@e6a675e
03/02/12 13:51:10 |
Ralf Corsepius |
2011-03-02 Ralf Corsépius <ralf.corsepius@…>
4.115
@7f2036aa
03/02/12 12:01:07 |
Ralf Corsepius |
2012-03-02 Ralf Corsépius <ralf.corsepius@…>
4.115
@396b80e
03/02/12 08:31:38 |
Ralf Corsepius |
* configure.ac: …
4.115
@f7bb9f9
02/29/12 16:08:44 |
werner |
PR2028: Milkymist USB: forward MIDI messages.
Forward MIDI messages …
4.115
@19d18f23
02/23/12 18:09:55 |
Joel Sherrill |
Fix typo in comment.
4.115
@8f7f6ca
02/23/12 16:43:58 |
Jennifer Averett |
Merge remote-tracking branch 'upstream/master'
4.115
@4f1173bc
02/23/12 16:40:33 |
Jennifer Averett |
Avoid NULL dereference in printk() before libchip console initialized
4.115
@9294f8f
02/23/12 08:55:44 |
Sebastian Huber |
psxtests: Fix typo in psxstat
4.115
@8d8f363
02/21/12 15:24:37 |
Sebastian Huber |
LPC32XX: Typo
4.115
@a4097fdb
02/21/12 11:56:51 |
Sebastian Huber |
PR 2026/filesystem - Fix semaphore attributes
Semaphores of type …
4.115
@6903c7cd
02/22/12 11:20:57 |
Ralf Corsepius |
2012-02-22 Ralf Corsépius <ralf.corsepius@…>
* .gitignore: …
4.115
@692aefe
02/22/12 09:00:33 |
Ralf Corsepius |
4.115
@5693f2e
02/22/12 08:58:59 |
Ralf Corsepius |
4.115
@56f1fbe
02/22/12 08:16:07 |
Ralf Corsepius |
4.115
@99aebcb
02/22/12 08:14:37 |
Ralf Corsepius |
4.115
@39e8aa9
02/17/12 20:28:19 |
Joel Sherrill |
PR 2015 - LEON3: make SHM driver configurable using weak
PR 2015/bsps …
4.115
@77998753
02/17/12 15:54:23 |
Sebastian Huber |
Use alternative API
Replaced Allocate_majority_of_workspace() with …
4.115
@622d670
02/17/12 12:42:51 |
Sebastian Huber |
Add functions for greedy workspace allocation
Various tests must …
4.115
@d6f6dfaa
02/17/12 14:52:53 |
Ralf Corsepius |
Remove (Moved to git.rtems.org/data/git/rtems-crossrpms.git).
4.115
@f14327a2
02/15/12 08:59:55 |
Sebastian Huber |
Fixed incorrect error path
The inet_aton() function returns non-zero …
4.115
@8c85ca3
02/14/12 15:46:04 |
Sebastian Huber |
Avoid buffer overflow and misaligned memory access
4.115
@002affc
02/13/12 15:40:54 |
Sebastian Huber |
Avoid NULL pointer access
4.115
@e1ebfebf
02/11/12 20:15:06 |
Sebastian Huber |
Patches for Qemu 1.0.50
4.115
@14ee5a1e
02/11/12 20:10:12 |
Sebastian Huber |
Support for NXP LPC1700 family
4.115
@1f8771d2
02/07/12 21:11:50 |
Sebastian Huber |
Use proper ARMv7-M compiler flags.
4.115
@701f078
02/07/12 21:07:01 |
Sebastian Huber |
Support Thumb 2.
4.115
@6091f1a6
02/07/12 21:11:01 |
Sebastian Huber |
ARMv7-M NVIC and MPU API changes.
4.115
@d6f947e
02/07/12 21:09:45 |
Sebastian Huber |
ARMv7-M Systick API change
4.115
@034b041
02/07/12 21:13:04 |
Sebastian Huber |
Fixed bug intoduced due to API changes.
