@1ee9a1a
09/25/98 13:24:00 |
Joel Sherrill |
Added information on every service in this chapter. Most of them are …
4.104.114.84.95
@97149ba
09/25/98 13:17:32 |
Joel Sherrill |
Added ENOSYS stubs for a number of process routines.
4.104.114.84.95
@1d2366e
09/25/98 12:50:36 |
Joel Sherrill |
Stuff added by Kerwin.
4.104.114.84.95
@7a86dc4
09/24/98 20:30:09 |
Joel Sherrill |
Improved missing directory message.
4.104.114.84.95
@85420c8
09/24/98 20:29:52 |
Joel Sherrill |
Removed blank line.
4.104.114.84.95
@da38d8a
09/24/98 15:43:38 |
Joel Sherrill |
Removed superfluous initialization of PC video.
4.104.114.84.95
@32f3e34
09/24/98 13:55:18 |
Joel Sherrill |
Patch from Erik Ivanenko <erik.ivanenko@…>:
Please find …
4.104.114.84.95
@287e9584
09/24/98 13:46:27 |
Joel Sherrill |
New version from Erik Ivanenko <erik.ivanenko@…>.
4.104.114.84.95
@1fd26a5
09/23/98 16:46:52 |
Joel Sherrill |
Patch from Ralf Corsepius <corsepiu@…>.
4.104.114.84.95
@ecc3fe3
09/23/98 16:41:00 |
Joel Sherrill |
IDLE task stack size now specified as a field in the CPU Table for all …
4.104.114.84.95
@3b93a2de
09/23/98 16:34:23 |
Joel Sherrill |
Modifed to zero out the C heap if the CPU Table indicates that the …
4.104.114.84.95
@87c857a9
09/23/98 13:43:44 |
Joel Sherrill |
changed version to 980923
4.104.114.84.95
@5d17a64
09/23/98 13:43:14 |
Joel Sherrill |
Updated to remove bad comment.
4.104.114.84.95
@1cf2df40
09/23/98 13:25:37 |
Joel Sherrill |
Removed printk() references.
4.104.114.84.95
@479c86dd
09/23/98 13:22:43 |
Joel Sherrill |
Please find …
4.104.114.84.95
@8a496e46
09/23/98 13:20:34 |
Joel Sherrill |
Patch from Aleksey (Quality Quorum <qqi@…>):
1. …
4.104.114.84.95
@362b88e
09/23/98 13:17:23 |
Joel Sherrill |
Switched "NEW_GAS" flag.
4.104.114.84.95
@f26f5828
09/23/98 13:17:10 |
Joel Sherrill |
Regenerated.
4.104.114.84.95
@6385cbd
09/21/98 22:04:07 |
warm38 |
Updated file based upon red-lines received.
4.104.114.84.95
@98bdf7a
09/21/98 21:34:04 |
warm38 |
Updated file based upon read_lines received.
4.104.114.84.95
@f8c5bad
09/21/98 21:31:59 |
warm38 |
4.104.114.84.95
@af973e57
09/21/98 16:38:20 |
Joel Sherrill |
changed version to 980921
4.104.114.84.95
@219aedad
09/21/98 15:27:03 |
warm38 |
Modified sentences in the file to avoid using "shall" statements.
4.104.114.84.95
@f9b0efb0
09/21/98 15:17:00 |
warm38 |
Described the constants used by the admin_type in the background …
4.104.114.84.95
@42424ef
09/21/98 01:45:14 |
Joel Sherrill |
Corrected ColdFire? port information.
4.104.114.84.95
@e62488d
09/21/98 01:29:19 |
Joel Sherrill |
New file from Emmanuel Raguet <raguet@…>.
4.104.114.84.95
@718dc95
09/21/98 00:46:00 |
Joel Sherrill |
Patch from Eric Norum <eric@…>:
Here's a patch to …
4.104.114.84.95
@7ddcfb8c
09/21/98 00:42:07 |
Joel Sherrill |
Patch from Eric Norum and David Fiddes to put ColdFire? support in
the …
4.104.114.84.95
@97d7b068
09/21/98 00:40:18 |
Joel Sherrill |
Update from Aleksey (Quality Quorum <qqi@…>) to pick up …
4.104.114.84.95
@75e44fa3
09/21/98 00:39:47 |
Joel Sherrill |
Removed by patch from Aleksey.
4.104.114.84.95
@3f929757
09/21/98 00:38:13 |
Joel Sherrill |
Patches from Aleksey which were not in 980911.
