@eae0863
04/27/14 08:11:09 |
Chris Johns |
rtems: Fix sp2038 test.
Avoid using newlib's gmtime_r call which …
4.115
@a070c8b
05/21/14 07:30:14 |
Sebastian Huber |
rtems: Simplify rtems_semaphore_obtain()
4.115
@1bf0666
05/21/14 20:08:23 |
Joel Sherrill |
schedulersmpimpl.h: Fix spacing
4.115
@82f90743
05/21/14 08:30:34 |
Sebastian Huber |
score: _Thread_Set_life_protection()
Enable usage of …
4.115
@c8e83288
05/21/14 08:29:59 |
Sebastian Huber |
score: Add and use _Scheduler_Get_index_by_id()
4.115
@4ddc3b5
05/21/14 08:29:36 |
Sebastian Huber |
score: Add const qualifier
4.115
@884a6c59
05/21/14 07:18:29 |
Sebastian Huber |
score: Add comment regarding TLS workspace size
4.115
@40f2eafe
05/21/14 06:30:25 |
Sebastian Huber |
score: Simplify _Scheduler_Set()
4.115
@e5274df
05/20/14 08:03:35 |
Sebastian Huber |
rtems: Clarify task set/get scheduler parameters
4.115
@2d96533
05/20/14 06:06:43 |
Sebastian Huber |
score: SMP scheduler support documentation
4.115
@39840438
05/16/14 13:34:33 |
Sebastian Huber |
dosfs: Fix read from invalid memory area
4.115
@1ac0b083
05/16/14 08:55:01 |
Sebastian Huber |
score: Simplify SMP scheduler support
4.115
@b532bb2c
05/16/14 08:54:48 |
Sebastian Huber |
score: Fix state diagram
4.115
@c0bff5e
05/15/14 08:31:22 |
Sebastian Huber |
score: Split SMP scheduler enqueue function
Extract code from …
4.115
@b4bdbcf
05/15/14 07:41:20 |
Sebastian Huber |
score: Make _Thread_queue_Requeue() static
This function is only used …
4.115
@6359b68
05/15/14 06:47:50 |
Sebastian Huber |
score: Add and use _Scheduler_SMP_Start_idle()
4.115
@3733b224
05/15/14 06:46:56 |
Sebastian Huber |
score: Add and use _Scheduler_default_Schedule()
4.115
@f39f667a
05/14/14 11:50:48 |
Sebastian Huber |
score: Simplify _Thread_Change_priority()
The function to change a …
4.115
@2369b10
05/14/14 14:04:10 |
Sebastian Huber |
score: Add and use _Scheduler_Get_context()
4.115
@0f41cc3
05/14/14 09:25:07 |
Sebastian Huber |
score: _Scheduler_priority_Ready_queue_requeue()
Delete unused …
4.115
@c21c5912
05/14/14 09:11:05 |
Sebastian Huber |
score: Add STATES_RESTARTING
Use separate state for thread restart.
4.115
@01f302b
05/14/14 09:07:34 |
Sebastian Huber |
score: Typo
4.115
@0e8d55b0
05/14/14 09:06:40 |
Sebastian Huber |
monitor: Support STATES_MIGRATING
4.115
@249eaf9
05/14/14 08:28:09 |
Sebastian Huber |
bsps/sparc: Fix BSS initialization
Use bss_start available via %g2 …
4.115
@b2d191e
05/14/14 08:23:18 |
Sebastian Huber |
bsps/sparc: Fix data copy in start procedure
Use the register %g4 for …
4.115
@3730a07f
05/13/14 13:08:07 |
Sebastian Huber |
score: Use Scheduler_Context for SMP scheduler
Use the basic …
4.115
@e9ee2f0
05/13/14 12:36:57 |
Sebastian Huber |
score: Capitalize SMP acronym
4.115
@c6522a65
05/12/14 06:38:38 |
Sebastian Huber |
score: SMP scheduler documentation
4.115
@beab7329
05/13/14 14:03:05 |
Sebastian Huber |
score: Introduce scheduler nodes
Rename scheduler per-thread …
4.115
@5b1ff71a
05/13/14 13:57:43 |
Sebastian Huber |
score: Scheduler documentation
4.115
@774ee002
05/14/14 08:17:47 |
cederman |
sparc: Change asm to asm to compile with -std=c99.
