@f0ad529
03/07/06 20:47:53 |
Joel Sherrill |
2006-03-07 Joel Sherrill <joel@…>
PR 866/rtems
4.104.114.84.95
@a03debd5
03/07/06 14:03:01 |
Ralf Corsepius |
New.
4.104.114.84.95
@c429c016
03/07/06 13:42:57 |
Ralf Corsepius |
Use gcc_rpmvers for subpackage deps.
4.104.114.84.95
@027c603
03/07/06 09:02:11 |
Ralf Corsepius |
Use %echo instead of %%echo in %expand
4.104.114.84.95
@9087b7c
03/07/06 05:28:35 |
Ralf Corsepius |
Fix main package name. Update version.
4.104.114.84.95
@6eba5919
03/07/06 05:26:26 |
Ralf Corsepius |
Distribute local *.add files.
4.104.114.84.95
@0166739
03/07/06 05:26:08 |
Ralf Corsepius |
Distribute local *.add files. Reflect having renamed *-libc.add into …
4.104.114.84.95
@29ffb1e7
03/07/06 05:24:02 |
Ralf Corsepius |
Reflect having renamed gcc/*-libc.add into gcc/*-newlib.add
4.104.114.84.95
@d11d10fe
03/07/06 03:29:13 |
Ralf Corsepius |
Renamed into *-newlib.add
4.104.114.84.95
@2c7efaa7
03/07/06 03:26:23 |
Ralf Corsepius |
Renamed from *-libc.add to *-newlib.add
4.104.114.84.95
@ab163629
03/06/06 15:43:10 |
Ralf Corsepius |
GCC_VERS = 4.1.0
4.104.114.84.95
@5c8f5f66
03/06/06 15:36:59 |
Ralf Corsepius |
Subst gcc_rpmvers for LIB packages.
4.104.114.84.95
@c04a6103
03/06/06 05:55:02 |
Ralf Corsepius |
Remove stray blank in %expand to setup rpmvers.
4.104.114.84.95
@503be14
03/04/06 06:04:34 |
Ralf Corsepius |
Add osversion hack
4.104.114.84.95
@a3ba1e2d
03/03/06 16:58:51 |
Ralf Corsepius |
Propagate osversion.
4.104.114.84.95
@82e0551
03/03/06 16:56:57 |
Ralf Corsepius |
Add gfortran.
Add objc.
4.104.114.84.95
@6355f04
03/01/06 16:43:29 |
Ralf Corsepius |
Remove --sysroot
4.104.114.84.95
@d257306
03/01/06 16:42:51 |
Ralf Corsepius |
gcc-4.1.0 still has issues with mudflap.
4.104.114.84.95
@32ecfd6f
03/01/06 15:24:12 |
Joel Sherrill |
Formatting
4.104.114.84.95
@87f443cc
02/28/06 23:09:54 |
Ralf Corsepius |
Add --with-sysroot (Required by GCC-4.1.0)
4.104.114.84.95
@f7842ce
02/28/06 20:50:03 |
WENorum |
Just "cc" in the clobbered register list for interrupt …
4.104.114.84.95
@e25d8c9
02/27/06 18:03:23 |
Ralf Corsepius |
Revert to cd'ing into gcc-%{gcc_version} for gcc_update
4.104.114.84.95
@2f9c5897
02/25/06 04:52:44 |
Ralf Corsepius |
Fix stupid typo.
4.104.114.84.95
@740d8240
02/25/06 04:50:13 |
Ralf Corsepius |
Use gcc_rpmvers to setup Version:
4.104.114.84.95
@2aba80d3
02/25/06 03:28:52 |
Ralf Corsepius |
GPL.
4.104.114.84.95
@975e0f75
02/25/06 03:27:17 |
Ralf Corsepius |
Add my Copyright blurb.
4.104.114.84.95
@00565e4
02/25/06 03:23:34 |
Ralf Corsepius |
New.
4.104.114.84.95
@c046309
02/24/06 15:46:17 |
Ralf Corsepius |
Use %{_builddir}/%{name}-%{gcc_rpmvers}/find-* to work around rpmbuild …
4.104.114.84.95
@5e52a84
02/24/06 15:28:02 |
Ralf Corsepius |
Invoke gcc-%{gcc_version}/configure
4.104.114.84.95
@06fb9c3
02/24/06 15:27:07 |
Ralf Corsepius |
Add @PREP@, remove RTEMS version magic
4.104.114.84.95
@102c876
02/24/06 15:24:03 |
Ralf Corsepius |
Add gcc-prep.add
4.104.114.84.95
@255d476
02/24/06 15:20:39 |
Ralf Corsepius |
Remove no-define foreign from AM_INIT_AUTOMAKE.
4.104.114.84.95
@ef607c60
02/24/06 15:04:25 |
Ralf Corsepius |
New.
