# # ChangeLog for aclocal/enable-networking.m4 in rtems # # Generated by Trac 1.2.1.dev0 # 05/06/24 03:28:58 Thu, 13 Sep 2001 13:14:30 GMT Joel Sherrill [e712997] * ChangeLog (modified) * aclocal/enable-bare.m4 (modified) * aclocal/enable-cxx.m4 (modified) * aclocal/enable-gcc28.m4 (modified) * aclocal/enable-inlines.m4 (modified) * aclocal/enable-itron.m4 (modified) * aclocal/enable-libcdir.m4 (modified) * aclocal/enable-multiprocessing.m4 (modified) * aclocal/enable-networking.m4 (modified) * aclocal/enable-posix.m4 (modified) * aclocal/enable-rdbg.m4 (modified) * aclocal/enable-rtemsbsp.m4 (modified) * aclocal/enable-tests.m4 (modified) * aclocal/env-rtemsbsp.m4 (modified) * aclocal/multilib.m4 (modified) * aclocal/rtems-debug.m4 (modified) * aclocal/rtems-test-no-pause.m4 (modified) * aclocal/rtems-top.m4 (modified) * bootstrap (modified) * configure.in (modified) 2001-07-19 Ralf Corsepius * ... Tue, 23 Nov 1999 13:57:02 GMT Joel Sherrill [9f4868c] * Makefile.am (modified) * aclocal/enable-itron.m4 (modified) * aclocal/enable-networking.m4 (modified) * aclocal/enable-posix.m4 (modified) * c/src/exec/librpc/include/rpc/Makefile.am (modified) * c/src/libchip/network/Makefile.am (modified) * c/src/libchip/rtc/Makefile.am (modified) * c/src/libchip/serial/Makefile.am (modified) * c/src/libnetworking/include/Makefile.in (modified) * c/src/libnetworking/rtems_webserver/Makefile.in (modified) * c/src/libnetworking/wrapup/Makefile.in (modified) * c/src/librdbg/src/i386/Makefile.am (modified) * c/src/librdbg/src/i386/any/Makefile.in (modified) * c/src/librdbg/src/i386/pc386/Makefile.in (modified) * c/src/librpc/include/rpc/Makefile.am (modified) * c/src/librpc/src/Makefile.in (modified) * c/src/librtems++/src/Makefile.in (modified) * c/src/make/compilers/gcc-target-default.cfg (modified) * c/src/tests/psxtests/Makefile.am (modified) * c/src/tests/psxtests/configure.in (modified) * c/src/tests/support/stubdr/Makefile.in (modified) * c/src/wrapup/Makefile.in (modified) * cpukit/httpd/Makefile.in (modified) * cpukit/librpc/include/rpc/Makefile.am (modified) * make/compilers/gcc-target-default.cfg (modified) * make/custom/gensh1.cfg (modified) * make/custom/pc386.cfg (modified) * testsuites/psxtests/Makefile.am (modified) * tools/update/acpolish (modified) * tools/update/ampolish (modified) Miscellaneous patches from Ralf Corsepius ... Mon, 04 Oct 1999 18:20:14 GMT Joel Sherrill [b62a92c] * aclocal/check-bsps.m4 (modified) * aclocal/check-cpu.m4 (modified) * aclocal/check-multiprocessing.m4 (modified) * aclocal/check-networking.m4 (modified) * aclocal/check-posix.m4 (modified) * aclocal/check-rdbg.m4 (modified) * aclocal/enable-networking.m4 (modified) * aclocal/enable-posix.m4 (modified) * aclocal/enable-rdbg.m4 (modified) * aclocal/enable-rtemsbsp.m4 (modified) * aclocal/gcc-specs.m4 (modified) * aclocal/prog-cc.m4 (modified) * aclocal/prog-cxx.m4 (modified) * aclocal/rtems-top.m4 (modified) * c/configure.in (modified) * c/src/configure.in (modified) * c/src/exec/libcsupport/Makefile.am (modified) * c/src/lib/Makefile.am (modified) * c/src/lib/configure.in (modified) * c/src/lib/include/Makefile.am (modified) * c/src/lib/libbsp/configure.