I am sending you …
4.104.114.84.95
@c610a1f3
09/21/98 00:24:51 |
Joel Sherrill |
Update from Eric Valette <valette@…>:
Here are patches …
4.104.114.84.95
@04bc5d9
09/21/98 00:23:02 |
Joel Sherrill |
Update from Erik Ivanenko <erik.ivanenko@…> to bring the …
4.104.114.84.95
@30ba752
09/21/98 00:01:26 |
Joel Sherrill |
Patch from Eric Norum:
I fixed the problems noted by Victor …
4.104.114.84.95
@6bd0fe4
09/20/98 23:52:43 |
Joel Sherrill |
Patch from Eric Valette <valette@…>:
Compiled and booted …
4.104.114.84.95
@6c455f37
09/16/98 15:15:41 |
warm38 |
Remove many of the shall verbs and replaced them with present tense verbs
4.104.114.84.95
@433c5585
09/13/98 13:44:28 |
warm38 |
Changes the name of readdir, umask, mkdir, chmod, chown to …
4.104.114.84.95
@08142b48
09/12/98 15:57:18 |
warm38 |
Documented the following routines added to the Configuration Space …
4.104.114.84.95
@bfcf4cb3
09/11/98 23:35:09 |
Joel Sherrill |
Updates to tree to make it build with all desired changes and the …
4.104.114.84.95
@23f014a
09/11/98 19:21:41 |
warm38 |
Added documentation for the log_facilityisvalid routine and add thew …
4.104.114.84.95
@b29378e
09/11/98 19:17:49 |
Joel Sherrill |
Corrected spelling error.
4.104.114.84.95
@c5bb1e02
09/11/98 15:40:41 |
Joel Sherrill |
changed version to 980911
4.104.114.84.95
@b3956369
09/11/98 13:12:04 |
Joel Sherrill |
Patch from "David J. Fiddes" <D.J@…>:
I've fixed …
4.104.114.84.95
@0ea9829
09/10/98 13:07:31 |
Joel Sherrill |
Fixed back so it would build.
4.104.114.84.95
@d2b1204
09/10/98 13:07:20 |
Joel Sherrill |
Added references.
4.104.114.84.95
@bd3dec5
09/10/98 12:46:41 |
Joel Sherrill |
If you're getting …
4.104.114.84.95
@23cdd84c
09/10/98 12:43:00 |
Joel Sherrill |
Patch from David Fiddes <D.J.Fiddes@…> to make this compile
for …
4.104.114.84.95
@b67245d0
09/10/98 12:31:27 |
Joel Sherrill |
Patch from Chris Johns <ccj@…>:
I have managed to build the …
4.104.114.84.95
@b7e3949
09/10/98 12:28:59 |
Joel Sherrill |
Patch from Eric Valette <valette@…>. Most of this was …
4.104.114.84.95
@109b17f4
09/10/98 12:23:08 |
Joel Sherrill |
Patch from Eric Norum <eric@…> to fix a cryptic error …
4.104.114.84.95
@eff217e
09/10/98 12:16:39 |
Joel Sherrill |
Patch from Emmanuel Raguet <raguet@…>:
After some good …
4.104.114.84.95
@c7cb6bbb
09/09/98 18:09:23 |
Joel Sherrill |
Added section on format of the configuration space file.
4.104.114.84.95
@c247120a
09/09/98 18:09:02 |
Joel Sherrill |
Added gettimeofday().
4.104.114.84.95
@8d0ea20
09/08/98 15:19:21 |
Joel Sherrill |
New file
4.104.114.84.95
@62e508f
09/08/98 13:17:21 |
Joel Sherrill |
Removed chapter names from automatically generated node names.
4.104.114.84.95
@d778b4a
09/08/98 13:17:08 |
Joel Sherrill |
Fixed include file path.
4.104.114.84.95
@251f8b1
09/02/98 14:22:40 |
Jennifer.Averett |
Added text to describe System log, Non-system logs,facility, and severity.
4.104.114.84.95
@4cf89a8
08/31/98 23:09:17 |
Joel Sherrill |
Fixed spacing. More comments from Eric Norum need to be addressed.
4.104.114.84.95
@d9d75fc
08/31/98 23:06:50 |
Joel Sherrill |
I have reworked …
4.104.114.84.95
@b285860
08/31/98 23:03:45 |
Joel Sherrill |
Eric> NB : there …
4.104.114.84.95
@de9edc4
08/31/98 22:56:20 |
Joel Sherrill |
Here is a brief …
4.104.114.84.95
@85734b3
08/31/98 22:53:42 |
Joel Sherrill |
I think I figured …
4.104.114.84.95
@90c60f7
08/31/98 15:39:03 |
warm38 |
Updated the descriptions section for the log_create and log_sys_create …
4.104.114.84.95
@82db2d3a
08/28/98 19:59:44 |
Joel Sherrill |
Reviewed log_read().
4.104.114.84.95
@566669f5
08/28/98 16:48:45 |
Joel Sherrill |
Reviewed and corrected log_write(), log_write_any(), and log_write_entry().
4.104.114.84.95
@b67f7946
08/28/98 14:32:01 |
Joel Sherrill |
Added log_write_any and part of log_copy.
