@d7072e5
10/21/97 18:37:32 |
Joel Sherrill |
Moved rtems directory up one directory in the install point. It was …
4.104.114.84.95
@97faafa5
10/21/97 18:36:48 |
Joel Sherrill |
Added termios submission from Eric Norum and Katsutoshi Shibuya.
4.104.114.84.95
@a75c783
10/21/97 17:03:18 |
Joel Sherrill |
Converted from using a message queue for the raw input queue to using …
4.104.114.84.95
@55e1322
10/21/97 17:03:17 |
Joel Sherrill |
4.104.114.84.95
@ae35953d
10/21/97 16:18:03 |
Joel Sherrill |
4.104.114.84.95
@4fd61795
10/21/97 16:17:12 |
Joel Sherrill |
Added casts and fixed line break.
4.104.114.84.95
@f33a3f2a
10/16/97 21:06:47 |
Joel Sherrill |
Control and Data addresses were swapped for port A.
4.104.114.84.95
@d17d4d2f
10/15/97 21:27:00 |
Joel Sherrill |
Moved selection of console port to custom file.
4.104.114.84.95
@84ff8b7b
10/13/97 17:38:18 |
Joel Sherrill |
New version of this file from Eric Norum.
4.104.114.84.95
@d9fe8e2
10/09/97 20:21:43 |
Joel Sherrill |
Fixed some spacing.
4.104.114.84.95
@f00108f
10/09/97 18:35:02 |
Joel Sherrill |
Fixed incorrect reference to RTEMS_BSP instead of RTEMS_BSP_FAMILY.
4.104.114.84.95
@a86443fb
10/09/97 18:33:46 |
Joel Sherrill |
Added search of libcpu and fpsp.
4.104.114.84.95
@c3a0358
10/08/97 20:09:58 |
Joel Sherrill |
Renamed mlink to make_subdir.
Removed a junk line.
4.104.114.84.95
@b546242
10/08/97 19:52:47 |
Joel Sherrill |
Modified to search RTEMS library before Newlib C library.
4.104.114.84.95
@58e3dc79
10/08/97 18:25:30 |
Joel Sherrill |
Fix from Eric Norum so FPSP is installed before any FP code is …
4.104.114.84.95
@89f5f5a1
10/08/97 18:23:58 |
Joel Sherrill |
Fix from Eric Norum to assemble under COFF.
4.104.114.84.95
@7de0960
10/08/97 18:19:43 |
Joel Sherrill |
Update from Eric Norum:
Change label names so they can be …
4.104.114.84.95
@6fd3979
10/08/97 17:57:04 |
Joel Sherrill |
Added comment about using --enable-gcc28 and --enable-libcdir
options …
4.104.114.84.95
@98e4ebf5
10/08/97 15:45:54 |
Joel Sherrill |
Fixed typo in the pointer to the license terms.
4.104.114.84.95
@a2016b99
10/08/97 14:42:08 |
Joel Sherrill |
Removed include directory at "build" point and the link of this …
4.104.114.84.95
@f05f704
10/08/97 14:06:17 |
Joel Sherrill |
Updated information on building your own application.
4.104.114.84.95
@f5afb69
10/08/97 14:05:38 |
Joel Sherrill |
Reworked building of make subdirectory and contents in the object
tree.
4.104.114.84.95
@0c618b67
10/07/97 20:47:49 |
Joel Sherrill |
Redid the installation of the "make" directory at the install point. …
4.104.114.84.95
@3a321e23
10/06/97 21:32:47 |
Joel Sherrill |
Fixed some weird line duplications. Thanks to Chris Johns.
4.104.114.84.95
@ffa6183
10/06/97 21:30:16 |
Joel Sherrill |
Increased interrupt stack space.
4.104.114.84.95
@b6770d1
10/06/97 21:29:29 |
Joel Sherrill |
Fixed comment.
4.104.114.84.95
@7e4938c
10/06/97 21:28:40 |
Joel Sherrill |
Make Post an atomic operation.
4.104.114.84.95
@d14418b
10/06/97 21:28:18 |
Joel Sherrill |
Added _Thread_Enable_dispatch to already_timedout path on Wait_support.
4.104.114.84.95
@7d5566e
10/06/97 21:26:11 |
Joel Sherrill |
Fixed bug where include not actually created.
4.104.114.84.95
@e8ee2f32
10/05/97 16:26:04 |
Joel Sherrill |
If the specified time period is less than a clock tick, then
it is …
4.104.114.84.95
@8959fcc
09/30/97 14:49:56 |
Joel Sherrill |
fixed typo
4.104.114.84.95
@63cebf6
09/30/97 14:44:28 |
Joel Sherrill |
Fixed typos.
4.104.114.84.95
@f795ca90
09/21/97 17:44:50 |
Joel Sherrill |
Uncommented gettimeofday_r to resolve missing symbol.
