@fb339a8
07/29/98 00:04:02 |
Joel Sherrill |
Deleted probe routine as device specific.
Renamed port table.
4.104.114.84.95
@866c9dd5
07/29/98 00:03:12 |
Joel Sherrill |
Added function table.
4.104.114.84.95
@cb5e6f68
07/29/98 00:03:07 |
Joel Sherrill |
Renamed control register constants.
Set time->ticks to 0.
Added …
4.104.114.84.95
@1177cda
07/29/98 00:02:11 |
Joel Sherrill |
New files for Harris Semiconductor ICM7170.
4.104.114.84.95
@8d6e7120
07/29/98 00:01:56 |
Joel Sherrill |
New files.
4.104.114.84.95
@677943a
07/29/98 00:01:44 |
Joel Sherrill |
Added new files.
4.104.114.84.95
@9968efb
07/28/98 23:16:34 |
Joel Sherrill |
First cut at configuration table for libchip RTC. At this point, we …
4.104.114.84.95
@a1f514f
07/28/98 23:03:40 |
Joel Sherrill |
First cut implementation of real-time clock support in libchip. This …
4.104.114.84.95
@009c235
07/28/98 21:18:17 |
Joel Sherrill |
Corrected spacing.
4.104.114.84.95
@07e91808
07/28/98 21:18:11 |
Joel Sherrill |
Added rtc directory.
4.104.114.84.95
@30cde042
07/28/98 16:50:14 |
Joel Sherrill |
Added missing parts of patch from Ralf Corsepius <corsepiu@…>.
4.104.114.84.95
@bd7c547
07/28/98 16:49:36 |
Joel Sherrill |
Closed window thanks to patch from Eric Norum.
4.104.114.84.95
@5752f930
07/25/98 17:34:41 |
Joel Sherrill |
New file -- copied from dmv177 but same as ppcn_60x.
4.104.114.84.95
@749c54e
07/25/98 17:22:58 |
Joel Sherrill |
Added comments and corrected spacing.
4.104.114.84.95
@cae0504
07/25/98 17:19:45 |
Joel Sherrill |
Corrected spacing and added headers.
4.104.114.84.95
@8739322
07/25/98 17:17:46 |
Joel Sherrill |
Added ns16550_set_attributes.
4.104.114.84.95
@b636d56
07/25/98 17:17:36 |
Joel Sherrill |
Corrected spacing and added a comment.
4.104.114.84.95
@ccfa60b
07/25/98 17:17:05 |
Joel Sherrill |
Updated to reflect set attributes.
4.104.114.84.95
@70a9451
07/25/98 16:53:21 |
Joel Sherrill |
Rewrote NS16550 TX interrupt processing to use termios for the buffer …
4.104.114.84.95
@adedb057
07/25/98 16:52:17 |
Joel Sherrill |
Removed TX ring buffer.
4.104.114.84.95
@cb27f05
07/25/98 16:52:00 |
Joel Sherrill |
Changed variable to hold received data to unsigned.
4.104.114.84.95
@db29826d
07/25/98 16:20:57 |
Joel Sherrill |
Switching console interrupts on and off as we test.
4.104.114.84.95
@dfb16ce
07/25/98 16:20:33 |
Joel Sherrill |
Added constants for z85c30_enable_interrupts.
4.104.114.84.95
@04c5ac7
07/25/98 16:20:14 |
Joel Sherrill |
Removed z85c30_flush().
Reworked transmit interrupt processing to …
4.104.114.84.95
@c1da250
07/25/98 16:18:46 |
Joel Sherrill |
Changed comment on TxBuffer?.
4.104.114.84.95
@b070d69a
07/25/98 16:18:27 |
Joel Sherrill |
Removed mc68681_flush and corrected spacing.
4.104.114.84.95
@f600da3f
07/25/98 16:17:33 |
Joel Sherrill |
Added information on Chris Johns' suggestion to use pointers …
4.104.114.84.95
@3d2c161
07/25/98 16:16:10 |
Joel Sherrill |
Removed "if 0" used to switch between serial ports.
4.104.114.84.95
@da8ac60a
07/25/98 16:02:21 |
Joel Sherrill |
New file.
4.104.114.84.95
@c68b990
07/25/98 14:51:57 |
Joel Sherrill |
Changed to utilize return status from …
4.104.114.84.95
@a3c9f0d
07/25/98 14:50:07 |
Joel Sherrill |
Moved console.c to libbsp/shared.
