@f04dff4
11/19/14 20:21:28 |
Chris Johns |
Update MAINTAINERS with blanket commits for Daniel and SPARC.
4.115
@c87ff97
11/19/14 18:32:17 |
Chris Johns |
Update maintainers with Daniel.
4.115
@ab8a9ad
11/19/14 18:25:40 |
Chris Johns |
Update the maintainers list.
4.115
@7ecd1fc
11/19/14 09:09:54 |
Chris Johns |
libmisc: Add the libmisc/redirector to the wrap up.
4.115
@f98abbe
11/06/14 02:08:48 |
Chris Johns |
libdl: Disable building libdl for the NIOS2. No relocation support.
4.115
@a373dc37
11/05/14 23:52:23 |
Joel Sherrill |
lpc23xx_tli800-testsuite.tcfg: Add dl02
4.115
@091c610
11/05/14 23:52:05 |
Joel Sherrill |
lpc2362-testsuite.tcfg: Add dl02
4.115
@0b91cfbf
11/05/14 23:51:43 |
Joel Sherrill |
lpc1768_mbed_ahb_ram_eth-testsuite.tcfg: Add a handful more tests
4.115
@f9e4139
11/05/14 21:31:36 |
Joel Sherrill |
lm3s3749-testsuite.tcfg: Add dl02
4.115
@54998f6
11/04/14 22:05:44 |
Joel Sherrill |
shell/main_edit.c: Fix warnings
4.115
@8d74b80e
11/04/14 21:05:08 |
Joel Sherrill |
lpc23xx_tli800-testsuite.tcfg: Add dl01
4.115
@6d84a9f
11/04/14 21:04:46 |
Joel Sherrill |
lpc2362-testsuite.tcfg: Add dl01
4.115
@a7812cdc
11/04/14 21:04:28 |
Joel Sherrill |
lpc1768_mbed_ahb_ram_eth-testsuite.tcfg: Add rbheap01
4.115
@643e7cb8
11/04/14 21:02:03 |
Joel Sherrill |
lm3s3749-testsuite.tcfg: Add dl01
4.115
@1a3c611c
11/04/14 20:55:43 |
Joel Sherrill |
sapi/src/testextension.c: Fix warnings
4.115
@1dc5b0e0
11/04/14 20:55:21 |
Joel Sherrill |
libdl/rtl-mdreloc-bfin.c: Include rtems/rtl/rtl.h not rtl.h
4.115
@598a1f4a
11/04/14 20:54:48 |
Joel Sherrill |
libdl/Makefile.am: Need preinstall on all targets
4.115
@028ed6c3
11/04/14 05:34:37 |
Chris Johns |
libdl: RTLD_DEFAULT searches the global symbol table.
4.115
@540b7b41
11/04/14 05:31:50 |
Chris Johns |
libtests: Add libdl test dl02.
Loads 2 interdependent ELF object files.
4.115
@d52c9e4d
11/04/14 05:30:08 |
Chris Johns |
libtests: Update dl01 documentation.
4.115
@de5596b
11/04/14 02:02:03 |
Chris Johns |
Regenerated preinstall.am file.
4.115
@a2e1e30d
11/04/14 01:12:25 |
Chris Johns |
libdl: Add a local symbol table to the object module.
Adding a local …
4.115
@53dd6d61
11/03/14 18:53:40 |
Ben Gras |
BSP for several Beagle products
Specifically the beagleboard, …
4.115
@7a66986
08/22/12 12:39:02 |
ziemke |
Added BeagleBoard? BSP
Coding done in course of GSoC2012.
Commit …
4.115
@b51842b
11/03/14 18:52:03 |
Ben Gras |
Add some generic ARM am335x and omap definitions
4.115
@4123e244
11/03/14 12:56:00 |
Jennifer Averett |
cpuuse: Resolve compile errors.
4.115
@c58f90b
11/03/14 00:54:55 |
Joel Sherrill |
dl01/dl-load.c: Add missing const
4.115
@def1337
10/31/14 14:11:13 |
Joel Sherrill |
libcpu/bfin/clock/tod.h: Delete - missed on previous commits
4.115
@e08b0b9
10/30/14 13:29:09 |
Sebastian Huber |
bsp/mpc55xxevb: Fix flash settings for MPC5510
4.115
@7ae1c30
10/31/14 05:20:02 |
Chris Johns |
libnetworking: Fix the sethostname decl to match newlib.
4.115
@ae5fe7e6
10/27/14 01:09:41 |
Chris Johns |
cpukit: Add libdl with the Runtime Loader (RTL) code.
This is a merge …
4.115
@513668f6
10/29/14 16:07:20 |
chrisn |
Added missing stm32f4xxxx_adc.h
4.115
@410bcdfe
09/29/14 19:31:18 |
Jennifer Averett |
top: Add new test.
