@a8595605
03/06/17 12:08:04 |
maberg |
leon, occan: Converted disable/enable to SMP locks
This commit …
5
@c609ccea
01/19/17 17:57:58 |
maberg |
leon, ahbstat: Use RTEMS 4.12 SMP interrupt lock
5
@c241236
03/15/17 13:38:21 |
javier.jalle |
leon, memscrub: add GR740 memory scrubber driver
5
@d79429f
03/15/17 14:04:33 |
javier.jalle |
leon, griommu: add GR740 IOMMU driver
The driver is limited to the …
5
@3e948cc
02/15/17 15:51:33 |
javier.jalle |
leon, ambapp: Added GRIOMMU driver to ambapp ids
5
@dfa86338
02/21/17 08:14:46 |
javier.jalle |
leon, l2cache: add GR740 L2-Cache driver
5
@d24ed54
03/15/17 13:58:04 |
javier.jalle |
leon, ambapp: Added L2CACHE driver to ambapp ids
5
@93c5e63
02/09/17 13:09:17 |
javier.jalle |
leon, grpci2dma: add GR740 PCI DMA driver
5
@31ba1f21
02/15/17 10:14:13 |
javier.jalle |
leon, grpci2: prepare for GRPCI2DMA driver
5
@8e45d55
02/15/17 10:09:23 |
javier.jalle |
leon, grpci2: Make driver SMP safe
5
@9631e5a9
03/17/17 13:44:25 |
Daniel Hellstrom |
leon, ambapp: updated AMBA PnP IDs and names database
5
@e5e44bdb
03/14/17 16:46:12 |
maberg |
leon, apbuart: Wait for shift register on close
Do not disable …
5
@6860ddb
03/14/17 16:27:57 |
maberg |
leon, apbuart: Optimized RX processing in ISR
Limit the number of …
5
@3df6710
03/13/17 09:53:47 |
maberg |
leon, apbuart: support termios task driven mode
The APBUART control …
5
@f164a294
03/10/17 14:32:38 |
maberg |
leon, apbuart: Inherit HW parameters on sysconsole
The cons layer …
5
@6e2e1299
03/10/17 13:03:11 |
maberg |
leon, apbuart: Assign proper device name
Always assign a device/file …
5
@1fefc719
03/09/17 17:51:47 |
maberg |
leon, apbuart: RX delayed interrupt
Utilize the APBUART RX delayed …
5
@fd9fb21
02/01/17 15:48:51 |
maberg |
leon, cons: drvmgr cons interface uses new TERMIOS
LEON driver …
5
@7cb93250
03/06/17 10:14:23 |
maberg |
leon, apbuart: added register defines: FIFO, delay int
The FIFOs …
5
@f600458d
02/23/17 15:33:21 |
maberg |
leon, clock: new driver manager clock driver
- Compatible with SMP
5
@78e56096
04/10/17 12:52:16 |
Daniel Hellstrom |
leon, tlib: added timer width mask information
5
@ae203e0d
04/07/17 06:31:48 |
Daniel Hellstrom |
leon, ambapp_bus: IRQ affinity for on-chip AMBAPP bus
5
@7075fb11
04/07/17 06:30:46 |
Daniel Hellstrom |
drvmgr: ability to configure IRQ affinity
5
@61788e76
01/31/17 09:13:41 |
javier.jalle |
leon, GR-CPCI-GR740: Added peripheral PCI driver
5
@6b42018e
05/02/17 06:06:12 |
Sebastian Huber |
shell: Fix format specifiers
5
@0e6542fb
04/29/17 13:20:28 |
Pavel Pisa |
bsp/tms570: include package balls and PINMMR registers mapping for …
5
@20775247
04/28/17 16:11:14 |
joel |
rtems/inttypes.h: Add PRIdrtems_vector_number. Missed in previous commit
5
@12f9c5b7
04/27/17 23:52:01 |
joel |
posix/src/mutexinit.c: Reorder to make priority a scoped variable
5
@c16d45a5
04/26/17 20:42:09 |
joel |
5
@61568e6
04/26/17 15:53:56 |
joel |
virtex5/startup/dummy_console.c: Use <rtems/bspIo.h> and …
5
@78eb6132
04/26/17 15:53:40 |
joel |
dhrystone/dhry_1.c: Move assignment to before start of timer
5
@c0ea829
04/26/17 15:50:08 |
joel |
virtex4/startup/dummy_console.c: Use <rtems/bspIo.h> and …
5
@b73b952
04/26/17 03:11:55 |
joel |
