@a52e5d9
02/16/21 06:48:39 |
Sebastian Huber |
rtems: Remove unused ASR_Information::nest_level
Update #4244.
@9d5d73b
02/16/21 06:47:53 |
Sebastian Huber |
rtems: Remove unused _Modes_Change()
Update #4244.
@600360d
02/16/21 06:47:20 |
Sebastian Huber |
rtems: Remove unused _Modes_Mask_changed()
Update #4244.
@f9a59164
02/17/21 08:02:31 |
Sebastian Huber |
score: Add _Thread_Append_post_switch_action()
Update #4244.
@fea848b
02/17/21 07:05:37 |
Sebastian Huber |
score: Change thread action locking
Require that the corresponding …
@3e7d658
02/15/21 13:02:49 |
Sebastian Huber |
validation: Add signal manager tests
Update #4244.
@f38c0de4
02/15/21 08:14:41 |
Sebastian Huber |
validation: Add Validation1 test suite
Update #4244.
@fac1ff1
02/16/21 22:39:30 |
ryan.long |
grspw_pkt.c: Fix Dereference before null check (CID #1399846)
CID …
@1fd56a96
02/16/21 22:15:01 |
ryan.long |
grtc.c: Fix Dereference before null check (CID #1399840)
CID 1399840: …
@4edcdf43
02/16/21 21:41:25 |
ryan.long |
b1553rt.c: Fix Deference before null check (CID #1399830)
CID …
@eff3d7c
02/16/21 21:20:04 |
ryan.long |
b1553brm.c: Fix Dereference before null check (CID #1399829)
CID …
@8b1b9872
06/24/20 05:10:25 |
Sebastian Huber |
rtems: Generate <rtems/rtems/signal.h>
Change license to BSD-2-Clause …
@be603721
02/10/21 05:43:39 |
Sebastian Huber |
basedefs: Add RTEMS_ALIGNOF()
@fa25b73
02/18/21 14:35:13 |
thisisryanlong |
shell.c: Fix Dereference before null check (CID #1467420)
CID …
@407e351
06/22/20 05:09:23 |
Sebastian Huber |
rtems: Generate <rtems/rtems/sem.h>
@2768280
06/22/20 07:06:51 |
Sebastian Huber |
rtems: Generate <rtems/rtems/clock.h>
@0c4c035
06/22/20 06:39:29 |
Sebastian Huber |
rtems: Generate <rtems/rtems/barrier.h>
Change license to …
@97825da
02/15/21 12:57:37 |
Sebastian Huber |
rtems: Clarify object services documentation
Unify the wording across …
@7a1828ac
02/15/21 12:57:37 |
Sebastian Huber |
rtems: Clarify IO manager documentation
@bf3b9f45
02/10/21 05:44:12 |
Sebastian Huber |
rtems: Clarify partition manager documentation
Unify the wording …
@f9dc44a
01/27/21 05:10:16 |
Sebastian Huber |
rtems: Clarify timer manager documentation
@2730599c
01/27/21 05:10:15 |
Sebastian Huber |
rtems: Clarify event manager documentation
@026eb3db
02/15/21 22:27:14 |
Chris Johns |
powerpc/motorola_powerpc: Add cache coherent memory to the allocator
@23aad64
02/15/21 22:04:45 |
Chris Johns |
powerpc/motorola_powerpc: Enable bus PCI support in LibBSD
Updates #4245
@6e3c6e04
02/15/21 22:01:57 |
Chris Johns |
powerpc/io: Make [out/in] le and be calls conditional
- These calls …
@85df127
02/15/21 22:01:32 |
Chris Johns |
powerpc/shared: Fix warnings in i8259 PIC code.
