makefile.am (modified) * c/src/tests/mptests/mp06/node1/Makefile.am (modified) * c/src/tests/mptests/mp06/node2/Makefile.am (modified) * c/src/tests/mptests/mp07/node1/Makefile.am (modified) * c/src/tests/mptests/mp07/node2/Makefile.am (modified) * c/src/tests/mptests/mp08/node1/Makefile.am (modified) * c/src/tests/mptests/mp08/node2/Makefile.am (modified) * c/src/tests/mptests/mp09/node1/Makefile.am (modified) * c/src/tests/mptests/mp09/node2/Makefile.am (modified) * c/src/tests/mptests/mp10/node1/Makefile.am (modified) * c/src/tests/mptests/mp10/node2/Makefile.am (modified) * c/src/tests/mptests/mp11/node1/Makefile.am (modified) * c/src/tests/mptests/mp11/node2/Makefile.am (modified) * c/src/tests/mptests/mp12/node1/Makefile.am (modified) * c/src/tests/mptests/mp12/node2/Makefile.am (modified) * c/src/tests/mptests/mp13/node1/Makefile.am (modified) * c/src/tests/mptests/mp13/node2/Makefile.am (modified) * c/src/tests/mptests/mp14/node1/Makefile.am (modified) * c/src/tests/mptests/mp14/node2/Makefile.am (modified) * c/src/tests/mptests/mptests.am (modified) * c/src/tests/psxtests/configure.in (modified) * c/src/tests/psxtests/psxtests.am (modified) * c/src/tests/samples/base_mp/node1/Makefile.am (modified) * c/src/tests/samples/base_mp/node2/Makefile.am (modified) * c/src/tests/samples/configure.in (modified) * c/src/tests/samples/sample.am (modified) * c/src/tests/sptests/configure.in (modified) * c/src/tests/sptests/sptests.am (modified) * c/src/tests/support/configure.in (modified) * c/src/tests/tmitrontests/configure.in (modified) * c/src/tests/tmitrontests/tmitrontests.am (modified) * c/src/tests/tmtests/configure.in (modified) * c/src/tests/tmtests/tmtests.am (modified) * make/custom/Cygwin-posix.cfg (modified) * make/custom/FreeBSD-posix.cfg (modified) * make/custom/HPUX9-posix.cfg (modified) * make/custom/Linux-posix.cfg (modified) * make/custom/Solaris-posix.cfg (modified) * make/custom/bare.cfg (modified) * make/custom/cvme961.cfg (modified) * make/custom/dmv152.cfg (modified) * make/custom/dmv177.cfg (modified) * make/custom/efi332.cfg (modified) * make/custom/efi68k.cfg (modified) * make/custom/erc32.cfg (modified) * make/custom/eth_comm.cfg (modified) * make/custom/gen68302.cfg (modified) * make/custom/gen68340.cfg (modified) * make/custom/gen68360.cfg (modified) * make/custom/gensh1.cfg (modified) * make/custom/gensh2.cfg (modified) * make/custom/h8sim.cfg (modified) * make/custom/helas403.cfg (modified) * make/custom/i386ex.cfg (modified) * make/custom/i960sim.cfg (modified) * make/custom/idp.cfg (modified) * make/custom/mbx860_005b.cfg (modified) * make/custom/mbx8xx.cfg (modified) * make/custom/mcp750.cfg (modified) * make/custom/mvme136.cfg (modified) * make/custom/mvme147.cfg (modified) * make/custom/mvme162.cfg (modified) * make/custom/mvme167.cfg (modified) * make/custom/mvme2307.cfg (modified) * make/custom/ods68302.cfg (modified) * make/custom/p4000.cfg (modified) * make/custom/p4600.cfg (modified) * make/custom/p4650.cfg (modified) * make/custom/papyrus.cfg (modified) * make/custom/pc386.cfg (modified) * make/custom/portsw.cfg (modified) * make/custom/ppcn_60x.cfg (modified) * make/custom/psim.cfg (modified) * make/custom/rxgen960.cfg (modified) * make/custom/score603e.cfg (modified) * make/custom/simhppa.cfg (modified) * make/custom/ts_386ex.cfg (modified) * testsuites/itrontests/itrontests.am (modified) * testsuites/libtests/libtests.am (modified) * testsuites/mptests/mp01/node1/Makefile.am (modified) * testsuites/mptests/mp01/node2/Makefile.am (modified) * testsuites/mptests/mp02/node1/Makefile.am (modified) * testsuites/mptests/mp02/node2/Makefile.am (modified) * testsuites/mptests/mp03/node1/Makefile.am (modified) * testsuites/mptests/mp03/node2/Makefile.am (modified) * testsuites/mptests/mp04/node1/Makefile.am (modified) * testsuites/mptests/mp04/node2/Makefile.am (modified) * testsuites/mptests/mp05/node1/Makefile.am (modified) * testsuites/mptests/mp05/node2/Makefile.am (modified) * testsuites/mptests/mp06/node1/Makefile.am (modified) * testsuites/mptests/mp06/node2/Makefile.am (modified) * testsuites/mptests/mp07/node1/Makefile.am (modified) * testsuites/mptests/mp07/node2/Makefile.am (modified) * testsuites/mptests/mp08/node1/Makefile.am (modified) * testsuites/mptests/mp08/node2/Makefile.am (modified) * testsuites/mptests/mp09/node1/Makefile.am (modified) * testsuites/mptests/mp09/node2/Makefile.am (modified) * testsuites/mptests/mp10/node1/Makefile.am (modified) * testsuites/mptests/mp10/node2/Makefile.am (modified) * testsuites/mptests/mp11/node1/Makefile.am (modified) * testsuites/mptests/mp11/node2/Makefile.am (modified) * testsuites/mptests/mp12/node1/Makefile.am (modified) * testsuites/mptests/mp12/node2/Makefile.am (modified) * testsuites/mptests/mp13/node1/Makefile.am (modified) * testsuites/mptests/mp13/node2/Makefile.am (modified) * testsuites/mptests/mp14/node1/Makefile.am (modified) * testsuites/mptests/mp14/node2/Makefile.am (modified) * testsuites/mptests/mptests.am (modified) * testsuites/psxtests/psxtests.am (modified) * testsuites/samples/base_mp/node1/Makefile.am (modified) * testsuites/samples/base_mp/node2/Makefile.am (modified) * testsuites/samples/sample.am (modified) * testsuites/sptests/sptests.am (modified) * testsuites/tmitrontests/tmitrontests.am (modified) * testsuites/tmtests/tmtests.am (modified) Patch rtems-rc-20000713-1-cvs.diff from Ralf Corsepius [39607984] * aclocal/rtems-debug.m4 (added) * c/src/exec/configure.in (modified) * configure.in (modified) * make/custom/Cygwin-posix.cfg (modified) * make/custom/FreeBSD-posix.cfg (modified) * make/custom/HPUX9-posix.cfg (modified) * make/custom/Linux-posix.cfg (modified) * make/custom/Solaris-posix.cfg (modified) * make/custom/bare.cfg (modified) * make/custom/cvme961.cfg (modified) * make/custom/dmv152.cfg (modified) * make/custom/dmv177.cfg (modified) * make/custom/efi332.cfg (modified) * make/custom/efi68k.cfg (modified) * make/custom/erc32.cfg (modified) * make/custom/eth_comm.cfg (modified) * make/custom/gen68302.cfg (modified) * make/custom/gen68340.cfg (modified) * make/custom/gen68360.cfg (modified) * make/custom/gensh1.cfg (modified) * make/custom/gensh2.cfg (modified) * make/custom/h8sim.cfg (modified) * make/custom/helas403.cfg (modified) * make/custom/i386ex.cfg (modified) * make/custom/i960sim.cfg (modified) * make/custom/idp.cfg (modified) * make/custom/mbx860_005b.cfg (modified) * make/custom/mbx8xx.cfg (modified) * make/custom/mcp750.cfg (modified) * make/custom/mvme136.cfg (modified) * make/custom/mvme147.cfg (modified) * make/custom/mvme162.cfg (modified) * make/custom/mvme167.cfg (modified) * make/custom/mvme2307.cfg (modified) * make/custom/ods68302.cfg (modified) * make/custom/p4000.cfg (modified) * make/custom/p4600.cfg (modified) * make/custom/p4650.cfg (modified) * make/custom/papyrus.cfg (modified) * make/custom/pc386.cfg (modified) * make/custom/portsw.cfg (modified) * make/custom/ppcn_60x.cfg (modified) * make/custom/psim.cfg (modified) * make/custom/rxgen960.cfg (modified) * make/custom/score603e.cfg (modified) * make/custom/simhppa.cfg (modified) * make/custom/ts_386ex.cfg (modified) Patch rtems-rc-20000712-1-cvs.diff from Ralf Corsepius [256cbec] * aclocal/enable-rtemsbsp.m4 (modified) * c/src/exec/configure.in (modified) * c/src/exec/itron/configure.in (modified) * c/src/exec/posix/configure.in (modified) * c/src/exec/score/cpu/a29k/configure.in (modified) * c/src/exec/score/cpu/h8300/configure.in (modified) * c/src/exec/score/cpu/hppa1.1/configure.in (modified) * c/src/exec/score/cpu/i386/configure.in (modified) * c/src/exec/score/cpu/i960/configure.in (modified) * c/src/exec/score/cpu/m68k/configure.in (modified) * c/src/exec/score/cpu/mips/configure.in (modified) * c/src/exec/score/cpu/mips64orion/configure.in (modified) * c/src/exec/score/cpu/no_cpu/configure.in (modified) * c/src/exec/score/cpu/powerpc/configure.in (modified) * c/src/exec/score/cpu/sh/configure.in (modified) * c/src/exec/score/cpu/sparc/configure.in (modified) * c/src/exec/score/cpu/unix/configure.in (modified) Patch rtems-rc-20000708-1.diff from Ralf Corsepius [823938f] * aclocal/check-newlib.m4 (modified) Patch rtems-rc-20000707-1-cvs.diff from Ralf Corsepius ... Thu, 06 Jul 2000 20:15:35 GMT Joel Sherrill [02217e0b] * aclocal/multilib.m4 (modified) Patch rtems-rc-20000704-1.diff from Ralf Corsepius [04e6f7bf] * aclocal/check-itron.m4 (modified) * aclocal/check-multiprocessing.m4 (modified) * aclocal/check-posix.m4 (modified) * aclocal/enable-inlines.m4 (modified) * aclocal/enable-rtemsbsp.m4 (modified) * c/src/configure.in (modified) * c/src/exec/configure.in (modified) * c/src/exec/itron/configure.in (modified) * c/src/exec/posix/configure.in (modified) * c/src/exec/score/cpu/a29k/configure.in (modified) * c/src/exec/score/cpu/h8300/configure.in (modified) * c/src/exec/score/cpu/hppa1.1/configure.in (modified) * c/src/exec/score/cpu/i386/configure.in (modified) * c/src/exec/score/cpu/i960/configure.in (modified) * c/src/exec/score/cpu/m68k/configure.in (modified) * c/src/exec/score/cpu/mips/configure.in (modified) * c/src/exec/score/cpu/mips64orion/configure.in (modified) * c/src/exec/score/cpu/no_cpu/configure.in (modified) * c/src/exec/score/cpu/powerpc/configure.in (modified) * c/src/exec/score/cpu/sh/configure.in (modified) * c/src/exec/score/cpu/sparc/configure.in (modified) * c/src/exec/score/cpu/unix/configure.in (modified) * c/src/exec/score/include/rtems/score/Makefile.am (modified) Patch rtems-rc-20000705-3.diff from Ralf Corsepius [04e4829] * aclocal/check-newlib.m4 (modified) * c/src/lib/configure.in (modified) * c/src/lib/include/sys/Makefile.am (modified) Patch rtems-rc-20000626-1.diff from Ralf Corsepius [fe5851ce] * Makefile.am (modified) * aclocal/check-multiprocessing.m4 (modified) * aclocal/multilib.m4 (added) Patch rtems-rc-20000627-1 from Ralf Corsepius [3207f0a] * aclocal/canonical-host.m4 (modified) * aclocal/canonical-target-name.m4 (modified) * aclocal/enable-itron.m4 (modified) * aclocal/enable-posix.m4 (modified) * aclocal/rtems-top.m4 (modified) Patch from James Housley to address FreeBSD 4.x ... Wed, 14 Jun 2000 17:12:23 GMT Joel Sherrill [c63a5cf] * aclocal/bsp-alias.m4 (modified) * aclocal/check-multiprocessing.m4 (modified) * aclocal/check-posix.m4 (modified) Patch rtems-rc-20000614-1-cvs.diff from Ralf Corsepius ... Mon, 12 Jun 2000 19:57:02 GMT Joel Sherrill [8ef3818] * aclocal/bsp-alias.m4 (modified) * aclocal/check-bsps.m4 (modified) * c/src/exec/libcsupport/include/sys/termios.h (modified) * c/src/exec/libcsupport/src/malloc.c (modified) * c/src/exec/libcsupport/src/termios.c (modified) * c/src/exec/posix/src/waitpid.c (modified) * c/src/exec/rtems/include/rtems/rtems/Makefile.am (modified) * c/src/exec/rtems/include/rtems/rtems/cache.h (added) * c/src/exec/rtems/src/Makefile.am (modified) * c/src/exec/rtems/src/cache.c (added) * c/src/exec/score/cpu/i386/rtems/score/i386.h (modified) * c/src/exec/score/cpu/m68k/rtems/score/m68k.h (modified) * c/src/exec/score/cpu/powerpc/asm.h (modified) * c/src/exec/score/cpu/powerpc/old_exception_processing/Makefile.am (modified) * c/src/exec/score/cpu/powerpc/old_exception_processing/cpu.c (modified) * c/src/exec/score/cpu/powerpc/old_exception_processing/cpu.h (modified) * c/src/exec/score/cpu/powerpc/rtems/score/ppc.h (modified) * c/src/exec/score/cpu/powerpc/shared/asm.h (modified) * c/src/exec/score/cpu/powerpc/shared/ppc.h (modified) * c/src/exec/score/include/rtems/score/object.h (modified) * c/src/exec/score/include/rtems/score/thread.h (modified) * c/src/exec/score/src/Makefile.am (modified) * c/src/exec/score/src/objectlocaliterate.c (added) * c/src/exec/score/src/threadlocaliterate.c (added) * c/src/lib/include/sys/termios.h (modified) * c/src/lib/libbsp/m68k/gen68360/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme167/README (modified) * c/src/lib/libbsp/m68k/mvme167/bsp_specs (modified) * c/src/lib/libbsp/m68k/mvme167/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme167/network/network.c (modified) * c/src/lib/libbsp/m68k/mvme167/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme167/startup/page_table.c (modified) * c/src/lib/libbsp/powerpc/eth_comm/canbus/canbus.c (modified) * c/src/lib/libbsp/powerpc/eth_comm/console/console.c (modified) * c/src/lib/libbsp/powerpc/eth_comm/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/eth_comm/network/network.c (modified) * c/src/lib/libbsp/powerpc/eth_comm/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/eth_comm/startup/cpuinit.c (added) * c/src/lib/libbsp/powerpc/eth_comm/startup/linkcmds (modified) * c/src/lib/libbsp/powerpc/eth_comm/startup/mmutlbtab.c (added) * c/src/lib/libbsp/powerpc/mbx8xx/Makefile.am (added) * c/src/lib/libbsp/powerpc/mbx8xx/README (added) * c/src/lib/libbsp/powerpc/mbx8xx/bsp_specs (added) * c/src/lib/libbsp/powerpc/mbx8xx/configure.in (added) * c/src/lib/libbsp/powerpc/mbx8xx/console/Makefile.am (added) * c/src/lib/libbsp/powerpc/mbx8xx/console/console.c (added) * c/src/lib/libbsp/powerpc/mbx8xx/include/Makefile.am (added) * c/src/lib/libbsp/powerpc/mbx8xx/include/bsp.h (added) * c/src/lib/libbsp/powerpc/mbx8xx/include/coverhd.h (added) * c/src/lib/libbsp/powerpc/mbx8xx/network/Makefile.am (added) * c/src/lib/libbsp/powerpc/mbx8xx/network/network.c (added) * c/src/lib/libbsp/powerpc/mbx8xx/startup/Makefile.am (added) * c/src/lib/libbsp/powerpc/mbx8xx/startup/bspstart.c (added) * c/src/lib/libbsp/powerpc/mbx8xx/startup/bspstart.c.nocache (added) * c/src/lib/libbsp/powerpc/mbx8xx/startup/imbx8xx.c (added) * c/src/lib/libbsp/powerpc/mbx8xx/startup/linkcmds (added) * c/src/lib/libbsp/powerpc/mbx8xx/startup/mmutlbtab.c (added) * c/src/lib/libbsp/powerpc/mbx8xx/startup/setvec.c (added) * c/src/lib/libbsp/powerpc/mbx8xx/startup/start.S (added) * c/src/lib/libbsp/powerpc/mbx8xx/times-mbx821 (added) * c/src/lib/libbsp/powerpc/mbx8xx/times-mbx860 (added) * c/src/lib/libbsp/powerpc/mbx8xx/wrapup/Makefile.am (added) * c/src/lib/libbsp/powerpc/support/old_exception_processing/Makefile.am (modified) * c/src/lib/libbsp/powerpc/support/old_exception_processing/cpu.c (modified) * c/src/lib/libbsp/powerpc/support/old_exception_processing/cpu.h (modified) * c/src/lib/libc/malloc.c (modified) * c/src/lib/libc/termios.c (modified) * c/src/lib/libcpu/i386/cpu.h (modified) * c/src/lib/libcpu/i386/page.c (modified) * c/src/lib/libcpu/powerpc/Makefile.am (modified) * c/src/lib/libcpu/powerpc/configure.in (modified) * c/src/lib/libcpu/powerpc/mpc8xx/Makefile.am (added) * c/src/lib/libcpu/powerpc/mpc8xx/README (added) * c/src/lib/libcpu/powerpc/mpc8xx/clock/Makefile.am (added) * c/src/lib/libcpu/powerpc/mpc8xx/clock/clock.c (added) * c/src/lib/libcpu/powerpc/mpc8xx/console-generic/Makefile.am (added) * c/src/lib/libcpu/powerpc/mpc8xx/console-generic/console-generic.c (added) * c/src/lib/libcpu/powerpc/mpc8xx/cpm/Makefile.am (added) * c/src/lib/libcpu/powerpc/mpc8xx/cpm/cp.c (added) * c/src/lib/libcpu/powerpc/mpc8xx/cpm/dpram.c (added) * c/src/lib/libcpu/powerpc/mpc8xx/include/Makefile.am (added) * c/src/lib/libcpu/powerpc/mpc8xx/include/console.h (added) * c/src/lib/libcpu/powerpc/mpc8xx/include/cpm.h (added) * c/src/lib/libcpu/powerpc/mpc8xx/include/mmu.h (added) * c/src/lib/libcpu/powerpc/mpc8xx/include/mpc8xx.h (added) * c/src/lib/libcpu/powerpc/mpc8xx/mmu/Makefile.am (added) * c/src/lib/libcpu/powerpc/mpc8xx/mmu/mmu.c (added) * c/src/lib/libcpu/powerpc/mpc8xx/timer/Makefile.am (added) * c/src/lib/libcpu/powerpc/mpc8xx/timer/timer.c (added) * c/src/lib/libcpu/powerpc/mpc8xx/vectors/Makefile.am (added) * c/src/lib/libcpu/powerpc/mpc8xx/vectors/README (added) * c/src/lib/libcpu/powerpc/mpc8xx/vectors/align_h.S (added) * c/src/lib/libcpu/powerpc/mpc8xx/vectors/vectors.S (added) * c/src/lib/libcpu/powerpc/old-exceptions/cpu.c (modified) * c/src/lib/libcpu/powerpc/old_exception_processing/Makefile.am (modified) * c/src/lib/libcpu/powerpc/old_exception_processing/cpu.c (modified) * c/src/lib/libcpu/powerpc/old_exception_processing/cpu.h (modified) * c/src/lib/libcpu/powerpc/shared/cpu.h (modified) * c/src/make/compilers/gcc-target-default.cfg (modified) * c/src/tests/configure.in (modified) * c/src/tests/libtests/termios/init.c (modified) * c/src/tests/samples/cdtest/system.h (modified) * c/src/tests/sptests/Makefile.am (modified) * c/src/tests/sptests/configure.in (modified) * cpukit/libcsupport/include/sys/termios.h (modified) * cpukit/libcsupport/src/malloc.c (modified) * cpukit/libcsupport/src/termios.c (modified) * cpukit/posix/src/waitpid.c (modified) * cpukit/rtems/include/rtems/rtems/cache.h (added) * cpukit/rtems/src/Makefile.am (modified) * cpukit/score/cpu/i386/rtems/score/i386.h (modified) * cpukit/score/cpu/m68k/rtems/score/m68k.h (modified) * cpukit/score/cpu/powerpc/asm.h (modified) * cpukit/score/cpu/powerpc/rtems/asm.h (modified) * cpukit/score/cpu/powerpc/rtems/score/ppc.h (modified) * cpukit/score/include/rtems/score/object.h (modified) * cpukit/score/include/rtems/score/thread.h (modified) * cpukit/score/src/Makefile.am (modified) * make/compilers/gcc-target-default.cfg (modified) * make/custom/eth_comm.cfg (modified) * make/custom/mvme167.cfg (modified) * make/leaf.cfg (modified) * testsuites/libtests/termios/init.c (modified) * testsuites/samples/cdtest/system.h (modified) * testsuites/sptests/Makefile.am (modified) Patch from John Cotton , Charles-Antoine Gauthier ... Mon, 12 Jun 2000 15:00:15 GMT Joel Sherrill [df49c60] * Makefile.am (modified) * VERSION (modified) * aclocal/canonical-host.m4 (modified) * aclocal/canonical-target-name.m4 (modified) * aclocal/check-multiprocessing.m4 (modified) * aclocal/enable-itron.m4 (modified) * aclocal/enable-posix.m4 (modified) * aclocal/prog-cxx.m4 (modified) * aclocal/target.m4 (modified) * automake/host.am (added) * automake/local.am (modified) * automake/subdirs.am (modified) * bootstrap (modified) * c/Makefile.am (modified) * c/make/Makefile.am (modified) * c/src/Makefile.am (modified) * c/src/exec/itron/include/Makefile.am (modified) * c/src/exec/itron/include/itronsys/Makefile.am (modified) * c/src/exec/itron/include/rtems/itron/Makefile.am (modified) * c/src/exec/itron/inline/rtems/itron/Makefile.am (modified) * c/src/exec/itron/src/Makefile.am (modified) * c/src/exec/itron/src/cre_tsk.c (modified) * c/src/exec/itron/src/eventflags.c (modified) * c/src/exec/itron/src/fmempool.c (modified) * c/src/exec/itron/src/itronsem.c (modified) * c/src/exec/itron/src/mbox.c (modified) * c/src/exec/itron/src/msgbuffer.c (modified) * c/src/exec/itron/src/port.c (modified) * c/src/exec/itron/src/vmempool.c (modified) * c/src/exec/libcsupport/Makefile.am (modified) * c/src/exec/libcsupport/include/console.h (modified) * c/src/exec/libcsupport/include/rtems/error.h (modified) * c/src/exec/libcsupport/include/sys/termios.h (modified) * c/src/exec/libcsupport/src/Makefile.am (modified) * c/src/exec/libcsupport/src/gxx_wrappers.c (modified) * c/src/exec/libcsupport/src/libio.c (modified) * c/src/exec/libcsupport/src/malloc.c (modified) * c/src/exec/libcsupport/src/scandir.c (modified) * c/src/exec/libcsupport/src/termios.c (modified) * c/src/exec/libcsupport/src/termiosreserveresources.c (modified) * c/src/exec/libcsupport/src/unmount.c (modified) * c/src/exec/libfs/src/imfs/imfs.h (modified) * c/src/exec/libfs/src/imfs/imfs_creat.c (modified) * c/src/exec/libfs/src/imfs/imfs_directory.c (modified) * c/src/exec/libfs/src/imfs/imfs_stat.c (modified) * c/src/exec/libfs/src/imfs/imfs_utime.c (modified) * c/src/exec/libnetworking/Makefile.am (modified) * c/src/exec/libnetworking/arpa/Makefile.am (modified) * c/src/exec/libnetworking/kern/Makefile.am (modified) * c/src/exec/libnetworking/lib/Makefile.am (modified) * c/src/exec/libnetworking/lib/rtems_bsdnet_ntp.c (modified) * c/src/exec/libnetworking/libc/Makefile.am (modified) * c/src/exec/libnetworking/machine/Makefile.am (modified) * c/src/exec/libnetworking/memory.h (modified) * c/src/exec/libnetworking/net/Makefile.am (modified) * c/src/exec/libnetworking/net/if_loop.c (modified) * c/src/exec/libnetworking/netinet/Makefile.am (modified) * c/src/exec/libnetworking/netinet/in.h (modified) * c/src/exec/libnetworking/nfs/Makefile.am (modified) * c/src/exec/libnetworking/rtems/Makefile.am (modified) * c/src/exec/libnetworking/rtems/rtems_syscall.c (modified) * c/src/exec/libnetworking/sys/Makefile.am (modified) * c/src/exec/libnetworking/sys/un.h (modified) * c/src/exec/libnetworking/vm/Makefile.am (modified) * c/src/exec/libnetworking/wrapup/Makefile.am (modified) * c/src/exec/librpc/Makefile.am (modified) * c/src/exec/librpc/README_RTEMS (modified) * c/src/exec/librpc/include/Makefile.am (modified) * c/src/exec/librpc/include/rpc/Makefile.am (modified) * c/src/exec/librpc/include/rpc/auth.h (modified) * c/src/exec/librpc/include/rpc/auth_des.h (modified) * c/src/exec/librpc/include/rpc/auth_unix.h (modified) * c/src/exec/librpc/include/rpc/clnt.h (modified) * c/src/exec/librpc/include/rpc/des.h (modified) * c/src/exec/librpc/include/rpc/des_crypt.h (modified) * c/src/exec/librpc/include/rpc/pmap_clnt.h (modified) * c/src/exec/librpc/include/rpc/pmap_prot.h (modified) * c/src/exec/librpc/include/rpc/pmap_rmt.h (modified) * c/src/exec/librpc/include/rpc/rpc.h (modified) * c/src/exec/librpc/include/rpc/rpc_com.h (modified) * c/src/exec/librpc/include/rpc/rpc_msg.h (modified) * c/src/exec/librpc/include/rpc/svc.h (modified) * c/src/exec/librpc/include/rpc/svc_auth.h (modified) * c/src/exec/librpc/include/rpc/types.h (modified) * c/src/exec/librpc/include/rpc/xdr.h (modified) * c/src/exec/librpc/include/rpcsvc/.cvsignore (modified) * c/src/exec/librpc/include/rpcsvc/Makefile.am (modified) * c/src/exec/librpc/include/rpcsvc/bootparam_prot.x (modified) * c/src/exec/librpc/include/rpcsvc/crypt.x (modified) * c/src/exec/librpc/include/rpcsvc/key_prot.x (modified) * c/src/exec/librpc/include/rpcsvc/klm_prot.x (modified) * c/src/exec/librpc/include/rpcsvc/mount.x (modified) * c/src/exec/librpc/include/rpcsvc/nfs_prot.x (modified) * c/src/exec/librpc/include/rpcsvc/nis.x (modified) * c/src/exec/librpc/include/rpcsvc/nis_cache.x (modified) * c/src/exec/librpc/include/rpcsvc/nis_callback.x (modified) * c/src/exec/librpc/include/rpcsvc/nis_db.h (modified) * c/src/exec/librpc/include/rpcsvc/nis_object.x (modified) * c/src/exec/librpc/include/rpcsvc/nis_tags.h (modified) * c/src/exec/librpc/include/rpcsvc/nislib.h (modified) * c/src/exec/librpc/include/rpcsvc/nlm_prot.x (modified) * c/src/exec/librpc/include/rpcsvc/pmap_prot.x (modified) * c/src/exec/librpc/include/rpcsvc/rex.x (modified) * c/src/exec/librpc/include/rpcsvc/rnusers.x (modified) * c/src/exec/librpc/include/rpcsvc/rquota.x (modified) * c/src/exec/librpc/include/rpcsvc/rstat.x (modified) * c/src/exec/librpc/include/rpcsvc/rwall.x (modified) * c/src/exec/librpc/include/rpcsvc/sm_inter.x (modified) * c/src/exec/librpc/include/rpcsvc/spray.x (modified) * c/src/exec/librpc/include/rpcsvc/yp.x (modified) * c/src/exec/librpc/include/rpcsvc/yp_prot.h (modified) * c/src/exec/librpc/include/rpcsvc/ypclnt.h (modified) * c/src/exec/librpc/include/rpcsvc/yppasswd.x (modified) * c/src/exec/librpc/include/rpcsvc/ypupdate_prot.x (modified) * c/src/exec/librpc/include/rpcsvc/ypxfrd.x (modified) * c/src/exec/librpc/src/Makefile.am (modified) * c/src/exec/librpc/src/rpc/DISCLAIMER (modified) * c/src/exec/librpc/src/rpc/Makefile.am (modified) * c/src/exec/librpc/src/rpc/PSD.doc/.cvsignore (modified) * c/src/exec/librpc/src/rpc/PSD.doc/Makefile.am (modified) * c/src/exec/librpc/src/rpc/PSD.doc/nfs.rfc.ms (modified) * c/src/exec/librpc/src/rpc/PSD.doc/rpc.prog.ms (modified) * c/src/exec/librpc/src/rpc/PSD.doc/rpc.rfc.ms (modified) * c/src/exec/librpc/src/rpc/PSD.doc/rpcgen.ms (modified) * c/src/exec/librpc/src/rpc/PSD.doc/xdr.nts.ms (modified) * c/src/exec/librpc/src/rpc/PSD.doc/xdr.rfc.ms (modified) * c/src/exec/librpc/src/rpc/README (modified) * c/src/exec/librpc/src/rpc/auth_des.c (modified) * c/src/exec/librpc/src/rpc/auth_none.c (modified) * c/src/exec/librpc/src/rpc/auth_time.c (modified) * c/src/exec/librpc/src/rpc/auth_unix.c (modified) * c/src/exec/librpc/src/rpc/authdes_prot.c (modified) * c/src/exec/librpc/src/rpc/authunix_prot.c (modified) * c/src/exec/librpc/src/rpc/bindresvport.3 (modified) * c/src/exec/librpc/src/rpc/bindresvport.c (modified) * c/src/exec/librpc/src/rpc/clnt_generic.c (modified) * c/src/exec/librpc/src/rpc/clnt_perror.c (modified) * c/src/exec/librpc/src/rpc/clnt_raw.c (modified) * c/src/exec/librpc/src/rpc/clnt_simple.c (modified) * c/src/exec/librpc/src/rpc/clnt_tcp.c (modified) * c/src/exec/librpc/src/rpc/clnt_udp.c (modified) * c/src/exec/librpc/src/rpc/clnt_unix.c (modified) * c/src/exec/librpc/src/rpc/crypt_client.c (modified) * c/src/exec/librpc/src/rpc/des_crypt.3 (modified) * c/src/exec/librpc/src/rpc/des_crypt.c (modified) * c/src/exec/librpc/src/rpc/des_soft.c (modified) * c/src/exec/librpc/src/rpc/get_myaddress.c (modified) * c/src/exec/librpc/src/rpc/getpublickey.c (modified) * c/src/exec/librpc/src/rpc/getrpcent.3 (modified) * c/src/exec/librpc/src/rpc/getrpcent.c (modified) * c/src/exec/librpc/src/rpc/getrpcport.3 (modified) * c/src/exec/librpc/src/rpc/getrpcport.c (modified) * c/src/exec/librpc/src/rpc/key_call.c (modified) * c/src/exec/librpc/src/rpc/key_prot_xdr.c (modified) * c/src/exec/librpc/src/rpc/netname.c (modified) * c/src/exec/librpc/src/rpc/netnamer.c (modified) * c/src/exec/librpc/src/rpc/pmap_clnt.c (modified) * c/src/exec/librpc/src/rpc/pmap_getmaps.c (modified) * c/src/exec/librpc/src/rpc/pmap_getport.c (modified) * c/src/exec/librpc/src/rpc/pmap_prot.c (modified) * c/src/exec/librpc/src/rpc/pmap_prot2.c (modified) * c/src/exec/librpc/src/rpc/pmap_rmt.c (modified) * c/src/exec/librpc/src/rpc/publickey.3 (modified) * c/src/exec/librpc/src/rpc/publickey.5 (modified) * c/src/exec/librpc/src/rpc/rpc.3 (modified) * c/src/exec/librpc/src/rpc/rpc.5 (modified) * c/src/exec/librpc/src/rpc/rpc_callmsg.c (modified) * c/src/exec/librpc/src/rpc/rpc_commondata.c (modified) * c/src/exec/librpc/src/rpc/rpc_dtablesize.c (modified) * c/src/exec/librpc/src/rpc/rpc_prot.c (modified) * c/src/exec/librpc/src/rpc/rpc_secure.3 (modified) * c/src/exec/librpc/src/rpc/rpcdname.c (modified) * c/src/exec/librpc/src/rpc/rstat.1 (modified) * c/src/exec/librpc/src/rpc/rstat_svc.8 (modified) * c/src/exec/librpc/src/rpc/rtems_portmapper.c (modified) * c/src/exec/librpc/src/rpc/rtems_rpc.c (modified) * c/src/exec/librpc/src/rpc/rtime.3 (modified) * c/src/exec/librpc/src/rpc/rtime.c (modified) * c/src/exec/librpc/src/rpc/svc.c (modified) * c/src/exec/librpc/src/rpc/svc_auth.c (modified) * c/src/exec/librpc/src/rpc/svc_auth_des.c (modified) * c/src/exec/librpc/src/rpc/svc_auth_unix.c (modified) * c/src/exec/librpc/src/rpc/svc_raw.c (modified) * c/src/exec/librpc/src/rpc/svc_run.c (modified) * c/src/exec/librpc/src/rpc/svc_simple.c (modified) * c/src/exec/librpc/src/rpc/svc_tcp.c (modified) * c/src/exec/librpc/src/rpc/svc_udp.c (modified) * c/src/exec/librpc/src/rpc/svc_unix.c (modified) * c/src/exec/librpc/src/xdr/Makefile.am (modified) * c/src/exec/librpc/src/xdr/xdr.3 (modified) * c/src/exec/librpc/src/xdr/xdr.c (modified) * c/src/exec/librpc/src/xdr/xdr_array.c (modified) * c/src/exec/librpc/src/xdr/xdr_float.c (modified) * c/src/exec/librpc/src/xdr/xdr_mem.c (modified) * c/src/exec/librpc/src/xdr/xdr_rec.c (modified) * c/src/exec/librpc/src/xdr/xdr_reference.c (modified) * c/src/exec/librpc/src/xdr/xdr_sizeof.c (modified) * c/src/exec/librpc/src/xdr/xdr_stdio.c (modified) * c/src/exec/posix/include/Makefile.am (modified) * c/src/exec/posix/include/pthread.h (deleted) * c/src/exec/posix/include/rtems/posix/Makefile.am (modified) * c/src/exec/posix/include/sys/Makefile.am (modified) * c/src/exec/posix/inline/rtems/posix/Makefile.am (modified) * c/src/exec/posix/inline/rtems/posix/cond.inl (modified) * c/src/exec/posix/macros/rtems/posix/Makefile.am (modified) * c/src/exec/posix/optman/Makefile.am (modified) * c/src/exec/posix/src/Makefile.am (modified) * c/src/exec/posix/src/mqueuecreatesupp.c (modified) * c/src/exec/posix/src/mqueuedeletesupp.c (modified) * c/src/exec/posix/src/mqueueunlink.c (modified) * c/src/exec/posix/src/pthread.c (modified) * c/src/exec/posix/src/pthreadcreate.c (modified) * c/src/exec/posix/src/sigtimedwait.c (modified) * c/src/exec/posix/src/waitpid.c (modified) * c/src/exec/rtems/include/Makefile.am (modified) * c/src/exec/rtems/include/rtems/rtems/Makefile.am (modified) * c/src/exec/rtems/include/rtems/rtems/rtemsapi.h (modified) * c/src/exec/rtems/inline/rtems/rtems/Makefile.am (modified) * c/src/exec/rtems/macros/rtems/rtems/Makefile.am (modified) * c/src/exec/rtems/optman/Makefile.am (modified) * c/src/exec/rtems/optman/no-mp.c (modified) * c/src/exec/rtems/src/Makefile.am (modified) * c/src/exec/rtems/src/semdelete.c (modified) * c/src/exec/rtems/src/tasks.c (modified) * c/src/exec/rtems/src/taskvariableadd.c (modified) * c/src/exec/rtems/src/taskvariabledelete.c (modified) * c/src/exec/rtems/src/taskvariableget.c (modified) * c/src/exec/sapi/include/Makefile.am (modified) * c/src/exec/sapi/include/confdefs.h (modified) * c/src/exec/sapi/include/rtems/Makefile.am (modified) * c/src/exec/sapi/include/rtems/README (modified) * c/src/exec/sapi/inline/rtems/Makefile.am (modified) * c/src/exec/sapi/macros/rtems/Makefile.am (modified) * c/src/exec/sapi/optman/Makefile.am (modified) * c/src/exec/sapi/src/Makefile.am (modified) * c/src/exec/score/cpu/a29k/Makefile.am (modified) * c/src/exec/score/cpu/a29k/rtems/Makefile.am (modified) * c/src/exec/score/cpu/a29k/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/a29k/rtems/score/a29k.h (modified) * c/src/exec/score/cpu/hppa1.1/Makefile.am (modified) * c/src/exec/score/cpu/hppa1.1/rtems/Makefile.am (modified) * c/src/exec/score/cpu/hppa1.1/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/hppa1.1/rtems/score/hppa.h (modified) * c/src/exec/score/cpu/i386/Makefile.am (modified) * c/src/exec/score/cpu/i386/rtems/Makefile.am (modified) * c/src/exec/score/cpu/i386/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/i386/rtems/score/i386.h (modified) * c/src/exec/score/cpu/i960/Makefile.am (modified) * c/src/exec/score/cpu/i960/rtems/Makefile.am (modified) * c/src/exec/score/cpu/i960/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/i960/rtems/score/i960.h (modified) * c/src/exec/score/cpu/m68k/Makefile.am (modified) * c/src/exec/score/cpu/m68k/qsm.h (modified) * c/src/exec/score/cpu/m68k/rtems/Makefile.am (modified) * c/src/exec/score/cpu/m68k/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/m68k/rtems/score/m68k.h (modified) * c/src/exec/score/cpu/m68k/sim.h (modified) * c/src/exec/score/cpu/mips/Makefile.am (modified) * c/src/exec/score/cpu/mips/rtems/Makefile.am (modified) * c/src/exec/score/cpu/mips/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/mips/rtems/score/mips.h (modified) * c/src/exec/score/cpu/mips/rtems/score/mips64orion.h (modified) * c/src/exec/score/cpu/mips64orion/Makefile.am (modified) * c/src/exec/score/cpu/mips64orion/rtems/Makefile.am (modified) * c/src/exec/score/cpu/mips64orion/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/mips64orion/rtems/score/mips64orion.h (modified) * c/src/exec/score/cpu/no_cpu/Makefile.am (modified) * c/src/exec/score/cpu/no_cpu/cpu.c (modified) * c/src/exec/score/cpu/no_cpu/cpu_asm.c (modified) * c/src/exec/score/cpu/no_cpu/rtems.c (modified) * c/src/exec/score/cpu/no_cpu/rtems/Makefile.am (modified) * c/src/exec/score/cpu/no_cpu/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/no_cpu/rtems/score/cpu.h (modified) * c/src/exec/score/cpu/no_cpu/rtems/score/no_cpu.h (modified) * c/src/exec/score/cpu/powerpc/Makefile.am (modified) * c/src/exec/score/cpu/powerpc/new_exception_processing/Makefile.am (modified) * c/src/exec/score/cpu/powerpc/old_exception_processing/Makefile.am (modified) * c/src/exec/score/cpu/powerpc/old_exception_processing/irq_stub.S (modified) * c/src/exec/score/cpu/powerpc/rtems/score/ppc.h (modified) * c/src/exec/score/cpu/powerpc/shared/Makefile.am (modified) * c/src/exec/score/cpu/powerpc/shared/ppc.h (modified) * c/src/exec/score/cpu/sh/Makefile.am (modified) * c/src/exec/score/cpu/sh/rtems/Makefile.am (modified) * c/src/exec/score/cpu/sh/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/sh/rtems/score/sh.h (modified) * c/src/exec/score/cpu/sparc/Makefile.am (modified) * c/src/exec/score/cpu/sparc/rtems/Makefile.am (modified) * c/src/exec/score/cpu/sparc/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/sparc/rtems/score/sparc.h (modified) * c/src/exec/score/cpu/unix/Makefile.am (modified) * c/src/exec/score/cpu/unix/cpu.c (modified) * c/src/exec/score/cpu/unix/rtems/Makefile.am (modified) * c/src/exec/score/cpu/unix/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/unix/rtems/score/cpu.h (modified) * c/src/exec/score/cpu/unix/rtems/score/unix.h (modified) * c/src/exec/score/include/rtems/Makefile.am (modified) * c/src/exec/score/include/rtems/score/Makefile.am (modified) * c/src/exec/score/include/rtems/score/thread.h (modified) * c/src/exec/score/include/rtems/system.h (modified) * c/src/exec/score/inline/rtems/score/Makefile.am (modified) * c/src/exec/score/macros/rtems/score/Makefile.am (modified) * c/src/exec/score/macros/rtems/score/address.inl (modified) * c/src/exec/score/src/Makefile.am (modified) * c/src/exec/score/src/objectcopynamestring.c (modified) * c/src/exec/wrapup/itron/Makefile.am (modified) * c/src/exec/wrapup/posix/Makefile.am (modified) * c/src/exec/wrapup/rtems/Makefile.am (modified) * c/src/lib/Makefile.am (modified) * c/src/lib/configure.in (modified) * c/src/lib/include/Makefile.am (modified) * c/src/lib/include/console.h (modified) * c/src/lib/include/motorola/Makefile.am (modified) * c/src/lib/include/rtems/error.h (modified) * c/src/lib/include/sys/Makefile.am (modified) * c/src/lib/include/sys/termios.h (modified) * c/src/lib/include/zilog/Makefile.am (modified) * c/src/lib/libbsp/Makefile.am (modified) * c/src/lib/libbsp/a29k/Makefile.am (modified) * c/src/lib/libbsp/a29k/portsw/Makefile.am (modified) * c/src/lib/libbsp/a29k/portsw/console/Makefile.am (modified) * c/src/lib/libbsp/a29k/portsw/include/Makefile.am (modified) * c/src/lib/libbsp/a29k/portsw/include/bsp.h (modified) * c/src/lib/libbsp/a29k/portsw/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/a29k/portsw/start/Makefile.am (modified) * c/src/lib/libbsp/a29k/portsw/startup/Makefile.am (modified) * c/src/lib/libbsp/a29k/portsw/startup/bspstart.c (modified) * c/src/lib/libbsp/a29k/portsw/wrapup/Makefile.am (modified) * c/src/lib/libbsp/bare/Makefile.am (modified) * c/src/lib/libbsp/bare/bsp_specs (modified) * c/src/lib/libbsp/bare/include/Makefile.am (modified) * c/src/lib/libbsp/bare/include/bsp.h (modified) * c/src/lib/libbsp/hppa1.1/Makefile.am (modified) * c/src/lib/libbsp/hppa1.1/simhppa/Makefile.am (modified) * c/src/lib/libbsp/hppa1.1/simhppa/include/Makefile.am (modified) * c/src/lib/libbsp/hppa1.1/simhppa/include/bsp.h (modified) * c/src/lib/libbsp/hppa1.1/simhppa/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/hppa1.1/simhppa/start/Makefile.am (modified) * c/src/lib/libbsp/hppa1.1/simhppa/startup/Makefile.am (modified) * c/src/lib/libbsp/hppa1.1/simhppa/startup/bspstart.c (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/Makefile.am (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tty/Makefile.am (modified) * c/src/lib/libbsp/hppa1.1/simhppa/wrapup/Makefile.am (modified) * c/src/lib/libbsp/i386/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/clock/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/console/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/console/console.c (modified) * c/src/lib/libbsp/i386/i386ex/include/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/include/bsp.h (modified) * c/src/lib/libbsp/i386/i386ex/network/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/start/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/start/start.S (modified) * c/src/lib/libbsp/i386/i386ex/startup/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/i386ex/timer/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/wrapup/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/3c509/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/HOWTO (modified) * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/clock/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/console/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/console/console.c (modified) * c/src/lib/libbsp/i386/pc386/include/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/include/bsp.h (modified) * c/src/lib/libbsp/i386/pc386/ne2000/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/start/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/start/start16.S (modified) * c/src/lib/libbsp/i386/pc386/startup/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/pc386/startup/ldsegs.S (modified) * c/src/lib/libbsp/i386/pc386/timer/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/tools/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/wd8003/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/wrapup/Makefile.am (modified) * c/src/lib/libbsp/i386/shared/Makefile.am (modified) * c/src/lib/libbsp/i386/shared/comm/Makefile.am (modified) * c/src/lib/libbsp/i386/shared/io/Makefile.am (modified) * c/src/lib/libbsp/i386/shared/irq/Makefile.am (modified) * c/src/lib/libbsp/i386/shared/pci/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/clock/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/console/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/console/console.c (modified) * c/src/lib/libbsp/i386/ts_386ex/include/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/include/bsp.h (modified) * c/src/lib/libbsp/i386/ts_386ex/network/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/start/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/start/start.S (modified) * c/src/lib/libbsp/i386/ts_386ex/startup/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/ts_386ex/timer/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/debug_ada/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/debug_ada/init.c (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/debug_c/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/debug_c/system.h (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/dos_sup/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/network_ada/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/network_ada/adasockets/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/network_ada/listener/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/network_ada/listener/init.c (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/network_ada/tcprelay/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/network_ada/tcprelay/init.c (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/ts_1325_ada/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/ts_1325_ada/init.c (modified) * c/src/lib/libbsp/i386/ts_386ex/wrapup/Makefile.am (modified) * c/src/lib/libbsp/i960/Makefile.am (modified) * c/src/lib/libbsp/i960/cvme961/Makefile.am (modified) * c/src/lib/libbsp/i960/cvme961/clock/Makefile.am (modified) * c/src/lib/libbsp/i960/cvme961/console/Makefile.am (modified) * c/src/lib/libbsp/i960/cvme961/include/Makefile.am (modified) * c/src/lib/libbsp/i960/cvme961/include/bsp.h (modified) * c/src/lib/libbsp/i960/cvme961/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/i960/cvme961/start/Makefile.am (modified) * c/src/lib/libbsp/i960/cvme961/startup/Makefile.am (modified) * c/src/lib/libbsp/i960/cvme961/startup/bspstart.c (modified) * c/src/lib/libbsp/i960/cvme961/timer/Makefile.am (modified) * c/src/lib/libbsp/i960/cvme961/wrapup/Makefile.am (modified) * c/src/lib/libbsp/i960/rxgen960/Makefile.am (modified) * c/src/lib/libbsp/i960/rxgen960/bsp_specs (modified) * c/src/lib/libbsp/i960/rxgen960/clock/Makefile.am (modified) * c/src/lib/libbsp/i960/rxgen960/console/Makefile.am (modified) * c/src/lib/libbsp/i960/rxgen960/include/Makefile.am (modified) * c/src/lib/libbsp/i960/rxgen960/include/bsp.h (modified) * c/src/lib/libbsp/i960/rxgen960/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/i960/rxgen960/startup/Makefile.am (modified) * c/src/lib/libbsp/i960/rxgen960/startup/bspstart.c (modified) * c/src/lib/libbsp/i960/rxgen960/timer/Makefile.am (modified) * c/src/lib/libbsp/i960/rxgen960/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/Makefile.am (modified) * c/src/lib/libbsp/m68k/dmv152/Makefile.am (modified) * c/src/lib/libbsp/m68k/dmv152/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/dmv152/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/dmv152/console/console.c (modified) * c/src/lib/libbsp/m68k/dmv152/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/dmv152/include/bsp.h (modified) * c/src/lib/libbsp/m68k/dmv152/spurious/Makefile.am (modified) * c/src/lib/libbsp/m68k/dmv152/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/dmv152/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/dmv152/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/dmv152/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/dmv152/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/dmv152/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi332/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi332/README (modified) * c/src/lib/libbsp/m68k/efi332/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi332/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi332/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi332/include/bsp.h (modified) * c/src/lib/libbsp/m68k/efi332/misc/dotests (modified) * c/src/lib/libbsp/m68k/efi332/misc/gdbinit68 (modified) * c/src/lib/libbsp/m68k/efi332/misc/interr.c (modified) * c/src/lib/libbsp/m68k/efi332/spurious/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi332/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi332/start/start.c (modified) * c/src/lib/libbsp/m68k/efi332/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi332/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/efi332/startup/except_vect_332_ROM.S (modified) * c/src/lib/libbsp/m68k/efi332/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/efi332/startup/linkcmds_ROM (modified) * c/src/lib/libbsp/m68k/efi332/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi332/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi68k/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi68k/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi68k/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi68k/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi68k/include/bsp.h (modified) * c/src/lib/libbsp/m68k/efi68k/spurious/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi68k/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi68k/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi68k/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/efi68k/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/efi68k/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi68k/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68302/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68302/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68302/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68302/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68302/include/bsp.h (modified) * c/src/lib/libbsp/m68k/gen68302/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68302/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68302/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/gen68302/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/gen68302/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68302/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/console/console.c (modified) * c/src/lib/libbsp/m68k/gen68340/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/include/bsp.h (modified) * c/src/lib/libbsp/m68k/gen68340/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/gen68340/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/gen68340/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/console/consolereserveresources.c (modified) * c/src/lib/libbsp/m68k/gen68360/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/include/bsp.h (modified) * c/src/lib/libbsp/m68k/gen68360/network/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/network/network.c (modified) * c/src/lib/libbsp/m68k/gen68360/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/start/start.S (modified) * c/src/lib/libbsp/m68k/gen68360/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/gen68360/startup/init68360.c (modified) * c/src/lib/libbsp/m68k/gen68360/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/gen68360/startup/linkcmds.bootp (modified) * c/src/lib/libbsp/m68k/gen68360/startup/linkcmds.prom (modified) * c/src/lib/libbsp/m68k/gen68360/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/idp/Makefile.am (modified) * c/src/lib/libbsp/m68k/idp/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/idp/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/idp/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/idp/include/bsp.h (modified) * c/src/lib/libbsp/m68k/idp/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/idp/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/idp/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/idp/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/idp/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/idp/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme136/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme136/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme136/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme147/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme147/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme147/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme147s/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme147s/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme147s/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/consolex/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme162/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme162/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme162/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/tod/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/tools/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/README (modified) * c/src/lib/libbsp/m68k/mvme167/bsp_specs (modified) * c/src/lib/libbsp/m68k/mvme167/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/configure.in (modified) * c/src/lib/libbsp/m68k/mvme167/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/console/console-recording.c (modified) * c/src/lib/libbsp/m68k/mvme167/console/console.c (modified) * c/src/lib/libbsp/m68k/mvme167/fatal/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme167/network/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/network/network.c (modified) * c/src/lib/libbsp/m68k/mvme167/network/uti596.h (modified) * c/src/lib/libbsp/m68k/mvme167/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme167/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme167/startup/page_table.c (modified) * c/src/lib/libbsp/m68k/mvme167/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/ods68302/Makefile.am (modified) * c/src/lib/libbsp/m68k/ods68302/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/ods68302/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/ods68302/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/ods68302/include/bsp.h (modified) * c/src/lib/libbsp/m68k/ods68302/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/ods68302/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/ods68302/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/ods68302/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/ods68302/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/ods68302/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/shared/m68kpretaskinghook.c (modified) * c/src/lib/libbsp/m68k/shared/start.S (modified) * c/src/lib/libbsp/mips/Makefile.am (modified) * c/src/lib/libbsp/mips/p4000/Makefile.am (modified) * c/src/lib/libbsp/mips/p4000/console/Makefile.am (modified) * c/src/lib/libbsp/mips/p4000/include/Makefile.am (modified) * c/src/lib/libbsp/mips/p4000/include/bsp.h (modified) * c/src/lib/libbsp/mips/p4000/liblnk/Makefile.am (modified) * c/src/lib/libbsp/mips/p4000/start/Makefile.am (modified) * c/src/lib/libbsp/mips/p4000/startup/Makefile.am (modified) * c/src/lib/libbsp/mips/p4000/startup/bspstart.c (modified) * c/src/lib/libbsp/mips/p4000/wrapup/Makefile.am (modified) * c/src/lib/libbsp/mips64orion/Makefile.am (modified) * c/src/lib/libbsp/mips64orion/p4000/Makefile.am (modified) * c/src/lib/libbsp/mips64orion/p4000/console/Makefile.am (modified) * c/src/lib/libbsp/mips64orion/p4000/include/Makefile.am (modified) * c/src/lib/libbsp/mips64orion/p4000/include/bsp.h (modified) * c/src/lib/libbsp/mips64orion/p4000/liblnk/Makefile.am (modified) * c/src/lib/libbsp/mips64orion/p4000/start/Makefile.am (modified) * c/src/lib/libbsp/mips64orion/p4000/startup/Makefile.am (modified) * c/src/lib/libbsp/mips64orion/p4000/startup/bspstart.c (modified) * c/src/lib/libbsp/mips64orion/p4000/wrapup/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/clock/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/console/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/include/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/include/bsp.h (modified) * c/src/lib/libbsp/no_cpu/no_bsp/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/bspstart.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/timer/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/wrapup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/bsp_specs (modified) * c/src/lib/libbsp/powerpc/dmv177/clock/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/console/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/include/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/dmv177/scv64/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/sonic/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/start/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/dmv177/timer/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/tod/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/wrapup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/eth_comm/Makefile.am (modified) * c/src/lib/libbsp/powerpc/eth_comm/bsp_specs (modified) * c/src/lib/libbsp/powerpc/eth_comm/canbus/Makefile.am (modified) * c/src/lib/libbsp/powerpc/eth_comm/console/Makefile.am (modified) * c/src/lib/libbsp/powerpc/eth_comm/include/Makefile.am (modified) * c/src/lib/libbsp/powerpc/eth_comm/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/eth_comm/network/Makefile.am (modified) * c/src/lib/libbsp/powerpc/eth_comm/start/Makefile.am (modified) * c/src/lib/libbsp/powerpc/eth_comm/start/start.S (modified) * c/src/lib/libbsp/powerpc/eth_comm/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/eth_comm/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/eth_comm/wrapup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/helas403/Makefile.am (modified) * c/src/lib/libbsp/powerpc/helas403/dlentry/Makefile.am (modified) * c/src/lib/libbsp/powerpc/helas403/flashentry/Makefile.am (modified) * c/src/lib/libbsp/powerpc/helas403/include/Makefile.am (modified) * c/src/lib/libbsp/powerpc/helas403/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/helas403/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/helas403/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/helas403/wrapup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/bsp_specs (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/clock/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/console/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/include/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/irq/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/motorola/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/openpic/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/pci/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/residual/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/start/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/vectors/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/wrapup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/papyrus/Makefile.am (modified) * c/src/lib/libbsp/powerpc/papyrus/dlentry/Makefile.am (modified) * c/src/lib/libbsp/powerpc/papyrus/flashentry/Makefile.am (modified) * c/src/lib/libbsp/powerpc/papyrus/include/Makefile.am (modified) * c/src/lib/libbsp/powerpc/papyrus/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/papyrus/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/papyrus/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/papyrus/wrapup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/bsp_specs (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/clock/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/console/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/console/console.c (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/include/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/network/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/nvram/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/pci/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/start/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/timer/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/tod/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/universe/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/vectors/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/wrapup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/bsp_specs (modified) * c/src/lib/libbsp/powerpc/psim/clock/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/console/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/console/console.c (modified) * c/src/lib/libbsp/powerpc/psim/include/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/psim/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/start/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/psim/timer/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/tools/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/tools/runtest (modified) * c/src/lib/libbsp/powerpc/psim/vectors/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/wrapup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/PCI_bus/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/bsp_specs (modified) * c/src/lib/libbsp/powerpc/score603e/clock/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/console/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/console/consolereserveresources.c (modified) * c/src/lib/libbsp/powerpc/score603e/include/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/score603e/start/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/score603e/timer/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/tod/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/vectors/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/wrapup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/bootloader/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/bootloader/misc.c (modified) * c/src/lib/libbsp/powerpc/shared/clock/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/console/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/console/console.c (modified) * c/src/lib/libbsp/powerpc/shared/include/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/shared/irq/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/irq/irq_asm.S (modified) * c/src/lib/libbsp/powerpc/shared/motorola/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/openpic/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/pci/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/residual/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/start/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/start/start.S (modified) * c/src/lib/libbsp/powerpc/shared/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/shared/vectors/Makefile.am (modified) * c/src/lib/libbsp/powerpc/support/new_exception_processing/Makefile.am (modified) * c/src/lib/libbsp/powerpc/support/old_exception_processing/Makefile.am (modified) * c/src/lib/libbsp/powerpc/support/old_exception_processing/irq_stub.S (modified) * c/src/lib/libbsp/sh/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/bsp_specs (modified) * c/src/lib/libbsp/sh/gensh1/console/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/include/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/include/bsp.h (modified) * c/src/lib/libbsp/sh/gensh1/scitab/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/start/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/startup/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/startup/bspstart.c (modified) * c/src/lib/libbsp/sh/gensh1/wrapup/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/README (modified) * c/src/lib/libbsp/sh/gensh2/bsp_specs (modified) * c/src/lib/libbsp/sh/gensh2/console/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/include/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/include/bsp.h (modified) * c/src/lib/libbsp/sh/gensh2/scitab/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/start/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/start/start.S (modified) * c/src/lib/libbsp/sh/gensh2/startup/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/startup/bspstart.c (modified) * c/src/lib/libbsp/sh/gensh2/startup/hw_init.c (modified) * c/src/lib/libbsp/sh/gensh2/wrapup/Makefile.am (modified) * c/src/lib/libbsp/sh/shared/Makefile.am (modified) * c/src/lib/libbsp/shared/console.c (modified) * c/src/lib/libbsp/shmdr/Makefile.am (modified) * c/src/lib/libbsp/sparc/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/clock/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/console/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/console/consolereserveresources.c (modified) * c/src/lib/libbsp/sparc/erc32/gnatsupp/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/include/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/include/bsp.h (modified) * c/src/lib/libbsp/sparc/erc32/start/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/startup/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/startup/bspstart.c (modified) * c/src/lib/libbsp/sparc/erc32/startup/linkcmds (modified) * c/src/lib/libbsp/sparc/erc32/startup/spurious.c (modified) * c/src/lib/libbsp/sparc/erc32/timer/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/tools/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/tools/runtest.in (modified) * c/src/lib/libbsp/sparc/erc32/wrapup/Makefile.am (modified) * c/src/lib/libbsp/unix/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/clock/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/configure.in (modified) * c/src/lib/libbsp/unix/posix/console/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/include/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/include/bsp.h (modified) * c/src/lib/libbsp/unix/posix/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/startup/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/startup/bspstart.c (modified) * c/src/lib/libbsp/unix/posix/timer/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/tools/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/wrapup/Makefile.am (modified) * c/src/lib/libc/Makefile.am (modified) * c/src/lib/libc/error.h (modified) * c/src/lib/libc/gxx_wrappers.c (modified) * c/src/lib/libc/imfs.h (modified) * c/src/lib/libc/imfs_creat.c (modified) * c/src/lib/libc/imfs_directory.c (modified) * c/src/lib/libc/imfs_stat.c (modified) * c/src/lib/libc/imfs_utime.c (modified) * c/src/lib/libc/libio.c (modified) * c/src/lib/libc/malloc.c (modified) * c/src/lib/libc/scandir.c (modified) * c/src/lib/libc/termios.c (modified) * c/src/lib/libc/termiosreserveresources.c (modified) * c/src/lib/libc/unmount.c (modified) * c/src/lib/libcpu/Makefile.am (modified) * c/src/lib/libcpu/a29k/Makefile.am (modified) * c/src/lib/libcpu/a29k/clock/Makefile.am (modified) * c/src/lib/libcpu/a29k/timer/Makefile.am (modified) * c/src/lib/libcpu/hppa1.1/Makefile.am (modified) * c/src/lib/libcpu/hppa1.1/clock/Makefile.am (modified) * c/src/lib/libcpu/hppa1.1/include/Makefile.am (modified) * c/src/lib/libcpu/hppa1.1/milli/Makefile.am (modified) * c/src/lib/libcpu/hppa1.1/semaphore/Makefile.am (modified) * c/src/lib/libcpu/hppa1.1/timer/Makefile.am (modified) * c/src/lib/libcpu/i386/Makefile.am (modified) * c/src/lib/libcpu/m68k/Makefile.am (modified) * c/src/lib/libcpu/m68k/m68040/Makefile.am (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/Makefile.am (modified) * c/src/lib/libcpu/mips/Makefile.am (modified) * c/src/lib/libcpu/mips/clock/Makefile.am (modified) * c/src/lib/libcpu/mips/timer/Makefile.am (modified) * c/src/lib/libcpu/mips64orion/Makefile.am (modified) * c/src/lib/libcpu/mips64orion/clock/Makefile.am (modified) * c/src/lib/libcpu/mips64orion/timer/Makefile.am (modified) * c/src/lib/libcpu/powerpc/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc505/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc505/timer/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc505/vectors/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc6xx/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc6xx/clock/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc6xx/exceptions/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc6xx/mmu/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc6xx/timer/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc6xx/wrapup/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc821/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc821/clock/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc821/console-generic/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc821/console-generic/console-generic.c (modified) * c/src/lib/libcpu/powerpc/mpc821/include/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc821/timer/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc821/vectors/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc860/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc860/clock/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc860/console-generic/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc860/console-generic/console-generic.c (modified) * c/src/lib/libcpu/powerpc/mpc860/include/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc860/include/mpc860.h (modified) * c/src/lib/libcpu/powerpc/mpc860/timer/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc860/vectors/Makefile.am (modified) * c/src/lib/libcpu/powerpc/new_exception_processing/Makefile.am (modified) * c/src/lib/libcpu/powerpc/old-exceptions/irq_stub.S (modified) * c/src/lib/libcpu/powerpc/old_exception_processing/Makefile.am (modified) * c/src/lib/libcpu/powerpc/old_exception_processing/irq_stub.S (modified) * c/src/lib/libcpu/powerpc/ppc403/Makefile.am (modified) * c/src/lib/libcpu/powerpc/ppc403/clock/Makefile.am (modified) * c/src/lib/libcpu/powerpc/ppc403/console/Makefile.am (modified) * c/src/lib/libcpu/powerpc/ppc403/console/console.c (modified) * c/src/lib/libcpu/powerpc/ppc403/ictrl/Makefile.am (modified) * c/src/lib/libcpu/powerpc/ppc403/timer/Makefile.am (modified) * c/src/lib/libcpu/powerpc/ppc403/vectors/Makefile.am (modified) * c/src/lib/libcpu/powerpc/shared/Makefile.am (modified) * c/src/lib/libcpu/powerpc/wrapup/Makefile.am (modified) * c/src/lib/libcpu/sh/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7032/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7032/clock/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7032/delay/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7032/include/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7032/null/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7032/sci/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7032/timer/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7045/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7045/clock/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7045/include/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7045/null/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7045/sci/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7045/sci/sci.c (modified) * c/src/lib/libcpu/sh/sh7045/timer/Makefile.am (modified) * c/src/lib/libcpu/sparc/Makefile.am (modified) * c/src/lib/libcpu/sparc/reg_win/Makefile.am (modified) * c/src/lib/libcpu/sparc/syscall/Makefile.am (modified) * c/src/libchip/network/Makefile.am (modified) * c/src/libchip/network/README.dec21140 (modified) * c/src/libchip/network/dec21140.c (modified) * c/src/libchip/rtc/Makefile.am (modified) * c/src/libchip/serial/Makefile.am (modified) * c/src/libchip/serial/README.ns16550 (modified) * c/src/libchip/serial/STATUS (modified) * c/src/libchip/serial/ns16550.c (modified) * c/src/libchip/serial/ns16550_p.h (modified) * c/src/libfs/src/imfs/imfs.h (modified) * c/src/libfs/src/imfs/imfs_creat.c (modified) * c/src/libfs/src/imfs/imfs_directory.c (modified) * c/src/libfs/src/imfs/imfs_stat.c (modified) * c/src/libfs/src/imfs/imfs_utime.c (modified) * c/src/libmisc/cpuuse/Makefile.am (modified) * c/src/libmisc/dummy/Makefile.am (modified) * c/src/libmisc/dummy/dummy.c (modified) * c/src/libmisc/dumpbuf/Makefile.am (modified) * c/src/libmisc/monitor/Makefile.am (modified) * c/src/libmisc/monitor/mon-server.c (modified) * c/src/libmisc/rtmonuse/Makefile.am (modified) * c/src/libmisc/stackchk/Makefile.am (modified) * c/src/libmisc/stackchk/internal.h (modified) * c/src/libmisc/untar/Makefile.am (modified) * c/src/libmisc/wrapup/Makefile.am (modified) * c/src/libnetworking/Makefile.am (modified) * c/src/libnetworking/arpa/Makefile.am (modified) * c/src/libnetworking/include/Makefile.am (modified) * c/src/libnetworking/kern/Makefile.am (modified) * c/src/libnetworking/lib/Makefile.am (modified) * c/src/libnetworking/lib/rtems_bsdnet_ntp.c (modified) * c/src/libnetworking/libc/Makefile.am (modified) * c/src/libnetworking/machine/Makefile.am (modified) * c/src/libnetworking/memory.h (modified) * c/src/libnetworking/net/Makefile.am (modified) * c/src/libnetworking/net/if_loop.c (modified) * c/src/libnetworking/netinet/Makefile.am (modified) * c/src/libnetworking/netinet/in.h (modified) * c/src/libnetworking/nfs/Makefile.am (modified) * c/src/libnetworking/pppd/Makefile.am (modified) * c/src/libnetworking/pppd/options.c (modified) * c/src/libnetworking/pppd/pppd.h (modified) * c/src/libnetworking/pppd/rtems-ppp.c (modified) * c/src/libnetworking/rtems/Makefile.am (modified) * c/src/libnetworking/rtems/rtems_syscall.c (modified) * c/src/libnetworking/rtems_servers/Makefile.am (modified) * c/src/libnetworking/rtems_servers/ftpd.c (modified) * c/src/libnetworking/rtems_webserver/Makefile.am (modified) * c/src/libnetworking/rtems_webserver/balloc.c (modified) * c/src/libnetworking/rtems_webserver/ejlex.c (modified) * c/src/libnetworking/rtems_webserver/handler.c (modified) * c/src/libnetworking/rtems_webserver/uemf.c (modified) * c/src/libnetworking/rtems_webserver/uemf.h (modified) * c/src/libnetworking/rtems_webserver/webs.c (modified) * c/src/libnetworking/sys/Makefile.am (modified) * c/src/libnetworking/sys/un.h (modified) * c/src/libnetworking/vm/Makefile.am (modified) * c/src/libnetworking/wrapup/Makefile.am (modified) * c/src/librdbg/include/rdbg/Makefile.am (modified) * c/src/librdbg/include/rdbg/i386/Makefile.am (modified) * c/src/librdbg/include/rdbg/powerpc/Makefile.am (modified) * c/src/librdbg/src/Makefile.am (modified) * c/src/librdbg/src/i386/Makefile.am (modified) * c/src/librdbg/src/i386/any/Makefile.am (modified) * c/src/librdbg/src/powerpc/Makefile.am (modified) * c/src/librdbg/src/powerpc/mcp750/Makefile.am (modified) * c/src/librdbg/src/powerpc/new_exception_processing/Makefile.am (modified) * c/src/librpc/Makefile.am (modified) * c/src/librpc/README_RTEMS (modified) * c/src/librpc/configure.in (modified) * c/src/librpc/include/Makefile.am (modified) * c/src/librpc/include/rpc/Makefile.am (modified) * c/src/librpc/include/rpc/auth.h (modified) * c/src/librpc/include/rpc/auth_des.h (modified) * c/src/librpc/include/rpc/auth_unix.h (modified) * c/src/librpc/include/rpc/clnt.h (modified) * c/src/librpc/include/rpc/des.h (modified) * c/src/librpc/include/rpc/des_crypt.h (modified) * c/src/librpc/include/rpc/pmap_clnt.h (modified) * c/src/librpc/include/rpc/pmap_prot.h (modified) * c/src/librpc/include/rpc/pmap_rmt.h (modified) * c/src/librpc/include/rpc/rpc.h (modified) * c/src/librpc/include/rpc/rpc_com.h (modified) * c/src/librpc/include/rpc/rpc_msg.h (modified) * c/src/librpc/include/rpc/svc.h (modified) * c/src/librpc/include/rpc/svc_auth.h (modified) * c/src/librpc/include/rpc/types.h (modified) * c/src/librpc/include/rpc/xdr.h (modified) * c/src/librpc/include/rpcsvc/.cvsignore (modified) * c/src/librpc/include/rpcsvc/Makefile.am (modified) * c/src/librpc/include/rpcsvc/bootparam_prot.x (modified) * c/src/librpc/include/rpcsvc/crypt.x (modified) * c/src/librpc/include/rpcsvc/key_prot.x (modified) * c/src/librpc/include/rpcsvc/klm_prot.x (modified) * c/src/librpc/include/rpcsvc/mount.x (modified) * c/src/librpc/include/rpcsvc/nfs_prot.x (modified) * c/src/librpc/include/rpcsvc/nis.x (modified) * c/src/librpc/include/rpcsvc/nis_cache.x (modified) * c/src/librpc/include/rpcsvc/nis_callback.x (modified) * c/src/librpc/include/rpcsvc/nis_db.h (modified) * c/src/librpc/include/rpcsvc/nis_object.x (modified) * c/src/librpc/include/rpcsvc/nis_tags.h (modified) * c/src/librpc/include/rpcsvc/nislib.h (modified) * c/src/librpc/include/rpcsvc/nlm_prot.x (modified) * c/src/librpc/include/rpcsvc/pmap_prot.x (modified) * c/src/librpc/include/rpcsvc/rex.x (modified) * c/src/librpc/include/rpcsvc/rnusers.x (modified) * c/src/librpc/include/rpcsvc/rquota.x (modified) * c/src/librpc/include/rpcsvc/rstat.x (modified) * c/src/librpc/include/rpcsvc/rwall.x (modified) * c/src/librpc/include/rpcsvc/sm_inter.x (modified) * c/src/librpc/include/rpcsvc/spray.x (modified) * c/src/librpc/include/rpcsvc/yp.x (modified) * c/src/librpc/include/rpcsvc/yp_prot.h (modified) * c/src/librpc/include/rpcsvc/ypclnt.h (modified) * c/src/librpc/include/rpcsvc/yppasswd.x (modified) * c/src/librpc/include/rpcsvc/ypupdate_prot.x (modified) * c/src/librpc/include/rpcsvc/ypxfrd.x (modified) * c/src/librpc/src/Makefile.am (modified) * c/src/librpc/src/rpc/DISCLAIMER (modified) * c/src/librpc/src/rpc/Makefile.am (modified) * c/src/librpc/src/rpc/PSD.doc/.cvsignore (modified) * c/src/librpc/src/rpc/PSD.doc/Makefile.am (modified) * c/src/librpc/src/rpc/PSD.doc/nfs.rfc.ms (modified) * c/src/librpc/src/rpc/PSD.doc/rpc.prog.ms (modified) * c/src/librpc/src/rpc/PSD.doc/rpc.rfc.ms (modified) * c/src/librpc/src/rpc/PSD.doc/rpcgen.ms (modified) * c/src/librpc/src/rpc/PSD.doc/xdr.nts.ms (modified) * c/src/librpc/src/rpc/PSD.doc/xdr.rfc.ms (modified) * c/src/librpc/src/rpc/README (modified) * c/src/librpc/src/rpc/auth_des.c (modified) * c/src/librpc/src/rpc/auth_none.c (modified) * c/src/librpc/src/rpc/auth_time.c (modified) * c/src/librpc/src/rpc/auth_unix.c (modified) * c/src/librpc/src/rpc/authdes_prot.c (modified) * c/src/librpc/src/rpc/authunix_prot.c (modified) * c/src/librpc/src/rpc/bindresvport.3 (modified) * c/src/librpc/src/rpc/bindresvport.c (modified) * c/src/librpc/src/rpc/clnt_generic.c (modified) * c/src/librpc/src/rpc/clnt_perror.c (modified) * c/src/librpc/src/rpc/clnt_raw.c (modified) * c/src/librpc/src/rpc/clnt_simple.c (modified) * c/src/librpc/src/rpc/clnt_tcp.c (modified) * c/src/librpc/src/rpc/clnt_udp.c (modified) * c/src/librpc/src/rpc/clnt_unix.c (modified) * c/src/librpc/src/rpc/crypt_client.c (modified) * c/src/librpc/src/rpc/des_crypt.3 (modified) * c/src/librpc/src/rpc/des_crypt.c (modified) * c/src/librpc/src/rpc/des_soft.c (modified) * c/src/librpc/src/rpc/get_myaddress.c (modified) * c/src/librpc/src/rpc/getpublickey.c (modified) * c/src/librpc/src/rpc/getrpcent.3 (modified) * c/src/librpc/src/rpc/getrpcent.c (modified) * c/src/librpc/src/rpc/getrpcport.3 (modified) * c/src/librpc/src/rpc/getrpcport.c (modified) * c/src/librpc/src/rpc/key_call.c (modified) * c/src/librpc/src/rpc/key_prot_xdr.c (modified) * c/src/librpc/src/rpc/netname.c (modified) * c/src/librpc/src/rpc/netnamer.c (modified) * c/src/librpc/src/rpc/pmap_clnt.c (modified) * c/src/librpc/src/rpc/pmap_getmaps.c (modified) * c/src/librpc/src/rpc/pmap_getport.c (modified) * c/src/librpc/src/rpc/pmap_prot.c (modified) * c/src/librpc/src/rpc/pmap_prot2.c (modified) * c/src/librpc/src/rpc/pmap_rmt.c (modified) * c/src/librpc/src/rpc/publickey.3 (modified) * c/src/librpc/src/rpc/publickey.5 (modified) * c/src/librpc/src/rpc/rpc.3 (modified) * c/src/librpc/src/rpc/rpc.5 (modified) * c/src/librpc/src/rpc/rpc_callmsg.c (modified) * c/src/librpc/src/rpc/rpc_commondata.c (modified) * c/src/librpc/src/rpc/rpc_dtablesize.c (modified) * c/src/librpc/src/rpc/rpc_prot.c (modified) * c/src/librpc/src/rpc/rpc_secure.3 (modified) * c/src/librpc/src/rpc/rpcdname.c (modified) * c/src/librpc/src/rpc/rstat.1 (modified) * c/src/librpc/src/rpc/rstat_svc.8 (modified) * c/src/librpc/src/rpc/rtems_portmapper.c (modified) * c/src/librpc/src/rpc/rtems_rpc.c (modified) * c/src/librpc/src/rpc/rtime.3 (modified) * c/src/librpc/src/rpc/rtime.c (modified) * c/src/librpc/src/rpc/svc.c (modified) * c/src/librpc/src/rpc/svc_auth.c (modified) * c/src/librpc/src/rpc/svc_auth_des.c (modified) * c/src/librpc/src/rpc/svc_auth_unix.c (modified) * c/src/librpc/src/rpc/svc_raw.c (modified) * c/src/librpc/src/rpc/svc_run.c (modified) * c/src/librpc/src/rpc/svc_simple.c (modified) * c/src/librpc/src/rpc/svc_tcp.c (modified) * c/src/librpc/src/rpc/svc_udp.c (modified) * c/src/librpc/src/rpc/svc_unix.c (modified) * c/src/librpc/src/rpc_callmsg.c (deleted) * c/src/librpc/src/rpc_prot.c (deleted) * c/src/librpc/src/svc.c (deleted) * c/src/librpc/src/svc_auth.c (deleted) * c/src/librpc/src/svc_udp.c (deleted) * c/src/librpc/src/xdr.c (deleted) * c/src/librpc/src/xdr/Makefile.am (modified) * c/src/librpc/src/xdr/xdr.3 (modified) * c/src/librpc/src/xdr/xdr.c (modified) * c/src/librpc/src/xdr/xdr_array.c (modified) * c/src/librpc/src/xdr/xdr_float.c (modified) * c/src/librpc/src/xdr/xdr_mem.c (modified) * c/src/librpc/src/xdr/xdr_rec.c (modified) * c/src/librpc/src/xdr/xdr_reference.c (modified) * c/src/librpc/src/xdr/xdr_sizeof.c (modified) * c/src/librpc/src/xdr/xdr_stdio.c (modified) * c/src/librpc/src/xdr_array.c (deleted) * c/src/librpc/src/xdr_mem.c (deleted) * c/src/librtems++/include/rtems++/Makefile.am (modified) * c/src/librtems++/src/Makefile.am (modified) * c/src/make/Makefile.am (modified) * c/src/make/README (modified) * c/src/make/compilers/Makefile.am (modified) * c/src/make/compilers/gcc-target-default.cfg (modified) * c/src/make/configure.in (modified) * c/src/make/custom/Makefile.am (modified) * c/src/make/host.cfg.in (modified) * c/src/make/leaf.cfg (modified) * c/src/make/main.cfg.in (modified) * c/src/optman/rtems/Makefile.am (modified) * c/src/optman/rtems/no-mp.c (modified) * c/src/optman/sapi/Makefile.am (modified) * c/src/tests/itrontests/itronhello/Makefile.am (modified) * c/src/tests/itrontests/itronhello/system.h (modified) * c/src/tests/itrontests/itronmbf01/Makefile.am (modified) * c/src/tests/itrontests/itronmbf01/system.h (modified) * c/src/tests/itrontests/itronmbox01/Makefile.am (modified) * c/src/tests/itrontests/itronmbox01/itronmbox01.scn (modified) * c/src/tests/itrontests/itronmbox01/system.h (modified) * c/src/tests/itrontests/itronsem01/Makefile.am (modified) * c/src/tests/itrontests/itronsem01/init.c (modified) * c/src/tests/itrontests/itronsem01/system.h (modified) * c/src/tests/itrontests/itrontask01/Makefile.am (modified) * c/src/tests/itrontests/itrontask01/system.h (modified) * c/src/tests/itrontests/itrontask02/Makefile.am (modified) * c/src/tests/itrontests/itrontask02/system.h (modified) * c/src/tests/itrontests/itrontask03/Makefile.am (modified) * c/src/tests/itrontests/itrontask03/system.h (modified) * c/src/tests/itrontests/itrontask04/Makefile.am (modified) * c/src/tests/itrontests/itrontask04/system.h (modified) * c/src/tests/itrontests/itrontime01/Makefile.am (modified) * c/src/tests/itrontests/itrontime01/itrontime01.scn (modified) * c/src/tests/itrontests/itrontime01/system.h (modified) * c/src/tests/libtests/cpuuse/Makefile.am (modified) * c/src/tests/libtests/cpuuse/cpuuse.scn (modified) * c/src/tests/libtests/cpuuse/system.h (modified) * c/src/tests/libtests/cpuuse/task2.c (modified) * c/src/tests/libtests/cpuuse/tswitch.c (modified) * c/src/tests/libtests/malloctest/Makefile.am (modified) * c/src/tests/libtests/malloctest/malloctest.scn (modified) * c/src/tests/libtests/malloctest/system.h (modified) * c/src/tests/libtests/monitor/Makefile.am (modified) * c/src/tests/libtests/monitor/system.h (modified) * c/src/tests/libtests/putenvtest/Makefile.am (modified) * c/src/tests/libtests/putenvtest/init.c (modified) * c/src/tests/libtests/rtems++/Makefile.am (modified) * c/src/tests/libtests/rtems++/System.h (modified) * c/src/tests/libtests/rtmonuse/Makefile.am (modified) * c/src/tests/libtests/rtmonuse/system.h (modified) * c/src/tests/libtests/stackchk/Makefile.am (modified) * c/src/tests/libtests/stackchk/system.h (modified) * c/src/tests/libtests/termios/Makefile.am (modified) * c/src/tests/libtests/termios/README (modified) * c/src/tests/libtests/termios/init.c (modified) * c/src/tests/mptests/mp01/node1/Makefile.am (modified) * c/src/tests/mptests/mp01/node2/Makefile.am (modified) * c/src/tests/mptests/mp01/system.h (modified) * c/src/tests/mptests/mp02/node1/Makefile.am (modified) * c/src/tests/mptests/mp02/node2/Makefile.am (modified) * c/src/tests/mptests/mp02/system.h (modified) * c/src/tests/mptests/mp03/node1/Makefile.am (modified) * c/src/tests/mptests/mp03/node2/Makefile.am (modified) * c/src/tests/mptests/mp03/system.h (modified) * c/src/tests/mptests/mp04/node1/Makefile.am (modified) * c/src/tests/mptests/mp04/node2/Makefile.am (modified) * c/src/tests/mptests/mp04/system.h (modified) * c/src/tests/mptests/mp05/node1/Makefile.am (modified) * c/src/tests/mptests/mp05/node2/Makefile.am (modified) * c/src/tests/mptests/mp05/system.h (modified) * c/src/tests/mptests/mp06/node1/Makefile.am (modified) * c/src/tests/mptests/mp06/node2/Makefile.am (modified) * c/src/tests/mptests/mp06/system.h (modified) * c/src/tests/mptests/mp07/node1/Makefile.am (modified) * c/src/tests/mptests/mp07/node2/Makefile.am (modified) * c/src/tests/mptests/mp07/system.h (modified) * c/src/tests/mptests/mp08/node1/Makefile.am (modified) * c/src/tests/mptests/mp08/node2/Makefile.am (modified) * c/src/tests/mptests/mp08/system.h (modified) * c/src/tests/mptests/mp09/node1/Makefile.am (modified) * c/src/tests/mptests/mp09/node2/Makefile.am (modified) * c/src/tests/mptests/mp09/system.h (modified) * c/src/tests/mptests/mp10/node1/Makefile.am (modified) * c/src/tests/mptests/mp10/node2/Makefile.am (modified) * c/src/tests/mptests/mp10/system.h (modified) * c/src/tests/mptests/mp11/node1/Makefile.am (modified) * c/src/tests/mptests/mp11/node2/Makefile.am (modified) * c/src/tests/mptests/mp11/system.h (modified) * c/src/tests/mptests/mp12/node1/Makefile.am (modified) * c/src/tests/mptests/mp12/node2/Makefile.am (modified) * c/src/tests/mptests/mp12/system.h (modified) * c/src/tests/mptests/mp13/node1/Makefile.am (modified) * c/src/tests/mptests/mp13/node2/Makefile.am (modified) * c/src/tests/mptests/mp13/system.h (modified) * c/src/tests/mptests/mp14/Makefile.am (modified) * c/src/tests/mptests/mp14/node1/Makefile.am (modified) * c/src/tests/mptests/mp14/node2/Makefile.am (modified) * c/src/tests/mptests/mp14/system.h (modified) * c/src/tests/psxtests/Makefile.am (modified) * c/src/tests/psxtests/psx01/Makefile.am (modified) * c/src/tests/psxtests/psx01/psx01.scn (modified) * c/src/tests/psxtests/psx01/system.h (modified) * c/src/tests/psxtests/psx02/Makefile.am (modified) * c/src/tests/psxtests/psx02/system.h (modified) * c/src/tests/psxtests/psx03/Makefile.am (modified) * c/src/tests/psxtests/psx03/system.h (modified) * c/src/tests/psxtests/psx04/Makefile.am (modified) * c/src/tests/psxtests/psx04/system.h (modified) * c/src/tests/psxtests/psx05/Makefile.am (modified) * c/src/tests/psxtests/psx05/system.h (modified) * c/src/tests/psxtests/psx06/Makefile.am (modified) * c/src/tests/psxtests/psx06/system.h (modified) * c/src/tests/psxtests/psx07/Makefile.am (modified) * c/src/tests/psxtests/psx07/system.h (modified) * c/src/tests/psxtests/psx08/Makefile.am (modified) * c/src/tests/psxtests/psx08/system.h (modified) * c/src/tests/psxtests/psx09/Makefile.am (modified) * c/src/tests/psxtests/psx09/system.h (modified) * c/src/tests/psxtests/psx10/Makefile.am (modified) * c/src/tests/psxtests/psx10/system.h (modified) * c/src/tests/psxtests/psx11/Makefile.am (modified) * c/src/tests/psxtests/psx11/system.h (modified) * c/src/tests/psxtests/psx12/Makefile.am (modified) * c/src/tests/psxtests/psx12/system.h (modified) * c/src/tests/psxtests/psx13/Makefile.am (modified) * c/src/tests/psxtests/psx13/main.c (modified) * c/src/tests/psxtests/psxcancel/Makefile.am (modified) * c/src/tests/psxtests/psxcancel/system.h (modified) * c/src/tests/psxtests/psxfile01/Makefile.am (modified) * c/src/tests/psxtests/psxfile01/main.c (modified) * c/src/tests/psxtests/psxfile01/psxfile01.scn (modified) * c/src/tests/psxtests/psxfile01/test.c (modified) * c/src/tests/psxtests/psxhdrs/Makefile.am (modified) * c/src/tests/psxtests/psxmount/Makefile.am (modified) * c/src/tests/psxtests/psxmount/main.c (modified) * c/src/tests/psxtests/psxmsgq01/Makefile.am (modified) * c/src/tests/psxtests/psxmsgq01/system.h (modified) * c/src/tests/psxtests/psxreaddir/Makefile.am (modified) * c/src/tests/psxtests/psxreaddir/main.c (modified) * c/src/tests/psxtests/psxsem01/Makefile.am (modified) * c/src/tests/psxtests/psxsem01/system.h (modified) * c/src/tests/psxtests/psxstat/Makefile.am (modified) * c/src/tests/psxtests/psxstat/main.c (modified) * c/src/tests/psxtests/psxstat/test.c (modified) * c/src/tests/psxtests/psxtime/Makefile.am (modified) * c/src/tests/psxtests/psxtime/main.c (modified) * c/src/tests/psxtests/psxtimer/Makefile.am (modified) * c/src/tests/psxtests/psxtimer/system.h (modified) * c/src/tests/samples/Makefile.am (modified) * c/src/tests/samples/base_mp/apptask.c (modified) * c/src/tests/samples/base_mp/init.c (modified) * c/src/tests/samples/base_mp/system.h (modified) * c/src/tests/samples/base_sp/apptask.c (modified) * c/src/tests/samples/base_sp/init.c (modified) * c/src/tests/samples/base_sp/system.h (modified) * c/src/tests/samples/cdtest/Makefile.am (modified) * c/src/tests/samples/cdtest/init.c (modified) * c/src/tests/samples/cdtest/system.h (modified) * c/src/tests/samples/hello/Makefile.am (modified) * c/src/tests/samples/hello/init.c (modified) * c/src/tests/samples/hello/system.h (modified) * c/src/tests/samples/minimum/Makefile.am (modified) * c/src/tests/samples/minimum/init.c (modified) * c/src/tests/samples/paranoia/Makefile.am (modified) * c/src/tests/samples/paranoia/init.c (modified) * c/src/tests/samples/paranoia/system.h (modified) * c/src/tests/samples/ticker/Makefile.am (modified) * c/src/tests/samples/ticker/init.c (modified) * c/src/tests/samples/ticker/system.h (modified) * c/src/tests/samples/ticker/tasks.c (modified) * c/src/tests/samples/unlimited/Makefile.am (modified) * c/src/tests/samples/unlimited/init.c (modified) * c/src/tests/samples/unlimited/system.h (modified) * c/src/tests/sptests/sp01/Makefile.am (modified) * c/src/tests/sptests/sp01/system.h (modified) * c/src/tests/sptests/sp02/Makefile.am (modified) * c/src/tests/sptests/sp02/system.h (modified) * c/src/tests/sptests/sp03/Makefile.am (modified) * c/src/tests/sptests/sp03/system.h (modified) * c/src/tests/sptests/sp04/Makefile.am (modified) * c/src/tests/sptests/sp04/system.h (modified) * c/src/tests/sptests/sp04/tswitch.c (modified) * c/src/tests/sptests/sp05/Makefile.am (modified) * c/src/tests/sptests/sp05/system.h (modified) * c/src/tests/sptests/sp06/Makefile.am (modified) * c/src/tests/sptests/sp06/system.h (modified) * c/src/tests/sptests/sp07/Makefile.am (modified) * c/src/tests/sptests/sp07/system.h (modified) * c/src/tests/sptests/sp08/Makefile.am (modified) * c/src/tests/sptests/sp08/system.h (modified) * c/src/tests/sptests/sp09/Makefile.am (modified) * c/src/tests/sptests/sp09/screen07.c (modified) * c/src/tests/sptests/sp09/screen08.c (modified) * c/src/tests/sptests/sp09/system.h (modified) * c/src/tests/sptests/sp11/Makefile.am (modified) * c/src/tests/sptests/sp11/system.h (modified) * c/src/tests/sptests/sp12/Makefile.am (modified) * c/src/tests/sptests/sp12/system.h (modified) * c/src/tests/sptests/sp13/Makefile.am (modified) * c/src/tests/sptests/sp13/fillbuff.c (modified) * c/src/tests/sptests/sp13/init.c (modified) * c/src/tests/sptests/sp13/putbuff.c (modified) * c/src/tests/sptests/sp13/system.h (modified) * c/src/tests/sptests/sp13/task1.c (modified) * c/src/tests/sptests/sp13/task2.c (modified) * c/src/tests/sptests/sp14/Makefile.am (modified) * c/src/tests/sptests/sp14/system.h (modified) * c/src/tests/sptests/sp15/Makefile.am (modified) * c/src/tests/sptests/sp15/system.h (modified) * c/src/tests/sptests/sp16/Makefile.am (modified) * c/src/tests/sptests/sp16/system.h (modified) * c/src/tests/sptests/sp17/Makefile.am (modified) * c/src/tests/sptests/sp17/system.h (modified) * c/src/tests/sptests/sp19/Makefile.am (modified) * c/src/tests/sptests/sp19/system.h (modified) * c/src/tests/sptests/sp20/Makefile.am (modified) * c/src/tests/sptests/sp20/system.h (modified) * c/src/tests/sptests/sp21/Makefile.am (modified) * c/src/tests/sptests/sp21/system.h (modified) * c/src/tests/sptests/sp22/Makefile.am (modified) * c/src/tests/sptests/sp22/system.h (modified) * c/src/tests/sptests/sp23/Makefile.am (modified) * c/src/tests/sptests/sp23/system.h (modified) * c/src/tests/sptests/sp24/Makefile.am (modified) * c/src/tests/sptests/sp24/system.h (modified) * c/src/tests/sptests/sp25/Makefile.am (modified) * c/src/tests/sptests/sp25/sp25.scn (modified) * c/src/tests/sptests/sp25/system.h (modified) * c/src/tests/sptests/sp26/Makefile.am (modified) * c/src/tests/sptests/sp26/system.h (modified) * c/src/tests/sptests/sp27/Makefile.am (modified) * c/src/tests/sptests/sp27/init.c (modified) * c/src/tests/sptests/sp28/Makefile.am (modified) * c/src/tests/sptests/sp28/init.c (modified) * c/src/tests/sptests/sp29/Makefile.am (modified) * c/src/tests/sptests/sp29/init.c (modified) * c/src/tests/sptests/spfatal/Makefile.am (modified) * c/src/tests/sptests/spfatal/system.h (modified) * c/src/tests/sptests/spsize/Makefile.am (modified) * c/src/tests/sptests/spsize/system.h (modified) * c/src/tests/support/include/Makefile.am (modified) * c/src/tests/support/stubdr/Makefile.am (modified) * c/src/tests/support/wrapup/Makefile.am (modified) * c/src/tests/tmitrontests/tmitronsem01/Makefile.am (modified) * c/src/tests/tmitrontests/tmitronsem01/system.h (modified) * c/src/tests/tmtests/Makefile.am (modified) * c/src/tests/tmtests/tm01/Makefile.am (modified) * c/src/tests/tmtests/tm01/system.h (modified) * c/src/tests/tmtests/tm02/Makefile.am (modified) * c/src/tests/tmtests/tm02/system.h (modified) * c/src/tests/tmtests/tm03/Makefile.am (modified) * c/src/tests/tmtests/tm03/system.h (modified) * c/src/tests/tmtests/tm04/Makefile.am (modified) * c/src/tests/tmtests/tm04/system.h (modified) * c/src/tests/tmtests/tm05/Makefile.am (modified) * c/src/tests/tmtests/tm05/system.h (modified) * c/src/tests/tmtests/tm06/Makefile.am (modified) * c/src/tests/tmtests/tm06/system.h (modified) * c/src/tests/tmtests/tm07/Makefile.am (modified) * c/src/tests/tmtests/tm07/system.h (modified) * c/src/tests/tmtests/tm08/Makefile.am (modified) * c/src/tests/tmtests/tm08/system.h (modified) * c/src/tests/tmtests/tm09/Makefile.am (modified) * c/src/tests/tmtests/tm09/system.h (modified) * c/src/tests/tmtests/tm09/task1.c (modified) * c/src/tests/tmtests/tm10/Makefile.am (modified) * c/src/tests/tmtests/tm10/system.h (modified) * c/src/tests/tmtests/tm11/Makefile.am (modified) * c/src/tests/tmtests/tm11/system.h (modified) * c/src/tests/tmtests/tm11/task1.c (modified) * c/src/tests/tmtests/tm12/Makefile.am (modified) * c/src/tests/tmtests/tm12/system.h (modified) * c/src/tests/tmtests/tm12/task1.c (modified) * c/src/tests/tmtests/tm13/Makefile.am (modified) * c/src/tests/tmtests/tm13/system.h (modified) * c/src/tests/tmtests/tm13/task1.c (modified) * c/src/tests/tmtests/tm14/Makefile.am (modified) * c/src/tests/tmtests/tm14/system.h (modified) * c/src/tests/tmtests/tm14/task1.c (modified) * c/src/tests/tmtests/tm15/Makefile.am (modified) * c/src/tests/tmtests/tm15/system.h (modified) * c/src/tests/tmtests/tm16/Makefile.am (modified) * c/src/tests/tmtests/tm16/system.h (modified) * c/src/tests/tmtests/tm17/Makefile.am (modified) * c/src/tests/tmtests/tm17/system.h (modified) * c/src/tests/tmtests/tm18/Makefile.am (modified) * c/src/tests/tmtests/tm18/system.h (modified) * c/src/tests/tmtests/tm19/Makefile.am (modified) * c/src/tests/tmtests/tm19/system.h (modified) * c/src/tests/tmtests/tm20/Makefile.am (modified) * c/src/tests/tmtests/tm20/system.h (modified) * c/src/tests/tmtests/tm21/Makefile.am (modified) * c/src/tests/tmtests/tm21/system.h (modified) * c/src/tests/tmtests/tm21/task1.c (modified) * c/src/tests/tmtests/tm22/Makefile.am (modified) * c/src/tests/tmtests/tm22/system.h (modified) * c/src/tests/tmtests/tm22/task1.c (modified) * c/src/tests/tmtests/tm23/Makefile.am (modified) * c/src/tests/tmtests/tm23/system.h (modified) * c/src/tests/tmtests/tm24/Makefile.am (modified) * c/src/tests/tmtests/tm24/system.h (modified) * c/src/tests/tmtests/tm25/Makefile.am (modified) * c/src/tests/tmtests/tm25/system.h (modified) * c/src/tests/tmtests/tm26/Makefile.am (modified) * c/src/tests/tmtests/tm26/system.h (modified) * c/src/tests/tmtests/tm27/Makefile.am (modified) * c/src/tests/tmtests/tm27/system.h (modified) * c/src/tests/tmtests/tm28/Makefile.am (modified) * c/src/tests/tmtests/tm28/system.h (modified) * c/src/tests/tmtests/tm29/Makefile.am (modified) * c/src/tests/tmtests/tm29/system.h (modified) * c/src/tests/tmtests/tmck/Makefile.am (modified) * c/src/tests/tmtests/tmck/system.h (modified) * c/src/tests/tmtests/tmoverhd/Makefile.am (modified) * c/src/tests/tmtests/tmoverhd/system.h (modified) * c/src/tests/tools/Makefile.am (modified) * c/src/tests/tools/generic/Makefile.am (modified) * c/src/wrapup/Makefile.am (modified) * configure.in (modified) * cpukit/ftpd/Makefile.am (modified) * cpukit/ftpd/ftpd.c (modified) * cpukit/httpd/Makefile.am (modified) * cpukit/httpd/balloc.c (modified) * cpukit/httpd/ejlex.c (modified) * cpukit/httpd/handler.c (modified) * cpukit/httpd/uemf.c (modified) * cpukit/httpd/uemf.h (modified) * cpukit/httpd/webs.c (modified) * cpukit/itron/include/Makefile.am (modified) * cpukit/itron/src/Makefile.am (modified) * cpukit/itron/src/cre_tsk.c (modified) * cpukit/itron/src/eventflags.c (modified) * cpukit/itron/src/fmempool.c (modified) * cpukit/itron/src/itronsem.c (modified) * cpukit/itron/src/mbox.c (modified) * cpukit/itron/src/msgbuffer.c (modified) * cpukit/itron/src/port.c (modified) * cpukit/itron/src/vmempool.c (modified) * cpukit/libcsupport/Makefile.am (modified) * cpukit/libcsupport/include/console.h (modified) * cpukit/libcsupport/include/rtems/error.h (modified) * cpukit/libcsupport/include/sys/termios.h (modified) * cpukit/libcsupport/src/gxx_wrappers.c (modified) * cpukit/libcsupport/src/libio.c (modified) * cpukit/libcsupport/src/malloc.c (modified) * cpukit/libcsupport/src/scandir.c (modified) * cpukit/libcsupport/src/termios.c (modified) * cpukit/libcsupport/src/termiosreserveresources.c (modified) * cpukit/libcsupport/src/unmount.c (modified) * cpukit/libfs/src/imfs/imfs.h (modified) * cpukit/libfs/src/imfs/imfs_creat.c (modified) * cpukit/libfs/src/imfs/imfs_directory.c (modified) * cpukit/libfs/src/imfs/imfs_stat.c (modified) * cpukit/libfs/src/imfs/imfs_utime.c (modified) * cpukit/libmisc/cpuuse/Makefile.am (modified) * cpukit/libmisc/dummy/Makefile.am (modified) * cpukit/libmisc/dummy/dummy.c (modified) * cpukit/libmisc/dumpbuf/Makefile.am (modified) * cpukit/libmisc/monitor/Makefile.am (modified) * cpukit/libmisc/monitor/mon-server.c (modified) * cpukit/libmisc/rtmonuse/Makefile.am (modified) * cpukit/libmisc/stackchk/Makefile.am (modified) * cpukit/libmisc/stackchk/internal.h (modified) * cpukit/libmisc/untar/Makefile.am (modified) * cpukit/libmisc/wrapup/Makefile.am (modified) * cpukit/libnetworking/Makefile.am (modified) * cpukit/libnetworking/arpa/Makefile.am (modified) * cpukit/libnetworking/kern/Makefile.am (modified) * cpukit/libnetworking/lib/Makefile.am (modified) * cpukit/libnetworking/lib/rtems_bsdnet_ntp.c (modified) * cpukit/libnetworking/libc/Makefile.am (modified) * cpukit/libnetworking/machine/Makefile.am (modified) * cpukit/libnetworking/memory.h (modified) * cpukit/libnetworking/net/Makefile.am (modified) * cpukit/libnetworking/net/if_loop.c (modified) * cpukit/libnetworking/netinet/Makefile.am (modified) * cpukit/libnetworking/netinet/in.h (modified) * cpukit/libnetworking/nfs/Makefile.am (modified) * cpukit/libnetworking/rtems/Makefile.am (modified) * cpukit/libnetworking/rtems/rtems_syscall.c (modified) * cpukit/libnetworking/sys/Makefile.am (modified) * cpukit/libnetworking/sys/un.h (modified) * cpukit/libnetworking/vm/Makefile.am (modified) * cpukit/libnetworking/wrapup/Makefile.am (modified) * cpukit/librpc/Makefile.am (modified) * cpukit/librpc/README_RTEMS (modified) * cpukit/librpc/include/Makefile.am (modified) * cpukit/librpc/include/rpc/Makefile.am (modified) * cpukit/librpc/include/rpc/auth.h (modified) * cpukit/librpc/include/rpc/auth_des.h (modified) * cpukit/librpc/include/rpc/auth_unix.h (modified) * cpukit/librpc/include/rpc/clnt.h (modified) * cpukit/librpc/include/rpc/des.h (modified) * cpukit/librpc/include/rpc/des_crypt.h (modified) * cpukit/librpc/include/rpc/pmap_clnt.h (modified) * cpukit/librpc/include/rpc/pmap_prot.h (modified) * cpukit/librpc/include/rpc/pmap_rmt.h (modified) * cpukit/librpc/include/rpc/rpc.h (modified) * cpukit/librpc/include/rpc/rpc_com.h (modified) * cpukit/librpc/include/rpc/rpc_msg.h (modified) * cpukit/librpc/include/rpc/svc.h (modified) * cpukit/librpc/include/rpc/svc_auth.h (modified) * cpukit/librpc/include/rpc/types.h (modified) * cpukit/librpc/include/rpc/xdr.h (modified) * cpukit/librpc/include/rpcsvc/.cvsignore (modified) * cpukit/librpc/include/rpcsvc/Makefile.am (modified) * cpukit/librpc/include/rpcsvc/bootparam_prot.x (modified) * cpukit/librpc/include/rpcsvc/crypt.x (modified) * cpukit/librpc/include/rpcsvc/key_prot.x (modified) * cpukit/librpc/include/rpcsvc/klm_prot.x (modified) * cpukit/librpc/include/rpcsvc/mount.x (modified) * cpukit/librpc/include/rpcsvc/nfs_prot.x (modified) * cpukit/librpc/include/rpcsvc/nis.x (modified) * cpukit/librpc/include/rpcsvc/nis_cache.x (modified) * cpukit/librpc/include/rpcsvc/nis_callback.x (modified) * cpukit/librpc/include/rpcsvc/nis_db.h (modified) * cpukit/librpc/include/rpcsvc/nis_object.x (modified) * cpukit/librpc/include/rpcsvc/nis_tags.h (modified) * cpukit/librpc/include/rpcsvc/nislib.h (modified) * cpukit/librpc/include/rpcsvc/nlm_prot.x (modified) * cpukit/librpc/include/rpcsvc/pmap_prot.x (modified) * cpukit/librpc/include/rpcsvc/rex.x (modified) * cpukit/librpc/include/rpcsvc/rnusers.x (modified) * cpukit/librpc/include/rpcsvc/rquota.x (modified) * cpukit/librpc/include/rpcsvc/rstat.x (modified) * cpukit/librpc/include/rpcsvc/rwall.x (modified) * cpukit/librpc/include/rpcsvc/sm_inter.x (modified) * cpukit/librpc/include/rpcsvc/spray.x (modified) * cpukit/librpc/include/rpcsvc/yp.x (modified) * cpukit/librpc/include/rpcsvc/yp_prot.h (modified) * cpukit/librpc/include/rpcsvc/ypclnt.h (modified) * cpukit/librpc/include/rpcsvc/yppasswd.x (modified) * cpukit/librpc/include/rpcsvc/ypupdate_prot.x (modified) * cpukit/librpc/include/rpcsvc/ypxfrd.x (modified) * cpukit/librpc/src/Makefile.am (modified) * cpukit/librpc/src/rpc/DISCLAIMER (modified) * cpukit/librpc/src/rpc/Makefile.am (modified) * cpukit/librpc/src/rpc/PSD.doc/.cvsignore (modified) * cpukit/librpc/src/rpc/PSD.doc/Makefile.am (modified) * cpukit/librpc/src/rpc/PSD.doc/nfs.rfc.ms (modified) * cpukit/librpc/src/rpc/PSD.doc/rpc.prog.ms (modified) * cpukit/librpc/src/rpc/PSD.doc/rpc.rfc.ms (modified) * cpukit/librpc/src/rpc/PSD.doc/rpcgen.ms (modified) * cpukit/librpc/src/rpc/PSD.doc/xdr.nts.ms (modified) * cpukit/librpc/src/rpc/PSD.doc/xdr.rfc.ms (modified) * cpukit/librpc/src/rpc/README (modified) * cpukit/librpc/src/rpc/auth_des.c (modified) * cpukit/librpc/src/rpc/auth_none.c (modified) * cpukit/librpc/src/rpc/auth_time.c (modified) * cpukit/librpc/src/rpc/auth_unix.c (modified) * cpukit/librpc/src/rpc/authdes_prot.c (modified) * cpukit/librpc/src/rpc/authunix_prot.c (modified) * cpukit/librpc/src/rpc/bindresvport.3 (modified) * cpukit/librpc/src/rpc/bindresvport.c (modified) * cpukit/librpc/src/rpc/clnt_generic.c (modified) * cpukit/librpc/src/rpc/clnt_perror.c (modified) * cpukit/librpc/src/rpc/clnt_raw.c (modified) * cpukit/librpc/src/rpc/clnt_simple.c (modified) * cpukit/librpc/src/rpc/clnt_tcp.c (modified) * cpukit/librpc/src/rpc/clnt_udp.c (modified) * cpukit/librpc/src/rpc/clnt_unix.c (modified) * cpukit/librpc/src/rpc/crypt_client.c (modified) * cpukit/librpc/src/rpc/des_crypt.3 (modified) * cpukit/librpc/src/rpc/des_crypt.c (modified) * cpukit/librpc/src/rpc/des_soft.c (modified) * cpukit/librpc/src/rpc/get_myaddress.c (modified) * cpukit/librpc/src/rpc/getpublickey.c (modified) * cpukit/librpc/src/rpc/getrpcent.3 (modified) * cpukit/librpc/src/rpc/getrpcent.c (modified) * cpukit/librpc/src/rpc/getrpcport.3 (modified) * cpukit/librpc/src/rpc/getrpcport.c (modified) * cpukit/librpc/src/rpc/key_call.c (modified) * cpukit/librpc/src/rpc/key_prot_xdr.c (modified) * cpukit/librpc/src/rpc/netname.c (modified) * cpukit/librpc/src/rpc/netnamer.c (modified) * cpukit/librpc/src/rpc/pmap_clnt.c (modified) * cpukit/librpc/src/rpc/pmap_getmaps.c (modified) * cpukit/librpc/src/rpc/pmap_getport.c (modified) * cpukit/librpc/src/rpc/pmap_prot.c (modified) * cpukit/librpc/src/rpc/pmap_prot2.c (modified) * cpukit/librpc/src/rpc/pmap_rmt.c (modified) * cpukit/librpc/src/rpc/publickey.3 (modified) * cpukit/librpc/src/rpc/publickey.5 (modified) * cpukit/librpc/src/rpc/rpc.3 (modified) * cpukit/librpc/src/rpc/rpc.5 (modified) * cpukit/librpc/src/rpc/rpc_callmsg.c (modified) * cpukit/librpc/src/rpc/rpc_commondata.c (modified) * cpukit/librpc/src/rpc/rpc_dtablesize.c (modified) * cpukit/librpc/src/rpc/rpc_prot.c (modified) * cpukit/librpc/src/rpc/rpc_secure.3 (modified) * cpukit/librpc/src/rpc/rpcdname.c (modified) * cpukit/librpc/src/rpc/rstat.1 (modified) * cpukit/librpc/src/rpc/rstat_svc.8 (modified) * cpukit/librpc/src/rpc/rtems_portmapper.c (modified) * cpukit/librpc/src/rpc/rtems_rpc.c (modified) * cpukit/librpc/src/rpc/rtime.3 (modified) * cpukit/librpc/src/rpc/rtime.c (modified) * cpukit/librpc/src/rpc/svc.c (modified) * cpukit/librpc/src/rpc/svc_auth.c (modified) * cpukit/librpc/src/rpc/svc_auth_des.c (modified) * cpukit/librpc/src/rpc/svc_auth_unix.c (modified) * cpukit/librpc/src/rpc/svc_raw.c (modified) * cpukit/librpc/src/rpc/svc_run.c (modified) * cpukit/librpc/src/rpc/svc_simple.c (modified) * cpukit/librpc/src/rpc/svc_tcp.c (modified) * cpukit/librpc/src/rpc/svc_udp.c (modified) * cpukit/librpc/src/rpc/svc_unix.c (modified) * cpukit/librpc/src/xdr/Makefile.am (modified) * cpukit/librpc/src/xdr/xdr.3 (modified) * cpukit/librpc/src/xdr/xdr.c (modified) * cpukit/librpc/src/xdr/xdr_array.c (modified) * cpukit/librpc/src/xdr/xdr_float.c (modified) * cpukit/librpc/src/xdr/xdr_mem.c (modified) * cpukit/librpc/src/xdr/xdr_rec.c (modified) * cpukit/librpc/src/xdr/xdr_reference.c (modified) * cpukit/librpc/src/xdr/xdr_sizeof.c (modified) * cpukit/librpc/src/xdr/xdr_stdio.c (modified) * cpukit/posix/include/Makefile.am (modified) * cpukit/posix/inline/rtems/posix/cond.inl (modified) * cpukit/posix/src/Makefile.am (modified) * cpukit/posix/src/mqueuecreatesupp.c (modified) * cpukit/posix/src/mqueuedeletesupp.c (modified) * cpukit/posix/src/mqueueunlink.c (modified) * cpukit/posix/src/pthread.c (modified) * cpukit/posix/src/pthreadcreate.c (modified) * cpukit/posix/src/sigtimedwait.c (modified) * cpukit/posix/src/waitpid.c (modified) * cpukit/pppd/Makefile.am (modified) * cpukit/pppd/options.c (modified) * cpukit/pppd/pppd.h (modified) * cpukit/rtems/include/Makefile.am (modified) * cpukit/rtems/include/rtems/rtems/rtemsapi.h (modified) * cpukit/rtems/src/Makefile.am (modified) * cpukit/rtems/src/semdelete.c (modified) * cpukit/rtems/src/tasks.c (modified) * cpukit/rtems/src/taskvariableadd.c (modified) * cpukit/rtems/src/taskvariabledelete.c (modified) * cpukit/rtems/src/taskvariableget.c (modified) * cpukit/sapi/include/Makefile.am (modified) * cpukit/sapi/include/confdefs.h (modified) * cpukit/sapi/include/rtems/README (modified) * cpukit/sapi/src/Makefile.am (modified) * cpukit/score/cpu/a29k/Makefile.am (modified) * cpukit/score/cpu/a29k/rtems/score/a29k.h (modified) * cpukit/score/cpu/hppa1.1/Makefile.am (modified) * cpukit/score/cpu/hppa1.1/rtems/score/hppa.h (modified) * cpukit/score/cpu/i386/Makefile.am (modified) * cpukit/score/cpu/i386/rtems/score/i386.h (modified) * cpukit/score/cpu/i960/Makefile.am (modified) * cpukit/score/cpu/i960/rtems/score/i960.h (modified) * cpukit/score/cpu/m68k/Makefile.am (modified) * cpukit/score/cpu/m68k/qsm.h (modified) * cpukit/score/cpu/m68k/rtems/m68k/qsm.h (modified) * cpukit/score/cpu/m68k/rtems/m68k/sim.h (modified) * cpukit/score/cpu/m68k/rtems/score/m68k.h (modified) * cpukit/score/cpu/m68k/sim.h (modified) * cpukit/score/cpu/mips/Makefile.am (modified) * cpukit/score/cpu/mips/rtems/score/mips.h (modified) * cpukit/score/cpu/mips64orion/Makefile.am (modified) * cpukit/score/cpu/mips64orion/rtems/score/mips64orion.h (modified) * cpukit/score/cpu/no_cpu/Makefile.am (modified) * cpukit/score/cpu/no_cpu/cpu.c (modified) * cpukit/score/cpu/no_cpu/cpu_asm.c (modified) * cpukit/score/cpu/no_cpu/rtems/score/cpu.h (modified) * cpukit/score/cpu/no_cpu/rtems/score/no_cpu.h (modified) * cpukit/score/cpu/powerpc/Makefile.am (modified) * cpukit/score/cpu/powerpc/rtems/score/ppc.h (modified) * cpukit/score/cpu/sh/Makefile.am (modified) * cpukit/score/cpu/sh/rtems/score/sh.h (modified) * cpukit/score/cpu/sparc/Makefile.am (modified) * cpukit/score/cpu/sparc/rtems/score/sparc.h (modified) * cpukit/score/cpu/unix/Makefile.am (modified) * cpukit/score/cpu/unix/cpu.c (modified) * cpukit/score/cpu/unix/rtems/score/cpu.h (modified) * cpukit/score/cpu/unix/rtems/score/unix.h (modified) * cpukit/score/include/rtems/score/thread.h (modified) * cpukit/score/include/rtems/system.h (modified) * cpukit/score/macros/rtems/score/address.inl (modified) * cpukit/score/src/Makefile.am (modified) * cpukit/score/src/objectcopynamestring.c (modified) * make/Makefile.am (modified) * make/README (modified) * make/Templates/Makefile.am (modified) * make/Templates/Makefile.dir (modified) * make/Templates/Makefile.leaf (modified) * make/Templates/Makefile.lib (modified) * make/compilers/Makefile.am (modified) * make/compilers/gcc-no_bsp.cfg (modified) * make/compilers/gcc-portsw.cfg (modified) * make/compilers/gcc-target-default.cfg (modified) * make/custom/FreeBSD-posix.cfg (modified) * make/custom/HPUX9-posix.cfg (modified) * make/custom/Linux-posix.cfg (modified) * make/custom/Makefile.am (modified) * make/custom/Solaris-posix.cfg (modified) * make/custom/cvme961.cfg (modified) * make/custom/dmv152.cfg (modified) * make/custom/dmv177.cfg (modified) * make/custom/efi332.cfg (modified) * make/custom/efi68k.cfg (modified) * make/custom/erc32.cfg (modified) * make/custom/eth_comm.cfg (modified) * make/custom/gen68302.cfg (modified) * make/custom/gen68340.cfg (modified) * make/custom/gen68360.cfg (modified) * make/custom/gensh1.cfg (modified) * make/custom/gensh2.cfg (modified) * make/custom/helas403.cfg (modified) * make/custom/i386ex.cfg (modified) * make/custom/idp.cfg (modified) * make/custom/mcp750.cfg (modified) * make/custom/mvme136.cfg (modified) * make/custom/mvme147.cfg (modified) * make/custom/mvme162.cfg (modified) * make/custom/mvme167.cfg (modified) * make/custom/mvme2307.cfg (modified) * make/custom/ods68302.cfg (modified) * make/custom/p4000.cfg (modified) * make/custom/p4600.cfg (modified) * make/custom/p4650.cfg (modified) * make/custom/papyrus.cfg (modified) * make/custom/pc386.cfg (modified) * make/custom/ppcn_60x.cfg (modified) * make/custom/psim.cfg (modified) * make/custom/rxgen960.cfg (modified) * make/custom/score603e.cfg (modified) * make/custom/simhppa.cfg (modified) * make/custom/ts_386ex.cfg (modified) * make/host.cfg.in (modified) * make/leaf.cfg (modified) * make/main.cfg (modified) * scripts-ada/.cvsignore (modified) * scripts-ada/Makefile.am (modified) * scripts-ada/binutils/.cvsignore (modified) * scripts-ada/binutils/Makefile.am (modified) * scripts-ada/binutils/binutils.spec.in (modified) * scripts-ada/buildall.in (modified) * scripts-ada/configure.in (modified) * scripts-ada/gdb/.cvsignore (modified) * scripts-ada/gdb/Makefile.am (modified) * scripts-ada/gdb/gdb.spec.in (modified) * scripts-ada/gnatnewlib/.cvsignore (modified) * scripts-ada/gnatnewlib/Makefile.am (modified) * scripts-ada/gnatnewlib/gnatnewlib.spec.in (modified) * scripts-ada/mkbinutilspec.in (modified) * scripts-ada/mkgdbspec.in (modified) * scripts-ada/mkgnatnewlibspec.in (modified) * scripts-ada/setup.def (modified) * scripts/Makefile.am (modified) * scripts/binutils/.cvsignore (modified) * scripts/binutils/Makefile.am (modified) * scripts/binutils/base-binutils.add (modified) * scripts/binutils/binutils.add (modified) * scripts/binutils/target-binutils.add (modified) * scripts/buildall.in (modified) * scripts/configure.in (modified) * scripts/gccnewlib/.cvsignore (modified) * scripts/gccnewlib/Makefile.am (modified) * scripts/gccnewlib/README (added) * scripts/gccnewlib/base-chill.add (modified) * scripts/gccnewlib/base-g77.add (modified) * scripts/gccnewlib/base-gcc.add (modified) * scripts/gccnewlib/base-gcj.add (modified) * scripts/gccnewlib/gccnewlib.add (modified) * scripts/gccnewlib/target-chill.add (modified) * scripts/gccnewlib/target-g77.add (modified) * scripts/gccnewlib/target-gcc.add (modified) * scripts/gccnewlib/target-gcj.add (modified) * scripts/gccnewlib/target-objc.add (modified) * scripts/gdb/.cvsignore (modified) * scripts/gdb/Makefile.am (modified) * scripts/gdb/base-gdb.add (modified) * scripts/gdb/gdb.add (modified) * scripts/gdb/target-gdb.add (modified) * scripts/rtems/.cvsignore (modified) * scripts/rtems/Makefile.am (modified) * scripts/rtems/rtems.spec.in (modified) * scripts/setup.def (modified) * testsuites/itrontests/itronhello/Makefile.am (modified) * testsuites/itrontests/itronhello/system.h (modified) * testsuites/itrontests/itronmbf01/Makefile.am (modified) * testsuites/itrontests/itronmbf01/system.h (modified) * testsuites/itrontests/itronmbox01/Makefile.am (modified) * testsuites/itrontests/itronmbox01/itronmbox01.scn (modified) * testsuites/itrontests/itronmbox01/system.h (modified) * testsuites/itrontests/itronsem01/Makefile.am (modified) * testsuites/itrontests/itronsem01/init.c (modified) * testsuites/itrontests/itronsem01/system.h (modified) * testsuites/itrontests/itrontask01/Makefile.am (modified) * testsuites/itrontests/itrontask01/system.h (modified) * testsuites/itrontests/itrontask02/Makefile.am (modified) * testsuites/itrontests/itrontask02/system.h (modified) * testsuites/itrontests/itrontask03/Makefile.am (modified) * testsuites/itrontests/itrontask03/system.h (modified) * testsuites/itrontests/itrontask04/Makefile.am (modified) * testsuites/itrontests/itrontask04/system.h (modified) * testsuites/itrontests/itrontime01/Makefile.am (modified) * testsuites/itrontests/itrontime01/itrontime01.scn (modified) * testsuites/itrontests/itrontime01/system.h (modified) * testsuites/libtests/cpuuse/Makefile.am (modified) * testsuites/libtests/cpuuse/cpuuse.scn (modified) * testsuites/libtests/cpuuse/system.h (modified) * testsuites/libtests/cpuuse/task2.c (modified) * testsuites/libtests/cpuuse/tswitch.c (modified) * testsuites/libtests/malloctest/Makefile.am (modified) * testsuites/libtests/malloctest/malloctest.scn (modified) * testsuites/libtests/malloctest/system.h (modified) * testsuites/libtests/monitor/Makefile.am (modified) * testsuites/libtests/monitor/system.h (modified) * testsuites/libtests/putenvtest/Makefile.am (modified) * testsuites/libtests/putenvtest/init.c (modified) * testsuites/libtests/rtems++/Makefile.am (modified) * testsuites/libtests/rtems++/System.h (modified) * testsuites/libtests/rtmonuse/Makefile.am (modified) * testsuites/libtests/rtmonuse/system.h (modified) * testsuites/libtests/stackchk/Makefile.am (modified) * testsuites/libtests/stackchk/system.h (modified) * testsuites/libtests/termios/Makefile.am (modified) * testsuites/libtests/termios/README (modified) * testsuites/libtests/termios/init.c (modified) * testsuites/mptests/mp01/node1/Makefile.am (modified) * testsuites/mptests/mp01/node2/Makefile.am (modified) * testsuites/mptests/mp01/system.h (modified) * testsuites/mptests/mp02/node1/Makefile.am (modified) * testsuites/mptests/mp02/node2/Makefile.am (modified) * testsuites/mptests/mp02/system.h (modified) * testsuites/mptests/mp03/node1/Makefile.am (modified) * testsuites/mptests/mp03/node2/Makefile.am (modified) * testsuites/mptests/mp03/system.h (modified) * testsuites/mptests/mp04/node1/Makefile.am (modified) * testsuites/mptests/mp04/node2/Makefile.am (modified) * testsuites/mptests/mp04/system.h (modified) * testsuites/mptests/mp05/node1/Makefile.am (modified) * testsuites/mptests/mp05/node2/Makefile.am (modified) * testsuites/mptests/mp05/system.h (modified) * testsuites/mptests/mp06/node1/Makefile.am (modified) * testsuites/mptests/mp06/node2/Makefile.am (modified) * testsuites/mptests/mp06/system.h (modified) * testsuites/mptests/mp07/node1/Makefile.am (modified) * testsuites/mptests/mp07/node2/Makefile.am (modified) * testsuites/mptests/mp07/system.h (modified) * testsuites/mptests/mp08/node1/Makefile.am (modified) * testsuites/mptests/mp08/node2/Makefile.am (modified) * testsuites/mptests/mp08/system.h (modified) * testsuites/mptests/mp09/node1/Makefile.am (modified) * testsuites/mptests/mp09/node2/Makefile.am (modified) * testsuites/mptests/mp09/system.h (modified) * testsuites/mptests/mp10/node1/Makefile.am (modified) * testsuites/mptests/mp10/node2/Makefile.am (modified) * testsuites/mptests/mp10/system.h (modified) * testsuites/mptests/mp11/node1/Makefile.am (modified) * testsuites/mptests/mp11/node2/Makefile.am (modified) * testsuites/mptests/mp11/system.h (modified) * testsuites/mptests/mp12/node1/Makefile.am (modified) * testsuites/mptests/mp12/node2/Makefile.am (modified) * testsuites/mptests/mp12/system.h (modified) * testsuites/mptests/mp13/node1/Makefile.am (modified) * testsuites/mptests/mp13/node2/Makefile.am (modified) * testsuites/mptests/mp13/system.h (modified) * testsuites/mptests/mp14/Makefile.am (modified) * testsuites/mptests/mp14/node1/Makefile.am (modified) * testsuites/mptests/mp14/node2/Makefile.am (modified) * testsuites/mptests/mp14/system.h (modified) * testsuites/psxtests/Makefile.am (modified) * testsuites/psxtests/psx01/Makefile.am (modified) * testsuites/psxtests/psx01/psx01.scn (modified) * testsuites/psxtests/psx01/system.h (modified) * testsuites/psxtests/psx02/Makefile.am (modified) * testsuites/psxtests/psx02/system.h (modified) * testsuites/psxtests/psx03/Makefile.am (modified) * testsuites/psxtests/psx03/system.h (modified) * testsuites/psxtests/psx04/Makefile.am (modified) * testsuites/psxtests/psx04/system.h (modified) * testsuites/psxtests/psx05/Makefile.am (modified) * testsuites/psxtests/psx05/system.h (modified) * testsuites/psxtests/psx06/Makefile.am (modified) * testsuites/psxtests/psx06/system.h (modified) * testsuites/psxtests/psx07/Makefile.am (modified) * testsuites/psxtests/psx07/system.h (modified) * testsuites/psxtests/psx08/Makefile.am (modified) * testsuites/psxtests/psx08/system.h (modified) * testsuites/psxtests/psx09/Makefile.am (modified) * testsuites/psxtests/psx09/system.h (modified) * testsuites/psxtests/psx10/Makefile.am (modified) * testsuites/psxtests/psx10/system.h (modified) * testsuites/psxtests/psx11/Makefile.am (modified) * testsuites/psxtests/psx11/system.h (modified) * testsuites/psxtests/psx12/Makefile.am (modified) * testsuites/psxtests/psx12/system.h (modified) * testsuites/psxtests/psx13/Makefile.am (modified) * testsuites/psxtests/psx13/main.c (modified) * testsuites/psxtests/psxcancel/Makefile.am (modified) * testsuites/psxtests/psxfile01/Makefile.am (modified) * testsuites/psxtests/psxfile01/main.c (modified) * testsuites/psxtests/psxfile01/psxfile01.scn (modified) * testsuites/psxtests/psxfile01/test.c (modified) * testsuites/psxtests/psxhdrs/Makefile.am (modified) * testsuites/psxtests/psxmount/Makefile.am (modified) * testsuites/psxtests/psxmount/main.c (modified) * testsuites/psxtests/psxmsgq01/Makefile.am (modified) * testsuites/psxtests/psxmsgq01/system.h (modified) * testsuites/psxtests/psxreaddir/Makefile.am (modified) * testsuites/psxtests/psxreaddir/main.c (modified) * testsuites/psxtests/psxsem01/Makefile.am (modified) * testsuites/psxtests/psxsem01/system.h (modified) * testsuites/psxtests/psxstat/Makefile.am (modified) * testsuites/psxtests/psxstat/main.c (modified) * testsuites/psxtests/psxstat/test.c (modified) * testsuites/psxtests/psxtime/Makefile.am (modified) * testsuites/psxtests/psxtime/main.c (modified) * testsuites/psxtests/psxtimer/Makefile.am (modified) * testsuites/psxtests/psxtimer/system.h (modified) * testsuites/samples/Makefile.am (modified) * testsuites/samples/base_mp/apptask.c (modified) * testsuites/samples/base_mp/init.c (modified) * testsuites/samples/base_mp/system.h (modified) * testsuites/samples/base_sp/apptask.c (modified) * testsuites/samples/base_sp/init.c (modified) * testsuites/samples/base_sp/system.h (modified) * testsuites/samples/cdtest/Makefile.am (modified) * testsuites/samples/cdtest/init.c (modified) * testsuites/samples/cdtest/system.h (modified) * testsuites/samples/hello/Makefile.am (modified) * testsuites/samples/hello/init.c (modified) * testsuites/samples/hello/system.h (modified) * testsuites/samples/minimum/Makefile.am (modified) * testsuites/samples/minimum/init.c (modified) * testsuites/samples/paranoia/Makefile.am (modified) * testsuites/samples/paranoia/init.c (modified) * testsuites/samples/paranoia/system.h (modified) * testsuites/samples/ticker/Makefile.am (modified) * testsuites/samples/ticker/init.c (modified) * testsuites/samples/ticker/system.h (modified) * testsuites/samples/ticker/tasks.c (modified) * testsuites/samples/unlimited/Makefile.am (modified) * testsuites/samples/unlimited/init.c (modified) * testsuites/samples/unlimited/system.h (modified) * testsuites/sptests/sp01/Makefile.am (modified) * testsuites/sptests/sp01/system.h (modified) * testsuites/sptests/sp02/Makefile.am (modified) * testsuites/sptests/sp02/system.h (modified) * testsuites/sptests/sp03/Makefile.am (modified) * testsuites/sptests/sp03/system.h (modified) * testsuites/sptests/sp04/Makefile.am (modified) * testsuites/sptests/sp04/system.h (modified) * testsuites/sptests/sp04/tswitch.c (modified) * testsuites/sptests/sp05/Makefile.am (modified) * testsuites/sptests/sp05/system.h (modified) * testsuites/sptests/sp06/Makefile.am (modified) * testsuites/sptests/sp06/system.h (modified) * testsuites/sptests/sp07/Makefile.am (modified) * testsuites/sptests/sp07/system.h (modified) * testsuites/sptests/sp08/Makefile.am (modified) * testsuites/sptests/sp08/system.h (modified) * testsuites/sptests/sp09/Makefile.am (modified) * testsuites/sptests/sp09/screen07.c (modified) * testsuites/sptests/sp09/screen08.c (modified) * testsuites/sptests/sp09/system.h (modified) * testsuites/sptests/sp11/Makefile.am (modified) * testsuites/sptests/sp11/system.h (modified) * testsuites/sptests/sp12/Makefile.am (modified) * testsuites/sptests/sp12/system.h (modified) * testsuites/sptests/sp13/Makefile.am (modified) * testsuites/sptests/sp13/fillbuff.c (modified) * testsuites/sptests/sp13/init.c (modified) * testsuites/sptests/sp13/putbuff.c (modified) * testsuites/sptests/sp13/system.h (modified) * testsuites/sptests/sp13/task1.c (modified) * testsuites/sptests/sp13/task2.c (modified) * testsuites/sptests/sp14/Makefile.am (modified) * testsuites/sptests/sp14/system.h (modified) * testsuites/sptests/sp15/Makefile.am (modified) * testsuites/sptests/sp15/system.h (modified) * testsuites/sptests/sp16/Makefile.am (modified) * testsuites/sptests/sp16/system.h (modified) * testsuites/sptests/sp17/Makefile.am (modified) * testsuites/sptests/sp17/system.h (modified) * testsuites/sptests/sp19/Makefile.am (modified) * testsuites/sptests/sp19/system.h (modified) * testsuites/sptests/sp20/Makefile.am (modified) * testsuites/sptests/sp20/system.h (modified) * testsuites/sptests/sp21/Makefile.am (modified) * testsuites/sptests/sp21/system.h (modified) * testsuites/sptests/sp22/Makefile.am (modified) * testsuites/sptests/sp22/system.h (modified) * testsuites/sptests/sp23/Makefile.am (modified) * testsuites/sptests/sp23/system.h (modified) * testsuites/sptests/sp24/Makefile.am (modified) * testsuites/sptests/sp24/system.h (modified) * testsuites/sptests/sp25/Makefile.am (modified) * testsuites/sptests/sp25/sp25.scn (modified) * testsuites/sptests/sp25/system.h (modified) * testsuites/sptests/sp26/Makefile.am (modified) * testsuites/sptests/sp26/system.h (modified) * testsuites/sptests/sp27/Makefile.am (modified) * testsuites/sptests/sp27/init.c (modified) * testsuites/sptests/sp28/Makefile.am (modified) * testsuites/sptests/sp28/init.c (modified) * testsuites/sptests/sp29/Makefile.am (modified) * testsuites/sptests/sp29/init.c (modified) * testsuites/sptests/spfatal/Makefile.am (modified) * testsuites/sptests/spfatal/system.h (modified) * testsuites/sptests/spsize/Makefile.am (modified) * testsuites/sptests/spsize/system.h (modified) * testsuites/tmitrontests/tmitronsem01/Makefile.am (modified) * testsuites/tmitrontests/tmitronsem01/system.h (modified) * testsuites/tmtests/Makefile.am (modified) * testsuites/tmtests/tm01/Makefile.am (modified) * testsuites/tmtests/tm01/system.h (modified) * testsuites/tmtests/tm02/Makefile.am (modified) * testsuites/tmtests/tm02/system.h (modified) * testsuites/tmtests/tm03/Makefile.am (modified) * testsuites/tmtests/tm03/system.h (modified) * testsuites/tmtests/tm04/Makefile.am (modified) * testsuites/tmtests/tm04/system.h (modified) * testsuites/tmtests/tm05/Makefile.am (modified) * testsuites/tmtests/tm05/system.h (modified) * testsuites/tmtests/tm06/Makefile.am (modified) * testsuites/tmtests/tm06/system.h (modified) * testsuites/tmtests/tm07/Makefile.am (modified) * testsuites/tmtests/tm07/system.h (modified) * testsuites/tmtests/tm08/Makefile.am (modified) * testsuites/tmtests/tm08/system.h (modified) * testsuites/tmtests/tm09/Makefile.am (modified) * testsuites/tmtests/tm09/system.h (modified) * testsuites/tmtests/tm09/task1.c (modified) * testsuites/tmtests/tm10/Makefile.am (modified) * testsuites/tmtests/tm10/system.h (modified) * testsuites/tmtests/tm11/Makefile.am (modified) * testsuites/tmtests/tm11/system.h (modified) * testsuites/tmtests/tm11/task1.c (modified) * testsuites/tmtests/tm12/Makefile.am (modified) * testsuites/tmtests/tm12/system.h (modified) * testsuites/tmtests/tm12/task1.c (modified) * testsuites/tmtests/tm13/Makefile.am (modified) * testsuites/tmtests/tm13/system.h (modified) * testsuites/tmtests/tm13/task1.c (modified) * testsuites/tmtests/tm14/Makefile.am (modified) * testsuites/tmtests/tm14/system.h (modified) * testsuites/tmtests/tm14/task1.c (modified) * testsuites/tmtests/tm15/Makefile.am (modified) * testsuites/tmtests/tm15/system.h (modified) * testsuites/tmtests/tm16/Makefile.am (modified) * testsuites/tmtests/tm16/system.h (modified) * testsuites/tmtests/tm17/Makefile.am (modified) * testsuites/tmtests/tm17/system.h (modified) * testsuites/tmtests/tm18/Makefile.am (modified) * testsuites/tmtests/tm18/system.h (modified) * testsuites/tmtests/tm19/Makefile.am (modified) * testsuites/tmtests/tm19/system.h (modified) * testsuites/tmtests/tm20/Makefile.am (modified) * testsuites/tmtests/tm20/system.h (modified) * testsuites/tmtests/tm21/Makefile.am (modified) * testsuites/tmtests/tm21/system.h (modified) * testsuites/tmtests/tm21/task1.c (modified) * testsuites/tmtests/tm22/Makefile.am (modified) * testsuites/tmtests/tm22/system.h (modified) * testsuites/tmtests/tm22/task1.c (modified) * testsuites/tmtests/tm23/Makefile.am (modified) * testsuites/tmtests/tm23/system.h (modified) * testsuites/tmtests/tm24/Makefile.am (modified) * testsuites/tmtests/tm24/system.h (modified) * testsuites/tmtests/tm25/Makefile.am (modified) * testsuites/tmtests/tm25/system.h (modified) * testsuites/tmtests/tm26/Makefile.am (modified) * testsuites/tmtests/tm26/system.h (modified) * testsuites/tmtests/tm27/Makefile.am (modified) * testsuites/tmtests/tm27/system.h (modified) * testsuites/tmtests/tm28/Makefile.am (modified) * testsuites/tmtests/tm28/system.h (modified) * testsuites/tmtests/tm29/Makefile.am (modified) * testsuites/tmtests/tm29/system.h (modified) * testsuites/tmtests/tmck/Makefile.am (modified) * testsuites/tmtests/tmck/system.h (modified) * testsuites/tmtests/tmoverhd/Makefile.am (modified) * testsuites/tmtests/tmoverhd/system.h (modified) * testsuites/tools/Makefile.am (modified) * testsuites/tools/generic/Makefile.am (modified) * tools/Makefile.am (modified) * tools/build/Makefile.am (modified) * tools/cpu/Makefile.am (modified) * tools/cpu/generic/Makefile.am (modified) * tools/cpu/generic/size_rtems.in (modified) * tools/cpu/hppa1.1/Makefile.am (modified) * tools/cpu/sh/Makefile.am (modified) * tools/cpu/sh/configure.in (modified) * tools/cpu/sh/shgen.c (modified) * tools/cpu/unix/Makefile.am (modified) * tools/cpu/unix/gensize.c (modified) * tools/update/Makefile.am (modified) * tools/update/acpolish (modified) * tools/update/ampolish (modified) * tools/update/cipolish (modified) * tools/update/rtems-polish.sh (modified) Merged from 4.5.0-beta3a Tue, 08 Feb 2000 22:33:25 GMT Joel Sherrill [70810dc] * aclocal/canonicalize-tools.m4 (modified) * aclocal/gcc-pipe.m4 (modified) * aclocal/prog-cc.m4 (modified) * aclocal/prog-cxx.m4 (modified) * aclocal/project-root.m4 (modified) * c/configure.in (modified) * c/make/Makefile.am (modified) * c/make/configure.in (modified) * c/src/configure.in (modified) * c/src/exec/configure.in (modified) * c/src/exec/itron/configure.in (modified) * c/src/exec/itron/src/Makefile.am (modified) * c/src/exec/libcsupport/src/Makefile.am (modified) * c/src/exec/posix/configure.in (modified) * c/src/exec/posix/src/Makefile.am (modified) * c/src/exec/rtems/src/Makefile.am (modified) * c/src/exec/sapi/src/Makefile.am (modified) * c/src/exec/score/cpu/a29k/configure.in (modified) * c/src/exec/score/cpu/hppa1.1/configure.in (modified) * c/src/exec/score/cpu/i386/configure.in (modified) * c/src/exec/score/cpu/i960/configure.in (modified) * c/src/exec/score/cpu/m68k/configure.in (modified) * c/src/exec/score/cpu/mips/configure.in (modified) * c/src/exec/score/cpu/mips64orion/configure.in (modified) * c/src/exec/score/cpu/no_cpu/configure.in (modified) * c/src/exec/score/cpu/powerpc/configure.in (modified) * c/src/exec/score/cpu/sh/configure.in (modified) * c/src/exec/score/cpu/sparc/configure.in (modified) * c/src/exec/score/cpu/unix/configure.in (modified) * c/src/exec/score/src/Makefile.am (modified) * c/src/lib/configure.in (modified) * c/src/lib/libbsp/a29k/configure.in (modified) * c/src/lib/libbsp/a29k/portsw/configure.in (modified) * c/src/lib/libbsp/bare/configure.in (modified) * c/src/lib/libbsp/configure.in (modified) * c/src/lib/libbsp/hppa1.1/configure.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/configure.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/configure.in (modified) * c/src/lib/libbsp/i386/configure.in (modified) * c/src/lib/libbsp/i386/i386ex/configure.in (modified) * c/src/lib/libbsp/i386/pc386/configure.in (modified) * c/src/lib/libbsp/i386/pc386/tools/configure.in (modified) * c/src/lib/libbsp/i386/ts_386ex/configure.in (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/configure.in (modified) * c/src/lib/libbsp/i960/configure.in (modified) * c/src/lib/libbsp/i960/cvme961/configure.in (modified) * c/src/lib/libbsp/i960/rxgen960/configure.in (modified) * c/src/lib/libbsp/i960/rxgen960/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/configure.in (modified) * c/src/lib/libbsp/m68k/dmv152/configure.in (modified) * c/src/lib/libbsp/m68k/efi332/configure.in (modified) * c/src/lib/libbsp/m68k/efi68k/configure.in (modified) * c/src/lib/libbsp/m68k/gen68302/configure.in (modified) * c/src/lib/libbsp/m68k/gen68340/configure.in (modified) * c/src/lib/libbsp/m68k/gen68360/configure.in (modified) * c/src/lib/libbsp/m68k/gen68360/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/idp/configure.in (modified) * c/src/lib/libbsp/m68k/mvme136/configure.in (modified) * c/src/lib/libbsp/m68k/mvme147/configure.in (modified) * c/src/lib/libbsp/m68k/mvme147s/configure.in (modified) * c/src/lib/libbsp/m68k/mvme162/configure.in (modified) * c/src/lib/libbsp/m68k/mvme162/tools/configure.in (modified) * c/src/lib/libbsp/m68k/mvme167/configure.in (modified) * c/src/lib/libbsp/m68k/ods68302/configure.in (modified) * c/src/lib/libbsp/mips/configure.in (modified) * c/src/lib/libbsp/mips/p4000/configure.in (modified) * c/src/lib/libbsp/mips64orion/configure.in (modified) * c/src/lib/libbsp/mips64orion/p4000/configure.in (modified) * c/src/lib/libbsp/no_cpu/configure.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/configure.in (modified) * c/src/lib/libbsp/powerpc/configure.in (modified) * c/src/lib/libbsp/powerpc/dmv177/configure.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/configure.in (modified) * c/src/lib/libbsp/powerpc/helas403/configure.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/configure.in (modified) * c/src/lib/libbsp/powerpc/papyrus/configure.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/configure.in (modified) * c/src/lib/libbsp/powerpc/psim/configure.in (modified) * c/src/lib/libbsp/powerpc/psim/tools/configure.in (modified) * c/src/lib/libbsp/powerpc/score603e/configure.in (modified) * c/src/lib/libbsp/sh/configure.in (modified) * c/src/lib/libbsp/sh/gensh1/configure.in (modified) * c/src/lib/libbsp/sh/gensh2/configure.in (modified) * c/src/lib/libbsp/sparc/configure.in (modified) * c/src/lib/libbsp/sparc/erc32/configure.in (modified) * c/src/lib/libbsp/sparc/erc32/tools/configure.in (modified) * c/src/lib/libbsp/unix/configure.in (modified) * c/src/lib/libbsp/unix/posix/configure.in (modified) * c/src/lib/libbsp/unix/posix/tools/configure.in (modified) * c/src/lib/libc/Makefile.am (modified) * c/src/lib/libcpu/a29k/clock/Makefile.am (modified) * c/src/lib/libcpu/a29k/configure.in (modified) * c/src/lib/libcpu/a29k/timer/Makefile.am (modified) * c/src/lib/libcpu/configure.in (modified) * c/src/lib/libcpu/hppa1.1/configure.in (modified) * c/src/lib/libcpu/i386/configure.in (modified) * c/src/lib/libcpu/m68k/configure.in (modified) * c/src/lib/libcpu/mips/configure.in (modified) * c/src/lib/libcpu/mips64orion/configure.in (modified) * c/src/lib/libcpu/powerpc/configure.in (modified) * c/src/lib/libcpu/sh/configure.in (modified) * c/src/lib/libcpu/sparc/configure.in (modified) * c/src/libchip/configure.in (modified) * c/src/libchip/network/Makefile.am (modified) * c/src/libchip/rtc/Makefile.am (modified) * c/src/libchip/serial/Makefile.am (modified) * c/src/libmisc/configure.in (modified) * c/src/libmisc/cpuuse/Makefile.am (modified) * c/src/libmisc/monitor/Makefile.am (modified) * c/src/libmisc/rtmonuse/Makefile.am (modified) * c/src/libmisc/stackchk/Makefile.am (modified) * c/src/libmisc/untar/Makefile.am (modified) * c/src/libmisc/wrapup/Makefile.am (modified) * c/src/libnetworking/configure.in (modified) * c/src/librdbg/configure.in (modified) * c/src/librdbg/include/Makefile.am (modified) * c/src/librdbg/src/Makefile.am (modified) * c/src/librdbg/src/i386/Makefile.am (modified) * c/src/librdbg/src/powerpc/Makefile.am (modified) * c/src/librpc/configure.in (modified) * c/src/librtems++/configure.in (modified) * c/src/make/compilers/gcc-target-default.cfg (modified) * c/src/make/configure.in (modified) * c/src/make/lib.cfg (modified) * c/src/tests/configure.in (modified) * c/src/tests/itrontests/configure.in (modified) * c/src/tests/libtests/configure.in (modified) * c/src/tests/mptests/configure.in (modified) * c/src/tests/psxtests/configure.in (modified) * c/src/tests/samples/configure.in (modified) * c/src/tests/samples/hello/Makefile.am (modified) * c/src/tests/samples/ticker/Makefile.am (modified) * c/src/tests/sptests/configure.in (modified) * c/src/tests/support/configure.in (modified) * c/src/tests/tmitrontests/configure.in (modified) * c/src/tests/tmtests/configure.in (modified) * c/src/tests/tools/configure.in (modified) * c/src/tests/tools/generic/configure.in (modified) * configure.in (modified) * cpukit/itron/src/Makefile.am (modified) * cpukit/libmisc/cpuuse/Makefile.am (modified) * cpukit/libmisc/monitor/Makefile.am (modified) * cpukit/libmisc/rtmonuse/Makefile.am (modified) * cpukit/libmisc/stackchk/Makefile.am (modified) * cpukit/libmisc/untar/Makefile.am (modified) * cpukit/libmisc/wrapup/Makefile.am (modified) * cpukit/posix/src/Makefile.am (modified) * cpukit/rtems/src/Makefile.am (modified) * cpukit/sapi/src/Makefile.am (modified) * cpukit/score/src/Makefile.am (modified) * make/compilers/gcc-target-default.cfg (modified) * make/custom/gen68360.cfg (modified) * make/lib.cfg (modified) * scripts-ada/configure.in (modified) * scripts/configure.in (modified) * testsuites/samples/hello/Makefile.am (modified) * testsuites/samples/ticker/Makefile.am (modified) * tools/build/configure.in (modified) * tools/cpu/configure.in (modified) * tools/cpu/generic/configure.in (modified) * tools/cpu/hppa1.1/configure.in (modified) * tools/cpu/sh/configure.in (modified) * tools/cpu/unix/configure.in (modified) * tools/update/cipolish (modified) * tools/update/configure.in (modified) Patches rtems-rc-20000204-0.diff from Ralf Corsepius [95d9072] * aclocal/check-files-in.m4 (deleted) * aclocal/check-makefile.m4 (deleted) Obsolete files. Removed per recommendation from Ralf Corsepius ... Thu, 27 Jan 2000 17:06:49 GMT Joel Sherrill [1b2b923] * aclocal/check-bsps.m4 (modified) Patch to fix typo from Ralf Corsepius . Mon, 10 Jan 2000 20:56:35 GMT Joel Sherrill [6d3ab0f] * aclocal/bsp-alias.m4 (modified) * aclocal/check-bsps.m4 (modified) * make/custom/pc386.cfg (modified) * make/custom/pc486.cfg (added) * make/custom/pc586.cfg (added) Added pc486 and pc586 as aliases of pc386 with proper cpu flags. Fri, 07 Jan 2000 20:51:56 GMT Joel Sherrill [d273d78a] * aclocal/bsp-alias.m4 (modified) * make/custom/mcp750.cfg (modified) * make/custom/mvme2307.cfg (modified) Renaming mcp750 to motorola_shared since that is the basis for both ... Fri, 07 Jan 2000 14:47:02 GMT Joel Sherrill [0ff37e68] * aclocal/check-bsps.m4 (modified) * automake/lib.am (modified) * c/src/lib/libbsp/MERGE.PROCEDURE (modified) * c/src/lib/libbsp/Makefile.am.new (deleted) * c/src/lib/libcpu/powerpc/mpc6xx/Makefile.am (modified) * make/custom/gensh2.cfg (modified) * tools/update/rtems-polish.sh (modified) Patch rtems-rc-20000104-0.diff from Ralf Corsepius [fa178d49] * aclocal/project-root.m4 (modified) * c/src/lib/libbsp/configure.in (modified) Patch rtems-rc-19991203-3.diff from Ralf Corsepius [000a9a9] * aclocal/check-rdbg.m4 (modified) Patch rtems-rc-19991203-1.diff from Ralf Corsepius [fc81cc9] * aclocal/check-bsp-cache.m4 (added) * c/src/exec/score/cpu/powerpc/configure.in (added) Patch rtems-rc-19991123-rc-3.diff from Ralf Corsepius ... Tue, 30 Nov 1999 13:49:04 GMT Joel Sherrill [96344c8] * Makefile.am (modified) * aclocal/enable-itron.m4 (modified) * aclocal/enable-posix.m4 (modified) * make/custom/mcp750.cfg (modified) Patch rtems-rc-19991123-rc-0.diff from Ralf Corsepius [9f4868c] * Makefile.am (modified) * aclocal/enable-itron.m4 (modified) * aclocal/enable-networking.m4 (modified) * aclocal/enable-posix.m4 (modified) * c/src/exec/librpc/include/rpc/Makefile.am (modified) * c/src/libchip/network/Makefile.am (modified) * c/src/libchip/rtc/Makefile.am (modified) * c/src/libchip/serial/Makefile.am (modified) * c/src/libnetworking/include/Makefile.in (modified) * c/src/libnetworking/rtems_webserver/Makefile.in (modified) * c/src/libnetworking/wrapup/Makefile.in (modified) * c/src/librdbg/src/i386/Makefile.am (modified) * c/src/librdbg/src/i386/any/Makefile.in (modified) * c/src/librdbg/src/i386/pc386/Makefile.in (modified) * c/src/librpc/include/rpc/Makefile.am (modified) * c/src/librpc/src/Makefile.in (modified) * c/src/librtems++/src/Makefile.in (modified) * c/src/make/compilers/gcc-target-default.cfg (modified) * c/src/tests/psxtests/Makefile.am (modified) * c/src/tests/psxtests/configure.in (modified) * c/src/tests/support/stubdr/Makefile.in (modified) * c/src/wrapup/Makefile.in (modified) * cpukit/httpd/Makefile.in (modified) * cpukit/librpc/include/rpc/Makefile.am (modified) * make/compilers/gcc-target-default.cfg (modified) * make/custom/gensh1.cfg (modified) * make/custom/pc386.cfg (modified) * testsuites/psxtests/Makefile.am (modified) * tools/update/acpolish (modified) * tools/update/ampolish (modified) Miscellaneous patches from Ralf Corsepius ... Mon, 22 Nov 1999 13:41:11 GMT Joel Sherrill [9608320] * aclocal/check-cpu.m4 (modified) * aclocal/check-multiprocessing.m4 (modified) * aclocal/check-networking.m4 (modified) * aclocal/check-posix.m4 (modified) * aclocal/enable-rtemsbsp.m4 (modified) * automake/local.am (modified) * c/src/Makefile.am (modified) * c/src/exec/configure.in (modified) * c/src/exec/itron/include/Makefile.am (modified) * c/src/exec/itron/include/itronsys/Makefile.am (modified) * c/src/exec/itron/include/rtems/itron/Makefile.am (modified) * c/src/exec/itron/inline/rtems/itron/Makefile.am (modified) * c/src/exec/librpc/include/rpc/Makefile.am (modified) * c/src/exec/posix/configure.in (modified) * c/src/exec/posix/include/Makefile.am (modified) * c/src/exec/posix/include/rtems/posix/Makefile.am (modified) * c/src/exec/posix/include/sys/Makefile.am (modified) * c/src/exec/posix/inline/rtems/posix/Makefile.am (modified) * c/src/exec/posix/macros/rtems/posix/Makefile.am (modified) * c/src/exec/rtems/include/Makefile.am (modified) * c/src/exec/rtems/include/rtems/rtems/Makefile.am (modified) * c/src/exec/rtems/inline/rtems/rtems/Makefile.am (modified) * c/src/exec/rtems/macros/rtems/rtems/Makefile.am (modified) * c/src/exec/sapi/include/Makefile.am (modified) * c/src/exec/sapi/include/rtems/Makefile.am (modified) * c/src/exec/sapi/inline/rtems/Makefile.am (modified) * c/src/exec/sapi/macros/rtems/Makefile.am (modified) * c/src/exec/score/cpu/Makefile.in (modified) * c/src/exec/score/cpu/a29k/Makefile.in (modified) * c/src/exec/score/cpu/a29k/rtems/Makefile.in (modified) * c/src/exec/score/cpu/hppa1.1/Makefile.in (modified) * c/src/exec/score/cpu/hppa1.1/rtems/Makefile.in (modified) * c/src/exec/score/cpu/i386/Makefile.in (modified) * c/src/exec/score/cpu/i386/rtems/Makefile.in (modified) * c/src/exec/score/cpu/i960/Makefile.in (modified) * c/src/exec/score/cpu/i960/rtems/Makefile.in (modified) * c/src/exec/score/cpu/m68k/Makefile.in (modified) * c/src/exec/score/cpu/m68k/rtems/Makefile.in (modified) * c/src/exec/score/cpu/mips64orion/Makefile.in (modified) * c/src/exec/score/cpu/mips64orion/rtems/Makefile.in (modified) * c/src/exec/score/cpu/no_cpu/Makefile.in (modified) * c/src/exec/score/cpu/no_cpu/rtems/Makefile.in (modified) * c/src/exec/score/cpu/powerpc/Makefile.in (modified) * c/src/exec/score/cpu/sh/Makefile.in (modified) * c/src/exec/score/cpu/sh/rtems/Makefile.in (modified) * c/src/exec/score/cpu/sparc/Makefile.in (modified) * c/src/exec/score/cpu/sparc/rtems/Makefile.in (modified) * c/src/exec/score/cpu/unix/Makefile.in (modified) * c/src/exec/score/cpu/unix/rtems/Makefile.in (modified) * c/src/exec/score/include/rtems/Makefile.am (modified) * c/src/exec/score/inline/rtems/score/Makefile.am (modified) * c/src/exec/score/macros/rtems/score/Makefile.am (modified) * c/src/lib/include/Makefile.am (modified) * c/src/lib/include/motorola/Makefile.am (modified) * c/src/lib/include/sys/Makefile.am (modified) * c/src/lib/include/zilog/Makefile.am (modified) * c/src/lib/libbsp/Makefile.in (modified) * c/src/lib/libbsp/a29k/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/Makefile.in (modified) * c/src/lib/libbsp/bare/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/Makefile.in (modified) * c/src/lib/libbsp/i386/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/Makefile.in (modified) * c/src/lib/libbsp/i386/shared/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/Makefile.in (modified) * c/src/lib/libbsp/i960/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/Makefile.in (modified) * c/src/lib/libbsp/i960/rxgen960/Makefile.in (modified) * c/src/lib/libbsp/m68k/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/Makefile.in (modified) * c/src/lib/libbsp/powerpc/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mvme2307/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/Makefile.in (modified) * c/src/lib/libbsp/sh/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh2/Makefile.in (modified) * c/src/lib/libbsp/sparc/Makefile.in (modified) * c/src/lib/libbsp/unix/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/Makefile.in (modified) * c/src/lib/libcpu/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/Makefile.in (modified) * c/src/lib/libcpu/m68k/Makefile.in (modified) * c/src/lib/libcpu/m68k/m68040/Makefile.in (modified) * c/src/lib/libcpu/mips64orion/Makefile.in (modified) * c/src/lib/libcpu/powerpc/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc505/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc750/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc821/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/Makefile.in (modified) * c/src/lib/libcpu/sh/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7045/Makefile.in (modified) * c/src/lib/libcpu/sparc/Makefile.in (modified) * c/src/libchip/network/Makefile.am (added) * c/src/libchip/network/Makefile.in (deleted) * c/src/libchip/rtc/Makefile.am (added) * c/src/libchip/rtc/Makefile.in (deleted) * c/src/libchip/serial/Makefile.am (added) * c/src/libchip/serial/Makefile.in (deleted) * c/src/libmisc/configure.in (modified) * c/src/libmisc/cpuuse/Makefile.am (added) * c/src/libmisc/cpuuse/Makefile.in (deleted) * c/src/libmisc/dummy/Makefile.am (added) * c/src/libmisc/dummy/Makefile.in (deleted) * c/src/libmisc/dumpbuf/Makefile.am (added) * c/src/libmisc/dumpbuf/Makefile.in (deleted) * c/src/libmisc/monitor/Makefile.am (added) * c/src/libmisc/monitor/Makefile.in (deleted) * c/src/libmisc/rtmonuse/Makefile.am (added) * c/src/libmisc/rtmonuse/Makefile.in (deleted) * c/src/libmisc/stackchk/Makefile.am (added) * c/src/libmisc/stackchk/Makefile.in (deleted) * c/src/libmisc/untar/Makefile.am (added) * c/src/libmisc/untar/Makefile.in (deleted) * c/src/libmisc/wrapup/Makefile.am (added) * c/src/libmisc/wrapup/Makefile.in (deleted) * c/src/librdbg/include/rdbg/Makefile.am (modified) * c/src/librdbg/include/rdbg/i386/Makefile.am (modified) * c/src/librdbg/include/rdbg/powerpc/Makefile.am (modified) * c/src/librpc/include/rpc/Makefile.am (modified) * c/src/librtems++/include/rtems++/Makefile.am (modified) * c/src/make/README (modified) * c/src/make/compilers/gcc-target-default.cfg (modified) * c/src/make/directory.cfg (modified) * c/src/make/lib.cfg (modified) * c/src/make/main.cfg.in (modified) * c/src/tests/mptests/mp01/Makefile.in (modified) * c/src/tests/mptests/mp02/Makefile.in (modified) * c/src/tests/mptests/mp03/Makefile.in (modified) * c/src/tests/mptests/mp04/Makefile.in (modified) * c/src/tests/mptests/mp05/Makefile.in (modified) * c/src/tests/mptests/mp06/Makefile.in (modified) * c/src/tests/mptests/mp07/Makefile.in (modified) * c/src/tests/mptests/mp08/Makefile.in (modified) * c/src/tests/mptests/mp09/Makefile.in (modified) * c/src/tests/mptests/mp10/Makefile.in (modified) * c/src/tests/mptests/mp11/Makefile.in (modified) * c/src/tests/mptests/mp12/Makefile.in (modified) * c/src/tests/mptests/mp13/Makefile.in (modified) * c/src/tests/mptests/mp14/Makefile.in (modified) * c/src/tests/psxtests/support/Makefile.in (modified) * c/src/tests/samples/base_mp/Makefile.in (modified) * c/src/tests/tools/generic/Makefile.am (modified) * cpukit/itron/include/Makefile.am (modified) * cpukit/libmisc/cpuuse/Makefile.am (added) * cpukit/libmisc/dummy/Makefile.am (added) * cpukit/libmisc/dumpbuf/Makefile.am (added) * cpukit/libmisc/monitor/Makefile.am (added) * cpukit/libmisc/rtmonuse/Makefile.am (added) * cpukit/libmisc/stackchk/Makefile.am (added) * cpukit/libmisc/untar/Makefile.am (added) * cpukit/libmisc/wrapup/Makefile.am (added) * cpukit/librpc/include/rpc/Makefile.am (modified) * cpukit/posix/include/Makefile.am (modified) * cpukit/rtems/include/Makefile.am (modified) * cpukit/sapi/include/Makefile.am (modified) * make/README (modified) * make/Templates/Makefile.dir (modified) * make/compilers/gcc-target-default.cfg (modified) * make/custom/Linux-posix.cfg (modified) * make/custom/erc32.cfg (modified) * make/directory.cfg (modified) * make/lib.cfg (modified) * make/main.cfg (modified) * testsuites/tools/generic/Makefile.am (modified) Patch rtems-rc-19991117-4.diff from Ralf Corsepius [c73b8ac2] * aclocal/check-itron.m4 (added) * aclocal/enable-itron.m4 (added) * c/src/lib/libbsp/shared/console.c (modified) * c/src/lib/wrapup/Makefile.in (modified) * c/src/make/Makefile.inc.in (modified) * c/src/make/bsp.cfg.in (modified) * c/src/make/configure.in (modified) * c/src/make/target.cfg.in (modified) * c/src/wrapup/Makefile.in (modified) * configure.in (modified) * make/target.cfg.in (modified) * tools/update/cipolish (modified) This patch adds the basic framework for the ITRON 3.0 API ... Mon, 11 Oct 1999 15:50:20 GMT Joel Sherrill [78ffe89] * aclocal/bsp-alias.m4 (modified) * aclocal/canonical-target-name.m4 (modified) * aclocal/canonicalize-tools.m4 (modified) * aclocal/check-bsps.m4 (modified) * aclocal/enable-posix.m4 (modified) * aclocal/gcc-pipe.m4 (modified) Patch from Ralf Corsepius Removed all ... Mon, 11 Oct 1999 15:34:26 GMT Joel Sherrill [45269dc] * aclocal/check-rdbg.m4 (modified) * c/src/configure.in (modified) * c/src/exec/libcsupport/Makefile.am (modified) * c/src/lib/Makefile.am (modified) * c/src/lib/configure.in (modified) * c/src/lib/include/Makefile.am (modified) * c/src/librdbg/src/Makefile.in (modified) * c/src/librdbg/src/configure.in (deleted) * c/src/librdbg/src/i386/Makefile.in (modified) * c/src/librdbg/src/i386/any/Makefile.in (modified) * c/src/librdbg/src/i386/pc386/Makefile.in (modified) * c/src/librdbg/src/powerpc/Makefile.in (modified) * c/src/librdbg/src/powerpc/mcp750/Makefile.in (modified) * cpukit/libcsupport/Makefile.am (modified) Patch from Ralf Corsepius to move librdbg ... Mon, 04 Oct 1999 18:20:14 GMT Joel Sherrill [b62a92c] * aclocal/check-bsps.m4 (modified) * aclocal/check-cpu.m4 (modified) * aclocal/check-multiprocessing.m4 (modified) * aclocal/check-networking.m4 (modified) * aclocal/check-posix.m4 (modified) * aclocal/check-rdbg.m4 (modified) * aclocal/enable-networking.m4 (modified) * aclocal/enable-posix.m4 (modified) * aclocal/enable-rdbg.m4 (modified) * aclocal/enable-rtemsbsp.m4 (modified) * aclocal/gcc-specs.m4 (modified) * aclocal/prog-cc.m4 (modified) * aclocal/prog-cxx.m4 (modified) * aclocal/rtems-top.m4 (modified) * c/configure.in (modified) * c/src/configure.in (modified) * c/src/exec/libcsupport/Makefile.am (modified) * c/src/lib/Makefile.am (modified) * c/src/lib/configure.in (modified) * c/src/lib/include/Makefile.am (modified) * c/src/lib/libbsp/configure.