@0d018268
07/05/13 13:18:24 |
Sebastian Huber |
psxtests/psxcleanup: Fix cleanup push/pop test
The …
4.115
@5e2a66d
07/05/13 12:53:57 |
Sebastian Huber |
psxtests/psxhdrs: Fix cleanup push/pop test
The …
4.115
@6009da1
07/05/13 12:56:23 |
Sebastian Huber |
posix: Add comment
4.115
@818edbd
07/02/13 13:16:33 |
Sebastian Huber |
bsp/mpc55xx: Update due to API changes
Termios notifies now the …
4.115
@d91d50f
07/02/13 13:14:51 |
Sebastian Huber |
bsp/mpc55xx: Avoid integer overflow
4.115
@c97d3dd
07/02/13 13:13:54 |
Sebastian Huber |
bsp/mpc55xx: Round PLL divider up
4.115
@cd7db89
06/24/13 15:14:08 |
ralf.kirchner |
bsp/psim: Use EABI and System V small-data area
4.115
@3da02169
06/24/13 15:16:16 |
ralf.kirchner |
bsps/powerpc: Avoid placement in small-data area
4.115
@1b47871d
06/24/13 15:15:42 |
ralf.kirchner |
bsp/psim: Fix declaration
It declares a symbol defined in the linker …
4.115
@3b645c1
06/28/13 19:26:59 |
Sebastian Huber |
bsps/arm: Add PL050 support
4.115
@c8312b3
06/23/13 12:39:47 |
Sebastian Huber |
bsps/arm: Add PL111 support
4.115
@e310dcd
06/28/13 19:26:11 |
Sebastian Huber |
libchip/serial: Add const qualifier
4.115
@a4006fee
06/28/13 19:25:30 |
Sebastian Huber |
mouse: Include missing header file
4.115
@311ba73
06/23/13 15:50:55 |
Sebastian Huber |
framebuffer: Add and use FRAMEBUFFER_DEVICE_0_NAME
4.115
@98db96e
06/29/13 12:00:39 |
Sebastian Huber |
make: Use C flags for C++ as default
In case a BSP selects special …
4.115
@40ce265
06/28/13 13:05:30 |
Sebastian Huber |
bsp/psim: Use plain symbol for PSIM
This avoids a linker assertion …
4.115
@4800ffe
06/28/13 07:07:13 |
Sebastian Huber |
bsps/powerpc: Update debug sections
4.115
@ca59217
06/28/13 07:03:11 |
Sebastian Huber |
bsps/arm: Set vector base on all processors
4.115
@a3a4cd5
06/26/13 07:40:44 |
Sebastian Huber |
bsps/arm: Move input sections
Move input sections to preserve order …
4.115
@56435e6
06/26/13 08:25:42 |
Sebastian Huber |
powerpc: Fix Altivec support
Use the right context.
4.115
@4b83e8f1
06/21/13 07:59:27 |
Sebastian Huber |
bsps/arm: Fix set exception handler for ARMv7
4.115
@b4062c3f
06/25/13 09:15:18 |
Sebastian Huber |
tmtests/tm20: Change allocation sizes
This avoids problems with …
4.115
@22c7a64
06/25/13 10:22:23 |
Sebastian Huber |
psxtests/psxkey02: Simplify
This avoids problems with debugging enabled.
4.115
@d79973d
06/25/13 09:13:15 |
Sebastian Huber |
sptests/spwkspace: Reserve space for duplicates
4.115
@8ebc680
06/24/13 11:44:51 |
Sebastian Huber |
sptests/spmountmgr01: Simplify
This avoids problems with debugging …
4.115
@b9acb4e
06/25/13 12:03:51 |
Sebastian Huber |
sptests/sp64: Simplify
4.115
@83889708
06/25/13 12:32:44 |
Sebastian Huber |
sptests/sp62: Rework to avoid heap internals
This avoids problems …
4.115
@7c1fcff3
06/25/13 12:59:45 |
Sebastian Huber |
sptests/sp59: Change allocation size
4.115
@9f37fb1
06/25/13 10:16:13 |
Sebastian Huber |
sptests/sp18: Simplify
4.115
@b64e8dc0
06/25/13 14:57:38 |
Sebastian Huber |
sptests/sp16: Change allocation sizes
4.115
@3948a0b
06/25/13 09:14:17 |
Sebastian Huber |
sptests/sp09: Change allocation sizes
4.115
@d0d357ed
06/25/13 10:09:50 |
Sebastian Huber |
heap: Add _Heap_Greedy_allocate_all_except_largest
Add …
4.115
@c497657
06/25/13 12:31:47 |
Sebastian Huber |
heap: Free all delayed blocks during resize
4.115
@cc0cb7c
06/25/13 09:11:40 |
Sebastian Huber |
heap: Free all delayed blocks during extend
4.115
@1d48e25d
06/24/13 14:48:17 |
