@efc227cd
11/08/18 09:24:19 |
Sebastian Huber |
rtems: Move internal structures to eventdata.h
Update #3598.
5
@72a4a42
11/08/18 09:19:39 |
Sebastian Huber |
rtems: Move internal structures to dpmemdata.h
Update #3598.
5
@395a49e1
11/08/18 09:12:21 |
Sebastian Huber |
rtems: Move internal structures to barrierdata.h
Update #3598.
5
@bdd4eb87
11/08/18 08:13:59 |
Sebastian Huber |
rtems: Remove Modes_Control
Use rtems_mode directly. This is in line …
5
@257cf74
11/08/18 08:03:47 |
Sebastian Huber |
rtems: Move internal structures to asrdata.h
Update #3598.
5
@78bbe59
11/07/18 13:12:52 |
Sebastian Huber |
rtems: Move internal structures to ratemondata.h
Update #3598.
5
@93fae332
11/12/18 08:33:04 |
Sebastian Huber |
Include missing <sys/types.h>
Update #3598.
5
@0a9378af
11/12/18 12:09:36 |
Sebastian Huber |
x86_64: Remove duplicate _CPU_Thread_Idle_body()
5
@bfcf1473
11/08/18 15:21:48 |
Sebastian Huber |
m32c: Remove this target
Update #3599.
5
@7ea7178
11/09/18 18:16:27 |
shashvatjain2002 |
arm/csb337: Update Doxygen (GCI 2018)
5
@62954aaf
11/11/18 15:12:51 |
joel |
psxtmtests_plan.csv: Add pthread cleanup and attr test cases
5
@b3c624d8
11/08/18 00:47:49 |
shashvatjain2002 |
arm/altera cyclone v: Update Doxygen (GCI 2018)
5
@84aedcae
11/08/18 12:49:38 |
Sebastian Huber |
Include missing <rtems/score/thread.h>
Update #3598.
5
@5841e0b
11/09/18 12:47:20 |
Sebastian Huber |
bsp/lpc32xx: Include missing <time.h>
Update #3598.
5
@fdd3b85
11/09/18 09:46:50 |
Sebastian Huber |
bsp/motorola_powerpc: Include <sys/param.h>
Update #3598.
5
@0288536
11/09/18 08:40:45 |
Sebastian Huber |
bsps: Include missing header files
Update #3598.
5
@efdb4a7
11/09/18 08:37:53 |
Sebastian Huber |
bsp/beatnik: Fix warnings
5
@1e039fb3
11/08/18 07:01:13 |
Sebastian Huber |
rtems: Deprecate rtems_rate_monotonic_period_time_t
The …
5
@aacc7a0
11/08/18 06:59:04 |
Sebastian Huber |
rtems: Deprecate rtems_thread_cpu_usage_t
The …
5
@d53862a
11/08/18 06:56:54 |
Sebastian Huber |
rtems: Deprecate region_information_block
The …
5
@7e86e00
11/08/18 06:54:03 |
Sebastian Huber |
rtems: Deprecate rtems_context_fp
The rtems_context_fp typedef as no …
5
@0ac4a77
11/08/18 06:53:14 |
Sebastian Huber |
The rtems_context typedef as no …
5
@06ced25
11/07/18 05:09:07 |
Chris Johns |
testsuite: Add python verison support to rtems-test-check.py
Closes #3579
5
@947b679
11/08/18 15:46:17 |
Sebastian Huber |
h8300: Remove left over files
Update #2452.
5
@942d52a
11/08/18 12:59:27 |
Sebastian Huber |
build: Fix library order
Update #3551.
5
@4f4ed2f0
11/08/18 12:11:54 |
Sebastian Huber |
rtems: Add missing include
Update #3598.
5
@ac8025c
11/08/18 12:09:54 |
Sebastian Huber |
libcsupport: Add missing include
Update #3598.
5
@2c8b87f
11/08/18 11:10:41 |
Sebastian Huber |
rtems: Move includes out of extern "C" scope
5
@795dfaac
11/08/18 09:49:43 |
Malte Münch |
small typo
5
@ea8cf79
11/08/18 11:00:12 |
Sebastian Huber |
config: Move includes out of extern "C" scope
5
@32953f90
11/08/18 07:38:24 |
Sebastian Huber |
bsp/realview-pbx-a9: Update headers.am
5
@ef30eb1
11/08/18 06:52:28 |
Sebastian Huber |
monitor: Remove dead code
Update #3587.
Update #3589.
5
@a9767a07
11/07/18 13:27:17 |
Sebastian Huber |
score: Use RTEMS_DEPRECATED for deprecated types
Update #3584.
