# # ChangeLog for aclocal in rtems # # Generated by Trac 1.2.1.dev0 # 04/23/24 12:52:57 Fri, 16 May 2003 09:11:40 GMT Ralf Corsepius [1cd9dfc] * ChangeLog (modified) * aclocal/check-cxx.m4 (modified) * automake/compile.am (modified) 2003-05-16 Ralf Corsepius * ... Thu, 17 Apr 2003 19:44:03 GMT Joel Sherrill [7ae9530] * ChangeLog (modified) * aclocal/version.m4 (modified) * cpukit/ChangeLog (modified) * cpukit/aclocal/version.m4 (modified) 2003-04-17 Joel Sherrill * ... Fri, 11 Apr 2003 21:51:46 GMT Joel Sherrill [f1208c0] * ChangeLog (modified) * aclocal/version.m4 (modified) * cpukit/ChangeLog (modified) * cpukit/aclocal/version.m4 (modified) 2003-04-11 Joel Sherrill * ... Fri, 11 Apr 2003 21:29:42 GMT Joel Sherrill [1ee68d1] * ChangeLog (modified) * aclocal/version.m4 (modified) * cpukit/ChangeLog (modified) * cpukit/aclocal/version.m4 (modified) 2003-04-11 Joel Sherrill * ... Mon, 10 Mar 2003 16:46:32 GMT Ralf Corsepius [89b51f4] * aclocal/rtems-top.m4 (modified) * make/ChangeLog (modified) * make/custom/arm_bare_bsp.cfg (modified) * make/custom/armulator.cfg (modified) * make/custom/edb7312.cfg (modified) * make/custom/ppcn_60x.cfg (modified) * make/custom/vegaplus.cfg (modified) Merger from rtems-4-6-branch Fri, 14 Feb 2003 19:43:28 GMT Joel Sherrill [6dd184ce] * ChangeLog (modified) * README.configure (modified) * aclocal/rtems-cpu-subdirs.m4 (modified) 2003-02-14 Joel Sherrill * ... Fri, 14 Feb 2003 05:15:15 GMT Ralf Corsepius [6b2b4a36] * ChangeLog (modified) * aclocal/canonical-target-name.m4 (modified) * cpukit/ChangeLog (modified) * cpukit/aclocal/canonical-target-name.m4 (modified) Merger from rtems-4-6-branch. Tue, 28 Jan 2003 18:47:37 GMT Joel Sherrill [4f3e2c28] * ChangeLog (modified) * aclocal/version.m4 (modified) * cpukit/ChangeLog (modified) 2003-01-28 Joel Sherrill * ... Thu, 16 Jan 2003 04:29:28 GMT Ralf Corsepius [2a2def9] * ChangeLog (modified) * aclocal/enable-cxx.m4 (modified) * aclocal/rtems-cpu-subdirs.m4 (modified) 2001-01-16 Ralf Corsepius * ... Thu, 19 Dec 2002 16:00:03 GMT Ralf Corsepius [bde6014e] * ChangeLog (modified) * aclocal/prog-cxx.m4 (modified) 2002-12-19 Ralf Corsepius * ... Tue, 10 Dec 2002 16:43:55 GMT Ralf Corsepius [3907075f] * ChangeLog (modified) * aclocal/prog-cxx.m4 (modified) 2002-12-10 Ralf Corsepius * ... Sat, 07 Dec 2002 13:06:23 GMT Ralf Corsepius [6fea3824] * ChangeLog (modified) * aclocal/bsp-configure.m4 (modified) * aclocal/env-rtemsbsp.m4 (modified) 2002-12-07 Ralf Corsepius * ... Fri, 06 Dec 2002 07:13:50 GMT Ralf Corsepius [c2113d3] * ChangeLog (modified) * aclocal/env-rtemsbsp.m4 (modified) * aclocal/prog-cc.m4 (modified) * aclocal/prog-cxx.m4 (modified) 2002-12-06 Ralf Corsepius * ... Fri, 06 Dec 2002 04:40:18 GMT Ralf Corsepius [8b38a769] * ChangeLog (modified) * aclocal/rtems-flags.m4 (added) * cpukit/ChangeLog (modified) * cpukit/aclocal/rtems-flags.m4 (added) 2002-12-06 Ralf Corsepius * ... Sun, 01 Dec 2002 11:45:50 GMT Ralf Corsepius [c47c12b] * ChangeLog (modified) * aclocal/prog-cc.m4 (modified) 2002-12-01 Ralf Corsepius * ... Fri, 29 Nov 2002 08:27:53 GMT Ralf Corsepius [ff65620] * ChangeLog (modified) * aclocal/canonicalize-tools.m4 (modified) * aclocal/check-bsps.m4 (modified) * aclocal/check-custom-bsp.m4 (added) * aclocal/prog-ccas.m4 (added) 2002-11-29 Ralf Corsepius * ... Wed, 20 Nov 2002 02:57:38 GMT Ralf Corsepius [0a9a0f5] * ChangeLog (modified) * aclocal/quoting.m4 (modified) 2002-11-19 Ralf Corsepius * ... Tue, 19 Nov 2002 17:05:34 GMT Ralf Corsepius [86f12bc] * ChangeLog (modified) * aclocal/check-newlib.m4 (modified) * automake/compile.am (modified) 2002-11-19 Ralf Corsepius * ... Tue, 19 Nov 2002 14:54:45 GMT Ralf Corsepius [984123f] * ChangeLog (modified) * aclocal/sysv-ipc.m4 (deleted) * aclocal/target.m4 (modified) 2002-11-19 Ralf Corsepius * ... Tue, 19 Nov 2002 00:31:31 GMT Ralf Corsepius [824bf2e4] * ChangeLog (modified) * aclocal/target.m4 (modified) 2002-11-18 Ralf Corsepius * ... Mon, 18 Nov 2002 13:57:54 GMT Joel Sherrill [b5a59c3f] * ChangeLog (modified) * aclocal/version.m4 (modified) * cpukit/ChangeLog (modified) * cpukit/aclocal/version.m4 (modified) 2002-11-18 Joel Sherrill * ... Mon, 18 Nov 2002 03:31:27 GMT Joel Sherrill [174eed8c] * ChangeLog (modified) * aclocal/bsp-alias.m4 (modified) * aclocal/check-bsps.m4 (modified) 2002-11-17 Joel Sherrill * ... Fri, 15 Nov 2002 14:13:01 GMT Ralf Corsepius [f289c09] * ChangeLog (modified) * acinclude.m4 (modified) * aclocal/prog-cc.m4 (modified) 2002-11-15 Ralf Corsepius * ... Mon, 11 Nov 2002 21:55:50 GMT Joel Sherrill [b99463c] * ChangeLog (modified) * aclocal/version.m4 (modified) * cpukit/ChangeLog (modified) 2002-11-11 Joel Sherrill * ... Wed, 06 Nov 2002 11:16:52 GMT Ralf Corsepius [e05468fb] * ChangeLog (modified) * aclocal/enable-inlines.m4 (modified) * aclocal/quoting.m4 (modified) * aclocal/target.m4 (modified) 2002-11-06 Ralf Corsepius ... Tue, 29 Oct 2002 14:37:34 GMT Ralf Corsepius [314a962] * ChangeLog (modified) * aclocal/enable-bare.m4 (modified) * aclocal/enable-cxx.m4 (modified) * aclocal/enable-inlines.m4 (modified) * aclocal/enable-itron.m4 (modified) * aclocal/enable-multiprocessing.m4 (modified) * aclocal/enable-networking.m4 (modified) * aclocal/enable-posix.m4 (modified) * aclocal/enable-rdbg.m4 (modified) * aclocal/enable-rtemsbsp.m4 (modified) * aclocal/enable-tests.m4 (modified) 2002-10-29 Ralf Corsepius * ... Mon, 28 Oct 2002 17:56:41 GMT Ralf Corsepius [1da0c52] * ChangeLog (modified) * aclocal/enable-rtemsbsp.m4 (modified) 2002-10-28 Ralf Corsepius * ... Mon, 21 Oct 2002 16:59:21 GMT Joel Sherrill [f8ee48bf] * ChangeLog (modified) * aclocal/version.m4 (modified) * cpukit/ChangeLog (modified) * cpukit/aclocal/version.m4 (modified) 2002-10-21 Joel Sherrill * ... Fri, 11 Oct 2002 04:28:28 GMT Ralf Corsepius [aa7428a] * ChangeLog (modified) * aclocal/ppc.m4 (modified) 2002-10-11 Ralf Corsepius * ... Fri, 11 Oct 2002 04:27:07 GMT Ralf Corsepius [59d28b7] * ChangeLog (modified) * acinclude.m4 (modified) * aclocal/quoting.m4 (added) 2002-10-11 Ralf Corsepius * ... Mon, 07 Oct 2002 17:13:56 GMT Joel Sherrill [523fb4b] * ChangeLog (modified) * aclocal/version.m4 (modified) * cpukit/ChangeLog (modified) 2002-10-07 Joel Sherrill * ... Fri, 04 Oct 2002 16:03:20 GMT Joel Sherrill [47c6985d] * aclocal/version.m4 (modified) * cpukit/ChangeLog (modified) * cpukit/aclocal/version.m4 (modified) 2002-10-04 Joel Sherrill * ... Thu, 29 Aug 2002 15:54:00 GMT Ralf Corsepius [72f4ec87] * ChangeLog (modified) * aclocal/bsp-configure.m4 (modified) 2002-08-29 Ralf Corsepius * ... Wed, 28 Aug 2002 17:42:44 GMT Ralf Corsepius [6c15108] * ChangeLog (modified) * aclocal/prog-gnat.m4 (added) 2002-08-28 Ralf Corsepius * ... Sun, 11 Aug 2002 09:10:48 GMT Ralf Corsepius [ca3fa6bb] * ChangeLog (modified) * aclocal/bsp-configure.m4 (modified) 2002-08-11 Ralf Corsepius * ... Sun, 11 Aug 2002 09:07:33 GMT Ralf Corsepius [24688dbd] * ChangeLog (modified) * aclocal/env-rtemsbsp.m4 (modified) 2002-08-11 Ralf Corsepius * ... Fri, 09 Aug 2002 04:25:56 GMT Ralf Corsepius [d69c9c6] * ChangeLog (modified) * aclocal/check-bsp-cache.m4 (modified) 2002-08-09 Ralf Corsepius * ... Wed, 07 Aug 2002 16:21:47 GMT Joel Sherrill [d5dc04f] * ChangeLog (modified) * aclocal/version.m4 (modified) * cpukit/ChangeLog (modified) 2002-08-07 Joel Sherrill * ... Tue, 06 Aug 2002 07:31:47 GMT Ralf Corsepius [d3f954e] * ChangeLog (modified) * aclocal/env-rtemsbsp.m4 (modified) 2002-08-06 Ralf Corsepius * ... Wed, 31 Jul 2002 13:32:27 GMT Joel Sherrill [79b15c1d] * ChangeLog (modified) * aclocal/rtems-cpu-subdirs.m4 (modified) * cpukit/ChangeLog (modified) * cpukit/aclocal/rtems-cpu-subdirs.m4 (modified) 2002-07-31 Joel Sherrill * ... Mon, 22 Jul 2002 16:07:34 