# # ChangeLog for LICENSE.NET in rtems # # Generated by Trac 1.2.1.dev0 # 06/03/24 12:56:46 Thu, 03 May 2012 17:24:46 GMT Joel Sherrill [65c6425] * INSTALL (modified) * LICENSE (modified) * LICENSE.NET (modified) * LICENSE.RPCXDR (modified) * LICENSE.WEBSERVER (modified) * SUPPORT (modified) * VERSION (modified) * ampolish3 (modified) * bootstrap (modified) * c/ACKNOWLEDGEMENTS (modified) * c/TOOL_TARGETS (modified) * c/src/aclocal/bsp-alias.m4 (modified) * c/src/aclocal/bsp-bootcard-options.m4 (modified) * c/src/aclocal/bsp-bspcleanup-options.m4 (modified) * c/src/aclocal/bspopts.m4 (modified) * c/src/aclocal/canonicalize-tools.m4 (modified) * c/src/aclocal/check-cxx.m4 (modified) * c/src/aclocal/check-networking.m4 (modified) * c/src/aclocal/check-posix.m4 (modified) * c/src/aclocal/check-smp.m4 (modified) * c/src/aclocal/gcc-pipe.m4 (modified) * c/src/aclocal/gcc-specs.m4 (modified) * c/src/aclocal/i386-gas-code16.m4 (modified) * c/src/aclocal/ppc.m4 (modified) * c/src/aclocal/project-root.m4 (modified) * c/src/lib/libbsp/MERGE.PROCEDURE (modified) * c/src/lib/libbsp/arm/gp32/include/bsp.h (modified) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/rumble.c (modified) * c/src/lib/libbsp/i386/pc386/3c509/elink.c (modified) * c/src/lib/libbsp/i386/pc386/3c509/elink.h (modified) * c/src/lib/libbsp/i386/pc386/HOWTO (modified) * c/src/lib/libbsp/i386/pc386/console/outch.c (modified) * c/src/lib/libbsp/m68k/mcf5206elite/README (modified) * c/src/lib/libbsp/m68k/mcf5206elite/startup/gdbinit (modified) * c/src/lib/libbsp/m68k/mcf5206elite/tools/runtest (modified) * c/src/lib/libbsp/m68k/mcf52235/make/custom/mcf52235.cfg (modified) * c/src/lib/libbsp/m68k/mcf5225x/make/custom/mcf5225x.cfg (modified) * c/src/lib/libbsp/m68k/mcf5235/make/custom/mcf5235.cfg (modified) * c/src/lib/libbsp/m68k/mrm332/console/sci.c (modified) * c/src/lib/libbsp/m68k/mrm332/console/sci.h (modified) * c/src/lib/libbsp/m68k/mrm332/misc/dotests (modified) * c/src/lib/libbsp/m68k/mrm332/misc/gdbinit68 (modified) * c/src/lib/libbsp/m68k/mvme162/include/page_table.h (modified) * c/src/lib/libbsp/m68k/ods68302/startup/debugger (modified) * c/src/lib/libbsp/m68k/ods68302/startup/rom (modified) * c/src/lib/libbsp/powerpc/mbx8xx/startup/bspstart.c.nocache (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/BOOTING (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/network/if_hdlcsubr.c (modified) * c/src/lib/libbsp/powerpc/shared/bootloader/pci.h (modified) * c/src/lib/libbsp/sh/gensh2/start/start.ram (modified) * c/src/lib/libbsp/sh/gensh2/start/start.rom (modified) * c/src/lib/libbsp/sparc64/shared/helenos/README (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/fpsp.defs (modified) * c/src/lib/libcpu/mips/mongoosev/duart/README.mguart (modified) * c/src/lib/libcpu/powerpc/new-exceptions/bspsupport/README (modified) * c/src/lib/libcpu/powerpc/ppc403/console/console.c.polled (modified) * c/src/libchip/display/disp_hcms29xx.c (modified) * c/src/libchip/network/README.tulipclone (modified) * c/src/libchip/network/cs8900.c.bsp (modified) * c/src/libchip/network/cs8900.h.bsp (modified) * c/src/libchip/network/if_dc.c (modified) * c/src/make/bsp.mak (modified) * contrib/mingw/rtems.ini (modified) * cpukit/doxy-filter (modified) * cpukit/libcsupport/include/sys/filio.h (modified) * cpukit/libcsupport/include/sys/ttycom.h (modified) * cpukit/libcsupport/src/CASES (modified) * cpukit/libcsupport/src/TODO (modified) * cpukit/libmisc/serdbg/serdbgio.c (modified) * cpukit/libmisc/serdbg/termios_printk.c (modified) * cpukit/libnetworking/arpa/inet.h (modified) * cpukit/libnetworking/arpa/nameser_compat.h (modified) * cpukit/libnetworking/libc/ether_addr.c (modified) * cpukit/libnetworking/machine/in_cksum.h (modified) * cpukit/libnetworking/net/route.c (modified) * cpukit/libnetworking/netinet/igmp.h (modified) * cpukit/libnetworking/netinet/in_proto.c (modified) * cpukit/libnetworking/netinet/in_var.h (modified) * cpukit/libnetworking/netinet/ip_fw.c (modified) * cpukit/libnetworking/netinet/ip_fw.h (modified) * cpukit/libnetworking/netinet/tcp_input.c (modified) * cpukit/libnetworking/netinet/tcp_output.c (modified) * cpukit/libnetworking/netinet/tcp_timer.c (modified) * cpukit/libnetworking/netinet/tcp_var.h (modified) * cpukit/libnetworking/nfs/bootp_subr.c (modified) * cpukit/libnetworking/resolv.h (modified) * cpukit/libnetworking/rtems/mkrootfs.h (modified) * cpukit/libnetworking/rtems/rtems_mii_ioctl.c (modified) * cpukit/libnetworking/rtems/rtems_mii_ioctl_kern.c (modified) * cpukit/libnetworking/sys/socketvar.h (modified) * cpukit/libnetworking/vm/vm.h (modified) * cpukit/librpc/include/rpc/rpc_com.h (modified) * cpukit/librpc/include/rpc/rpc_msg.h (modified) * cpukit/pppd/Makefile.am (modified) * cpukit/pppd/README (modified) * cpukit/pppd/STATUS (modified) * cpukit/pppd/example/README (modified) * cpukit/pppd/pppd.8 (modified) * cpukit/score/cpu/m68k/rtems/m68k/m68360.h (modified) * cpukit/score/src/Unlimited.txt (modified) * doc/TODO (modified) * doc/new_chapters/STATUS (modified) * doc/new_chapters/gen_section (modified) * doc/posix1003.1/summarize (modified) * doc/posix_users/gen_size_report (modified) * doc/setup.def (modified) * doc/tools/word-replace2 (modified) * make/Templates/Makefile.dir (modified) * make/Templates/Makefile.leaf (modified) * make/Templates/Makefile.lib (modified) * release_support (modified) * tools/build/Makefile.am (modified) * tools/build/cvsignore-add.sh (modified) * tools/build/doxy-filter (modified) * tools/build/multigen (modified) * tools/build/search-id.sh (deleted) * tools/cpu/sh/COPYING (modified) Remove CVS Id Strings (manual edits after script) These ... Fri, 01 Sep 2000 07:19:16 GMT Joel Sherrill [f9e72d3] * ChangeLog (modified) * LICENSE.NET (modified) * README (modified) * README.configure (modified) 2000-08-31 Ralf Corsepius * ... Wed, 30 Aug 2000 16:54:53 GMT Joel Sherrill [08f06ad1] * ChangeLog (modified) * LICENSE.NET (added) * LICENSE.RPCXDR (added) * LICENSE.WEBSERVER (added) 2000-08-30 Joel Sherrill * ...