4.104.114.84.95
@61b0cc6
02/24/06 07:26:51 |
Ralf Corsepius |
Allow shared libgfortran
4.104.114.84.95
@7f7298c4
02/23/06 21:05:16 |
WENorum |
Changes from Daron Chabot
4.104.114.84.95
@0d0560a1
02/22/06 13:02:32 |
Ralf Corsepius |
Cosmetics.
4.104.114.84.95
@c8956fd7
02/22/06 11:54:10 |
Ralf Corsepius |
Use gcc_version instead of %version, to work around rpm screwing up on …
4.104.114.84.95
@70aecfc
02/22/06 11:52:41 |
Ralf Corsepius |
Run make install-info to get the newlib infos
4.104.114.84.95
@323f178
02/22/06 07:48:31 |
Ralf Corsepius |
Cleanup comment on vxaddr2line.
4.104.114.84.95
@7afdf54c
02/22/06 07:45:45 |
Ralf Corsepius |
Add ",g" in sed call to propagate _prefix to brp-compress.
4.104.114.84.95
@c2dade8
02/22/06 06:35:50 |
Ralf Corsepius |
Correct /-handling
4.104.114.84.95
@c18cad7
02/22/06 03:03:29 |
Ralf Corsepius |
Remove.
4.104.114.84.95
@4af30d8
02/22/06 02:59:55 |
Ralf Corsepius |
Remove
4.104.114.84.95
@52970c21
02/21/06 11:43:47 |
Ralf Corsepius |
Silence the tar calls.
4.104.114.84.95
@4077a78
02/21/06 10:27:52 |
Ralf Corsepius |
Add @tool_target@-gcc hacks.
4.104.114.84.95
@cb185ee
02/21/06 10:27:25 |
Ralf Corsepius |
Remove @tool_target@-gcc hacks.
4.104.114.84.95
@0f3d1bb
02/21/06 10:23:26 |
Ralf Corsepius |
Ignore unsupported targets.
4.104.114.84.95
@fccf862
02/21/06 10:21:29 |
Ralf Corsepius |
Delete refs to *-w32api-sys-root packages in *-gcc.spec.in
4.104.114.84.95
@ce3cc41e
02/21/06 10:14:30 |
Ralf Corsepius |
Delete refs to *-sys-root packages in *-gcc.spec.in
4.104.114.84.95
@3072c09
02/21/06 10:11:07 |
Ralf Corsepius |
Delete refs to *-newlib packages in *-gcc.spec.in
4.104.114.84.95
@c665ca3
02/21/06 08:47:54 |
Ralf Corsepius |
Rename libc to newlib.
4.104.114.84.95
@d70a677
02/21/06 08:46:16 |
Ralf Corsepius |
Rename files.libc to files.newlib.
4.104.114.84.95
@147427ca
02/21/06 08:36:05 |
Ralf Corsepius |
Re-add BINUTILS_*, GCC_*
4.104.114.84.95
@8b479480
02/21/06 08:22:53 |
Ralf Corsepius |
Add osversion
4.104.114.84.95
@a310f56
02/21/06 08:22:43 |
Ralf Corsepius |
Eliminate osversion
4.104.114.84.95
@1259c55
02/21/06 08:18:29 |
Ralf Corsepius |
Eliminate newlib_version
4.104.114.84.95
@14179bab
02/21/06 08:14:06 |
Ralf Corsepius |
Use $(MKSPEC) to generate *-w32api.spec.
4.104.114.84.95
@42b1efb8
02/21/06 08:12:54 |
Ralf Corsepius |
Use $(MKSPEC) to generate *-binutils.spec.
4.104.114.84.95
@fe977c7
02/21/06 08:12:10 |
Ralf Corsepius |
Use $(MKSPEC) to generate *-gcc.spec.
4.104.114.84.95
@773ab4f
02/21/06 08:10:46 |
Ralf Corsepius |
Use $(MKSPEC) to generate *-libs.spec.
4.104.114.84.95
@f538086
02/21/06 07:54:50 |
Ralf Corsepius |
Include ../mkspec.am
4.104.114.84.95
@026e27dc
02/21/06 07:48:59 |
Ralf Corsepius |
New.
4.104.114.84.95
@dd3a261
02/20/06 16:37:01 |
Ralf Corsepius |
Backup.
4.104.114.84.95
@f058946
02/20/06 16:27:09 |
Ralf Corsepius |
Unconditionally remove configure.info, because cygwin still ships it:(
4.104.114.84.95
@3596fee
02/20/06 14:25:14 |
Ralf Corsepius |
Require/BuildRequire?: w32api-sys-root, Remove a comment.
4.104.114.84.95
@c7373465
02/20/06 14:02:46 |
Ralf Corsepius |
Add blank line.
