@c0e01a28
02/24/15 15:27:08 |
Gedare Bloom |
posix: fix error return code for pthread_mutex_trylock
4.115
@ee870077
12/22/14 00:50:31 |
Chris Johns |
Panic on RTEMS_FAST_MUTEX network semaphore claim/release.
Fix the …
4.115
@9d090fb7
02/23/15 20:42:59 |
Gedare Bloom |
sparc64: fix copyright notices.
The sparc64 port had some incorrect …
4.115
@ced84fc0
02/23/15 17:27:05 |
Jeffrey Hill |
rpc: misaligned pointer dereference in clnt_udp.c line 363
closes #2248
4.115
@49ff36b
02/23/15 17:06:21 |
Jeffrey Hill |
rpc: misaligned address exception in get_myaddress.c
closes #2249 see …
4.115
@748fbd1
02/23/15 15:49:15 |
Sebastian Huber |
rtems-bin2c: Fix Windows build
Update #2238.
4.115
@25e14e31
02/23/15 15:46:22 |
strauman |
networking: alignment exception in ioctl(SIOCGIFCONF)
Access memory …
4.115
@1281c34
02/23/15 15:38:37 |
Gedare Bloom |
Use counted strnlen in bin2c. Closes #2238.
4.115
@83fe4468
02/23/15 14:59:49 |
Gedare Bloom |
psxtests: add string param to printf. closes #2241
4.115
@dc9aaf7
02/20/15 13:08:01 |
Martin Galvan |
ARM: Support VFP-D16
This patch allows the existing FPU code to …
4.115
@a45dfa14
02/20/15 08:42:15 |
Sebastian Huber |
IMFS: Fix copy on write for linfiles
4.115
@5eb27ce
02/20/15 04:00:47 |
Nick Withers |
Don't fail to create passwd and group files if /etc already exists
4.115
@c53705c
02/17/14 08:39:27 |
Nick Withers |
doc: Note that rename() is only partially implemented.
Replacing of …
4.115
@7f1bb40a
02/19/15 20:48:47 |
Gedare Bloom |
bfin: do not reset dispatch needed
Closes #2148
Fix suggested in …
4.115
@a3316f47
02/19/15 10:12:01 |
Sebastian Huber |
sptests: Add missing test extension
4.115
@4e3d9a4d
02/18/15 16:46:37 |
Sebastian Huber |
score: Make <rtems/score/atomic.h> available
Make …
4.115
@fd14430
02/18/15 16:06:05 |
Sebastian Huber |
IMFS: Silence warning
4.115
@7fcb71a
02/17/15 12:43:57 |
Sebastian Huber |
score: Fix _Thread_Start_multitasking() on SMP
Close #2268.
4.115
@8d6e6eeb
02/17/15 09:00:43 |
Sebastian Huber |
score: Fix FP context restore via _Thread_Handler
After a context …
4.115
@c34f94f7
02/16/15 10:55:03 |
Sebastian Huber |
score: Add _CPU_SMP_Prepare_start_multitasking()
Update #2268.
4.115
@a43a3466
02/15/15 09:38:15 |
Sebastian Huber |
IMFS: Implement variable length node names
This reduces the average …
4.115
@f785492
02/14/15 19:07:19 |
Sebastian Huber |
IMFS: Add CONFIGURE_IMFS_DISABLE_READDIR
4.115
@5640dd5
02/11/15 23:36:34 |
Joel Sherrill |
lpc1768_mbed_ahb_ram_eth-testsuite.tcfg: Add ftp01
4.115
@79b45a1
02/11/15 23:34:44 |
Joel Sherrill |
lpc1768_mbed-testsuite.tcfg: Add ftp01
4.115
@2d84c4e
02/13/15 21:07:45 |
Sebastian Huber |
score: Mention ticket in comment
4.115
@249766c5
02/13/15 20:26:17 |
Sebastian Huber |
IMFS: Rename CONFIGURE_IMFS_DISABLE_FCHMOD
Rename …
4.115
@40a18d7f
02/13/15 20:11:55 |
Sebastian Huber |
IMFS: Add CONFIGURE_IMFS_DISABLE_MKNOD_FILE
4.115
@12eee4fd
02/13/15 19:53:41 |
Sebastian Huber |
IMFS: CONFIGURE_USE_MINIIMFS_AS_BASE_FILESYSTEM
Resurrect …
4.115
@50f8bfd
02/13/15 17:52:43 |
Joel Sherrill |
sapi/Makefile.am: Do not install libsapi.a
sapi/preinstall.am: …
4.115
@353506b9
02/02/15 13:55:23 |
Sebastian Huber |
sys/event.h: Update to FreeBSD 9.3
4.115
@b57a6a7
02/11/15 19:59:29 |
Joel Sherrill |
psxhdrs: Reorganize into subdirectories per .h file and rename files
4.115
@86076f3
02/11/15 19:31:30 |
Joel Sherrill |
psxhdrs: Remove test of pthread_attr_[gs]et_cputime
These methods are …
4.115
@eedaf9b
02/11/15 20:00:35 |
Joel Sherrill |
psxhdrs: Add tests for <sys/socket.h> API compliance
4.115
@547c2282
02/11/15 20:12:48 |
Joel Sherrill |
sys/socket.h: Include <sys/types.h> for ssize_t
closes 2245
4.115
@a9df916
02/08/15 18:43:09 |
Sebastian Huber |
IMFS: Add fine grained configuration
Remove miniIMFS. Statically …
4.115
@a2f5c7e1
02/08/15 15:09:27 |
Sebastian Huber |
IMFS: Allow static initialization of FS info
4.115
@11026956
02/06/15 19:50:49 |
Sebastian Huber |
IMFS: Fix resource leak
4.115
@60cf8a5
02/06/15 15:32:39 |
Sebastian Huber |
IMFS: Add root directory to FS info
Fix memory leak in IMFS_fsunmount().
