@fb94e65
03/27/98 20:50:31 |
Joel Sherrill |
Added dependency so html would build from scratch.
4.104.114.84.95
@0a702cfb
03/27/98 20:50:14 |
Joel Sherrill |
Corrected by adding "end markers".
4.104.114.84.95
@a30359bb
03/27/98 19:42:58 |
Joel Sherrill |
Changed int to unsigned32 to match cpu.h.
4.104.114.84.95
@20515fc
03/27/98 18:53:17 |
Joel Sherrill |
Nodes, menus, etc are automatically generated now
4.104.114.84.95
@1f020c6
03/27/98 17:34:25 |
Joel Sherrill |
Renamed extra_manuals to oar_manuals.
4.104.114.84.95
@9809ab1e
03/27/98 17:30:42 |
Joel Sherrill |
Removed ruler line since it is automatically inserted now along with …
4.104.114.84.95
@e8f7f83
03/27/98 16:49:23 |
Joel Sherrill |
Localized for use in doc tree.
4.104.114.84.95
@b753a345
03/27/98 16:48:50 |
Joel Sherrill |
Added directive and constant prefixes.
4.104.114.84.95
@75e22db
03/27/98 16:47:53 |
Joel Sherrill |
Completed sweep adding directive and constant prefixes.
4.104.114.84.95
@3973e40
03/27/98 16:34:25 |
Joel Sherrill |
Should have included <rtems.h> before checking for ifdef RTEMS_UNIX. …
4.104.114.84.95
@f331481c
03/27/98 13:24:52 |
Joel Sherrill |
Conditionally adding RTEMS_ and rtems_ prefixes.
4.104.114.84.95
@4fa4ea65
03/27/98 13:24:21 |
Joel Sherrill |
Added Hitachi SH
4.104.114.84.95
@a3a7527
03/27/98 13:04:02 |
Joel Sherrill |
Attempting to add variable so that in C all constants start with …
4.104.114.84.95
@0ef0ff2
03/27/98 11:53:51 |
Joel Sherrill |
Added POSIX 1003.1h and PowerPC supplement to internal manuals.
4.104.114.84.95
@fad4de2b
03/26/98 20:47:42 |
Joel Sherrill |
New file. Basically m68k version with Hitachi SH comments thrown in.
4.104.114.84.95
@54fc6fe
03/26/98 20:44:35 |
Joel Sherrill |
The script did not handle public distributions at all.
4.104.114.84.95
@433a01b
03/26/98 20:40:34 |
Joel Sherrill |
Added support for easily building different sets of the manuals
for …
4.104.114.84.95
@7c8c767
03/26/98 20:34:38 |
Joel Sherrill |
Better handling of local documentation tools and corrected invocation …
4.104.114.84.95
@5a348d3
03/26/98 20:33:56 |
Joel Sherrill |
Updated for SH port and variable insertion of version.
4.104.114.84.95
@bc0307e
03/26/98 20:33:27 |
Joel Sherrill |
Added build of tools to build procedure.
Automatically insert version …
4.104.114.84.95
@c027242
03/26/98 20:32:41 |
Joel Sherrill |
rtems.html renamed index.html since that is what httpd looks for …
4.104.114.84.95
@090f1a4
03/26/98 20:31:13 |
Joel Sherrill |
Attempt at separating public, support, partners, and internal.
4.104.114.84.95
@8a8b7519
03/26/98 20:30:52 |
Joel Sherrill |
Added variables for dates and revision info
4.104.114.84.95
@9cb1040c
03/26/98 20:30:01 |
Joel Sherrill |
Enhanced.
4.104.114.84.95
@2e9dfd59
03/26/98 20:29:49 |
Joel Sherrill |
Installed in partners subdirectory
4.104.114.84.95
@b317e78c
03/26/98 20:29:08 |
Joel Sherrill |
removed @ifinfo around something needed for html structure
4.104.114.84.95
@e8b63db4
03/26/98 20:28:13 |
Joel Sherrill |
Do not copy headers, use make
4.104.114.84.95
@9ec289ca
03/26/98 17:16:53 |
Joel Sherrill |
More appropriate for public consumption
4.104.114.84.95
@3c7117d
03/26/98 17:15:03 |
Joel Sherrill |
Made more appropriate for public consumption.
4.104.114.84.95
@fb9a80f
03/26/98 17:10:03 |
Joel Sherrill |
renamed to user's guide.
4.104.114.84.95
@3cc03ac
03/26/98 12:39:49 |
Joel Sherrill |
HAS_CPLUSPLUS should have been RTEMS_HAS_CPLUSPLUS.
4.104.114.84.95
@5e0fbcc
03/25/98 19:02:37 |
Joel Sherrill |
Moved memcpy to newlib/libc/machine/m68k
4.104.114.84.95
@c80add4
03/25/98 18:46:47 |
Joel Sherrill |
m68k software interrupt stack support from Chris Johns and Eric Norum.
