@9728ef3
07/17/13 13:05:56 |
Sebastian Huber |
posix: Convert to inline function
4.115
@15462a6f
07/17/13 13:01:03 |
Sebastian Huber |
rtems: Convert to inline functions
4.115
@20e239c2
07/17/13 12:23:14 |
Sebastian Huber |
score: Create mutex implementation header
Move implementation …
4.115
@f9d533a5
07/17/13 12:34:05 |
Sebastian Huber |
posix: Create mutex implementation header
4.115
@2bbea657
07/17/13 11:52:00 |
Sebastian Huber |
rtems: Create semaphore implementation header
4.115
@0dd262d3
07/18/13 07:42:46 |
Sebastian Huber |
libtests/gxx01: Avoid random memory read/write
4.115
@cbfe05c
07/18/13 07:50:43 |
Sebastian Huber |
score: Update due to API changes
4.115
@f7740e97
06/13/13 14:05:20 |
Sebastian Huber |
smp: Rename _CPU_Processor_event_receive()
Rename to …
4.115
@07f6e419
06/13/13 14:00:54 |
Sebastian Huber |
smp: Rename _CPU_Processor_event_broadcast()
Rename to …
4.115
@ca63ae2
06/13/13 13:41:21 |
Sebastian Huber |
smp: Add and use _CPU_SMP_Send_interrupt()
Delete bsp_smp_interrupt_cpu().
4.115
@39e51758
06/14/13 12:00:38 |
Sebastian Huber |
smp: Add and use _CPU_SMP_Get_current_processor()
Add and use …
4.115
@a7ce0ce
06/13/13 08:34:12 |
Sebastian Huber |
smp: Delete RTEMS_BSP_SMP_CONTEXT_SWITCH_NECESSARY
The thread …
4.115
@9c9b62d8
07/17/13 09:44:55 |
Sebastian Huber |
score: Changes due to Newlib DYNAMIC_REENT
Delete …
4.115
@f74d9496
07/17/13 09:03:02 |
Sebastian Huber |
score: Add _Thread_Get_executing()
4.115
@8b721d5
04/25/13 08:48:16 |
Sebastian Huber |
libcsupport: Use _reclaim_reent()
A Newlib including the following …
4.115
@a04182c
07/15/13 15:31:14 |
wei.a.yang |
clean up old atomic related files
4.115
@2e7f5798
07/15/13 15:31:13 |
wei.a.yang |
stdatomic.h support check when configure
4.115
@5186b55
07/15/13 15:31:12 |
wei.a.yang |
smpatomic test case update
4.115
@a3e9c228
07/15/13 15:31:11 |
wei.a.yang |
spatomic test case update
4.115
@d61e54c2
07/15/13 15:31:10 |
wei.a.yang |
update-all-architectures-to-new-atomic-implementation
4.115
@34229d5
07/15/13 15:31:09 |
wei.a.yang |
A generic atomic implementation for smp architectures
4.115
@1180099
07/15/13 15:31:08 |
wei.a.yang |
New atomic API definition based on C11 atomic
4.115
@39234725
07/17/13 06:42:35 |
Ric Claus |
bsps/arm: Fix for top of the address space
4.115
@691e0ef
07/13/13 20:58:27 |
Ric Claus |
bsp/xilinx-zynq: Provide BSP variants
4.115
@51a58e0
07/16/13 12:40:19 |
Sebastian Huber |
bsp/xilinx-zynq: Use bsp_console_select()
4.115
@7306578
07/16/13 12:39:59 |
Sebastian Huber |
bsps/serial: Move bsp_console_select() declaration
4.115
@7a7f071
07/16/13 15:34:51 |
Sebastian Huber |
posix: Delete unused functions
4.115
@b71cdd2
07/16/13 15:34:37 |
Sebastian Huber |
rtems: Delete unused functions
4.115
@3ccaf3c
07/16/13 15:18:18 |
Sebastian Huber |
bsps: Use rtems_task_self()
4.115
@85d2e4b
07/16/13 15:11:51 |
Sebastian Huber |
libchip/ata: Remove dead code
4.115
@ad4ce28
07/15/13 12:39:28 |
Vipul Nayyar |
Updated legacy code in arm edb7312
4.115
@4e5608dd
07/16/13 06:25:41 |
Sebastian Huber |
arm: Fix exception frame information
Use the right stack pointer …
4.115
@06adfae
07/15/13 07:52:45 |
Sebastian Huber |
bsps/arm: Disable alignment exceptions
4.115
@c8d78ee
07/02/13 08:37:13 |
Sebastian Huber |
bsp/mpc55xx: Add MPC5668G support
4.115
@583eb458
07/15/13 09:34:45 |
Vipul Nayyar |
bsp/rtl22xx: Use IRQ extensions API
4.115
@818d4b0
07/13/13 20:52:06 |
Ric Claus |
bsps/arm: Fix printk args to match format
4.115
@163e88a
07/12/13 17:03:57 |
Vipul Nayyar |
bsp/gumstix: Fix warnings
4.115
@9b6add4
07/12/13 11:34:17 |
Vipul Nayyar |
Updated Legacy code in arm gba
4.115
@5252822
07/11/13 08:06:35 |
Sebastian Huber |
bsps: Simplify bsp_generic_fatal() declaration
4.115
@79363a1
07/10/13 17:38:12 |
Joel Sherrill |
libbsp/shared/generic-fatal.h: Add RTEMS_COMPILER_NO_RETURN_ATTRIBUTE …
4.115
@e183211b
07/10/13 14:57:24 |
Vipul Nayyar |
Updated Legacy code in arm gumstix
4.115
@893d669
07/10/13 14:52:28 |
Vipul Nayyar |
Updated Legacy code in arm edb7312
4.115
@26c093e
07/10/13 12:36:50 |
Sebastian Huber |
bsp/virtex: Use #if instead of #ifdef
This allows …
4.115
@52e44630
07/10/13 07:54:01 |
Vipul Nayyar |
bsp/csb336: Use IRQ extensions API
Fix warnings.