4.115
@9247d3f
02/05/15 15:58:09 |
Sebastian Huber |
IMFS: Simplify IMFS_symlink()
4.115
@e4d35d8
02/05/15 15:43:58 |
Sebastian Huber |
IMFS: Split linfile and memfile modules
Make several functions static.
4.115
@24ec25d
02/05/15 15:14:59 |
Sebastian Huber |
IMFS: Introduce IMFS_mknod_control
Drop IMFS_node_control::node_size …
4.115
@194eb007
02/12/15 19:52:16 |
Sebastian Huber |
Filesystem: Use ENOTSUP for default mount/unmount
4.115
@5efbb66
02/04/15 09:33:17 |
cederman |
grspw: Fix typos
4.115
@8244a2f
01/12/15 10:24:58 |
cederman |
doc: Document network task affinity option
4.115
@b92f737
01/12/15 10:24:16 |
cederman |
doc: Describe new default error handler for Sparc
4.115
@8d8573ac
02/04/15 09:04:05 |
cederman |
smpcapture02: Add test of functionality to add custom entries to …
4.115
@0c94a46
01/09/15 08:03:59 |
cederman |
bsp/sparc: Move BSP_ISR_handler to a separate file and rename it
This …
4.115
@1c7ee73
02/10/15 20:18:27 |
Hesham Almatary |
or1k/cpu.c: Eliminate dependency on BSP provided header
4.115
@16939b18
02/09/15 18:09:23 |
Sebastian Huber |
Filesystem: Simplify FIFO and pipe configuration
4.115
@eb77534
02/09/15 14:37:00 |
Sebastian Huber |
Filesystem: Delete unused fsmountme_h handler
4.115
@b4e52ce9
02/06/15 20:12:38 |
Sebastian Huber |
fstests/fsrename: Avoid double initialization
4.115
@cf4dfc1
02/04/15 17:20:27 |
pisa |
arm/tms570: sci context has to be writable because it holds state …
4.115
@924cbd4f
01/31/15 20:27:01 |
Sebastian Huber |
IMFS: Simplify ino generation
The type of ino_t is unsigned long, so …
4.115
@95308caf
01/31/15 20:25:57 |
Sebastian Huber |
IMFS: Use rtems_filesystem_make_dev_t_from_pointer
4.115
@4c14ace6
01/31/15 20:23:26 |
Sebastian Huber |
Add rtems_filesystem_make_dev_t_from_pointer()
4.115
@efd2965a
02/02/15 14:25:26 |
Sebastian Huber |
Filesystem: Statically initialize rtems_libio_iops
4.115
@ec0f2df
02/02/15 14:25:25 |
Sebastian Huber |
Filesystem: Use rtems_libio_iop_to_descriptor()
Drop parameter check …
4.115
@97db9e30
02/02/15 14:25:24 |
Sebastian Huber |
Filesystem: Delete rtems_libio_last_iop
4.115
@ead010c
02/02/15 14:25:23 |
Sebastian Huber |
Filesystem: Make rtems_libio_number_iops const
4.115
@d11b711
01/28/15 04:04:26 |
Nick Withers |
bsps/powerpc: Fix a clock driver
PowerPC Book E: Account for an extra …
4.115
@40d062f5
01/28/15 17:47:19 |
Sebastian Huber |
IMFS: Reduce IMFS node types
Provide only types used by IMFS_mknod().
4.115
@29fa241
01/28/15 17:25:49 |
Sebastian Huber |
IMFS: Aggregate link support in dedicated modules
4.115
@cf36b70
12/31/14 09:56:05 |
Sebastian Huber |
IMFS: Replace node union with individual struct
This reduces the …
4.115
@369328f0
01/26/15 22:22:21 |
Joel Sherrill |
user/conf.t: Fix typo
4.115
@081a697
01/23/15 15:43:59 |
Joel Sherrill |
sys/socket.h: Add include of <sys/_types.h> for ssize_t
This was …
4.115
@80bfd3a
01/23/15 15:46:48 |
Joel Sherrill |
psx07: Add missing parameter to printf() call
Close 2241.
