@7306578
07/16/13 12:39:59 |
Sebastian Huber |
bsps/serial: Move bsp_console_select() declaration
4.115
@7a7f071
07/16/13 15:34:51 |
Sebastian Huber |
posix: Delete unused functions
4.115
@b71cdd2
07/16/13 15:34:37 |
Sebastian Huber |
rtems: Delete unused functions
4.115
@3ccaf3c
07/16/13 15:18:18 |
Sebastian Huber |
bsps: Use rtems_task_self()
4.115
@85d2e4b
07/16/13 15:11:51 |
Sebastian Huber |
libchip/ata: Remove dead code
4.115
@ad4ce28
07/15/13 12:39:28 |
Vipul Nayyar |
Updated legacy code in arm edb7312
4.115
@4e5608dd
07/16/13 06:25:41 |
Sebastian Huber |
arm: Fix exception frame information
Use the right stack pointer …
4.115
@06adfae
07/15/13 07:52:45 |
Sebastian Huber |
bsps/arm: Disable alignment exceptions
4.115
@c8d78ee
07/02/13 08:37:13 |
Sebastian Huber |
bsp/mpc55xx: Add MPC5668G support
4.115
@583eb458
07/15/13 09:34:45 |
Vipul Nayyar |
bsp/rtl22xx: Use IRQ extensions API
4.115
@818d4b0
07/13/13 20:52:06 |
Ric Claus |
bsps/arm: Fix printk args to match format
4.115
@163e88a
07/12/13 17:03:57 |
Vipul Nayyar |
bsp/gumstix: Fix warnings
4.115
@9b6add4
07/12/13 11:34:17 |
Vipul Nayyar |
Updated Legacy code in arm gba
4.115
@5252822
07/11/13 08:06:35 |
Sebastian Huber |
bsps: Simplify bsp_generic_fatal() declaration
4.115
@79363a1
07/10/13 17:38:12 |
Joel Sherrill |
libbsp/shared/generic-fatal.h: Add RTEMS_COMPILER_NO_RETURN_ATTRIBUTE …
4.115
@e183211b
07/10/13 14:57:24 |
Vipul Nayyar |
Updated Legacy code in arm gumstix
4.115
@893d669
07/10/13 14:52:28 |
Vipul Nayyar |
Updated Legacy code in arm edb7312
4.115
@26c093e
07/10/13 12:36:50 |
Sebastian Huber |
bsp/virtex: Use #if instead of #ifdef
This allows …
4.115
@52e44630
07/10/13 07:54:01 |
Vipul Nayyar |
bsp/csb336: Use IRQ extensions API
Fix warnings.
4.115
@48a22ed
07/09/13 16:15:57 |
Joel Sherrill |
libchip ns16550.c: Improve comment
4.115
@155ea78
07/09/13 16:15:34 |
Joel Sherrill |
threadhandler.c: Add comments
4.115
@0a697dd9
07/09/13 09:24:27 |
Sebastian Huber |
bsp/virtex: Add VIRTEX_CONSOLE_USE_INTERRUPTS
Add interrupt support …
4.115
@d168079
07/09/13 14:38:03 |
Sebastian Huber |
bsp/virtex: Use ppc_count_leading_zeros()
Use …
4.115
@296b60d7
07/09/13 14:04:04 |
Sebastian Huber |
bsp/virtex: Fix interrupt handling
Some modules like the XPS UART …
4.115
@4fe3ad2
07/09/13 14:37:32 |
Sebastian Huber |
bsps/powerpc: Add ppc_count_leading_zeros()
4.115
@6886a485
07/07/13 13:00:45 |
Vipul Nayyar |
bsp/csb337: Use IRQ extensions API
Fix warnings.
