@f57d4d5
11/29/18 18:32:46 |
shashvatjain2002 |
m68k/mcf5206elite:Add per-section compilation and linking support (GCI …
5
@7ea4c02
11/29/18 17:03:19 |
himanshuwindows8.1 |
psxtests : Add POSIX API Signature Compliance Tests for semaphore.h …
5
@d6d4002
11/29/18 16:54:12 |
joel |
bfin/shared/dev/clock.c: Include rtems/score/thread.h
5
@b56edf1
11/29/18 16:53:48 |
joel |
lpc23xx_tli800-testsuite.tcfg: Add dl07
5
@9002859
11/29/18 16:53:32 |
joel |
lpc2362-testsuite.tcfg: Add dl07
5
@7ed1e618
11/29/18 15:19:44 |
joel |
lpc1768_mbed_ahb_ram_eth-testsuite.tcfg: Add dl07
5
@1491db5b
11/29/18 15:19:06 |
joel |
lpc1768_mbed_ahb_ram-testsuite.tcfg: Add dl07
5
@1d78d66
11/29/18 15:18:48 |
joel |
lpc1768_mbed-testsuite.tcfg: Add dl07
5
@1fe6d11
11/28/18 17:53:36 |
shashvatjain2002 |
m68k/mcf52235:Add per-section compilation and linking support(GCI …
5
@9c4dc7b0
11/28/18 20:07:41 |
shashvatjain2002 |
m68k/mcf5225x:Add per-section compilation and linking support(GCI …
5
@cc119eb
11/28/18 15:36:31 |
shashvatjain2002 |
m68k/mcf5329:Add per-section compilation and linking support (GCI …
5
@e80d34e
11/28/18 13:15:38 |
shashvatjain2002 |
m68k/mcf5235:Add per-section compilation and linking support (GCI …
5
@93ccf479
11/28/18 08:04:34 |
psxtests: add POSIX API signature compliance tests for mqueue.h file …
5
@a919807
11/28/18 16:43:23 |
joel |
lm3s3749-testsuite.tcfg: Add dl07
5
@5bf0c1a
11/28/18 13:52:22 |
Sebastian Huber |
bsps/sparc: Fix SMP build
Update #3622.
5
@aa5c462
11/28/18 09:32:46 |
Chris Johns |
testsuite: Parse TCFG path based on OS path separator.
5
@27a8fc5
11/27/18 17:10:30 |
psxtests: add POSIX API signature compliance tests for dirent.h file …
5
@89bff5a
11/27/18 02:29:49 |
shashvatjain2002 |
m68k/av5282: Add per-section compilation and linking support (GCI …
5
@06331e4
11/27/18 10:56:01 |
Sebastian Huber |
dosfs: Fix device identifier
Update #3358.
5
@a7267241
11/26/18 14:44:25 |
Sebastian Huber |
bsps/sparc: Add and use <grlib_impl.h>
Reduce copy and paste.
5
@c1864a0a
10/15/18 05:46:27 |
Sebastian Huber |
Add LICENSE.BSD-2-Clause
Copied from:
5
@0a75a4aa
11/26/18 13:04:59 |
Sebastian Huber |
Remove rtems_cache_*_processor_set() functions
The following …
5
@6378978
11/26/18 09:14:00 |
Sebastian Huber |
rtems: Fix semaphore MPCI support
5
@5fc727f
11/26/18 07:25:36 |
Sebastian Huber |
score: <rtems/score/smplockstats.h>
Remove <rtems/score/chainimpl.h> …
5
@eaa5ea84
11/20/18 15:22:56 |
Sebastian Huber |
score: Introduce <rtems/score/heapinfo.h>
Move Heap_Information_block …
5
@1947449
11/25/18 20:17:54 |
shashvatjain2002 |
m68k/uC5282: Add per-section compilation and linking (GCI 2018)
The …
5
@183b0ae
11/25/18 15:49:30 |
psxtmtests: add psxtmmqrcvblock02 (GCI 2018)
5
@16d5e394
11/24/18 20:11:50 |
abhimanyuraghuvanshi29 |
psxtests/psxhdrs patch (GCI 2018)
5
@ffe9e7a
11/25/18 07:37:01 |
shashvatjain2002 |
m68k/gen68360:Add per-section compilation and linking support
The …
5
@1b2124d
11/24/18 20:55:07 |
pritishjain2001 |
m68k/gen68340:Add per-section compilation and linking support
The …
5
@2ce44de
11/22/18 01:25:43 |
zenon.hans.taneka |
Changed slightly awkward sentence structure
5
@9dfb9a98
11/22/18 00:46:35 |
joel |
pipe/fifo.c: Remove dead code (CID 1437649)
Closes #3581.
5
@03139d5b
11/20/18 03:56:11 |
Chris Johns |
libdl: Add object file dependencies to track references
Tracking …
5
@8e7c72a7
11/20/18 03:00:48 |
Chris Johns |
libdl: Reindex unresolved names after removing used records.