4.104.114.84.95
@059dbcf
03/25/98 18:36:19 |
Joel Sherrill |
Added group and example around tree pictures in html.
4.104.114.84.95
@c4e09029
03/25/98 14:14:46 |
Joel Sherrill |
Corrected argument passing.
4.104.114.84.95
@85047f02
03/25/98 14:00:41 |
Joel Sherrill |
Corrected definition of main and boot_card to be more ANSI compliant.
4.104.114.84.95
@0f26250
03/25/98 13:59:55 |
Joel Sherrill |
Corrected invocation of boot_card().
4.104.114.84.95
@ddf142d
03/24/98 20:53:48 |
Joel Sherrill |
Added _XOPEN_SOURCE definition to allow use of UNIX IPC.
4.104.114.84.95
@abbd5b1
03/24/98 19:14:47 |
Joel Sherrill |
changed version to 4.0.0-beta1
4.104.114.84.95
@e6c92eef
03/24/98 18:44:40 |
Joel Sherrill |
Changed RTEMS cpu to hppa1.1.
4.104.114.84.95
@526ebe8
03/24/98 18:44:25 |
Joel Sherrill |
Added rule to transform hppa1.1 to hppa1_1 since hppa1.1 is not a …
4.104.114.84.95
@bdac86b5
03/24/98 17:13:03 |
Joel Sherrill |
Real definition for the beginning of the data section per Eric Norum's …
4.104.114.84.95
@72b397a
03/24/98 17:10:44 |
Joel Sherrill |
Corrected register constraints per suggestion from Thomas Doerfler, …
4.104.114.84.95
@d662fef8
03/24/98 16:33:32 |
Joel Sherrill |
More cpu model flags converted to using cpp predefines.
4.104.114.84.95
@3ec7bfc
03/24/98 16:24:39 |
Joel Sherrill |
Rename hppa1_1 to hppa1.1 and switched to using XXX macros for
the …
4.104.114.84.95
@222788b
03/24/98 14:33:28 |
Joel Sherrill |
new file
4.104.114.84.95
@237f8b0d
03/24/98 14:24:57 |
Joel Sherrill |
Renamed hppa1_1 to hppa1.1
4.104.114.84.95
@42dc81e
03/23/98 23:08:10 |
Joel Sherrill |
4.104.114.84.95
@e4829a05
03/23/98 22:54:55 |
Joel Sherrill |
renamed ppc to powerpc
4.104.114.84.95
@d53130be
03/23/98 19:54:35 |
Joel Sherrill |
Updated now that the phony crt0.c in newlib defines all odd symbols …
4.104.114.84.95
@01518357
03/23/98 19:53:08 |
Joel Sherrill |
* empty log message *
4.104.114.84.95
@5839b0c1
03/23/98 19:51:40 |
Joel Sherrill |
Converted to conditionally uses strerr code to better work with glibc2.
4.104.114.84.95
@98bcbda3
03/23/98 18:35:41 |
Joel Sherrill |
Patches from Eric Norum:
Here are some patches to the gen68360 …
4.104.114.84.95
@61bbe543
03/23/98 18:35:07 |
Joel Sherrill |
Update from Eric Norum:
4.104.114.84.95
@4e01c9c
03/21/98 15:44:26 |
Joel Sherrill |
Added BSP specific start since it had become VERY complex to attempt …
4.104.114.84.95
@77bf1b1
03/21/98 15:37:43 |
Joel Sherrill |
Corrected typo in copyright notice.
4.104.114.84.95
@e2a2ec60
03/21/98 15:37:18 |
Joel Sherrill |
Switch to using a shared main() for all of the embedded BSPs
based on …
4.104.114.84.95
@2b4aec8
03/21/98 15:31:13 |
Joel Sherrill |
Fixed spacing to be consistent with other CPUs.
4.104.114.84.95
@04c99873
03/21/98 15:27:00 |
Joel Sherrill |
Fixed RTEMS_PROG_CC_WORKS and RTEMS_PROG_CXX_WORKS so they could …
4.104.114.84.95
@5b3cf09
03/21/98 15:25:47 |
Joel Sherrill |
Added enough symbols to the conftest.c program to make sure it would …
4.104.114.84.95
@771dac2
03/21/98 14:34:58 |
Joel Sherrill |
POSIX not properly conditionalized
4.104.114.84.95
@670b2edf
03/20/98 19:08:26 |
Joel Sherrill |
Fixed typo.
4.104.114.84.95
@db4aaf8
03/20/98 17:39:56 |
Joel Sherrill |
Patch from Eric Norum <eric@…>:
I've included a …
4.104.114.84.95
@25804b60
03/20/98 17:38:53 |
Joel Sherrill |
Here is my attempt at …
4.104.114.84.95
@22393efc
03/20/98 17:22:23 |
Joel Sherrill |
Added Hitachi SH port info.