block08/bdbuf_tests.c: Add include of <rtems/inttypes.h>
5
@9e6ef36
04/26/17 01:14:28 |
joel |
rtems/inttypes.h, block08: Add and use PRIdrtems_blkdev_bnum
5
@03e4be12
04/26/17 01:02:09 |
joel |
score/cpu/or1k/rtems/score/cpu.h: Fix printf() format warning
5
@65807379
04/26/17 01:01:41 |
joel |
score/cpu/or1k/or1k-exception-frame-print.c: Fix printf() format warning
5
@ab77827
04/26/17 01:01:10 |
joel |
or1k/generic_or1k/irq/irq.c: Include <rtems/inttypes.h> and fix …
5
@c723ee4
04/25/17 18:57:21 |
joel |
libdl/rtl-obj-cache.c: Fix printf() format warning
5
@6601684f
04/25/17 18:57:03 |
joel |
posix/src/mutexinit.c: Fix used before initialized warning
5
@f6bd41e
04/25/17 18:56:31 |
joel |
moxie/rtems/score/cpu.h: Fix printf() format warning
5
@fdfbb0a8
04/25/17 18:39:50 |
joel |
epiphany/rtems/score/cpu.h: Fix printf() format warning
5
@7db09923
04/25/17 16:42:18 |
joel |
rtems/inttypes.h epiphany_sim/irq/irq.c: Add PRIdrtems_vector_number …
5
@28e5749e
04/25/17 16:41:35 |
joel |
epiphany/cpu.c: Fix typo to eliminate warning
5
@786c365
04/25/17 16:40:21 |
joel |
psxtests/Makefile.am: Disable tests which should not be built when …
5
@55b967a
04/25/17 16:22:25 |
joel |
devnullfatal01/testcase.h: Avoid redefinition of TESTS_USE_PRINTK
5
@b261dec
04/24/17 17:00:43 |
joel |
xz/xz_config.h: Address unable to inline warning
5
@485222e
04/24/17 17:00:15 |
joel |
genmcf548x/irq/irq.c: Fix incompatible pointer warning
5
@3144292b
04/24/17 16:18:47 |
joel |
libdl/rtl-obj-cache.c: Use PRIdoff_t to avoid printf() format warnings …
5
@0d01cdd6
04/24/17 16:18:03 |
joel |
sh/sh7750/sci/sh4uart.c: ix misleading indentation warning
5
@646df54c
04/24/17 16:17:41 |
joel |
powerpc/new-exceptions/bspsupport/ppc_exc_print.c: Fix printf() format …
5
@2808c26
04/24/17 16:17:12 |
joel |
powerpc/mpc5xx/console-generic/console-generic.c: Use updated struct …
5
@3ed2cf60
04/24/17 16:16:37 |
joel |
leon2/console/debugputs.c: Fix misleading indentation warning
5
@fd48b43
04/24/17 16:15:53 |
joel |
virtex5/startup/dummy_console.c: Fix no prototype warning
5
@9beada51
04/24/17 16:15:44 |
joel |
virtex4/startup/dummy_console.c: Fix no prototype warning
5
@523b4fb
04/24/17 16:15:18 |
joel |
mcf5235/console/console.c: Fix indentation and add braces
5
@a300ca1b
04/24/17 01:35:41 |
joel |
ratemonreportstatistics.c: Fix printf() warnings so clean on 32 and 64 …
5
@5e899b5
04/24/17 01:35:05 |
joel |
sparc64/shared/helenos/boot/sparc64/loader/main.c: Fix printf() format …
5
@436008c
04/24/17 01:34:42 |
joel |
sparc64/shared/clock/ckinit.c: Include <rtems/bspIo.h>
5
@38d0a94
04/24/17 01:17:54 |
joel |
shared/drvmgr/leon2_amba_bus.c: Include <rtems/bspIo.h>
5
@5796c21
04/24/17 01:05:53 |
joel |
shared/startup/panic.c: Fix printf() format warnings
5
@3f12cfe
04/24/17 01:05:41 |
joel |
shared/pci/detect_raven_bridge.c: Fix printf() format warnings
5
@31908b12
04/24/17 01:05:12 |
joel |
shared/bootloader/mm.c: Fix printf() format warnings
5
@79d45cbd
04/24/17 01:05:03 |
joel |
shared/bootloader/misc.c: Fix printf() format warnings
5
@1b24a9b
04/24/17 01:04:41 |
joel |
beatnik/pci/gt_pci_init.c: Fix printf() format warnings
5
@c44a7402
04/24/17 01:04:19 |
joel |
beatnik/startup/bspstart.c: Fix printf() format warnings
5
@93206c12