4.115
@48a22ed
07/09/13 16:15:57 |
Joel Sherrill |
libchip ns16550.c: Improve comment
4.115
@155ea78
07/09/13 16:15:34 |
Joel Sherrill |
threadhandler.c: Add comments
4.115
@0a697dd9
07/09/13 09:24:27 |
Sebastian Huber |
bsp/virtex: Add VIRTEX_CONSOLE_USE_INTERRUPTS
Add interrupt support …
4.115
@d168079
07/09/13 14:38:03 |
Sebastian Huber |
bsp/virtex: Use ppc_count_leading_zeros()
Use …
4.115
@296b60d7
07/09/13 14:04:04 |
Sebastian Huber |
bsp/virtex: Fix interrupt handling
Some modules like the XPS UART …
4.115
@4fe3ad2
07/09/13 14:37:32 |
Sebastian Huber |
bsps/powerpc: Add ppc_count_leading_zeros()
4.115
@6886a485
07/07/13 13:00:45 |
Vipul Nayyar |
bsp/csb337: Use IRQ extensions API
Fix warnings.
4.115
@ad83ea0
07/07/13 12:43:17 |
Sebastian Huber |
mouse: Add shared bsp_get_serial_mouse_device()
4.115
@0d018268
07/05/13 13:18:24 |
Sebastian Huber |
psxtests/psxcleanup: Fix cleanup push/pop test
The …
4.115
@5e2a66d
07/05/13 12:53:57 |
Sebastian Huber |
psxtests/psxhdrs: Fix cleanup push/pop test
The …
4.115
@6009da1
07/05/13 12:56:23 |
Sebastian Huber |
posix: Add comment
4.115
@818edbd
07/02/13 13:16:33 |
Sebastian Huber |
bsp/mpc55xx: Update due to API changes
Termios notifies now the …
4.115
@d91d50f
07/02/13 13:14:51 |
Sebastian Huber |
bsp/mpc55xx: Avoid integer overflow
4.115
@c97d3dd
07/02/13 13:13:54 |
Sebastian Huber |
bsp/mpc55xx: Round PLL divider up
4.115
@cd7db89
06/24/13 15:14:08 |
ralf.kirchner |
bsp/psim: Use EABI and System V small-data area
4.115
@3da02169
06/24/13 15:16:16 |
ralf.kirchner |
bsps/powerpc: Avoid placement in small-data area
4.115
@1b47871d
06/24/13 15:15:42 |
ralf.kirchner |
bsp/psim: Fix declaration
It declares a symbol defined in the linker …
4.115
@3b645c1
06/28/13 19:26:59 |
Sebastian Huber |
bsps/arm: Add PL050 support
4.115
@c8312b3
06/23/13 12:39:47 |
Sebastian Huber |
bsps/arm: Add PL111 support
4.115
@e310dcd
06/28/13 19:26:11 |
Sebastian Huber |
libchip/serial: Add const qualifier
4.115
@a4006fee
06/28/13 19:25:30 |
Sebastian Huber |
mouse: Include missing header file
4.115
@311ba73
06/23/13 15:50:55 |
Sebastian Huber |
framebuffer: Add and use FRAMEBUFFER_DEVICE_0_NAME
4.115
@98db96e
06/29/13 12:00:39 |
Sebastian Huber |
make: Use C flags for C++ as default
In case a BSP selects special …
4.115
@40ce265
06/28/13 13:05:30 |
Sebastian Huber |
bsp/psim: Use plain symbol for PSIM
This avoids a linker assertion …
4.115
@4800ffe
06/28/13 07:07:13 |
Sebastian Huber |
bsps/powerpc: Update debug sections
4.115
@ca59217
06/28/13 07:03:11 |
Sebastian Huber |
bsps/arm: Set vector base on all processors
4.115
@a3a4cd5
06/26/13 07:40:44 |
Sebastian Huber |
bsps/arm: Move input sections
Move input sections to preserve order …
4.115
@56435e6
06/26/13 08:25:42 |
Sebastian Huber |
powerpc: Fix Altivec support
Use the right context.
