# # ChangeLog for Makefile.maint in rtems # # Generated by Trac 1.2.1.dev0 # 05/28/24 07:35:49 Tue, 04 Sep 2007 23:48:38 GMT Joel Sherrill [e959d8d] * ChangeLog (modified) * Makefile.maint (modified) 2007-09-04 Joel Sherrill * ... Tue, 07 Aug 2007 14:33:53 GMT Joel Sherrill [ecda1e42] * ChangeLog (modified) * Makefile.maint (modified) 2007-08-07 Joel Sherrill * ... Thu, 02 Aug 2007 15:01:29 GMT Joel Sherrill [27ccd807] * ChangeLog (modified) * Makefile.maint (modified) * aclocal/enable-rdbg.m4 (deleted) * configure.ac (modified) * release_support (modified) 2007-08-02 Joel Sherrill * ... Thu, 22 Feb 2007 16:28:33 GMT Ralf Corsepius [4a2337cd] * Makefile.maint (modified) Fix stupid typo Thu, 22 Feb 2007 15:50:38 GMT Ralf Corsepius [76c6166a] * Makefile.maint (modified) use cvs -q Thu, 22 Feb 2007 15:36:36 GMT Ralf Corsepius [d3e101e] * Makefile.maint (modified) Don't redirect output of make tag Thu, 22 Feb 2007 14:48:15 GMT Ralf Corsepius [4380436] * Makefile.maint (modified) Sync with rtems-4-7-branch. Thu, 22 Feb 2007 10:09:00 GMT Ralf Corsepius [b481c8a] * Makefile.maint (modified) Eliminate hard-coded PATHs. Add rtems_api. Sort TOOL_VERSIONS. Thu, 22 Feb 2007 08:57:44 GMT Ralf Corsepius [e6a77a15] * Makefile.maint (modified) Rename TEST_TAG into TAG_SUFFIX. Thu, 22 Feb 2007 08:10:46 GMT Ralf Corsepius [85cf337] * Makefile.maint (modified) Move TOOL_VERSIONS into tarball. Thu, 22 Feb 2007 07:40:54 GMT Ralf Corsepius [5749232] * Makefile.maint (modified) Preps for testing. Thu, 22 Feb 2007 07:39:37 GMT Ralf Corsepius [ceb5acf] * Makefile.maint (modified) Simplify rpm -qa call Wed, 21 Feb 2007 22:57:20 GMT Joel Sherrill [f9f1d96] * ChangeLog (modified) * Makefile.maint (modified) 2007-02-21 Joel Sherrill * ... Wed, 21 Feb 2007 18:10:50 GMT Ralf Corsepius [03d1fed8] * Makefile.maint (modified) Misc. hacks Wed, 21 Feb 2007 18:09:23 GMT Ralf Corsepius [b4f45706] * Makefile.maint (modified) Misc. hacks Wed, 21 Feb 2007 17:41:45 GMT Ralf Corsepius [2daec3b2] * Makefile.maint (modified) Misc. hacks Wed, 21 Feb 2007 17:40:47 GMT Ralf Corsepius [0496121] * Makefile.maint (modified) Misc. hacks Wed, 21 Feb 2007 17:35:20 GMT Ralf Corsepius [b85e49d] * Makefile.maint (modified) Misc. hacks Wed, 21 Feb 2007 17:33:02 GMT Ralf Corsepius [d36bfd19] * Makefile.maint (modified) Misc. hacks Wed, 21 Feb 2007 17:32:00 GMT Ralf Corsepius [039970a] * Makefile.maint (modified) Misc. hacks Thu, 15 Feb 2007 09:03:44 GMT Ralf Corsepius [8b75a07] * ChangeLog (modified) * Makefile.maint (modified) 2007-02-15 Ralf Corsépius * ... Sun, 28 Jan 2007 05:50:06 GMT Ralf Corsepius [859fbb49] * ChangeLog (modified) * Makefile.maint (modified) 2007-01-28 Ralf Corsépius * ... Sat, 27 Jan 2007 07:34:47 GMT Ralf Corsepius [17ab08dc] * ChangeLog (modified) * Makefile.maint (modified) 2007-01-27 Ralf Corsépius * ... Sat, 27 Jan 2007 04:42:56 GMT Ralf Corsepius [952a969] * Makefile.maint (modified) Add CVS_RUN. Fri, 26 Jan 2007 12:11:11 GMT Ralf Corsepius [294030f5] * Makefile.maint (modified) Misc. updates. Fri, 26 Jan 2007 08:00:58 GMT Ralf Corsepius [e6a00cae] * Makefile.maint (added) New.
