# # ChangeLog for aclocal in rtems # # Generated by Trac 1.2.1.dev0 # 04/23/24 11:24:32 Fri, 24 Sep 2004 04:42:11 GMT Ralf Corsepius [20286cb] * ChangeLog (modified) * aclocal/rtems-cpu-subdirs.m4 (deleted) 2004-09-24 Ralf Corsepius * ... Wed, 28 Jul 2004 15:32:02 GMT Joel Sherrill [82fe9c1] * ChangeLog (modified) * aclocal/version.m4 (modified) * c/src/ChangeLog (modified) * c/src/aclocal/version.m4 (modified) * cpukit/ChangeLog (modified) * cpukit/aclocal/version.m4 (modified) * testsuites/ChangeLog (modified) * testsuites/aclocal/version.m4 (modified) 2004-07-28 * aclocal/version.m4: Updated to rtems-4.6.99.1. Wed, 31 Mar 2004 10:55:15 GMT Ralf Corsepius [3456ce8a] * ChangeLog (modified) * acinclude.m4 (modified) * aclocal/rtems-top.m4 (modified) 2004-03-31 Ralf Corsepius * ... Fri, 20 Feb 2004 01:44:19 GMT Ralf Corsepius [6e2ef53f] * Makefile.am (modified) * aclocal/rtems-top.m4 (modified) 2004-02-20 Ralf Corsepius * ... Tue, 17 Feb 2004 13:50:24 GMT Ralf Corsepius [9078e097] * ChangeLog (modified) * Makefile.am (modified) * aclocal/enable-rtemsbsp.m4 (modified) * configure.ac (modified) 2004-02-17 Ralf Corsepius * ... Thu, 12 Feb 2004 14:38:21 GMT Ralf Corsepius [32bda8f] * VERSION (modified) * aclocal/version.m4 (modified) 2004-02-12 Ralf Corsepius * ... Fri, 06 Feb 2004 20:35:03 GMT Joel Sherrill [75b453f] * ChangeLog (modified) * aclocal/bsp-alias.m4 (modified) 2004-02-06 Joel Sherrill * ... Tue, 03 Feb 2004 04:56:26 GMT Ralf Corsepius [1f1b298] * ChangeLog (modified) * aclocal/rpm.m4 (modified) * aclocal/rtems-top.m4 (modified) 2004-02-03 Ralf Corsepius * ... Sun, 01 Feb 2004 08:27:24 GMT Ralf Corsepius [9b962b28] * ChangeLog (modified) * aclocal/rpm.m4 (added) 2004-02-01 Ralf Corsepius * ... Fri, 16 Jan 2004 16:18:26 GMT Ralf Corsepius [86a84373] * ChangeLog (modified) * aclocal/check-bsps.m4 (modified) * configure.ac (modified) 2004-01-16 Ralf Corsepius * ... Wed, 07 Jan 2004 20:51:05 GMT Joel Sherrill [8d93706] * ChangeLog (modified) * aclocal/bsp-alias.m4 (modified) * aclocal/rtems-cpu-subdirs.m4 (modified) 2004-01-07 Joel Sherrill * ... Wed, 17 Dec 2003 20:56:10 GMT Joel Sherrill [44652f8] * ChangeLog (modified) * aclocal/version.m4 (modified) * c/src/ChangeLog (modified) * cpukit/ChangeLog (modified) * cpukit/aclocal/version.m4 (modified) * testsuites/ChangeLog (modified) * testsuites/aclocal/version.m4 (modified) 2003-12-17 Joel Sherrill * ... Wed, 26 Nov 2003 05:32:03 GMT Ralf Corsepius [3959276e] * ChangeLog (modified) * acinclude.m4 (modified) * aclocal/bsp-alias.m4 (modified) * aclocal/canonical-target-name.m4 (modified) * aclocal/check-bsps.m4 (modified) * aclocal/check-custom-bsp.m4 (modified) * aclocal/enable-bare.m4 (modified) * aclocal/enable-cxx.m4 (modified) * aclocal/enable-inlines.m4 (modified) * aclocal/enable-itron.m4 (modified) * aclocal/enable-multiprocessing.m4 (modified) * aclocal/enable-networking.m4 (modified) * aclocal/enable-posix.m4 (modified) * aclocal/enable-rdbg.m4 (modified) * aclocal/enable-rtems-debug.m4 (modified) * aclocal/enable-rtemsbsp.m4 (modified) * aclocal/enable-tests.m4 (modified) * aclocal/multilib.m4 (modified) * aclocal/path-ksh.m4 (modified) * aclocal/project-root.m4 (modified) * aclocal/rtems-top.m4 (modified) * aclocal/tool-paths.m4 (modified) 2003-11-26 Ralf Corsepius * ... Thu, 23 Oct 2003 15:41:52 GMT Ralf Corsepius [532b7d1] * ChangeLog (modified) * Makefile.am (modified) * aclocal/config-subdirs.m4 (deleted) 2003-10-23 Ralf Corsepius * ... Thu, 23 Oct 2003 08:05:58 GMT Ralf Corsepius [fb2fc21] * ChangeLog (modified) * Makefile.am (modified) * aclocal/canonical-host.m4 (deleted) 2003-10-23 Ralf Corsepius * ... Thu, 02 Oct 2003 01:47:27 GMT Ralf Corsepius [4f2064f1] * ChangeLog (modified) * Makefile.am (modified) * acinclude.m4 (modified) * aclocal/check-cpu.m4 (deleted) 2003-10-01 Ralf Corsepius * ... Fri, 26 Sep 2003 21:41:25 GMT Joel Sherrill [5e8552a4] * ChangeLog (modified) * README.configure (modified) * aclocal/rtems-cpu-subdirs.m4 (modified) 2003-09-26 Joel Sherrill * ... Fri, 29 Aug 2003 00:06:15 GMT Ralf Corsepius [ac3786b] * aclocal/rtems-top.m4 (modified) * c/src/ChangeLog (modified) * c/src/aclocal/rtems-top.m4 (modified) * c/src/tests/ChangeLog (modified) * c/src/tests/aclocal/rtems-top.m4 (modified) * cpukit/ChangeLog (modified) * cpukit/aclocal/rtems-top.m4 (modified) * testsuites/ChangeLog (modified) * testsuites/aclocal/rtems-top.m4 (modified) 2003-08-28 Ralf Corsepius * ... Fri, 22 Aug 2003 04:21:16 GMT Ralf Corsepius [d2c6e4c1] * ChangeLog (modified) * aclocal/enable-rtems-debug.m4 (added) * aclocal/enable-tests.m4 (modified) 2003-08-22 Ralf Corsepius * ... Thu, 21 Aug 2003 05:37:41 GMT Ralf Corsepius [8ad16ba] * ChangeLog (modified) * Makefile.am (modified) * aclocal/bsp-arg-enable.m4 (deleted) * aclocal/bsp-configure.m4 (deleted) * aclocal/bspopts.m4 (deleted) * aclocal/canonicalize-tools.m4 (deleted) * aclocal/check-bsp-cache.m4 (deleted) * aclocal/check-cxx.m4 (deleted) * aclocal/check-itron.m4 (deleted) * aclocal/check-multiprocessing.m4 (deleted) * aclocal/check-networking.m4 (deleted) * aclocal/check-newlib.m4 (deleted) * aclocal/check-posix.m4 (deleted) * aclocal/check-rdbg.m4 (deleted) * aclocal/check-tool.m4 (deleted) * aclocal/env-rtemsbsp.m4 (deleted) * aclocal/gcc-isystem.m4 (deleted) * aclocal/gcc-pipe.m4 (deleted) * aclocal/gcc-specs.m4 (deleted) * aclocal/i386-gas-code16.m4 (deleted) * aclocal/path-perl.m4 (deleted) * aclocal/ppc.m4 (deleted) * aclocal/prog-cc.m4 (deleted) * aclocal/prog-ccas.m4 (deleted) * aclocal/prog-cxx.m4 (deleted) * aclocal/prog-gnat.m4 (deleted) * aclocal/rtems-debug.m4 (deleted) * aclocal/rtems-flags.m4 (deleted) * aclocal/rtems-test-no-pause.m4 (deleted) * aclocal/target.m4 (deleted) * automake/force-preinstall.am (deleted) * automake/leaf.am (deleted) 2003-08-21 Ralf Corsepius * ... Thu, 03 Jul 2003 14:17:35 GMT Joel Sherrill [73defea0] * ChangeLog (modified) * aclocal/version.m4 (modified) * cpukit/ChangeLog (modified) * cpukit/aclocal/version.m4 (modified) 2003-07-03 Joel Sherrill * ... Thu, 12 Jun 2003 06:28:16 GMT Ralf Corsepius [7a928017] * Makefile.am (modified) * acinclude.m4 (modified) * aclocal/prog-cc.m4 (modified) * configure.ac (modified) 2003-06-12 Ralf Corsepius * ... Thu, 12 Jun 2003 06:03:24 GMT Ralf Corsepius [87a95526] * ChangeLog (modified) * aclocal/gcc-isystem.m4 (added) 2003-06-12 Ralf Corsepius * ... Tue, 27 May 2003 13:47:02 GMT Ralf Corsepius [acd7c408] * ChangeLog (modified) * aclocal/check-bsp-cache.m4 (modified) * aclocal/env-rtemsbsp.m4 (modified) * automake/compile.am (modified) * automake/host.am (modified) * automake/local.am (modified) 2003-05-27 Ralf Corsepius PR ... Fri, 16 May 2003 09:11:40 GMT Ralf Corsepius [1cd9dfc] * ChangeLog (modified) * aclocal/check-cxx.m4 (modified) * automake/compile.am (modified) 2003-05-16 Ralf Corsepius * ... Thu, 17 Apr 2003 19:44:03 GMT Joel Sherrill [7ae9530] * ChangeLog (modified) * aclocal/version.m4 (modified) * cpukit/ChangeLog (modified) * cpukit/aclocal/version.m4 (modified) 2003-04-17 Joel Sherrill * ... Fri, 11 Apr 2003 21:51:46 GMT Joel Sherrill [f1208c0] * ChangeLog (modified) * aclocal/version.m4 (modified) * cpukit/ChangeLog (modified) * cpukit/aclocal/version.m4 (modified) 2003-04-11 Joel Sherrill * ... Fri, 11 Apr 2003 21:29:42 GMT Joel Sherrill [1ee68d1] * ChangeLog (modified) * aclocal/version.m4 (modified) * cpukit/ChangeLog (modified) * cpukit/aclocal/version.m4 (modified) 2003-04-11 Joel Sherrill * ... Mon, 10 Mar 2003 16:46:32 GMT Ralf Corsepius [89b51f4] * aclocal/rtems-top.m4 (modified) * make/ChangeLog (modified) * make/custom/arm_bare_bsp.cfg (modified) * make/custom/armulator.cfg (modified) * make/custom/edb7312.cfg (modified) * make/custom/ppcn_60x.cfg (modified) * make/custom/vegaplus.cfg (modified) Merger from rtems-4-6-branch Fri, 14 Feb 2003 19:43:28 GMT Joel Sherrill [6dd184ce] * ChangeLog (modified) * README.configure (modified) * aclocal/rtems-cpu-subdirs.m4 (modified) 2003-02-14 Joel Sherrill * ... Fri, 14 Feb 2003 05:15:15 GMT Ralf Corsepius [6b2b4a36] * ChangeLog (modified) * aclocal/canonical-target-name.m4 (modified) * cpukit/ChangeLog (modified) * cpukit/aclocal/canonical-target-name.m4 (modified) Merger from rtems-4-6-branch. Tue, 28 Jan 2003 18:47:37 GMT Joel Sherrill [4f3e2c28] * ChangeLog (modified) * aclocal/version.m4 (modified) * cpukit/ChangeLog (modified) 2003-01-28 Joel Sherrill * ... Thu, 16 Jan 2003 04:29:28 GMT Ralf Corsepius [2a2def9] * ChangeLog (modified) * aclocal/enable-cxx.m4 (modified) * aclocal/rtems-cpu-subdirs.m4 (modified) 2001-01-16 Ralf Corsepius * ... Thu, 19 Dec 2002 16:00:03 GMT Ralf Corsepius [bde6014e] * ChangeLog (modified) * aclocal/prog-cxx.m4 (modified) 2002-12-19 Ralf Corsepius * ... Tue, 10 Dec 2002 16:43:55 GMT Ralf Corsepius [3907075f] * ChangeLog (modified) * aclocal/prog-cxx.m4 (modified) 2002-12-10 Ralf Corsepius * ... Sat, 07 Dec 2002 13:06:23 GMT Ralf Corsepius [6fea3824] * ChangeLog (modified) * aclocal/bsp-configure.m4 (modified) * aclocal/env-rtemsbsp.m4 (modified) 2002-12-07 Ralf Corsepius * ... Fri, 06 Dec 2002 07:13:50 GMT Ralf Corsepius [c2113d3] * ChangeLog (modified) * aclocal/env-rtemsbsp.m4 (modified) * aclocal/prog-cc.m4 (modified) * aclocal/prog-cxx.m4 (modified) 2002-12-06 Ralf Corsepius * ... Fri, 06 Dec 2002 04:40:18 GMT Ralf Corsepius [8b38a769] * ChangeLog (modified) * aclocal/rtems-flags.m4 (added) * cpukit/ChangeLog (modified) * cpukit/aclocal/rtems-flags.m4 (added) 2002-12-06 Ralf Corsepius * ... Sun, 01 Dec 2002 11:45:50 GMT Ralf Corsepius [c47c12b] * ChangeLog (modified) * aclocal/prog-cc.m4 (modified) 2002-12-01 Ralf Corsepius * ... Fri, 29 Nov 2002 08:27:53 GMT Ralf Corsepius [ff65620] * ChangeLog (modified) * aclocal/canonicalize-tools.m4 (modified) * aclocal/check-bsps.m4 (modified) * aclocal/check-custom-bsp.m4 (added) * aclocal/prog-ccas.m4 (added) 2002-11-29 Ralf Corsepius * ... Wed, 20 Nov 2002 02:57:38 GMT Ralf Corsepius [0a9a0f5] * ChangeLog (modified) * aclocal/quoting.m4 (modified) 2002-11-19 Ralf Corsepius * ... Tue, 19 Nov 2002 17:05:34 GMT Ralf Corsepius [86f12bc] * ChangeLog (modified) * aclocal/check-newlib.m4 (modified) * automake/compile.am (modified) 2002-11-19 Ralf Corsepius * ... Tue, 19 Nov 2002 14:54:45 GMT Ralf Corsepius [984123f] * ChangeLog (modified) * aclocal/sysv-ipc.m4 (deleted) * aclocal/target.m4 (modified) 2002-11-19 Ralf Corsepius * ... Tue, 19 Nov 2002 00:31:31 GMT Ralf Corsepius [824bf2e4] * ChangeLog (modified) * aclocal/target.m4 (modified) 2002-11-18 Ralf Corsepius * ... Mon, 18 Nov 2002 13:57:54 GMT Joel Sherrill [b5a59c3f] * ChangeLog (modified) * aclocal/version.m4 (modified) * cpukit/ChangeLog (modified) * cpukit/aclocal/version.m4 (modified) 2002-11-18 Joel Sherrill * ... Mon, 