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/configure.in (modified) * c/src/lib/libbsp/i386/pc386/tools/configure.in (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/configure.in (modified) * c/src/lib/libbsp/m68k/mvme162/tools/configure.in (modified) * c/src/lib/libbsp/powerpc/psim/tools/configure.in (modified) * c/src/lib/libbsp/sparc/erc32/tools/configure.in (modified) * c/src/lib/libbsp/unix/posix/tools/configure.in (modified) * c/src/lib/libchip/configure.in (modified) * c/src/lib/libcpu/configure.in (modified) * c/src/lib/libnetworking/configure.in (modified) * c/src/lib/librdbg/configure.in (modified) * c/src/lib/librpc/Makefile.in (deleted) * c/src/lib/librpc/aclocal.m4 (deleted) * c/src/lib/librpc/configure (deleted) * c/src/lib/librpc/configure.in (deleted) * c/src/lib/librpc/rpc_callmsg.c (deleted) * c/src/lib/librpc/rpc_prot.c (deleted) * c/src/lib/librpc/svc.c (deleted) * c/src/lib/librpc/svc_auth.c (deleted) * c/src/lib/librpc/svc_udp.c (deleted) * c/src/lib/librpc/xdr.c (deleted) * c/src/lib/librpc/xdr_array.c (deleted) * c/src/lib/librpc/xdr_mem.c (deleted) * c/src/lib/start/a29k/configure.in (modified) * c/src/lib/start/i960/configure.in (modified) * c/src/lib/start/m68k/configure.in (modified) * c/src/lib/start/mips64orion/configure.in (modified) * c/src/lib/start/sh/configure.in (modified) * c/src/libchip/configure.in (modified) * c/src/libnetworking/configure.in (modified) * c/src/librdbg/src/configure.in (modified) * c/src/librpc/src/Makefile.in (modified) * c/src/librtems++/configure.in (modified) * c/src/make/configure.in (modified) * c/src/tests/support/configure.in (modified) * c/src/tests/tools/configure.in (modified) * c/src/tests/tools/generic/configure.in (modified) * cpukit/libcsupport/Makefile.am (modified) * tools/build/configure.in (modified) * tools/cpu/configure.in (modified) * tools/cpu/generic/configure.in (modified) * tools/cpu/hppa1.1/configure.in (modified) * tools/cpu/sh/configure.in (modified) * tools/cpu/unix/configure.in (modified) * tools/update/configure.in (modified) Patch from Ralf Corsepius : The patch ... Tue, 07 Sep 1999 13:45:03 GMT Joel Sherrill [e1d8abb] * Makefile.in (modified) * aclocal/check-cxx.m4 (modified) * automake/local.am (modified) * c/Makefile.in (modified) * c/src/Makefile.am (modified) * c/src/Makefile.in (modified) * c/src/aclocal.m4 (modified) * c/src/configure (modified) * c/src/configure.in (modified) * c/src/exec/Makefile.am (added) * c/src/exec/Makefile.in (modified) * c/src/exec/aclocal.m4 (modified) * c/src/exec/configure (modified) * c/src/exec/configure.in (modified) * c/src/exec/libcsupport/Makefile.am (added) * c/src/exec/libnetworking/Makefile.am (added) * c/src/exec/librpc/include/rpc/Makefile.am (added) * c/src/exec/posix/Makefile.am (added) * c/src/exec/posix/Makefile.in (modified) * c/src/exec/posix/configure.in (added) * c/src/exec/posix/include/Makefile.am (added) * c/src/exec/posix/include/Makefile.in (modified) * c/src/exec/posix/include/rtems/Makefile.am (added) * c/src/exec/posix/include/rtems/Makefile.in (modified) * c/src/exec/posix/include/rtems/posix/Makefile.am (added) * c/src/exec/posix/include/rtems/posix/Makefile.in (modified) * c/src/exec/posix/include/sys/Makefile.am (added) * c/src/exec/posix/include/sys/Makefile.in (modified) * c/src/exec/posix/inline/Makefile.am (added) * c/src/exec/posix/inline/Makefile.in (modified) * c/src/exec/posix/inline/rtems/Makefile.am (added) * c/src/exec/posix/inline/rtems/Makefile.in (modified) * c/src/exec/posix/inline/rtems/posix/Makefile.am (added) * c/src/exec/posix/inline/rtems/posix/Makefile.in (modified) * c/src/exec/posix/macros/Makefile.am (added) * c/src/exec/posix/macros/Makefile.in (modified) * c/src/exec/posix/macros/rtems/Makefile.am (added) * c/src/exec/posix/macros/rtems/Makefile.in (modified) * c/src/exec/posix/macros/rtems/posix/Makefile.am (added) * c/src/exec/posix/macros/rtems/posix/Makefile.in (modified) * c/src/exec/posix/optman/Makefile.in (modified) * c/src/exec/posix/src/Makefile.in (modified) * c/src/exec/rtems/Makefile.am (added) * c/src/exec/rtems/Makefile.in (modified) * c/src/exec/rtems/include/Makefile.am (added) * c/src/exec/rtems/include/Makefile.in (modified) * c/src/exec/rtems/include/rtems/Makefile.am (added) * c/src/exec/rtems/include/rtems/Makefile.in (modified) * c/src/exec/rtems/include/rtems/rtems/Makefile.am (added) * c/src/exec/rtems/include/rtems/rtems/Makefile.in (modified) * c/src/exec/rtems/inline/Makefile.am (added) * c/src/exec/rtems/inline/Makefile.in (modified) * c/src/exec/rtems/inline/rtems/Makefile.am (added) * c/src/exec/rtems/inline/rtems/Makefile.in (modified) * c/src/exec/rtems/inline/rtems/rtems/Makefile.am (added) * c/src/exec/rtems/inline/rtems/rtems/Makefile.in (modified) * c/src/exec/rtems/macros/Makefile.am (added) * c/src/exec/rtems/macros/Makefile.in (modified) * c/src/exec/rtems/macros/rtems/Makefile.am (added) * c/src/exec/rtems/macros/rtems/Makefile.in (modified) * c/src/exec/rtems/macros/rtems/rtems/Makefile.am (added) * c/src/exec/rtems/macros/rtems/rtems/Makefile.in (modified) * c/src/exec/sapi/Makefile.am (added) * c/src/exec/sapi/Makefile.in (modified) * c/src/exec/sapi/include/Makefile.am (added) * c/src/exec/sapi/include/Makefile.in (modified) * c/src/exec/sapi/include/rtems/Makefile.am (added) * c/src/exec/sapi/include/rtems/Makefile.in (modified) * c/src/exec/sapi/inline/Makefile.am (added) * c/src/exec/sapi/inline/Makefile.in (modified) * c/src/exec/sapi/inline/rtems/Makefile.am (added) * c/src/exec/sapi/inline/rtems/Makefile.in (modified) * c/src/exec/sapi/macros/Makefile.am (added) * c/src/exec/sapi/macros/Makefile.in (modified) * c/src/exec/sapi/macros/rtems/Makefile.am (added) * c/src/exec/sapi/macros/rtems/Makefile.in (modified) * c/src/exec/score/Makefile.am (added) * c/src/exec/score/Makefile.in (modified) * c/src/exec/score/cpu/Makefile.in (modified) * c/src/exec/score/cpu/a29k/Makefile.in (modified) * c/src/exec/score/cpu/a29k/rtems/Makefile.in (modified) * c/src/exec/score/cpu/a29k/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/a29k/wrap/Makefile.in (modified) * c/src/exec/score/cpu/configure.in (added) * c/src/exec/score/cpu/hppa1.1/Makefile.in (modified) * c/src/exec/score/cpu/hppa1.1/rtems/Makefile.in (modified) * c/src/exec/score/cpu/hppa1.1/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/hppa1.1/wrap/Makefile.in (modified) * c/src/exec/score/cpu/i386/Makefile.in (modified) * c/src/exec/score/cpu/i386/rtems/Makefile.in (modified) * c/src/exec/score/cpu/i386/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/i386/wrap/Makefile.in (modified) * c/src/exec/score/cpu/i960/Makefile.in (modified) * c/src/exec/score/cpu/i960/rtems/Makefile.in (modified) * c/src/exec/score/cpu/i960/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/i960/wrap/Makefile.in (modified) * c/src/exec/score/cpu/m68k/Makefile.in (modified) * c/src/exec/score/cpu/m68k/rtems/Makefile.in (modified) * c/src/exec/score/cpu/m68k/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/m68k/wrap/Makefile.in (modified) * c/src/exec/score/cpu/mips64orion/Makefile.in (modified) * c/src/exec/score/cpu/mips64orion/rtems/Makefile.in (modified) * c/src/exec/score/cpu/mips64orion/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/mips64orion/wrap/Makefile.in (modified) * c/src/exec/score/cpu/no_cpu/Makefile.in (modified) * c/src/exec/score/cpu/no_cpu/rtems/Makefile.in (modified) * c/src/exec/score/cpu/no_cpu/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/no_cpu/wrap/Makefile.in (modified) * c/src/exec/score/cpu/powerpc/Makefile.in (modified) * c/src/exec/score/cpu/powerpc/mpc750/Makefile.in (modified) * c/src/exec/score/cpu/powerpc/other_cpu/Makefile.in (modified) * c/src/exec/score/cpu/powerpc/shared/Makefile.in (modified) * c/src/exec/score/cpu/powerpc/wrap/Makefile.in (modified) * c/src/exec/score/cpu/sh/Makefile.in (modified) * c/src/exec/score/cpu/sh/rtems/Makefile.in (modified) * c/src/exec/score/cpu/sh/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/sh/wrap/Makefile.in (modified) * c/src/exec/score/cpu/sparc/Makefile.in (modified) * c/src/exec/score/cpu/sparc/rtems/Makefile.in (modified) * c/src/exec/score/cpu/sparc/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/sparc/wrap/Makefile.in (modified) * c/src/exec/score/cpu/unix/Makefile.in (modified) * c/src/exec/score/cpu/unix/rtems/Makefile.in (modified) * c/src/exec/score/cpu/unix/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/unix/wrap/Makefile.in (modified) * c/src/exec/score/include/Makefile.am (added) * c/src/exec/score/include/Makefile.in (modified) * c/src/exec/score/include/rtems/Makefile.am (added) * c/src/exec/score/include/rtems/Makefile.in (modified) * c/src/exec/score/inline/Makefile.am (added) * c/src/exec/score/inline/Makefile.in (modified) * c/src/exec/score/inline/rtems/Makefile.am (added) * c/src/exec/score/inline/rtems/Makefile.in (modified) * c/src/exec/score/inline/rtems/score/Makefile.am (added) * c/src/exec/score/inline/rtems/score/Makefile.in (modified) * c/src/exec/score/macros/Makefile.am (added) * c/src/exec/score/macros/Makefile.in (modified) * c/src/exec/score/macros/rtems/Makefile.am (added) * c/src/exec/score/macros/rtems/Makefile.in (modified) * c/src/exec/score/macros/rtems/score/Makefile.am (added) * c/src/exec/score/macros/rtems/score/Makefile.in (modified) * c/src/exec/wrapup/Makefile.am (added) * c/src/exec/wrapup/Makefile.in (modified) * c/src/exec/wrapup/posix/Makefile.in (modified) * c/src/lib/Makefile.am (added) * c/src/lib/Makefile.in (modified) * c/src/lib/aclocal.m4 (modified) * c/src/lib/configure (modified) * c/src/lib/configure.in (modified) * c/src/lib/include/Makefile.am (added) * c/src/lib/include/Makefile.in (modified) * c/src/lib/include/motorola/Makefile.am (added) * c/src/lib/include/rdbg/Makefile.am (added) * c/src/lib/include/rdbg/i386/Makefile.am (added) * c/src/lib/include/rdbg/powerpc/Makefile.am (added) * c/src/lib/include/rpc/Makefile.am (added) * c/src/lib/include/sys/Makefile.am (added) * c/src/lib/include/zilog/Makefile.am (added) * c/src/lib/libbsp/Makefile.am.new (added) * c/src/lib/libbsp/Makefile.in (modified) * c/src/lib/libbsp/a29k/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/console/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/include/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/start/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/startup/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/wrapup/Makefile.in (modified) * c/src/lib/libbsp/bare/Makefile.in (modified) * c/src/lib/libbsp/bare/include/Makefile.in (modified) * c/src/lib/libbsp/bare/wrapup/Makefile.in (modified) * c/src/lib/libbsp/configure.in (added) * c/src/lib/libbsp/hppa1.1/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/pxfl/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/include/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/start/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/startup/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tty/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/console/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/include/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/start/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/console/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/include/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/console/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/include/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/network/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/start/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/3c509/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/console/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/dec21140/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/include/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/ne2000/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/start/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/tools/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/wd8003/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/shared/Makefile.in (modified) * c/src/lib/libbsp/i386/shared/comm/Makefile.in (modified) * c/src/lib/libbsp/i386/shared/io/Makefile.in (modified) * c/src/lib/libbsp/i386/shared/irq/Makefile.in (modified) * c/src/lib/libbsp/i386/shared/pci/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/console/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/include/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/network/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/start/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/dos_sup/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/ts_1325_ada/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i960/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/clock/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/console/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/include/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/start/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/startup/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/timer/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/spurious/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/spurious/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/start332/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/spurious/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/start68k/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/start302/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/start340/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/network/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/start360/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/consolex/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/tod/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/tools/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/bsp_specs (modified) * c/src/lib/libbsp/m68k/mvme167/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/fatal/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/start302/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/wrapup/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/console/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/include/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/liblnk/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/start/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/startup/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/wrapup/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/clock/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/console/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/include/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/timer/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/clock/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/scv64/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/sonic/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/timer/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/tod/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/canbus/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/network/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/dlentry/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/flashentry/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/bootloader/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/irq/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/openpic/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/pci/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/residual/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/vectors/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/irq/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/openpic/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/pci/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/residual/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/vectors/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/dlentry/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/flashentry/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/clock/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/network/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/nvram/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/pci/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/timer/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/tod/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/universe/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/vectors/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/clock/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/startsim/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/timer/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/tools/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/vectors/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/PCI_bus/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/clock/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/timer/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/tod/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/vectors/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/wrapup/Makefile.in (modified) * c/src/lib/libbsp/sh/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/include/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/scitab/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/start/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/startup/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/wrapup/Makefile.in (modified) * c/src/lib/libbsp/shmdr/Makefile.in (modified) * c/src/lib/libbsp/sparc/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/clock/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/console/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/gnatsupp/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/include/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/start/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/startsis/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/startup/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/timer/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/tools/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/wrapup/Makefile.in (modified) * c/src/lib/libbsp/unix/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/clock/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/console/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/include/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/startup/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/timer/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/tools/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/wrapup/Makefile.in (modified) * c/src/lib/libchip/Makefile.am (added) * c/src/lib/libchip/Makefile.in (modified) * c/src/lib/libchip/configure.in (added) * c/src/lib/libchip/network/Makefile.in (modified) * c/src/lib/libchip/rtc/Makefile.in (modified) * c/src/lib/libchip/serial/Makefile.in (modified) * c/src/lib/libcpu/Makefile.in (modified) * c/src/lib/libcpu/configure.in (added) * c/src/lib/libcpu/hppa1.1/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/clock/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/include/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/milli/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/runway/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/semaphore/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/timer/Makefile.in (modified) * c/src/lib/libcpu/i386/Makefile.in (modified) * c/src/lib/libcpu/i386/wrapup/Makefile.in (modified) * c/src/lib/libcpu/m68k/Makefile.in (modified) * c/src/lib/libcpu/m68k/m68040/Makefile.in (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/Makefile.in (modified) * c/src/lib/libcpu/mips64orion/Makefile.in (modified) * c/src/lib/libcpu/mips64orion/clock/Makefile.in (modified) * c/src/lib/libcpu/mips64orion/include/Makefile.in (modified) * c/src/lib/libcpu/mips64orion/timer/Makefile.in (modified) * c/src/lib/libcpu/powerpc/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc505/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc505/timer/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc505/vectors/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc750/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc750/clock/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc750/exceptions/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc750/mmu/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc750/wrapup/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc821/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc821/clock/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc821/console-generic/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc821/include/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc821/timer/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc821/vectors/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/clock/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/console-generic/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/include/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/timer/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/vectors/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/clock/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/console/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/ictrl/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/include/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/timer/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/vectors/Makefile.in (modified) * c/src/lib/libcpu/powerpc/shared/Makefile.in (modified) * c/src/lib/libcpu/powerpc/wrapup/Makefile.in (modified) * c/src/lib/libcpu/sh/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/clock/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/console/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/include/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/null/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/timer/Makefile.in (modified) * c/src/lib/libcpu/sparc/Makefile.in (modified) * c/src/lib/libcpu/sparc/reg_win/Makefile.in (modified) * c/src/lib/libcpu/sparc/syscall/Makefile.in (modified) * c/src/lib/libmisc/Makefile.am (added) * c/src/lib/libmisc/Makefile.in (modified) * c/src/lib/libmisc/assoc/Makefile.in (modified) * c/src/lib/libmisc/configure.in (added) * c/src/lib/libmisc/cpuuse/Makefile.in (modified) * c/src/lib/libmisc/dumpbuf/Makefile.in (modified) * c/src/lib/libmisc/error/Makefile.in (modified) * c/src/lib/libmisc/monitor/Makefile.in (modified) * c/src/lib/libmisc/rtmonuse/Makefile.in (modified) * c/src/lib/libmisc/stackchk/Makefile.in (modified) * c/src/lib/libmisc/untar/Makefile.in (modified) * c/src/lib/libmisc/wrapup/Makefile.in (modified) * c/src/lib/libnetworking/Makefile.am (added) * c/src/lib/libnetworking/Makefile.in (modified) * c/src/lib/libnetworking/configure.in (added) * c/src/lib/libnetworking/include/Makefile.in (modified) * c/src/lib/libnetworking/kern/Makefile.in (modified) * c/src/lib/libnetworking/lib/Makefile.in (modified) * c/src/lib/libnetworking/libc/Makefile.in (modified) * c/src/lib/libnetworking/net/Makefile.in (modified) * c/src/lib/libnetworking/netinet/Makefile.in (modified) * c/src/lib/libnetworking/nfs/Makefile.in (modified) * c/src/lib/libnetworking/rtems/Makefile.in (modified) * c/src/lib/libnetworking/rtems_servers/Makefile.in (modified) * c/src/lib/libnetworking/wrapup/Makefile.in (modified) * c/src/lib/librdbg/Makefile.in (modified) * c/src/lib/librdbg/configure.in (added) * c/src/lib/librdbg/i386/Makefile.in (modified) * c/src/lib/librdbg/i386/pc386/Makefile.in (modified) * c/src/lib/librdbg/powerpc/Makefile.in (modified) * c/src/lib/librdbg/powerpc/mcp750/Makefile.in (modified) * c/src/lib/librpc/Makefile.in (modified) * c/src/lib/librpc/configure.in (added) * c/src/lib/start/Makefile.am (added) * c/src/lib/start/Makefile.in (modified) * c/src/lib/start/a29k/Makefile.in (modified) * c/src/lib/start/a29k/configure.in (added) * c/src/lib/start/i960/Makefile.in (modified) * c/src/lib/start/i960/configure.in (added) * c/src/lib/start/m68k/Makefile.in (modified) * c/src/lib/start/m68k/configure.in (added) * c/src/lib/start/mips64orion/Makefile.in (modified) * c/src/lib/start/mips64orion/configure.in (added) * c/src/lib/start/sh/Makefile.in (modified) * c/src/lib/start/sh/configure.in (added) * c/src/libchip/Makefile.am (added) * c/src/libchip/configure.in (added) * c/src/libchip/network/Makefile.in (modified) * c/src/libchip/rtc/Makefile.in (modified) * c/src/libchip/serial/Makefile.in (modified) * c/src/libmisc/Makefile.am (added) * c/src/libmisc/assoc/Makefile.in (modified) * c/src/libmisc/configure.in (added) * c/src/libmisc/cpuuse/Makefile.in (modified) * c/src/libmisc/dumpbuf/Makefile.in (modified) * c/src/libmisc/error/Makefile.in (modified) * c/src/libmisc/monitor/Makefile.in (modified) * c/src/libmisc/rtmonuse/Makefile.in (modified) * c/src/libmisc/stackchk/Makefile.in (modified) * c/src/libmisc/untar/Makefile.in (modified) * c/src/libmisc/wrapup/Makefile.in (modified) * c/src/libnetworking/Makefile.am (added) * c/src/libnetworking/Makefile.in (modified) * c/src/libnetworking/configure.in (added) * c/src/libnetworking/include/Makefile.in (modified) * c/src/libnetworking/kern/Makefile.in (modified) * c/src/libnetworking/lib/Makefile.in (modified) * c/src/libnetworking/libc/Makefile.in (modified) * c/src/libnetworking/net/Makefile.in (modified) * c/src/libnetworking/netinet/Makefile.in (modified) * c/src/libnetworking/nfs/Makefile.in (modified) * c/src/libnetworking/rtems/Makefile.in (modified) * c/src/libnetworking/rtems_servers/Makefile.in (modified) * c/src/libnetworking/wrapup/Makefile.in (modified) * c/src/librdbg/include/rdbg/Makefile.am (added) * c/src/librdbg/include/rdbg/i386/Makefile.am (added) * c/src/librdbg/include/rdbg/powerpc/Makefile.am (added) * c/src/librdbg/src/Makefile.in (modified) * c/src/librdbg/src/configure.in (added) * c/src/librdbg/src/i386/Makefile.in (modified) * c/src/librdbg/src/i386/any/Makefile.in (modified) * c/src/librdbg/src/i386/pc386/Makefile.in (modified) * c/src/librdbg/src/powerpc/Makefile.in (modified) * c/src/librdbg/src/powerpc/mcp750/Makefile.in (modified) * c/src/librpc/include/rpc/Makefile.am (added) * c/src/librpc/src/Makefile.in (modified) * c/src/librtems++/Makefile.am (added) * c/src/librtems++/Makefile.in (added) * c/src/librtems++/aclocal.m4 (added) * c/src/librtems++/configure (added) * c/src/librtems++/configure.in (added) * c/src/librtems++/include/Makefile.am (added) * c/src/librtems++/include/Makefile.in (added) * c/src/librtems++/include/rtems++/Makefile.am (added) * c/src/librtems++/include/rtems++/Makefile.in (added) * c/src/make/Makefile.in (modified) * c/src/make/aclocal.m4 (modified) * c/src/make/compilers/Makefile.in (modified) * c/src/make/custom/Makefile.in (modified) * c/src/make/custom/default.cfg.in (modified) * c/src/tests/Makefile.in (modified) * c/src/tests/libtests/Makefile.in (modified) * c/src/tests/libtests/aclocal.m4 (modified) * c/src/tests/mptests/Makefile.in (modified) * c/src/tests/psxtests/Makefile.in (modified) * c/src/tests/samples/Makefile.in (modified) * c/src/tests/samples/aclocal.m4 (modified) * c/src/tests/sptests/Makefile.in (modified) * c/src/tests/support/Makefile.in (modified) * c/src/tests/support/include/Makefile.in (modified) * c/src/tests/tmtests/Makefile.in (modified) * c/src/tests/tmtests/include/Makefile.in (modified) * c/src/tests/tools/Makefile.in (modified) * c/src/tests/tools/generic/Makefile.in (modified) * cpukit/Makefile.am (added) * cpukit/libcsupport/Makefile.am (added) * cpukit/libmisc/Makefile.am (added) * cpukit/libnetworking/Makefile.am (added) * cpukit/librpc/include/rpc/Makefile.am (added) * cpukit/posix/Makefile.am (added) * cpukit/posix/include/Makefile.am (added) * cpukit/posix/inline/Makefile.am (added) * cpukit/posix/macros/Makefile.am (added) * cpukit/rtems/Makefile.am (added) * cpukit/rtems/include/Makefile.am (added) * cpukit/rtems/inline/Makefile.am (added) * cpukit/rtems/macros/Makefile.am (added) * cpukit/sapi/Makefile.am (added) * cpukit/sapi/include/Makefile.am (added) * cpukit/sapi/inline/Makefile.am (added) * cpukit/sapi/macros/Makefile.am (added) * cpukit/score/Makefile.am (added) * cpukit/score/include/Makefile.am (added) * cpukit/score/inline/Makefile.am (added) * cpukit/score/macros/Makefile.am (added) * cpukit/wrapup/Makefile.am (added) * doc/Makefile.in (modified) * make/Makefile.in (modified) * make/Templates/Makefile.in (modified) * make/compilers/Makefile.in (modified) * make/custom/Makefile.in (modified) * tools/Makefile.in (modified) * tools/build/Makefile.in (modified) * tools/build/configure (modified) * tools/build/configure.in (modified) * tools/cpu/Makefile.am (modified) * tools/cpu/Makefile.in (modified) * tools/cpu/configure (modified) * tools/cpu/configure.in (modified) * tools/cpu/generic/Makefile.in (modified) * tools/cpu/sh/Makefile.in (modified) * tools/cpu/unix/Makefile.in (modified) * tools/update/Makefile.in (modified) * tools/update/configure (modified) * tools/update/configure.in (modified) Applied patch rtems-rc-19990820-6.diff.gz from Ralf Corsepius ... Wed, 18 Aug 1999 16:49:52 GMT Joel Sherrill [6fc973e] * aclocal.m4 (modified) * aclocal/target.m4 (modified) * c/src/exec/libcsupport/src/malloc.c (modified) * c/src/lib/configure (modified) * c/src/lib/configure.in (modified) * c/src/lib/include/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/startup/bspstart.c (modified) * c/src/lib/libc/Makefile.in (modified) * c/src/lib/libc/malloc.c (modified) * c/src/lib/libmisc/monitor/mon-symbols.c (modified) * c/src/libmisc/monitor/mon-symbols.c (modified) * configure (modified) * cpukit/libcsupport/src/malloc.c (modified) * cpukit/libmisc/monitor/mon-symbols.c (modified) * make/custom/Linux-posix.cfg (modified) Patch from Ralf Corsepius : Here is ... Thu, 12 Aug 1999 18:22:17 GMT Joel Sherrill [ea562ee9] * aclocal/sysv-ipc.m4 (modified) * c/src/exec/aclocal.m4 (modified) * c/src/exec/configure (modified) * c/src/exec/score/cpu/unix/cpu.c (modified) * c/src/exec/score/cpu/unix/wrap/Makefile.in (modified) * c/src/lib/aclocal.m4 (modified) * c/src/lib/configure (modified) * c/src/lib/configure.in (modified) * c/src/make/configure (modified) * c/src/make/configure.in (modified) * c/src/make/custom/Makefile.am (modified) * c/src/make/custom/Makefile.in (modified) * c/src/make/custom/default.cfg.in (modified) * cpukit/score/cpu/unix/cpu.c (modified) * make/custom/mcp750.cfg (modified) * make/custom/posix.cfg (modified) Patch from Ralf Corsepius : After ... Tue, 10 Aug 1999 15:38:09 GMT Joel Sherrill [908436c1] * aclocal/check-cxx.m4 (added) * aclocal/check-networking.m4 (added) * aclocal/check-posix.m4 (added) * c/src/lib/libbsp/bare/include/coverhd.h (added) * c/src/tests/Makefile.am (added) * c/src/tests/libtests/Makefile.am (added) * c/src/tests/libtests/aclocal.m4 (added) * c/src/tests/libtests/configure (added) * c/src/tests/libtests/configure.in (added) * c/src/tests/mptests/Makefile.am (added) * c/src/tests/mptests/aclocal.m4 (added) * c/src/tests/mptests/configure (added) * c/src/tests/mptests/configure.in (added) * c/src/tests/psxtests/Makefile.am (added) * c/src/tests/psxtests/aclocal.m4 (added) * c/src/tests/psxtests/configure (added) * c/src/tests/psxtests/configure.in (added) * c/src/tests/samples/Makefile.am (added) * c/src/tests/samples/aclocal.m4 (added) * c/src/tests/samples/configure (added) * c/src/tests/samples/configure.in (added) * c/src/tests/sptests/Makefile.am (added) * c/src/tests/sptests/aclocal.m4 (added) * c/src/tests/sptests/configure (added) * c/src/tests/sptests/configure.in (added) * c/src/tests/support/Makefile.am (added) * c/src/tests/support/aclocal.m4 (added) * c/src/tests/support/configure (added) * c/src/tests/support/configure.in (added) * c/src/tests/support/include/Makefile.am (added) * c/src/tests/tmtests/Makefile.am (added) * c/src/tests/tmtests/aclocal.m4 (added) * c/src/tests/tmtests/configure (added) * c/src/tests/tmtests/configure.in (added) * c/src/tests/tmtests/include/Makefile.am (added) * c/src/tests/tools/Makefile.am (added) * c/src/tests/tools/aclocal.m4 (added) * c/src/tests/tools/configure (added) * c/src/tests/tools/configure.in (added) * testsuites/Makefile.am (added) * testsuites/libtests/Makefile.am (added) * testsuites/mptests/Makefile.am (added) * testsuites/psxtests/Makefile.am (added) * testsuites/samples/Makefile.am (added) * testsuites/sptests/Makefile.am (added) * testsuites/support/Makefile.am (added) * testsuites/tmtests/Makefile.am (added) * testsuites/tmtests/include/Makefile.am (added) * testsuites/tools/Makefile.am (added) New configuration files added by patch from Ralf Corsepius ... Fri, 06 Aug 1999 17:55:25 GMT Joel Sherrill [3a8915e] * aclocal/check-multiprocessing.m4 (modified) * aclocal/check-rdbg.m4 (modified) * c/Makefile.am (modified) * c/src/exec/aclocal.m4 (modified) * c/src/exec/configure (modified) * c/src/exec/configure.in (modified) * c/src/lib/aclocal.m4 (modified) * c/src/lib/configure (modified) * c/src/lib/configure.in (modified) * c/src/lib/include/Makefile.in (modified) * c/src/lib/libbsp/bare/include/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/bsp_specs (modified) * c/src/lib/libbsp/i386/pc386/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/startup/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/startup/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/startup/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/startup/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/start/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/startup/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/startup/Makefile.in (modified) * c/src/lib/libmisc/wrapup/Makefile.in (modified) * c/src/lib/start/sh/Makefile.in (modified) * c/src/libmisc/wrapup/Makefile.in (modified) * c/src/make/Makefile.am (modified) * c/src/make/Makefile.in (modified) * c/src/make/Makefile.inc.in (modified) * c/src/make/Templates/Makefile.in (modified) * c/src/make/aclocal.m4 (modified) * c/src/make/bsp.cfg.in (modified) * c/src/make/compilers/Makefile.in (modified) * c/src/make/compilers/gcc-target-default.cfg (modified) * c/src/make/configure (modified) * c/src/make/configure.in (modified) * c/src/make/custom/Makefile.in (modified) * c/src/make/custom/default.cfg.in (modified) * c/src/make/host.cfg.in (modified) * c/src/tests/Makefile.in (modified) * c/src/tests/aclocal.m4 (modified) * c/src/tests/configure (modified) * c/src/tests/configure.in (modified) * c/src/tests/libtests/Makefile.in (modified) * c/src/tests/libtests/cpuuse/Makefile.in (modified) * c/src/tests/libtests/malloctest/Makefile.in (modified) * c/src/tests/libtests/monitor/Makefile.in (modified) * c/src/tests/libtests/rtems++/Makefile.in (modified) * c/src/tests/libtests/rtmonuse/Makefile.in (modified) * c/src/tests/libtests/stackchk/Makefile.in (modified) * c/src/tests/libtests/termios/Makefile.in (modified) * c/src/tests/mptests/Makefile.in (modified) * c/src/tests/mptests/mp01/Makefile.in (modified) * c/src/tests/mptests/mp01/node1/Makefile.in (modified) * c/src/tests/mptests/mp01/node2/Makefile.in (modified) * c/src/tests/mptests/mp02/Makefile.in (modified) * c/src/tests/mptests/mp02/node1/Makefile.in (modified) * c/src/tests/mptests/mp02/node2/Makefile.in (modified) * c/src/tests/mptests/mp03/Makefile.in (modified) * c/src/tests/mptests/mp03/node1/Makefile.in (modified) * c/src/tests/mptests/mp03/node2/Makefile.in (modified) * c/src/tests/mptests/mp04/Makefile.in (modified) * c/src/tests/mptests/mp04/node1/Makefile.in (modified) * c/src/tests/mptests/mp04/node2/Makefile.in (modified) * c/src/tests/mptests/mp05/Makefile.in (modified) * c/src/tests/mptests/mp05/node1/Makefile.in (modified) * c/src/tests/mptests/mp05/node2/Makefile.in (modified) * c/src/tests/mptests/mp06/Makefile.in (modified) * c/src/tests/mptests/mp06/node1/Makefile.in (modified) * c/src/tests/mptests/mp06/node2/Makefile.in (modified) * c/src/tests/mptests/mp07/Makefile.in (modified) * c/src/tests/mptests/mp07/node1/Makefile.in (modified) * c/src/tests/mptests/mp07/node2/Makefile.in (modified) * c/src/tests/mptests/mp08/Makefile.in (modified) * c/src/tests/mptests/mp08/node1/Makefile.in (modified) * c/src/tests/mptests/mp08/node2/Makefile.in (modified) * c/src/tests/mptests/mp09/Makefile.in (modified) * c/src/tests/mptests/mp09/node1/Makefile.in (modified) * c/src/tests/mptests/mp09/node2/Makefile.in (modified) * c/src/tests/mptests/mp10/Makefile.in (modified) * c/src/tests/mptests/mp10/node1/Makefile.in (modified) * c/src/tests/mptests/mp10/node2/Makefile.in (modified) * c/src/tests/mptests/mp11/Makefile.in (modified) * c/src/tests/mptests/mp11/node1/Makefile.in (modified) * c/src/tests/mptests/mp11/node2/Makefile.in (modified) * c/src/tests/mptests/mp12/Makefile.in (modified) * c/src/tests/mptests/mp12/node1/Makefile.in (modified) * c/src/tests/mptests/mp12/node2/Makefile.in (modified) * c/src/tests/mptests/mp13/Makefile.in (modified) * c/src/tests/mptests/mp13/node1/Makefile.in (modified) * c/src/tests/mptests/mp13/node2/Makefile.in (modified) * c/src/tests/mptests/mp14/Makefile.in (modified) * c/src/tests/mptests/mp14/node1/Makefile.in (modified) * c/src/tests/mptests/mp14/node2/Makefile.in (modified) * c/src/tests/psxtests/Makefile.in (modified) * c/src/tests/psxtests/psx01/Makefile.in (modified) * c/src/tests/psxtests/psx02/Makefile.in (modified) * c/src/tests/psxtests/psx03/Makefile.in (modified) * c/src/tests/psxtests/psx04/Makefile.in (modified) * c/src/tests/psxtests/psx05/Makefile.in (modified) * c/src/tests/psxtests/psx06/Makefile.in (modified) * c/src/tests/psxtests/psx07/Makefile.in (modified) * c/src/tests/psxtests/psx08/Makefile.in (modified) * c/src/tests/psxtests/psx09/Makefile.in (modified) * c/src/tests/psxtests/psx10/Makefile.in (modified) * c/src/tests/psxtests/psx11/Makefile.in (modified) * c/src/tests/psxtests/psx12/Makefile.in (modified) * c/src/tests/psxtests/psx13/Makefile.in (modified) * c/src/tests/psxtests/psxfile01/Makefile.in (modified) * c/src/tests/psxtests/psxfile02/Makefile.in (modified) * c/src/tests/psxtests/psxhdrs/Makefile.in (modified) * c/src/tests/psxtests/psxmount/Makefile.in (modified) * c/src/tests/psxtests/psxreaddir/Makefile.in (modified) * c/src/tests/psxtests/psxstat/Makefile.in (modified) * c/src/tests/psxtests/psxtime/Makefile.in (modified) * c/src/tests/psxtests/psxtimer/Makefile.in (modified) * c/src/tests/psxtests/support/Makefile.in (modified) * c/src/tests/psxtests/support/include/Makefile.in (modified) * c/src/tests/samples/Makefile.in (modified) * c/src/tests/samples/base_mp/Makefile.in (modified) * c/src/tests/samples/base_mp/node1/Makefile.in (modified) * c/src/tests/samples/base_mp/node2/Makefile.in (modified) * c/src/tests/samples/base_sp/Makefile.in (modified) * c/src/tests/samples/cdtest/Makefile.in (modified) * c/src/tests/samples/hello/Makefile.in (modified) * c/src/tests/samples/minimum/Makefile.in (modified) * c/src/tests/samples/paranoia/Makefile.in (modified) * c/src/tests/samples/ticker/Makefile.in (modified) * c/src/tests/samples/unlimited/Makefile.in (modified) * c/src/tests/sptests/Makefile.in (modified) * c/src/tests/sptests/sp01/Makefile.in (modified) * c/src/tests/sptests/sp02/Makefile.in (modified) * c/src/tests/sptests/sp03/Makefile.in (modified) * c/src/tests/sptests/sp04/Makefile.in (modified) * c/src/tests/sptests/sp05/Makefile.in (modified) * c/src/tests/sptests/sp06/Makefile.in (modified) * c/src/tests/sptests/sp07/Makefile.in (modified) * c/src/tests/sptests/sp08/Makefile.in (modified) * c/src/tests/sptests/sp09/Makefile.in (modified) * c/src/tests/sptests/sp11/Makefile.in (modified) * c/src/tests/sptests/sp12/Makefile.in (modified) * c/src/tests/sptests/sp13/Makefile.in (modified) * c/src/tests/sptests/sp14/Makefile.in (modified) * c/src/tests/sptests/sp15/Makefile.in (modified) * c/src/tests/sptests/sp16/Makefile.in (modified) * c/src/tests/sptests/sp17/Makefile.in (modified) * c/src/tests/sptests/sp19/Makefile.in (modified) * c/src/tests/sptests/sp20/Makefile.in (modified) * c/src/tests/sptests/sp21/Makefile.in (modified) * c/src/tests/sptests/sp22/Makefile.in (modified) * c/src/tests/sptests/sp23/Makefile.in (modified) * c/src/tests/sptests/sp24/Makefile.in (modified) * c/src/tests/sptests/sp25/Makefile.in (modified) * c/src/tests/sptests/spfatal/Makefile.in (modified) * c/src/tests/sptests/spsize/Makefile.in (modified) * c/src/tests/support/Makefile.in (modified) * c/src/tests/support/include/Makefile.in (modified) * c/src/tests/support/stubdr/Makefile.in (modified) * c/src/tests/support/wrapup/Makefile.in (modified) * c/src/tests/tmtests/Makefile.in (modified) * c/src/tests/tmtests/include/Makefile.in (modified) * c/src/tests/tmtests/tm01/Makefile.in (modified) * c/src/tests/tmtests/tm02/Makefile.in (modified) * c/src/tests/tmtests/tm03/Makefile.in (modified) * c/src/tests/tmtests/tm04/Makefile.in (modified) * c/src/tests/tmtests/tm05/Makefile.in (modified) * c/src/tests/tmtests/tm06/Makefile.in (modified) * c/src/tests/tmtests/tm07/Makefile.in (modified) * c/src/tests/tmtests/tm08/Makefile.in (modified) * c/src/tests/tmtests/tm09/Makefile.in (modified) * c/src/tests/tmtests/tm10/Makefile.in (modified) * c/src/tests/tmtests/tm11/Makefile.in (modified) * c/src/tests/tmtests/tm12/Makefile.in (modified) * c/src/tests/tmtests/tm13/Makefile.in (modified) * c/src/tests/tmtests/tm14/Makefile.in (modified) * c/src/tests/tmtests/tm15/Makefile.in (modified) * c/src/tests/tmtests/tm16/Makefile.in (modified) * c/src/tests/tmtests/tm17/Makefile.in (modified) * c/src/tests/tmtests/tm18/Makefile.in (modified) * c/src/tests/tmtests/tm19/Makefile.in (modified) * c/src/tests/tmtests/tm20/Makefile.in (modified) * c/src/tests/tmtests/tm21/Makefile.in (modified) * c/src/tests/tmtests/tm22/Makefile.in (modified) * c/src/tests/tmtests/tm23/Makefile.in (modified) * c/src/tests/tmtests/tm24/Makefile.in (modified) * c/src/tests/tmtests/tm25/Makefile.in (modified) * c/src/tests/tmtests/tm26/Makefile.in (modified) * c/src/tests/tmtests/tm27/Makefile.in (modified) * c/src/tests/tmtests/tm28/Makefile.in (modified) * c/src/tests/tmtests/tm29/Makefile.in (modified) * c/src/tests/tmtests/tmck/Makefile.in (modified) * c/src/tests/tmtests/tmoverhd/Makefile.in (modified) * c/src/tests/tools/Makefile.in (modified) * c/src/tests/tools/generic/Makefile.am (modified) * c/src/tests/tools/generic/Makefile.in (modified) * make/Templates/Makefile.am (modified) * make/Templates/Makefile.in (modified) * make/Templates/Makefile.inc.in (deleted) * make/compilers/gcc-target-default.cfg (modified) * make/custom/FreeBSD-posix.cfg (modified) * make/custom/HPUX9-posix.cfg (modified) * make/custom/Linux-posix.cfg (modified) * make/custom/Solaris-posix.cfg (modified) * make/custom/cvme961.cfg (modified) * make/custom/default.cfg (modified) * make/custom/dmv152.cfg (modified) * make/custom/efi332.cfg (modified) * make/custom/efi68k.cfg (modified) * make/custom/force386.cfg (modified) * make/custom/gen68302.cfg (modified) * make/custom/gensh1.cfg (modified) * make/custom/go32.cfg (modified) * make/custom/helas403.cfg (modified) * make/custom/idp.cfg (modified) * make/custom/mvme136.cfg (modified) * make/custom/mvme147.cfg (modified) * make/custom/mvme162.cfg (modified) * make/custom/mvme167.cfg (modified) * make/custom/no_bsp.cfg (modified) * make/custom/ods68302.cfg (modified) * make/custom/p4000.cfg (modified) * make/custom/p4600.cfg (modified) * make/custom/p4650.cfg (modified) * make/custom/papyrus.cfg (modified) * make/custom/portsw.cfg (modified) * make/custom/psim.cfg (modified) * make/custom/score603e.cfg (modified) * make/custom/simhppa.cfg (modified) * make/host.cfg.in (modified) * make/leaf.cfg (modified) * testsuites/tools/generic/Makefile.am (modified) * tools/update/acpolish (modified) Patch rtems-rc-19990709-6-diff from Ralf Corsepius [fdb37e8] * aclocal/check-multiprocessing.m4 (added) New file from Ralf Corsepius missed being ... Fri, 30 Jul 1999 17:52:50 GMT Joel Sherrill [1896a650] * aclocal/check-rdbg.m4 (modified) * c/src/exec/aclocal.m4 (modified) * c/src/exec/configure (modified) * c/src/exec/configure.in (modified) * c/src/exec/posix/include/rtems/posix/Makefile.in (modified) * c/src/exec/rtems/Makefile.in (modified) * c/src/exec/rtems/include/rtems/rtems/Makefile.in (modified) * c/src/exec/rtems/src/Makefile.in (modified) * c/src/exec/sapi/include/rtems/Makefile.in (modified) * c/src/exec/score/Makefile.in (modified) * c/src/exec/score/include/rtems/score/Makefile.in (modified) * c/src/exec/score/inline/rtems/score/Makefile.in (modified) * c/src/exec/score/macros/rtems/score/Makefile.in (modified) * c/src/exec/score/src/Makefile.in (modified) * c/src/exec/wrapup/posix/Makefile.in (modified) * c/src/lib/aclocal.m4 (modified) * c/src/lib/configure (modified) * c/src/lib/configure.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/console/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/console/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/start/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/startup/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/start302/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/bootloader/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/startup/Makefile.in (modified) * c/src/lib/libchip/serial/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc750/exceptions/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc750/mmu/Makefile.in (modified) * c/src/lib/libmisc/monitor/Makefile.in (modified) * c/src/lib/libnetworking/include/Makefile.in (modified) * c/src/lib/librdbg/i386/pc386/Makefile.in (modified) * c/src/libchip/serial/Makefile.in (modified) * c/src/libmisc/monitor/Makefile.in (modified) * c/src/libnetworking/include/Makefile.in (modified) * c/src/librdbg/src/i386/any/Makefile.in (modified) * c/src/librdbg/src/i386/pc386/Makefile.in (modified) * c/src/make/Makefile.am (modified) * c/src/make/Makefile.in (modified) * c/src/make/Templates/Makefile.in (modified) * c/src/make/aclocal.m4 (modified) * c/src/make/bsp.cfg.in (added) * c/src/make/compilers/Makefile.in (modified) * c/src/make/configure (modified) * c/src/make/configure.in (modified) * c/src/make/custom/Makefile.am (modified) * c/src/make/custom/Makefile.in (modified) * c/src/make/custom/default.cfg.in (modified) * c/src/make/main.cfg.in (modified) * c/src/tests/aclocal.m4 (modified) * c/src/tests/configure (modified) * c/src/tests/configure.in (modified) * make/custom/default.cfg (modified) * make/custom/force386.cfg (modified) * make/custom/i386ex.cfg (modified) * make/custom/pc386.cfg (modified) * make/custom/portsw.cfg (modified) * make/custom/ppcn_60x.cfg (modified) * make/custom/psim.cfg (modified) * make/custom/ts_386ex.cfg (modified) * make/main.cfg (modified) * tools/build/configure (modified) * tools/update/acpolish (modified) Patch from Ralf Corsepius : The main ... Mon, 26 Jul 1999 20:20:22 GMT Joel Sherrill [eb299afc] * Makefile.am (added) * aclocal/bsp-alias.m4 (added) * aclocal/check-newlib.m4 (added) * aclocal/check-rdbg.m4 (added) * aclocal/enable-rtemsbsp.m4 (added) * aclocal/project-root.m4 (added) * aclocal/target.m4 (added) * c/Makefile.am (added) * c/aclocal.m4 (added) * c/configure (added) * c/configure.in (added) * c/src/Makefile.am (added) * c/src/aclocal.m4 (added) * c/src/configure (added) * c/src/configure.in (added) * c/src/exec/aclocal.m4 (added) * c/src/exec/configure (added) * c/src/exec/configure.in (added) * c/src/lib/aclocal.m4 (added) * c/src/lib/configure (added) * c/src/lib/configure.in (added) * c/src/lib/libbsp/i386/ts_386ex/tools/Makefile.am (added) * c/src/lib/libbsp/i386/ts_386ex/tools/aclocal.m4 (added) * c/src/lib/libbsp/i386/ts_386ex/tools/configure (added) * c/src/lib/libbsp/i386/ts_386ex/tools/configure.in (added) * c/src/lib/libbsp/i386/ts_386ex/tools/dos_sup/Makefile.am (added) * c/src/lib/libbsp/i386/ts_386ex/tools/dos_sup/Makefile.in (added) * c/src/lib/libbsp/i386/ts_386ex/tools/ts_1325_ada/Makefile.am (added) * c/src/lib/libbsp/i386/ts_386ex/tools/ts_1325_ada/Makefile.in (added) * c/src/make/Makefile.am (added) * c/src/make/Makefile.in (added) * c/src/make/Makefile.inc.in (added) * c/src/make/Templates/Makefile.am (added) * c/src/make/Templates/Makefile.dir (added) * c/src/make/Templates/Makefile.in (added) * c/src/make/Templates/Makefile.leaf (added) * c/src/make/Templates/Makefile.lib (added) * c/src/make/aclocal.m4 (added) * c/src/make/compilers/Makefile.am (added) * c/src/make/compilers/Makefile.in (added) * c/src/make/compilers/gcc.cfg.in (added) * c/src/make/configure (added) * c/src/make/configure.in (added) * c/src/make/custom/Makefile.am (added) * c/src/make/custom/Makefile.in (added) * c/src/make/custom/default.cfg.in (added) * c/src/make/main.cfg.in (added) * c/src/make/target.cfg.in (added) * c/src/tests/aclocal.m4 (added) * c/src/tests/configure (added) * c/src/tests/configure.in (added) * make/Makefile.am (added) * make/Templates/Makefile.am (added) * make/Templates/Makefile.in (added) * make/compilers/Makefile.am (added) * make/compilers/Makefile.in (added) * make/custom/Makefile.am (added) * make/custom/Makefile.in (added) * tools/Makefile.am (added) * tools/Makefile.in (added) * tools/cpu/Makefile.am (added) * tools/cpu/aclocal.m4 (added) * tools/cpu/configure (added) * tools/cpu/configure.in (added) This is part of a major patch from Ralf Corsepius [83f62bf] * aclocal/check-bsps.m4 (added) This is part of a major patch from Ralf Corsepius [6693a68] * Makefile.in (modified) * aclocal.m4 (modified) * aclocal/canonicalize-tools.m4 (modified) * aclocal/gcc-pipe.m4 (modified) * aclocal/prog-cc.m4 (modified) * aclocal/prog-cxx.m4 (modified) * aclocal/rtems-top.m4 (modified) * aclocal/sysv-ipc.m4 (modified) * aclocal/tool-paths.m4 (modified) * aclocal/tool-prefix.m4 (modified) * autogen (modified) * c/Makefile.in (modified) * c/src/Makefile.in (modified) * c/src/exec/Makefile.in (modified) * c/src/exec/posix/Makefile.in (modified) * c/src/exec/posix/include/Makefile.in (modified) * c/src/exec/posix/include/rtems/Makefile.in (modified) * c/src/exec/posix/include/rtems/posix/Makefile.in (modified) * c/src/exec/posix/include/sys/Makefile.in (modified) * c/src/exec/posix/include/wrap/Makefile.in (modified) * c/src/exec/posix/inline/Makefile.in (modified) * c/src/exec/posix/inline/rtems/Makefile.in (modified) * c/src/exec/posix/inline/rtems/posix/Makefile.in (modified) * c/src/exec/posix/macros/Makefile.in (modified) * c/src/exec/posix/macros/rtems/Makefile.in (modified) * c/src/exec/posix/macros/rtems/posix/Makefile.in (modified) * c/src/exec/posix/optman/Makefile.in (modified) * c/src/exec/posix/src/Makefile.in (modified) * c/src/exec/rtems/Makefile.in (modified) * c/src/exec/rtems/include/Makefile.in (modified) * c/src/exec/rtems/include/rtems/Makefile.in (modified) * c/src/exec/rtems/include/rtems/rtems/Makefile.in (modified) * c/src/exec/rtems/include/wrap/Makefile.in (modified) * c/src/exec/rtems/inline/Makefile.in (modified) * c/src/exec/rtems/inline/rtems/Makefile.in (modified) * c/src/exec/rtems/inline/rtems/rtems/Makefile.in (modified) * c/src/exec/rtems/macros/Makefile.in (modified) * c/src/exec/rtems/macros/rtems/Makefile.in (modified) * c/src/exec/rtems/macros/rtems/rtems/Makefile.in (modified) * c/src/exec/rtems/optman/Makefile.in (modified) * c/src/exec/rtems/src/Makefile.in (modified) * c/src/exec/sapi/Makefile.in (modified) * c/src/exec/sapi/include/Makefile.in (modified) * c/src/exec/sapi/include/rtems/Makefile.in (modified) * c/src/exec/sapi/include/rtems/sptables.h.in (added) * c/src/exec/sapi/include/wrap/Makefile.in (modified) * c/src/exec/sapi/inline/Makefile.in (modified) * c/src/exec/sapi/inline/rtems/Makefile.in (modified) * c/src/exec/sapi/macros/Makefile.in (modified) * c/src/exec/sapi/macros/rtems/Makefile.in (modified) * c/src/exec/sapi/optman/Makefile.in (modified) * c/src/exec/sapi/src/Makefile.in (modified) * c/src/exec/score/Makefile.in (modified) * c/src/exec/score/cpu/Makefile.in (modified) * c/src/exec/score/cpu/a29k/Makefile.in (modified) * c/src/exec/score/cpu/a29k/rtems/Makefile.in (modified) * c/src/exec/score/cpu/a29k/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/a29k/wrap/Makefile.in (modified) * c/src/exec/score/cpu/hppa1.1/Makefile.in (modified) * c/src/exec/score/cpu/hppa1.1/rtems/Makefile.in (modified) * c/src/exec/score/cpu/hppa1.1/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/hppa1.1/wrap/Makefile.in (modified) * c/src/exec/score/cpu/i386/Makefile.in (modified) * c/src/exec/score/cpu/i386/rtems/Makefile.in (modified) * c/src/exec/score/cpu/i386/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/i386/wrap/Makefile.in (modified) * c/src/exec/score/cpu/i960/Makefile.in (modified) * c/src/exec/score/cpu/i960/rtems/Makefile.in (modified) * c/src/exec/score/cpu/i960/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/i960/wrap/Makefile.in (modified) * c/src/exec/score/cpu/m68k/Makefile.in (modified) * c/src/exec/score/cpu/m68k/rtems/Makefile.in (modified) * c/src/exec/score/cpu/m68k/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/m68k/wrap/Makefile.in (modified) * c/src/exec/score/cpu/mips64orion/Makefile.in (modified) * c/src/exec/score/cpu/mips64orion/rtems/Makefile.in (modified) * c/src/exec/score/cpu/mips64orion/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/mips64orion/wrap/Makefile.in (modified) * c/src/exec/score/cpu/no_cpu/Makefile.in (modified) * c/src/exec/score/cpu/no_cpu/rtems/Makefile.in (modified) * c/src/exec/score/cpu/no_cpu/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/no_cpu/wrap/Makefile.in (modified) * c/src/exec/score/cpu/powerpc/Makefile.in (modified) * c/src/exec/score/cpu/powerpc/mpc750/Makefile.in (modified) * c/src/exec/score/cpu/powerpc/other_cpu/Makefile.in (modified) * c/src/exec/score/cpu/powerpc/shared/Makefile.in (modified) * c/src/exec/score/cpu/powerpc/wrap/Makefile.in (modified) * c/src/exec/score/cpu/sh/Makefile.in (modified) * c/src/exec/score/cpu/sh/rtems/Makefile.in (modified) * c/src/exec/score/cpu/sh/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/sh/wrap/Makefile.in (modified) * c/src/exec/score/cpu/sparc/Makefile.in (modified) * c/src/exec/score/cpu/sparc/rtems/Makefile.in (modified) * c/src/exec/score/cpu/sparc/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/sparc/wrap/Makefile.in (modified) * c/src/exec/score/cpu/unix/Makefile.in (modified) * c/src/exec/score/cpu/unix/rtems/Makefile.in (modified) * c/src/exec/score/cpu/unix/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/unix/wrap/Makefile.in (modified) * c/src/exec/score/include/Makefile.in (modified) * c/src/exec/score/include/rtems/Makefile.in (modified) * c/src/exec/score/include/rtems/score/Makefile.in (modified) * c/src/exec/score/include/rtems/wrap/Makefile.in (modified) * c/src/exec/score/inline/Makefile.in (modified) * c/src/exec/score/inline/rtems/Makefile.in (modified) * c/src/exec/score/inline/rtems/score/Makefile.in (modified) * c/src/exec/score/macros/Makefile.in (modified) * c/src/exec/score/macros/rtems/Makefile.in (modified) * c/src/exec/score/macros/rtems/score/Makefile.in (modified) * c/src/exec/score/src/Makefile.in (modified) * c/src/exec/wrapup/Makefile.in (modified) * c/src/exec/wrapup/posix/Makefile.in (modified) * c/src/exec/wrapup/rtems/Makefile.in (modified) * c/src/lib/Makefile.in (modified) * c/src/lib/include/Makefile.in (modified) * c/src/lib/libbsp/Makefile.in (modified) * c/src/lib/libbsp/a29k/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/console/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/include/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/start/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/startup/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/wrapup/Makefile.in (modified) * c/src/lib/libbsp/bare/Makefile.in (modified) * c/src/lib/libbsp/bare/include/Makefile.in (modified) * c/src/lib/libbsp/bare/wrapup/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/pxfl/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/include/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/start/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/startup/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/Makefile.am (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/aclocal.m4 (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/configure (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/configure.