@fe283f6c
09/14/18 11:20:05 |
Sebastian Huber |
powerpc: Fix _CPU_Counter_read() for MPC860
The mpc860 is a …
5
@aaa6653
09/13/18 09:33:11 |
Sebastian Huber |
score: Fix PER_CPU_DATA_ITEM_DECLARE()
Fix …
5
@1fe1b820
09/10/18 09:47:24 |
Sebastian Huber |
score: Fix PER_CPU_DATA_GET_BY_OFFSET()
Add uniprocessor version for …
5
@e58f1cd3
09/05/18 05:27:24 |
Sebastian Huber |
Add more dummy values to <sys/priority.h>
Update #3472.
5
@7097962
08/29/18 07:43:44 |
Sebastian Huber |
score: Add thread pin/unpin support
Add support to temporarily pin a …
5
@d8bc0730
09/07/18 09:27:45 |
Sebastian Huber |
score: Modify _Scheduler_Unblock()
In SMP configurations, obtain the …
5
@cfc4231d
08/27/18 08:36:35 |
Sebastian Huber |
score: Add flexible per-CPU data
Update #3507.
5
@77d374f5
09/07/18 05:12:06 |
Sebastian Huber |
cpukit/Makefile.am: Cleanup
5
@cb68253
09/07/18 04:19:02 |
Sebastian Huber |
network: Use kernel/user space header files
Add and use …
5
@43fb904e
09/07/18 05:06:05 |
Sebastian Huber |
network: Remove man page installation
The man page installation is …
5
@eae4d147
09/07/18 04:24:00 |
Sebastian Huber |
network: Remove unused files
5
@d9296d24
09/07/18 04:39:50 |
Sebastian Huber |
Move <poll.h> to set of default header files
The <poll.h> is a POSIX …
5
@ea0a680
09/10/18 08:36:41 |
Sebastian Huber |
score: Debug aid for _Chain_Extract_unprotected()
Ensure that a chain …
5
@2d1c3dff
09/07/18 05:33:47 |
Sebastian Huber |
nfsclient: Fix unused variable warning
5
@0e907232
09/06/18 05:01:48 |
Sebastian Huber |
sptests/spconfig01: New test
Close #3435.
5
@2f61eb21
09/06/18 05:03:49 |
Sebastian Huber |
bsp/qoriq: Add struct qoriq to allow forward decls
5
@54d87f2
09/04/18 16:28:57 |
Sebastian Huber |
bsps/powerpc: Simplify ppc_exc_initialize()
Remove parameters from …
5
@9a21fc7
09/05/18 05:38:13 |
Sebastian Huber |
bsp/mpc55xxevb: Fix format warning
Close #3504.
5
@ccdce9d8
09/05/18 05:31:23 |
Sebastian Huber |
libchip/ata: Fix ATA_DRIVER_TABLE_ENTRY
Drop unused and deprecated …
5
@e0a9336b
09/03/18 06:12:35 |
Sebastian Huber |
score: Fix EDF SMP scheduler
Fix a special case: block a one-to-one …
5
@3aad9d9b
09/03/18 07:31:19 |
Sebastian Huber |
score: Generalize SMP scheduler block support
Add extract from …
5
@fad3f79b
08/31/18 05:44:53 |
Sebastian Huber |
bsps: BSP_INTERRUPT_STACK_AT_WORK_AREA_BEGIN
Remove the …
5
@7b1a711
08/29/18 23:02:09 |
joel |
bootstrap: Correct help message
closes #3509.
5
@66e78854
08/29/18 17:51:50 |
joel |
Remove bsps/sparc64/shared/helenos/boot/generic/string.c
5
@9b5b864
08/29/18 17:42:10 |
joel |
rtems/score/epiphany-utility.h: Fix not a prototype warning
5
@bc696482
08/29/18 17:41:35 |
joel |
score/cpu/bfin/cpu.c: Fix _CPU_Thread_Idle_body() prototype
5
@5da1593
08/29/18 17:39:17 |
joel |
psim/include/tm27.h: Fix not a prototype warnings
5
@a8d3f10
08/29/18 17:39:01 |
joel |
mvme5500/include/tm27.h: Fix not a prototype warnings
5
@a5c3bfb
08/29/18 17:37:29 |
joel |
uC5282/clock/clock.c: Correct bsp_idle_thread() prototype
5
@34e959fa
08/29/18 17:36:50 |
joel |
gen68340/include/m340timer.h: Fix not a prototype warnings
5
@76ac42ff
08/29/18 17:36:18 |
joel |
lpc32xx/include/bsp.h: Resolve set but not used warning
5
@350b07a0
08/29/18 17:34:58 |
joel |
monlib.[ch]: Fix warnings for external vs internal use of .h
5
@60702ab
08/22/18 16:58:12 |
joel |
qoriq/include/tm27.h: Fix warnings
5
@126a454
08/22/18 16:57:57 |
joel |
gen5200/include/tm27.h: Fix warnings
5
@c80f5afc
08/22/18 16:50:19 |
joel |
mpc55xxevb/clock/clock-config.c: Remove unused mpc55xx_clock_cleanup() …
5
@76b3f8c
08/22/18 14:30:44 |
joel |
gen5200/include/bsp/bestcomm.h: Fix unused variable warning
5
@bb6eeabf
08/21/18 15:35:26 |
joel |
bsps/i386/shared/cache/cache.c: Fix warnings
5
@c2e8ed6
08/21/18 15:35:16 |
joel |
gdbarmsim/include/bsp.h: Fix warnings
5
@14a218f
08/21/18 15:32:48 |
joel |
cpukit/telnetd/pty.c: Fix format overflow warning on sprintf()
5
@cba349c
08/17/18 18:30:19 |
joel |
bsps/m68k/shared/cache/cache.h: Fix warnings and clean up
5
@9e8bba5
08/29/18 05:53:02 |
Sebastian Huber |
score: Remove redundant #ifdef RTEMS_SMP
5
@a6fca76
08/29/18 05:46:31 |
Sebastian Huber |
bsp/qoriq: Remove README
Update #2854.