Updates #3194
5
@803eac9
11/13/18 06:26:17 |
Chris Johns |
libdl: Manage the allocation of common uninitialised variables.
The …
5
@69812aa
11/21/18 16:00:35 |
psxtmbarrierattr01: Added new POSIX timing suite (GCI 2018)
5
@52c7cb1
11/21/18 16:30:22 |
Sebastian Huber |
score: Simplify _Workspace_String_duplicate()
5
@59e7209f
11/16/18 06:06:12 |
Sebastian Huber |
score: Remove support for RTEMS_USE_16_BIT_OBJECT
The …
5
@e0caabe
11/20/18 12:09:53 |
Sebastian Huber |
bsps/arm: Avoid short range branch in start.S
5
@faafc229
11/20/18 12:06:04 |
Sebastian Huber |
bsps/arm: Use local labels in start.S
5
@94529131
11/20/18 12:03:20 |
Sebastian Huber |
bsps/arm: Simplify start.S
The boot_card() function does not return.
5
@bde6ac20
11/20/18 15:45:51 |
kualeyidxa |
Misc: Minor English fixes (GCI 2018)
5
@edae517
11/20/18 01:11:58 |
psxtmutexattr01: Added new POSIX timing suite (GCI 2018)
5
@0a6a4ddb
11/16/18 06:46:16 |
Sebastian Huber |
bsps/moxie: Use interrupt stack for init stack
Update #3459.
5
@38f81bfc
11/16/18 07:01:24 |
Sebastian Huber |
bsps/nios2: Use interrupt stack for init stack
Update #3459.
5
@0989001
11/15/18 05:40:35 |
Sebastian Huber |
bsps/sparc64: Use interrupt stack for init stack
Update #3459.
5
@5f5bbd1
11/16/18 07:55:30 |
Sebastian Huber |
bsps/x86_64: Use interrupt stack for init stack
Update #3459.
5
@0ce6bf3
11/16/18 05:39:49 |
Sebastian Huber |
bsps/epiphany: Use interrupt stack for init stack
Update #3459.
5
@a74ee417
11/16/18 05:36:28 |
Sebastian Huber |
bsps/bfin: Use interrupt stack for init stack
Update #3459.
5
@508f319e
11/16/18 06:43:51 |
Sebastian Huber |
bsps/mips: Use interrupt stack for init stack
Update #3459.
5
@84e59b7c
11/15/18 19:47:22 |
Sebastian Huber |
bsps/powerpc: Use interrupt stack for init stack
Move start.o to …
5
@cc61d5c
11/16/18 06:36:04 |
Sebastian Huber |
bsps/m68k: Use interrupt stack for init stack
Update #3459.
5
@edd366c
11/17/18 17:09:05 |
psxtmcleanup01: new POSIX timing suite (GCI 2018)
5
@f06c436
11/16/18 17:17:13 |
shashvatjain2002 |
psxtmtests_plan.csv: Update to reflect psxtmmqrcvblock01 (GCI 2018)
5
@ccf11ce
11/15/18 18:55:11 |
shashvatjain2002 |
psxtmmqrcvblock01: Add new POSIX timing test (GCI 2018)
5
@841b54e
11/15/18 22:31:21 |
psxtmthreadattr01: Correct mistakes in previous merge (GCI 2018)
Joel …
5
@8abb230b
11/15/18 06:18:48 |
psxtmthreadattr01: Add new test (GCI 2018)
5
@68c8a197
11/14/18 23:30:57 |
joel |
testsuites/psxtests/psxhdrs: Fix comment so copyright block is separate
5
@5247a214
11/14/18 22:48:56 |
pisa |
bsp/tms570: correct baudrate calculation.
5
@aefd4a2
11/14/18 22:46:43 |
pisa |
bsp/tms570: correct inclusion of header files for build with HW init.
5
@a13b89b
11/14/18 07:42:22 |
Sebastian Huber |
bsp/i386: Use interrupt stack for init stack
Update #3459.
5
@5f32da0
11/14/18 06:58:38 |
Sebastian Huber |
bsp/or1k: Use interrupt stack for init stack
Update #3459.
5
@dc563556
11/14/18 06:23:21 |
Sebastian Huber |
Include missing <sys/cpuset.h>
Update #3598.
5
@28bf4ca
11/14/18 06:00:59 |
Sebastian Huber |
or1k: Support GCC 9
Close #3602.
5
@9a029ce
11/09/18 12:06:52 |
Sebastian Huber |
bsps/irq: Use rtems_malloc()
5
@6efc831
11/09/18 11:11:11 |
Sebastian Huber |
Add rtems_malloc() and rtems_calloc()
Close #3583.
5
@c1f3c2b8
11/09/18 10:20:09 |
Sebastian Huber |
score: Add and use malloc() family attributes
Update #3583.