4.115
@8b11ff67
10/28/14 12:58:28 |
Jennifer Averett |
capture: Remove ctload command.
rtems_cpu_usage_top should be used …
4.115
@a7817010
09/29/14 15:21:00 |
Jennifer Averett |
libmisc: Add top to shell.
4.115
@6031da4
09/29/14 15:20:27 |
Jennifer Averett |
libmisc: Add top to cpuusage.
4.115
@254b7db0
09/08/14 14:47:13 |
Jennifer Averett |
capture01: Remove capture task tracking.
This involved adding a new …
4.115
@05e4e599
09/04/14 18:49:04 |
Jennifer Averett |
capture: Removal of capture task tracking.
This patch removes …
4.115
@7c797a1
09/19/14 19:05:49 |
Jennifer Averett |
cpuuse: Move is_executing_on_a_core to threadimpl.h
4.115
@f9b19d9
09/19/14 19:04:49 |
Jennifer Averett |
score: Move is_executing_on_a_core from cpuusagereport.c to threadimpl.h
4.115
@134a181
09/08/14 14:46:43 |
Jennifer Averett |
score: Add capture data to tcb.
4.115
@42c77e99
10/24/14 23:06:54 |
Chris Johns |
shell: Add an editor to the shell.
This is a small (21K on sparc) …
4.115
@ea9232d
10/24/14 23:05:59 |
Chris Johns |
ilibcsupport: Add realpath call.
4.115
@d412e2f
10/24/14 07:18:38 |
Sebastian Huber |
smptests/smpfatal03: Wait for end of test msg
4.115
@092b8c5
10/24/14 05:21:51 |
Sebastian Huber |
tests/smptests: Normal use of test extension
4.115
@801ad184
10/24/14 05:09:31 |
Sebastian Huber |
sapi: Use an interrupt lock for test extension
Ensure to report only …
4.115
@17889b2
10/23/14 15:15:47 |
Sebastian Huber |
tests/smptests: Use barriers in smpfatal0{12}
Call the test extension …
4.115
@a4203273
10/23/14 13:39:28 |
Sebastian Huber |
sapi: Report only if not an SMP shutdown response
4.115
@866a6fc
10/23/14 12:31:15 |
Sebastian Huber |
bsps/sparc: Include right header file
4.115
@b442032
10/23/14 08:11:59 |
Sebastian Huber |
bsp/leon3: Fix LEON3_mp_irq definition
Provide it also if …
4.115
@46dde0fc
10/23/14 08:05:17 |
Sebastian Huber |
bsps: Move extern "C" to not cover includes
Some includes may use C++ …
4.115
@3e739ae
10/23/14 07:42:18 |
Sebastian Huber |
testsuites: Move include for C++ compatibility
4.115
@77a2226
09/10/14 11:39:53 |
cederman |
bsp/sparc: Ensure that data cache snooping is enabled
Check that data …
4.115
@cf4f962
10/23/14 06:21:26 |
Sebastian Huber |
dosfs: Write meta-data only if it changed
4.115
@66c1ef9
10/17/14 12:46:13 |
Sebastian Huber |
Revert "fstests/mdosfs_fstime: Remove test"
This reverts commit …
4.115
@a7eaaae8
10/20/14 07:33:34 |
Sebastian Huber |
dosfs: Support ctime and mtime
Implement ctime and mtime updates …
4.115
@040ed0b4
10/18/14 08:55:37 |
chrisn |
bsp/stm32f4: Add header files
Added register definition headers for …
4.115
@ea05c438
10/20/14 20:25:37 |
Joel Sherrill |
or1k/or1ksim: Fix warnings
4.115
@ddc8165
10/20/14 20:25:22 |
Joel Sherrill |
arm/raspberrypi: Fix warnings
4.115
@3532ff91
10/20/14 19:36:49 |
Joel Sherrill |
shared/clockdrv_shell.h: Always include <rtems/clockdrv.h> to avoid …
4.115
@71bc995
10/20/14 19:36:19 |
Joel Sherrill |
powerpc/qoriq/include/bsp.h: Add prototypes to fix warnings
4.115
@ed18345
10/20/14 19:21:37 |
Joel Sherrill |
powerpc/qemuppc/startup/cmain.c: Fix warnings
4.115
@7294054b
10/20/14 19:13:47 |
Joel Sherrill |
powerpc/shared/startup/bspstart.c: Fix warning for mvme2100
4.115
@ce5c3b3
10/20/14 18:58:12 |
Joel Sherrill |
nios2/nios2_iss: Fix warnings
4.115
@a4fea82
10/20/14 18:57:54 |