4.115
@ad83ea0
07/07/13 12:43:17 |
Sebastian Huber |
mouse: Add shared bsp_get_serial_mouse_device()
4.115
@0d018268
07/05/13 13:18:24 |
Sebastian Huber |
psxtests/psxcleanup: Fix cleanup push/pop test
The …
4.115
@5e2a66d
07/05/13 12:53:57 |
Sebastian Huber |
psxtests/psxhdrs: Fix cleanup push/pop test
The …
4.115
@6009da1
07/05/13 12:56:23 |
Sebastian Huber |
posix: Add comment
4.115
@818edbd
07/02/13 13:16:33 |
Sebastian Huber |
bsp/mpc55xx: Update due to API changes
Termios notifies now the …
4.115
@d91d50f
07/02/13 13:14:51 |
Sebastian Huber |
bsp/mpc55xx: Avoid integer overflow
4.115
@c97d3dd
07/02/13 13:13:54 |
Sebastian Huber |
bsp/mpc55xx: Round PLL divider up
4.115
@cd7db89
06/24/13 15:14:08 |
ralf.kirchner |
bsp/psim: Use EABI and System V small-data area
4.115
@3da02169
06/24/13 15:16:16 |
ralf.kirchner |
bsps/powerpc: Avoid placement in small-data area
4.115
@1b47871d
06/24/13 15:15:42 |
ralf.kirchner |
bsp/psim: Fix declaration
It declares a symbol defined in the linker …
4.115
@3b645c1
06/28/13 19:26:59 |
Sebastian Huber |
bsps/arm: Add PL050 support
4.115
@c8312b3
06/23/13 12:39:47 |
Sebastian Huber |
bsps/arm: Add PL111 support
4.115
@e310dcd
06/28/13 19:26:11 |
Sebastian Huber |
libchip/serial: Add const qualifier
4.115
@a4006fee
06/28/13 19:25:30 |
Sebastian Huber |
mouse: Include missing header file
4.115
@311ba73
06/23/13 15:50:55 |
Sebastian Huber |
framebuffer: Add and use FRAMEBUFFER_DEVICE_0_NAME
4.115
@98db96e
06/29/13 12:00:39 |
Sebastian Huber |
make: Use C flags for C++ as default
In case a BSP selects special …
4.115
@40ce265
06/28/13 13:05:30 |
Sebastian Huber |
bsp/psim: Use plain symbol for PSIM
This avoids a linker assertion …
4.115
@4800ffe
06/28/13 07:07:13 |
Sebastian Huber |
bsps/powerpc: Update debug sections
4.115
@ca59217
06/28/13 07:03:11 |
Sebastian Huber |
bsps/arm: Set vector base on all processors
4.115
@a3a4cd5
06/26/13 07:40:44 |
Sebastian Huber |
bsps/arm: Move input sections
Move input sections to preserve order …
4.115
@56435e6
06/26/13 08:25:42 |
Sebastian Huber |
powerpc: Fix Altivec support
Use the right context.
4.115
@4b83e8f1
06/21/13 07:59:27 |
Sebastian Huber |
bsps/arm: Fix set exception handler for ARMv7
4.115
@b4062c3f
06/25/13 09:15:18 |
Sebastian Huber |
tmtests/tm20: Change allocation sizes
This avoids problems with …
4.115
@22c7a64
06/25/13 10:22:23 |
Sebastian Huber |
psxtests/psxkey02: Simplify
This avoids problems with debugging enabled.
4.115
@d79973d
06/25/13 09:13:15 |
Sebastian Huber |
sptests/spwkspace: Reserve space for duplicates
4.115
@8ebc680
06/24/13 11:44:51 |
Sebastian Huber |
sptests/spmountmgr01: Simplify
This avoids problems with debugging …
4.115
@b9acb4e
06/25/13 12:03:51 |
Sebastian Huber |
sptests/sp64: Simplify
4.115
@83889708
06/25/13 12:32:44 |
Sebastian Huber |
sptests/sp62: Rework to avoid heap internals
This avoids problems …
4.115
@7c1fcff3
06/25/13 12:59:45 |
Sebastian Huber |
sptests/sp59: Change allocation size
4.115
@9f37fb1
06/25/13 10:16:13 |
Sebastian Huber |
sptests/sp18: Simplify
4.115
@b64e8dc0
06/25/13 14:57:38 |
Sebastian Huber |
sptests/sp16: Change allocation sizes
4.115
@3948a0b
06/25/13 09:14:17 |
Sebastian Huber |
sptests/sp09: Change allocation sizes
4.115
@d0d357ed
06/25/13 10:09:50 |
Sebastian Huber |
heap: Add _Heap_Greedy_allocate_all_except_largest
Add …
4.115
@c497657
06/25/13 12:31:47 |
Sebastian Huber |
heap: Free all delayed blocks during resize
4.115
@cc0cb7c
06/25/13 09:11:40 |
Sebastian Huber |
heap: Free all delayed blocks during extend
4.115
@1d48e25d
06/24/13 14:48:17 |
Sebastian Huber |
heap: Workaround for workspace protection
4.115
@e18db9f
06/24/13 15:29:11 |
Sebastian Huber |
termios: Update due to API changes