GMT Ralf Corsepius [b4cde04] * ChangeLog (modified) * acinclude.m4 (moved) 2002-07-22 Ralf Corsepius * ... Mon, 22 Jul 2002 10:13:20 GMT Ralf Corsepius [0e08a3c3] * ChangeLog (modified) * aclocal/check-cpu.m4 (modified) 2002-07-22 Ralf Corsepius * ... Mon, 22 Jul 2002 09:17:40 GMT Ralf Corsepius [35b2275] * ChangeLog (modified) * aclocal/bsp-configure.m4 (modified) * automake/compile.am (modified) * automake/lib.am (modified) 2002-07-22 Ralf Corsepius * ... Fri, 19 Jul 2002 04:04:49 GMT Ralf Corsepius [cca5631] * ChangeLog (modified) * aclocal/env-rtemsbsp.m4 (modified) 2002-07-18 Ralf Corsepius * ... Wed, 17 Jul 2002 17:21:49 GMT Joel Sherrill [76af1fc] * ChangeLog (modified) * aclocal/version.m4 (modified) 2002-07-17 Joel Sherrill * ... Sun, 30 Jun 2002 06:27:36 GMT Ralf Corsepius [0f8ae13c] * ChangeLog (modified) * aclocal/check-multiprocessing.m4 (modified) * aclocal/enable-multiprocessing.m4 (modified) 2002-06-30 Ralf Corsepius * ... Fri, 28 Jun 2002 19:28:49 GMT Joel Sherrill [f610f0c5] * ChangeLog (modified) * aclocal/version.m4 (modified) 2002-06-28 Joel Sherrill * ... Mon, 17 Jun 2002 14:58:21 GMT Ralf Corsepius [ba2df911] * ChangeLog (modified) * aclocal/env-rtemscpu.m4 (deleted) * aclocal/multi.m4 (deleted) * aclocal/multilib.m4 (modified) 2002-06-17 Ralf Corsepius * ... Tue, 28 May 2002 13:13:29 GMT Joel Sherrill [28311188] * ChangeLog (modified) * aclocal/version.m4 (modified) 2002-05-28 Joel Sherrill * ... Wed, 17 Apr 2002 13:27:29 GMT Joel Sherrill [53eb191] * ChangeLog (modified) * aclocal/prog-cc.m4 (modified) * aclocal/prog-cxx.m4 (modified) 2002-04-15 Ralf Corsepius * ... Tue, 16 Apr 2002 17:37:03 GMT Joel Sherrill [fd2bc17a] * ChangeLog (modified) * aclocal/enable-gcc28.m4 (deleted) * aclocal/enable-libcdir.m4 (deleted) 2002-04-16 Ralf Corsepius * ... Thu, 28 Mar 2002 14:25:50 GMT Joel Sherrill [321f5ff] * ChangeLog (modified) * aclocal/version.m4 (added) 2002-03-27 Ralf Corsepius * ... Thu, 28 Mar 2002 13:53:19 GMT Joel Sherrill [76d527ec] * aclocal/rtems-top.m4 (modified) * bootstrap (modified) * configure.ac (modified) 2002-03-27 Ralf Corsepius * ... Fri, 15 Mar 2002 18:57:17 GMT Joel Sherrill [dee576c0] * ChangeLog (modified) * aclocal/env-rtemscpu.m4 (modified) 2002-03-14 Ralf Corsepius * ... Wed, 06 Feb 2002 16:41:37 GMT Joel Sherrill [9b11632] * ChangeLog (modified) * aclocal/subdirs.m4 (modified) 2002-02-06 Ralf Corsepius * ... Thu, 24 Jan 2002 14:14:55 GMT Joel Sherrill [d7aabb7c] * ChangeLog (modified) * aclocal/sysv-ipc.m4 (modified) * bootstrap (modified) 2002-01-23 Ralf Corsepius * ... Tue, 22 Jan 2002 18:03:19 GMT Joel Sherrill [cbc4e6fa] * ChangeLog (modified) * aclocal/env-rtemsbsp.m4 (modified) 2002-01-22 Ralf Corsepius * ... Tue, 08 Jan 2002 12:06:18 GMT Joel Sherrill [36202ec] * ChangeLog (modified) * aclocal/check-tool.m4 (modified) 2002-02-07 Ralf Corsepius * ... Sun, 06 Jan 2002 20:12:13 GMT Joel Sherrill [a0ea6f1] * ChangeLog (modified) * aclocal/check-newlib.m4 (modified) * aclocal/config-subdirs.m4 (modified) * aclocal/subdirs.m4 (modified) * aclocal/sysv-ipc.m4 (modified) * aclocal/target.m4 (modified) * automake/compile.am (modified) 2002-02-05 Ralf Corsepius * ... Thu, 20 Dec 2001 17:33:23 GMT Joel Sherrill [ba748523] * ChangeLog (modified) * aclocal/check-posix.m4 (modified) * aclocal/config-subdirs.m4 (modified) * aclocal/env-rtemsbsp.m4 (modified) * aclocal/env-rtemscpu.m4 (modified) * aclocal/multi.m4 (added) * aclocal/multilib.m4 (modified) * aclocal/project-root.m4 (modified) * aclocal/rtems-debug.m4 (modified) * aclocal/rtems-top.m4 (modified) * aclocal/subdirs.m4 (added) * automake/compile.am (modified) * configure.ac (modified) 2001-12-20 Ralf Corsepius * ... Mon, 03 Dec 2001 16:09:08 GMT Joel Sherrill [1a457f5] * ChangeLog (modified) * Makefile.am (modified) * aclocal/bsp-configure.m4 (added) 2001-11-30 Ralf Corsepius * ... Wed, 21 Nov 2001 18:36:51 GMT Joel Sherrill [8e541868] * ChangeLog (modified) * aclocal/bsp-alias.m4 (modified) * aclocal/check-bsps.m4 (modified) * aclocal/prog-cc.m4 (modified) 2001-11-21 Ralf Corsepius * ... Tue, 20 Nov 2001 18:50:12 GMT Joel Sherrill [466e590] * ChangeLog (modified) * aclocal/ppc.m4 (added) * automake/force-preinstall.am (added) 2001-11-15 Ralf Corsepius * ... Thu, 15 Nov 2001 16:50:33 GMT Joel Sherrill [9c392aa2] * ChangeLog (modified) * aclocal/bsp-alias.m4 (modified) * aclocal/check-bsps.m4 (modified) 2001-11-14 Ralf Corsepius * ... Wed, 14 Nov 2001 18:57:26 GMT Joel Sherrill [7ee86ba7] * ChangeLog (modified) * aclocal/bspopts.m4 (added) 2001-11-14 Ralf Corsepius * ... Wed, 17 Oct 2001 20:30:38 GMT Joel Sherrill [60c7524] * ChangeLog (modified) * aclocal/check-rdbg.m4 (modified) 2001-10-17 Ralf Corsepius * ... Wed, 17 Oct 2001 13:15:11 GMT Joel Sherrill [080afec] * ChangeLog (modified) * Makefile.am (modified) * aclocal/rtems-cpu-subdirs.m4 (modified) * aclocal/target.m4 (modified) 2001-10-16 Ralf Corsepius * ... Wed, 10 Oct 2001 00:38:56 GMT Joel Sherrill [083b72a] * ChangeLog (modified) * aclocal/rtems-cpu-subdirs.m4 (added) 2001-10-09 Ralf Corsepius * ... Fri, 14 Sep 2001 17:30:22 GMT Joel Sherrill [37b5d78] * ChangeLog (modified) * aclocal/canonical-target-name.m4 (modified) * aclocal/config-subdirs.m4 (modified) * aclocal/target.m4 (modified) * make/custom/mbx8xx.cfg (modified) 2001-09-14 Ralf Corsepius * ... Thu, 13 Sep 2001 13:14:30 GMT Joel Sherrill [e712997] * ChangeLog (modified) * aclocal/enable-bare.m4 (modified) * aclocal/enable-cxx.m4 (modified) * aclocal/enable-gcc28.m4 (modified) * aclocal/enable-inlines.m4 (modified) * aclocal/enable-itron.m4 (modified) * aclocal/enable-libcdir.m4 (modified) * aclocal/enable-multiprocessing.m4 (modified) * aclocal/enable-networking.m4 (modified) * aclocal/enable-posix.m4 (modified) * aclocal/enable-rdbg.m4 (modified) * aclocal/enable-rtemsbsp.m4 (modified) * aclocal/enable-tests.m4 (modified) * aclocal/env-rtemsbsp.m4 (modified) * aclocal/multilib.m4 (modified) * aclocal/rtems-debug.m4 (modified) * aclocal/rtems-test-no-pause.m4 (modified) * aclocal/rtems-top.m4 (modified) * bootstrap (modified) * configure.in (modified) 2001-07-19 Ralf Corsepius * ... Thu, 24 May 2001 20:01:10 GMT Joel Sherrill [a86c171] * ChangeLog (modified) * aclocal/canonical-target-name.m4 (modified) * aclocal/config-subdirs.m4 (modified) 2001-05-16 Ralf Corsepius * ... Mon, 07 May 2001 13:15:49 GMT Joel Sherrill [f1d08c98] * ChangeLog (modified) * aclocal/prog-cc.m4 (modified) 2001-04-27 Ralf Corsepius * ... Fri, 20 Apr 2001 17:27:55 GMT Joel Sherrill [084556d] * ChangeLog (modified) * aclocal/check-rdbg.m4 (modified) 2001-04-20 Eric Valette * ... Wed, 21 Feb 2001 14:20:50 GMT Joel Sherrill [b50b3c8] * ChangeLog (modified) * aclocal/bsp-alias.m4 (modified) * aclocal/check-bsps.m4 (modified) * aclocal/config-subdirs.m4 (modified) * aclocal/enable-rtemsbsp.m4 (modified) 2001-02-20 Ralf Corsepius * ... Mon, 05 Feb 2001 18:04:57 GMT Joel Sherrill [f5c58361] * aclocal/config-subdirs.m4 (added) * aclocal/target.m4 (modified) 2001-02-03 Ralf Corsepius * ... Fri, 02 Feb 2001 18:32:12 GMT Joel Sherrill [2608a535] * aclocal/env-rtemsbsp.m4 (modified) * aclocal/env-rtemscpu.m4 (modified) 2001-02-02 Ralf Corsepius * ... Fri, 02 Feb 2001 18:30:42 GMT Joel Sherrill [21d7de3a] * ChangeLog (modified) * aclocal/bsp-arg-enable.m4 (modified) * aclocal/check-bsps.m4 (modified) * configure.in (modified) 2001-02-02 Ralf Corsepius * ... Mon, 29 Jan 2001 15:27:25 GMT Joel Sherrill [560aae24] * ChangeLog (modified) * aclocal/bsp-arg-enable.m4 (added) * aclocal/enable-rtemsbsp.m4 (modified) * aclocal/env-rtemsbsp.m4 (added) * aclocal/env-rtemscpu.m4 (added) * aclocal/prog-cc.m4 (modified) * automake/compile.am (modified) 2001-01-26 Ralf Corsepius * ... Mon, 