4.104.114.84.95
@b7cd78c1
02/20/06 14:00:55 |
Ralf Corsepius |
Backup.
4.104.114.84.95
@d31a75a
02/20/06 07:50:18 |
Ralf Corsepius |
Apply @rpmprefix@ to *.spec files.
4.104.114.84.95
@3d612dc4
02/19/06 15:17:05 |
Ralf Corsepius |
Use package version as RPMREL.
4.104.114.84.95
@ca2b4f3
02/19/06 05:07:37 |
Ralf Corsepius |
Apply target_alias to setup TARGET.
4.104.114.84.95
@392c841
02/19/06 05:06:31 |
Ralf Corsepius |
Add TARGET_SUBDIRS
4.104.114.84.95
@0ce942a
02/19/06 05:06:06 |
Ralf Corsepius |
Add AC_CANONICAL_TARGET.
Apply target magic to setup rtems.
4.104.114.84.95
@9827ed6f
02/18/06 14:47:46 |
Ralf Corsepius |
Comment out @tool_target@-gcc %package
4.104.114.84.95
@1c9d6de
02/18/06 14:45:38 |
Ralf Corsepius |
delete sysroot related lines from *gcc.spec
4.104.114.84.95
@38da76ea
02/18/06 14:42:05 |
Ralf Corsepius |
Switch off _cxx
4.104.114.84.95
@403d2176
02/18/06 11:15:13 |
Ralf Corsepius |
Add NEWLIB_VERS
4.104.114.84.95
@e3bd4a3
02/18/06 11:13:26 |
Ralf Corsepius |
Reflect newlib having been split out
4.104.114.84.95
@1b8fc3e4
02/18/06 11:11:51 |
Ralf Corsepius |
Add binutils/prep.add, binutils/build.add binutils/install.add
4.104.114.84.95
@6cc81d31
02/18/06 11:10:22 |
Ralf Corsepius |
Cosmetics.
4.104.114.84.95
@00a9702b
02/18/06 11:07:18 |
Ralf Corsepius |
Split out prep, build, install
4.104.114.84.95
@14653c86
02/18/06 11:06:56 |
Ralf Corsepius |
New.
4.104.114.84.95
@31ca289a
02/18/06 09:03:22 |
Ralf Corsepius |
Add @rpmprefix@ in comments.
4.104.114.84.95
@82880e5
02/18/06 09:00:56 |
Ralf Corsepius |
Remove hard-coded default for _cxx for mingw
4.104.114.84.95
@fd1eb5a
02/18/06 08:03:36 |
Ralf Corsepius |
Remove %prep, %build
4.104.114.84.95
@384fa937
02/18/06 08:02:54 |
Ralf Corsepius |
Reflect having split out gcc/prep.add and gcc/build.add
4.104.114.84.95
@c7cc52a
02/18/06 08:01:11 |
Ralf Corsepius |
New.
4.104.114.84.95
@9d07966e
02/18/06 06:53:57 |
Ralf Corsepius |
Misc. sed magic.
4.104.114.84.95
@89d2e86
02/18/06 05:17:08 |
Ralf Corsepius |
Sed out %package -n @rpmprefix@@tool_target@-gcc from *gcc.spec
4.104.114.84.95
@4a35072
02/17/06 20:31:11 |
Ralf Corsepius |
Add target-libc.add base-libc.add
4.104.114.84.95
@e94d6430
02/17/06 20:30:18 |
Ralf Corsepius |
Cosmetics.
4.104.114.84.95
@85829b5
02/17/06 20:24:52 |
Ralf Corsepius |
Cosmetics
4.104.114.84.95
@89864278
02/17/06 20:24:15 |
Ralf Corsepius |
Add %build_newlib guard
4.104.114.84.95
@b780f00
02/17/06 20:22:58 |
Ralf Corsepius |
New.
4.104.114.84.95
@ce1402f
02/17/06 19:43:37 |
Ralf Corsepius |
Install newlib infos only if building newlib
4.104.114.84.95
@149930b1
02/17/06 15:49:16 |
Ralf Corsepius |
Let *.spec.in depend on Makefile.am
4.104.114.84.95
@2fb29308
02/17/06 15:45:13 |
Ralf Corsepius |
Increment release numbers
4.104.114.84.95
@0d349d29
02/17/06 15:44:28 |
Ralf Corsepius |
Use %{tar} instead of plain tar
4.104.114.84.95
@0cc0a8b6
02/17/06 15:25:34 |
Ralf Corsepius |
Use @FREEBSD_VERS@ instead of hard-coded 6.0
4.104.114.84.95
@79a3e1b
02/17/06 15:22:03 |
Ralf Corsepius |
Add libs.add target-libs.add
4.104.114.84.95
@584f2214
02/17/06 15:21:46 |
Ralf Corsepius |
Add *.spec.in
4.104.114.84.95