Termios notifies now the driver …
4.115
@1df348b
06/24/13 09:00:36 |
Sebastian Huber |
bsps/arm: Rename function
Rename …
4.115
@e916b125
06/21/13 15:17:28 |
Sebastian Huber |
bsp/virtex: Use shared clock driver
4.115
@0110491
06/20/13 14:22:16 |
Sebastian Huber |
bsp/virtex: Add console devices only if present
4.115
@dbf62b3
06/20/13 14:20:43 |
Sebastian Huber |
bsp/virtex: Fix warnings
4.115
@c4cfc62
06/20/13 12:33:19 |
Sebastian Huber |
bsp/virtex: Use XPAR_INTC_SINGLE_BASEADDR
This define is also present …
4.115
@dfb5805
06/20/13 12:32:12 |
Sebastian Huber |
bsp/virtex: Remove unused configure macros
4.115
@53dc697
06/18/13 14:42:25 |
Sebastian Huber |
bsp/virtex: Delete BSP_ask_for_reset and BSP_panic
4.115
@39c1534f
06/18/13 15:20:28 |
Sebastian Huber |
bsp/virtex: Use generic interrupt support
4.115
@894e93f
06/18/13 14:44:40 |
Sebastian Huber |
bsp/virtex: Fix header includes
4.115
@bee7612e
06/18/13 14:39:24 |
Sebastian Huber |
bsp/virtex: Move timer config to new file
4.115
@48ab8465
06/18/13 14:27:42 |
Sebastian Huber |
bsp/virtex: Do not use PPC403 TTY driver
4.115
@ad094f4
06/18/13 14:26:25 |
Sebastian Huber |
4.115
@b45397fb
06/18/13 14:25:53 |
Sebastian Huber |
bsp/virtex: Delete bsp_XAssertHandler()
4.115
@ff538bbf
06/18/13 14:24:10 |
Sebastian Huber |
bsp/virtex: Delete unused variables
4.115
@0ba2736
06/18/13 14:12:56 |
Sebastian Huber |
bsp/virtex: Replace low-level BSP start code
Use linkcmds.base. Use …
4.115
@546c1056
06/18/13 13:19:19 |
Sebastian Huber |
bsp/virtex: Rename file dlentry.S in start.S
Use default bsp_specs file.
4.115
@509e0f3f
06/21/13 15:16:37 |
Sebastian Huber |
bsps/powerpc: Add PPC405 support for shared clock
4.115
@7d0e88f2
06/21/13 14:19:46 |
Sebastian Huber |
bsps/powerpc: Delete clock_4xx.c
4.115
@27b207a8
06/21/13 13:10:48 |
Sebastian Huber |
bsps: Delete bspreset_fatal.c
Use bspreset_loop.c instead. This …
4.115
@1ebffa89
06/21/13 07:18:01 |
Chris Johns |
arm: Fix default exception prologues
4.115
@4f1da72
06/21/13 07:16:19 |
Sebastian Huber |
score: _Heap_Protection_free_all_delayed_blocks()
Add and use …
4.115
@9165a5b0
06/18/13 12:14:43 |
Sebastian Huber |
IMFS: Fix reference count for debug enabled
4.115
@f97f46ce
06/20/13 09:03:45 |
Sebastian Huber |
libchip/serial: Fix warning
4.115
@c9db7f9
06/18/13 15:47:41 |
Sebastian Huber |
bsps: Use CONSOLE_DEVICE_NAME
4.115
@a4bc725e
06/18/13 15:45:50 |
Sebastian Huber |
bsps: Remove debug output in shared console driver
4.115
@37220fac
06/20/13 10:00:29 |
Sebastian Huber |
bsps: Do not use printk() in shared console driver
4.115
@6307b1a
06/20/13 09:57:34 |
Sebastian Huber |
bsps: Add fatal errors for shared console driver
4.115
@ade27c6
06/20/13 09:44:04 |
Sebastian Huber |
bsps: Move bsp_generic_fatal_code to new file
Add bsp_generic_fatal().
4.115
@5f91272
06/20/13 09:17:23 |
Sebastian Huber |
bsps/powerpc: Delete bsp_exceptions_in_RAM
Delete …
4.115
@6520aef1
06/20/13 15:52:16 |
Joel Sherrill |
sparc in_cksum: Use sparc which is available in -ansi mode
4.115
@cddb8f4
06/20/13 07:48:27 |
Ric Claus |
bsps/arm: Fix some GIC functions
4.115
@9a037da9
06/19/13 09:20:06 |
Sebastian Huber |
bsps/arm: Set vector base address if necessary
4.115
@45fecbb6
06/16/13 13:40:03 |
Jiri Gaisler |
greth: do not advertise 1000M capability if MAC does not support it.
4.115
@1bdc6d1
06/16/13 13:28:20 |
Jiri Gaisler |
greth: prefer full duplex if available
4.115
@1f4ee30
06/15/13 22:13:41 |
Jiri Gaisler |
Added in_cksum_sparc.h to optimize IP checksum calculations for SPARC.
4.115
@cb6b9ba
06/19/13 10:57:54 |
Sebastian Huber |
bsp/xilinx-zynq: Use magic UART baud divisor
Use a baud divisor …
4.115
@3f6a823
06/19/13 10:57:26 |
Sebastian Huber |
bsp/xilinx-zynq: Do not start transmitter break
4.115