Sebastian Huber |
heap: Workaround for workspace protection
4.115
@e18db9f
06/24/13 15:29:11 |
Sebastian Huber |
termios: Update due to API changes
Termios notifies now the driver …
4.115
@1df348b
06/24/13 09:00:36 |
Sebastian Huber |
bsps/arm: Rename function
Rename …
4.115
@e916b125
06/21/13 15:17:28 |
Sebastian Huber |
bsp/virtex: Use shared clock driver
4.115
@0110491
06/20/13 14:22:16 |
Sebastian Huber |
bsp/virtex: Add console devices only if present
4.115
@dbf62b3
06/20/13 14:20:43 |
Sebastian Huber |
bsp/virtex: Fix warnings
4.115
@c4cfc62
06/20/13 12:33:19 |
Sebastian Huber |
bsp/virtex: Use XPAR_INTC_SINGLE_BASEADDR
This define is also present …
4.115
@dfb5805
06/20/13 12:32:12 |
Sebastian Huber |
bsp/virtex: Remove unused configure macros
4.115
@53dc697
06/18/13 14:42:25 |
Sebastian Huber |
bsp/virtex: Delete BSP_ask_for_reset and BSP_panic
4.115
@39c1534f
06/18/13 15:20:28 |
Sebastian Huber |
bsp/virtex: Use generic interrupt support
4.115
@894e93f
06/18/13 14:44:40 |
Sebastian Huber |
bsp/virtex: Fix header includes
4.115
@bee7612e
06/18/13 14:39:24 |
Sebastian Huber |
bsp/virtex: Move timer config to new file
4.115
@48ab8465
06/18/13 14:27:42 |
Sebastian Huber |
bsp/virtex: Do not use PPC403 TTY driver
4.115
@ad094f4
06/18/13 14:26:25 |
Sebastian Huber |
4.115
@b45397fb
06/18/13 14:25:53 |
Sebastian Huber |
bsp/virtex: Delete bsp_XAssertHandler()
4.115
@ff538bbf
06/18/13 14:24:10 |
Sebastian Huber |
bsp/virtex: Delete unused variables
4.115
@0ba2736
06/18/13 14:12:56 |
Sebastian Huber |
bsp/virtex: Replace low-level BSP start code
Use linkcmds.base. Use …
4.115
@546c1056
06/18/13 13:19:19 |
Sebastian Huber |
bsp/virtex: Rename file dlentry.S in start.S
Use default bsp_specs file.
4.115
@509e0f3f
06/21/13 15:16:37 |
Sebastian Huber |
bsps/powerpc: Add PPC405 support for shared clock
4.115
@7d0e88f2
06/21/13 14:19:46 |
Sebastian Huber |
bsps/powerpc: Delete clock_4xx.c
4.115
@27b207a8
06/21/13 13:10:48 |
Sebastian Huber |
bsps: Delete bspreset_fatal.c
Use bspreset_loop.c instead. This …
4.115
@1ebffa89
06/21/13 07:18:01 |
Chris Johns |
arm: Fix default exception prologues
4.115
@4f1da72
06/21/13 07:16:19 |
Sebastian Huber |
score: _Heap_Protection_free_all_delayed_blocks()
Add and use …
4.115
@9165a5b0
06/18/13 12:14:43 |
Sebastian Huber |
IMFS: Fix reference count for debug enabled
4.115
@f97f46ce
06/20/13 09:03:45 |
Sebastian Huber |
libchip/serial: Fix warning
4.115
@c9db7f9
06/18/13 15:47:41 |
Sebastian Huber |
bsps: Use CONSOLE_DEVICE_NAME
4.115
@a4bc725e
06/18/13 15:45:50 |
Sebastian Huber |
bsps: Remove debug output in shared console driver
4.115
@37220fac
06/20/13 10:00:29 |
Sebastian Huber |
bsps: Do not use printk() in shared console driver
4.115
@6307b1a
06/20/13 09:57:34 |
Sebastian Huber |
bsps: Add fatal errors for shared console driver
4.115
@ade27c6
06/20/13 09:44:04 |
Sebastian Huber |
bsps: Move bsp_generic_fatal_code to new file
Add bsp_generic_fatal().
4.115
@5f91272
06/20/13 09:17:23 |
Sebastian Huber |
bsps/powerpc: Delete bsp_exceptions_in_RAM
Delete …
4.115
@6520aef1
06/20/13 15:52:16 |
Joel Sherrill |
sparc in_cksum: Use sparc which is available in -ansi mode
4.115
@cddb8f4
06/20/13 07:48:27 |
Ric Claus |
bsps/arm: Fix some GIC functions
4.115
@9a037da9
06/19/13 09:20:06 |
Sebastian Huber |
bsps/arm: Set vector base address if necessary
4.115
@45fecbb6
06/16/13 13:40:03 |
Jiri Gaisler |
greth: do not advertise 1000M capability if MAC does not support it.
