@8abbbdde
07/21/14 16:29:00 |
Sebastian Huber |
rbtree: Do not set node off-tree in extract
4.115
@d7a94693
07/21/14 16:16:47 |
Sebastian Huber |
rbtree: Remove superfluous NULL pointer checks
4.115
@6b0a7efc
07/21/14 16:08:07 |
Sebastian Huber |
rbtree: Format
4.115
@87894c0
07/11/14 11:29:53 |
Sebastian Huber |
doc: Update console driver documentation
4.115
@742402b5
07/16/14 20:45:49 |
Joel Sherrill |
m68k/gen68360/include/tm27.h: Correct comment
4.115
@6e868d87
07/16/14 20:43:05 |
Joel Sherrill |
Add More Testsuite Configuration Files and Update Existing Ones
The …
4.115
@6832a560
07/16/14 00:45:32 |
Chris Johns |
Common ARM A8 code.
4.115
@0ea6d07
07/09/14 18:22:28 |
Joel Sherrill |
Use Shared Method for Thread Unblock Cleanup
When a thread is removed …
4.115
@3250664
07/15/14 17:37:36 |
Joel Sherrill |
Thread Queue: Merge discipline subroutines into main methods
There …
4.115
@ed7a028
07/07/14 19:26:13 |
Joel Sherrill |
Thread Queue Priority Discipline Reimplemented with RBTree
4.115
@64939bc
07/12/14 19:22:22 |
Sebastian Huber |
rbtree: Reduce RBTree_Control size
Remove compare function and is …
4.115
@7e119990
07/12/14 19:22:21 |
Sebastian Huber |
rbtree: Delete unused functions
4.115
@7e60b7d
07/12/14 22:04:19 |
Ben Gras |
uart-output-char.h: extra offset definition.
All,
This patch is …
4.115
@9ba76ed8
07/07/14 22:42:28 |
Joel Sherrill |
sp59: Fix typos
4.115
@764e8b11
07/07/14 19:23:24 |
Joel Sherrill |
scheduleredfunblock.c: Correct spacing
4.115
@3a01e8b
07/07/14 19:22:57 |
Joel Sherrill |
semdelete.c: Correct spacing
4.115
@b6343c6
07/10/14 19:20:39 |
Joel Sherrill |
Enhance Semaphore Blocking and Readying Time Test Cases
tm02 and tm03 …
4.115
@648c86c
07/14/14 18:12:31 |
Jennifer Averett |
capture01: Add include of assert.h.
4.115
@247118bf
07/10/14 16:55:04 |
Jennifer Averett |
smpschedsem01: new test.
This test verifies priority is inherited …
4.115
@7eb3fd47
07/10/14 16:45:58 |
Jennifer Averett |
smpschedaffinity05: Add test for worst case migration for affintiy …
4.115
@61d26f93
07/10/14 16:36:40 |
Jennifer Averett |
smpschedaffinity04: New test.
This test walks a secondary high …
4.115
@28d66749
07/10/14 16:18:02 |
Jennifer Averett |
smpschedaffinity03: New test.
This task walks the affinity of self …
4.115
@09293069
07/10/14 15:19:06 |
Jennifer Averett |
smpschedaffinity02: New test.
This test checks setting the affinity …
4.115
@d88b0e7f
05/22/14 14:00:14 |
Jennifer Averett |
smpschedaffinity01: New test.
This test verifies that affinity is …
4.115
@82d137ae
04/23/14 20:08:26 |
Jennifer Averett |
capture01: New non-interactive test for capture engine.
4.115
@463de59
04/16/14 14:42:37 |
Jennifer Averett |
capture: Fix capture engine to handle new extensions.
4.115
@1af8634a
04/11/14 15:18:20 |
Jennifer Averett |
capture: Update comment block style in capture engine.
Doxygen added …
4.115
@f0c8501
07/11/14 07:47:05 |
Sebastian Huber |
score: Scheduler helping proto for affinity sched
The priority …
4.115
@27783f6
07/10/14 12:27:42 |
Sebastian Huber |
score: Fix scheduler helping implementation
Do not extract the idle …
4.115
@333f9426
07/10/14 10:49:43 |
Sebastian Huber |
score: Fix assertions
4.115
@76ad756c
07/10/14 05:56:11 |
Chris Johns |
FreeBSD standard shell does not support substring expansion.