4.104.114.84.95
@8cd3748
09/21/97 17:44:14 |
Joel Sherrill |
Removed duplicate listing of install in MTARGETS.
Add monitor test.
4.104.114.84.95
@5beb562
09/21/97 16:58:57 |
Joel Sherrill |
Cleaned up as part of adding the Monitor test.
4.104.114.84.95
@f37e656d
09/21/97 16:57:46 |
Joel Sherrill |
Added Monitor test.
4.104.114.84.95
@8f367d6b
09/19/97 18:31:05 |
Joel Sherrill |
Bug fix from Eric Norum:
After weeks of trying to figure why my …
4.104.114.84.95
@6b4ca31
09/18/97 16:01:52 |
Joel Sherrill |
Merged changes from Eric Norum:
Enable 68360 watchdog. The …
4.104.114.84.95
@a72e3dd
09/16/97 13:08:58 |
Joel Sherrill |
updated
4.104.114.84.95
@fc4675f0
09/15/97 19:01:33 |
Joel Sherrill |
syslog added
4.104.114.84.95
@8f35817
09/15/97 18:52:26 |
Joel Sherrill |
eliminated potential for overfilling buffer on read
4.104.114.84.95
@8d05346
09/03/97 22:05:51 |
Joel Sherrill |
Fix from Eric Norum. Here is the comment:
Enable SDMA …
4.104.114.84.95
@cf5ef6d
09/03/97 15:36:05 |
Joel Sherrill |
More specific information on error code.
4.104.114.84.95
@ad9250cf
08/28/97 22:23:10 |
Joel Sherrill |
Fixed IO Manager calls to remove an argument which was used in 3.2.1 …
4.104.114.84.95
@e9932367
08/28/97 21:54:59 |
Joel Sherrill |
Switched to new style which does not require hackspecs.awk.
4.104.114.84.95
@de5e24f
08/28/97 21:52:27 |
Joel Sherrill |
Removed hackspecs.awk in move from -mrtems to -qrtems.
4.104.114.84.95
@7d352a49
08/28/97 13:59:41 |
Joel Sherrill |
Added RTEMS_IO_ERROR status code.
4.104.114.84.95
@b47be20
08/28/97 13:57:29 |
Joel Sherrill |
Added IO_Error status code and fixed No_Memory error number.
4.104.114.84.95
@d1b60f0
08/27/97 20:34:23 |
Joel Sherrill |
Corrected reference to LIBC_LIBM to work on all targets.
4.104.114.84.95
@3473f605
08/27/97 20:33:49 |
Joel Sherrill |
Added error numbers and changed default error code from 0 to -1 for …
4.104.114.84.95
@f80faeb
08/27/97 20:33:11 |
Joel Sherrill |
Modified to support the BSP family concept.
4.104.114.84.95
@49c2f589
08/27/97 20:31:34 |
Joel Sherrill |
Modified to have correct address for vector table on multiple models.
4.104.114.84.95
@2a1a547
08/27/97 20:29:26 |
Joel Sherrill |
Added rule so TARGET_VARIANTS are dependent on the environment stuff.
4.104.114.84.95
@39ffc7d
08/26/97 19:25:20 |
Joel Sherrill |
Use own pdir option was reversed.
4.104.114.84.95
@2d60095
08/26/97 19:24:22 |
Joel Sherrill |
Patches from Chris Johns to clean up test.
4.104.114.84.95
@588a2382
08/26/97 19:19:21 |
Joel Sherrill |
removed -lm
4.104.114.84.95
@12a17af3
08/26/97 18:10:59 |
Joel Sherrill |
Corrected to compile with egcs.
4.104.114.84.95
@5316519
08/26/97 18:09:16 |
Joel Sherrill |
Added support for TARGET_VARIANTS.
4.104.114.84.95
@e63e254e
08/22/97 19:19:07 |
Joel Sherrill |
Corrected bug per Katsutoshi Shibuya's report:
The definition of …
4.104.114.84.95
@b57992a
08/22/97 19:17:54 |
Joel Sherrill |
Removed assert condition when not initialized or there are 0 periods.
4.104.114.84.95
@b1459dc
08/22/97 19:17:09 |
Joel Sherrill |
Moved reentrant wrappers into their own file.
4.104.114.84.95
@78d87bd
08/22/97 19:16:47 |
Joel Sherrill |
Fixed iop/memory leak bug reported by Dan Dickey.
4.104.114.84.95
@8affd6f1
08/22/97 19:16:22 |
Joel Sherrill |
Removed redundant stanza.
4.104.114.84.95
@9b1f5678
08/22/97 19:11:02 |
Joel Sherrill |
Fixed infinite recursion bug in PTHREAD_MUTEX_INITIALIZER.
4.104.114.84.95
@799a5b9
08/22/97 19:10:44 |
Joel Sherrill |
Added commit about missing support for condition initializer.