4.115
@4b83e8f1
06/21/13 07:59:27 |
Sebastian Huber |
bsps/arm: Fix set exception handler for ARMv7
4.115
@b4062c3f
06/25/13 09:15:18 |
Sebastian Huber |
tmtests/tm20: Change allocation sizes
This avoids problems with …
4.115
@22c7a64
06/25/13 10:22:23 |
Sebastian Huber |
psxtests/psxkey02: Simplify
This avoids problems with debugging enabled.
4.115
@d79973d
06/25/13 09:13:15 |
Sebastian Huber |
sptests/spwkspace: Reserve space for duplicates
4.115
@8ebc680
06/24/13 11:44:51 |
Sebastian Huber |
sptests/spmountmgr01: Simplify
This avoids problems with debugging …
4.115
@b9acb4e
06/25/13 12:03:51 |
Sebastian Huber |
sptests/sp64: Simplify
4.115
@83889708
06/25/13 12:32:44 |
Sebastian Huber |
sptests/sp62: Rework to avoid heap internals
This avoids problems …
4.115
@7c1fcff3
06/25/13 12:59:45 |
Sebastian Huber |
sptests/sp59: Change allocation size
4.115
@9f37fb1
06/25/13 10:16:13 |
Sebastian Huber |
sptests/sp18: Simplify
4.115
@b64e8dc0
06/25/13 14:57:38 |
Sebastian Huber |
sptests/sp16: Change allocation sizes
4.115
@3948a0b
06/25/13 09:14:17 |
Sebastian Huber |
sptests/sp09: Change allocation sizes
4.115
@d0d357ed
06/25/13 10:09:50 |
Sebastian Huber |
heap: Add _Heap_Greedy_allocate_all_except_largest
Add …
4.115
@c497657
06/25/13 12:31:47 |
Sebastian Huber |
heap: Free all delayed blocks during resize
4.115
@cc0cb7c
06/25/13 09:11:40 |
Sebastian Huber |
heap: Free all delayed blocks during extend
4.115
@1d48e25d
06/24/13 14:48:17 |
Sebastian Huber |
heap: Workaround for workspace protection
4.115
@e18db9f
06/24/13 15:29:11 |
Sebastian Huber |
termios: Update due to API changes
Termios notifies now the driver …
4.115
@1df348b
06/24/13 09:00:36 |
Sebastian Huber |
bsps/arm: Rename function
Rename …
4.115
@e916b125
06/21/13 15:17:28 |
Sebastian Huber |
bsp/virtex: Use shared clock driver
4.115
@0110491
06/20/13 14:22:16 |
Sebastian Huber |
bsp/virtex: Add console devices only if present
4.115
@dbf62b3
06/20/13 14:20:43 |
Sebastian Huber |
bsp/virtex: Fix warnings
4.115
@c4cfc62
06/20/13 12:33:19 |
Sebastian Huber |
bsp/virtex: Use XPAR_INTC_SINGLE_BASEADDR
This define is also present …
4.115
@dfb5805
06/20/13 12:32:12 |
Sebastian Huber |
bsp/virtex: Remove unused configure macros
4.115
@53dc697
06/18/13 14:42:25 |
Sebastian Huber |
bsp/virtex: Delete BSP_ask_for_reset and BSP_panic
4.115
@39c1534f
06/18/13 15:20:28 |
Sebastian Huber |
bsp/virtex: Use generic interrupt support
4.115
@894e93f
06/18/13 14:44:40 |
Sebastian Huber |
bsp/virtex: Fix header includes
4.115
@bee7612e
06/18/13 14:39:24 |
Sebastian Huber |
bsp/virtex: Move timer config to new file
4.115
@48ab8465
06/18/13 14:27:42 |
Sebastian Huber |
bsp/virtex: Do not use PPC403 TTY driver
4.115
@ad094f4
06/18/13 14:26:25 |
Sebastian Huber |
4.115