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tty/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/console/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/include/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/start/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/console/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/include/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/console/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/include/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/network/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/start/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/3c509/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/console/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/dec21140/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/include/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/ne2000/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/start/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/tools/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/tools/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/tools/aclocal.m4 (modified) * c/src/lib/libbsp/i386/pc386/tools/configure (modified) * c/src/lib/libbsp/i386/pc386/tools/configure.in (modified) * c/src/lib/libbsp/i386/pc386/wd8003/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/shared/Makefile.in (modified) * c/src/lib/libbsp/i386/shared/comm/Makefile.in (modified) * c/src/lib/libbsp/i386/shared/io/Makefile.in (modified) * c/src/lib/libbsp/i386/shared/irq/Makefile.in (modified) * c/src/lib/libbsp/i386/shared/pci/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/console/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/include/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/network/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/start/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/ts_1325_ada/Makefile (deleted) * c/src/lib/libbsp/i386/ts_386ex/tools/ts_1325_ada/README (added) * c/src/lib/libbsp/i386/ts_386ex/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i960/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/clock/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/console/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/include/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/start/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/startup/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/timer/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/spurious/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/spurious/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/start332/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/spurious/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/start68k/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/start302/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/start340/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/network/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/start360/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/consolex/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/tod/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/tools/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/tools/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/tools/aclocal.m4 (modified) * c/src/lib/libbsp/m68k/mvme162/tools/configure (modified) * c/src/lib/libbsp/m68k/mvme162/tools/configure.in (modified) * c/src/lib/libbsp/m68k/mvme162/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/fatal/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/start302/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/wrapup/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/console/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/include/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/liblnk/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/start/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/startup/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/wrapup/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/clock/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/console/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/include/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/timer/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/clock/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/scv64/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/sonic/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/timer/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/tod/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/canbus/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/network/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/dlentry/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/flashentry/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/bootloader/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/irq/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/openpic/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/pci/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/residual/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/vectors/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/irq/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/openpic/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/pci/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/residual/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/vectors/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/dlentry/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/flashentry/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/clock/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/network/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/nvram/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/pci/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/timer/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/tod/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/universe/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/vectors/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/clock/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/startsim/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/timer/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/tools/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/tools/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/tools/aclocal.m4 (modified) * c/src/lib/libbsp/powerpc/psim/tools/configure (modified) * c/src/lib/libbsp/powerpc/psim/tools/configure.in (modified) * c/src/lib/libbsp/powerpc/psim/vectors/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/PCI_bus/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/clock/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/timer/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/tod/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/vectors/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/wrapup/Makefile.in (modified) * c/src/lib/libbsp/sh/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/include/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/scitab/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/start/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/startup/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/wrapup/Makefile.in (modified) * c/src/lib/libbsp/shmdr/Makefile.in (modified) * c/src/lib/libbsp/sparc/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/clock/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/console/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/gnatsupp/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/include/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/start/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/startsis/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/startup/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/timer/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/tools/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/tools/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/tools/aclocal.m4 (modified) * c/src/lib/libbsp/sparc/erc32/tools/configure (modified) * c/src/lib/libbsp/sparc/erc32/tools/configure.in (modified) * c/src/lib/libbsp/sparc/erc32/wrapup/Makefile.in (modified) * c/src/lib/libbsp/unix/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/clock/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/console/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/include/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/startup/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/timer/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/tools/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/tools/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/tools/aclocal.m4 (modified) * c/src/lib/libbsp/unix/posix/tools/configure (modified) * c/src/lib/libbsp/unix/posix/tools/configure.in (modified) * c/src/lib/libbsp/unix/posix/wrapup/Makefile.in (modified) * c/src/lib/libc/Makefile.in (modified) * c/src/lib/libchip/Makefile.in (modified) * c/src/lib/libchip/network/Makefile.in (modified) * c/src/lib/libchip/rtc/Makefile.in (modified) * c/src/lib/libchip/serial/Makefile.in (modified) * c/src/lib/libcpu/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/clock/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/include/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/milli/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/runway/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/semaphore/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/timer/Makefile.in (modified) * c/src/lib/libcpu/i386/Makefile.in (modified) * c/src/lib/libcpu/i386/wrapup/Makefile.in (modified) * c/src/lib/libcpu/m68k/Makefile.in (modified) * c/src/lib/libcpu/m68k/m68040/Makefile.in (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/Makefile.in (modified) * c/src/lib/libcpu/mips64orion/Makefile.in (modified) * c/src/lib/libcpu/mips64orion/clock/Makefile.in (modified) * c/src/lib/libcpu/mips64orion/include/Makefile.in (modified) * c/src/lib/libcpu/mips64orion/timer/Makefile.in (modified) * c/src/lib/libcpu/powerpc/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc750/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc750/clock/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc750/exceptions/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc750/mmu/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc750/wrapup/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc821/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc821/clock/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc821/console-generic/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc821/include/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc821/timer/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc821/vectors/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/clock/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/console-generic/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/include/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/timer/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/vectors/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/clock/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/console/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/ictrl/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/include/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/timer/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/vectors/Makefile.in (modified) * c/src/lib/libcpu/powerpc/shared/Makefile.in (modified) * c/src/lib/libcpu/powerpc/wrapup/Makefile.in (modified) * c/src/lib/libcpu/sh/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/clock/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/console/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/include/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/null/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/timer/Makefile.in (modified) * c/src/lib/libcpu/sparc/Makefile.in (modified) * c/src/lib/libcpu/sparc/reg_win/Makefile.in (modified) * c/src/lib/libcpu/sparc/syscall/Makefile.in (modified) * c/src/lib/libmisc/Makefile.in (modified) * c/src/lib/libmisc/assoc/Makefile.in (modified) * c/src/lib/libmisc/cpuuse/Makefile.in (modified) * c/src/lib/libmisc/dumpbuf/Makefile.in (modified) * c/src/lib/libmisc/error/Makefile.in (modified) * c/src/lib/libmisc/monitor/Makefile.in (modified) * c/src/lib/libmisc/rtmonuse/Makefile.in (modified) * c/src/lib/libmisc/stackchk/Makefile.in (modified) * c/src/lib/libmisc/untar/Makefile.in (modified) * c/src/lib/libmisc/wrapup/Makefile.in (modified) * c/src/lib/libnetworking/Makefile.in (modified) * c/src/lib/libnetworking/include/Makefile.in (modified) * c/src/lib/libnetworking/kern/Makefile.in (modified) * c/src/lib/libnetworking/lib/Makefile.in (modified) * c/src/lib/libnetworking/libc/Makefile.in (modified) * c/src/lib/libnetworking/net/Makefile.in (modified) * c/src/lib/libnetworking/netinet/Makefile.in (modified) * c/src/lib/libnetworking/nfs/Makefile.in (modified) * c/src/lib/libnetworking/rtems/Makefile.in (modified) * c/src/lib/libnetworking/rtems_servers/Makefile.in (modified) * c/src/lib/libnetworking/wrapup/Makefile.in (modified) * c/src/lib/librdbg/Makefile.in (modified) * c/src/lib/librdbg/i386/Makefile.in (modified) * c/src/lib/librdbg/i386/pc386/Makefile.in (modified) * c/src/lib/librpc/Makefile.in (modified) * c/src/lib/librtems++/Makefile.in (modified) * c/src/lib/start/Makefile.in (modified) * c/src/lib/start/a29k/Makefile.in (modified) * c/src/lib/start/i960/Makefile.in (modified) * c/src/lib/start/m68k/Makefile.in (modified) * c/src/lib/start/mips64orion/Makefile.in (modified) * c/src/lib/start/sh/Makefile.in (modified) * c/src/lib/wrapup/Makefile.in (modified) * c/src/libchip/network/Makefile.in (modified) * c/src/libchip/rtc/Makefile.in (modified) * c/src/libchip/serial/Makefile.in (modified) * c/src/libmisc/assoc/Makefile.in (modified) * c/src/libmisc/cpuuse/Makefile.in (modified) * c/src/libmisc/dumpbuf/Makefile.in (modified) * c/src/libmisc/error/Makefile.in (modified) * c/src/libmisc/monitor/Makefile.in (modified) * c/src/libmisc/rtmonuse/Makefile.in (modified) * c/src/libmisc/stackchk/Makefile.in (modified) * c/src/libmisc/untar/Makefile.in (modified) * c/src/libmisc/wrapup/Makefile.in (modified) * c/src/libnetworking/Makefile.in (modified) * c/src/libnetworking/include/Makefile.in (modified) * c/src/libnetworking/kern/Makefile.in (modified) * c/src/libnetworking/lib/Makefile.in (modified) * c/src/libnetworking/libc/Makefile.in (modified) * c/src/libnetworking/net/Makefile.in (modified) * c/src/libnetworking/netinet/Makefile.in (modified) * c/src/libnetworking/nfs/Makefile.in (modified) * c/src/libnetworking/rtems/Makefile.in (modified) * c/src/libnetworking/rtems_servers/Makefile.in (modified) * c/src/libnetworking/wrapup/Makefile.in (modified) * c/src/librdbg/src/Makefile.in (modified) * c/src/librdbg/src/i386/Makefile.in (modified) * c/src/librdbg/src/i386/any/Makefile.in (modified) * c/src/librdbg/src/i386/pc386/Makefile.in (modified) * c/src/librpc/src/Makefile.in (modified) * c/src/librtems++/src/Makefile.in (modified) * c/src/make/directory.cfg (modified) * c/src/make/host.cfg.in (modified) * c/src/tests/Makefile.in (modified) * c/src/tests/libtests/Makefile.in (modified) * c/src/tests/libtests/cpuuse/Makefile.in (modified) * c/src/tests/libtests/malloctest/Makefile.in (modified) * c/src/tests/libtests/monitor/Makefile.in (modified) * c/src/tests/libtests/rtems++/Makefile.in (modified) * c/src/tests/libtests/rtmonuse/Makefile.in (modified) * c/src/tests/libtests/stackchk/Makefile.in (modified) * c/src/tests/libtests/termios/Makefile.in (modified) * c/src/tests/mptests/Makefile.in (modified) * c/src/tests/mptests/mp01/Makefile.in (modified) * c/src/tests/mptests/mp01/node1/Makefile.in (modified) * c/src/tests/mptests/mp01/node2/Makefile.in (modified) * c/src/tests/mptests/mp02/Makefile.in (modified) * c/src/tests/mptests/mp02/node1/Makefile.in (modified) * c/src/tests/mptests/mp02/node2/Makefile.in (modified) * c/src/tests/mptests/mp03/Makefile.in (modified) * c/src/tests/mptests/mp03/node1/Makefile.in (modified) * c/src/tests/mptests/mp03/node2/Makefile.in (modified) * c/src/tests/mptests/mp04/Makefile.in (modified) * c/src/tests/mptests/mp04/node1/Makefile.in (modified) * c/src/tests/mptests/mp04/node2/Makefile.in (modified) * c/src/tests/mptests/mp05/Makefile.in (modified) * c/src/tests/mptests/mp05/node1/Makefile.in (modified) * c/src/tests/mptests/mp05/node2/Makefile.in (modified) * c/src/tests/mptests/mp06/Makefile.in (modified) * c/src/tests/mptests/mp06/node1/Makefile.in (modified) * c/src/tests/mptests/mp06/node2/Makefile.in (modified) * c/src/tests/mptests/mp07/Makefile.in (modified) * c/src/tests/mptests/mp07/node1/Makefile.in (modified) * c/src/tests/mptests/mp07/node2/Makefile.in (modified) * c/src/tests/mptests/mp08/Makefile.in (modified) * c/src/tests/mptests/mp08/node1/Makefile.in (modified) * c/src/tests/mptests/mp08/node2/Makefile.in (modified) * c/src/tests/mptests/mp09/Makefile.in (modified) * c/src/tests/mptests/mp09/node1/Makefile.in (modified) * c/src/tests/mptests/mp09/node2/Makefile.in (modified) * c/src/tests/mptests/mp10/Makefile.in (modified) * c/src/tests/mptests/mp10/node1/Makefile.in (modified) * c/src/tests/mptests/mp10/node2/Makefile.in (modified) * c/src/tests/mptests/mp11/Makefile.in (modified) * c/src/tests/mptests/mp11/node1/Makefile.in (modified) * c/src/tests/mptests/mp11/node2/Makefile.in (modified) * c/src/tests/mptests/mp12/Makefile.in (modified) * c/src/tests/mptests/mp12/node1/Makefile.in (modified) * c/src/tests/mptests/mp12/node2/Makefile.in (modified) * c/src/tests/mptests/mp13/Makefile.in (modified) * c/src/tests/mptests/mp13/node1/Makefile.in (modified) * c/src/tests/mptests/mp13/node2/Makefile.in (modified) * c/src/tests/mptests/mp14/Makefile.in (modified) * c/src/tests/mptests/mp14/node1/Makefile.in (modified) * c/src/tests/mptests/mp14/node2/Makefile.in (modified) * c/src/tests/psxtests/Makefile.in (modified) * c/src/tests/psxtests/psx01/Makefile.in (modified) * c/src/tests/psxtests/psx02/Makefile.in (modified) * c/src/tests/psxtests/psx03/Makefile.in (modified) * c/src/tests/psxtests/psx04/Makefile.in (modified) * c/src/tests/psxtests/psx05/Makefile.in (modified) * c/src/tests/psxtests/psx06/Makefile.in (modified) * c/src/tests/psxtests/psx07/Makefile.in (modified) * c/src/tests/psxtests/psx08/Makefile.in (modified) * c/src/tests/psxtests/psx09/Makefile.in (modified) * c/src/tests/psxtests/psx10/Makefile.in (modified) * c/src/tests/psxtests/psx11/Makefile.in (modified) * c/src/tests/psxtests/psx12/Makefile.in (modified) * c/src/tests/psxtests/psx13/Makefile.in (modified) * c/src/tests/psxtests/psxfile01/Makefile.in (modified) * c/src/tests/psxtests/psxfile02/Makefile.in (modified) * c/src/tests/psxtests/psxhdrs/Makefile.in (modified) * c/src/tests/psxtests/psxmount/Makefile.in (modified) * c/src/tests/psxtests/psxreaddir/Makefile.in (modified) * c/src/tests/psxtests/psxstat/Makefile.in (modified) * c/src/tests/psxtests/psxtime/Makefile.in (modified) * c/src/tests/psxtests/psxtimer/Makefile.in (modified) * c/src/tests/psxtests/support/Makefile.in (modified) * c/src/tests/psxtests/support/include/Makefile.in (modified) * c/src/tests/samples/Makefile.in (modified) * c/src/tests/samples/base_mp/Makefile.in (modified) * c/src/tests/samples/base_mp/node1/Makefile.in (modified) * c/src/tests/samples/base_mp/node2/Makefile.in (modified) * c/src/tests/samples/base_sp/Makefile.in (modified) * c/src/tests/samples/cdtest/Makefile.in (modified) * c/src/tests/samples/hello/Makefile.in (modified) * c/src/tests/samples/minimum/Makefile.in (modified) * c/src/tests/samples/paranoia/Makefile.in (modified) * c/src/tests/samples/ticker/Makefile.in (modified) * c/src/tests/samples/unlimited/Makefile.in (modified) * c/src/tests/sptests/Makefile.in (modified) * c/src/tests/sptests/sp01/Makefile.in (modified) * c/src/tests/sptests/sp02/Makefile.in (modified) * c/src/tests/sptests/sp03/Makefile.in (modified) * c/src/tests/sptests/sp04/Makefile.in (modified) * c/src/tests/sptests/sp05/Makefile.in (modified) * c/src/tests/sptests/sp06/Makefile.in (modified) * c/src/tests/sptests/sp07/Makefile.in (modified) * c/src/tests/sptests/sp08/Makefile.in (modified) * c/src/tests/sptests/sp09/Makefile.in (modified) * c/src/tests/sptests/sp11/Makefile.in (modified) * c/src/tests/sptests/sp12/Makefile.in (modified) * c/src/tests/sptests/sp13/Makefile.in (modified) * c/src/tests/sptests/sp14/Makefile.in (modified) * c/src/tests/sptests/sp15/Makefile.in (modified) * c/src/tests/sptests/sp16/Makefile.in (modified) * c/src/tests/sptests/sp17/Makefile.in (modified) * c/src/tests/sptests/sp19/Makefile.in (modified) * c/src/tests/sptests/sp20/Makefile.in (modified) * c/src/tests/sptests/sp21/Makefile.in (modified) * c/src/tests/sptests/sp22/Makefile.in (modified) * c/src/tests/sptests/sp23/Makefile.in (modified) * c/src/tests/sptests/sp24/Makefile.in (modified) * c/src/tests/sptests/sp25/Makefile.in (modified) * c/src/tests/sptests/spfatal/Makefile.in (modified) * c/src/tests/sptests/spsize/Makefile.in (modified) * c/src/tests/support/Makefile.in (modified) * c/src/tests/support/include/Makefile.in (modified) * c/src/tests/support/stubdr/Makefile.in (modified) * c/src/tests/support/wrapup/Makefile.in (modified) * c/src/tests/tmtests/Makefile.in (modified) * c/src/tests/tmtests/include/Makefile.in (modified) * c/src/tests/tmtests/tm01/Makefile.in (modified) * c/src/tests/tmtests/tm02/Makefile.in (modified) * c/src/tests/tmtests/tm03/Makefile.in (modified) * c/src/tests/tmtests/tm04/Makefile.in (modified) * c/src/tests/tmtests/tm05/Makefile.in (modified) * c/src/tests/tmtests/tm06/Makefile.in (modified) * c/src/tests/tmtests/tm07/Makefile.in (modified) * c/src/tests/tmtests/tm08/Makefile.in (modified) * c/src/tests/tmtests/tm09/Makefile.in (modified) * c/src/tests/tmtests/tm10/Makefile.in (modified) * c/src/tests/tmtests/tm11/Makefile.in (modified) * c/src/tests/tmtests/tm12/Makefile.in (modified) * c/src/tests/tmtests/tm13/Makefile.in (modified) * c/src/tests/tmtests/tm14/Makefile.in (modified) * c/src/tests/tmtests/tm15/Makefile.in (modified) * c/src/tests/tmtests/tm16/Makefile.in (modified) * c/src/tests/tmtests/tm17/Makefile.in (modified) * c/src/tests/tmtests/tm18/Makefile.in (modified) * c/src/tests/tmtests/tm19/Makefile.in (modified) * c/src/tests/tmtests/tm20/Makefile.in (modified) * c/src/tests/tmtests/tm21/Makefile.in (modified) * c/src/tests/tmtests/tm22/Makefile.in (modified) * c/src/tests/tmtests/tm23/Makefile.in (modified) * c/src/tests/tmtests/tm24/Makefile.in (modified) * c/src/tests/tmtests/tm25/Makefile.in (modified) * c/src/tests/tmtests/tm26/Makefile.in (modified) * c/src/tests/tmtests/tm27/Makefile.in (modified) * c/src/tests/tmtests/tm28/Makefile.in (modified) * c/src/tests/tmtests/tm29/Makefile.in (modified) * c/src/tests/tmtests/tmck/Makefile.in (modified) * c/src/tests/tmtests/tmoverhd/Makefile.in (modified) * c/src/tests/tools/Makefile.in (modified) * c/src/tests/tools/generic/Makefile.am (modified) * c/src/tests/tools/generic/Makefile.in (modified) * c/src/tests/tools/generic/aclocal.m4 (modified) * c/src/tests/tools/generic/configure (modified) * c/src/tests/tools/generic/configure.in (modified) * c/src/wrapup/Makefile.in (modified) * configure (modified) * configure.in (modified) * cpukit/sapi/include/rtems/sptables.h.in (moved) * doc/Makefile.in (modified) * make/Makefile.in (modified) * make/custom/FreeBSD-posix.cfg (modified) * make/custom/Linux-posix.cfg (modified) * make/custom/Solaris-posix.cfg (modified) * make/custom/default.cfg (modified) * make/custom/gensh1.cfg (modified) * make/custom/no_bsp.cfg (modified) * make/custom/portsw.cfg (modified) * make/custom/posix.cfg (modified) * make/custom/simhppa.cfg (modified) * make/directory.cfg (modified) * make/host.cfg.in (modified) * make/leaf.cfg (modified) * make/main.cfg (modified) * make/target.cfg.in (modified) * testsuites/tools/generic/Makefile.am (modified) * tools/build/Makefile.am (modified) * tools/build/Makefile.in (modified) * tools/build/aclocal.m4 (modified) * tools/build/configure (modified) * tools/build/configure.in (modified) * tools/cpu/Makefile.in (modified) * tools/cpu/generic/Makefile.am (modified) * tools/cpu/generic/Makefile.in (modified) * tools/cpu/generic/aclocal.m4 (modified) * tools/cpu/generic/configure (modified) * tools/cpu/generic/configure.in (modified) * tools/cpu/generic/size_rtems.in (modified) * tools/cpu/hppa1.1/Makefile.am (modified) * tools/cpu/hppa1.1/aclocal.m4 (modified) * tools/cpu/hppa1.1/configure (modified) * tools/cpu/hppa1.1/configure.in (modified) * tools/cpu/sh/Makefile.am (modified) * tools/cpu/sh/Makefile.in (modified) * tools/cpu/sh/aclocal.m4 (modified) * tools/cpu/sh/configure (modified) * tools/cpu/sh/configure.in (modified) * tools/cpu/unix/Makefile.am (modified) * tools/cpu/unix/Makefile.in (modified) * tools/cpu/unix/aclocal.m4 (modified) * tools/cpu/unix/configure (modified) * tools/cpu/unix/configure.in (modified) * tools/update/Makefile.am (modified) * tools/update/Makefile.in (modified) * tools/update/aclocal.m4 (modified) * tools/update/acpolish (modified) * tools/update/ampolish (modified) * tools/update/configure (modified) * tools/update/configure.in (modified) * tools/update/rtems-polish.sh (modified) This is part of a major patch from Ralf Corsepius [8c92fa3] * aclocal.m4 (modified) * aclocal/canonical-target-name.m4 (modified) * c/src/exec/score/tools/generic/aclocal.m4 (modified) * c/src/exec/score/tools/generic/configure (modified) * c/src/exec/score/tools/hppa1.1/aclocal.m4 (modified) * c/src/exec/score/tools/hppa1.1/configure (modified) * c/src/exec/score/tools/sh/aclocal.m4 (modified) * c/src/exec/score/tools/sh/configure (modified) * c/src/exec/score/tools/unix/aclocal.m4 (modified) * c/src/exec/score/tools/unix/configure (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/aclocal.m4 (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/configure (modified) * c/src/lib/libbsp/i386/pc386/tools/aclocal.m4 (modified) * c/src/lib/libbsp/i386/pc386/tools/configure (modified) * c/src/lib/libbsp/m68k/mvme162/tools/aclocal.m4 (modified) * c/src/lib/libbsp/m68k/mvme162/tools/configure (modified) * c/src/lib/libbsp/powerpc/psim/tools/aclocal.m4 (modified) * c/src/lib/libbsp/powerpc/psim/tools/configure (modified) * c/src/lib/libbsp/sparc/erc32/tools/aclocal.m4 (modified) * c/src/lib/libbsp/sparc/erc32/tools/configure (modified) * c/src/lib/libbsp/unix/posix/tools/aclocal.m4 (modified) * c/src/lib/libbsp/unix/posix/tools/configure (modified) * c/src/tests/tools/generic/aclocal.m4 (modified) * c/src/tests/tools/generic/configure (modified) * configure (modified) * tools/cpu/generic/aclocal.m4 (modified) * tools/cpu/generic/configure (modified) * tools/cpu/hppa1.1/aclocal.m4 (modified) * tools/cpu/hppa1.1/configure (modified) * tools/cpu/sh/aclocal.m4 (modified) * tools/cpu/sh/configure (modified) * tools/cpu/unix/aclocal.m4 (modified) * tools/cpu/unix/configure (modified) Patcg from Ralf Corsepius : -- configure ...