Reviewed log_close.
4.104.114.84.95
@61b1b37c
08/28/98 13:31:40 |
Joel Sherrill |
Added author credit.
4.104.114.84.95
@f96e8ee
08/28/98 13:27:36 |
Joel Sherrill |
Added CVS Ids.
4.104.114.84.95
@e061a007
08/28/98 13:27:05 |
Joel Sherrill |
Added top level file and cleaned up chapter names
4.104.114.84.95
@6968c9e
08/28/98 13:26:25 |
Joel Sherrill |
Undid renaming.
4.104.114.84.95
@0918cc4
08/28/98 13:25:22 |
Joel Sherrill |
Renamed intro to preface.
4.104.114.84.95
@07b3693f
08/28/98 13:21:53 |
Joel Sherrill |
Base files
4.104.114.84.95
@a44a927
08/28/98 13:09:54 |
Joel Sherrill |
New file
4.104.114.84.95
@af5a571
08/27/98 20:53:21 |
Joel Sherrill |
Updated log_seek() per review.
4.104.114.84.95
@6520befe
08/27/98 20:16:39 |
Joel Sherrill |
Modified log_open() to reflect review.
4.104.114.84.95
@d65d22a0
08/27/98 18:53:34 |
Joel Sherrill |
Corrected descriptions of log facility set manipulation routines as …
4.104.114.84.95
@c5568160
08/27/98 18:28:17 |
Joel Sherrill |
Corrected log_severity_before as part of reviewing the code.
4.104.114.84.95
@9c79229
08/26/98 14:18:36 |
warm38 |
Incorporated the "#include <dump.h>" statement in file.
4.104.114.84.95
@3e6eb1dd
08/26/98 14:13:48 |
warm38 |
Incorporated the "#include cfg.h" statement in document
4.104.114.84.95
@984e5c1d
08/26/98 14:11:48 |
warm38 |
Incorporated the "#include <admin.h>" statement in file
4.104.114.84.95
@30cc2e0
08/26/98 14:08:20 |
warm38 |
Corrected mispelled words.
4.104.114.84.95
@571a915
08/25/98 22:09:13 |
Joel Sherrill |
Added some background and operations subsections.
4.104.114.84.95
@a99ea16
08/25/98 21:02:58 |
Joel Sherrill |
Fixed spelling mistakes.
4.104.114.84.95
@142f6a5
08/25/98 20:56:43 |
Joel Sherrill |
Fixed spelling mistake.
4.104.114.84.95
@d1a859c
08/25/98 20:54:47 |
Joel Sherrill |
Cleaned up formatting.
Added notes on background and operations …
4.104.114.84.95
@d5ef5bd1
08/25/98 19:49:51 |
Joel Sherrill |
Commit for review
4.104.114.84.95
@2a23c28
08/25/98 15:26:19 |
warm38 |
Documented the log_create and log_sys_create routines
4.104.114.84.95
@fd001d6
08/24/98 17:38:00 |
Joel Sherrill |
Posix users manual now makes multiple info files.
4.104.114.84.95
@7559232
08/24/98 17:32:58 |
Joel Sherrill |
changed version to 980824
4.104.114.84.95
@564d2c3a
08/24/98 16:59:20 |
Joel Sherrill |
Patch from Eric Valette <valette@…> to add an extra newline.
4.104.114.84.95
@69036586
08/24/98 16:58:39 |
Joel Sherrill |
Celso Labinaz …
4.104.114.84.95
@16f2037
08/24/98 14:50:23 |
Joel Sherrill |
Regenerated
4.104.114.84.95
@ff0b008
08/24/98 14:50:00 |
Joel Sherrill |
Added RTEMS_INSIDE macro to insure that ".inl" files are ALWAYS …
4.104.114.84.95
@9a95524f
08/24/98 14:47:19 |
Joel Sherrill |
Cleanup patch from Eric Norum.
4.104.114.84.95
@dffa304
08/24/98 14:44:54 |
Joel Sherrill |
Patch from Ralf Corsepius <corsepiu@…>:
The patch …
4.104.114.84.95
@4baa0f5
08/21/98 18:19:29 |
Joel Sherrill |
changed version to 980821
4.104.114.84.95
@4de817d
08/21/98 18:14:27 |
Joel Sherrill |
Added i386 specific version of in_cksum.c and restructured the main …
4.104.114.84.95
@cce81a7
08/21/98 17:43:22 |
Joel Sherrill |
A patch from Ralf Corsepius <corsepiu@…>:
Here is …
4.104.114.84.95
@aa2171b
08/21/98 17:42:25 |
Joel Sherrill |
Modified version number to recut snapshot.
4.104.114.84.95
@617a1a2d
08/21/98 17:37:01 |
Joel Sherrill |
Another missing piece. Thanks Eric.
4.104.114.84.95