4.115
@1bdc6d1
06/16/13 13:28:20 |
Jiri Gaisler |
greth: prefer full duplex if available
4.115
@1f4ee30
06/15/13 22:13:41 |
Jiri Gaisler |
Added in_cksum_sparc.h to optimize IP checksum calculations for SPARC.
4.115
@cb6b9ba
06/19/13 10:57:54 |
Sebastian Huber |
bsp/xilinx-zynq: Use magic UART baud divisor
Use a baud divisor …
4.115
@3f6a823
06/19/13 10:57:26 |
Sebastian Huber |
bsp/xilinx-zynq: Do not start transmitter break
4.115
@67f89f2
06/18/13 11:37:16 |
Ralf Corsepius |
Update from automake-1.13.3.
4.115
@49bc9f81
06/18/13 07:18:21 |
Sebastian Huber |
bsp/xilinx-zynq: Use second UART for console
This is in now line with …
4.115
@010e4058
06/17/13 08:21:48 |
Sebastian Huber |
smptests/smpschedule01: Update due to API change
4.115
@c4a236a
06/17/13 08:12:26 |
Sebastian Huber |
Revert "sptests/sp02: Fix maximum task count"
This reverts commit …
4.115
@cf46db85
06/17/13 07:57:42 |
Sebastian Huber |
bsps: Provide simple console selection
4.115
@9f868a16
06/17/13 07:57:08 |
Sebastian Huber |
bsps: Add missing include
4.115
@961669d
06/14/13 13:30:37 |
Sebastian Huber |
documentation: Fix Doxygen comments
4.115
@8b222be
06/11/13 08:00:25 |
Sebastian Huber |
smptests/smpschedule01: New test
4.115
@a936aa49
06/06/13 13:41:00 |
Sebastian Huber |
scheduler: New simple SMP scheduler implementation
The new Simple SMP …
4.115
@8f420927
06/12/13 09:39:49 |
Sebastian Huber |
scheduler: Simplify simple scheduler
Add and use …
4.115
@a344308
06/06/13 13:32:22 |
Sebastian Huber |
scheduler: Add and use _Scheduler_default_Tick()
Delete …
4.115
@6eba7c85
06/10/13 14:15:46 |
Sebastian Huber |
scheduler: Specify thread of yield operation
The yielding thread of …
4.115
@1ccb64e1
06/06/13 13:28:41 |
Sebastian Huber |
scheduler: Add start idle thread operation
Add and use …
4.115
@477259c
06/12/13 15:06:51 |
Sebastian Huber |
score: Simplify _Thread_Create_idle()
4.115
@edde99b
06/14/13 12:26:34 |
Sebastian Huber |
score: Rename rtems_smp_get_number_of_processors()
Rename in …
4.115
@5c78940d
06/12/13 08:08:58 |
Sebastian Huber |
score: Add and use _Thread_Dispatch_if_necessary()
Delete …
4.115
@49cdf40
06/12/13 07:25:39 |
Sebastian Huber |
score: Add and use _Thread_Dispatch_is_enabled()
Delete …
4.115
@ec978d9
06/12/13 09:29:12 |
Sebastian Huber |
score: Add _Chain_Insert_ordered_unprotected()
4.115
@7a34ca37
06/11/13 15:09:02 |
Sebastian Huber |
rtems: Simplify rtems_task_mode()
4.115
@6f8adb0
06/14/13 11:04:43 |
Sebastian Huber |
4.115
@873859a4
06/09/13 02:13:00 |
cynt6007 |
Make the default values easier for the configuration GUI to parse
4.115
@aabfcd0
06/12/13 13:11:57 |
Sebastian Huber |
smp: Fix _Thread_Dispatch_decrement_disable_level
We must obtain the …
4.115
@df244cfc
06/12/13 07:16:30 |
Sebastian Huber |
smp: Protect decrement operation
4.115
@a8ef3bf0
06/11/13 07:29:45 |
Sebastian Huber |
smp: Add and use _Per_CPU_Lock_acquire()
Add and use …
4.115
@f70526a7
06/11/13 07:26:30 |
Sebastian Huber |
score: Avoid cyclic include dependency
4.115
@1270440
06/11/13 07:23:35 |
Sebastian Huber |
score: Add missing include
4.115
@15f3a91
06/10/13 12:11:07 |
Sebastian Huber |
libchip: Use Termios API change for NS16550
This avoids a race …
4.115