Switch …
4.115
@e1f446d3
07/09/14 13:53:31 |
Sebastian Huber |
bsps/sparc: Set best baud in APBUART driver
This prevents failures of …
4.115
@93726e5
07/09/14 13:44:13 |
Sebastian Huber |
termios: Add rtems_termios_set_best_baud()
4.115
@8074342c
07/03/14 10:55:42 |
Christian.Mauderer |
termios: Add rtems_termios_get_termios()
4.115
@8448a4d
07/01/14 13:09:49 |
bsps/sparc: Move APBUART printk support
4.115
@21abc43
06/30/14 07:33:36 |
Sebastian Huber |
bsps/sparc: Add and use shared APBUART console
Move the APBUART …
4.115
@a0eb21e
06/27/14 14:20:44 |
Sebastian Huber |
bsps: Basic console driver for Termios devices
4.115
@a0fb29f
07/09/14 09:52:56 |
Sebastian Huber |
termios: PR1279: Use first open status
4.115
@32fc6a3
07/09/14 09:15:53 |
Sebastian Huber |
termios: PR1279: Use set attributes status
4.115
@ef8c00bc
06/27/14 11:10:15 |
Sebastian Huber |
termios: PR2153: New low-level device API
Add a new low-level device …
4.115
@c6048ee
07/09/14 09:20:23 |
Sebastian Huber |
score: _Scheduler_Thread_get_own_node()
Provide this function also …
4.115
@9f228bea
06/24/14 08:00:06 |
Sebastian Huber |
smptests/smpmrsp01: Add and update test cases
4.115
@5c3d250
07/04/14 12:34:23 |
Sebastian Huber |
score: Implement scheduler helping protocol
The following scheduler …
4.115
@52f8e90d
07/08/14 16:42:05 |
Joel Sherrill |
schedulerpriorityaffinitysmp.c: Add period at end of sentence
4.115
@8568341
06/11/14 12:31:03 |
Sebastian Huber |
score: Need for help indicator for scheduler ops
Return a thread in …
4.115
@ac532f3
07/04/14 11:40:10 |
Sebastian Huber |
score: Add _Scheduler_Help()
Manage the help state of threads with …
4.115
@08d9760
07/08/14 12:25:55 |
Sebastian Huber |
score: Rename *_Node_get() to *_Thread_get_node()
This emphasizes …
4.115
@19e41767
07/08/14 08:38:19 |
Sebastian Huber |
score: Simplify SMP processor allocation
Avoid copy and paste and set …
4.115
@835b88b
07/07/14 14:41:03 |
Sebastian Huber |
score: Rename _Scheduler_SMP_Update_heir()
Rename and move …
4.115
@5c632c4
07/07/14 11:31:07 |
Sebastian Huber |
score: Fix warning
4.115
@46cd17a
07/04/14 12:32:35 |
Sebastian Huber |
score: Fix MrsP resource root change
Use the root of the owner for …
4.115
@fbda4a8
07/01/14 08:48:28 |
Sebastian Huber |
score: PR2183: Fix context switch on SMP
Fix context switch on SMP …
4.115
@f28f5c4
06/30/14 14:47:06 |
Sebastian Huber |
arm: Use local label in _CPU_Context_restore()
4.115
@bec4730
06/30/14 10:55:50 |
Sebastian Huber |
score: Add PER_CPU_OFFSET_EXECUTING
Add PER_CPU_OFFSET_HEIR. Move …
4.115
@7ab6046
07/01/14 13:30:07 |
Sebastian Huber |
bsp/altera-cyclone-v: Move MMU configuration table
This makes it …
4.115
@9eb1994f
07/01/14 13:17:40 |
Sebastian Huber |
bsps/arm: Rename bsp_mm_config_table
Rename bsp_mm_config_table to …
4.115
@8852594
07/01/14 10:02:24 |
Sebastian Huber |
sptests/spcontext01: Avoid NULL pointer access
4.115
@516a60a
06/30/14 11:34:09 |
Sebastian Huber |
bsps/sparc: Reduce copy and paste
4.115
@47cf1add
06/04/14 12:22:00 |
Daniel Hellstrom |
LEON3: devfs free nodes must be sized
.. according to the maximum …
4.115
@9f99232
06/13/14 13:14:54 |
Daniel Hellstrom |
LEON3: fix console close handling
On SMP rtems_interrupt_lock_context …
4.115
@0b4ec4d
06/30/14 10:30:12 |
Sebastian Huber |
smptests/smpfatal08: Support RTEMS_PARAVIRT
4.115
@f6b1e063
06/27/14 11:08:28 |
Sebastian Huber |
termios: Make tty list static
4.115
@dd510a0
06/26/14 11:30:59 |
Sebastian Huber |
rtems: Delete unused <rtems/rtems/atomic.h>
4.115
@89f8eab5
05/07/14 12:55:37 |
Sebastian Huber |
score: Workaround for GCC 4.9 for atomic ops
The GCC 4.9 ships its …
4.115
@b42e148
06/24/14 07:53:11 |
Sebastian Huber |
