Notice: We have migrated to GitLab launching 2024-05-01 see here: https://gitlab.rtems.org/
source: rtems
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
Graph Diff Rev Age Author Log Message
(edit) @dc936a4   02/05/09 05:19:16 Ralf Corsepius Change SIX_MONTHS to time_t. 4.104.115
(edit) @c37c919c   02/05/09 04:54:02 Ralf Corsepius 2009-02-05 Ralf Corsépius <ralf.corsepius@…> * … 4.104.115
(edit) @cd8b8c3   02/05/09 04:53:51 Ralf Corsepius Move extern "C" brace after includes. 4.104.115
(edit) @165eb8d   02/05/09 04:46:03 Ralf Corsepius 2009-02-04 Ralf Corsépius <ralf.corsepius@…> * … 4.104.115
(edit) @02be07f   02/04/09 15:47:39 Ralf Corsepius Eliminate pppattach, pppintr (Unused). 4.104.115
(edit) @a02cdc8   02/04/09 15:47:09 Ralf Corsepius Eliminate pppintr (Unused). 4.104.115
(edit) @dba24c39   02/04/09 15:42:03 Ralf Corsepius 2009-02-04 Ralf Corsépius <ralf.corsepius@…> * Makefile.am: … 4.104.115
(edit) @99a4f71   02/04/09 13:34:45 Ralf Corsepius 2009-02-04 Ralf Corsépius <ralf.corsepius@…> * … 4.104.115
(edit) @a0fac2e   02/04/09 13:34:34 Ralf Corsepius Remove #define KERNEL. 4.104.115
(edit) @e7b2159   02/04/09 13:33:05 Ralf Corsepius 2009-02-04 Ralf Corsépius <ralf.corsepius@…> * … 4.104.115
(edit) @0eb5b37c   02/04/09 13:32:53 Ralf Corsepius Remove -D_COMPILING_BSD_KERNEL_ (Unused). 4.104.115
(edit) @245a9ce   02/04/09 13:31:15 Ralf Corsepius Remove -D_COMPILING_BSD_KERNEL_. 4.104.115
(edit) @23415d9c   02/04/09 13:17:52 Ralf Corsepius 2009-02-04 Ralf Corsépius <ralf.corsepius@…> * … 4.104.115
(edit) @ca0a7d53   02/04/09 13:17:22 Ralf Corsepius Remove -DKERNEL. 4.104.115
(edit) @404ba122   02/04/09 13:01:12 Ralf Corsepius 2009-02-04 Ralf Corsépius <ralf.corsepius@…> * … 4.104.115
(edit) @0d454b2e   02/04/09 13:00:59 Ralf Corsepius Remove #undef KERNEL. 4.104.115
(edit) @de64f79   02/04/09 12:59:26 Ralf Corsepius 2009-02-04 Ralf Corsépius <ralf.corsepius@…> * … 4.104.115
(edit) @e8a837d   02/04/09 12:54:28 Ralf Corsepius #include <sys/ucred.h>. 4.104.115
(edit) @013285a   02/04/09 12:52:37 Ralf Corsepius 2009-02-04 Ralf Corsépius <ralf.corsepius@…> * … 4.104.115
(edit) @da6950d   02/04/09 12:52:22 Ralf Corsepius Remove #define KERNEL, #define _KERNEL. 4.104.115
(edit) @d78cd7e5   02/04/09 12:50:55 Ralf Corsepius 2009-02-04 Ralf Corsépius <ralf.corsepius@…> * … 4.104.115
(edit) @24465ec   02/04/09 12:50:19 Ralf Corsepius Remove #define KERNEL. 4.104.115
(edit) @a95ca51   02/04/09 12:46:38 Ralf Corsepius 2009-02-04 Ralf Corsépius <ralf.corsepius@…> * … 4.104.115