18 Nov 2002 03:31:27 GMT Joel Sherrill [174eed8c] * ChangeLog (modified) * aclocal/bsp-alias.m4 (modified) * aclocal/check-bsps.m4 (modified) 2002-11-17 Joel Sherrill * ... Fri, 15 Nov 2002 14:13:01 GMT Ralf Corsepius [f289c09] * ChangeLog (modified) * acinclude.m4 (modified) * aclocal/prog-cc.m4 (modified) 2002-11-15 Ralf Corsepius * ... Mon, 11 Nov 2002 21:55:50 GMT Joel Sherrill [b99463c] * ChangeLog (modified) * aclocal/version.m4 (modified) * cpukit/ChangeLog (modified) 2002-11-11 Joel Sherrill * ... Wed, 06 Nov 2002 11:16:52 GMT Ralf Corsepius [e05468fb] * ChangeLog (modified) * aclocal/enable-inlines.m4 (modified) * aclocal/quoting.m4 (modified) * aclocal/target.m4 (modified) 2002-11-06 Ralf Corsepius ... Tue, 29 Oct 2002 14:37:34 GMT Ralf Corsepius [314a962] * ChangeLog (modified) * aclocal/enable-bare.m4 (modified) * aclocal/enable-cxx.m4 (modified) * aclocal/enable-inlines.m4 (modified) * aclocal/enable-itron.m4 (modified) * aclocal/enable-multiprocessing.m4 (modified) * aclocal/enable-networking.m4 (modified) * aclocal/enable-posix.m4 (modified) * aclocal/enable-rdbg.m4 (modified) * aclocal/enable-rtemsbsp.m4 (modified) * aclocal/enable-tests.m4 (modified) 2002-10-29 Ralf Corsepius * ... Mon, 28 Oct 2002 17:56:41 GMT Ralf Corsepius [1da0c52] * ChangeLog (modified) * aclocal/enable-rtemsbsp.m4 (modified) 2002-10-28 Ralf Corsepius * ... Mon, 21 Oct 2002 16:59:21 GMT Joel Sherrill [f8ee48bf] * ChangeLog (modified) * aclocal/version.m4 (modified) * cpukit/ChangeLog (modified) * cpukit/aclocal/version.m4 (modified) 2002-10-21 Joel Sherrill * ... Fri, 11 Oct 2002 04:28:28 GMT Ralf Corsepius [aa7428a] * ChangeLog (modified) * aclocal/ppc.m4 (modified) 2002-10-11 Ralf Corsepius * ... Fri, 11 Oct 2002 04:27:07 GMT Ralf Corsepius [59d28b7] * ChangeLog (modified) * acinclude.m4 (modified) * aclocal/quoting.m4 (added) 2002-10-11 Ralf Corsepius * ... Mon, 07 Oct 2002 17:13:56 GMT Joel Sherrill [523fb4b] * ChangeLog (modified) * aclocal/version.m4 (modified) * cpukit/ChangeLog (modified) 2002-10-07 Joel Sherrill * ... Fri, 04 Oct 2002 16:03:20 GMT Joel Sherrill [47c6985d] * aclocal/version.m4 (modified) * cpukit/ChangeLog (modified) * cpukit/aclocal/version.m4 (modified) 2002-10-04 Joel Sherrill * ... Thu, 29 Aug 2002 15:54:00 GMT Ralf Corsepius [72f4ec87] * ChangeLog (modified) * aclocal/bsp-configure.m4 (modified) 2002-08-29 Ralf Corsepius * ... Wed, 28 Aug 2002 17:42:44 GMT Ralf Corsepius [6c15108] * ChangeLog (modified) * aclocal/prog-gnat.m4 (added) 2002-08-28 Ralf Corsepius * ... Sun, 11 Aug 2002 09:10:48 GMT Ralf Corsepius [ca3fa6bb] * ChangeLog (modified) * aclocal/bsp-configure.m4 (modified) 2002-08-11 Ralf Corsepius * ... Sun, 11 Aug 2002 09:07:33 GMT Ralf Corsepius [24688dbd] * ChangeLog (modified) * aclocal/env-rtemsbsp.m4 (modified) 2002-08-11 Ralf Corsepius * ... Fri, 09 Aug 2002 04:25:56 GMT Ralf Corsepius [d69c9c6] * ChangeLog (modified) * aclocal/check-bsp-cache.m4 (modified) 2002-08-09 Ralf Corsepius * ... Wed, 07 Aug 2002 16:21:47 GMT Joel Sherrill [d5dc04f] * ChangeLog (modified) * aclocal/version.m4 (modified) * cpukit/ChangeLog (modified) 2002-08-07 Joel Sherrill * ... Tue, 06 Aug 2002 07:31:47 GMT Ralf Corsepius [d3f954e] * ChangeLog (modified) * aclocal/env-rtemsbsp.m4 (modified) 2002-08-06 Ralf Corsepius * ... Wed, 31 Jul 2002 13:32:27 GMT Joel Sherrill [79b15c1d] * ChangeLog (modified) * aclocal/rtems-cpu-subdirs.m4 (modified) * cpukit/ChangeLog (modified) * cpukit/aclocal/rtems-cpu-subdirs.m4 (modified) 2002-07-31 Joel Sherrill * ... Mon, 22 Jul 2002 16:07:34 GMT Ralf Corsepius [b4cde04] * ChangeLog (modified) * acinclude.m4 (moved) 2002-07-22 Ralf Corsepius * ... Mon, 22 Jul 2002 10:13:20 GMT Ralf Corsepius [0e08a3c3] * ChangeLog (modified) * aclocal/check-cpu.m4 (modified) 2002-07-22 Ralf Corsepius * ... Mon, 22 Jul 2002 09:17:40 GMT Ralf Corsepius [35b2275] * ChangeLog (modified) * aclocal/bsp-configure.m4 (modified) * automake/compile.am (modified) * automake/lib.am (modified) 2002-07-22 Ralf Corsepius * ... Fri, 19 Jul 2002 04:04:49 GMT Ralf Corsepius [cca5631] * ChangeLog (modified) * aclocal/env-rtemsbsp.m4 (modified) 2002-07-18 Ralf Corsepius * ... Wed, 17 Jul 2002 17:21:49 GMT Joel Sherrill [76af1fc] * ChangeLog (modified) * aclocal/version.m4 (modified) 2002-07-17 Joel Sherrill * ... Sun, 30 Jun 2002 06:27:36 GMT Ralf Corsepius [0f8ae13c] * ChangeLog (modified) * aclocal/check-multiprocessing.m4 (modified) * aclocal/enable-multiprocessing.m4 (modified) 2002-06-30 Ralf Corsepius * ... Fri, 28 Jun 2002 19:28:49 GMT Joel Sherrill [f610f0c5] * ChangeLog (modified) * aclocal/version.m4 (modified) 2002-06-28 Joel Sherrill * ... Mon, 17 Jun 2002 14:58:21 GMT Ralf Corsepius [ba2df911] * ChangeLog (modified) * aclocal/env-rtemscpu.m4 (deleted) * aclocal/multi.m4 (deleted) * aclocal/multilib.m4 (modified) 2002-06-17 Ralf Corsepius * ... Tue, 28 May 2002 13:13:29 GMT Joel Sherrill [28311188] * ChangeLog (modified) * aclocal/version.m4 (modified) 2002-05-28 Joel Sherrill * ... Wed, 17 Apr 2002 13:27:29 GMT Joel Sherrill [53eb191] * ChangeLog (modified) * aclocal/prog-cc.m4 (modified) * aclocal/prog-cxx.m4 (modified) 2002-04-15 Ralf Corsepius * ... Tue, 16 Apr 2002 17:37:03 GMT Joel Sherrill [fd2bc17a] * ChangeLog (modified) * aclocal/enable-gcc28.m4 (deleted) * aclocal/enable-libcdir.m4 (deleted) 2002-04-16 Ralf Corsepius * ... Thu, 