4.104.114.84.95
@2d997375
08/22/97 13:08:56 |
Joel Sherrill |
start no longer a global symbol per Eric Norum's request.
Also, I …
4.104.114.84.95
@5b9ec351
08/15/97 16:40:21 |
Joel Sherrill |
Added command line options for next, previous, and up node.
Added …
4.104.114.84.95
@d074e12
08/04/97 22:22:59 |
Joel Sherrill |
Switched to new version of mc68681.h
4.104.114.84.95
@19fd334
08/04/97 22:22:31 |
Joel Sherrill |
moved mc68230.h from main include directory to motorola
4.104.114.84.95
@0789abef
08/04/97 22:17:17 |
Joel Sherrill |
new implementation of mc68681.h
4.104.114.84.95
@89a32784
08/04/97 22:12:39 |
Joel Sherrill |
Fixed type
4.104.114.84.95
@3dd8372
08/04/97 22:03:03 |
Joel Sherrill |
Corrected typo
4.104.114.84.95
@a397c9c1
08/04/97 21:59:14 |
Joel Sherrill |
Corrected descent to a hardcoded directory and made it dependent on …
4.104.114.84.95
@8bc9051
08/04/97 21:58:30 |
Joel Sherrill |
Fixed typo and removed duplicated code
4.104.114.84.95
@4ef9e99
08/04/97 21:58:00 |
Joel Sherrill |
First attempt at values for PPC
4.104.114.84.95
@50b5f9d
08/04/97 21:57:06 |
Joel Sherrill |
Trying to support all models
4.104.114.84.95
@c74169bd
08/04/97 21:56:48 |
Joel Sherrill |
Trying to support all models.
4.104.114.84.95
@c9647b3
08/04/97 21:56:00 |
Joel Sherrill |
consolex built for all models.
4.104.114.84.95
@81d96577
08/04/97 21:55:30 |
Joel Sherrill |
moved header files into the motorola and zilog subdirectories
4.104.114.84.95
@669123e1
08/04/97 21:53:42 |
Joel Sherrill |
Correcting difference between mvme162lx and mvme162. All versions …
4.104.114.84.95
@02d0880
08/04/97 21:50:35 |
Joel Sherrill |
4.104.114.84.95
@033ec54
08/04/97 21:49:47 |
Joel Sherrill |
Modified to reflect changes in mc68681.h header file.
4.104.114.84.95
@b739617
08/04/97 21:45:27 |
Joel Sherrill |
Header files moved into zilog subdirectory.
4.104.114.84.95
@9b024884
08/04/97 21:44:05 |
Joel Sherrill |
Moved files into the zilog and motorola subdirectories.
4.104.114.84.95
@b61e6e1
08/04/97 21:43:36 |
Joel Sherrill |
Added GNAT configuration parameters.
4.104.114.84.95
@7510f18c
08/04/97 21:42:22 |
Joel Sherrill |
Added include/motorola and include/zilog directories to the
install …
4.104.114.84.95
@c46732c
08/04/97 21:41:38 |
Joel Sherrill |
Added ppc-rtems as alternative name.
Moved files around in list of …
4.104.114.84.95
@28a4b1d
08/04/97 21:39:07 |
Joel Sherrill |
moved from main include directory
4.104.114.84.95
@1f552a0
08/04/97 20:06:33 |
Joel Sherrill |
Fixed wildcard in copy command.
4.104.114.84.95
@0e5dd428
08/04/97 20:06:16 |
Joel Sherrill |
Added comments to help avoid editting generated file.
4.104.114.84.95
@1ca951ce
08/04/97 20:05:48 |
Joel Sherrill |
Added information based on comments from Katsu Shibuya.
4.104.114.84.95
@6059e111
08/04/97 20:04:43 |
Joel Sherrill |
Fixed node links.
4.104.114.84.95
@6943b0e
08/04/97 20:04:25 |
Joel Sherrill |
removed binary files
4.104.114.84.95
@b2fed481
08/02/97 17:55:09 |
Joel Sherrill |
Added these files to contain bodies for routines included in the API …
4.104.114.84.95
@30e3029
08/01/97 20:58:10 |
Joel Sherrill |
Added conditional for KA9Q.
4.104.114.84.95
@1f581ec
08/01/97 20:57:21 |
Joel Sherrill |
Added include of termios.h which was accidentally left out.
4.104.114.84.95
@bcbd75d4
08/01/97 20:56:36 |
Joel Sherrill |
Added consolex to wrapup
4.104.114.84.95
@a7fcfd0
08/01/97 20:56:24 |
Joel Sherrill |
Corrected typo.
4.104.114.84.95
@978a9ba0
08/01/97 20:22:57 |
Joel Sherrill |
Added --enable-gmake-print-directory option and ods68302 bsp.
4.104.114.84.95
@3f70e3c
08/01/97 20:22:29 |
Joel Sherrill |
Corrected typo where "+ " was pasted in from another window.
Added …
4.104.114.84.95