4.104.114.84.95
@f8b27df9
03/20/98 17:20:45 |
Joel Sherrill |
New port from Ralf Corsepius <corsepiu@…>.
4.104.114.84.95
@50cf94da
03/20/98 17:16:31 |
Joel Sherrill |
SH port submitted from Ralf Corsepius <corsepiu@…>.
4.104.114.84.95
@a7a08713
03/20/98 16:52:10 |
Joel Sherrill |
Patch from Ralf Corsepius to properly detect that Cygwin32 does not …
4.104.114.84.95
@aa24c61
03/20/98 16:30:51 |
Joel Sherrill |
Fixed MANAGERS_NOT_WANTED.
4.104.114.84.95
@725f310
03/20/98 16:28:36 |
Joel Sherrill |
Removed blank line.
4.104.114.84.95
@7331714
03/18/98 18:15:01 |
Joel Sherrill |
Added Constants, Feature Flags, and Macros (included in Functions).
No …
4.104.114.84.95
@c78be42
03/17/98 23:10:33 |
Joel Sherrill |
First attempt at adding constants and feature flags
4.104.114.84.95
@6984a19
03/17/98 18:50:14 |
Joel Sherrill |
Completed status pass on functions and data types.
4.104.114.84.95
@3cffce87
03/17/98 16:37:57 |
Joel Sherrill |
Completed first pass at function status.
Added most data types …
4.104.114.84.95
@2a087f3
03/16/98 22:43:37 |
Joel Sherrill |
Added types, status of functions, cleaned up output of summarize.
4.104.114.84.95
@3349409
03/16/98 18:08:38 |
Joel Sherrill |
Added function status and data types
4.104.114.84.95
@aedf452
03/16/98 18:08:25 |
Joel Sherrill |
Cleaned up format and added data types.
4.104.114.84.95
@34683fee
03/16/98 17:08:52 |
Joel Sherrill |
Added Function field.
4.104.114.84.95
@53d804ff
03/16/98 17:06:12 |
Joel Sherrill |
summarize now generates a nicely formatted function status summary.
4.104.114.84.95
@4936b65
03/16/98 17:05:47 |
Joel Sherrill |
Function implmentation status information correct.
4.104.114.84.95
@e7acb60
03/16/98 16:15:32 |
Joel Sherrill |
First time summary chapter is included in the document.
4.104.114.84.95
@d2865dce
03/16/98 13:52:11 |
Joel Sherrill |
Fix from Chris Johns for inconsistent invocation of make.
4.104.114.84.95
@17ab8f5b
03/14/98 18:06:27 |
Joel Sherrill |
Added blank lines.
4.104.114.84.95
@2071990
03/14/98 18:06:08 |
Joel Sherrill |
Added summary chapter.
4.104.114.84.95
@22c9e0e
03/14/98 18:05:51 |
Joel Sherrill |
New file.
4.104.114.84.95
@5e53171d
03/14/98 17:43:56 |
Joel Sherrill |
Added functions from POSIX standard.
4.104.114.84.95
@76fa649
03/14/98 17:09:27 |
Joel Sherrill |
4.104.114.84.95
@24331760
03/14/98 16:33:20 |
Joel Sherrill |
Added copyright header
4.104.114.84.95
@0874502
03/14/98 16:31:11 |
Joel Sherrill |
4.104.114.84.95
@68feecfd
03/11/98 22:56:23 |
Joel Sherrill |
Outline complete and apparently correct.
4.104.114.84.95
@2d19ed6c
03/11/98 22:06:41 |
Joel Sherrill |
Baseline
4.104.114.84.95
@e25b7ee
03/03/98 20:43:14 |
Joel Sherrill |
Corrected to indicate test cases which were skipped.
4.104.114.84.95
@23683dd5
03/03/98 20:42:30 |
Joel Sherrill |
Changed to remove warning.
4.104.114.84.95
@607e0a25
03/03/98 16:20:52 |
Joel Sherrill |
Switched from "extern int errno" to "#include <errno.h>".
4.104.114.84.95
@79597c7
02/27/98 18:18:47 |
Joel Sherrill |
Removed use of dc. David Fiddes reported that this is part of the
GNU …
4.104.114.84.95
@0799dec
02/23/98 21:33:43 |
Joel Sherrill |
Patch from Eric Norum:
Here's another small patch. The changes to …
4.104.114.84.95
@9b39bab
02/20/98 20:23:57 |
Joel Sherrill |
Modified to make it possible for an ISR to return a mutex which did …
4.104.114.84.95
@ee7f4e34
02/20/98 20:23:12 |
Joel Sherrill |
updated
4.104.114.84.95
@b1b4fd5a
02/20/98 19:59:41 |
Joel Sherrill |
Modified to reflect new restrictions on mutex being released.
4.104.114.84.95
@de76809
02/20/98 19:59:23 |
Joel Sherrill |
Removed extra line.
4.104.114.84.95