5
@6d70a11
08/27/18 05:33:29 |
Sebastian Huber |
Include <stdbool.h> in <machine/_kernel_types.h>
The FreeBSD kernel …
5
@27c89d7
08/08/18 09:52:09 |
Sebastian Huber |
Add FreeBSD kernel space header files
Move the kernel space content …
5
@97d2c44
06/29/18 12:24:58 |
Daniel Hellstrom |
spglobalcon01: LLVM optimization makes variable i always 1
Declare i …
5
@655108e4
06/28/18 12:43:38 |
Daniel Hellstrom |
psxfile01: floating point context required when calling fprintf
This …
5
@26c3f9f
06/28/18 12:42:11 |
Daniel Hellstrom |
psx13: floating point context required when calling fprintf
This …
5
@0d51b6d8
06/28/18 12:39:37 |
Daniel Hellstrom |
capture: prevent unaligned access when reading time
LLVM warns about …
5
@408fad3
06/20/18 07:23:31 |
Daniel Hellstrom |
leon,grspw_pkt: remove incorrect comment on SMP not being tested
To …
5
@aea3134e
06/15/18 06:49:31 |
Daniel Hellstrom |
leon,apbuart: replace termios c_cflag & CBAUD with c_{i,o}speed
ince …
5
@243ddb52
06/15/18 12:28:36 |
Daniel Hellstrom |
leon,greth: enable MAC filtering (promiscous mode, multicast)
It …
5
@2fbe2ef3
02/13/18 06:47:14 |
Daniel Hellstrom |
leon, greth: 10/100 MAC enable TX BD interrupt
Missed to enable …
5
@a87964d
08/23/18 09:13:44 |
Daniel Hellstrom |
sparc,smp: typo in start.S causing SMP not working
5
@59a0541c
07/12/18 07:15:55 |
cederman |
sparc: Restore npc when returning from the syscall_lazy_fp_switch trap …
5
@6695d02
08/23/18 12:39:33 |
Sebastian Huber |
Update FreeBSD kernel timespec support
This change is based on the …
5
@ba0e9631
08/10/18 05:34:03 |
Sebastian Huber |
score: Do not inline _Thread_Dispatch_enable()
This function is …
5
@a36aa86
08/23/18 12:32:07 |
Sebastian Huber |
Add dummy PI_SOFT to <sys/priority.h>
Update #3472.
5
@d14f934
08/10/18 05:22:43 |
Sebastian Huber |
score: Fix ISR enable in _Thread_Dispatch_enable()
This bug had …
5
@2cd3716
08/20/18 06:35:26 |
Sebastian Huber |
bsps/arm: Fix PL111 register define re-definition
Close #3502.
5
@dcaea71
08/15/18 10:26:13 |
christian.mauderer |
dev/sc16is752: Add name space for field names.
The field names for …
5
@da8b12bc
08/15/18 14:48:28 |
joel |
dl06/dl06-o1.c: Remove set, not used warning
5
@adbd7e7
08/15/18 14:47:53 |
joel |
fsdosfssync01/init.c: Remove unused variable
5
@bc731313
08/13/18 10:55:34 |
amaan.cheval |
bsps/x86_64: Add APIC timer based clock driver
The APIC timer is …
5
@6869321
08/13/18 10:50:38 |
amaan.cheval |
bsps/x86_64: Add support for RTEMS interrupts
Updates #2898.
5
@4544749e
08/13/18 10:33:12 |
amaan.cheval |
bsps/x86_64: Add paging support with 1GiB super pages
Updates #2898.