5
@4539e307
11/08/18 15:06:44 |
Sebastian Huber |
x86_64: Remove use of proc_ptr
Update #3585.
5
@70928bc9
11/09/18 07:12:49 |
Sebastian Huber |
sparc64: Remove use of proc_ptr
Update #3585.
5
@ce37237f
11/08/18 05:41:15 |
Sebastian Huber |
sparc: Remove use of proc_ptr
Update #3585.
5
@510fbfc3
11/08/18 14:31:03 |
Sebastian Huber |
sh: Remove use of proc_ptr
Update #3585.
5
@ed9da8e
11/09/18 06:56:48 |
Sebastian Huber |
powerpc: Remove use of proc_ptr
Update #3585.
5
@54c5ffc
11/08/18 14:05:22 |
Sebastian Huber |
or1k: Remove use of proc_ptr
Update #3585.
5
@12dfa5e2
11/08/18 15:03:10 |
Sebastian Huber |
nios2: Remove use of proc_ptr
Update #3585.
5
@264e128
11/09/18 07:04:23 |
Sebastian Huber |
moxie: Remove use of proc_ptr
Update #3585.
5
@b6be8f33
11/08/18 14:34:59 |
Sebastian Huber |
mips: Remove use of proc_ptr
Update #3585.
5
@5c6edee
11/08/18 14:44:56 |
Sebastian Huber |
m68k: Remove use of proc_ptr
Update #3585.
5
@0e16fa45
11/08/18 14:47:42 |
Sebastian Huber |
lm32: Remove use of proc_ptr
Update #3585.
5
@3c6a6e8
11/08/18 14:14:32 |
Sebastian Huber |
i386: Remove use of proc_ptr
Update #3585.
5
@a043ff8
11/08/18 14:33:47 |
Sebastian Huber |
epiphany: Remove use of proc_ptr
Update #3585.
5
@8203db45
11/09/18 06:59:57 |
Sebastian Huber |
bfin: Remove use of proc_ptr
Update #3585.
5
@685aa28
11/09/18 07:01:53 |
Sebastian Huber |
arm: Remove use of proc_ptr
Update #3585.
5
@d997aa1
11/09/18 06:54:31 |
Sebastian Huber |
no_cpu: Remove use of proc_ptr
Update #3585.
5
@3faa8459
11/08/18 05:25:32 |
Sebastian Huber |
rtems: Simplify rtems_interrupt_catch()
Remove casts and superfluous …
5
@b15b288
11/08/18 05:25:06 |
Sebastian Huber |
score: Deprecate proc_ptr
Update #3585.
5
@963c6c2
11/12/18 08:28:49 |
Sebastian Huber |
score: Move internal structures to userextdata.h
Update #3598.
5
@356b07e6
11/12/18 08:24:28 |
Sebastian Huber |
score: Includes in <rtems/score/smplockstats.h>
Include …
5
@3b69a0e2
11/12/18 08:23:32 |
Sebastian Huber |
rtems: Simplify includes in <rtems/rtems/cache.h>
Update #3598.
5
@a6e7d5e4
11/12/18 08:00:36 |
Sebastian Huber |
score: Move internal structures to objectdata.h
Update #3598.
5
@e897c7d
11/08/18 11:57:26 |
Sebastian Huber |
rtems: Avoid include of <rtems/score/scheduler.h>
Update #3598.
5
@2fa014db
11/08/18 11:05:44 |
Sebastian Huber |
rtems: Avoid include of <rtems/score/thread.h>
Update #3598.
5
@805f9c26
11/08/18 10:55:11 |
Sebastian Huber |
score: Avoid complex include in heap.h
Update #3598.
5
@9763245
11/08/18 10:53:12 |
Sebastian Huber |
rtems: Remove superfluous include
Update #3598.
5
@ccc6695
11/08/18 10:50:24 |
Sebastian Huber |
score: Introduce <rtems/score/watchdogticks.h>
Separate the …
5
@98c01a5
11/08/18 10:32:13 |
Sebastian Huber |
rtems: Avoid <rtems/score/timecounter.h> in API
Use a real function …
5
@a11b98c
11/08/18 12:12:32 |
Sebastian Huber |
score: Avoid include of <rtems/score/thread.h>
Update #3598.
5
@742d6db
11/08/18 10:14:04 |
Sebastian Huber |
score: Remove empty <rtems/score/tod.h>
Update #3598.
5
@5fc855d
11/08/18 12:17:37 |
Sebastian Huber |
rtems: Move internal structures to extensiondata.h
Update #3598.
5
@e1b7c188
11/08/18 10:07:57 |
Sebastian Huber |
rtems: Move internal structures to timerdata.h
Update #3598.
5
@b7af3e44
11/08/18 09:57:21 |
Sebastian Huber |
rtems: Move internal structures to tasksdata.h
Update #3598.
5