04/24/17 01:03:58 |
joel |
beatnik/marvell/discovery.c: Fix printf() format warnings
5
@bd4072b
04/24/17 01:03:32 |
joel |
gensh2/console/config.c: Fix to reflect struct termios change
5
@ecd4cd4
04/24/17 00:42:34 |
joel |
uC5282/startup/bspstart.c: Fix printf() format warnings
5
@0a84172b
04/24/17 00:42:09 |
joel |
uC5282/console/console.c: Add braces and correct indentation to fix …
5
@0c334a5
04/23/17 17:57:27 |
joel |
epiphany/cpu.c: Fix not a prototype warning
5
@edec6dd
04/23/17 17:56:12 |
joel |
libbsp/shared/pci/pci_bus_count.c: Add include <rtems/bspIo.h>
5
@12c12e0
04/23/17 17:55:25 |
joel |
gen68340/startup/dumpanic.c: Fix printf() format warnings
5
@90033411
04/23/17 17:54:23 |
joel |
fb/fb.c: Include <rtems/inttypes.h> and use PRI constant to fix warning
5
@473a3cd
04/23/17 17:53:44 |
joel |
rtems/inttypes.h: Add PRIdioctl_command_t
5
@29129822
04/23/17 17:03:22 |
joel |
amba/ahbstat.c: Correct printf() format
5
@e4633241
04/23/17 16:51:22 |
joel |
linpack/linpack-pc.c: Fix no return statement warning
5
@906e67f
04/23/17 16:50:46 |
joel |
dhrystone/dhry_1.c: Fix may be used uninitialized warning
5
@35e523d9
04/23/17 16:49:54 |
joel |
uart/apbuart.c: Correct printk() format
5
@76052e6
04/23/17 16:49:05 |
joel |
spw/grspw_router.c: Include <rtems/bspIo.h>
5
@d968826
04/23/17 16:48:32 |
joel |
irq/genirq.c: Include <rtems/bspIo.h>
5
@5c93fb3b
04/23/17 16:48:15 |
joel |
drvmgr/ambapp_bus.c: Include <rtems/bspIo.h>
5
@9ed3266
04/23/17 16:47:53 |
joel |
amba/ahbstat.c: Include <rtems/bspIo.h>
5
@438ca2f
04/22/17 19:15:22 |
joel |
rtems/inttypes.h: Add blksize_t and blkcnt_t
5
@8ed5889f
04/21/17 01:52:09 |
joel |
elnk.c: Fix printf() format warnings
5
@9f55bfb
04/21/17 01:49:07 |
joel |
elnk.c: rtems_elnk_driver_attach() prototype added
5
@814bd025
04/21/17 01:47:34 |
joel |
elnk.c: Make elnk_txDaemon() static to fix warning
5
@8477652
04/21/17 01:44:49 |
joel |
if_fxp.c: Add prototype of rtems_fxp_attach()
5
@169d6f6e
04/21/17 01:43:04 |
joel |
if_fxp.c: Remove unused variable
5
@fc91f51
04/21/17 01:40:51 |
joel |
dec21140.c: Add prototype of dec21140_txDaemon()
5
@5ce0489
04/21/17 01:38:42 |
joel |
dec21140.c: Fix printk() warnings
5
@40d0a468
04/21/17 01:36:49 |
joel |
dec21140.c: Include <libcpu/page.h> to eliminate warnings
5
@bedd927
04/21/17 01:27:32 |
joel |
dec21140.c: Fix PRIxx formatter
5
@7f95cc0
04/19/17 04:33:29 |
Chris Johns |
libdebugger: Fix the mode on task create. Clean up warnings.
Closes #2976.
5
@3d803af
04/19/17 03:01:26 |
Chris Johns |
testsuite: Fix rtems-test-check-py when a BSP has no tcfg file.
5
@4fd25c4
04/18/17 02:44:44 |
Chris Johns |
libmisc/monitor: Correctly print unlimited configuration table …
5
@d420b67
04/14/17 20:18:56 |
joel |
Merge tmacros.h PRIxxx constants from testsuites/ into …
5
@54bdf0c
04/14/17 18:55:48 |
joel |
rtems/inttypes.h: New file. Uses contents from cpukit
Provide …
5
@18f63c0
04/15/17 23:51:57 |
Chris Johns |
testsuite: Fix rtems-test-check not excluding tests.
The include file …
5
@b53ad46
04/14/17 07:12:44 |
Chris Johns |
libdebugger: Work around assert when using _Thread_Executing.
Using …
5
@50b1269
04/08/17 11:25:43 |
cpodonnell8 |
m68k/mrm332/./sci.c: Use inttypes.h constants removes 6 warnings.
5