5
@4fea054c
11/06/18 18:34:15 |
Sebastian Huber |
score: Remove _ISR_Dispatch()
This function was only used on some …
5
@ff081aee
11/06/18 15:58:02 |
Sebastian Huber |
score: Rename interrupt stack symbols
Rename
5
@e9f15be
11/07/18 18:09:00 |
joel |
psxtmtests_plan.csv: Add psxtmonce01
5
@98cc00e6
11/07/18 18:07:53 |
joel |
psxtmonce01/init.c: Use static and Simple Console
5
@e94b73f
11/07/18 13:28:55 |
Sebastian Huber |
config: Include <rtems.h> for RTEMS_NEWLIB
5
@97a86719
11/06/18 15:57:21 |
Sebastian Huber |
config: Move definitions after includes
5
@2faea99
11/07/18 10:08:50 |
Sebastian Huber |
bsp/realview-pbx-a9: Fix printk() support
Avoid dependencies on the …
5
@e292beba
11/07/18 09:47:48 |
Sebastian Huber |
termios: Move default lock functions
Move …
5
@d1f7204
11/06/18 12:04:11 |
Sebastian Huber |
config: Fix CONFIGURE_DISABLE_NEWLIB_REENTRANCY
Move the getreent() …
5
@e71c097a
11/06/18 11:57:42 |
Sebastian Huber |
spconfig02: Check object methods in default config
Ensure that the …
5
@a818d13c
11/07/18 06:43:38 |
Sebastian Huber |
build: Remove superfluous psxtmonce01/Makefile.am
5
@99d6172
11/07/18 00:50:38 |
zenon.hans.taneka |
Correct minor spelling and grammar errors
This work was performed as …
5
@9bb39516
11/06/18 18:29:10 |
himanshuwindows8.1 |
psxtmonce01: New test written by Himanshu40 as part of GCI2018
5
@878487b0
11/05/18 08:53:04 |
Sebastian Huber |
score: Optimize Objects_Information
Reduce structure internal …
5
@d7c51da
11/05/18 20:48:20 |
Gedare Bloom |
altera-cyclone-v: tweak ingroup
5
@3b930548
11/03/18 20:45:50 |
44733601+ABR290B |
arm/altera-cyclone-v: update doxygen (GCI 2018)
5
@fa0adf36
10/30/18 10:53:46 |
Sebastian Huber |
ftpd: Avoid TOCTOU problem
Assume that opendir() returns only …
5
@8c3cd1e8
10/30/18 10:34:16 |
Sebastian Huber |
ftpd: Deal with too long command lines
Update #3530.
5
@706802f8
10/30/18 08:35:06 |
Sebastian Huber |
ftpd: Make send_dirline() more robust
Account for large file names.
5
@7e2aabd7
10/30/18 12:23:57 |
Sebastian Huber |
config: Fix check networking
This Autoconf macro used cache variables …
5
@bb3484c9
10/29/18 07:59:45 |
Sebastian Huber |
posix: Enable more sptests test cases by default
Update #2514.
5
@8dc1ed1
10/25/18 12:08:26 |
Sebastian Huber |
posix: Enable more psxtests by default
Update #2514.
5
@24f3e8f
10/25/18 12:02:23 |
Sebastian Huber |
posix: Enable more smptests tests by default
Update #2514.
5
@ef16a11
10/25/18 09:05:12 |
Sebastian Huber |
posix: Enable psxtmtests tests by default
Update #2514.
5
@54f35888
10/25/18 08:54:12 |
Sebastian Huber |
posix: Provide threads by default
Update #2514.
5
@033f31c8
10/25/18 08:26:40 |
Sebastian Huber |
posix: Hide POSIX_API_Control by default
Update #2514.
5
@fe7aefd5
10/25/18 08:12:39 |
Sebastian Huber |
posix: Provide message queues by default
Update #2514.
5
@701057e0
10/25/18 08:07:46 |
Sebastian Huber |
posix: Provide shared memory objects by default
Update #2514.
5
@9318cfb0
10/14/18 10:43:13 |
Sebastian Huber |
posix: Provide named semaphores by default
Update #2514.
5
@e97806a
10/14/18 17:20:05 |
Sebastian Huber |
posix: Split posix_api_configuration_table
Use separate configuration …
5
@55b69ed
10/15/18 06:33:45 |
Sebastian Huber |
Move default config to librtemsdefaultconfig.a
An RTEMS application …
5
@7038271
10/25/18 10:05:53 |
Sebastian Huber |
Remove RTEMS_SCORE_OBJECT_ENABLE_STRING_NAMES
Enable support for …
5
@5090a71b
10/25/18 09:32:01 |
Sebastian Huber |
score: Remove bogus thread object name support
Update #2514.