5
@6eccd0c
08/13/18 10:25:51 |
amaan.cheval |
bsps/x86_64: Reduce default RamSize? to 1GiB
Simulators may not always …
5
@ab971bf5
08/13/18 10:21:47 |
amaan.cheval |
bsps/x86_64: Reorganize header files and compile-options
Updates #2898.
5
@382d653
08/10/18 13:23:01 |
joel |
libtests/POSIX: Fix warnings and style.
5
@b3693f5
08/10/18 13:22:49 |
joel |
bsps/sparc/include/bsp/gradcdac.h: Fix nested comment warning
5
@d071d9a
08/10/18 13:22:02 |
joel |
qoriq/include/tm27.h: Fix prototype warning
5
@ebd1937
08/10/18 13:21:36 |
joel |
motorola_powerpc/include/tm27.h: Fix prototype warning
5
@3cff531f
08/10/18 13:21:09 |
joel |
bsps/powerpc/include/mpc83xx/mpc83xx.h: Fix nested comment warning
5
@5896da4
08/10/18 13:20:38 |
joel |
bsps/powerpc/include/bsp/tictac.h: Fix protototype warnings
5
@ae4fbf3b
08/10/18 13:20:07 |
joel |
gen83xx/include/tm27.h: Fix prototype warning
5
@ec8c955d
08/10/18 13:19:40 |
joel |
gen5200/include/tm27.h: Fix prototype warning
5
@7de51829
08/10/18 13:18:59 |
joel |
gen5200/include/bsp/ata.h: Fix warning
5
@0fc87d47
08/10/18 13:18:40 |
joel |
csb337/include/at91rm9200_dbgu.h: Fix nested comment warning
5
@b2de426
08/06/18 09:53:42 |
Sebastian Huber |
score: Fix _Addresses_Subtract()
Use architecture-specific integer …
5
@66cb142
08/06/18 08:51:00 |
Sebastian Huber |
rtems: Parameter types in rtems_partition_create()
Use uintptr_t to …
5
@b8eae140
08/10/18 05:11:56 |
Sebastian Huber |
Add dummy PRI_MIN_KERN to <sys/priority.h>
Update #3472.
5
@0e6f7dc4
08/10/18 05:10:20 |
Sebastian Huber |
bsps/sparc: Fix external variable declarations
5
@f4424cfb
08/09/18 07:20:33 |
Sebastian Huber |
bsps/sparc: Move polled APBUART functions
This reduces the link-time …
5
@aac36d15
08/08/18 09:17:36 |
Sebastian Huber |
posix: Add configure check for mprotect()
Update #3491.
5
@8e6cfcc
08/06/18 08:29:14 |
bsp/atsam: Fix handling of slow SPI speeds.
This patch fixes an …
5
@71948f76
08/08/18 05:52:18 |
Sebastian Huber |
sys/event.h: Update version FreeBSD tag
Update #3472.
5
@ac824ff
07/18/18 13:04:03 |
dab |
Make the definition of struct kevent in event.h match what the man …
5
@96b32773
07/11/18 02:09:11 |
dab |
Address some (although not all) style(9) issues in event.h after …
5
@1d00acb1
06/28/18 20:37:17 |
dab |
Fix compilation error in r335765 under gcc 4.2.1.
The anonymous …
5
@b37ef68
06/28/18 17:01:04 |
dab |
Remove potential identifier conflict in the EV_SET macro.
PR43905 …
5
@bf026dd4
11/27/17 15:01:59 |
pfg |
sys/sys: further adoption of SPDX licensing ID tags.
Mainly focus on …
5
@57c03363
11/25/17 04:49:12 |
jhb |
Decode kevent structures logged via ktrace(2) in kdump.
- Add a new …
5
@e9b708a
06/17/17 00:57:26 |
kib |
Add abstime kqueue(2) timers and expand struct kevent members.
This …
5
@f51aec8
04/08/17 04:34:18 |
pkelsey |
Fix typo.
hist -> hint
MFC after: 3 days
5
@fd27bae
08/07/18 04:25:47 |
Sebastian Huber |
CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE
Make …
5
@97417bb
08/07/18 05:09:55 |
Sebastian Huber |
tests: Remove CONFIGURE_MAXIMUM_DRIVERS
This configuration is …
5
@0b038bd4
08/04/18 08:38:48 |
Sebastian Huber |
libblock: Add RTEMS_DEPRECATED
Close #3358.
5
@b152d33
08/06/18 04:26:50 |
Sebastian Huber |
fileio: Avoid deprecated rtems_disk_obtain()
Update #3358.
5
@ab96aec
08/04/18 08:56:46 |
Sebastian Huber |
dosfs: Avoid deprecated routine
Update #3358.
5
@dd66fda
08/04/18 08:47:56 |
Sebastian Huber |
tests: Avoid deprecated rtems_disk_io_initialize()
Update #3358.
5
@1836c6a
08/04/18 08:45:19 |
Sebastian Huber |
bsp/gen5200: Avoid deprecated routine
Update #3358.
5