Conflicts: …
4.115
@296846a
01/14/15 22:23:53 |
Joel Sherrill |
mcf5206elite/include/i2c.h: Fix spelling error
4.115
@b1dcae0
01/14/15 22:23:16 |
Joel Sherrill |
stm32f4/.../stm32f105rc-testsuite.tcfg: Add more tests
4.115
@3d345508
01/14/15 22:22:59 |
Joel Sherrill |
lpc24xx/.../lpc23xx_tli800-testsuite.tcfg: Add more tests
4.115
@b302880e
01/14/15 22:22:41 |
Joel Sherrill |
lpc24xx/.../lpc2362-testsuite.tcfg: Add more tests
4.115
@05eaca8
01/14/15 22:22:26 |
Joel Sherrill |
lm3s69xx/.../lm3s6965-testsuite.tcfg: Add more tests
4.115
@c1c45f5
01/14/15 22:22:09 |
Joel Sherrill |
lm3s69xx/.../lm3s3749-testsuite.tcfg: Add more tests
4.115
@e6a7896f
01/23/15 13:49:36 |
Sebastian Huber |
bsp/altera-cyclone-v: Use proper free function
4.115
@c8cd4ff
01/23/15 11:56:53 |
Sebastian Huber |
libnetworking: Fix memset() call
Close #2244.
4.115
@2a0923c5
01/23/15 11:55:02 |
Sebastian Huber |
bsps/sparc: Use calloc()
Close #2242.
4.115
@ffb1a45
01/23/15 11:49:44 |
Sebastian Huber |
psxtests/psx07: Fix printf() statement
Close #2240.
4.115
@b033e85
01/23/15 11:47:46 |
Sebastian Huber |
tools: Fix fprintf() statement
Close #2240.
4.115
@f63e9a3
01/23/15 10:31:54 |
Sebastian Huber |
bsps/powerpc: Fix switch statement in CPU ident
Close #2237.
4.115
@2f16001
01/23/15 10:24:01 |
Sebastian Huber |
libchip: Fix high capacity detection for MMC
Close #2239.
4.115
@2486c492
12/16/13 19:36:18 |
Daniel Ramirez |
grspw: descriptor tables no longer statically allocated
4.115
@50a50313
01/21/15 14:22:46 |
Sebastian Huber |
score: Delete superfluous Heap_Statistics::instance
This value …
4.115
@c625a641
12/21/14 19:12:28 |
Sebastian Huber |
Filesystem: Delete node type operation
Use the fstat handler instead.
4.115
@60d39b66
01/20/15 13:01:50 |
Sebastian Huber |
powerpc: Fix AltiVec? VSCR save/restore
4.115
@f87ede5
01/15/15 13:13:19 |
Sebastian Huber |
libnetworking: Fix close of active sockets
Send a special event to …
4.115
@51c88e8b
01/16/15 08:08:23 |
Sebastian Huber |
libnetworking: Delete dead code
The so_uid is always 0 in RTEMS.
4.115
@f2f39f3c
01/16/15 08:05:15 |
Sebastian Huber |
libnetworking: Avoid spurious event delivery
The so_pgid field …
4.115
@8a7048a
01/19/15 12:53:51 |
Marcos Diaz |
Fixed dl01 and dl02 makefiles
4.115
@ac6e8c4
01/15/15 10:30:13 |
Sebastian Huber |
libnetworking: Simplify sbwait()
4.115
@f1c044d
01/14/15 19:07:59 |
Sebastian Huber |
bsps/powerpc: Fix conditional compilation
4.115
@6042fdb7
01/14/15 06:53:00 |
Sebastian Huber |
bsp/mcf5206elite: Remove <i2c.h> inlude in <bsp.h>
This prevents a …
4.115
@77c5ddd4
01/14/15 06:34:44 |
Sebastian Huber |
smptests/smpmrsp01: Fix task delete race condition
Do not supsend …
4.115
@125e23b
01/13/15 21:40:47 |
Joel Sherrill |
tools/cpu/nios2/ptf.c: Add include to fix warnings
4.115
@85dbf52
01/13/15 21:40:31 |
Joel Sherrill |
libcpu/powerpc/mpc6xx/mmu/bat.c: Now compiles with gcc 5.x
4.115
@f2e6c3e
01/13/15 10:38:18 |
Sebastian Huber |
bsp/qoriq: Add T2080RDB and T4240RDB variants
4.115
@3e2647a7
12/23/14 13:18:06 |
Sebastian Huber |
powerpc: AltiVec? and FPU context support
Add AltiVec? and FPU support …
4.115
@c279d0a3
12/19/14 12:05:00 |
Sebastian Huber |
bsps/powerpc: Use e500 exc categories for e6500
This is not correct, …
4.115
@99a1f122
01/13/15 07:24:36 |
Sebastian Huber |
nios2: Disable assembler warning
Close #2232.
4.115
@5139d21
01/10/15 19:04:06 |
Anthony Green |
moxiesim: Add conditional logic to handle old and new gas syntax
4.115
@5759510
01/09/15 12:25:09 |
Sebastian Huber |
arm: Fix compile error for ARMv6-M multilib
ARMv6-M is not supported …
4.115
@b1268e6
01/07/15 09:37:23 |
Sebastian Huber |
powerpc: Add AltiVec? register ASM defines
4.115