22 Jan 2001 14:03:44 GMT Joel Sherrill [227ae749] * ChangeLog (modified) * aclocal/bsp-alias.m4 (modified) * aclocal/check-bsps.m4 (modified) * make/ChangeLog (modified) * make/custom/shsim.cfg (modified) * make/custom/simsh7032.cfg (added) * make/custom/simsh7045.cfg (added) 2001-01-22 Ralf Corsepius * ... Wed, 15 Nov 2000 21:56:52 GMT Joel Sherrill [1033e27] * ChangeLog (modified) * aclocal/canonical-host.m4 (modified) * aclocal/check-newlib.m4 (modified) * aclocal/rtems-debug.m4 (modified) * aclocal/rtems-top.m4 (modified) 2000-11-13 Ralf Corsepius * ... Mon, 13 Nov 2000 22:51:54 GMT Joel Sherrill [a44f9ca5] * ChangeLog (modified) * README.configure (modified) * aclocal/bsp-alias.m4 (modified) * aclocal/check-bsps.m4 (modified) 2000-11-13 Jiri Gaisler * ... Thu, 09 Nov 2000 17:04:53 GMT Joel Sherrill [2dbd07f8] * ChangeLog (modified) * aclocal/check-bsp-cache.m4 (modified) * aclocal/gcc-pipe.m4 (modified) * aclocal/gcc-specs.m4 (modified) * aclocal/multilib.m4 (modified) * aclocal/prog-cc.m4 (modified) 2000-11-09 Ralf Corsepius * ... Thu, 09 Nov 2000 17:01:25 GMT Joel Sherrill [5913d94] * ChangeLog (modified) * aclocal/check-newlib.m4 (modified) * aclocal/enable-itron.m4 (modified) * aclocal/enable-posix.m4 (modified) * aclocal/sysv-ipc.m4 (modified) * configure.in (modified) 2000-11-09 Ralf Corsepius * ... Fri, 03 Nov 2000 14:15:29 GMT Joel Sherrill [6870384] * aclocal/check-tool.m4 (added) 2000-11-02 Ralf Corsepius * ... Thu, 02 Nov 2000 22:51:12 GMT Joel Sherrill [4686e5d9] * ChangeLog (modified) * aclocal/canonicalize-tools.m4 (modified) * aclocal/prog-cc.m4 (modified) * aclocal/prog-cxx.m4 (modified) 2000-11-02 Ralf Corsepius * ... Thu, 02 Nov 2000 15:55:26 GMT Joel Sherrill [2f17d74] * ChangeLog (modified) * aclocal/canonicalize-tools.m4 (modified) 2000-11-02 Ralf Corsepius * ... Thu, 02 Nov 2000 15:44:04 GMT Joel Sherrill [2e0fd427] * ChangeLog (modified) * Makefile.am (modified) * aclocal/ar-s.m4 (deleted) * aclocal/canonicalize-tools.m4 (modified) * aclocal/check-cxx.m4 (modified) * aclocal/check-newlib.m4 (modified) * aclocal/enable-rtemsbsp.m4 (modified) * aclocal/gcc-pipe.m4 (modified) * aclocal/gcc-specs.m4 (modified) * aclocal/i386-gas-code16.m4 (modified) * aclocal/multilib.m4 (modified) * aclocal/prog-cc.m4 (modified) * aclocal/prog-cxx.m4 (modified) * aclocal/project-root.m4 (modified) * aclocal/rtems-top.m4 (modified) * aclocal/target.m4 (modified) * aclocal/tool-prefix.m4 (deleted) * macros/bsp-alias.m4 (deleted) * macros/canonical-host.m4 (deleted) * macros/canonical-target-name.m4 (deleted) * macros/canonicalize-tools.m4 (deleted) * macros/check-bsp-cache.m4 (deleted) * macros/check-bsps.m4 (deleted) * macros/check-cpu.m4 (deleted) * macros/check-cxx.m4 (deleted) * macros/check-itron.m4 (deleted) * macros/check-multiprocessing.m4 (deleted) * macros/check-networking.m4 (deleted) * macros/check-newlib.m4 (deleted) * macros/check-posix.m4 (deleted) * macros/check-rdbg.m4 (deleted) * macros/enable-bare.m4 (deleted) * macros/enable-cxx.m4 (deleted) * macros/enable-gcc28.m4 (deleted) * macros/enable-inlines.m4 (deleted) * macros/enable-itron.m4 (deleted) * macros/enable-libcdir.m4 (deleted) * macros/enable-multiprocessing.m4 (deleted) * macros/enable-networking.m4 (deleted) * macros/enable-posix.m4 (deleted) * macros/enable-rdbg.m4 (deleted) * macros/enable-rtemsbsp.m4 (deleted) * macros/enable-tests.m4 (deleted) * macros/gcc-pipe.m4 (deleted) * macros/gcc-specs.m4 (deleted) * macros/i386-gas-code16.m4 (deleted) * macros/multilib.m4 (deleted) * macros/path-ksh.m4 (deleted) * macros/path-perl.m4 (deleted) * macros/prog-cc.m4 (deleted) * macros/prog-cxx.m4 (deleted) * macros/project-root.m4 (deleted) * macros/rtems-debug.m4 (deleted) * macros/rtems-test-no-pause.m4 (deleted) * macros/rtems-top.m4 (deleted) * macros/sysv-ipc.m4 (deleted) * macros/target.m4 (deleted) * macros/tool-paths.m4 (deleted) 2000-11-02 Ralf Corsepius * ... Tue, 24 Oct 2000 21:59:16 GMT Joel Sherrill [509f8351] * ChangeLog (modified) * aclocal/rtems-top.m4 (modified) * automake/compile.am (modified) * automake/lib.am (modified) 2000-10-24 Ralf Corsepius * ... Thu, 14 Sep 2000 16:54:39 GMT Joel Sherrill [c9782f9] * ChangeLog (modified) * aclocal/enable-hwapi.m4 (deleted) 2000-09-14 Joel Sherrill * ... Wed, 13 Sep 2000 13:08:11 GMT Joel Sherrill [372e4e2] * ChangeLog (modified) * aclocal/rtems-top.m4 (modified) * automake/compile.am (modified) 2000-09-13 Ralf Corsepius * ... Tue, 12 Sep 2000 20:54:13 GMT Joel Sherrill [1ea70d78] * ChangeLog (modified) * aclocal/check-cxx.m4 (modified) * aclocal/prog-cc.m4 (modified) * automake/compile.am (modified) * automake/local.am (modified) 2000-09-12 Ralf Corsepius * ... Tue, 12 Sep 2000 12:52:12 GMT Joel Sherrill [03d5706] * ChangeLog (modified) * aclocal/enable-rtemsbsp.m4 (modified) * aclocal/i386-gas-code16.m4 (modified) * aclocal/target.m4 (modified) * automake/compile.am (modified) 2000-09-12 Ralf Corsepius * ... Wed, 06 Sep 2000 15:29:57 GMT Joel Sherrill [9322194] * ChangeLog (modified) * aclocal/project-root.m4 (modified) 2000-09-06 Ralf Corsepius * ... Fri, 01 Sep 2000 07:12:52 GMT Joel Sherrill [be28778] * ChangeLog (modified) * aclocal/check-bsps.m4 (modified) 2000-08-31 Ralf Corsepius * ... Fri, 25 Aug 2000 17:27:52 GMT Joel Sherrill [8e57762] * ChangeLog (modified) * aclocal/bsp-alias.m4 (modified) * aclocal/check-bsps.m4 (modified) 2000-08-17 Ralf Corsepius * ... Tue, 01 Aug 2000 20:01:14 GMT Joel Sherrill [b812f84] * aclocal/bsp-alias.m4 (modified) * aclocal/check-bsps.m4 (modified) * c/ACKNOWLEDGEMENTS (modified) * c/TESTED (modified) * c/src/lib/libbsp/m68k/shared/bspspuriousinit.c (added) * c/src/lib/libbsp/m68k/shared/m68000spurious.c (added) * c/src/lib/libbsp/m68k/sim68000/.cvsignore (added) * c/src/lib/libbsp/m68k/sim68000/Makefile.am (added) * c/src/lib/libbsp/m68k/sim68000/README (added) * c/src/lib/libbsp/m68k/sim68000/bsp_specs (added) * c/src/lib/libbsp/m68k/sim68000/clock/.cvsignore (added) * c/src/lib/libbsp/m68k/sim68000/clock/Makefile.am (added) * c/src/lib/libbsp/m68k/sim68000/clock/clockdrv.c (added) * c/src/lib/libbsp/m68k/sim68000/configure.in (added) * c/src/lib/libbsp/m68k/sim68000/console/.cvsignore (added) * c/src/lib/libbsp/m68k/sim68000/console/Makefile.am (added) * c/src/lib/libbsp/m68k/sim68000/console/conscfg.c (added) * c/src/lib/libbsp/m68k/sim68000/include/.cvsignore (added) * c/src/lib/libbsp/m68k/sim68000/include/Makefile.am (added) * c/src/lib/libbsp/m68k/sim68000/include/bsp.h (added) * c/src/lib/libbsp/m68k/sim68000/sim68000.setup (added) * c/src/lib/libbsp/m68k/sim68000/start/.cvsignore (added) * c/src/lib/libbsp/m68k/sim68000/start/Makefile.am (added) * c/src/lib/libbsp/m68k/sim68000/start/start.S (added) * c/src/lib/libbsp/m68k/sim68000/startup/.cvsignore (added) * c/src/lib/libbsp/m68k/sim68000/startup/Makefile.am (added) * c/src/lib/libbsp/m68k/sim68000/startup/bspstart.c (added) * c/src/lib/libbsp/m68k/sim68000/startup/linkcmds (added) * c/src/lib/libbsp/m68k/sim68000/startup/spurious_assistant.c (added) * c/src/lib/libbsp/m68k/sim68000/wrapup/.cvsignore (added) * c/src/lib/libbsp/m68k/sim68000/wrapup/Makefile.am (added) * make/custom/sim68000.cfg (added) * make/custom/simcpu32.cfg (added) Added sim68000 BSP for the BSVC simulator. This BSP includes the ... Tue, 25 Jul 2000 13:33:08 GMT Joel Sherrill [7496d9c] * aclocal/rtems-top.m4 (modified) Patch rtems-rc-20000725-1-cvs.diff from Ralf Corsepius [dbe50fd] * aclocal/bsp-alias.m4 (modified) * aclocal/check-bsps.m4 (modified) Added c3xsim as alias of c4xsim. Mon, 17 Jul 2000 01:54:14 GMT Joel Sherrill [237c259] * aclocal/rtems-test-no-pause.m4 (modified) Changed default value to "pause". Thu, 13 Jul 2000 15:05:38 GMT Joel