smptests/smpmigration02: PR2183: Add test case
4.115
@152ad7d1
06/24/14 07:31:14 |
Sebastian Huber |
score: Fix _Thread_Start_multitasking() on SMP
The …
4.115
@a92989a
06/18/14 13:16:02 |
Sebastian Huber |
score: Fix thread deletion on SMP
Close the thread object in …
4.115
@8f0c7a46
06/10/14 14:13:37 |
Sebastian Huber |
score: Decouple thread and scheduler nodes on SMP
Add a chain node to …
4.115
@647b95d
06/10/14 14:32:12 |
Sebastian Huber |
score: Use chain nodes for ready queue support
This reduces the API …
4.115
@2d36931
06/11/14 09:03:25 |
Sebastian Huber |
score: Collect scheduler related fields in TCB
Add …
4.115
@92635cb
06/03/14 14:27:53 |
Sebastian Huber |
score: Remove scheduler parameter from most ops
Remove the scheduler …
4.115
@bd1431a
06/20/14 10:05:23 |
Sebastian Huber |
score: Use default get/set affinity operation
Add and use …
4.115
@2803c8ce
06/20/14 07:59:05 |
Sebastian Huber |
score: Fix statement with no effect
4.115
@f6b7b7ba
06/18/14 10:11:04 |
Sebastian Huber |
score: Fix _Thread_Delay_ended() on SMP
Suppose we have two tasks A …
4.115
@bd56356b
06/18/14 08:54:04 |
Sebastian Huber |
smptests/smpwakeafter01: New test
4.115
@11947299
06/13/14 14:06:20 |
Sebastian Huber |
smptests: Avoid use of uninitialized data
4.115
@73bf499
06/10/14 08:56:55 |
Sebastian Huber |
JFFS2: Add device identifier for the flash device
It is used in …
4.115
@2ba2743
06/12/14 12:50:33 |
Sebastian Huber |
score: Delete _Thread_Set_transient()
4.115
@a80c3b6
06/10/14 14:11:58 |
Sebastian Huber |
score: _Scheduler_priority_Get_scheduler_info()
Delete …
4.115
@701dd96f
06/12/14 12:37:57 |
Sebastian Huber |
score: PR2181: Add _Thread_Yield()
The _Scheduler_Yield() was called …
4.115
@970aa80
06/12/14 09:18:48 |
Sebastian Huber |
bsp/realview-pbx-a9: Fix SMP startup
4.115
@4962d24d
06/11/14 14:34:51 |
Sebastian Huber |
smptests/smpscheduler03: Test all SMP schedulers
4.115
@4639002
06/12/14 07:17:39 |
Sebastian Huber |
score: Make functions inline
These functions are used only via the …
4.115
@82df6f3
06/12/14 07:06:53 |
Sebastian Huber |
score: Move NULL pointer check to order function
This helps to avoid …
4.115
@6500614
06/12/14 06:49:08 |
Sebastian Huber |
score: Fix warnings
4.115
@d9b54da
06/12/14 06:48:02 |
Sebastian Huber |
score: Format
4.115
@6f4993e
06/12/14 06:43:25 |
Sebastian Huber |
score: Add missing inline
4.115
@897a0935
06/11/14 13:37:11 |
Sebastian Huber |
score: Fix scheduler context initializer
4.115
@238629f
05/19/14 20:26:55 |
Joel Sherrill |
Add SMP Priority Scheduler with Affinity
This scheduler attempts to …
4.115
@647859e
06/11/14 12:37:03 |
Sebastian Huber |
samples/pppd: Fix extra drivers initializer
4.115
@cb42c9a
06/10/14 14:48:54 |
omgalvan.86 |
lm3s6965-testsuite.cfg: Add pppd.
When trying to compile RTEMS for …
4.115
@e473f3c
06/10/14 12:30:47 |
Sebastian Huber |
score: Fix MrsP root node update
Set the new root after the resource …
4.115
@2a2a1695
06/10/14 09:42:19 |
Sebastian Huber |
smptest/smpfatal03: Update due to API changes
4.115
@19260fb
06/09/14 14:27:18 |
martin.boretto |
bsp/lpc176x: New BSP
4.115
@c1072919
06/06/14 12:54:37 |
Sebastian Huber |
Revert "bsps/powerpc: Fix potential relocation truncation"
This …
4.115
@d9ff8b3e
06/06/14 11:35:56 |
Sebastian Huber |
See also
4.115
@dc44de7
06/05/14 14:38:29 |
Sebastian Huber |
bsps/arm: Fix TLB invalidation for ARMv7-A
4.115
@c19342a7
06/05/14 14:19:21 |
Sebastian Huber |
bsps/arm: Fix Cortex-A9 MPCore clock driver
The nanoseconds extension …
4.115
@1468d70
06/05/14 08:03:55 |
Sebastian Huber |
bsp/altera-cyclone-v: Enable unified L2 cache
4.115
@2a1d86c
06/05/14 08:03:06 |
Sebastian Huber |
bsp/altera-cyclone-v: Move SMP support
4.115