Joel Sherrill |
ss555/startup/bspstart.c: BSP does not use SPRG0
4.115
@ad456877
10/20/14 18:57:41 |
Joel Sherrill |
ep1a/startup/bspstart.c: BSP does not use SPRG0
4.115
@82f5ec4
10/20/14 16:31:41 |
Joel Sherrill |
libcpu/sh/sh7045/sci/sci.c: Eliminate use of obsolete method
4.115
@6fc2d389
10/20/14 16:31:25 |
Joel Sherrill |
libbsp/sh/shared/console.c: Eliminate use of obsolete method
4.115
@e48bbaa
10/20/14 16:31:07 |
Joel Sherrill |
cpukit/libfs/src/imfs/ioman.c: Fix typo
4.115
@d6db94a
10/20/14 15:59:08 |
Joel Sherrill |
m68k/mrm332: Fix warnings
4.115
@a8777397
10/20/14 15:58:57 |
Joel Sherrill |
m68k/mcf5329: Fix warnings
4.115
@63fe77e1
10/20/14 15:58:38 |
Joel Sherrill |
m68k/mcf5235: Fix warnings
4.115
@13827524
10/20/14 15:58:21 |
Joel Sherrill |
m68k/mcf5225x: Fix warnings
4.115
@3bba2a9b
10/20/14 15:58:09 |
Joel Sherrill |
m68k/mcf52235: Fix warnings
4.115
@fd36451
10/20/14 15:57:54 |
Joel Sherrill |
m68k/idp: Fix warnings
4.115
@21ee1c8
10/20/14 15:57:44 |
Joel Sherrill |
m68k/gen68360: Fix warnings
4.115
@c2e32ff
10/20/14 14:25:41 |
Joel Sherrill |
lm32 BSP shared and lm32_evr: Fix BSPs
4.115
@770e379
10/20/14 14:15:32 |
Joel Sherrill |
arm/csb337/console/fbcons.c: Fix warning
4.115
@d0c4793
10/20/14 14:13:22 |
Joel Sherrill |
libcpu/arm/pxa255/ffuart/ffuart.c: Fix warning
4.115
@1c4890b
10/20/14 14:13:06 |
Joel Sherrill |
libcpu/arm/at91rm9200/dbgu/dbgu.c: Fix warning
4.115
@5bdda7f
10/20/14 14:12:46 |
Joel Sherrill |
arm/gba/console/conio.c: Fix warning
4.115
@0f8ee10e
10/20/14 14:11:41 |
Joel Sherrill |
arm/edb7312: Fix warnings
4.115
@0e74a51
10/20/14 02:46:06 |
Joel Sherrill |
cpukit/score/cpu/lm32/irq.c: Fix warning
4.115
@a9c45a04
10/20/14 02:45:51 |
Joel Sherrill |
score/cpu/lm32/rtems/score/cpu.h: Fix set but not used warning
4.115
@6c8e0dc8
10/20/14 02:45:37 |
Joel Sherrill |
score/cpu/i386/rtems/score/cpu.h: Fix set but not used warning
4.115
@4f21badb
10/20/14 02:27:09 |
Joel Sherrill |
m68k/csb360: Fix warnings
4.115
@3d4898f
10/20/14 02:21:06 |
Joel Sherrill |
m68k/av5282: Fix warning
4.115
@8566e1fc
10/20/14 02:14:23 |
Joel Sherrill |
lm32/milkymist/startup/bspclean.c: Include <bsp.h> to fix warning
4.115
@b83fe77c
10/20/14 02:11:00 |
Joel Sherrill |
jffs2: Add casts and constant designators to address warnings on …
4.115
@51995b69
10/19/14 22:14:07 |
Joel Sherrill |
m68k/mrm332: Move include of <rtems/m68k/sim.h>
This file defines at …
4.115
@8200c9e
10/19/14 21:59:47 |
Joel Sherrill |
libcpu/powerpc configure logic: Do not built e500 components unused by …
4.115
@6e8e869
10/17/14 15:21:31 |
Joel Sherrill |
powerpc/shared/irq/irq_init.c: Fix warnings
4.115
@f33e6c0
10/17/14 15:21:18 |
Joel Sherrill |
powerpc/shared/bootloader: Fix warnings
4.115
@04d3761
10/17/14 15:20:50 |
Joel Sherrill |
powerpc/motorola_powerpc/include/bsp.h: Fix warnings
4.115
@ba9c4a7
10/17/14 15:09:55 |
Joel Sherrill |
powerpc/psim: Fix warnings
4.115
@3064411
10/17/14 15:08:01 |
Joel Sherrill |
powerpc/qemuppc: Fix warnings
4.115
@b5548e5
10/17/14 14:50:05 |
Joel Sherrill |
powerpc/gen83xx: Fix warnings
4.115
@d8e2046
10/17/14 13:52:43 |
Joel Sherrill |
sparc/leon3/include/bsp.h: Fix warnings
4.115
@c676ef3
10/17/14 13:52:33 |
Joel Sherrill |
sparc/leon2/include/bsp.h: Fix warnings
4.115
@4c75e72
10/17/14 13:52:07 |
Joel Sherrill |
sparc/erc32: Fix warnings
4.115