Sherrill [b8a30d07] * Makefile.am (modified) * aclocal/check-itron.m4 (modified) * aclocal/check-multiprocessing.m4 (modified) * aclocal/check-posix.m4 (modified) * aclocal/rtems-debug.m4 (modified) * aclocal/rtems-test-no-pause.m4 (added) * c/src/exec/configure.in (modified) * c/src/exec/itron/configure.in (modified) * c/src/exec/posix/configure.in (modified) * c/src/exec/score/cpu/unix/configure.in (modified) * c/src/lib/configure.in (modified) * c/src/lib/libbsp/a29k/portsw/configure.in (modified) * c/src/lib/libbsp/configure.in (modified) * c/src/lib/libbsp/h8300/h8sim/configure.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/configure.in (modified) * c/src/lib/libbsp/i960/cvme961/configure.in (modified) * c/src/lib/libbsp/i960/i960sim/configure.in (modified) * c/src/lib/libbsp/i960/rxgen960/configure.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/configure.in (modified) * c/src/lib/libbsp/powerpc/dmv177/configure.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/configure.in (modified) * c/src/lib/libbsp/powerpc/helas403/configure.in (modified) * c/src/lib/libbsp/powerpc/mbx8xx/configure.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/configure.in (modified) * c/src/lib/libbsp/powerpc/papyrus/configure.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/configure.in (modified) * c/src/lib/libbsp/powerpc/psim/configure.in (modified) * c/src/lib/libbsp/unix/posix/configure.in (modified) * c/src/libmisc/configure.in (modified) * c/src/tests/configure.in (modified) * c/src/tests/itrontests/configure.in (modified) * c/src/tests/itrontests/itrontests.am (modified) * c/src/tests/libtests/configure.in (modified) * c/src/tests/libtests/libtests.am (modified) * c/src/tests/mptests/configure.in (modified) * c/src/tests/mptests/mp01/node1/Makefile.am (modified) * c/src/tests/mptests/mp01/node2/Makefile.am (modified) * c/src/tests/mptests/mp02/node1/Makefile.am (modified) * c/src/tests/mptests/mp02/node2/Makefile.am (modified) * c/src/tests/mptests/mp03/node1/Makefile.am (modified) * c/src/tests/mptests/mp03/node2/Makefile.am (modified) * c/src/tests/mptests/mp04/node1/Makefile.am (modified) * c/src/tests/mptests/mp04/node2/Makefile.am (modified) * c/src/tests/mptests/mp05/node1/Makefile.am (modified) * c/src/tests/mptests/mp05/node2/Makefile.am (modified) * c/src/tests/mptests/mp06/node1/Makefile.am (modified) * c/src/tests/mptests/mp06/node2/Makefile.am (modified) * c/src/tests/mptests/mp07/node1/Makefile.am (modified) * c/src/tests/mptests/mp07/node2/Makefile.am (modified) * c/src/tests/mptests/mp08/node1/Makefile.am (modified) * c/src/tests/mptests/mp08/node2/Makefile.am (modified) * c/src/tests/mptests/mp09/node1/Makefile.am (modified) * c/src/tests/mptests/mp09/node2/Makefile.am (modified) * c/src/tests/mptests/mp10/node1/Makefile.am (modified) * c/src/tests/mptests/mp10/node2/Makefile.am (modified) * c/src/tests/mptests/mp11/node1/Makefile.am (modified) * c/src/tests/mptests/mp11/node2/Makefile.am (modified) * c/src/tests/mptests/mp12/node1/Makefile.am (modified) * c/src/tests/mptests/mp12/node2/Makefile.am (modified) * c/src/tests/mptests/mp13/node1/Makefile.am (modified) * c/src/tests/mptests/mp13/node2/Makefile.am (modified) * c/src/tests/mptests/mp14/node1/Makefile.am (modified) * c/src/tests/mptests/mp14/node2/Makefile.am (modified) * c/src/tests/mptests/mptests.am (modified) * c/src/tests/psxtests/configure.in (modified) * c/src/tests/psxtests/psxtests.am (modified) * c/src/tests/samples/base_mp/node1/Makefile.am (modified) * c/src/tests/samples/base_mp/node2/Makefile.am (modified) * c/src/tests/samples/configure.in (modified) * c/src/tests/samples/sample.am (modified) * c/src/tests/sptests/configure.in (modified) * c/src/tests/sptests/sptests.am (modified) * c/src/tests/support/configure.in (modified) * c/src/tests/tmitrontests/configure.in (modified) * c/src/tests/tmitrontests/tmitrontests.am (modified) * c/src/tests/tmtests/configure.in (modified) * c/src/tests/tmtests/tmtests.am (modified) * make/custom/Cygwin-posix.cfg (modified) * make/custom/FreeBSD-posix.cfg (modified) * make/custom/HPUX9-posix.cfg (modified) * make/custom/Linux-posix.cfg (modified) * make/custom/Solaris-posix.cfg (modified) * make/custom/bare.cfg (modified) * make/custom/cvme961.cfg (modified) * make/custom/dmv152.cfg (modified) * make/custom/dmv177.cfg (modified) * make/custom/efi332.cfg (modified) * make/custom/efi68k.cfg (modified) * make/custom/erc32.cfg (modified) * make/custom/eth_comm.cfg (modified) * make/custom/gen68302.cfg (modified) * make/custom/gen68340.cfg (modified) * make/custom/gen68360.cfg (modified) * make/custom/gensh1.cfg (modified) * make/custom/gensh2.cfg (modified) * make/custom/h8sim.cfg (modified) * make/custom/helas403.cfg (modified) * make/custom/i386ex.cfg (modified) * make/custom/i960sim.cfg (modified) * make/custom/idp.cfg (modified) * make/custom/mbx860_005b.cfg (modified) * make/custom/mbx8xx.cfg (modified) * make/custom/mcp750.cfg (modified) * make/custom/mvme136.cfg (modified) * make/custom/mvme147.cfg (modified) * make/custom/mvme162.cfg (modified) * make/custom/mvme167.cfg (modified) * make/custom/mvme2307.cfg (modified) * make/custom/ods68302.cfg (modified) * make/custom/p4000.cfg (modified) * make/custom/p4600.cfg (modified) * make/custom/p4650.cfg (modified) * make/custom/papyrus.cfg (modified) * make/custom/pc386.cfg (modified) * make/custom/portsw.cfg (modified) * make/custom/ppcn_60x.cfg (modified) * make/custom/psim.cfg (modified) * make/custom/rxgen960.cfg (modified) * make/custom/score603e.cfg (modified) * make/custom/simhppa.cfg (modified) * make/custom/ts_386ex.cfg (modified) * testsuites/itrontests/itrontests.am (modified) * testsuites/libtests/libtests.am (modified) * testsuites/mptests/mp01/node1/Makefile.am (modified) * testsuites/mptests/mp01/node2/Makefile.am (modified) * testsuites/mptests/mp02/node1/Makefile.am (modified) * testsuites/mptests/mp02/node2/Makefile.am (modified) * testsuites/mptests/mp03/node1/Makefile.am (modified) * testsuites/mptests/mp03/node2/Makefile.am (modified) * testsuites/mptests/mp04/node1/Makefile.am (modified) * testsuites/mptests/mp04/node2/Makefile.am (modified) * testsuites/mptests/mp05/node1/Makefile.am (modified) * testsuites/mptests/mp05/node2/Makefile.am (modified) * testsuites/mptests/mp06/node1/Makefile.am (modified) * testsuites/mptests/mp06/node2/Makefile.am (modified) * testsuites/mptests/mp07/node1/Makefile.am (modified) * testsuites/mptests/mp07/node2/Makefile.am (modified) * testsuites/mptests/mp08/node1/Makefile.am (modified) * testsuites/mptests/mp08/node2/Makefile.am (modified) * testsuites/mptests/mp09/node1/Makefile.am (modified) * testsuites/mptests/mp09/node2/Makefile.am (modified) * testsuites/mptests/mp10/node1/Makefile.am (modified) * testsuites/mptests/mp10/node2/Makefile.am (modified) * testsuites/mptests/mp11/node1/Makefile.am (modified) * testsuites/mptests/mp11/node2/Makefile.am (modified) * testsuites/mptests/mp12/node1/Makefile.am (modified) * testsuites/mptests/mp12/node2/Makefile.am (modified) * testsuites/mptests/mp13/node1/Makefile.am (modified) * testsuites/mptests/mp13/node2/Makefile.am (modified) * testsuites/mptests/mp14/node1/Makefile.am (modified) * testsuites/mptests/mp14/node2/Makefile.am (modified) * testsuites/mptests/mptests.am (modified) * testsuites/psxtests/psxtests.am (modified) * testsuites/samples/base_mp/node1/Makefile.am (modified) * testsuites/samples/base_mp/node2/Makefile.am (modified) * testsuites/samples/sample.am (modified) * testsuites/sptests/sptests.am (modified) * testsuites/tmitrontests/tmitrontests.am (modified) * testsuites/tmtests/tmtests.am (modified) Patch rtems-rc-20000713-1-cvs.diff from Ralf Corsepius