28 Mar 2002 14:25:50 GMT Joel Sherrill [321f5ff] * ChangeLog (modified) * aclocal/version.m4 (added) 2002-03-27 Ralf Corsepius * ... Thu, 28 Mar 2002 13:53:19 GMT Joel Sherrill [76d527ec] * aclocal/rtems-top.m4 (modified) * bootstrap (modified) * configure.ac (modified) 2002-03-27 Ralf Corsepius * ... Fri, 15 Mar 2002 18:57:17 GMT Joel Sherrill [dee576c0] * ChangeLog (modified) * aclocal/env-rtemscpu.m4 (modified) 2002-03-14 Ralf Corsepius * ... Wed, 06 Feb 2002 16:41:37 GMT Joel Sherrill [9b11632] * ChangeLog (modified) * aclocal/subdirs.m4 (modified) 2002-02-06 Ralf Corsepius * ... Thu, 24 Jan 2002 14:14:55 GMT Joel Sherrill [d7aabb7c] * ChangeLog (modified) * aclocal/sysv-ipc.m4 (modified) * bootstrap (modified) 2002-01-23 Ralf Corsepius * ... Tue, 22 Jan 2002 18:03:19 GMT Joel Sherrill [cbc4e6fa] * ChangeLog (modified) * aclocal/env-rtemsbsp.m4 (modified) 2002-01-22 Ralf Corsepius * ... Tue, 08 Jan 2002 12:06:18 GMT Joel Sherrill [36202ec] * ChangeLog (modified) * aclocal/check-tool.m4 (modified) 2002-02-07 Ralf Corsepius * ... Sun, 06 Jan 2002 20:12:13 GMT Joel Sherrill [a0ea6f1] * ChangeLog (modified) * aclocal/check-newlib.m4 (modified) * aclocal/config-subdirs.m4 (modified) * aclocal/subdirs.m4 (modified) * aclocal/sysv-ipc.m4 (modified) * aclocal/target.m4 (modified) * automake/compile.am (modified) 2002-02-05 Ralf Corsepius * ... Thu, 20 Dec 2001 17:33:23 GMT Joel Sherrill [ba748523] * ChangeLog (modified) * aclocal/check-posix.m4 (modified) * aclocal/config-subdirs.m4 (modified) * aclocal/env-rtemsbsp.m4 (modified) * aclocal/env-rtemscpu.m4 (modified) * aclocal/multi.m4 (added) * aclocal/multilib.m4 (modified) * aclocal/project-root.m4 (modified) * aclocal/rtems-debug.m4 (modified) * aclocal/rtems-top.m4 (modified) * aclocal/subdirs.m4 (added) * automake/compile.am (modified) * configure.ac (modified) 2001-12-20 Ralf Corsepius * ... Mon, 03 Dec 2001 16:09:08 GMT Joel Sherrill [1a457f5] * ChangeLog (modified) * Makefile.am (modified) * aclocal/bsp-configure.m4 (added) 2001-11-30 Ralf Corsepius * ... Wed, 21 Nov 2001 18:36:51 GMT Joel Sherrill [8e541868] * ChangeLog (modified) * aclocal/bsp-alias.m4 (modified) * aclocal/check-bsps.m4 (modified) * aclocal/prog-cc.m4 (modified) 2001-11-21 Ralf Corsepius * ... Tue, 20 Nov 2001 18:50:12 GMT Joel Sherrill [466e590] * ChangeLog (modified) * aclocal/ppc.m4 (added) * automake/force-preinstall.am (added) 2001-11-15 Ralf Corsepius * ... Thu, 15 Nov 2001 16:50:33 GMT Joel Sherrill [9c392aa2] * ChangeLog (modified) * aclocal/bsp-alias.m4 (modified) * aclocal/check-bsps.m4 (modified) 2001-11-14 Ralf Corsepius * ... Wed, 14 Nov 2001 18:57:26 GMT Joel Sherrill [7ee86ba7] * ChangeLog (modified) * aclocal/bspopts.m4 (added) 2001-11-14 Ralf Corsepius * ... Wed, 17 Oct 2001 20:30:38 GMT Joel Sherrill [60c7524] * ChangeLog (modified) * aclocal/check-rdbg.m4 (modified) 2001-10-17 Ralf Corsepius * ... Wed, 17 Oct 2001 13:15:11 GMT Joel Sherrill [080afec] * ChangeLog (modified) * Makefile.am (modified) * aclocal/rtems-cpu-subdirs.m4 (modified) * aclocal/target.m4 (modified) 2001-10-16 Ralf Corsepius * ... Wed, 10 Oct 2001 00:38:56 GMT Joel Sherrill [083b72a] * ChangeLog (modified) * aclocal/rtems-cpu-subdirs.m4 (added) 2001-10-09 Ralf Corsepius * ... Fri, 14 Sep 2001 17:30:22 GMT Joel Sherrill [37b5d78] * ChangeLog (modified) * aclocal/canonical-target-name.m4 (modified) * aclocal/config-subdirs.m4 (modified) * aclocal/target.m4 (modified) * make/custom/mbx8xx.cfg (modified) 2001-09-14 Ralf Corsepius * ... Thu, 13 Sep 2001 13:14:30 GMT Joel Sherrill [e712997] * ChangeLog (modified) * aclocal/enable-bare.m4 (modified) * aclocal/enable-cxx.m4 (modified) * aclocal/enable-gcc28.m4 (modified) * aclocal/enable-inlines.m4 (modified) * aclocal/enable-itron.m4 (modified) * aclocal/enable-libcdir.m4 (modified) * aclocal/enable-multiprocessing.m4 (modified) * aclocal/enable-networking.m4 (modified) * aclocal/enable-posix.m4 (modified) * aclocal/enable-rdbg.m4 (modified) * aclocal/enable-rtemsbsp.m4 (modified) * aclocal/enable-tests.m4 (modified) * aclocal/env-rtemsbsp.m4 (modified) * aclocal/multilib.m4 (modified) * aclocal/rtems-debug.m4 (modified) * aclocal/rtems-test-no-pause.m4 (modified) * aclocal/rtems-top.m4 (modified) * bootstrap (modified) * configure.in (modified) 2001-07-19 Ralf Corsepius * ... Thu, 24 May 2001 20:01:10 GMT Joel Sherrill [a86c171] * ChangeLog (modified) * aclocal/canonical-target-name.m4 (modified) * aclocal/config-subdirs.m4 (modified) 2001-05-16 Ralf Corsepius * ... Mon, 07 May 2001 13:15:49 GMT Joel Sherrill [f1d08c98] * ChangeLog (modified) * aclocal/prog-cc.m4 (modified) 2001-04-27 Ralf Corsepius * ... Fri, 20 Apr 2001 17:27:55 GMT Joel Sherrill [084556d] * ChangeLog (modified) * aclocal/check-rdbg.m4 (modified) 2001-04-20 Eric Valette * ... Wed, 21 Feb 2001 14:20:50 GMT Joel Sherrill [b50b3c8] * ChangeLog (modified) * aclocal/bsp-alias.m4 (modified) * aclocal/check-bsps.m4 (modified) * aclocal/config-subdirs.m4 (modified) * aclocal/enable-rtemsbsp.m4 (modified) 2001-02-20 Ralf Corsepius * ... Mon, 05 Feb 2001 18:04:57 GMT Joel Sherrill [f5c58361] * aclocal/config-subdirs.m4 (added) * aclocal/target.m4 (modified) 2001-02-03 Ralf Corsepius * ... Fri, 02 Feb 2001 18:32:12 GMT Joel Sherrill [2608a535] * aclocal/env-rtemsbsp.m4 (modified) * aclocal/env-rtemscpu.m4 (modified) 2001-02-02 Ralf Corsepius * ...