4.115
@c8b7b32
05/12/14 13:21:52 |
ralf.kirchner |
bsp/altera-caclone-v: Early printk support
Make sure printk can work …
4.115
@390e73c4
05/12/14 13:55:25 |
Sebastian Huber |
score: Move out of RTEMS_HAVE_SYS_CPUSET_H
Move _Scheduler_Get() …
4.115
@fa0a9a18
05/12/14 07:32:20 |
Sebastian Huber |
bsps: Declare bsp_start_on_secondary_processors()
4.115
@6c5c2f3
05/12/14 07:23:51 |
Sebastian Huber |
bsps: Use bsp_start_on_secondary_processor()
Use a standard function …
4.115
@64a04ac
05/12/14 06:53:11 |
Sebastian Huber |
bsps: Use standard file name for BSP support
4.115
@ca2dd1e
05/12/14 06:35:57 |
Sebastian Huber |
bsp/leon3: Delete unused function
4.115
@6339cd2d
05/09/14 08:08:29 |
Sebastian Huber |
rtems: Move extern "C" in <rtems.h>
Do not cover the includes with an …
4.115
@3a3869c4
05/09/14 12:25:40 |
Christian.Mauderer |
bsps/sparc: Move flags to grlib header
This enables re-use for other BSPs
4.115
@89f0794
05/08/14 11:00:08 |
Sebastian Huber |
bsp/gen83xx: Disable interrupt nesting for br_uid
This is necessary …
4.115
@11b05f1
05/08/14 08:11:13 |
Sebastian Huber |
score: Fix CPU context usage on SMP
We must not alter the is …
4.115
@35a3af7a
05/05/14 19:55:35 |
Sebastian Huber |
doc: Use @dfn for glossary terms
4.115
@29e6637e
05/05/14 19:55:13 |
Sebastian Huber |
doc: Move SMP glossary to global glossary
Add some terms.
4.115
@d9196d1d
04/10/14 06:25:33 |
Sebastian Huber |
configure: Paravirtualization for all targets
Virtual machines with …
4.115
@23b9d095
05/07/14 16:32:15 |
Sebastian Huber |
smptests/smp07: Fix test output
4.115
@8fa3422
05/07/14 16:30:36 |
Sebastian Huber |
smptests/smp05: Fix test name and output
4.115
@b97bc8bc
05/07/14 16:27:19 |
Sebastian Huber |
tests: Add locked_printf_plugin()
Add locked_vprintf(). Return an …
4.115
@0960fee
05/07/14 15:53:48 |
Sebastian Huber |
rtems: Fix ASR SMP support
Initialize the ISR lock only once and …
4.115
@6c36946f
05/07/14 12:22:56 |
Sebastian Huber |
score: Fix SMP startup
4.115
@38b59a6
05/02/14 08:31:09 |
Sebastian Huber |
score: Implement forced thread migration
The current implementation …
4.115
@58444f7
05/06/14 13:16:39 |
Sebastian Huber |
score: Delete _SMP_Test_message_default_handler
A default handler is …
4.115
@0034629
05/07/14 07:23:23 |
Sebastian Huber |
bsps/arm: Declare return types
4.115
@43ef7068
05/07/14 07:23:07 |
Sebastian Huber |
bsps: Fix BSP_INITIAL_EXTENSION
4.115
@07e7a7f8
05/07/14 06:13:44 |
Sebastian Huber |
score: Documentation
4.115
@3324383c
05/05/14 14:47:30 |
Joel Sherrill |
testsuites: Remove BSP_SMALL_MEMORY
4.115
@053abcda
04/23/14 23:38:43 |
Joel Sherrill |
multiple BSPs: Remove BSP_SMALL_MEMORY
4.115
@c2ea0ea
05/06/14 12:44:17 |
Sebastian Huber |
bsp/gen83xx: Add BSP_USB_EHCI_MPC83XX_HAS_ULPI
4.115
@7d1436e
05/06/14 11:41:28 |
Sebastian Huber |
posix: Fix POSIX keys initialization
Always initialize the freechain. …
4.115
@4d906bda
05/02/14 13:47:57 |
Sebastian Huber |
score: Use atomic operations for SMP messages
4.115
@145becf
05/02/14 13:33:23 |
Sebastian Huber |
score: Add SMP test message handler
This handler can be used to test …
4.115
@e239760
04/29/14 14:09:35 |
Sebastian Huber |
score: SMP_FATAL_SCHEDULER_WITHOUT_PROCESSORS
Avoid the …
4.115
@d20b029
04/16/14 18:54:48 |
Sebastian Huber |
doc: Add SMP glossary
4.115
@bee71f8e
04/30/14 12:54:58 |
Sebastian Huber |
score: Fix TLS size usage
4.115
@1461b648
05/04/14 22:12:52 |
Chris Johns |
testsuite: Add a per BSP test check for tests not to build.