4.104.114.84.95
@f246caf
07/25/98 14:13:34 |
Joel Sherrill |
Interrupts were incorrectly managed with a disable/disable pair rather …
4.104.114.84.95
@bf21172
07/24/98 18:30:50 |
Joel Sherrill |
changed version to 980724
4.104.114.84.95
@03c0961
07/24/98 16:18:39 |
Joel Sherrill |
Patch from David Fiddes <D.J.Fiddes@…>:
Here's a small …
4.104.114.84.95
@dbab462
07/24/98 16:09:51 |
Joel Sherrill |
Patch from Eric Valette <valette@…> and Emmanuel Raguet …
4.104.114.84.95
@1501809
07/23/98 22:13:46 |
Joel Sherrill |
changed version to 980723
4.104.114.84.95
@dbaf51a
07/23/98 22:13:10 |
Joel Sherrill |
Patch from Emmanuel Raguet <raguet@…>:
Here is a patch …
4.104.114.84.95
@67a2288
07/23/98 22:02:34 |
Joel Sherrill |
Patch from Eric VALETTE <valette@…>:
Here is a …
4.104.114.84.95
@73452854
07/23/98 20:04:55 |
Joel Sherrill |
Patch from Ralf Corsepius <corsepiu@…>:
Here is a pure …
4.104.114.84.95
@613ab62
07/23/98 19:39:25 |
Joel Sherrill |
Patch from Dario Alcocer <alcocer@…> and Ralf Corsepius …
4.104.114.84.95
@c91e032
07/23/98 19:32:01 |
Joel Sherrill |
Removed consolex from build list. This file should be obsoleted by …
4.104.114.84.95
@92fc5a5d
07/21/98 13:59:12 |
Joel Sherrill |
Fix from Chris Johns <ccj@…>. Comments:
Mask interrupts …
4.104.114.84.95
@bced36d
07/18/98 18:44:12 |
Joel Sherrill |
Changed so we could test interrupts on port 3.
4.104.114.84.95
@c14a619
07/18/98 18:35:34 |
Joel Sherrill |
Removed use of data port for z8530.
Move some code around.
4.104.114.84.95
@3652929e
07/18/98 18:35:07 |
Joel Sherrill |
Tested all four ports. MC68681 …
4.104.114.84.95
@91f16d5
07/18/98 18:34:04 |
Joel Sherrill |
New file
4.104.114.84.95
@a4d34dd2
07/18/98 17:47:50 |
Joel Sherrill |
Added z85c30 specific probe routine to decide what the clock rate was. …
4.104.114.84.95
@f8a5d54e
07/18/98 17:46:33 |
Joel Sherrill |
Addresses for SCC were wrong. A and B ports were swapped.
Deleted …
4.104.114.84.95
@c53e1df4
07/18/98 16:56:16 |
Joel Sherrill |
Swapped RX and TX since doing this makes the lights blink on the …
4.104.114.84.95
@fe05ec5e
07/18/98 16:11:13 |
Joel Sherrill |
Added RS-422 converter information and cable building information.
4.104.114.84.95
@cc3d33ac
07/18/98 15:34:03 |
Joel Sherrill |
Added information on the MC68681.
4.104.114.84.95
@f7d6e57
07/18/98 15:24:14 |
Joel Sherrill |
Added background and setup to add section on RS-422.
4.104.114.84.95
@f77670be
07/18/98 15:23:56 |
Joel Sherrill |
Reworked to removed dependency on DY-4 CSS ROM monitor interface.
4.104.114.84.95
@e286479
07/18/98 15:23:24 |
Joel Sherrill |
Removed css_iface.
4.104.114.84.95
@6d4062f
07/18/98 15:22:54 |
Joel Sherrill |
Removed. We are no longer dependent on DY-4 CSS interface code.
4.104.114.84.95
@cce1200e
07/18/98 15:19:28 |
Joel Sherrill |
New file.
4.104.114.84.95
@4555bc1e
07/17/98 22:34:54 |
Joel Sherrill |
Initialized tty->refcount to 0. When (for whatever reason) malloc() …
4.104.114.84.95
@4fb08fd
07/17/98 22:30:38 |
Joel Sherrill |
Regenerated.
4.104.114.84.95
@f95d2b53
07/17/98 15:49:12 |
Joel Sherrill |
Patch from Ralf Corsepius <corsepiu@…>. Comments:
4.104.114.84.95
@8123c635
07/17/98 15:43:42 |
Joel Sherrill |
Added scitab directory.
4.104.114.84.95
@a56e475f
07/17/98 15:42:39 |
Joel Sherrill |
Turned stack checker on.
4.104.114.84.95
@bdba552f
07/17/98 15:19:04 |
Joel Sherrill |
Patch fromalf Corsepius <corsepiu@…>:
4.104.114.84.95
@9305e52
07/17/98 15:18:08 |
Joel Sherrill |
Changes to …
4.104.114.84.95
@fa21a843
07/17/98 15:17:29 |
Joel Sherrill |
New files from Ralf Corsepius <corsepiu@…>. His …
4.104.114.84.95
@6e65840
07/17/98 13:05:03 |
Joel Sherrill |
Patch from Dario Alcocer <alcocer@…>. His comments:
4.104.114.84.95
@16d0e63
07/16/98 00:16:22 |
Joel Sherrill |
Corrected header files.