5
@0dbf67b
10/25/18 12:37:08 |
Sebastian Huber |
posix: Provide aio_suspend() by default
Update #2514.
5
@135cb10
10/25/18 07:56:02 |
Sebastian Huber |
posix: Provide more functions by default
Update #2514.
5
@4a7be22
10/25/18 08:03:46 |
Sebastian Huber |
posix: Fix build with POSIX API disabled
Update #2514.
5
@24b5807
10/24/18 05:35:51 |
Sebastian Huber |
config: Modify CONFIGURE_INTERRUPT_STACK_SIZE
Use …
5
@4b801ac
10/24/18 05:54:27 |
Sebastian Huber |
posix: Provide simple thread functions by default
Update #2514.
5
@c1ce9a2
10/24/18 05:40:23 |
Sebastian Huber |
posix: Provide get thread attributes by default
Update #2514.
5
@522d4b91
10/24/18 05:16:46 |
Sebastian Huber |
malloctest: Hide NULL pointer from compiler
Disabling a warning does …
5
@01595a4
10/24/18 08:17:58 |
Sebastian Huber |
bsp/imx: Adjust workspace according to device tree
5
@8ba76b9
10/12/18 15:20:39 |
Sebastian Huber |
tmonetoone: Add yield test case
5
@8d81622
10/14/18 15:10:32 |
Sebastian Huber |
posix: Provide non-thread functions by default
Update #2514.
5
@0b2808ce
10/14/18 10:41:22 |
Sebastian Huber |
posix: Provide scheduler support by default
Update #2514.
5
@dd804bb
10/14/18 10:36:22 |
Sebastian Huber |
posix: Provide cancel state/type by default
Sort POSIX sources …
5
@6da1bb0
10/18/18 12:58:31 |
Sebastian Huber |
Remove superfluous configure checks
The results of these checks are …
5
@167654e
10/18/18 12:45:24 |
Sebastian Huber |
Remove checks for flockfile(), etc. declarations
Declarations …
5
@f59edebf
10/18/18 12:39:09 |
Sebastian Huber |
Remove getcwd()
This function is provided by Newlib since 2000.
5
@79d145a7
10/18/18 12:36:44 |
Sebastian Huber |
Remove optional getrusage() declaration
Declaration provided by …
5
@e161767e
10/18/18 12:33:58 |
Sebastian Huber |
Remove ttyname()
5
@658ec75
10/18/18 12:28:17 |
Sebastian Huber |
Remove assert()
5
@87a9900f
10/18/18 12:22:46 |
Sebastian Huber |
Remove isatty()
These functions are provided by Newlib since 2000.
5
@3cf12c9
10/18/18 12:11:10 |
Sebastian Huber |
Remove strlcat(), strlcpy(), strsep(), readdir_r()
These functions …
5
@1ad26cd
10/18/18 10:38:58 |
Sebastian Huber |
Support O_NOFOLLOW open() flag
Close #3546.
5
@3825926
10/18/18 09:51:32 |
Sebastian Huber |
Support O_CLOEXEC open() flag
Make sure this flag is ignored and does …
5
@92e0eed
10/22/18 05:58:44 |
Sebastian Huber |
psxreaddir: Adjust test due to opendir() changes
Update #3545.
5
@b4043ea
09/24/18 14:32:49 |
joel |
check-networking.m4: Disable legacy stack for x86_64 and epiphany
5
@28fb5b71
09/05/18 23:02:30 |
joel |
mpc8260ads/start/bspstart.c: Fix unused function warning
5
@c1233a33
09/04/18 13:35:37 |
joel |
qemuppc/start/cmain.c: Cast args to memcpy and bzero to fix warnings
5
@156b77a
09/04/18 13:35:07 |
joel |
gen5200/mscan/mscan.c: Fix printf() format warning
5
@023bd1d
09/04/18 13:34:42 |
joel |
or1k/shared/cache/cache.c: Remove unused methods
5
@35eab84
09/04/18 13:34:22 |
joel |
gdbarmsim/include/bsp.h: Include <sys/stat.h> to fix warning
5
@4af18b3
10/11/18 08:51:21 |
Sebastian Huber |
Support O_DIRECTORY open() flag
Close #3545.
5
@68799dac
10/18/18 05:22:44 |
Sebastian Huber |
bsp/atsam: Add const qualifier to AES_SetInput()
5
@c980eaf
10/16/18 12:35:12 |
Sebastian Huber |
console: Be fair in simple console read
Wait for one tick in case no …
5
@143c8d0
10/17/18 07:43:55 |
Sebastian Huber |
serial/ns16550: Fix precision clock synthesizer
The precision clock …
5
@d7c13c8
10/16/18 12:34:38 |
Sebastian Huber |
bsp/imx7: Add getchark() support
5