Provide a …
4.115
@b0e83e12
04/30/14 08:13:07 |
ralf.kirchner |
libchip: Add asserts to dwmac driver
4.115
@64bc102
04/30/14 08:07:20 |
ralf.kirchner |
libchip: Correct netstats message for dwmac driver
4.115
@bc9a71b
04/30/14 08:06:11 |
ralf.kirchner |
bsp/altera-cyclone-v: Move mbufs and network clusters to uncached RAM
4.115
@ff13e0b
04/30/14 08:06:10 |
ralf.kirchner |
bsp/altera-cyclone-v: Increase size of nocache region and nocache heap …
4.115
@dabf423
04/29/14 11:16:06 |
Sebastian Huber |
score: Typo
4.115
@0832ca7
04/29/14 14:57:37 |
ralf.kirchner |
doc: Extend documentation for unlimited objects
Mark POSIX Keys and …
4.115
@03b7789
04/26/14 13:09:10 |
Sebastian Huber |
score: Statically initialize _ISR_Vector_table
4.115
@a16af0b3
04/29/14 07:39:08 |
Sebastian Huber |
bsps/mips: Delete unused files
The MIPS port defines …
4.115
@0b344f34
04/29/14 06:53:35 |
Sebastian Huber |
bsps/m32r: Fix bsp_specs
4.115
@ef26454
04/29/14 06:43:04 |
Sebastian Huber |
bsps/bfin: Fix bsp_specs
4.115
@99be750
04/29/14 05:48:09 |
Sebastian Huber |
sapi: Report profiling only if enabled for tests
4.115
@6741427a
04/28/14 14:55:38 |
Sebastian Huber |
bsp/h8sim: Fix linker command file
4.115
@a336d51
04/28/14 07:56:33 |
Sebastian Huber |
score: Avoid copy and paste
4.115
@aea93fb4
04/22/14 09:50:29 |
Sebastian Huber |
sapi: Add profiling done message
4.115
@8365ad1
04/22/14 09:46:10 |
Sebastian Huber |
sapi: Add arithmetic means to XML profiling report
4.115
@7c0bd74
04/22/14 08:15:39 |
Sebastian Huber |
sparc: Add _CPU_Get_current_per_CPU_control()
Use register g6 for the …
4.115
@3fe1e43
04/22/14 08:40:26 |
Sebastian Huber |
sparc: Document register g7 usage
4.115
@b2ec2d15
04/22/14 05:46:56 |
Sebastian Huber |
sparc: Optimize context switch
The registers g2 through g4 are …
4.115
@e5120a5
04/22/14 08:10:39 |
Sebastian Huber |
score: Add _CPU_Get_current_per_CPU_control()
Add optional method …
4.115
@0c5beb8e
04/26/14 23:32:20 |
Chris Johns |
rtems: Account for the network semaphore.
4.115
@e306f3df
04/25/14 17:56:36 |
Jennifer Averett |
sapi: Fix condef.h compile error for disabled network configuration.
4.115
@5d2ae6e2
04/25/14 07:30:37 |
Chris Johns |
libfs/rfs: Fix the fstime failures for the RFS file system.
4.115
@c9a0a10
04/25/14 06:14:19 |
Chris Johns |
rtems: Account for file system semaphores.
Add support to account for …
4.115
@f412e12
04/24/14 13:21:00 |
Joel Sherrill |
mcf52235/configure.ac: Delete junk line
4.115
@b74c9cf
04/23/14 04:31:55 |
Chris Johns |
bootstrap: Sort the contents of the prinstall.am files.
Sorting …
4.115
@1450de0
04/22/14 18:10:47 |
Joel Sherrill |
shsim: Correct linking for C++
4.115
@25c3208a
04/22/14 18:08:14 |
Joel Sherrill |
gensh4: Correct linking for C++
4.115
@851e643
04/22/14 18:07:56 |
Joel Sherrill |
gensh2: Correct linking for C++
4.115
@3191b42
04/22/14 18:07:44 |
Joel Sherrill |
gensh1: Correct linking for C++
4.115
@b6a2e57b
04/22/14 18:07:01 |
Joel Sherrill |
score603e: Add rtems_crti
4.115
@77737ad
04/22/14 18:06:08 |
Joel Sherrill |
ss555: Add rtems_crti/n
4.115
@812c9d6
04/22/14 15:44:20 |
Joel Sherrill |
sim68000/bsp_specs: Add crtbegin/end, crt[in]
4.115
@2f36f5a5
04/22/14 15:36:44 |
Joel Sherrill |
mpc8260ads: Add rtems_crti/n
4.115
@8c18adde
04/22/14 14:45:55 |
Joel Sherrill |
h8sim/bsp_specs: Add crtbegin/end, crt[in]
4.115
@1ed8762e
04/21/14 18:08:38 |
Joel Sherrill |
mpci.c: Now compiles again
4.115
@d47904f
04/21/14 18:08:00 |
Joel Sherrill |
niagara/Makefile.am: Fix rule for start.o
4.115