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/configure.in (modified) * c/src/lib/libbsp/i386/pc386/tools/configure.in (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/configure.in (modified) * c/src/lib/libbsp/m68k/mvme162/tools/configure.in (modified) * c/src/lib/libbsp/powerpc/psim/tools/configure.in (modified) * c/src/lib/libbsp/sparc/erc32/tools/configure.in (modified) * c/src/lib/libbsp/unix/posix/tools/configure.in (modified) * c/src/lib/libchip/configure.in (modified) * c/src/lib/libcpu/configure.in (modified) * c/src/lib/libnetworking/configure.in (modified) * c/src/lib/librdbg/configure.in (modified) * c/src/lib/librpc/Makefile.in (deleted) * c/src/lib/librpc/aclocal.m4 (deleted) * c/src/lib/librpc/configure (deleted) * c/src/lib/librpc/configure.in (deleted) * c/src/lib/librpc/rpc_callmsg.c (deleted) * c/src/lib/librpc/rpc_prot.c (deleted) * c/src/lib/librpc/svc.c (deleted) * c/src/lib/librpc/svc_auth.c (deleted) * c/src/lib/librpc/svc_udp.c (deleted) * c/src/lib/librpc/xdr.c (deleted) * c/src/lib/librpc/xdr_array.c (deleted) * c/src/lib/librpc/xdr_mem.c (deleted) * c/src/lib/start/a29k/configure.in (modified) * c/src/lib/start/i960/configure.in (modified) * c/src/lib/start/m68k/configure.in (modified) * c/src/lib/start/mips64orion/configure.in (modified) * c/src/lib/start/sh/configure.in (modified) * c/src/libchip/configure.in (modified) * c/src/libnetworking/configure.in (modified) * c/src/librdbg/src/configure.in (modified) * c/src/librpc/src/Makefile.in (modified) * c/src/librtems++/configure.in (modified) * c/src/make/configure.in (modified) * c/src/tests/support/configure.in (modified) * c/src/tests/tools/configure.in (modified) * c/src/tests/tools/generic/configure.in (modified) * cpukit/libcsupport/Makefile.am (modified) * tools/build/configure.in (modified) * tools/cpu/configure.in (modified) * tools/cpu/generic/configure.in (modified) * tools/cpu/hppa1.1/configure.in (modified) * tools/cpu/sh/configure.in (modified) * tools/cpu/unix/configure.in (modified) * tools/update/configure.in (modified) Patch from Ralf Corsepius : The patch ... Mon, 29 Mar 1999 21:08:04 GMT Joel Sherrill [7e03d10] * aclocal.m4 (modified) * aclocal/cygwin.m4 (deleted) * aclocal/enable-gmake-print.m4 (modified) * aclocal/enable-hwapi.m4 (modified) * aclocal/enable-inlines.m4 (modified) * aclocal/enable-libcdir.m4 (modified) * aclocal/enable-multiprocessing.m4 (modified) * aclocal/enable-networking.m4 (modified) * aclocal/enable-posix.m4 (modified) * aclocal/enable-rdbg.m4 (modified) * aclocal/exeext.m4 (deleted) * aclocal/i386-gas-code16.m4 (modified) * autogen (modified) * c/src/exec/score/tools/generic/Makefile.am (modified) * c/src/exec/score/tools/generic/Makefile.in (modified) * c/src/exec/score/tools/generic/configure.in (modified) * c/src/exec/score/tools/hppa1.1/configure.in (modified) * c/src/exec/score/tools/sh/configure.in (modified) * c/src/exec/score/tools/unix/configure.in (modified) * c/update-tools/cipolish (added) * c/update-tools/rtems-polish.sh (modified) * configure (modified) * make/Templates/Makefile.inc.in (modified) * tools/cpu/generic/Makefile.am (modified) * tools/cpu/generic/Makefile.in (modified) * tools/cpu/generic/configure.in (modified) * tools/cpu/hppa1.1/configure.in (modified) * tools/cpu/sh/configure.in (modified) * tools/cpu/unix/configure.in (modified) * tools/update/cipolish (added) * tools/update/rtems-polish.sh (modified) Patch from Ralf Corsepius : Yet some ... Fri, 19 Mar 1999 21:54:36 GMT Joel Sherrill [9ec96478] * aclocal.m4 (modified) * aclocal/canonical-host.m4 (added) * aclocal/check-cpu.m4 (added) * aclocal/enable-bare.m4 (added) * aclocal/enable-cxx.m4 (added) * aclocal/enable-gcc28.m4 (added) * aclocal/enable-gmake-print.m4 (added) * aclocal/enable-hwapi.m4 (added) * aclocal/enable-inlines.m4 (added) * aclocal/enable-libcdir.m4 (added) * aclocal/enable-multiprocessing.m4 (added) * aclocal/enable-networking.m4 (added) * aclocal/enable-posix.m4 (added) * aclocal/enable-rdbg.m4 (added) * aclocal/enable-tests.m4 (added) * aclocal/rtems-top.m4 (added) * aclocal/tool-paths.m4 (added) * configure (modified) Towards automake VIII patch from Ralf Corsepius