4.115
@3b18c26
02/11/12 19:35:53 |
Wendell P Silva |
PR 2017/bsps - Update due to API changes
4.115
@28a0887
02/10/12 09:36:26 |
Sebastian Huber |
Added support functions for greedy heap allocation
4.115
@6491f67
02/09/12 11:00:15 |
Sebastian Huber |
Moved empty test in front of busy tests
4.115
@23c6f93a
02/09/12 09:55:25 |
Sebastian Huber |
Increase stack size for symbolic link loop test
4.115
@e303adf
02/09/12 09:53:16 |
Sebastian Huber |
Check that the file offset is valid after a seek
4.115
@28860ec0
02/08/12 14:57:04 |
Sebastian Huber |
Fixed warnings and minor bugs
o Due to the usual integer propagation …
4.115
@62d8a54
02/08/12 14:54:54 |
Sebastian Huber |
POSIX conformance
For symbolic links, the length in bytes of the …
4.115
@b9d56ea7
02/08/12 14:52:38 |
Sebastian Huber |
Fixed typo (setegid.c was missing)
4.115
@105c8a50
02/08/12 14:24:05 |
Ralf Corsepius |
Remove (Obsolete).
4.115
@fdcf6c11
02/03/12 22:05:50 |
Joel Sherrill |
PR 2001/shell - medit command argument parsing correction
"medit" …
4.115
@935ae4a
02/03/12 21:49:44 |
Joel Sherrill |
Update copyright year on manuals to 2012.
4.115
@5d443559
02/02/12 22:57:42 |
Joel Sherrill |
PR 1991/cpukit - attr.c (really mode code) warning rework
This PR was …
4.115
@1e1d0189
02/02/12 21:02:56 |
Joel Sherrill |
Merge remote branch 'upstream/master'
4.115
@6d1a1d3
02/02/12 21:02:16 |
Joel Sherrill |
PR 2012 - mdump/wdump shell cmds handle length arg incorrectly; add …
4.115
@c75430c
02/02/12 20:08:08 |
Joel Sherrill |
PR 1962/bsps - MVME162 Console Corrections and Improvements
4.115
@b3decdb
02/02/12 20:08:08 |
Joel Sherrill |
4.115
@ce3caf87
02/02/12 20:07:09 |
Joel Sherrill |
4.115
@796bb3f
02/02/12 19:33:09 |
Joel Sherrill |
PR 1998/networking - Move ftpd root initialization
4.115
@0f700ffc
02/02/12 19:06:26 |
Joel Sherrill |
PR 2011/networking - GRETH: performance improvements and one bugfix
4.115
@600bd1bb
02/02/12 19:05:24 |
Joel Sherrill |
PR 2011/networking GRETH: Moved print to remove potential deadlock
4.115
@2b2e409d
02/02/12 14:46:27 |
Daniel Hellstrom |
LEON3: change d-cache snoop detect implementation
PR 2010/bsps
The …
4.115
@735b0ca
02/02/12 17:00:49 |
Joel Sherrill |
White space correction.
4.115
@54a169db
02/02/12 14:46:26 |
Daniel Hellstrom |
LEON3: CPU index intialization moved to bspstart.c
PR 2009/bsps
All …
4.115
@6d79be5
02/02/12 14:46:22 |
Daniel Hellstrom |
LEON3: fix compiler warning in SHM driver
PR 2008/bsps
4.115
@2a68f53
02/02/12 14:46:23 |
Daniel Hellstrom |
LEON3BSP MP: may wake one more CPU than expected
The SHM code always …
4.115
@1052242
02/02/12 14:45:16 |
Sebastian Huber |
Removed fpathconf file system node handler.
There existed no calling …
4.115
@184a612e
02/02/12 14:17:25 |
Joel Sherrill |
Merge remote branch 'remotes/origin/gitignore'
4.115
@72a3af3
01/23/12 14:55:42 |
Sebastian Huber |
Extended API to support iteration of const chains.
4.115
@52694844
02/01/12 21:03:18 |
Joel Sherrill |
Improve comments on console select patch.
4.115
@d1887baf
02/01/12 21:02:03 |
Joel Sherrill |
4.115
@441b90e
02/01/12 20:32:28 |
Jennifer.Averett |
Correct run-time selection of console port.
This was broken by …
4.115
@61250b4
02/01/12 16:59:44 |
Joel Sherrill |
Remove all .cvsignore files.
4.115
@34ce24e
02/01/12 16:49:55 |
Joel Sherrill |
Add minimal .gitignore files.
4.115
@41572c4
01/31/12 21:15:20 |
Joel Sherrill |
Fix spelling error and improve comment.