4.104.114.84.95
@a6f441b
07/16/98 00:16:11 |
Joel Sherrill |
Minor corrections for typos to get it to compile.
4.104.114.84.95
@dd5d2f04
07/16/98 00:03:01 |
Joel Sherrill |
Split default baud rate table into its own file. This shrinks the …
4.104.114.84.95
@4a11d8c
07/15/98 23:58:08 |
Joel Sherrill |
Fixed typo in which last port did not get switched to default
register …
4.104.114.84.95
@849dc107
07/15/98 23:57:41 |
Joel Sherrill |
Fixed typos.
4.104.114.84.95
@670d037
07/15/98 23:55:04 |
Joel Sherrill |
Switched to usign the default z8530 and mc68681 register access routines.
4.104.114.84.95
@8414c033
07/15/98 23:54:24 |
Joel Sherrill |
Added default z85c30 register access routines.
4.104.114.84.95
@cce9322
07/15/98 23:54:08 |
Joel Sherrill |
Added default mc68681 register access routines.
4.104.114.84.95
@991a1ab4
07/15/98 23:21:55 |
Joel Sherrill |
Added check for proper deviceType to interrupt processing code.
4.104.114.84.95
@efaf85fa
07/15/98 23:21:30 |
Joel Sherrill |
Added interrupt mask and interrupt status register bit constants.
4.104.114.84.95
@49370cd
07/15/98 23:20:50 |
Joel Sherrill |
4.104.114.84.95
@198d851
07/15/98 23:20:33 |
Joel Sherrill |
Switched from driver's own buffering to using termios. This …
4.104.114.84.95
@27a66bd
07/15/98 23:15:49 |
Joel Sherrill |
Added information on the deviceType field.
4.104.114.84.95
@66f95fc
07/15/98 23:15:32 |
Joel Sherrill |
4.104.114.84.95
@8a2e9c41
07/15/98 21:43:28 |
Joel Sherrill |
Added SCV64_Get_Interrupt_Enable().
Added proper headers to routines.
4.104.114.84.95
@d0cff6dc
07/15/98 21:43:00 |
Joel Sherrill |
4.104.114.84.95
@38e717f
07/15/98 21:42:26 |
Joel Sherrill |
Added chip type identifier field. This was necessary because a single …
4.104.114.84.95
@c0573d7
07/15/98 21:40:42 |
Joel Sherrill |
Added comment to remove use of TxBuffer? ring buffer in all libchip …
4.104.114.84.95
@0f61336
07/15/98 19:28:29 |
Joel Sherrill |
Added comments.
4.104.114.84.95
@a69f0ad9
07/15/98 19:20:20 |
Joel Sherrill |
Added comments.
4.104.114.84.95
@100a4e5
07/15/98 19:19:14 |
Joel Sherrill |
Masked out interrupts not being used prior to processing the status …
4.104.114.84.95
@6c45da17
07/15/98 19:12:11 |
Joel Sherrill |
Added routine to return interrupt mask. Added comments.
4.104.114.84.95
@01e54b8
07/15/98 14:06:37 |
Joel Sherrill |
Added scv64 subdirectory.
4.104.114.84.95
@e49ef37c
07/15/98 14:06:08 |
Joel Sherrill |
Switched to SCV64.
4.104.114.84.95
@8f563b9b
07/15/98 14:05:51 |
Joel Sherrill |
Added CSCV64 functions and addresses.
4.104.114.84.95
@30a3f76
07/15/98 14:04:31 |
Joel Sherrill |
Switched from polling to interrupts and in the process added a …
4.104.114.84.95
@437b5a7d
07/15/98 14:00:23 |
Joel Sherrill |
4.104.114.84.95
@090a3511
07/15/98 14:00:09 |
Joel Sherrill |
New files.
4.104.114.84.95
@25e3f9a
07/15/98 13:59:36 |
Joel Sherrill |
Switched CONSOLE_USE_INTERRUPTS to "1" so console would use …
4.104.114.84.95
@be8cbbf
07/15/98 13:58:23 |
Joel Sherrill |
Switched deviceOutputUsesInterrupts to TRUE so output would be …
4.104.114.84.95
@e283140c
07/15/98 13:53:58 |
Joel Sherrill |
Switched to "deviceOutput = TRUE" which made device output use interrupts.
4.104.114.84.95
@5b8c1b7
07/11/98 14:23:53 |
Joel Sherrill |
Yet another EXEEXT patch. This one is from Ralf Corsepius …
4.104.114.84.95
@3a447c3
07/10/98 19:05:20 |
Joel Sherrill |
changed version to 980710
4.104.114.84.95
@dbfa3148
07/10/98 15:43:18 |
Joel Sherrill |
Patch from Quality Quorum <qqi@…>. Comments:
4.104.114.84.95
@cc8a388a
07/10/98 14:13:59 |
Joel Sherrill |
4.104.114.84.95