(edit) @9515e49a   02/04/09 12:46:09 Ralf Corsepius Move extern "C" brace after includes. 4.104.115
(edit) @92f690c9   02/03/09 12:10:29 Ralf Corsepius Regenerate. 4.104.115
(edit) @5e152a01   02/03/09 12:08:56 Ralf Corsepius Bump GCC_RPMREL, NEWLIB_RPMREL to rebuild against binutils-2.19.1 4.104.115
(edit) @6748c50f   02/03/09 11:41:04 Ralf Corsepius New. 4.104.115
(edit) @2453f66   02/03/09 11:40:15 Ralf Corsepius Upgrade to binutils-2.19.1 4.104.115
(edit) @9bde07e   02/03/09 10:11:10 Ralf Corsepius 2009-02-03 Ralf Corsépius <ralf.corsepius@…> * … 4.104.115
(edit) @b1dbfd7   02/03/09 10:10:57 Ralf Corsepius Eliminate TRUE/FALSE. 4.104.115
(edit) @43892800   02/03/09 09:13:41 Ralf Corsepius 2009-02-03 Ralf Corsépius <ralf.corsepius@…> * … 4.104.115
(edit) @f8c37aea   02/03/09 08:49:36 Ralf Corsepius 2009-02-03 Ralf Corsépius <ralf.corsepius@…> * … 4.104.115
(edit) @7f7a3ca4   02/03/09 06:40:33 Ralf Corsepius Regenerate. 4.104.115
(edit) @ccccd96   02/03/09 06:39:13 Ralf Corsepius Fix typo. 4.104.115
(edit) @ccee225   02/03/09 06:36:21 Ralf Corsepius newlib-1.17.0-rtems4.10-20090203.diff 4.104.115
(edit) @bf0e9f3   02/03/09 06:34:24 Ralf Corsepius sys/param.h: Acknowledge -D_KERNEL. Do not include ucred.h. … 4.104.115
(edit) @56ea40bd   02/03/09 05:45:29 Ralf Corsepius Eliminate %{newlib_release}. 4.104.115
(edit) @0f0c13b1   02/03/09 05:43:32 Ralf Corsepius Bump GCC_RPMREL, NEWLIB_RPMREL. 4.104.115
(edit) @c83a33cc   01/30/09 22:20:39 Joel Sherrill 2009-01-30 Joel Sherrill <joel.sherrill@…> * Makefile.am, … 4.104.115
(edit) @42740bd   01/30/09 22:14:47 Joel Sherrill 2009-01-30 Joel Sherrill <joel.sherrill@…> * … 4.104.115
(edit) @edd17485   01/29/09 17:18:43 Joel Sherrill 2009-01-29 Nickolay Semyonov-Kolchin <nbkolchin@…> PR … 4.104.115
(edit) @ee0f1e6   01/29/09 16:12:44 Joel Sherrill 2009-01-29 Gene Smith <gene.smith@…> PR 1363/filesystem * … 4.104.115
(edit) @8d50380   01/29/09 14:57:22 Joel Sherrill 2009-01-29 Sebastian Huber <sebastian.huber@…> * … 4.104.115
(edit) @b897028   01/29/09 14:32:43 Joel Sherrill 2009-01-29 Eric Norum <norume@…> PR 1364/cpukit * … 4.104.115
(edit) @147257d4   01/26/09 07:36:15 Ralf Corsepius Regenerate. 4.104.115
(edit) @e709b88c   01/26/09 07:35:35 Ralf Corsepius Bump GDB_RPMREL. 4.104.115
(edit) @9815ac7a   01/26/09 07:33:36 Ralf Corsepius Abandon SuSE < 10.3 4.104.115
(edit) @ddb4aaf   01/26/09 07:29:50 Ralf Corsepius Add Cdn-X hacks. 4.104.115
(edit) @11feece9   01/26/09 07:26:01 Ralf Corsepius Regenerate. 4.104.115