@53abbbd0
02/13/21 01:25:07 |
Chris Johns |
@86f031d4
02/13/21 01:23:21 |
Chris Johns |
powerpc/motorola_powerpc: Fix tm27 warnings
@b5aef78
02/13/21 01:22:07 |
Chris Johns |
score: Fix warning in thread queue ops
@e1676c1
02/12/21 19:35:40 |
Chris Johns |
Update motorola_power to irq-generic interrupt management
- Add …
@f65d3384
02/12/21 18:50:36 |
ryan.long |
rtems-debugger-threads.c: Fix three Dereference before null check …
@3f4cdd8
02/12/21 18:43:43 |
ryan.long |
rtems-debugger-target.c: Fix Dereference before null check (CID …
@14f5a05
02/12/21 20:38:23 |
ryan.long |
consolesimpletask.c: Fix Two Unchecked Return Values (CID #1437625 and …
@cc273ec1
02/12/21 18:39:54 |
ryan.long |
Add macros to assert status and use it
These macros are to be used to …
@426154f
02/12/21 20:09:38 |
Chris Johns |
cputkit/rtems: Remove warning
@03dff201
02/09/21 01:48:07 |
Chris Johns |
libcsupport: Add sbrk greedy support to consume all sbrk memory
@570992dc
02/09/21 07:17:21 |
Sebastian Huber |
bsp/riscv: Re-license to BSD-2-Clause
@286ff586
12/14/20 08:41:56 |
Sebastian Huber |
basedefs: Add stringification of argument lists
Change RTEMS_STRING() …
@8b32f1d
02/06/21 17:40:12 |
niteesh.gs |
bsps/shared/ofw: Bug fixes
Fixed bugs in rtems_ofw_get_prop, …
@6da50db
02/06/21 17:40:11 |
niteesh.gs |
bsps/shared/ofw: Make rtems_ofw_get_effective_phandle iterative
@066687c4
02/06/21 17:40:10 |
niteesh.gs |
bsps/shared/ofw: Use strlcpy instead of strncpy
Changed …
@c4985b77
02/06/21 17:40:09 |
niteesh.gs |
bsps/shared/ofw: Fix coverity reported defects
Fixed use after free …
@fafc923
02/05/21 09:15:48 |
Sebastian Huber |
validation: Tweak construct error tests
Unify the state names across …
@e59efd8
02/04/21 12:35:27 |
Sebastian Huber |
validation: Tests for barrier manager
@788fa86
02/05/21 15:05:20 |
Sebastian Huber |
libtest: Add T_get_thread_timer_state()
@c9ceff9
02/03/21 16:21:23 |
Sebastian Huber |
validation: Add tests for rtems_build_name()
@7ca3b28
02/08/21 06:27:34 |
Chris Johns |
libcsupport: Have greedy allocations use consume extended memory
@822cad89
01/25/21 01:03:06 |
Chris Johns |
libcsupport: Add no_regular_file_mknod as a mount option to the mount …
@ee14fdf
10/14/20 06:14:21 |
Chris Johns |
bsp/motorola_powerp: Print RTEMS_VERSION from the bootloader
@450e238
02/06/21 20:03:21 |
Chris Johns |
powerpc/shared: ISA bus bridge fails to enable the openpic irq
- The …
@96ea09ac
02/05/21 13:35:56 |
Sebastian Huber |
score: Add barrier thread queue operations
This fixes a missing …
@9477d9ae
02/05/21 13:13:31 |
Sebastian Huber |
score: Make FIFO thread queue ops public
Update #4230.
@2b5ce23b
02/05/21 13:19:06 |
Sebastian Huber |
score: Constify Thread_queue_First_operation
Update #4230.
@aa0060f4
02/03/21 05:08:21 |
Sebastian Huber |
Unify the wording …
@98549e45
02/02/21 14:40:42 |
Sebastian Huber |
score: _Objects_Build_name() signed/unsigned char
Change …
@ca68cfc8
02/02/21 11:15:28 |
Sebastian Huber |
rtems: Avoid duplicated implemenation
Use the …
@8a95e6f8
02/02/21 13:23:52 |
Sebastian Huber |
rtems: Rework object services API
Add a "Constraints" paragraph to …
@490e6e8
01/29/21 06:07:51 |
Sebastian Huber |
score: Define _Assert() for static analysis runs
The goal is to …
@8f7baef4
02/01/21 13:18:58 |
Sebastian Huber |
libtest: Remove double definition
@56494ed8
02/01/21 11:47:38 |
Sebastian Huber |
score: Clarify thread life state documentation
@05da65c
01/29/21 07:22:31 |
Sebastian Huber |
score: Document Thread_Life_state
@51e59d5
01/12/21 13:03:41 |
Sebastian Huber |
nios2: Allow ISR nesting in dispatch variant
Rename …
@19acb3b
01/12/21 09:31:27 |
Sebastian Huber |
nios2: Optimize ISR dispatch variant
Use _Thread_Do_dispatch() in …
@9165349d
01/12/21 06:13:08 |
Sebastian Huber |
nios2: Use Per_CPU_Control::isr_dispatch_disable
@c968b27
01/08/21 08:04:22 |
Sebastian Huber |
nios2: Add TLS support
Update #4214.