4.115
@77c2178
01/31/12 10:23:26 |
Sebastian Huber |
Fixed race condition during startup.
4.115
@be42aa1a
01/26/12 08:58:10 |
Sebastian Huber |
Revert "Google C++ Testing Framework 1.6.0."
This reverts commit …
4.115
@7838411
01/26/12 08:57:57 |
Sebastian Huber |
Revert "Support custom Makefiles."
4.115
@f4491f94
01/26/12 08:57:19 |
Sebastian Huber |
Revert "Disable optimization."
4.115
@a762dc2
01/23/12 10:19:22 |
Sebastian Huber |
Support for MPC5643L.
Rework of the start sequence to reduce the …
4.115
@9bf3a868
01/11/12 13:37:24 |
Sebastian Huber |
4.115
@621e1c9b
01/11/12 13:32:49 |
Sebastian Huber |
4.115
@8ae88d7
01/11/12 13:15:52 |
Sebastian Huber |
4.115
@01808064
01/11/12 13:15:25 |
Sebastian Huber |
Update due to API changes.
4.115
@6dde1121
01/20/12 01:53:09 |
Chris Johns |
Change the email address for Chris Johns.
4.115
@70fff65
12/14/11 19:23:49 |
Joel Sherrill |
2011-12-14 Joel Sherrill <joel.sherrilL@…>
* Makefile.am: …
4.115
@3b057ea
12/14/11 13:19:52 |
Sebastian Huber |
Typo.
4.115
@46231e1
12/14/11 13:18:01 |
Sebastian Huber |
2011-12-14 Sebastian Huber <sebastian.huber@…>
PR …
4.115
@9fa3cf0d
12/14/11 13:17:19 |
Sebastian Huber |
PR …
4.115
@f55595e
12/14/11 12:58:21 |
Sebastian Huber |
4.115
@3538e191
12/14/11 09:22:43 |
Sebastian Huber |
4.115
@40f8b21e
12/14/11 08:50:49 |
Sebastian Huber |
4.115
@fc8f39e
12/14/11 06:25:54 |
Ralf Corsepius |
Regenerate.
4.115
@380d93c8
12/14/11 06:25:13 |
Ralf Corsepius |
Bump GDB_RPMREL.
4.115
@56cdf03b
12/14/11 06:24:04 |
Ralf Corsepius |
Disable system-readline on EL5 with gdb >= 7.3.91.
4.115
@42703350
12/14/11 04:52:16 |
Ralf Corsepius |
readline-6.1.2-2.
4.115
@edbf1c6
12/13/11 18:09:29 |
Ralf Corsepius |
Work-around gdb-7.3.91 bug.
4.115
@d45c69a
12/13/11 18:08:46 |
Ralf Corsepius |
Regenerate.
4.115
@664d321a
12/13/11 18:08:16 |
Ralf Corsepius |
gdb-7.3.91.
4.115
@eb9f72c
12/13/11 18:07:31 |
Ralf Corsepius |
New.
4.115
@3df4d74
12/13/11 14:37:03 |
Sebastian Huber |
2011-12-13 Sebastian Huber <sebastian.huber@…>
4.115
@03cc73a
12/13/11 14:33:42 |
Sebastian Huber |
4.115
@b98d399f
12/13/11 12:56:53 |
Sebastian Huber |
4.115
@3007610
12/13/11 12:17:54 |
Ralf Corsepius |
2011-12-13 Ralf Corsépius <ralf.corsepius@…>
4.115
@b3dbca3
12/13/11 12:11:10 |
Ralf Corsepius |
* math/init.c, …
4.115
@fa011f35
12/13/11 12:00:13 |
Ralf Corsepius |
4.115
@517bf08
12/13/11 10:52:21 |
Sebastian Huber |
4.115
@9c2d082b
12/13/11 10:49:25 |
Ralf Corsepius |
4.115
@5f818ec1
12/13/11 10:49:13 |
Sebastian Huber |
4.115
@23e0b66
12/13/11 10:40:46 |
Ralf Corsepius |
4.115
@257d8fd
12/13/11 10:13:24 |
Ralf Corsepius |
4.115
@06a8139
12/13/11 10:06:53 |
Sebastian Huber |
4.115
