# # ChangeLog for aclocal/enable-tests.m4 in rtems # # Generated by Trac 1.2.1.dev0 # 04/25/24 15:12:26 Wed, 20 Feb 2008 13:09:29 GMT Ralf Corsepius [72896de] * aclocal/enable-cxx.m4 (modified) * aclocal/enable-itron.m4 (modified) * aclocal/enable-multiprocessing.m4 (modified) * aclocal/enable-networking.m4 (modified) * aclocal/enable-posix.m4 (modified) * aclocal/enable-rtems-debug.m4 (modified) * aclocal/enable-rtemsbsp.m4 (modified) * aclocal/enable-tests.m4 (modified) * aclocal/multilib.m4 (modified) * testsuites/aclocal/enable-rtemsbsp.m4 (modified) s/AC_HELP/AS_HELP/. Wed, 26 Nov 2003 05:32:03 GMT Ralf Corsepius [3959276e] * ChangeLog (modified) * acinclude.m4 (modified) * aclocal/bsp-alias.m4 (modified) * aclocal/canonical-target-name.m4 (modified) * aclocal/check-bsps.m4 (modified) * aclocal/check-custom-bsp.m4 (modified) * aclocal/enable-bare.m4 (modified) * aclocal/enable-cxx.m4 (modified) * aclocal/enable-inlines.m4 (modified) * aclocal/enable-itron.m4 (modified) * aclocal/enable-multiprocessing.m4 (modified) * aclocal/enable-networking.m4 (modified) * aclocal/enable-posix.m4 (modified) * aclocal/enable-rdbg.m4 (modified) * aclocal/enable-rtems-debug.m4 (modified) * aclocal/enable-rtemsbsp.m4 (modified) * aclocal/enable-tests.m4 (modified) * aclocal/multilib.m4 (modified) * aclocal/path-ksh.m4 (modified) * aclocal/project-root.m4 (modified) * aclocal/rtems-top.m4 (modified) * aclocal/tool-paths.m4 (modified) 2003-11-26 Ralf Corsepius * ... Fri, 22 Aug 2003 04:21:16 GMT Ralf Corsepius [d2c6e4c1] * ChangeLog (modified) * aclocal/enable-rtems-debug.m4 (added) * aclocal/enable-tests.m4 (modified) 2003-08-22 Ralf Corsepius * ... Tue, 29 Oct 2002 14:37:34 GMT Ralf Corsepius [314a962] * ChangeLog (modified) * aclocal/enable-bare.m4 (modified) * aclocal/enable-cxx.m4 (modified) * aclocal/enable-inlines.m4 (modified) * aclocal/enable-itron.m4 (modified) * aclocal/enable-multiprocessing.m4 (modified) * aclocal/enable-networking.m4 (modified) * aclocal/enable-posix.m4 (modified) * aclocal/enable-rdbg.m4 (modified) * aclocal/enable-rtemsbsp.m4 (modified) * aclocal/enable-tests.m4 (modified) 2002-10-29 Ralf Corsepius * ... Thu, 13 Sep 2001 13:14:30 GMT Joel Sherrill [e712997] * ChangeLog (modified) * aclocal/enable-bare.m4 (modified) * aclocal/enable-cxx.m4 (modified) * aclocal/enable-gcc28.m4 (modified) * aclocal/enable-inlines.m4 (modified) * aclocal/enable-itron.m4 (modified) * aclocal/enable-libcdir.m4 (modified) * aclocal/enable-multiprocessing.m4 (modified) * aclocal/enable-networking.m4 (modified) * aclocal/enable-posix.m4 (modified) * aclocal/enable-rdbg.m4 (modified) * aclocal/enable-rtemsbsp.m4 (modified) * aclocal/enable-tests.m4 (modified) * aclocal/env-rtemsbsp.m4 (modified) * aclocal/multilib.m4 (modified) * aclocal/rtems-debug.m4 (modified) * aclocal/rtems-test-no-pause.m4 (modified) * aclocal/rtems-top.m4 (modified) * bootstrap (modified) * configure.in (modified) 2001-07-19 Ralf Corsepius * ... Mon, 12 Apr 1999 20:24:56 GMT Joel Sherrill [82f490f] * aclocal.m4 (modified) * aclocal/enable-tests.m4 (modified) * c/src/exec/posix/src/psignal.c (modified) * c/src/exec/posix/src/ptimer.c (modified) * configure (modified) * cpukit/posix/src/psignal.c (modified) * cpukit/posix/src/ptimer.c (modified) Patch from Ralf Corsepius to correct the ... Tue, 06 Apr 1999 20:25:40 GMT Joel Sherrill [a37be5c4] * aclocal.m4 (modified) * aclocal/enable-tests.m4 (modified) * configure (modified) Eric Norum noticed that the documentation and ... Fri, 19 Mar 1999 21:54:36 GMT Joel Sherrill [9ec96478] * aclocal.m4 (modified) * aclocal/canonical-host.m4 (added) * aclocal/check-cpu.m4 (added) * aclocal/enable-bare.m4 (added) * aclocal/enable-cxx.m4 (added) * aclocal/enable-gcc28.m4 (added) * aclocal/enable-gmake-print.m4 (added) * aclocal/enable-hwapi.m4 (added) * aclocal/enable-inlines.m4 (added) * aclocal/enable-libcdir.m4 (added) * aclocal/enable-multiprocessing.m4 (added) * aclocal/enable-networking.m4 (added) * aclocal/enable-posix.m4 (added) * aclocal/enable-rdbg.m4 (added) * aclocal/enable-tests.m4 (added) * aclocal/rtems-top.m4 (added) * aclocal/tool-paths.m4 (added) * configure (modified) Towards automake VIII patch from Ralf Corsepius