@e324f82
01/05/21 13:56:25 |
Sebastian Huber |
nios2: Make _ISR_Is_in_progress() weak
This allows the BSP to …
@98c95d1
01/05/21 09:53:35 |
Sebastian Huber |
nios2: Fix ISR dispatch variants
The thread dispatch disabled level …
@9523887
01/29/21 06:22:21 |
Sebastian Huber |
rtems: Fix implicit type conversions
This fix relates to a Coverity …
@fe08e45
01/29/21 05:29:38 |
Sebastian Huber |
score: Remove unused _SMP_Assert()
@9e56c85
01/28/21 15:52:52 |
Sebastian Huber |
score: Fix implicit type conversion
@d52c4961
01/28/21 15:51:15 |
Sebastian Huber |
rtems: Fix explicit type conversion
@23f4e5b
01/28/21 15:43:55 |
Sebastian Huber |
libtest: Fix implicit type conversions
@c4db00db
01/28/21 14:09:38 |
Sebastian Huber |
rtems: Mark value as used
This fix relates to a Coverity issue …
@0c99206
01/28/21 14:06:48 |
Sebastian Huber |
score: Remove double assignment
@3b8137b
01/28/21 14:03:55 |
Sebastian Huber |
libtest: Check return values with RTEMS_DEBUG
This fix relates to a …
@8d099f4a
01/28/21 13:52:03 |
Sebastian Huber |
score: Remove superfluous type qualifier
@2c050633
01/28/21 13:50:11 |
Sebastian Huber |
score: Simplify _CORE_message_queue_Broadcast()
@ab97ea64
01/28/21 13:36:13 |
Sebastian Huber |
bsp/leon3: Improve printk() support
Use the idle stack to buffer …
@3dcdb9c9
01/28/21 11:55:52 |
Sebastian Huber |
score: Simplify _MRSP_Wait_for_ownership()
Do not shadow the …
@5dc4f9c7
01/28/21 10:59:44 |
Sebastian Huber |
@c44ab898
01/28/21 10:52:38 |
Sebastian Huber |
bsp/leon3: Fix incompatible function types
@198e926
01/28/21 10:40:10 |
Sebastian Huber |
kern_tc.c: Remove unused code
@450c170
01/28/21 10:35:18 |
Sebastian Huber |
score: Add comments and asserts for clarification
This fix relates to …
@64189a70
01/28/21 10:29:12 |
Sebastian Huber |
score: Fix _CORE_message_queue_Submit() indentation
This fix relates …
@dc2a6987
01/28/21 10:26:11 |
Sebastian Huber |
bsp/leon3: Fix bsp_fatal_extension) indentation
Remove superfluous …
@395c15f
01/28/21 10:17:51 |
Sebastian Huber |
score: Fix _Objects_Get_information() indentation
@bf8d4b9
01/27/21 18:28:56 |
Sebastian Huber |
score: Add _Thread_Get_objects_information()
We do not need all the …
@76eec484
01/29/21 17:45:05 |
Sebastian Huber |
score: Rename _Thread_Get_objects_information()
Rename …
@44ae183
01/28/21 18:27:12 |
Sebastian Huber |
bsps/aarch64: Add missing include
Fixes:
@f8b6359
01/28/21 09:31:07 |
Sebastian Huber |
bsp/leon3: Simplify bsp_interrupt_is_valid_vector()
There is not need …
@fcbefb5
01/28/21 08:48:21 |
Sebastian Huber |
rtems: Use _Status_Get()
This fixes implicit conversions between …
@b361eabd
01/28/21 05:28:33 |
Sebastian Huber |
bsps: Replace bsp_specs with an empty file
This fixes an issue with …
@e269e389
01/27/21 15:42:14 |
Sebastian Huber |
libtest: Remove superfluous NULL pointer check
@426b6cd
01/27/21 15:41:00 |
Sebastian Huber |
libtest: Use dependency injection
This helps static analyzers.
@361ec320
01/27/21 15:33:01 |
Sebastian Huber |
cacheimpl.h: Avoid potential dead code
If CPU_DATA_CACHE_ALIGNMENT == …
@3272dcb
01/27/21 08:39:51 |
Sebastian Huber |
Update copyright notice to 2021
@b35ac99
01/25/21 08:27:22 |
Sebastian Huber |
rtems: Add "Notes" paragraph header
Place the paragraphs in the same …
@30c71c3
01/07/21 11:05:37 |
Sebastian Huber |
heap: Fix _Heap_Area_overhead()
The first block must be a proper …
@c734e86
01/08/21 10:59:40 |
Sebastian Huber |
cpucounter: Increase conversion accuracy
The maximum frequency is …
@9d2db27a
01/05/21 09:45:28 |
Sebastian Huber |
build: Add CPPFLAGS to assembler command line
We use GCC to call the …