(edit) @fddb62c   01/26/09 07:25:38 Ralf Corsepius Upgrade to gcc-4.3.3 4.104.115
(edit) @eb58d81   01/26/09 07:21:55 Ralf Corsepius NEWLIB_RPMREL = 22%{?dist} 4.104.115
(edit) @aaf9eb47   01/26/09 07:20:05 Ralf Corsepius GCC_VERS = 1%{?dist} 4.104.115
(edit) @09cc8fb   01/26/09 07:19:11 Ralf Corsepius GCC_VERS = 4.3.3 4.104.115
(edit) @35381baa   01/26/09 07:17:37 Ralf Corsepius BR: exact version of build host tools for Cdn-X builds. 4.104.115
(edit) @3e850ef   01/26/09 06:16:46 Ralf Corsepius Abandon gccnewlib_version. 4.104.115
(edit) @d753b14   01/26/09 06:16:01 Ralf Corsepius Abandon suse10.2 4.104.115
(edit) @4d7ce3c   01/26/09 06:13:20 Ralf Corsepius Abandon gcc < 3.2 4.104.115
(edit) @fb85f5a   01/26/09 04:55:44 Ralf Corsepius Add NEWLIB_RELEASE, %{newlib_release}. 4.104.115
(edit) @a3eb107   01/26/09 04:53:50 Ralf Corsepius Bump GCC_RPMREL. Add NEWLIB_RPMREL. 4.104.115
(edit) @b2b9ba12   01/26/09 04:50:11 Ralf Corsepius New. 4.104.115
(edit) @7311863   01/23/09 00:12:31 Chris Johns 2009-01-23 Chris Johns <chrisj@…> * libmisc/shell/shell.c: … 4.104.115
(edit) @5ad3a91e   01/22/09 14:49:07 Ralf Corsepius Remove. 4.104.115
(edit) @9e22fded   01/22/09 14:46:12 Ralf Corsepius Add mingw hacks. 4.104.115
(edit) @3b35bcc5   01/22/09 14:45:06 Ralf Corsepius Regenerate. 4.104.115
(edit) @bf0597e   01/22/09 14:44:14 Ralf Corsepius Update to gdb-*-20090122.diff 4.104.115
(edit) @17a806a3   01/22/09 14:43:15 Ralf Corsepius Bump GDB_RPMREL. 4.104.115
(edit) @b2c4395d   01/22/09 14:42:29 Ralf Corsepius Add hacks to work around Cdn-X and MinGW build issues. 4.104.115
(edit) @e574678   01/22/09 06:58:15 Ralf Corsepius Add i686-pc-mingw32-termcap-helper.spec.in. 4.104.115
(edit) @03f0885   01/21/09 20:47:58 Joel Sherrill 2009-01-21 Nickolay Kolchin <nbkolchin@…> Joel … 4.104.115
(edit) @724527d   01/21/09 19:38:34 Joel Sherrill 2009-01-21 Joel Sherrill <joel.sherrill@…> * … 4.104.115
(edit) @e026b963   01/21/09 18:17:47 Joel Sherrill 2009-01-21 Frank Ueberschar <frank.ueberschar@…> PR … 4.104.115
(edit) @4c18d8c   01/21/09 18:08:32 Joel Sherrill 2009-01-21 Sebastian Huber <sebastian.huber@…> * … 4.104.115
(edit) @f29aa73   01/21/09 16:50:25 Joel Sherrill 2009-01-21 Eric Norum <norume@…> PR 1358/bsps * … 4.104.115
(edit) @15319e15   01/21/09 06:27:57 Ralf Corsepius New. 4.104.115
(edit) @8d40ab0   01/21/09 06:26:17 Ralf Corsepius Add gmp, mpfr, *-helper. 4.104.115
(edit) @15c468f3   01/21/09 06:24:50 Ralf Corsepius Update. 4.104.115
(edit) @3c044f1   01/18/09 15:19:13 Ralf Corsepius Add freebsd7.1, freebsd6.4 4.104.115
(edit) @6beaac1   01/18/09 15:18:39 Ralf Corsepius New. 4.104.115
(edit) @bdd2eb0a   01/18/09 15:15:41 Ralf Corsepius Add more mingw32 hacks. 4.104.115
(edit) @1bde0e5   01/17/09 08:34:44 Ralf Corsepius Add freebsd7.1 4.104.115
(edit) @22fa9d61   01/16/09 18:57:53 Jennifer.Averett 2009-01-16 Jennifer Averett <jennifer.averett@…> * … 4.104.115
(edit) @0c5b59de   01/08/09 15:02:25 Joel Sherrill 2009-01-08 Joel Sherrill <joel.sherrill@…> * … 4.104.115
(edit) @d041e59   01/08/09 15:01:52 Joel Sherrill 2009-01-08 Joel Sherrill <joel.sherrill@…> * … 4.104.115
(edit) @d326411   01/06/09 22:52:12 Joel Sherrill 2009-01-06 Joel Sherrill <joel.sherrill@…> * configure.ac: … 4.104.115
(edit) @95ff1c3   01/06/09 16:26:21 Joel Sherrill 2009-01-06 Joel Sherrill <joel.sherrill@…> PR 1350/bsps * … 4.104.115
(edit) @53f3084   01/06/09 05:05:16 Ralf Corsepius 2009-01-06 Ralf Corsépius <ralf.corsepius@…> * … 4.104.115
(edit) @eaef4657   01/06/09 05:05:03 Ralf Corsepius Eliminate TRUE/FALSE. 4.104.115
(edit) @3507c6df   01/05/09 20:26:01 Joel Sherrill 2009-01-05 Joel Sherrill <joel.sherrill@…> * … 4.104.115
(edit) @449ba1b   01/05/09 20:21:18 Joel Sherrill 2009-01-05 Joel Sherrill <joel.sherrill@…> * … 4.104.115
(edit) @8b3416f   01/05/09 20:19:51 Joel Sherrill 2009-01-05 Joel Sherrill <joel.sherrill@…> * … 4.104.115
(edit) @dee98ce   01/05/09 20:16:07 Joel Sherrill 2009-01-05 Joel Sherrill <joel.sherrill@…> PR 1351/cpukit … 4.104.115
(edit) @b028e725   01/05/09 20:09:02 Joel Sherrill 2009-01-05 Joel Sherrill <joel.sherrill@…> * … 4.104.115
(edit) @e64a143   01/05/09 19:58:41 Joel Sherrill 2009-01-05 Joel Sherrill <joel.sherrill@…> * varvects.h: … 4.104.115
(edit) @0666956f   01/05/09 19:57:14 Joel Sherrill 2009-01-05 Joel Sherrill <joel.sherrill@…> * … 4.104.115
(edit) @a26d515   01/05/09 19:49:23 Joel Sherrill 2009-01-05 Joel Sherrill <joel.sherrill@…> * … 4.104.115
(edit) @cb1b4060   01/05/09 19:48:15 Joel Sherrill 2009-01-05 Joel Sherrill <joel.sherrill@…> * psim-shared: … 4.104.115
(edit) @786330c0   01/05/09 19:47:16 Joel Sherrill 2009-01-05 Joel Sherrill <joel.sherrill@…> * sp30/task1.c: … 4.104.115
(edit) @fa8ad9c   01/05/09 19:45:49 Joel Sherrill 2009-01-05 Joel Sherrill <joel.sherrill@…> * … 4.104.115
(edit) @29a8335   01/05/09 19:44:53 Joel Sherrill 2009-01-05 Joel Sherrill <joel.sherrill@…> * … 4.104.115
(edit) @9d01e1d   01/05/09 19:41:11 Joel Sherrill 2009-01-05 Joel Sherrill <joel.sherrill@…> * … 4.104.115
